CC0603KRX7R7BB824
CC0603KRX7R7BB824
    YAGEO(国巨)
    贴片电容(MLCC) 0603
CC0603KRX7R7BB824 数据手册
DATA SHEET SURFACE-MOUNT CERAMIC MULTILAYER CAPACITORS C-Array NP0/X7R/Y5V 16 V TO 50 V sizes 0508 (4 x 0402) / 0612 (4 x 0603) Product Specification – Feb 05, 2010 V.1 RoHS compliant & Halogen Free Product specification Surface-Mount Ceramic Multilayer Capacitors SCOPE This specification describes NP0/X7R/Y5V 4-capacitor Array with lead-free terminations. APPLICATIONS Professional electronics High density consumer electronics NP0/X7R/Y5V 16 V to 50 V 2 17 ORDERING INFORMATION - GLOBAL PART NUMBER, PHYCOMP CTC & 12NC All part numbers are identified by the series, size, tolerance, TC material, packing style, voltage, process code, termination and capacitance value. Please note that 12 digits ordering code will expire at the end of 2010. YAGEO BRAND ordering code GLOBAL PART NUMBER (PREFERRED ) CA XXXX X X XXX X (1) FEATURES Supplied in tape on reel Nickel-barrier end termination 0508 (4x0402) / 0612 (4x0603) capacitors (of the same capacitance value) per array Less than 50% board space of an equivalent discrete component High volumetric efficiency Increased throughout, by time saved in mounting RoHS compliant Halogen Free compliant 4C-Array (2) (3) (4) (5) B X XXX (6) (7) (1) SIZE – INCH BASED (METRIC) 0508 (1220) 0612 (1632) (2) TOLERANCE J = ±5% K = ±10% M = ±20% Z = -20% to +80% (3) PACKING STYLE R = Paper/PE taping reel; Reel 7 inch (4) TC MATERIAL NPO X7R Y5V (5) RATED VOLTAGE 7 = 16 V 8 = 25 V 9 = 50 V (6) PROCESS N = NP0 B = X7R / Y5V (7) CAPACITANCE VALUE 2 significant digits+number of zeros The 3rd digit signifies the multiplying factor, and letter R is decimal point Example: 121 = 12 x 101 = 120 pF www.yageo.com Feb 05, 2010 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors 4C-Array 3 17 16 V to 50 V NP0/X7R/Y5V PHYCOMP BRAND ordering codes GLOBAL PART NUMBER (preferred), PHYCOMP CTC (for North America) and 12NC (traditional) codes are acceptable to order Phycomp brand products. GLOBAL PART NUMBER ( PREFERRED ) For detailed information of GLOBAL PART NUMBER and ordering example, please refer to page 2. 12NC CODE 2 2 XX XX X X X X XX Capacitance value(1) Carrier type 55 = Paper/PE Tolerance 5 = ±5% 6 = ±10% 7 = ±20% 8 = -20% to +80% Voltage 10 = 16 V 12 = 25 V 14 = 50 V Size 7 = 0508 (4 x 0402) 6 = 0612 (4 x 0603) YNM0030 Temperature characteristic 1 = NP0 5 = X7R 9 = Y5V Packaging(2) 1 = reel: ∅180 mm; 7" (1) Refer to “Conversion table of capacitance & last 2-digit of 12NC” (2) Quantity on reel depends on thickness classification; see table 5 PHYCOMP CTC CODE ( FOR NORTH AMERICA ) Example: 0508CG220K9B200 0508 CG 220 K Size code Temp. Char. Capacitance in pF Tolerance 0508 CG = NP0 101 = 100 pF; (4 x 0402) 2R = X7R the third digit signifies the 2F = Y5V 0612 multiplying factor: (4 x 0603) 0=×1 9 B Voltage Termination J = ±5% 7 = 16 V B = NiSn K = ±10% 8 = 25 V M = ±20% 9 = 50 