SLO0630H Series
SMD Molding Power Inductor
◆ Features
Pb
、Magnetically shielded construction, low DC resistance;
、The use of magnetic iron powder ensure capability
for large current;
3、Low audible core noise;
4、Ideal for DC-DC converter applications in hand held
personal computer and etc;
5、Frequency Range: up to 3.0MHz;
6、RoHS compliant。
1
2
◆ Applications
、Smart phone、MID;
、Next-generation mobile devices with multifunction such
as adding color TV and digital movie cameras;
3、Flat-screen TVs, blue-ray disc recorders, set top box;
4、Notebooks, desktop computers, servers, graphic cards;
5、Portable gaming devices, personal navigation systems,
personal multimedia devices;
6、Automotive systems;
7、Telecomm base stations。
1
2
External Dimensions Unit(mm)
◆ Lead Free Part Numbering
SLO
(1)
0630
(2)
(1)
(2)
(3)
(4)
H
(3)
100 M
(4) (5)
T
T
(6) (7)
Series Type
Dimension A X C
Material Code
Inductance 2R2=2.2μH
100=10μH 101=100μH
(5) Inductance Tolerance M= 20%, Y= 30%
(6) Company Code
(7) Packaging packed in embossed carrier tape
Recommended Land Pattern(mm)
◆ Dimensions
Series
A±0.3
(mm)
B±0.3
(mm)
C
(mm)
D±0.2
(mm)
E±0.2
(mm)
SLO0630H
7.1
6.6
3.0 Max
2.8
1.6
Rev.04
Page 1 of 4
G
(mm)
H
(mm)
7.5 Ref
3.6 Ref
I
(mm)
3.0 Ref
www.sunltech.com
SLO0630H Series
Specification
Ω
Rdc
(m )
Test a
condition
HEAT RATING
CURRENT(Idc)
DC AMPS1
(Typ.)
SATURATION
CURRENT(Isat)
DC AMPS2
(Typ.)
μ
Typ.
Max
SLO0630HR22MTT
0.22
2.8
3.0
100KHz/1V
23.0
40.0
SLO0630HR33MTT
0.33
3.1
3.5
100KHz/1V
22.0
35.0
SLO0630HR47MTT
0.47
4.0
4.2
100KHz/1V
18.0
27.0
SLO0630HR56MTT
0.56
4.3
4.9
100KHz/1V
16.0
25.0
SLO0630HR68MTT
0.68
5.0
5.5
100KHz/1V
15.0
24.0
SLO0630HR82MTT
0.82
5.5
6.5
100KHz/1V
12.5
23.0
SLO0630H1R0MTT
1.0
6.8
7.5
100KHz/1V
12.0
22.0
SLO0630H1R5MTT
1.5
10.5
12.1
100KHz/1V
9.5
18.0
SLO0630H2R2MTT
2.2
14.0
17.5
100KHz/1V
8.5
14.0
SLO0630H3R3MTT
3.3
24
26
100KHz/1V
6.0
12.0
SLO0630H4R7MTT
4.7
31
38
100KHz/1V
5.5
9.0
SLO0630H5R6MTT
5.6
33
42
100KHz/1V
5.0
8.0
SLO0630H6R8MTT
6.8
45
54
100KHz/1V
4.5
8.0
SLO0630H8R2MTT
8.2
55
65
100KHz/1V
4.0
6.0
SLO0630H100MTT
10
66
76
100KHz/1V
4.0
5.5
SLO0630H150MTT
15
97
115
100KHz/1V
3.0
5.0
SLO0630H220MTT
22
139
179
100KHz/1V
3.0
3.2
SLO0630H330MTT
33
189
270
100KHz/1V
2.0
3.0
SLO0630H470MTT
47
376
385
100KHz/1V
1.8
2.0
Part Number
INDUCTANCE
Lo( H)
SLO0630H Series
NOTES:
1. DC current (Idc) that will cause an approximate T of 40
2. DC current (Isat) that will cause Lo to drop approximately 20%
3. All test data is referenced to 25 ambient
4. Operating Temperature Range -55 to +150
5. The part temperature (ambient + temp rise) should not exceed 150
under the worst operating conditions. Circuit design, component placement,
PWB trace size and thickness, airflow and other cooling provisions all affect
Rev.04
Page 2 of 4
www.sunltech.com
SLO0630H Series
the part temperature. Part temperature should be verified in the end application.
◆ Wave Soldering
◆ Hand soldering
Rev.04
Page 3 of 4
www.sunltech.com
SLO0630H Series
◆ Reliability Mechanical
℃ ~+125℃
-45℃ ~ + 1 2 5 ℃
-55
Rev.04
Page 4 of 4
www.sunltech.com
很抱歉,暂时无法提供与“SLO0630H470MTT”相匹配的价格&库存,您可以联系我们找货
