6N139S-TA1-L
6N139S-TA1-L
    LITE-ON(光宝)
    OC8_9.68X6.5MM_SM
6N139S-TA1-L 数据手册
Photocoupler Product Data Sheet 6N138-L / 6N139-L Series Spec No.: DS70-2009-0001 Effective Date: 04/12/2016 Revision: A LITE-ON DCC RELEASE BNS-OD-FC001/A4 LITE-ON Technology Corp. / Optoelectronics No.90,Chien 1 Road, Chung Ho, New Taipei City 23585, Taiwan, R.O.C. Tel: 886-2-2222-6181 Fax: 886-2-2221-1948 / 886-2-2221-0660 http://www.liteon.com/opto Photocoupler 6N138-L 6N139-L series 1. DESCRIPTION These high gain series couplers use a light emitter diode and an integrated high gain photo detector to provide extremely high current transfer ratio between input and output. Separate pins for the photodiode and output stage result in TTL compatible saturation voltage and high speed operation. Where desired the Vcc and Vo terminals may be tied together to achieve conventional photo Darlington operation. A base access terminal allows a gain bandwidth adjustment to be made. 1.1 Features  High current transfer ratio – 2000% typical.  Low input current requirements – 0.5mA  High output current – 60mA  CTR guarantee – 0~70℃.  Instantaneous common mode rejection 10KV/μsec  TTL compatible output – 0.1V VOL typical  UL, CSA approved. 1.2 Applications  Digital logic ground isolation  Low input current line receiver  Telephone ring detector  EIA-RS-232C line receiver  Current loop receiver  High common mode noise line receiver 1.3 Functional Diagram Truth Table (Positive Logic) LED OUT ON L OFF H A 0.1μF bypass Capacitor must be connected between Pin8 and Pin5 1/15 Part No. : 6N138-L 6N139-L series BNS-OD-FC002/A4 Photocoupler 6N138-L 6N139-L series 2. PACKAGE DIMENSIONS 2.1 6N138-L 2.2 6N138M-L 2.3 6N138S-L Notes : 1. Year date code. 2. 2-digit work week. 3. Factory identification mark shall be marked (Y: Thailand , W: China-CZ) 4. For VDE option. Dimensions in millimeters (inches). 2/15 Part No. : 6N138-L 6N139-L series BNS-OD-FC002/A4 Photocoupler 6N138-L 6N139-L series 2.4 6N139-L 2.5 6N139M-L 2.6 6N139S-L Notes : 1. Year date code. 2. 2-digit work week. 3. Factory identification mark shall be marked (Y: Thailand , W: China-CZ) 4. For VDE option. Dimensions in millimeters (inches). 3/15 Part No. : 6N138-L 6N139-L series BNS-OD-FC002/A4 Photocoupler 6N138-L 6N139-L series 3. TAPING DIMENSIONS 3.1 6N138S-TA-L/ 6N139S-TA-L Description 3.2 6N138S-TA1-L/ 6N139S-TA1-L Symbol Dimension in mm (inch) Tape wide W 16±0.3 (0.63) Pitch of sprocket holes P0 4±0.1 (0.15) F 7.5±0.1 (0.295) Distance of compartment Distance of compartment to compartment P2 2±0.1 (0.079) P1 12±0.1 (0.472) 3.3 Quantities Per Reel Package Type TA / TA1 Quantities (pcs) 1000 4/15 Part No. : 6N138-L 6N139-L series BNS-OD-FC002/A4 Photocoupler 6N138-L 6N139-L series 4. RATING AND CHARACTERISTICS 4.1 Absolute Maximum Ratings at Ta=25°C *1 Parameter Symbol Rating Unit Note Average Forward Input Current IF 20 mA 2 Reverse Input Voltage VR 5 V Power Dissipation PI 35 mW Output Collector Current IO 50 mA Input 6N138 Output Output Voltage 7 VO 6N139 Output Collector Power Dissipation Po 100 mW Isolation Voltage Viso 5000 Vrms 6N138 Supply Voltage 7 VCC 6N139 V 18 Operating Temperature Topr -40 ~ +85 o C Storage Temperature Tstg -55 ~ +125 o C 260 o C Lead Solder Temperature *2 1. V 18 Tsol Ambient temperature = 25oC, unless otherwise specified. Stresses exceeding the absolute maximum ratings can cause permanent damage to the device. Exposure to absolute maximum ratings for long periods of time can adversely affect reliability. 