NJW4750MHH1(TE1)
NJW4750MHH1(TE1)
    JRC(⽇本无线)
    EQFN26-HH_3.4X2.6MM_EP
    NJW4750是一款四通道组合电源管理芯片,包括一个宽输入范围的降压转换器和三个同步降压转换器/线性稳压器。该芯片适用于汽车应用,具有AEC-Q100 Grade 1认证,工作温度范围为-40至125...
NJW4750MHH1(TE1) 数据手册
Automotive NJW4750 Quad Channel Combination Regulator  FEATURES  AEC-Q100 Grade1 Qualified *  Operating temperature range -40 to 125C  Including four regulators; Ch.1: Wide input range 1.2A buck converter. Ch.2: Low voltage 0.6A synchronous buck converter. Ch.3: Selectable regulator. Low voltage 0.6A synchronous buck converter / Low voltage 0.3A LDO Ch.4: Low voltage 0.3A LDO e.g.) Ta=85 C, fosc=2MHz DC-DC Ch.1: 12V  3.3V/1000mA (Included supply for Ch.2, 3, 4) Ch.2: 3.3V  1.8V/500mA Ch.3: 3.3V  1.2V/500mA LDO Ch.4: 3.3V  2.8V/200mA  Wide operating input voltage range 3.9V(UVLO ON: 3.35V) to 40V (Ch.1) 2.4V to 5.5V (Ch.2, Ch.3, Ch.4)  Free power-on sequence - Individual Power-Good Function (High precision -7%, + 15%) - Individual Standby Function  Protection function - UVLO (Under Voltage Lockout) - Over current protection function for more safety operation (Hiccup or Latch) - Thermal shutdown  Oscillating frequency 280kHz to 2.4MHz  External clock synchronization  Anti-phase operation between Ch.1 and Ch.2 / 3  Current mode control buck converters  Built-in compensation circuit  Soft start function *AEC-Q100 Reliability test is in progress now.  GENERAL DESCRIPTION The NJW4750 is quad channel combination regulator including one wide input range buck converter and three secondary synchronous buck converter / LDO. Ch.3 can be selectable to the synchronous buck converter mode or LDO mode. Therefore, the NJW4750 expands the choices when building power supply block suitable for various applications. The NJW4750 is operated anti-phase operation between Ch.1 and Ch.2 / 3 in order to reduce EMI noise. Every regulator has individual enable pin and power-good pin. Therefore, flexible power-on sequence configuration is available. The NJW4750 has two types of over-current protection according to application demand. Furthermore, it adopts a new overcurrent detection method which is more safety and contributes to miniaturization of the inductor. Small package: 3.4mm × 2.6mm QFN is adopted suitable for small application such as camera module.  TARGET APPLICATION  Camera Module(Automotive)  Rader(Automotive)  Photoelectric sensor(FA)  Small Application and other.  APPLICATION  PACKAGE EQFN26-HH 3.4mm x 2.6mm Ver.1.0 www.njr.com -1- Automotive NJW4750  BLOCK DIAGRAM Ver.1.0 www.njr.com -2- Automotive NJW4750  PIN CONFIGURATION TOP VIEW PIN NO. SYMBOL DESCRIPTION 1 GND Ground 2 EN3 3 FB3 4 PIN NO. SYMBOL DESCRIPTION 14 GND Ground Ch.3 Enable input 15 SW1 Ch.1 Output Ch.3 Voltage feedback input 16 EN4 Ch.4 Enable input NC NC 17 LDOVOUT Ch.4 Output 5 FB2 Ch.2 Voltage feedback input 18 FB4 Ch.4 Voltage feedback input 6 EN2 Ch.2 Enable input 19 LDOVIN Ch.4 Power supply input 7 RT Oscillation frequency setting 20 PG4 Ch.4 Power-good output 8 GND Ground 21 GND Ground 9 PG1 Ch.1 Power-good output 22 SW2 Ch.2 Output 10 MODE Ch.3 Mode select / OCP setting 23 PG2 Ch.2 Power-good output 11 FB1 Ch.1 Voltage feedback input 24 VIN2 Ch.2, Ch.3 Power supply input 12 EN1/SYNC Ch.1 Enable input /External CLK input 25 PG3 Ch.3 Power-good output 13 VIN1 Ch.1 Power supply input 26 SW3 Ch.3 Output  PRODUCT NAME INFORMATION NJW4750 MHH -T1 (TE1) Package MHH: EQFN26-HH  ORDERING INFORMATION Part Number Taping Form T1: Automotive PRODUCT NAME PACKAGE NJW4750MHH-T1(TE1) EQFN26-HH Ver.1.0 AUTO MOTIVE yes RoHS yes HALOGEN FREE yes www.njr.com TERMINAL FINISH Sn2Bi MARKING WEIGHT (mg) MOQ (pcs) 4750T 18 1500 -3- Automotive NJW4750  ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL MAXIMUM RATING UNIT VVIN1 -0.3 to +45 V VVIN2, VLDOVIN -0.3 to +7 V Voltage between pins VIN1 - SW1 VVIN1–SW1 +45 V SW2/SW3 pin Voltage VSW2 VSW3 +7 V EN/SYNC pin Voltage VEN1/SYNC -0.3 to +45 V VEN2, VEN3 -0.3 to +7 V VEN4 -0.3 to +45 V FB pin Voltage VFB1, VFB2, VFB3, VFB4 -0.3 to +7 V PG pin Voltage VPG1, VPG2, VPG3, VPG4 -0.3 to +7 Supply Voltage EN pin Voltage EQFN26-HH V 850 (1) 2500 (2) Power Dissipation(Ta=25C) PD mW Junction Temperature Tj -40 to +150 C Operating Temperature Topr -40 to +125 C Storage Temperature Tstg -50 to +150 C (1): Mounted on glass epoxy board. (101.5×114.5×1.6mm:based on EIA/JEDEC standard,2layers, with Exposed Pad) (2): Mounted on glass epoxy board. (101.5×114.5×1.6mm:based on EIA/JEDEC standard,4layers, with Exposed Pad) (For 4Layers: Applying 99.5×99.5mm inner Cu area and a thermal via holes to a board based on JEDEC standard JESD51-5)  RECOMMENDED OPERATING CONDITIONS PARAMETER SYMBOL VALUE UNIT VVIN1 3.9 to 40 V VVIN2, VLDOVIN 2.4 to 5.5 V VEN1/SYNC 0 to 40 V EN pin Voltage VEN2, VEN3, VEN4 0 to 5.5 V PG pin Voltage VPG1, VPG2, VPG3, VPG4 0 to 5.5 V Timing Resistor RT 1.8 to 27 Oscillating Frequency fOSC 280 to 2400 k kHz External Clock Input fSYNC fOSC0.9 to fOSC1.7 Upper limit 2800kHz Supply Voltage EN/SYNC pin Voltage Ver.1.0 www.njr.com kHz -4- Automotive NJW4750  ELECTRICAL CHARACTERISTICS (Unless otherwise noted, VVIN1=VEN1/SYNC=12V, RT=6.8k, Ta=25C) Ch.1 (Wide input range buck converter) PARAMETER SYMBOL TEST CONDITION MIN. TYP. MAX. 3.60 3.75 3.90 3.60 – 3.90 3.05 3.20 3.35 3.05 – 3.35 500 550 – VFB1=0.75V 1.0 2.5 4.0 VFB1=0.75V Ta=-40C to +125C 0.5 – 4.5 RT=27k 250 280 310 RT=27k Ta=-40C to +125C 250 – 310 RT=6.8k 900 1000 1100 RT=6.8k Ta=-40C to +125C 900 – 1100 RT=1.8k 2200 2400 2600 RT=1.8k Ta=-40C to +125C 2200 – 2600 -1.0% 0.8 +1.0% -2.0% – +2.0% -0.1 – 0.1 -0.1 – 0.1 UNIT Under Voltage Lock Out Circuit Block VVIN1=L → H ON Threshold Voltage VT_ON1 VVIN1=L → H Ta=-40C to +125C VVIN1=H → L OFF Threshold Voltage VT_OFF1 VVIN1=H → L Ta=-40C to +125C Hysteresis Voltage VHYS1 V V mV Soft Start Block Soft Start Time tSS1 ms Oscillator Block Oscillating Frequency 1 fOSC11 Oscillating Frequency 2 fOSC12 Oscillating Frequency 3 fOSC13 kHz kHz kHz Error Amplifier Block Reference Voltage VB1 Input Bias Current IB1 Ver.1.0 Ta=-40C to +125C Ta=-40C to +125C www.njr.com V A -5- Automotive NJW4750  ELECTRICAL CHARACTERISTICS (Unless otherwise noted, VVIN1=VEN1/SYNC=12V, RT=6.8k, Ta=25C) Ch.1 (Wide input range buck converter) PARAMETER SYMBOL TEST CONDITION MIN. TYP. MAX. VFB1=0.7V 100 – – VFB1=0.7V Ta=-40C to +125C 100 – – UNIT PWM Comparator Block Maximum Duty Cycle MAXDUTY1 % Minimum OFF Time tOFF1-min – 55 – ns Minimum ON Time tON1-min – 60 – ns Over Current Protection Circuit Block tCOOL1 RMODE=36k or 10 k – 75 – ms Output ON Resistance RON1 ISW1=0.8A – 0.5 0.8 Switching Current Limit ILIM1 1.4 1.7 2.0  A – – 4 A 1.6 – 40.0 1.6 – 40.0 0 – 0.4 0 – 0.4 – 1 3 – – 5 Cool Down Time Output Block Switching Leak Current ILEAK1 VEN1/SYNC=0V, VVIN1=40V VSW1=0V Ta=-40C to +125C Enable Control / Sync Block (EN1/SYNC) VEN1/SYNC=L → H High Threshold Voltage VTHH_EN1/SYNC VEN1/SYNC=L → H Ta=-40C to +125C VEN1/SYNC=H → L Low Threshold Voltage VTHL_EN1/SYNC VEN1/SYNC=H → L Ta=-40C to +125C VEN1/SYNC=5V Input Bias Current Ver.1.0 IEN1/SYNC VEN1/SYNC=5V Ta=-40C to +125C www.njr.com V V A -6- Automotive NJW4750  ELECTRICAL CHARACTERISTICS (Unless otherwise noted, VVIN1=VEN1/SYNC=12V, RT=6.8k, Ta=25C) Ch.1 (Wide input range buck converter) PARAMETER SYMBOL TEST CONDITION MIN. TYP. MAX. Rising 0.836 – 0.924 Rising, Ta=-40C to +125C Rising 0.836 – 0.924 0.745 – 0.775 Rising, Ta=-40C to +125C 0.745 – 0.775 UNIT Power Good Block(PG1) High Level Detection Reference Voltage VTHH_PG1 Low Level Detection Reference Voltage VTHL_PG1 Hysteresis Voltage VHYS_PG1 Power Good ON Resistance RON_PG1 Leak Current at OFF State Ver.1.0 ILEAK_PG1 V V – 16 – mV IPG1=10mA – 100 –  VPG1=5.5V – – 0.1 VPG1=5.5V Ta=-40C to +125C – – 0.1 www.njr.com A -7- Automotive NJW4750  ELECTRICAL CHARACTERISTICS (Unless otherwise noted, VVIN1=12V, VVIN2=VEN2=3.3V, RT=6.8k, Ta=25C) Ch.2 (Low voltage synchronous buck converter) PARAMETER SYMBOL TEST CONDITION MIN. TYP. MAX. 2.10 2.25 2.40 2.10 – 2.40 2.00 2.15 2.30 2.00 – 2.30 50 100 – VFB2=0.75V 1.0 2.5 4.0 VFB2=0.75V Ta=-40C to +125C 0.5 – 4.5 RT=27k 250 280 310 RT=27k Ta=-40C to +125C 250 – 310 RT=6.8k 900 1000 1100 RT=6.8k Ta=-40C to +125C 900 – 1100 RT=1.8k 2200 2400 2600 RT=1.8k Ta=-40C to +125C 2200 – 2600 -1.0% 0.8 +1.0% -2.0% – +2.0% -0.1 – 0.1 -0.1 – 0.1 UNIT Under Voltage Lock Out Circuit Block VVIN2=L → H ON Threshold Voltage VT_ON2 VVIN2=L → H Ta=-40C to +125C VVIN2=H → L OFF Threshold Voltage VT_OFF2 VVIN2=H → L Ta=-40C to +125C Hysteresis Voltage VHYS2 V V mV Soft Start Block Soft Start Time tSS2 ms Oscillator Block Oscillating Frequency 1 Oscillating Frequency 2 Oscillating Frequency 3 fOSC21 fOSC22 fOSC23 kHz kHz kHz Error Amplifier Block Reference Voltage VB2 Input Bias Current IB2 Ver.1.0 Ta=-40C to +125C Ta=-40C to +125C www.njr.com V A -8- Automotive NJW4750  ELECTRICAL CHARACTERISTICS (Unless otherwise noted, VVIN1=12V, VVIN2=VEN2=3.3V, RT=6.8k, Ta=25C) Ch.2 (Low voltage synchronous buck converter) PARAMETER SYMBOL TEST CONDITION MIN. TYP. MAX. VFB2=0.7V 100 – – VFB2=0.7V Ta=-40C to +125C 100 – – UNIT PWM Comparator Block Maximum Duty Cycle MAXDUTY2 % Minimum OFF Time tOFF2-min – 55 – ns Minimum ON Time tON2-min – 80 – ns Over Current Protection Circuit Block tCOOL2 RMODE=36k or 10 k – 75 – ms Pch Output ON Resistance RONP2 ISW2SOURCE=0.5A – 0.5 0.8  Nch Output ON Resistance RONN2 ISW2SINK=0.5A – 0.3 0.5 0.7 1.0 1.3  A – – 4 A 1.0 – 5.5 1.0 – 5.5 0 – 0.4 0 – 0.4 – 7 14 – – 14 Cool Down Time Output Block Switching Current Limit Switching Leak Current ILIM2 ILEAK2 VEN2=0V, VVIN2=5.5V VSW2=0V Ta=-40C to +125C Enable Control Block (EN2) VEN2=L → H High Threshold Voltage VTHH_EN2 VEN2=L → H Ta=-40C to +125C VEN2=H → L Low Threshold Voltage VTHL_EN2 VEN2=H → L Ta=-40C to +125C VEN2=3.3V Input Bias Current Ver.1.0 IEN2 VEN2=3.3V Ta=-40C to +125C www.njr.com V V A -9- Automotive NJW4750  ELECTRICAL CHARACTERISTICS (Unless otherwise noted, VVIN1=12V, VVIN2=VEN2=3.3V, RT=6.8k, Ta=25C) Ch.2 (Low voltage synchronous buck converter) PARAMETER SYMBOL TEST CONDITION MIN. TYP. MAX. Rising 0.836 – 0.924 Rising, Ta=-40C to +125C Rising 0.836 – 0.924 0.745 – 0.775 Rising, Ta=-40C to +125C 0.745 – 0.775 UNIT Power Good Block (PG2) High Level Detection Reference Voltage VTHH_PG2 Low Level Detection Reference Voltage VTHL_PG2 Hysteresis Voltage VHYS_PG2 Power Good ON Resistance RON_PG2 Leak Current at OFF State Ver.1.0 ILEAK_PG2 V V – 16 – mV IPG2=10mA – 100 –  VPG2=5.5V – – 0.1 VPG2=5.5V Ta=-40C to +125C – – 0.1 www.njr.com A - 10 - Automotive NJW4750  ELECTRICAL CHARACTERISTICS (Unless otherwise noted, VVIN1=12V, VVIN2=VEN3=3.3V, RT=6.8k , Ta=25C) Ch.3 (Selectable regulator: SW Reg. MODE and LDO MODE can share the same table.) PARAMETER SYMBOL TEST CONDITION MIN. TYP. MAX. UNIT 1.0 – 5.5 1.0 – 