V 2 0 0 Packing Marking Range identifier 2 = 180 mm 0 = no marking 0 = conv. Ceramic 7” Paper/PE D = Class 2 MLCC Z = -20% to +80% 1 = × 10 2 = × 100 3 = × 1,000 www.yageo.com Feb 05, 2010 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors 4C-Array 16 V to 50 V NP0/X7R/Y5V 4 17 CONSTRUCTION The capacitor consists of a rectangular block of ceramic dielectric in which a number of interleaved metal electrodes are contained. This structure gives rise to a high capacitance per unit volume. The inner electrodes are connected to the two end terminations and finally covered with a layer of plated tin (NiSn). The terminations are lead-free. An outline of the structure is shown in Fig.1. CCA833 Fig. 1 Simplified outline DIMENSIONS OUTLINES Table 1 TYPE 0508 (4 X 0402) 0612 (4 X 0603) L (mm) 2.0 ±0.15 3.2 ±0.15 W (mm) 1.25 ±0.15 1.60 ±0.15 Tmin. (mm) 0.50 0.70 Tmax. (mm) 0.70 0.90 A (mm) 0.28 ±0.10 0.4 ±0.10 B (mm) 0.2 ±0.10 0.3 ±0.20 P (mm) 0.5 ±0.10 0.8 ±0.10 For dimensions see Table 1 L W B P A T HBK092 Fig. 2 Surface mounted multilayer ceramic capacitor dimension www.yageo.com Feb 05, 2010 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors 4C-Array NP0/X7R/Y5V 16 V to 50 V 5 17 CAPACITANCE RANGE & THICKNESS FOR 4C-ARRAY Table 2 Temperature characteristic material from NP0 CAPACITANCE Last 2-digit of 12NC 10 pF 23 15 pF 25 18 pF 26 22 pF 27 33 pF 29 39 pF 31 47 pF 32 56 pF 33 68 pF 34 82 pF 35 100 pF 36 120 pF 37 150 pF 38 180 pF 39 220 pF 41 270 pF 42 330 pF 43 390 pF 44 470 pF 45 560 pF 46 680 pF 47 820 pF 48 1.0 nF 49 0508 (4 x 0402) 0612 (4 x 0603) 50 V 50 V 0.6±0.1 0.8±0.1 NOTE Values in shaded cells indicate thickness class in mm www.yageo.com Feb 05, 2010 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors 4C-Array NP0/X7R/Y5V 16 V to 50 V 6 17 CAPACITANCE RANGE & THICKNESS FOR 4C-ARRAY Table 3 Temperature characteristic material from X7R CAPACITANCE Last 2-digit of 0508 (4 x 0402) 0612 (4 x 0603) 16 V 16 V 12NC 180 pF 13 220 pF 14 270 pF 15 330 pF 16 390 pF 17 470 pF 18 560 pF 19 680 pF 21 820 pF 22 1.0 nF 23 1.2 nF 24 1.5 nF 25 1.8 nF 26 2.2 nF 27 2.7 nF 28 3.3 nF 29 3.9 nF 31 4.7 nF 32 5.6 nF 33 6.8 nF 34 8.2 nF 35 10 nF 36 12 nF 37 15 nF 38 18 nF 39 22 nF 41 27 nF 42 33 nF 43 47 nF 45 56 nF 46 68 nF 47 82 nF 48 100 nF 49 25 V 50 V 0.8±0.1 0.8±0.1 0.6±0.1 0.8±0.1 NOTE Values in shaded cells indicate thickness class in mm www.yageo.com Feb 05, 2010 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors 4C-Array NP0/X7R/Y5V 16 V to 50 V 7 17 CAPACITANCE RANGE & THICKNESS FOR 4C-ARRAY Table 4 Temperature characteristic material from Y5V 0612 (4 x 0603) CAPACITANCE Last 2-digit of 12NC 10 nF 36 22 nF 41 47 nF 45 100 nF 49 25 V 0.6±0.1 NOTE Values in shaded cells indicate thickness class in mm THICKNESS CLASSES AND PACKING QUANTITY Table 5 THICKNESS TAPE WIDTH QUANTITY Ø180 MM / 7 INCH CLASSIFICATION PER REEL Paper 0508 0.6 ±0.1 mm 8 mm 4,000 0612 0.8 ±0.1 mm 8 mm 