RLD16P700GMF
RLD16P700GMF
    PTTC(聚鼎)
    插件
RLD16P700GMF 数据手册
RLD 16V GMF Series PTC Devices RLD 16V GMF Series PTC Devices Description The GMF series provides radial leaded resettable over-current protection with holding current from 2.5A to 20.0A. This series is suitable for wide range of applications in modern electronics and automotive industry. Features  RoHS compliant and lead-free  Low profile  Halogen-free  Fast response to fault current  Compact design saves board space Applications  Computer & peripherals  Medical equipments  USB hubs, ports and peripherals  Transformers  General electronics  Motors Agency Approval and Environmental Compliance Agency File Number Regulation Standard Pending 2011/65/EU Pending IEC 61249-2-21:2003 Electrical Characteristics Maximum Time To Trip Current Time (A) (Sec.) Ihold (A) Itrip (A) Vmax (Vdc) Imax (A) Pd typ (W) RLD16P250GMF 2.5 5.0 16 100 0.5 12.5 RLD16P300GMF 3.0 6.0 16 100 0.7 15.0 RLD16P400GMF 4.0 8.0 16 100 0.8 RLD16P500GMF 5.0 10.0 16 100 RLD16P600GMF 6.0 11.5 16 100 RLD16P700GMF 7.0 13.0 16 RLD16P800GMF 8.0 14.0 16 RLD16P900GMF 9.0 16.0 RLD16P1000GMF 10.0 17.0 RLD16P1100GMF 11.0 RLD16P1200GMF Part Number Agency Approval Resistance Rmin (Ω) R1max (Ω) 1.4 0.0180 0.0950 Pending Pending 1.5 0.0170 0.0900 Pending Pending 20.0 1.8 0.0090 0.0510 Pending Pending 1.0 25.0 2.3 0.0040 0.0180 Pending Pending 1.1 30.0 3.3 0.0030 0.0150 Pending Pending 100 1.2 35.0 3.5 0.0026 0.0130 Pending Pending 100 1.3 40.0 5.0 0.0025 0.0100 Pending Pending 16 100 1.4 45.0 5.5 0.0023 0.0080 Pending Pending 16 100 1.6 50.0 6.0 0.0022 0.0065 Pending Pending 18.0 16 100 1.8 55.0 7.0 0.0020 0.0055 Pending Pending 12.0 19.5 16 100 2.0 60.0 7.5 0.0014 0.0045 Pending Pending RLD16P1400GMF 14.0 21.0 16 100 2.2 70.0 9.0 0.0012 0.0035 Pending Pending RLD16P1500GMF 15.0 24.0 16 100 2.4 75.0 10.0 0.0009 0.0030 Pending Pending 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 2 of 14 2015/7/1 Revision: Preliminary RLD 16V GMF Series PTC Devices Part Number Ihold (A) Itrip (A) Vmax (Vdc) Imax (A) Pd typ (W) Maximum Time To Trip Current Time (A) (Sec.) (Continued) Agency Approval Resistance Rmin (Ω) R1max (Ω) RLD16P1750GMF 17.5 27.5 16 100 2.8 87.5 11.0 0.0006 0.0025 Pending Pending RLD16P2000GMF 20.0 30.0 16 100 3.0 100.0 12.0 0.0005 0.0020 Pending Pending Note on Electrical Characteristics  Vocabulary Ihold = Hold current: maximum current device will pass without tripping in 23ºC still air. Itrip = Trip current: minimum current at which the device will trip in 23 ºC still air. Vmax = Maximum voltage device can withstand without damage at rated current (I max) Imax = Maximum fault current device can withstand without damage at rated voltage (Vmax) Pd typ = Typical power dissipated from device when in the tripped state at 23 ºC still air. Rmin = Minimum resistance of device in initial (un-soldered) state. R1max = Maximum resistance of device at 23 ºC measured one hour after tripping or reflow soldering of 260 ºC for 20 sec.  Caution: Operation beyond the specified rating may result in damage and possible arcing and flame.  