ME2804A33M3G
ME2804A33M3G
    MICRONE(南京微盟)
    SOT23-3
    ME2804系列是采用NMOS技术制造的高精度、低功耗电压检测器。检测电压极其精确,温度漂移极小。提供NMOS输出配置。
ME2804A33M3G 数据手册
ME2804 Voltage Detectors, ME2804 Series General Description Features ME2804 Series are highly precise, low power  Highly accuracy:±1% (-VDET>1.5V) consumption voltage detectors, manufactured using  Low power consumption: NMOS technologies. Detect voltage is extremely accurate with minimal temperature drift. NMOS TYP 0.7uA (VIN=3.5V, -VDET=2.0V)  output configurations are available. Detect voltage range: 1.0V~6.5V in 0.1V increments  Operating voltage range:0.7V~7V  Detect voltage temperature characteristics: TYP±100ppm/℃  Output configuration: NMOS Typical Application Package  Microprocessor reset circuitry   Memory battery back-up circuits  Power-on reset circuits  Power failure detection 3-pin SOT23-3 Typical Application Circuit V07 www.microne.com.cn Page 1 of 8 ME2804 Selection Guide ME 28 04 X XX XX G Environment mark Package M3:SOT23-3 Detect Voltage Function Product Type Product Series Microne product series product description ME2804A10M3G VDET =1.0V;Rising edge detection;Package:SOT23-3 ME2804A33M3G VDET =3.3V;Rising edge detection;Package:SOT23-3 NOTE: 1.At present ,there are thirteen kinds of voltage value: 1.0V、1.1V、1.2V、1.3V、1.4V、1.45V、1.8V、2.2V、 2.5V、2.7V、3.0V、3.3V、3.8V。 2.If you need other voltage or package, please contact our sales staff. V07 www.microne.com.cn Page 2 of 8 ME2804 Pin Configuration 3 1 2 SOT23-3 Pin Assignment Pin Number Pin Name Functions 2 GND Ground 1 VOUT Output Voltage 3 VIN Input Voltage SOT23-3 Block Diagram V07 www.microne.com.cn Page 3 of 8 ME2804 Absolute Maximum Ratings Parameter Symbal Ratings Units VIN Input Voltage VIN 8 V Output Current IOUT 50 mA Output Voltage NMOS VOUT GND-0.3~VIN+0.3 V Internal Power Dissipation SOT23-3 Pd 540 mW Thermal resistance (Junction to air) SOT23-3 θJA 230 ℃/W Operating Ambient Temperature TOpr -40~+85 ℃ Maximum junction temperature TJ -40~+150 ℃ Storage Temperature Tstg -55~+150 ℃ Soldering temperature and time Tsolder 260℃, 10s MM 400 V HBM 4000 V ESD Electrical Characteristics (-VDET(S)=1.0V to 6.5V±1% ,Ta=25OC ,unless otherwise noted) Parameter Detect Voltage Hysteresis Range Supply Current Symbol Conditions Min. Typ Max. -VDET(S)≦1.5V -VDET(S) ×0.98 -VDET(S) -VDET(S) ×1.02 -VDET(S)>1.5V -VDET(S) ×0.99 -VDET(S) -VDET(S) ×1.01 - 0.03 0.06 0.1 VIN=2.0V (1.0V-1.5V) - 0.7 1 VIN =3.5V (1.6V-2.0V) - 0.7 1 VIN=4.5V (2.1V-3.9V) - 1.2 2 VIN =6.0V (4.0V-5.6V) - 1.1 2 VIN=7.0V (5.7V-6.5V) - 1.0 2 0.01 0.14 - mA 0.7 - 7 V - - 60 us - ±100 ±350 ppm/℃ -VDET VHYS ISS Output Current Iout N-ch Operating voltage VIN Responding time tpLH Temperature characteristics   VDET Ta   VDET VDS=0.5V VIN =0.7V - Ta  40C~85C Note: 1、-VDET(S) :Specified Detection Voltage value 2、-VDET :Actual Detection Voltage value 3、Release Voltage:+VDET=-VDET+VHYS V07 www.microne.com.cn Page 4 of 8 Units V V uA ME2804 Functional Description: 1、 When input voltage (VIN) rises above detect voltage (–VDET), output voltage (VOUT) will be equal to VIN. 2、 When input voltage (VIN) falls below detect voltage (–VDET), output voltage (VOUT) will be equal to the ground voltage (GND) level. 