4,000 SIZE CODE www.yageo.com Feb 05, 2010 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors 4C-Array NP0/X7R/Y5V 16 V to 50 V 8 17 ELECTRICAL CHARACTERISTICS 4C-ARRAY DIELECTRIC CAPACITORS; NISN TERMINATIONS Unless otherwise stated all electrical values apply at an ambient temperature of 20±1 °C, an atmospheric pressure of 86 to 106 kPa, and a relative humidity of 63 to 67%. Table 6 VALUE DESCRIPTION Capacitance range 10 pF to 100 nF Rated voltage NP0 50 V X7R 0508: 16 V, 0612: 16 V to 50 V Y5V 0612: 25 V NP0 ±5%, ±10% X7R ±10%, ±20% Y5V –20% to +80% NP0 ≤ 0.1% X7R 16 V ≤ 3.5%, 25V ≤ 2.5%, 50V ≤ 2.5% Y5V 0508 ≤ 9%, 0612 ≤ 7% Capacitance tolerance Dissipation factor (D.F.) Insulation resistance after 1 minute at Ur (DC) Rins ≥ 10 GΩ or Rins × Cr ≥ 500 seconds whichever is less Maximum capacitance change as a function of temperature (temperature characteristic/coefficient): NP0 ±30 ppm/°C X7R ±15% Y5V +22% to –82% NP0 –55 °C to +125 °C X7R –55 °C to +125 °C Y5V –30 °C to +85 °C Operating temperature range: www.yageo.com Feb 05, 2010 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors 4C-Array 16 V to 50 V NP0/X7R/Y5V 9 17 NP0 0508/0612 50 V Sample limits (broken lines) Requirement levels (dotted lines) MEA607 MEA608 10 tan δ (x 10 4) 40 TC (x10 6/K) 7.5 20 5 0 20 2.5 40 0 40 Fig. 3 0 40 80 120 o T ( C) Typical temperature coefficient as a function of temperature Fig. 4 40 0 40 80 120 T ( oC) Typical tan δ as a function of temperature MEA614 15 ΔC C (%) 10 5 0 –5 – 10 – 15 0 Fig. 5 10 20 30 40 50 V DC (V) Typical capacitance change with respect to the capacitance at 1 V as a function of DC voltage www.yageo.com Feb 05, 2010 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors 4C-Array NP0/X7R/Y5V 16 V to 50 V 10 17 X7R 0508 16 V CCB966 0 CCB965 600 ΔC C (%) tan δ (× 10−4) −20 400 −40 200 −60 −80 Fig. 6 ΔC C (%) 0 20 40 0 100 80 VDC (V) 60 Typical capacitance change with respect to the capacitance at 1 V as a function of DC voltage at 20 °C Fig. 7 −40 0 40 80 120 T (°C) Typical tan δ as a function of temperature YNM0013 15 10 5 0 −5 −10 −15 −55 Fig. 8 −25 5 40 65 95 125 T (oC) Typical capacitance change as a function of temperature www.yageo.com Feb 05, 2010 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors 4C-Array 16 V to 50 V NP0/X7R/Y5V 11 17 X7R 0612 16 V to 50 V Curve 1 = 16 V product Curve 2 = 25 V product Curve 3 = 50 V product Curve 1 = 16 V product Curve 2 = 25 V product Curve 3 = 50 V product CCB558 0 CCB559 600 handbook, halfpage handbook, halfpage ΔC C (%) tan δ (× 10−4) 1 −20 400 1 2 2 3 3 −40 −60 200 0 Fig. 9 ΔC C (%) 20 40 VDC (V) 60 Typical capacitance change with respect to the capacitance at 1 V as a function of DC voltage at 25 °C 0 −60 −20 20 60 100 140 T (°C) Fig. 10 Typical tan δ as a function of temperature YNM0013 15 10 5 0 −5 −10 −15 −55 −25 5 40 65 95 125 T (oC) Fig. 11 Typical capacitance change as a function of temperature www.yageo.com