SPH-002GA-P0.5S
SPH-002GA-P0.5S
    JST
    SPH-002GA-P0.5S
SPH-002GA-P0.5S 数据手册
PH CONNECTOR Emboss Tape 2.0 mm pitch/Disconnectable Crimp style connectors Specifications 2 5 6 PH CONNECTOR • Current rating: 2 A AC/DC (AWG #24) • Voltage rating: 100 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 800 VAC/ minute • Applicable wire: AWG #32 to #24 • Applicable PC board thickness: 0.8 to 1.6 mm 4 3 This is a thin, low-profile 2.0 mm pitch connector 8.0 mm in height after mounting and 4.5 mm in width. It is designed to meet the demand for high-density connection of internal wires to printed circuit boards. It is compact, highly reliable and low in cost. ● ● ● ● Reliable contact Fully shrouded header Printed circuit board retention mechanism Surface mount model (SMT) ® * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details.   ® ® Standards Recognized E60389 R75087 ® ® PC board layout and Assembly layout 〈Through-hole type〉 Side entry type Top entry type 2 ±0.05 4.5 ±0.05 2 (9.6) (8) φ0.7 +0.1 0 6 +0.1 0 φ0.7 4.8 7.6 6.25 Note: 1. The above figure is the figure viewed from soldering side. 2. Tolerances are non-cumulative: ± 0.05 mm for all centers. 3. Hole dimensions differ according to the type of PC board and piercing method. If PC boards made of hard material are used, the hole dimensions should be larger. The dimensions above should serve as a guideline. Contact JST for details. 〈SMT type〉 SM4 type Top entry type ±0.1 ±0.05 2 End face of wafer on the mating side 3.4 5.5 max. ±0.1 (9.6) 6.6 (8.6) 7.5 min. 2 max. 3 ±0.1 Circuit No.1 ±0.1 1.6 (1) 7.6 5.5 1.5 (2) 0.2 5 9 min. 2±0.05 End face of wafer on the mating side 1 1.6±0.1 1.6±0.1 SM4 type Side entry type 1 min. Note: 1 . The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ± 0.05 mm for all centers. 3. The dimensions above should serve as a guideline. Contact JST for details. 1min. Circuit No.1 1 PH CONNECTOR Contact 1 2.05 SPH-002T-P0.5S SPH-002T-P0.5L SPH-004T-P0.5S 2.08 2.85 Applicable wire Model No. 1.5 5.7 mm2 AWG # 0.05 to 0.22 30 to 24 0.08 to 0.22 28 to 24 0.8 to 1.5 0.032 to 0.08 32 to 28 0.5 to 0.9 Insulation O.D. (mm) 0.8 to 1.5 Q'ty/ reel 8,000 10,000 Material and Finish Phosphor bronze, tin-plated (reflow treatment) Applicator Crimping machine Crimp applicator Contact SPH-002T-P0.5S MKS-L SPH-002T-P0.5L AP-K2N SPH-004T-P0.5S MKS-L-10 Dies Crimp applicator with dies MK/SPH-002-05S APLMK SPH002-05S MK/SPH-002-05L APLMK SPH002-05L MK/SPH-002-05S APLMK SPH004-05S RoHS2 compliance Note: 1. Contact JST for gold-plated products. 2. SPH-002T-P0.5L is low-insertion force type contact, for easier insertion/ withdrawal, which would be less resistant to the vibration. The crimp height is different from the standard. 