Specifications are subject to change without notice. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 3 of 14 2015/7/1 Revision: Preliminary RLD 16V GMF Series PTC Devices Polymeric PTC Selecting Guide  Determine the following operating parameters for the circuits:  Normal operating current (Ihold) ․ Maximum interrupt current (Imax)  Maximum circuit voltage (Vmax) ․ Normal operating temperature surrounding device (minºC/maxºC)  Select the device form factor and dimension suitable for the application:  Surface Mount Device (SMD) ․ Axial Leaded Device (ALD)  Radial Leaded Device (RLD) ․ DISC Device ․ Other Customized Form Factors  Compare the maximum rating for Vmax and Imax of the PPTC device with the circuit in application and make sure the circuit’s requirement does not exceed the device rating.  Check that PPTC device’s trip time (time-to-trip) will protect the circuit.  Verify that the circuit operating temperature is within the PPTC device’s normal operating temperature range.  Verify the performance and suitability of the chosen PPTC device in the application.  Mechanical Stress  PPTC devices will undergo a thermal expansion during fault condition. If PPTC devices are installed or placed in an application where the space between PPTC devices and the surrounding materials (e.g., covering materials, packaging materials, encapsulate materials and the like) is insufficient, it will cause an inhibiting effect upon the thermal expansion. Pressing, twisting, bending and other kinds of mechanical stress will also adversely affect the performance of the PPTC devices, and shall not be used or applied.  Chemical Pollutants  Silicone-based oils, oils, solvents, gels, electrolytes, fuels, acids, and the like will adversely affect the properties of PPTC devices, and shall not be used or applied.  Electronic and Thermal Effect  PPTC devices are secondary protection devices and are used solely for sporadic, accidental over-current or over-temperature error condition, and shall NOT be used if or when constant or repeated fault conditions (such fault conditions may be caused by, among others, incorrect pin-connection of a connector) or over-extensive trip events may occur.  PTTC devices are different from fuses and, when a fault condition occurs, will go into high-resistance state and do not open circuit, in which case the voltage at such PPTC devices may reach a hazardous level.  Operation over the maximum rating or other forms of improper use may cause failure, arcing, flame and/or other damage to the PPTC devices.  Conductive material contamination, such as metal particle, may induce shortage, flame or arcing.  Due to the inductance, the operation circuits may generate a circuit voltage (Ldi/dt) above the rated voltage of PPTC devices, which shall not be used under such circumstances.  General  Customers shall evaluate and test the properties of PPTC devices independently to verify and ensure that their individual applications will be met.  