5.5 0 – 0.4 0 – 0.4 – 7 14 – – 14 Rising 0.836 – 0.924 Rising, Ta=-40C to +125C Rising 0.836 – 0.924 0.745 – 0.775 Rising, Ta=-40C to +125C 0.745 – 0.775 – 16 – mV IPG3=10mA – 100 –  VPG3=5.5V – – 0.1 VPG3=5.5V Ta=-40C to +125C – – 0.1 Enable Control Block(EN3) VEN3=L → H High Threshold Voltage VTHH_EN3 VEN3=L → H Ta=-40C to +125C VEN3=H → L Low Threshold Voltage VTHL_EN3 VEN3=H → L Ta=-40C to +125C VEN3=3.3V Input Bias Current IEN3 VEN3=3.3V Ta=-40C to +125C V V A Power Good Block (PG3) High Level Detection Reference Voltage VTHH_PG3 Low Level Detection Reference Voltage VTHL_PG3 Hysteresis Voltage VHYS_PG3 Power Good ON Resistance RON_PG3 Leak Current at OFF State ILEAK_PG3 Ver.1.0 www.njr.com V V A - 11 - Automotive NJW4750  ELECTRICAL CHARACTERISTICS (Unless otherwise noted, VVIN1=12V, VVIN2=VEN3=3.3V, RT=6.8k, RMODE= 82kΩ or 36kΩ, Ta=25C) Ch.3 (Selectable regulator: SW Reg. MODE) PARAMETER SYMBOL TEST CONDITION MIN. TYP. MAX. 2.10 2.25 2.40 2.10 – 2.40 2.00 2.15 2.30 2.00 – 2.30 50 100 – VFB3=0.75V 1.0 2.5 4.0 VFB3=0.75V Ta=-40C to +125C 0.5 – 4.5 RT=27k 250 280 310 RT=27k Ta=-40C to +125C 250 – 310 RT=6.8k 900 1000 1100 RT=6.8k Ta=-40C to +125C 900 – 1100 RT=1.8k 2200 2400 2600 RT=1.8k Ta=-40C to +125C 2200 – 2600 -1.0% 0.8 +1.0% -2.0% – +2.0% -0.1 – 0.1 -0.1 – 0.1 UNIT Under Voltage Lock Out Circuit Block VVIN2=L → H ON Threshold Voltage VT_ON3 VVIN2=L → H Ta=-40C to +125C VVIN2=H → L OFF Threshold Voltage VT_OFF3 VVIN2=H → L Ta=-40C to +125C Hysteresis Voltage VHYS3 V V mV Soft Start Block Soft Start Time tSS3 ms Oscillator Block Oscillating Frequency 1 Oscillating Frequency 2 Oscillating Frequency 3 fOSC31 fOSC32 fOSC33 kHz kHz kHz Error Amplifier Block Reference Voltage VB3 Input Bias Current IB3 Ver.1.0 Ta=-40C to +125C Ta=-40C to +125C www.njr.com V A - 12 - Automotive NJW4750  ELECTRICAL CHARACTERISTICS (Unless otherwise noted, VVIN1=12V, VVIN2=VEN3=3.3V, RT=6.8k, RMODE= 82kΩ or 36kΩ, Ta=25C) Ch.3 (Selectable regulator: SW Reg. MODE) PARAMETER SYMBOL TEST CONDITION MIN. TYP. MAX. VFB3=0.7V 100 – – VFB3=0.7V Ta=-40C to +125C 100 – – UNIT PWM Comparator Block Maximum Duty Cycle MAXDUTY3 % Minimum OFF Time tOFF3-min – 55 – ns Minimum ON Time tON3-min – 80 – ns Over Current Protection Circuit Block tCOOL3 RMODE=36k – 75 – ms Pch Output ON Resistance RONP3 ISW3SOURCE=0.5A – 0.5 0.8  Nch Output ON Resistance RONN3 ISW3SINK=0.5A – 0.3 0.5 0.7 1.0 1.3  A – – 4 A Cool Down Time Output Block Switching Current Limit Switching Leak Current Ver.1.0 ILIM3 ILEAK3 VEN3=0V, VVIN2=5.5V VSW3=0V Ta=-40C to +125C www.njr.com - 13 - Automotive NJW4750  ELECTRICAL CHARACTERISTICS (Unless otherwise noted, VVIN1=12V, VVIN2 =VEN3=3.3V, RT=6.8k, RMODE= OPEN or 10kΩ, Ta=25C) Ch.3 (Selectable regulator: LDO MODE) PARAMETER SYMBOL TEST CONDITION MIN. TYP. MAX. -1.0% 0.8 +1.0% -2.0% – +2.0% 300 600 – 300 – – – 0.003 0.009 – – 0.020 – 40 – UNIT Error Amplifier Block Reference Voltage Output Current VB3 IOUT3 Ta=-40C to +125C VOUT3×0.9 VOUT3×0.9 Ta=-40C to +125C IOUT3=1mA to 200mA Load Regulation ⊿VOUT3 /IOUT3 Ripple Rejection RR3 IOUT3=200mA – 0.2 0.3 Dropout Voltage ⊿VIO3 IOUT3=200mA Ta=-40C to +125C – – 0.4 ⊿VOUT3 /Ta IOUT3=150mA Ta=-20C to +75C – ±50 – Average Temperature Coefficient of Output Voltage Ver.1.0 IOUT3=1mA to 200mA Ta=-40C to +125C ein=50mVrms, f=1kHz VOUT3=2.5V, IOUT3=150mA www.njr.com V mA %/mA dB V ppm/C - 14 - Automotive NJW4750  ELECTRICAL CHARACTERISTICS (Unless otherwise noted, VVIN1=12V, VLDOVIN=VEN4 =3.3V, RT=6.8k, Ta=25C) Ch.4 (Low voltage LDO) PARAMETER SYMBOL TEST CONDITION MIN. TYP. MAX. -1.0% 0.8 +1.0% -2.0% – +2.0% 300 600 – 300 – – – 0.003 0.009 – – 0.020 – 40 – UNIT Error Amplifier Block Reference Voltage Output Current VB4 IOUT4 Ta=-40C to +125C VOUT4×0.9 VOUT4×0.9 Ta=-40C to +125C IOUT4=1mA to 200mA Load Regulation ⊿VOUT4 /IOUT4 Ripple Rejection RR4 IOUT4=200mA – 0.2 0.3 Dropout Voltage ⊿VIO4 IOUT4=200mA Ta=-40C to +125C – – 0.4 ⊿VOUT4 /Ta IOUT4=150mA Ta=-20C to +75C – ±50 – 1.0 – 5.5 1.0 – 5.5 0 – 0.4 0 – 0.4 – 7 14 – – 14 Rising 0.836 – 0.924 Rising, Ta=-40C to +125C Rising 0.836 – 0.924 0.745 – 0.775 Rising, Ta=-40C to +125C 0.745 – 0.775 Average Temperature Coefficient of Output Voltage IOUT4=1mA to 200mA Ta=-40C to +125C ein=50mVrms, f=1kHz VOUT4=2.5V, IOUT4=150mA V mA %/mA dB V ppm/C Enable Control Block (EN4) VEN4=L → H High Threshold Voltage Low Threshold Voltage Input Bias Current VTHH_EN4 VTHL_EN4 IEN4 VEN4=L → H Ta=-40C to +125C VEN4=H → L VEN4=H → L Ta=-40C to +125C VEN4=3.3V VEN4=3.3V Ta=-40C to +125C V V A Power Good Block (PG4) High Level Detection Reference Voltage VTHH_PG4 Low Level Detection Reference Voltage VTHL_PG4 Hysteresis Voltage VHYS_PG4 Power Good ON Resistance RON_PG4 Leak Current at OFF State Ver.1.0 ILEAK_PG4 V V – 16 – mV IPG4=10mA – 100 –  VPG4=5.5V – – 0.1 VPG4=5.5V Ta=-40C to +125C – – 0.1 www.njr.com A - 15 - Automotive NJW4750  ELECTRICAL CHARACTERISTICS (Unless otherwise noted, VVIN1=VEN1/SYNC=12V, VVIN2=VLDOVIN=VEN2=VEN3=VEN4=3.3V, RT=6.8k, Ta=25C) Common parameter PARAMETER SYMBOL TEST CONDITION MIN. TYP. MAX. – 2.3 3.5 – – 3.5 – 2 3 UNIT General Characteristic Quiescent Current 1 (VIN1) Quiescent Current 2 (VIN2) Quiescent Current 3 (LDOVIN) Standby Current 1 (VIN1) Standby Current 2 (VIN2) Standby Current 3 (LDOVIN) Ver.1.0 RL=no load, VFB1=0.9V IDD1 IDD2 IDDLDO IDD_STB1 IDD_STB2 IDD_STBLDO RL=no load, VFB1=0.9V Ta=-40C to +125C