Feb 05, 2010 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors 4C-Array NP0/X7R/Y5V 16 V to 50 V 12 17 Y5V 0612 25 V CCB401 0 C C (%) −20 tan δ (× 10−4) 4000 −40 3000 −60 2000 −80 1000 −100 0 10 20 30 40 50 VDC (V) Fig. 12 Typical capacitance change with respect to the capacitance at 1 V as a function of DC voltage at 25 °C 0 −40 −20 0 20 40 60 80 100 T (°C) Fig. 13 Typical tan δ as a function of temperature CCB403 40 C C (%) CCB402 5000 20 0 −20 −40 −60 −80 −40 −20 0 20 40 60 80 100 T (°C) Fig. 14 Typical capacitance change as a function of temperature www.yageo.com Feb 05, 2010 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors 4C-Array NP0/X7R/Y5V 16 V to 50 V 13 17 TESTS AND REQUIREMENTS Table 7 Test procedures and requirements TEST TEST METHOD PROCEDURE REQUIREMENTS Mounting IEC 6038421/22 4.3 The capacitors may be mounted on printed-circuit boards or ceramic substrates No visible damage Visual inspection and dimension check 4.4 Any applicable method using × 10 magnification In accordance with specification Capacitance 4.5.1 Class 1: f = 1 MHz for C ≤ 1 nF, measuring at voltage 1 Vrms at 20 °C Within specified tolerance f = 1 KHz for C > 1 nF, measuring at voltage 1 Vrms at 20 °C Class 2: f = 1 KHz for C ≤ 10 µF, measuring at voltage 1 Vrms at 20 °C f = 120 Hz for C >10 µF, measuring at voltage 0.5 Vrms at 20 °C Dissipation factor (D.F.) 4.5.2 Class 1: f = 1 MHz for C ≤ 1 nF , measuring at voltage 1 Vrms at 20 °C In accordance with specification f = 1 KHz for C > 1 nF, measuring at voltage 1 Vrms at 20 °C Class 2: f = 1 KHz for C ≤ 10 µF, measuring at voltage 1 Vrms at 20 °C f = 120 Hz for C > 10 µF, measuring at voltage 0.5 Vrms at 20 °C Insulation resistance 4.5.3 At Ur (DC) for 1 minute In accordance with specification Temperature coefficient 4.6 Class 1: Between minimum and maximum temperature NP0: -55 °C to +125 °C Normal Temperature: 20 °C Class 2: Between minimum and maximum temperature X5R: -55 °C to +85 °C X7R: -55 °C to +125 °C Y5V: -30 °C to +85 °C Normal Temperature: 20 °C Class 2: X5R/X7R: ±15% Y5V: 22% to -82% A force applied for 10 seconds to the line joining the terminations and in a plane parallel to the substrate Force size ≥ 0603: 5N size = 0402: 2.5N size = 0201: 1N Temperature characteristic Adhesion 4.7 ΔC/C: Class 1: NP0: ±30 ppm/°C Class 2: X5R/X7R: ±15% Y5V: 22% to - 82% www.yageo.com Feb 05, 2010 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors 4C-Array NP0/X7R/Y5V 16 V to 50 V TEST TEST METHOD PROCEDURE REQUIREMENTS Bond strength of plating on end face IEC 6038421/22 Mounting in accordance with IEC 60384-22 paragraph 4.3 No visible damage Conditions: bending 1 mm at a rate of 1 mm/s, radius jig 340 mm 4.8 14 17 ∆C/C Class 1: NP0: within ±1% or 0.5 pF, whichever is greater Class2: X5R/X7R/Y5V: ±10% ∆C/C Class2: X5R/X7R/Y5V: ±10% Resistance to soldering heat 4.9 Precondition: 150 +0/–10 °C for 1 hour, then keep for 24 ±1 hours at