The performance of PPTC devices will be adversely affected if they are improperly used under electronic, thermal and/or mechanical procedures and/or conditions non-conformant to those recommended by manufacturer.  Customers shall be responsible for determining whether it is necessary to have back-up, failsafe and/or fool-proof protection to avoid or minimize damage that may result from extra-ordinary, irregular function or failure of PPTC devices.  Any and all responsibilities and liabilities are disclaimed if any item under this notice of warning is not complied with. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 4 of 14 2015/7/1 Revision: Preliminary RLD 16V GMF Series PTC Devices Average Time-to-Trip Curves C D E B A A = RLD16P250GMF B = RLD16P500GMF C = RLD16P900GMF D = RLD16P1500GMF E = RLD16P2000GMF 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 5 of 14 2015/7/1 Revision: Preliminary RLD 16V GMF Series PTC Devices Thermal Derating Curve 250GMF-400GMF 500GMF-2000GMF Thermal Derating Table Recommended Hold Current (A) vs. Ambient Temperature (ºC) Part Number Ambient Operation Temperature -40 ºC -20 ºC 0 ºC 23 ºC 40 ºC 50 ºC 60 ºC 70 ºC 85 ºC RLD16P250GMF 3.5 3.2 2.9 2.5 2.2 2.0 1.8 1.6 1.3 RLD16P300GMF 4.2 3.8 3.4 3.0 2.6 2.4 2.1 1.9 1.5 RLD16P400GMF 5.6 5.1 4.6 4.0 3.5 3.1 2.8 2.5 2.0 RLD16P500GMF 8.0 7.0 6.1 5.0 4.3 3.8 3.4 3.0 2.3 RLD16P600GMF 9.5 8.4 7.3 6.0 5.1 4.6 4.1 3.5 2.8 RLD16P700GMF 11.1 9.8 8.5 7.0 6.0 5.4 4.7 4.1 3.2 RLD16P800GMF 12.7 11.2 9.7 8.0 6.8 6.1 5.4 4.7 3.7 RLD16P900GMF 14.3 12.6 10.9 9.0 7.7 6.9 6.1 5.3 4.1 RLD16P1000GMF 15.9 14.0 12.2 10.0 8.5 7.6 6.8 5.9 4.6 RLD16P1100GMF 17.5 15.4 13.4 11.0 9.4 8.4 7.5 6.5 5.1 RLD16P1200GMF 19.1 16.8 14.6 12.0 10.2 9.2 8.1 7.1 5.5 RLD16P1400GMF 22.3 19.6 17.0 14.0 11.9 10.7 9.5 8.3 6.4 RLD16P1500GMF 23.9 21.0 18.2 15.0 12.8 11.5 10.2 8.9 6.9 RLD16P1750GMF 27.8 24.5 21.3 17.5 14.9 13.4 11.9 10.3 8.1 RLD16P2000GMF 31.8 28.1 24.3 20.0 17.0 15.3 13.6 11.8 9.2 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 6 of 14 2015/7/1 Revision: Preliminary RLD 16V GMF Series PTC Devices Physical Dimensions (mm.) Fig. 3 Fig. 2 Fig. 1 Fig. 5 Fig. 4 A Max. B Max. C Typ. D Min. E Max. Y Typ. Fig. RLD16P250GMF 7.6 12.2 5.1±0.7 7.6 2.8 0.8 3 0.51 RLD16P300GMF 8.0 9.4 5.1±0.7 7.6 3.2 1.1 4 0.81 RLD16P400GMF 8.9 11.9 5.1±0.7 7.6 3.2 1.1 4 0.51 RLD16P500GMF 7.6 12.2 5.1±0.7 7.6 3.2 1.3 5 0.51 RLD16P600GMF 8.0 14.2 5.1±0.7 7.6 3.2 1.3 5 0.51 RLD16P700GMF 9.1 12.1 5.1±0.7 7.6 3.2 1.3 4 0.51 RLD16P800GMF 9.3 12.8 5.1±0.7 7.6 3.2 1.3 4 0.51 RLD16P900GMF 10.0 13.4 5.1±0.7 7.6 3.2 1.3 4 0.81 RLD16P1000GMF 11.7 14.3 5.1±0.7 7.6 3.2 1.3 4 0.81 RLD16P1100GMF 12.1 15.7 5.1±0.7 7.6 3.2 1.3 4 0.81 RLD16P1200GMF 12.4 15.9 5.1±0.7 7.6 3.6 1.5 4 1.00 RLD16P1400GMF 13.0 16.3 5.1±0.7 7.6 3.6 1.5 4 1.00 7.6 3.6 1.5 4 1.00 Part Number Lead Dia. RLD16P1500GMF 13.0 19.5 5.1±0.7 RLD16P1750GMF 14.3 19.0 10.2±1.0 7.6 4.0 1.7 4 1.20 RLD16P2000GMF 14.5 23.0 10.2±1.0 7.6 4.0 1.7 4 1.20 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 7 of 14 2015/7/1 Revision: Preliminary RLD 16V GMF Series PTC Devices Recommend Pad Layout Part Number A B D1 D2 