RL=no load VFB2=0.9V, VFB3=0.9V RL=no load VFB2=0.9V, VFB3=0.9V Ta=-40C to +125C RL=no load, VFB4=0.9V RL=no load, VFB4=0.9V Ta=-40C to +125C VEN1/SYNC=0V VEN2=0V VEN3=0V VEN4=0V VEN1/SYNC=0V VEN2=0V VEN3=0V VEN4=0V Ta=-40C to +125C VEN1/SYNC=0V VEN2=0V VEN3=0V VEN4=0V VEN1/SYNC=0V VEN2=0V VEN3=0V VEN4=0V Ta=-40C to +125C VEN1/SYNC=0V VEN2=0V VEN3=0V VEN4=0V VEN1/SYNC=0V VEN2=0V VEN3=0V VEN4=0V Ta=-40C to +125C www.njr.com mA mA – – 3 – 0.1 0.2 – – 0.2 – – 3 mA A – – 6 – – 2 A – – 4 – – 15 A – – 20 - 16 - Automotive NJW4750  THERMAL CHARACTERISTICS PARAMETER Junction-to-ambient Thermal resistance Junction-to-Top of package Characterization parameter SYMBOL VALUE UNIT (3) θja 146.3 (4) 50.5 ψjt 6.1 (4) 0.8 °C /W (3) °C /W (3): Mounted on glass epoxy board. (101.5×114.5×1.6mm:based on EIA/JEDEC standard,2layers, with Exposed Pad) (4): Mounted on glass epoxy board. (101.5×114.5×1.6mm:based on EIA/JEDEC standard,4layers, with Exposed Pad) (For 4Layers: Applying 99.5×99.5mm inner Cu area and a thermal via holes to a board based on JEDEC standard JESD51-5)  POWER DISSIPATION vs. AMBIENT TEMPERATURE Ver.1.0 www.njr.com - 17 - Automotive NJW4750  TYPICAL CHARACTERISTICS Ver.1.0 www.njr.com - 18 - Automotive NJW4750  TYPICAL CHARACTERISTICS Ver.1.0 www.njr.com - 19 - Automotive NJW4750  TYPICAL CHARACTERISTICS Ver.1.0 www.njr.com - 20 - Automotive NJW4750  TYIPICAL CHARACTERISTICS Ver.1.0 www.njr.com - 21 - Automotive NJW4750  TYPICAL CHARACTERISTICS Ver.1.0 www.njr.com - 22 - Automotive NJW4750  TYPICAL CHARACTERITICS Ver.1.0 www.njr.com - 23 - Automotive NJW4750  TYPICAL CHARACTERISTICS Ver.1.0 www.njr.com - 24 - Automotive NJW4750  TYPICAL CHARACTERISTICS Ver.1.0 www.njr.com - 25 - Automotive NJW4750  TYPICAL CHARACTERISTICS Ver.1.0 www.njr.com - 26 - Automotive NJW4750  TYIPICAL CHARACTERISTICS Ver.1.0 www.njr.com - 27 - Automotive NJW4750 Technical Information  INTRODUCTION Please note the following when using NJW 4750.  The NJW 4750 can operate each Ch. independently. However, even if Ch.1 is not used, it is necessary to input a power supply to VIN1 pin.  Ch.3 (LDOMODE) and Ch.4 need to be start-up after power Ch. becomes active. The LDO may not be start-up by the protection function. e.g. The case of using Ch.1 as a power supply for Ch.4. It becomes the start of Ch.4 after normal start of Ch.1 by connecting PG1 pin of Ch.1 to EN4 pin of Ch.4.  PIN DESCRIPTION PIN NO. SYMBOL 1 GND Ground pin. 2 EN3 This pin controls the operation and stop of Ch.3. High Level: operation, Low level or Open level: Standby mode. 3 FB3 4 NC 5 FB2 6 EN2 This pin controls the operation and stop of Ch.2. High Level: operation, Low level or Open level: Standby mode. 7 RT Oscillation frequency setting pin by Timing Resistor. Oscillating frequency should set between 280kHz and 2.4MHz. 8 GND Ground pin. 9 PG1 Power-good output of Ch.1 configured with open drain. 10 MODE 11 FB1 12 EN1/SYNC 13 VIN1 14 GND Ground pin. 15 SW1 Ch.1 Output. 16 EN4 This pin controls the operation and stop of Ch.4. High Level: operation, Low level or Open level: Standby mode. 17 LDOVOUT 18 FB4 19 LDOVIN 20 PG4 Power-good output of Ch.4 configured with open drain. 21 GND Ground pin. 22 SW2 Ch.2 Output. 23 PG2 Power-good output of Ch.2 configured with open drain. 24 VIN2 25 PG3 Power-good output of Ch.3 configured with open drain. 26 SW3 Ch.3 Output. Exposed PAD Ver.1.0 - DESCRIPTION This pin detects the output voltage of Ch.3. The output voltage is divided and inputted so that the FB pin voltage becomes 0.8V same as the reference voltage. Non connection. This pin detects the output voltage of Ch.2. The output voltage is divided and inputted so that the FB pin voltage becomes 0.8V same as the reference voltage. This pin is used to determine the operation mode. Connect an open or mode setting resistor. This pin detects the output voltage of Ch.1. The output voltage is divided and inputted so that the FB pin voltage becomes 0.8V same as the reference voltage. This pin controls the operation and stop of Ch.1. High Level: operation, Low level or Open level: Standby mode. By inputting the clock signal, it operates synchronized with the input signal. Power supply input for IC and Ch.1. Since the impedance of the power supply path needs to be lowered connecting a capacitor (CIN) near the IC is required. Ch.4 Output This pin detects the output voltage of Ch.4. The output voltage is divided and inputted so that the FB pin voltage becomes 0.8V same as the reference voltage. Power supply input for Ch.4. Since the impedance of the power supply path needs to be lowered connecting a capacitor (CIN) near the IC is required. Power supply input for Ch.2 and Ch.3. Since the impedance of the power supply path needs to be lowered connecting a capacitor (CIN) near the IC is required. Exposed PAD on backside should be connected to the ground and soldered to PCB. www.njr.com - 28 - Automotive NJW4750 Technical Information  DESCRIPTION OF BLOCK FEATURES 1. Mode setting By connecting the resistor between the MODE pin and GND, the operation mode of Ch.3 and protection type of OCP are selected.(Table 1) Table 1 The NJW4750 operation mode and setting resistor value. Setting resistor RMODE(±5%) MODE Min 1 Ch.3 OCP Mode MODE Pin Output Voltage (±5%) LDO Latch 2.5V Max open 2 82kΩ 110kΩ SW reg. Latch 1.4V 3 27kΩ 39kΩ SW reg. Hiccup(SW) Foldback(LDO) 1.2V 4 6.8kΩ 15kΩ LDO Hiccup(SW) Foldback(LDO) 1.0V The mode setting can be set only at startup, and the state of the mode can be checked by pin voltage. 