room temperature Preheating: for size ≤ 1206: 120 °C to 150 °C for 1 minute Preheating: for size >1206: 100 °C to 120 °C for 1 minute and 170 °C to 200 °C for 1 minute Solder bath temperature: 260 ±5 °C Dipping time: 10 ±0.5 seconds Recovery time: 24 ±2 hours Dissolution of the end face plating shall not exceed 25% of the length of the edge concerned ∆C/C Class 1: NP0: within ±0.5% or 0.5 pF, whichever is greater Class2: X5R/X7R: ±10% Y5V: ±20% ∆C/C Class2: X5R/X7R: ±10% Y5V: ±20% D.F. within initial specified value Rins within initial specified value Solderability 4.10 Preheated the temperature of 80 °C to 140 °C and maintained for 30 seconds to 60 seconds. The solder should cover over 95% of the critical area of each termination Test conditions for lead containing solder alloy Temperature: 235 ±5 °C Dipping time: 2 ±0.2 seconds Depth of immersion: 10 mm Alloy Composition: 60/40 Sn/Pb Number of immersions: 1 Test conditions for leadfree containing solder alloy Temperature: 245 ±5 °C Dipping time: 3 ±0.3 seconds Depth of immersion: 10 mm Alloy Composition: SAC305 Number of immersions: 1 www.yageo.com Feb 05, 2010 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors 4C-Array NP0/X7R/Y5V TEST TEST METHOD PROCEDURE REQUIREMENTS Rapid change of temperature IEC 6038421/22 Preconditioning; 150 +0/–10 °C for 1 hour, then keep for 24 ±1 hours at room temperature No visual damage 4.11 16 V to 50 V 15 17 ∆C/C 5 cycles with following detail: 30 minutes at lower category temperature 30 minutes at upper category temperature Recovery time 24 ±2 hours Class 1: NP0: within ±1% or 1 pF, whichever is greater Class2: X5R/X7R: ±15% Y5V: ±20% ∆C/C Class2: X5R/X7R: ±15% Y5V: ±20% D.F. meet initial specified value Rins meet initial specified value Damp heat with Ur load 4.13 1. Preconditioning, class 2 only: 150 +0/-10 °C /1 hour, then keep for 24 ±1 hour at room temp 2. Initial measure: Spec: refer initial spec C, D, IR 3. Damp heat test: 500 ±12 hours at 40 ±2 °C; 90 to 95% R.H. 1.0 Ur applied 4. Recovery: Class 1: 6 to 24 hours Class 2: 24 ±2 hours 5. Final measure: C, D, IR P.S. If the capacitance value is less than the minimum value permitted, then after the other measurements have been made the capacitor shall be precondition according to “IEC 60384 4.1” and then the requirement shall be met. No visual damage after recovery ∆C/C Class 1: NP0: within ±2% or 1 pF, whichever is greater Class2: X5R/X7R: ±15%; Y5V: ±30% D.F. Class 1: NP0: ≤ 2 x specified value Class2: X5R/X7R: ≤ 16V: ≤ 7% ≥ 25V: ≤ 5% Y5V: ≤ 15% Rins Class 1: NP0: ≥ 2,500 MΩ or Rins x Cr ≥ 25s whichever is less Class2: X5R/X7R/Y5V: ≥ 500 MΩ or Rins x Cr ≥ 25s whichever is less ∆C/C Class2: X5R/X7R: ±20%; Y5V: ±30% D.F. Class2: 2 x initial value max Rins Class2: 500 MΩ or Rins x Cr ≥ 25s, whichever is less www.yageo.com Feb 05, 2010 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors 4C-Array NP0/X7R/Y5V TEST TEST METHOD PROCEDURE