RLD16P250GMF 5.1 0.8 1.0 2.5 RLD16P300GMF 5.1 1.1 1.5 3.5 RLD16P400GMF 5.1 1.1 1.5 3.5 RLD16P500GMF 5.1 1.3 1.5 3.5 RLD16P600GMF 5.1 1.3 1.5 3.5 RLD16P700GMF 5.1 1.3 1.5 3.5 3.5 RLD16P800GMF 5.1 1.3 1.5 RLD16P900GMF 5.1 1.3 1.5 3.5 RLD16P1000GMF 5.1 1.3 1.5 3.5 RLD16P1100GMF 5.1 1.3 1.5 3.5 RLD16P1200GMF 5.1 1.5 1.8 4.0 RLD16P1400GMF 5.1 1.5 1.8 4.0 RLD16P1500GMF 5.1 1.5 1.8 4.0 RLD16P1750GMF 10.2 1.7 2.1 4.5 RLD16P2000GMF 10.2 1.7 2.1 4.5 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 8 of 14 2015/7/1 Revision: Preliminary RLD 16V GMF Series PTC Devices Wave Soldering Parameters Profile Feature Average Ramp-Up Rate (Tsmax to TP) Preheat -Temperature Min (Tsmin) -Temperature Max (Tsmax) -Time (Tsmin to Tsmax) Peak Temperature (TP) Max Time at Peak Temperature (tP) Ramp-Down Rate Time 25ºC to Peak Temperature Storage Condition Pb-Free Assembly 4ºC/second max. 100ºC 125ºC 60-180 seconds 265ºC 5 seconds 6ºC /second max. 5 minutes max. 0ºC ~35ºC, ≦80%RH Note: If the wave soldering temperatures exceed the recommended profile, devices may not meet the performance requirements. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 9 of 14 2015/7/1 Revision: Preliminary RLD 16V GMF Series PTC Devices Environmental Specifications Operating Temperature -40ºC to +85 ºC Maximum Device Surface Temperature in Tripped State 125ºC Passive Aging +85ºC , 1000 hours ±5% typical resistance change Humidity Aging +85ºC , 85%R.H. 1000 hours ±5% typical resistance change Thermal Shock MIL-STD-202 Method 107G +85ºC /-40ºC 10 times -30% typical resistance change Solvent Resistance MIL-STD-202, Method 215 No change Vibration MIL-STD-883C, Method 2007.1, Condition A No change Moisture Sensitivity Level Level 1, J-STD-020C Physical Specifications Lead Material P250GMF-P2000GMF: Tin-plated copper Soldering Characteristics Solderability per MIL-STD-202, Method 208E Insulating Material Cured, flame retardant epoxy polymer meets UL94V-0 requirements. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 10 of 14 2015/7/1 Revision: Preliminary RLD 16V GMF Series PTC Devices Tape and Reel Specifications: EIA-481/IEC286-2 Dimension Description Carrier tape width Hold down tape width Top distance between tape edges Sprocket hole position Sprocket hole diameter* Abscissa to plane(straight lead) Abscissa to plane(kinked lead) Abscissa to top P250GMF-P900GMF Abscissa to top P1000GMF-P2000GMF Overall width without lead protrusion: P250GMF-P900GMF Overall width without lead protrusion: P1000GMF-P2000GMF Overall width with lead protrusion: P250GMF-P900GMF Overall width with lead protrusion: P1000GMF-P2000GMF Lead protrusion Protrusion of cut out Protrusion beyond hold-down tape Sprocket hole pitch: P250GMF-P1500GMF Sprocket hole pitch: P1750GMF-P2000GMF Pitch tolerance Device pitch: P250GMF-P1500GMF Device pitch: P1750GMF-P2000GMF Tape thickness Tape thickness with splice Splice sprocket hole alignment Body lateral deviation Body tape plane deviation Ordinate to adjacent component lead*: P250GMF-P1500GMF Ordinate to adjacent component lead*: P1750GMF-P2000GMF Lead spacing: P250GMF-P1500GMF Lead spacing: P1750GMF-P2000GMF Reel width P250GMF-P900GMF Reel width P1000GMF-P2000GMF Reel diameter Space between flanges less device* Arbor hole diameter Core diameter* Box Consecutive missing places Empty places per reel EIA Mark IEC Mark Dimensions Dim.