2. Basic functions of switching regulator. (Ch.1,2 and Ch.3)  Error Amplifier Section (Error AMP) 0.8V±1% precise reference voltage is connected to the non-inverted input of this section. The output voltage can be set by dividing the output of the converter and connecting to the inverted input (FB pin).  PWM comparator section (PWM), oscillating circuit Section (OSC) Oscillating frequency can be set by inserting resistor between the RT pin and GND. Table 2 shows example of oscillating frequency and timing resistor. The resistance is adapted to a series of E24 and a series of E96. Please set the oscillating frequency according to Table 2 Table 2 The NJW4750 oscillating frequency and timing resistor value Oscillating Frequency (kHz) Timing Resistor (k) Oscillating Frequency (kHz) Timing Resistor (k) 280 27 1200 5.6 380 20 1750 3.9 500 15 2000 3.0 700 10 2250 2.0 1000 6.8 2400 1.8 NJW4750 is limited in minimum ON time and minimum OFF time, refer to electrical characteristics. Maximum duty cycle is 100%. When you design the application, please refer to "Application information - Oscillating frequency setting". Ver.1.0 www.njr.com - 29 - Automotive NJW4750 Technical Information  DESCRIPTION OF BLOCK FEATURES (Continued)  Power MOSFET The power is stored in the inductor by the switch operation of built-in power MOSFET. The switching current is limited by the overcurrent protection function.  Power supply, GND pin(VIN、GND) Current flows into the IC according to drive frequency in a switching element. When impedance of a power supply line is high, power supply will be unstably, and the performance of the IC can't be drawn out sufficiently. Therefore, since the impedance of the power supply path needs to be lowered connecting a capacitor (CIN) near the IC is required. 3. Additional and protection functions of switching regulator. (Ch.1,2 and Ch.3 are similar)  Under voltage lockout (UVLO) The UVLO circuit stops the IC operation in a low power supply voltage case, and when a power supply voltage becomes higher voltage than threshold, then the IC operation starts. The threshold voltage has a hysteresis voltage width at rising and falling. A flutter of detection and release of UVLO is prevented by it.  Soft start function The output voltage of the converter gradually rises to a set value by the soft start function. The soft start time is 4ms (max.). It is defined with the time of the error amplifier reference voltage becoming from 0V to 0.75V.(Fig.1) Soft start operating condition. ・ Ch.1: VVIN1≧VT_ON1、VEN1≧VTHH_EN1 ・ Ch.2: VVIN1≧VT_ON1、VVIN2≧VT_ON2、VEN2≧VTHH_EN2 ・ Ch.3: VVIN1≧VT_ON1、VVIN2≧VT_ON2、VEN3≧VTHH_EN3 Also thermal shutdown must be disabled. Fig.1 Soft start timing chart Ver.1.0 www.njr.com - 30 - Automotive NJW4750  DESCRIPTION OF BLOCK FEATURES (Continued) Technical Information  Over current protection circuit (OCP) (Ch.1,2 and Ch.3 are similar) Switching regulator block of NJW4750 has 2 kinds of overcurrent protection function. 1. Hiccup (Fig.2): Switching operation is reduced and output is restricted. When the load state normally returns, it is reset automatically. 2. Latch (Fig.3): The function as the power supply is suspended. Latch is released by setting all EN pin to Low or VIN1 pin to 0 V. ※ Hiccup system is each Ch. Independent control. Latch system suspends all output of IC. Operating condition of OCP In the soft start operating, Hiccup/Latch becomes ineffective. The overcurrent protection function operates when one of them of 2 conditions was formed.  VFBx0.4V and 7cycle over current detection continuously.  Overcurrent detection continuously of 1/fosc×240 s. Fig.2 Hiccup mode OCP timing chart Fig.3 Latch mode OCP timing chart Ver.1.0 www.njr.com - 31 - Automotive NJW4750  DESCRIPTION OF BLOCK FEATURES (Continued) Technical Information  External clock synchronization (Ch.1,2 and Ch.3) By inputting a square wave to EN1/SYNC pin, the oscillator of NJW4750 can be synchronized to an external frequency. The input square wave must be on the following specification. (Table 3) Table 3 The input square wave to EN1/SYNC pin. Condition Input Frequency Duty Cycle Voltage Magnitude fOSC0.9 to fOSC1.7 Upper limit 2,800kHz 40% to 60% 1.6V or more (High level) 0.4V or less (Low level) Fig.4 Switching operation by external synchronized clock Ver.1.0 www.njr.com - 32 - Automotive NJW4750  DESCRIPTION OF BLOCK FEATURES (Continued) Technical Information 4. Basic functions of LDO (Ch.3 LDO MODE and Ch.4)  Error amplifier section (Error AMP) 0.8V±1% precise reference voltage is connected to the non-inverted input of this section. The output voltage can be set by dividing the output of the converter and connecting to the inverted input (FB pin). 5. Additional and protection functions of LDO (Ch.3 LDO MODE and Ch.4)  Over current protection circuit(OCP) LDO block of NJW4750 can choose 2 kinds of overcurrent protection function. 1. Fold back: Limits the output current as the output voltage decreases. 