825802B05300
825802B05300
    COMAIRROTRON
    825802B05300
825802B05300 数据手册
Board Level Heat Sinks P/N: 825802B05300 TO-220 PRODUCT SPECIFICATIONS FEATURES & BENEFITS • Multiple Holes for Device Attachment • Extended Area Folded Fins • Vertical Mounting via Solderable Tabs • RoHS Compliant CUSTOMIZED HEATSINKS • Specialized Tabs, Plating • Specialized Body Configurations • Contact Applications Engineering Air Velocity - LFM 0 200 400 600 800 1000 100 5 80 4 60 3 40 2 20 1 0 0 0 2 4 6 Heat Dissipated - Watts COMAIR ROTRON, INC 8929 Terman Court, San Diego, CA 92121 Ph (858) 348-6200 Fax (858) 566-4577 E-mail: sales@comairrotron.com, Web: www.comairrotron.com 8 10 Thermal Resistance - oC / Watt (Mounting Surface to Ambient) Devices: TO-220 Size: 24.1 x 48.3 x 49.5 mm Material: Aluminum, 1.2 mm Thick Type: Stamped PCB Mounting: Solderable Tabs Finish: Black Anodized Package: Bulk Optional Accessories: Mounting Hardware (screws or clips) & Thermal Interface Material Temp Rise Above Ambient -oC (Mounting Surface) • • • • • • • •
825802B05300 价格&库存
很抱歉,暂时无法提供与“825802B05300”相匹配的价格&库存,您可以联系我们找货
