CEST236LC5VU-M
CEST236LC5VU-M
    CREATEKMICRO(达晶微)
    CEST236LC5VU-M
CEST236LC5VU-M 数据手册
CEST236LC5VU CREATEK Microelectronics Low Capacitance ESD TVS Array in SOT23-6 Features ■ 80Watts peak pulse power (tp = 8/20μs) ■ SOT23-6 Package ■ Unidirectional configurations ■ Solid-state silicon-avalanche technology ■ Low clamping voltage ■ Low leakage current ■ Low capacitance (0.2pF typical I/O to I/O) 1 ■ ESD Protection for high-speed data lines to: IEC 61000-4-2 ±15KV contact ±15KV air IEC 61000-4-4 (EFT) 40A (5/50ns) IEC 61000-4-5 (Lightning) 6A (8/20μs) Mechanical Data Applications ■ Case: SOT23-6 (plastic package). Lead free; RoHS compliant ■ USB 3.0, USB 2.0, MHL ■ Molding Compound Flammability Rating: UL 94 V-0 ■ Unified Display Interface (UDI) ■ Terminals: High temperature soldering guaranteed: 260 °C/10 sec. at terminals ■ HDMI 2.0, Display Port 1.3, eSATA ■ Digital Visual Interface (DVI) ■ High speed serial interfaces Absolute Maximum Ratings Ratings at 25 °C, ambient temperature unless otherwise specified Parameter Symbol Value Unit Peak Pulse Power (TP=8/20μS) PPP 80 W ESD contact/air discharge (IEC-61000-4-2) kV VESD 15/15 Peak Pulse Current ( tP = 8/20μS ) IPP 6.0 A Junction Temperature TJ -55 to +125 ℃ Storage temperature TSTG -55 to +150 ℃ Electrical Characteristics (TA = 25 °C unless otherwise specified) Parameter Condition Min Typ Max 5 V VBR IT=1mA 6 6.8 8.5 V Reverse Leakage Current IR VR=5V 0.01 1 μA Clamping Voltage(SURGE) VC IPP=6A,TP=8/20μS 14 16 Trigger Voltage(ESD) VT Reverse stand-off Voltage Reverse Breakdown Voltage Clamping Voltage(ESD) Junction Capacitance Rev. 2.0, 28-Oct.-2016 Symbol VRWM VC VESD = +8kV 90 Unit V V CJ VESD = +8kV VR=0V,f=1MHz, I/O to I/O 15 0.2 0.4 V pF CJ VR=0V,f=1MHz, I/O to GND 0.4 0.8 pF www.crea-tek.com 1 CEST236LC5VU CREATEK Microelectronics Typical Characteristics (Tamb = 25 °C unless otherwise specified) Fig.1 Peak Pulse Power Rating Curve Fig.2 Pulse Derating Curve % of Rated Power (PPP) or IPP Peak Pulse Power –PPP(KW) 10 1 80W 0.1 0.01 0.1 1 10 100 110 100 1000 80 60 40 20 0 0 Pulse Duration tp (μs) 100 125 100%IPP , 8μS 150 100% 90% 30ns 80 50%IPP, 20μS -t e 60 Percent of IPP Percent of IPP 75 Fig.4 Pulse Waveform-ESD(IEC61000-4-2) 100 40 20 0 50 Ambient Temperature—TA(℃) Fig.3 Pulse Waveform-8/20μs 120 25 60ns 10% 0 5 10 15 20 25 30 tr 0.7 to 1ns 0 30 Time (μs) Fig.5 Eye Diagram - HDMI mask at 3.4Gbps per channel (with CESD2510LC5VU) 60 Time (ns) Fig.6 Insertion Loss S21 - I/O to GND 2 2.5GHz @ -1dB Horizontal: 50 ps/div Vertical: 200 mV/div Insertion Loss (dB) 0 -2 4GHz @ -3dB -4 -6 -8 -10 100k 1M 10M 100M 1G 10G Frequency (Hz) Rev. 2.0, 28-Oct.-2016 www.crea-tek.com 2 CEST236LC5VU CREATEK Microelectronics Package Dimensions Dimensions in millimeters Symbol Min A A1 A2 b c D E1 E e e1 L 1.050 0.000 1.050 0.300 0.100 2.820 1.500 2.650 0.950 (BSC) θ Max 1.250 0.100 1.150 0.500 0.200 3.020 1.700 2.950 1.800 0.300 2.000 0.600 0° 8° Part number system CES T236 LC 5V U Product series (ESD) Package (SOT23-6) Capacitance type (Low capacitance) Working voltage (5V) Directional (Unidirectional) Marking 05L or V5L Ordering information Order code Package Packaging option Base quantity Packaging specification CEST236LC5VU SOT23-6 Tape and reel 3000pcs / reel EIA STD RS-481 Revision history Date Revision 23-May-2012 1.0 Initial release 28-Oct.-2016 2.0 update marking Rev. 2.0, 28-Oct.-2016 Changes www.crea-tek.com 3 CEST236LC5VU CREATEK Microelectronics CAUTION / WARNING Information in this document is believed to be accurate and reliable. However, CREATEK does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Users should independently evaluate the suitability of and test each product selected for their own applications, and CREATEK assumes no liability whatsoever relating to the choice, selection or use of the CREATEK products and services described herein. CREATEK reserves the right to change or update, without notice, any information contained in this publication; to change, without notice, the design, construction, processing, or specification of any product; and to discontinue or limit production or distribution of any product. Information in this document supersedes and replaces all information previously supplied. Products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an CREATEK product can reasonably be expected to result in personal injury, death or severe property or environmental damage. CREATEK accepts no liability for inclusion and/or use of CREATEK products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Resale of CREATEK products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by CREATEK for the CREATEK product or service described herein and shall not create or extend in any manner whatsoever, any liability of CREATEK. CREATEK expressly disclaims all implied warranties regarding the information contained herein, including, but not limited to, any implied warranties of merchantability or fitness for a particular purpose. CREATEK only obligations are those in the CREATEK Standard Terms and Conditions of Sale and in no case will CREATEK be liable for any incidental, indirect, or consequential damages arising from the sale, resale, use, or misuse of its products. Specifications are subject to change without notice © Copyright 2009,CREATEK Microelectronics t ® is a registered trademark of CREATEK Microelectronics All rights reserved Rev. 2.0, 28-Oct.-2016 www.crea-tek.com 4
CEST236LC5VU-M 价格&库存
很抱歉,暂时无法提供与“CEST236LC5VU-M”相匹配的价格&库存,您可以联系我们找货