2. Latch: The function as the power supply is suspended at VFBx 0.4V. Latch is released by setting all EN pin to Low or VIN1 pin to 0V. ※ Fold back system is independent each Ch. Latch system suspends all output of IC. 6. Common protection function / features  Thermal shutdown function (TSD) When junction temperature of the NJW4750 exceeds the 160°C*, internal thermal shutdown circuit function stops SW function. When junction temperature decreases to 145°C* or less, SW operation re-start from the soft start operation. The purpose of this function is to prevent malfunctioning of IC at the high junction temperature. Therefore it is not something that urges positive use. Please make sure to operate within the junction temperature range rated (-40°C to 150°C). (* Design value)  Standby function Each Ch. stops the operating and becomes standby status when the ENx(/SYNC) pin becomes less than 0.4V. The ENx(/SYNC) pins are internally pulled down with resistor (CH1 :5MΩ、CH2 :500kΩ、CH3 :500kΩ、CH4 :500kΩ), therefore the NJW4750 becomes standby mode when it is OPEN. Please connect this pin to VINx when you do not use standby function. Ver.1.0 www.njr.com - 33 - Automotive NJW4750  DESCRIPTION OF BLOCK FEATURES (Continued) Technical Information  Power Good function It monitors the output status and outputs a signal from PGx pin that is internally connected to an open drain of MOSFET. If the FB pin is within the range of -7% to + 15% of the error amplifier reference voltage, the PG pin becomes high impedance and notifies that the output voltage is normal. Otherwise the PG pin becomes low level and tells the output voltage is abnormal. After soft start time, the Power Good function becomes effective in Ch.1, Ch.2, and Ch.3. The Power Good function of Ch.4 becomes effective after passage for 150μs from EN4: H(@LDOVIN=3.3V). When ENx pin control is performed by PGx pin, consider the input resistance value of ENx pin. Fig.5 Power Good function timing chart  Latch mode: added 1/fosc×40000 s delay in the last boot Ch. Fig.6 Power Good function timing chart at Latch mode Ver.1.0 www.njr.com - 34 - Automotive NJW4750  APPLICATION INFORMATION(Switching regulator) Technical Information  Oscillating frequency setting When a switching frequency is high, a small inductor and capacitor are available. If oscillating frequency is high, decrease in efficiency and a limit of the minimum ON time and minimum OFF time are demerit. The buck converter of ON time and OFF time is decided the following formula. tON = (VOUT +VL ) [s] (VIN -VSWH +VL )×fOSC tOFF = 1 fOSC -tON [s] VIN:Input voltage VOUT:Output voltage VSWH:High-side saturation voltage VL:Catch Diode Vf or Lo-side saturation voltage VSWL When the ON time becomes shorter than tON-MIN or OFF time becomes shorter than tOFF-MIN, a change of duty or pulse skip operation may be performed in order to maintain output voltage at a stable state.  Inductors Since a large current flows into an inductor, please select an appropriate inductor such as not saturate in the application. Inductors have an important role in slope compensation. Inductor value is limited selection by supply voltage and oscillation frequency. Recommended selection of the inductor value is between Hlim. and Llim. shown in Fig.8. The maximum Output current of worst condition is decided the following formula. ∆IL = (VIN -VOUT )×VOUT [A] L×VIN ×fOSC IOUT =ILIMx(MIN) - ∆IL [A] 2 Fig.7 Inductor current state transition (Continuous conduction mode) Ver.1.0 www.njr.com - 35 - Automotive NJW4750  APPLICATION INFORMATION(Switching regulator) Technical Information VOUT1=5V VOUT1=3.3V VOUT2/3=1.8V VOUT2/3=1.2V Fig.8 Inductance range.  Input capacitor Transient current which is responsive to frequency flows into the input section of a switching regulator. When impedance of a power supply line is high, power supply will be unstably, and the performance of the IC can't be drawn out sufficiently. Therefore, since the impedance of the power supply path needs to be lowered connecting a capacitor (CIN) near the IC is required. The effective input current can be expressed by the following formula. IRMS =IOUT × √VOUT ×(VIN -VOUT ) [Arms ] VIN In the above formula, the maximum current is obtained when VIN=2×VOUT, and the result in this case is IRMS=IOUT(MAX)÷2. When the input capacitor in selecting, please carry out an evaluation based on an application, and decide a capacitor value that has adequate margin. Ver.1.0 www.njr.com - 36 - Automotive NJW4750 Technical Information  APPLICATION INFORMATION(Switching regulator)  Output capacitor An output capacitor stores power from the inductor, and stabilizes voltage provided to the output. The NJW4750 is designed phase compensation so that output capacitor of low ESR can be used. Therefore a ceramic capacitor is the most suitable. Since capacity of a ceramic capacitor may decline by DC supply voltage and temperature change, please confirm it's characteristics on specification sheet. When selecting an output capacitor, must be considered Equivalent Series Resistance (ESR) characteristics, ripple current, and breakdown voltage. In case of using a low ESR capacitor, it's possible to lower the ripple voltage. The output ripple noise can be expressed by the following formula. Vripple(p-p) =∆IL × (ESR+ 1 ) [V] 8×fOSC ×COUT The effective ripple current that flows in a capacitor (IRMS) is obtained by the following equation. IRMS = ∆IL 2√3 [Arms ]  Setting of phase compensation The NJW 4750 has a built-in phase compensation circuit. Table 4 shows the values of extern al parts based on oscillation frequency and output voltage. Table 4 Value of phase