Crimp
5.08mm
LC-L CONNECTOR
Disconnectable Crimp style connectors
pitch
Features
● Space-saving
LC-L CONNECTOR
The miniaturization (improved from 20.5mm to 13.5mm height)
realizes radical space saving after mating and consequently
will provide more space for wiring.
● Lower insertion force
Insertion and withdrawal force are reduced by 40 to 50%
compared to the existing type.
● Double-crimping contact
For an internal branching or jumper connection, a doublecrimping type contact is adopted.
The LC connector is for the secondary power
circuit used in the office automation
equipment, such as the 3.5inch HDD and MO,
including the DVD.
This low-profile crimp type connector is
designed to meet further miniaturization of
the equipment.
The Plug Housing can also be mated with our
LC connector (top and side entry types) and
the power connection part of the LK connector.
Specifications
1
• Current rating: 5A AC, DC (AWG#20)
• Voltage rating: 250V AC, DC
• Temperature range: -25℃ to +90℃
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/10mΩ max.
After environmental testing/20mΩ max.
• Insulation resistance: 1,000MΩ min.
• Withstanding voltage: 1,500V AC/minute
• Applicable wire: 001 type: AWG#26 to #22, #26+#26
002 type: AWG#20 to #18, #26+#24,
#24+#24, #24+#22, #22+#22
• Applicable PC board thickness: 1.6mm
• Number of circuits: 4
* Compliant
with RoHS.
LC
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
LC-L CONNECTOR
Contact
Applicable wire
Model No.
AWG #
Insulation O.D.
(mm)
0.13 to 0.33
26 to 22
1.3 to 1.7
0.13 + 0.13
26 + 26
1.3 + 1.3
0.5 to 0.75
20 to 18
4.0
mm2
SLC-001T-P2.0
10.4
3.6
1.1
SLC-02T-P2.0
4.4
Q'ty /
reel
3,000
LC-L CONNECTOR
0.13 + 0.22 to 0.33 + 0.33 26 + 24 to 22 + 22
1.9 to 2.1
3,000
1.3 + 1.5 to 1.7 + 1.7
Material and Finish
3.9
Phosphor bronze, tin-plated (reflow treatment)
RoHS compliance
Housing
21.0
1
2
7.9
3
Model No.
Q'ty / bag
LCP-04L
500
4
Material
13.5
PA 66, UL94V-2
RoHS compliance
6.3
Header
057 LC-4
Top entry type
Top entry type
25.6
11.5
23.6
5.08
Q'ty / box
LC-04T
100
Material and Finish
Contact: Brass, tin-plated (reflow treatment)
Housing: PA 66, UL94V-0, natural (white)
2
3
Side entry type
Shape A
1
RoHS compliance
0.5
4
Side entry type
25.6
23.6
11.5
15.24
Shape
Model No.
A
LC-04A
B
LC-04B
8.0
4.18
Model No.
15.24
8.0
4.18
(4.7)
2
1.3
0.35
5.08
Shape B
100
Material and Finish
1
(3.8)
3
0.5
4
Q'ty / box
RoHS compliance
(3.8)
0.5
8.0
11.5
0.35
2
4
3
2
1
LC-L CONNECTOR
Housing clamp
Model No.
Q'ty / box
LCC-04
500
Material and Finish
23.8
4.1
Brass, copper-undercoated, tin-plated (reflow treatment)
12.0
10.6
RoHS compliance
2.0
PC board layout (viewed from component side) and Assembly layout
Side entry type
Top entry type
φ1.5±0.1
5.45
φ2.3±0.1
5.08±0.1
φ1.5±0.1
15.24±0.1
4.38 5.08±0.1
8.5
15.24±0.1
8.8
(16.6)
(16.6)
Note:
1. Tolerances are non-cumulative: ± 0.1mm for all centers.
2. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details.
3
LC-L CONNECTOR
Model number allocation
Contact
Housing
S LC - 001T - P 2.0
LC P - 04 L
Form: S…Strip form
Series name
Applicable wire range:
001…AWG #26 to #22, AWG #26 + #26
Series name
02…AWG #20 to #18, AWG #26 + #24 to #22 + #22
Surface finish: T…Tin-plated (reflow treatment)
Part name: Plug
Material: P…Phosphor bronze
No. of circuits: 4
Terminal size
Shape: L…Low-profile type
Header
Housing clamp
LC - 04 T
LC C - 04
Series name
No. of circuits: 4
Series name
Shape of assembled product: T…Top entry type
Part name: Clamp
A…Side entry type Type A
B…Side entry type Type B
No. of circuits: 4
Crimping machine, Applicator
Contact
Crimping
machine Crimp applicator
SLC-001T-P2.0
AP-K2N
SLC-02T-P2.0
MKS-L
Applicator
Dies
Crimp applicator with dies
MK/SLC-02-20
APLMK SLC02-20
MK/SLC-001-20
APLMK SLC001-20
Note: Contact JST for fully automatic crimping applicator.
4
很抱歉,暂时无法提供与“LC-04T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2.343801+0.30380
- 100+1.96283100+0.25442
- 300+1.61499300+0.20934
- 500+1.54045500+0.19968
- 1000+1.490761000+0.19323
- 4000+1.449354000+0.18787
- 5000+1.449355000+0.18787
- 国内价格
- 1+3.05640
- 10+2.46240
- 30+2.21400
- 国内价格 香港价格
- 1+3.147151+0.40793
- 10+2.5804910+0.33448
- 50+2.0399850+0.26442
- 100+1.67383100+0.21696
- 500+1.60409500+0.20792
- 1000+1.551781000+0.20114
- 2000+1.525632000+0.19775