2. 260oC for 10 seconds. Refer to Lead Free Reflow Profile. 5/15 Part No. : 6N138-L 6N139-L series BNS-OD-FC002/A4 Photocoupler 6N138-L 6N139-L series 4.2 ELECTRICAL CHARACTERISTICS at Ta = 25°C Parameters Test Condition Symbol Device Min Typ Max Units 1.1 1.7 V Input Input Forward Voltage IF =1.6mA, TA=25℃ Input Forward Voltage IF=1.6mA VF ΔVF/ΔTA Temperature Coefficient mV/℃ -1.9 6N138 6N139 Input Reverse Voltage IR = 10μA TA=25℃ BVR 5 - - V Input Capacitance VF=0; f=1MHZ CIN - 60 - pF 300 1600 2600 400 2000 5000 500 1600 2600 - 0.1 0.4 - 0.1 Detector IF=1.6mA; Vo=0.4V; Vcc=4.5V Current transfer ratio IF=0.5mA; Vo=0.4V; Vcc=4.5V 6N138 CTR % 6N139 IF=1.6mA; Vcc=0.4V; Vcc=4.5V IF=1.6mA; Vcc=4.5V; Io=4.8mA 6N138 IF=0.5mA; Vcc=4.5V; Io=2mA Logic low output voltage IF=1.6mA; Vcc=4.5V; Io=8mA VOL V 6N139 0.4 IF=5mA; Vcc=4.5V; Io=15mA IF=12mA; Vcc=4.5V; Io=24mA IF=0mA, Vo=Vcc=7V; TA=25℃ Logic high output current - 0.2 6N138 - 0.05 250 6N139 - 0.1 100 - 0.4 1.5 mA - 0.01 10 mA μA IOH IF=0mA, Vo=Vcc=18V; TA=25℃ 6N138 Logic low supply current IF=1.6mA, Vo=open (Vcc=18V) IccL 6N139 IF=0mA, Vo=open ; TA=25℃ Logic high supply current 6N138 IccH (Vcc=18V) 6N139 Specified over recommended temperature (TA = -40oC to +85oC, 4.5V ≤ VCC ≤ 5.5V), IF = 7.5mA unless otherwise specified. All typicals at TA = 25oC, VCC = 5.0V. 6/15 Part No. : 6N138-L 6N139-L series BNS-OD-FC002/A4 Photocoupler 6N138-L 6N139-L series 5. SWITCHING SPECIFICATIONS (AC) Parameter Test Condition Symbol IF=1.6mA; RL= 2.2kΩ Device Min Typ Max 6N138 - 1.6 10 - 5 25 - 0.1 1 - 10 35 - 18 60 - 2 7 1 10 - Units Propagation Delay Time to IF=0.5mA; RL=4.7KΩ tPHL Low Output Level μs 6N139 IF=12mA; RL=270Ω IF=1.6mA; RL= 2.2kΩ 6N138 Propagation Delay Time to IF=0.5mA; RL=4.7KΩ tPLH High Output Level IF=12mA; RL=270Ω Logic High Common Mode IF=0mA; |VCM|=10Vp-p Transient Immunity RL=2.2KΩ Logic Low Common Mode IF=1.6mA; |VCM|=10Vp-p 6N139 KV/μs KV/μs 6N138 |CML| RL=2.2KΩ KV/μs 6N138 |CMH| Transient Immunity μs 6N139 1 6N139 10 KV/μs *All Typical at TA =25oC 7/15 Part No. : 6N138-L 6N139-L series BNS-OD-FC002/A4 Photocoupler 6N138-L 6N139-L series 6. ISOLATION CHARACTERISTIC Parameter Symbol Min. Typ. Max. Unit II-O — — 1.0 μA Withstand Insulation Test Voltage VISO 5000 — — VRMS Input-Output Resistance RI-O — 1012 — Ω Input-Output Insulation Leakage Current Test Condition 45% RH, t = 5s, VI-O = 3kV DC, TA =25oC RH ≤ 50%, t = 1min, TA = 25oC VI-O = 500V DC *All Typical at TA =25oC Notes 1. AC For 1 Minute, R.H. = 40 ~ 60%. Isolation voltage shall be measured using the following method. (1) Short between anode and cathode on the primary side and between collector and emitter on the secondary side. (2) The isolation voltage tester with zero-cross circuit shall be used. (3) The waveform of applied voltage shall be a sine wave. 2. For 10 Seconds 3. Current Transfer Ratio (CTR) is defined as the ration of output collector current, Io, to the forward LED input current, IF, times 100%. 4. Pin 7 open. 5. Instantaneous common mode rejection voltage "output (1)" represents a common mode voltage variation that can hold the output above (1) level (Vo>2.0V).Instantaneous common mode rejection voltage "output (0)" represents a common mode voltage variation that can hold the output above (0) level (Vo
6N139S-TA1-L 价格&库存
很抱歉,暂时无法提供与“6N139S-TA1-L”相匹配的价格&库存,您可以联系我们找货