(mm) Tol.(mm) W W4 W6 W5 D0 H H0 H1 H1 C1 W W0 W2 W1 D0 H H0 H1 18 11 3 9 4 18.5 16 32.2 47.5 42.5 57 43.2 58 1.0 11 Not specified 12.7 25.4 20 consecutive. 12.7 25.4 0.9 2.0 0 0 0 3.81 7.62 5.08 10.18 56 63.5 370 4.75 26 91 56/372/372 None 0.1%max. C2 L1 L l2 P0 P0 l1 L l2 P0 P0 t t1 t Δh Δp P1 Δh Δp P1 F F w2 w2 a w1 c n F F w w d f h -0.5/+1.0 min. max. -0.5+0.75 -0.32/+0.2 +3.0 +0.5 max. max. max. max. max. max. +0.3 +0.5 +1 max. max. +0.3 +1.0 +1.3 +0.7 +0.7 +0.8 +0.8 max. max. max. -3.25/+9.25 +12.0 max. max. 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 11 of 14 2015/7/1 Revision: Preliminary RLD 16V GMF Series PTC Devices Tape and Reel Specifications: EIA-481/IEC286-2 (Continued) Fig. 1 Fig. 2 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 12 of 14 2015/7/1 Revision: Preliminary RLD 16V GMF Series PTC Devices Marking on Device Polytronics Trademark Voltage rating Current rating & series code Date code Part Ordering Number System RLD 16 P □□□ GMF - □□ Packaging Style (B: Bulk; TA: Tape & Ammo; TR: Tape & Reel) Minimized Lead- Free Product Series Holding Current Rating Polytronics Symbol Voltage Rating Radial Leaded Device 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 13 of 14 2015/7/1 Revision: Preliminary RLD 16V GMF Series PTC Devices Packaging Quantity Part Number RLD16P250GMF RLD16P300GMF RLD16P400GMF RLD16P500GMF RLD16P600GMF RLD16P700GMF RLD16P800GMF RLD16P900GMF RLD16P1000GMF RLD16P1100GMF RLD16P1200GMF RLD16P1400GMF RLD16P1500GMF RLD16P1750GMF RLD16P2000GMF Ordering Code Bag Quantity RLD16P250GMF-B RLD16P250GMF-TR RLD16P250GMF-TA RLD16P300GMF-B RLD16P300GMF-TR RLD16P300GMF-TA RLD16P400GMF-B RLD16P400GMF-TR RLD16P400GMF-TA RLD16P500GMF-B RLD16P500GMF-TR RLD16P500GMF-TA RLD16P600GMF-B RLD16P600GMF-TR RLD16P600GMF-TA RLD16P700GMF-B RLD16P700GMF-TR RLD16P700GMF-TA RLD16P800GMF-B RLD16P800GMF-TR RLD16P800GMF-TA RLD16P900GMF-B RLD16P900GMF-TR RLD16P900GMF-TA RLD16P1000GMF-B RLD16P1000GMF-TR RLD16P1000GMF-TA RLD16P1100GMF-B RLD16P1100GMF-TR RLD16P1100GMF-TA RLD16P1200GMF-B RLD16P1200GMF-TR RLD16P1200GMF-TA RLD16P1400GMF-B RLD16P1400GMF-TR RLD16P1400GMF-TA RLD16P1500GMF-B RLD16P1500GMF-TR RLD16P1500GMF-TA RLD16P1750GMF-B RLD16P1750GMF-TR RLD16P1750GMF-TA RLD16P2000GMF-B RLD16P2000GMF-TR RLD16P2000GMF-TA 500 Reelpack Quantity Ammopack Quantity 2000 2000 500 2000 2000 500 2000 2000 500 2000 2000 500 2000 2000 500 2000 2000 500 2000 2000 500 2000 2000 500 2000 2000 500 2000 2000 500 2000 2000 500 2000 2000 500 2000 2000 200 1000 1000 200 1000 1000 新竹市科學工業園區工業東四路 24-1 號 No. 24-1 Industry E. Rd. IV, Hsinchu Science Park, Hsinchu 300, Taiwan. TEL: +886-3-5643931 FAX: +886-3-5644624 http://www.pttc.com.tw Page: 14 of 14 2015/7/1 Revision: Preliminary
RLD16P700GMF 价格&库存
很抱歉,暂时无法提供与“RLD16P700GMF”相匹配的价格&库存,您可以联系我们找货
