APPLICABLE STANDARD
OPERATING
TEMPERATURE RANGE
Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents.
RATING
STORAGE
TEMPERATURE RANGE
APPLICABLE
CONNECTOR
-35 C TO +85 C(NOTES 1)
250
VOLTAGE
V
AC
AWG20 TO 24: 3A
AWG26: 2A
AWG28: 1A
AWG30: 0.5A
CURRENT
-10 C TO +60 C(NOTE2)
DF1E-*S-2.5C
VOLTAGE
AC 30V
AWG20 TO 22:
3A
AWG24 TO 28:
1A
AWG30: 0.5A
UL,CSA
CURRENT
SPECIFICATIONS
ITEM
TEST METHOD
REQUIREMENTS
QT
AT
X
X
X
X
X
X
X
X
X
X
X
X
NO DEFORMATION OF CASE OF EXCESSIVE
LOOSENESS OF THE TERMINALS.
X
SOLDER SHALL COVER A MINIMUM OF
95 OF THE SURFACE BEING IMMERSED.
X
CONSTRUCTION
GENERAL EXAMINATION VISUALLY AND BY MEASURING INSTRUMENT.
MARKING
ACCORDING TO DRAWING.
CONFIRMED VISUALLY.
ELECTRIC CHARACTERISTICS
CONTACT RESISTANCE 20 mV MAX, 1 mA(DC OR
MILLIVOLT LEVEL
METHOD.
INSULATION
500 V DC.
RESISTANCE
VOLTAGE PROOF
650 V AC FOR 1 min.
1000 Hz).
30 m MAX.
1000
M MIN.
NO FLASHOVER OR BREAKDOWN.
MECHANICAL CHARACTERISTICS
① CONTACT RESISTANCE: 30 m MAX.
② NO DAMAGE, CRACK OR LOOSENESS OF
PARTS.
MECHANICAL
OPERATION
30 TIMES INSERTIONS AND EXTRACTIONS.
VIBRATION
① NO ELECTRICAL DISCONTINUITY OF 1 s.
FREQUENCY 10 TO 55 Hz, SINGLE AMPLITUDE
0.75 mm, AT 2 h, FOR 3 DIRECTIONS.
2
PARTS.
490 m/s DURATION OF PULSE 11 ms AT 3 TIMES
FOR 3 DIRECTIONS.
SHOCK
ENVIRONMENTAL CHARACTERISTICS
RAPID CHANGE OF
TEMPERATURE
TEMPERATURE -55→ 5 TO 35→+85→ 5 TO 35 C ① CONTACT RESISTANCE: 30 m MAX.
TIME
30→ 5 MAX→ 30→ 5 MAX min ② INSULATION RESISTANCE: 1000 M MIN.
③ NO DAMAGE, CRACK OR LOOSENESS OF
UNDER 5 CYCLES.
DAMP HEAT
(STEADY STATE)
EXPOSED AT 40 ± 2 C, 90 TO 95 , 96 h.
RESISTANCE TO
SOLDERING HEAT
1) AUTOMATIC SOLDERING (FLOW)
SOLDER TEMPERATURE,
260 ℃
FOR
IMMERSION,DURATION, 10 sec.
2) MANUAL SOLDERING
SOLDERING IRON TEMPERATURE : 300 ℃,
SOLDERING TIME : 3 sec.
NO STRENGTH ON CONTACT.
SOLDERED AT SOLDER TEMPERATURE,
235 C FOR IMMERSING DURATION, 5 s.
PARTS.
SOLDERABILITY
COUNT
DESCRIPTION OF REVISIONS
② INSULATION RESISTANCE: 500 M MIN.
PARTS.
DESIGNED
CHECKED
DATE
REMARKS
TO
NOTE1: INCLUDE THE TEMPERATURE RISING BY CURRENT.
NOTE2:NO CONDENSING.
NOTE3:APPLY TO THE CONDITION OF LONG TERM STORAGE FOR UNUSED PRODUCTS
BEFORE PCB ON BOARD,AFTER PCB BOARD,OPERATING TEMPERATURE AND
HUMIDITY RANGE IS APPLIED FOR INTERIM STORAGE DURING TRANSPORTATION.
APPROVED
KI.AKIYAMA
15.05.23
CHECKED
TS.FUKUSHIMA
15.05.23
DESIGNED
TS.KUMAZAWA
15.05.23
DRAWN
MI.SAKIMURA
15.05.23
Unless otherwise specified, refer to IEC 60512.
Note
QT:Qualification Test
FORM HD0011-2-1
AT:Assurance Test X:Applicable Test
DRAWING NO.
SPECIFICATION SHEET
PART NO.
CODE NO.
ELC-161943-35-00
DF1EC-*P-2.5DSA(35)
CL541
DF1EC-8P-2.5DSA(35) 价格&库存
很抱歉,暂时无法提供与“DF1EC-8P-2.5DSA(35)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+6.65280
- 10+5.40000
- 30+4.77360
- 国内价格 香港价格
- 1+7.167971+0.93073
- 50+5.9443750+0.77185
- 100+5.15895100+0.66987
- 300+4.65463300+0.60438
- 500+4.55542500+0.59150
- 1000+4.464481000+0.57969
- 4000+4.414874000+0.57325