3. Contact JST for details. Note: Contact JST for fully automatic crimping applicator. Housing No. of circuits 2 3 4 B A 2 0.5 Circuit 1.9 No.1 5 4.5 6 7 8 10 6.35 H JST 8 9 11 12 13 □0.6 14 15 16 Model No. A PHR-2 PHR-3 PHR-4 PHR-5 PHR-6 PHR-7 PHR-8 PHR-9 PHR-10 PHR-11 PHR-12 PHR-13 PHR-14 PHR-15 PHR-16 Dimensions (mm) B Q'ty/ bag 2.0 5.8 2,000 4.0 7.8 2,000 6.0 9.8 2,000 8.0 11.8 2,000 10.0 13.8 2,000 12.0 15.8 2,000 14.0 17.8 1,000 16.0 19.8 1,000 18.0 21.8 1,000 20.0 23.8 1,000 22.0 25.8 1,000 24.0 27.8 1,000 26.0 29.8 1,000 28.0 31.8 1,000 30.0 33.8 1,000 Material and Finish PA 66, UL94V-0, natural (white) RoHS2 compliance Header No. of circuits Top entry type (2 circuits) (3 circuits or more) 3 4.5 4.5 1.7 B 2 4 1.7 B 5 6 6 6 7 8 1.95 A Circuit No.1 3.4 3.4 9 □0.5 2 A 11 12 □0.5 1.95 10 Circuit No.1 13 14 Side entry type 15 4.8 1.7 B 16 Model Top entry type B2B-PH-K-S B3B-PH-K-S B4B-PH-K-S B5B-PH-K-S B6B-PH-K-S B7B-PH-K-S B8B-PH-K-S B9B-PH-K-S B10B-PH-K-S B11B-PH-K-S B12B-PH-K-S B13B-PH-K-S B14B-PH-K-S B15B-PH-K-S B16B-PH-K-S No. Side entry type S2B-PH-K-S S3B-PH-K-S S4B-PH-K-S S5B-PH-K-S S6B-PH-K-S S7B-PH-K-S S8B-PH-K-S S9B-PH-K-S S10B-PH-K-S S11B-PH-K-S S12B-PH-K-S S13B-PH-K-S S14B-PH-K-S S15B-PH-K-S S16B-PH-K-S Dimensions (mm) Q'ty/box A B Top entry type Side entry type 2.0 5.9 1,000 1,000 4.0 7.9 1,000 1,000 6.0 9.9 1,000 500 8.0 11.9 1,000 500 10.0 13.9 1,000 500 12.0 15.9 500 500 14.0 17.9 500 250 16.0 19.9 500 250 18.0 21.9 500 250 20.0 23.9 500 250 22.0 25.9 400 250 24.0 27.9 250 250 26.0 29.9 250 250 28.0 31.9 250 200 30.0 33.9 250 200 6 6.25 Material and Finish Post: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 66, UL94V-0, natural (white) 1.95 2 □0.5 A Circuit No.1 1.6 RoHS2 compliance This product displays (LF)(SN) on a label. 2 3.4 PH CONNECTOR Header (Low insertion force type) Top entry type (2 circuits) (3 circuits or more) 4.5 B 1.7 3.4 3.4 6 6 1.7 B 4.5 1.95 A Circuit No.1 2 □0.5 □0.5 1.95 Circuit No.1 A Side entry type Circuit No.1 A Q'ty/box Top entry type Side entry type 2.0 5.9 1,000 1,000 4.0 7.9 1,000 1,000 6.0 9.9 1,000 500 8.0 11.9 1,000 500 10.0 13.9 1,000 500 12.0 15.9 500 500 14.0 17.9 500 250 16.0 19.9 500 250 18.0 21.9 500 250 20.0 23.9 500 250 22.0 25.9 400 250 24.0 27.9 250 250 26.0 29.9 250 200 28.0 31.9 250 200 30.0 33.9 250 200 Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 66, UL94V-0, gray RoHS2 compliance This product displays (LF)(SN) on a label. 6.25 6 □0.5 3.4 1.6 2 Dimensions (mm) A B Material and Finish 4.8 1.7 B 1.95 Model No. No. of circuits Top entry type Side entry type 2 B2B-PH-KL S2B-PH-KL 3 B3B-PH-KL S3B-PH-KL 4 B4B-PH-KL S4B-PH-KL 5 B5B-PH-KL S5B-PH-KL 6 B6B-PH-KL S6B-PH-KL 7 B7B-PH-KL S7B-PH-KL 8 B8B-PH-KL S8B-PH-KL 9 B9B-PH-KL S9B-PH-KL 10 B10B-PH-KL S10B-PH-KL 11 B11B-PH-KL S11B-PH-KL 12 B12B-PH-KL S12B-PH-KL 13 B13B-PH-KL S13B-PH-KL 14 B14B-PH-KL S14B-PH-KL 15 B15B-PH-KL S15B-PH-KL 16 B16B-PH-KL S16B-PH-KL Header (SMT type) Top entry type No. of circuits B 2.975 2 A 1.9 2 (2) 5 3 4 5 6.6 6 7 Circuit No.1 1.4 8 2.2 9 10 11 Side entry type 12 13 2.4 14 5.5 15 Circuit No.1 2.95 16 1.6 2 A B 6 (2.6) Model No. Top entry type Side entry type B2B-PH-SM4-TB B3B-PH-SM4-TB B4B-PH-SM4-TB B5B-PH-SM4-TB B6B-PH-SM4-TB B7B-PH-SM4-TB B8B-PH-SM4-TB B9B-PH-SM4-TB B10B-PH-SM4-TB B11B-PH-SM4-TB B12B-PH-SM4-TB B13B-PH-SM4-TB B14B-PH-SM4-TB B15B-PH-SM4-TB B16B-PH-SM4-TB S2B-PH-SM4-TB S3B-PH-SM4-TB S4B-PH-SM4-TB S5B-PH-SM4-TB S6B-PH-SM4-TB S7B-PH-SM4-TB S8B-PH-SM4-TB S9B-PH-SM4-TB S10B-PH-SM4-TB S11B-PH-SM4-TB