REQUIREMENTS Endurance IEC 6038421/22 1. Preconditioning, class 2 only: No visual damage 4.14 150 +0/-10 °C /1 hour, then keep for 24 ±1 hour at room temp 2. Initial measure: Spec: refer initial spec C, D, IR 3. Endurance test: Temperature: NP0/X7R: 125 °C X5R/Y5V: 85 °C Specified stress voltage applied for 1,000 hours: Applied 2.0 x Ur for general product. Applied 1.5 x Ur for high cap. product. High voltage series follows with below stress condition: Applied 1.3 x Ur for 500V series Applied 1.2 x Ur for 1KV, 2KV, 3KV series 4. Recovery time: 24 ±2 hours 5. Final measure: C, D, IR P.S. If the capacitance value is less than the minimum value permitted, then after the other measurements have been made the capacitor shall be precondition according to “IEC 60384 4.1” and then the requirement shall be met. 16 V to 50 V 16 17 ∆C/C Class1: NP0: within ±2% or 1 pF, whichever is greater Class2: X5R/X7R: ±15%; Y5V: ±30% D.F. Class1: NP0: ≤ 2 x specified value Class2: X5R/X7R: ≤ 16V: ≤ 7% ≥ 25V: ≤ 5% Y5V: ≤ 15% Rins Class1: NP0: ≥ 4,000 MΩ or Rins x Cr ≥ 40s whichever is less Class2: X5R/X7R/Y5V: ≥ 1,000 MΩ or Rins x Cr ≥ 50s whichever is less ∆C/C Class 2: X5R/X7R: ±20%; Y5V: ±30% D.F. Class 2: 2 x initial value max Rins Class 2: 1,000 MΩ or Rins x Cr ≥ 50s, whichever is less Voltage proof IEC 60384-1 4.6 Specified stress voltage applied for 1 minute Ur ≤ 100 V: series applied 2.5 Ur 100 V < Ur ≤ 200 V series applied (1.5 Ur + 100) 200 V < Ur ≤ 500 V series applied (1.3 Ur + 100) Ur > 500 V: 1.3 Ur I: 7.5 mA No breakdown or flashover www.yageo.com Feb 05, 2010 V.1 Product specification Surface-Mount Ceramic Multilayer Capacitors 4C-Array NP0/X7R/Y5V 16 V to 50 V 17 17 REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 1 Feb 05, 2010 - - The statement of "Halogen Free" on the cover added Version 0 Jun 22, 2009 - - New datasheet for 4C-Array series with RoHS compliant - Replace from pdf files: 0508_16V to 50V_1, 0612_16V to 50V_0, C-Array_NP0_50V_0508_7, C-Array_NP0_50V_0612_7, C-Array_X7R_16V_25V_50V_0612_6, C-Array_X7R_16V_0508_5, C-Array_Y5V_25V_0508_0, C-Array_Y5V_25V_0612_5 - Define global part number - Description of "Halogen Free compliant" added - Test method and procedure updated www.yageo.com Feb 05, 2010 V.1
CC0603KRX7R7BB824 价格&库存
很抱歉,暂时无法提供与“CC0603KRX7R7BB824”相匹配的价格&库存,您可以联系我们找货
CC0603KRX7R7BB824
  • 4000+0.179284000+0.02243
  • 8000+0.155688000+0.01948
  • 12000+0.1547712000+0.01936
  • 20000+0.1489320000+0.01863
  • 28000+0.1301728000+0.01628
  • 40000+0.1296340000+0.01622
  • 48000+0.1293748000+0.01619
  • 96000+0.1284796000+0.01607
  • 100000+0.12843100000+0.01607
库存:7185
CC0603KRX7R7BB824
  • 1+0.966801+0.12093
  • 10+0.5535210+0.06924
  • 50+0.3848150+0.04813
  • 100+0.33296100+0.04165
  • 500+0.24583500+0.03075
  • 1000+0.219121000+0.02741
库存:7185
CC0603KRX7R7BB824
    • 1+0.19870
    • 100+0.11190
    • 1000+0.07220
    • 2000+0.04850
    • 4000+0.03560
    库存:5872