compensation fOSC 1MHz or more 500kHz or less VOUT COUT CFB RFB R2 2.5V, 2.8V, 3.3V, 3.6V, 5V 1.8V 1.1V*, 1.2V* ALL 10μF or more 22pF 1kΩ 30kΩ to 82kΩ 1kΩ 1kΩ open 30kΩ to 82kΩ 30kΩ to 82kΩ 30kΩ to 82kΩ 22μF or more 22pF 47μF or more 22pF 100μF or more open * VVIN2 is 4 V or less. If VVIN2 is set to higher than 4 V, the oscillating frequency is limited up to 1.5MHz. Ver.1.0 www.njr.com - 37 - Automotive NJW4750  APPLICATION INFORMATION(Switching regulator) Technical Information  Catch diode When the switch element is in OFF cycle, the power stored in the inductor flows to the output capacitor via the catch diode. Therefore an electric current according to the load current flows to the diode every cycle. Since a diode's forward saturation voltage and current accumulation cause power loss, a Schottky Barrier Diode (SBD), which has a low forward saturation voltage, is most suitable. When select the SBD, the reverse current at the high temperature is important, too. The characteristic of SBD has a high reverse current than a general diode. If the reverse current is large, it leads to the loss of the diode, so check the specification of the SBD  Setting output voltage The output voltage VOUT is determined by the relative resistances of R1, R2. R2 VOUT = ( +1) ×VB [V] R1 Fig.9 Output voltage setting Ver.1.0 www.njr.com - 38 - Automotive NJW4750 Technical Information  APPLICATION INFORMATION(Switching regulator)  Board layout In the switching regulator application, since the current flow according to the oscillating frequency, the substrate (PCB) layout is very important. Therefore, a current flowing line must be wide and short as much as possible. Fig.10 shows a current loop of a step-down converter. (In case of synchronous rectification, SBD is changed to built-in SW.) Especially, the loop of CIN - SW - SBD which has a high frequency switching, is necessary to configure minimum loop as top priority. It is effective in reducing of spike noise caused by parasitic inductor. NJW4750 Built-in SW VIN CIN SBD NJW4750 Built-in SW L COUT VIN CIN L SBD COUT (a) Buck converter SW ON (b) Buck converter SW OFF Fig.10 Current loop of buck converter About concerning the GND, it is preferred to separate the power GND and the signal GND, and use single ground point. The voltage sensing feedback line should be away as far away as possible from the inductor. Since this line has high impedance, it is laid out to avoid the influence noise caused by leakage flux from the inductor. Fig.11 shows example of wiring at buck converter. To avoid the influence of the voltage drop, the output voltage should be detected near the load. Separate Signal GND Since FB pin is high impedance, the from Power GND voltage detection resistor: R1/R2 is placed from IC(FB) as near as possible. Fig.11 Board layout for buck Converter Ver.1.0 www.njr.com - 39 - Automotive NJW4750 Technical Information  APPLICATION INFORMATION(LDO)  Setting of output voltage The output voltage VOUT is determined by the relative resistances of R1, R2. R2 VOUT = ( +1) ×VB [V] R1 Fig.12 Output voltage setting  Setting of phase compensation The NJW 4750 has a built-in phase compensation circuit. Table 5 shows the values of external parts based on output voltage. Table 5 Value of phase compensation Ver.1.0 VOUT COUT R2 ALL 6.8μF to 22μF 47kΩ www.njr.com - 40 - Automotive NJW4750 Technical Information  CALCULATION OF PACKAGE POWER The loss of NJW 4750 is the sum of the loss due to switching converter and the loss due to LDO.  Switching convertor Input Power :PIN = VIN  IIN [W] Output Power :POUT = VOUT  IOUT [W] Diode Loss :PDIODE = VF  IL(avg)  OFF duty [W] Power Consumption :PLOSS = PIN  POUT  PDIODE [W] Where: VIN VOUT VF OFF Duty :Input Voltage of Converter :Output Voltage of Converter :Diode's Forward Saturation Voltage :Switch OFF Duty Cycle  LDO Input Power Output Power Power Consumption Where: VIN VOUT IIN IOUT IL(avg) :Input Current of Converter :Output Current of Converter :Inductor Average Current IIN IOUT :Input Current of LDO :Output Current of LDO :PIN = VIN  IIN [W] :POUT = VOUT  IOUT [W] :PLOSS = PIN  POUT [W] :Input Voltage of LDO :Output Voltage of LDO Efficiency (η) is calculated as follows. η= (POUT  PIN)  100 [%] Please consider temperature derating to the calculated power consumption. Please consider design power consumption in rated range referring to the power dissipation vs. ambient temperature characteristics. Ver.1.0 www.njr.com - 41 - Automotive NJW4750 Technical Information  APPLICATION DESIGN EXAMPLES Spec IC: NJW4750 Output: 3.3V (Ch.1) 1.8V (Ch.2) 1.2V (Ch.3) 2.8V (Ch.4) Oscillating frequency: 2.0MHz Schematic Parts list Ref. Part number Overview Manufacture IC CIN1 CIN2 CLDOIN RT L1 SBD COUT1 CFB1 RFB1 R11 R12 L2 COUT2 CFB2 RFB2 R21 R22 L3 COUT3 CFB3 RFB3 R31 R32 CLDOOUT R41 R42 RMODE NJW4750MHH-T1 CGA4J3X5R1H475K125AB GRT188C81C106ME13# GRT188C81C106ME13# 3.0kΩ VLS4012ET-1R5N CMS14 GRT188C81C106ME13# 22pF 1kΩ 24.3kΩ 76.8kΩ VLS3015ET-2R2M GRM21BB30J226ME38L 22pF 1kΩ 24kΩ 30kΩ VLS3015ET-2R2M JMK212BBJ476MG-T 22pF 1kΩ 75kΩ 37.4kΩ GRT188C81C106ME13# 18.7kΩ 47.5kΩ 30kΩ Quad Channel Combination Regulator Ceramic Capacitor 2125 4.7uF, 50V Ceramic Capacitor 1608 10uF, 16V Ceramic Capacitor 1608 10uF, 16V Resistor 1608 3.0kΩ, ±1%, 0.1W inductor 1.5uH, 2.1A Schottky Diode 60V, 2A Ceramic Capacitor 1608 10uF, 16V Ceramic Capacitor 22pF, 50V