S12B-PH-SM4-TB S13B-PH-SM4-TB S14B-PH-SM4-TB S15B-PH-SM4-TB ̶ Dimensions (mm) B A Top entry type Side entry type Q'ty/ reel 2.0 7.95 7.9 1,000 4.0 9.95 9.9 1,000 6.0 11.95 11.9 1,000 8.0 13.95 13.9 1,000 10.0 15.95 15.9 1,000 12.0 17.95 17.9 1,000 14.0 19.95 19.9 1,000 16.0 21.95 21.9 1,000 18.0 23.95 23.9 1,000 20.0 25.95 25.9 1,000 22.0 27.95 27.9 1,000 24.0 29.95 29.9 1,000 26.0 31.95 31.9 1,000 28.0 33.95 33.9 1,000 30.0 35.95 ̶ 1,000 Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: PA, UL94V-0, natural (ivory) Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment) RoHS2 compliance This product displays (LF)(SN) on a label. Note: Contact JST for the top entry type headers with suction cap. 3 PH CONNECTOR Model number allocation Contact Housing PH R - 2 - S PH - 002 T - P 0.5 S Form: S…Strip form Series name Applicable wire range: Normal type 002…AWG #30 to #24        004…AWG #32 to #28 Low insertion force type 002…AWG #28 to #24 Series name Surface finish: T…Tin-plated (reflow treatment) No. of circuits: 2 to 16 Material: P…Phosphor bronze Color: None…Natural (White), BK…Black, R…Red, TR…Tomato red, Part name: Receptacle    BL…Blue, Y…Yellow, L…Lemon yellow, M…Green, D…Orange, N…Brown, P…Purple, PK…Pink, H…Gray, LE…Light blue, Terminal size Type name: S…Normal type, L…Low insertion force type FY…Fluorescent yellow, DPK…Dark pink Header Header (Low insertion force type) B 2 B - PH - K L - B 2 B - PH - K - S Shape of assembled product: B…Top entry type S…Side entry type No. of circuits: Top and side entry types…2 to 16 Shape of assembled product: B…Top entry type, S…Side entry type Part name: Header No. of circuits: Top and side entry types…2 to 16 Series name Part name: Header Indication of clinch: K…Clinched Series name Color: S…Natural (White), K…Black, R…Red, TR…Tomato red, E…Blue, Y…Yellow, L…Lemon yellow, M…Green, O…Orange, N…Brown, P…Purple, PK…Pink, H…Gray, LE…Light blue, FY…Fluorescent yellow, None…Ivory Indication of clinch: K…Clinched Header (SMT type) B 2 B - PH - SM4 - -TB Shape of assembled product: B…Top entry type S…Side entry type No. of circuits: Top entry type…2 to 16 Side entry type…2 to 15 Part name: Header Series name SMT specification: SM4…With solder tab Color: None…Natural (Ivory), R…Red, E…Blue, M…Green, L…Lemon yellow, K…Black, DPK…Dark pink Packaging style: TB…Embossed-taping Suction tape: None…Without suction tape, T…With suction tape Note: Depending on the colors, it may take some time for delivery. 4 Type name: L…Low insertion force type Color: None…Gray, R…Red, E…Blue, S…Natural (White)
SPH-002GA-P0.5S 价格&库存
很抱歉,暂时无法提供与“SPH-002GA-P0.5S”相匹配的价格&库存,您可以联系我们找货
SPH-002GA-P0.5S
    • 5+1.00580
    • 50+0.82990
    • 150+0.74190
    • 500+0.67600
    • 2500+0.62320
    • 5000+0.59680
    库存:8000
    SPH-002GA-P0.5S
    • 8000+0.479818000+0.06236
    SPH-002GA-P0.5S
      • 8000+0.41890
      库存:8000
      SPH-002GA-P0.5S
        • 5+0.89781
        • 50+0.74078
        • 150+0.66226
        • 500+0.60329
        • 2500+0.55620
        • 5000+0.53266
        库存:7383
        SPH-002GA-P0.5S
          • 8000+0.46200
          库存:32000