3、 When input voltage (VIN) falls to a level below that of the minimum operating voltage (VMIN), output will become unstable. In this condition, VIN will equal the pulled-up output (should output be pulled-up.) 4、 When input voltage (VIN) rises above the ground voltage (GND) level, output will be unstable at levels below the minimum operating voltage (VMIN). Between the VMIN and detect release voltage +VDET) levels, the ground voltage (GND) level will be maintained. 5、 When input voltage (VIN) rises above detect release voltage (+VDET), output voltage (VOUT) will be equal to VIN. 6、 The difference between +VDET and –VDET represents the hysteresis range. Timing Chart: ME2804XX: Directions for use: 1、 Please use this IC within the stated maximum ratings. Operation beyond these limits may cause degrading or permanent damage to the device. 2、In order to stabilize the IC’s operations, please ensure that VIN pin’s input frequency’s rise and fall times are more than several u Sec/V. V07 www.microne.com.cn Page 5 of 8 ME2804 Type Characteristics 1、Supply Current VS. Ambient Temperature 2、Supply Current VS. Input Voltage -VDET=1.1V (T=25℃) VIN=2V,-VDET=1.1V Iss VS VIN 1.6 1 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 1.4 1.2 Iss (uA) Iss (uA) Iss VS Temp 1 0.8 0.6 0.4 0.2 0 -15 7 20 30 40 50 60 70 80 90 100 0.5 1 1.5 2 3、Detect, Release Voltage VS. Ambient Temperature 3.5 4 4.5 5 5.5 6 4、N-ch OUTPUT CURRENT VS. INPUT VOLTAGE -VDET=1.1V VDS=0.5V -VDET=1.1V Iout(N) VS VIN VDET VS TEMP 1.25 1 1.2 0.8 Iout (mA) VDET (V) 3 VIN (V) Temp (℃) 1.15 1.1 -VDET 1.05 2.5 T=100℃ 0.6 T=25℃ T=-15℃ 0.4 0.2 +VDET 0 1 -15 7 20 30 40 50 60 70 80 90 100 110 120 0.4 0.6 0.8 VIN (V) TEMP (℃) V07 0.2 www.microne.com.cn Page 6 of 8 1 ME2804 Packaging Information  Package Type:SOT23-3 DIM Millimeters Inches Min Max Min Max A 1.05 1.45 0.0413 0.0571 A1 0 0.15 0.0000 0.0059 A2 0.9 1.3 0.0354 0.0512 A3 0.6 0.7 0.0236 0.0276 b 0.25 0.5 0.0098 0.0197 c 0.1 0.25 0.0039 0.0098 D 2.8 3.1 0.1102 0.1220 E 2.6 3.1 0.1023 0.1220 E1 1.5 1.8 0.0591 0.0709 e L 0.95(TYP) 0.25 L1 θ c1 V07 0.0374(TYP) 0.6 0.0098 0.59(TYP) 0 0.0236 0.0232(TYP) 8° 0.2(TYP) 0.0000 8° 0.0079(TYP) www.microne.com.cn Page 7 of 8 ME2804  The contents of this document will be updated with the product's improvement without prior notice. Please consult our sales staff before using this document to ensure that you are using the l  The application circuit examples described in this document are only used to indicate the  Please use this product within the limits stated in this document. We will not be responsible for  The products described in this document are not allowed to be used in equipment or devices that affect the human body without the written permission of our company, including but not limited to: health equipment, medical equipment, disaster prevention equipment, fuel control equipment, automobile equipment, a  Although our company has always been committed to improving product quality and reliability, semiconductor products have a certain probability of malfunction or wrong work. To prevent personal injury or property damage caused by such accidents, please pay full attention to safety design, for example: Alternate design, fire protection design, and prevention of wrong  When exporting this product or this document overseas, you should abide by applicable import  Copying or reprinting part or all of this document in any form without the permission of our company is strictly prohibited. V07 www.microne.com.cn Page 8 of 8
ME2804A33M3G 价格&库存
很抱歉,暂时无法提供与“ME2804A33M3G”相匹配的价格&库存,您可以联系我们找货