Resistor 1kΩ, ±1%, 0.1W Resistor 24.3kΩ, ±1%, 0.1W Resistor 76.8kΩ, ±1%, 0.1W inductor 2.2uH, 1.5A Ceramic Capacitor 2125 22uF, 6.3V Ceramic Capacitor 22pF, 50V Resistor 1kΩ, ±1%, 0.1W Resistor 24kΩ, ±1%, 0.1W Resistor 30kΩ, ±1%, 0.1W inductor 2.2uH, 1.5A Ceramic Capacitor 2125 47uF, 6.3V Ceramic Capacitor 22pF, 50V Resistor 1kΩ, ±1%, 0.1W Resistor 75kΩ, ±1%, 0.1W Resistor 37.4kΩ, ±1%, 0.1W Ceramic Capacitor 1608 10uF, 16V Resistor 18.7kΩ, ±1%, 0.1W Resistor 47.5kΩ, ±1%, 0.1W Resistor 30kΩ, ±1%, 0.1W/SW_Hiccup MODE New Japan Radio TDK MURATA MURATA Std. TDK TOSHIBA MURATA Std. Std. Std. Std. TDK MURATA Std. Std. Std. Std. TDK TAIYO YUDEN Std. Std. Std. Std. MURATA Std. Std. Std. Ver.1.0 www.njr.com - 42 - Automotive NJW4750 Technical Information  APPLICATION CHARACTERISTICS Ver.1.0 www.njr.com - 43 - Automotive NJW4750 EQFN26-HH  PACKAGE/ FOOTPATTERN Unit: mm PACKAGE DIMENSIONS EXAMPLE OF SOLDER PADS DIMENSIONS 3.4 ±0.05 R0 .3 7 2.32 0.31 0.4 2.8 0.4 1.52 0.2 0.2 3.6 S 0.2 +0.010 -0.008 S 0. 7 ± 0.05 0.1 2.6 ± 0.05 0.1 0.01 0.05 S 0.21 ± 0.05 A C0 0.4 .4 1.59 ± 0.05 B 3 0 -R .4 2.39 ±0.05 0.2 ±0.05 Ver.1.0 0.05 M S AB www.njr.com - 44 - Automotive NJW4750 EQFN26-HH  PACKAGING INFORMATION Unit: mm TAPING DIMENSIONS Feed direction P0 φD0 SYMBOL A B D0 D1 E F P0 P1 P2 T T2 K0 W W1 T B W1 W F E P2 A φD1 P1 K0 T2 DIMENSION 2.8±0.05 3.6±0.05 1.5 +0.1 0 1.0 +0.1 0 1.75±0.1 5.5±0.05 4.0±0.1 8.0±0.1 2.0±0.05 0.25±0.05 1.2 0.85±0.05 +0.3 12.0 -0.1 9.5 REMARKS BOTTOM DIMENSION BOTTOM DIMENSION THICKNESS 0.1max REEL DIMENSIONS W1 E SYMBOL A B C D E W W1 B A D C DIMENSION φ180 -30 φ 60 +10 φ 13±0.2 φ 21±0.8 2±0.5 13 +1.0 0 15.4±1.0 W TAPING STATE Insert direction Sealing with covering tape (TE1) Feed direction Empty tape Devices Empty tape Covering tape more than 20pitch 1500pcs/reel more than 15pitch reel more than 1round PACKING STATE Label Label Put a reel into a box Ver.1.0 www.njr.com - 45 - Automotive NJW4750  RECOMMENDED MOUNTING METHOD INFRARED REFLOW SOLDERING METHOD Recommended reflow soldering procedure f 260°C e 230°C 220°C d 180°C 150°C Room Temp. a a:Temperature ramping rate b:Pre-heating temperature time c:Temperature ramp rate d:220℃ or higher time e:230℃ or higher time f:Peak temperature g:Temperature ramping rate b c g : 1 to 4°C /s : 150 to 180°C : 60 to 120s : 1 to 4°C /s : Shorter than 60s : Shorter than 40s : Lower than 260°C : 1 to 6°C /s The temperature indicates at the surface of mold package. Ver.1.0 www.njr.com - 46 - Automotive NJW4750  REVISION HISTORY DATE REVISION CHANGES 15.Jun.2018 Ver.1.0 New release Ver.1.0 www.njr.com - 47 - Automotive NJW4750 [ CAUTION ] 1. New JRC strives to produce reliable and high quality semiconductors. New JRC's semiconductors are intended for specific applications and require proper maintenance and handling. To enhance the performance and service of New JRC's semiconductors, the devices, machinery or equipment into which they are integrated should undergo preventative maintenance and inspection at regularly scheduled intervals. Failure to properly maintain equipment and machinery incorporating these products can result in catastrophic system failures 2. The specifications on this datasheet are only given for information without any guarantee as regards either mistakes or omissions. The application circuits in this datasheet are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. All other trademarks mentioned herein are property of their respective companies. 3. To ensure the highest levels of reliability, New JRC products must always be properly handled. The introduction of external contaminants (e.g. dust, oil or cosmetics) can result in failures of semiconductor products. 4. New JRC offers a variety of semiconductor products intended for particular applications. It is important that you select the proper component for your intended application. You may contact New JRC's Sale's Office if you are uncertain about the products listed in this catalog. 5. Special care is required in designing devices, machinery or equipment which demand high levels of reliability. This is particularly important when designing critical components or systems whose failure can foreseeably result in situations that could adversely affect health or safety. In designing such critical devices, equipment or machinery, careful consideration should be given to amongst other things, their safety design, fail-safe design, back-up and redundancy systems, and diffusion design. 6. The products listed in the catalog may not be appropriate for use in certain equipment where reliability is critical or where the products may be subjected to extreme conditions. You should consult our sales office before using the products in any of the following types of equipment. Aerospace Equipment Equipment Used in the Deep sea Power Generator Control Equipment (Nuclear, Steam, Hydraulic) Life Maintenance Medical Equipment Fire Alarm/Intruder Detector Vehicle Control Equipment (airplane, railroad, ship, etc.) Various Safety devices 7. New JRC's products have been designed and tested to function within controlled environmental conditions. Do not use products under conditions that deviate from methods or applications specified in this catalog. Failure to employ New JRC products in the proper applications can lead to deterioration, destruction or failure of the products. New JRC shall not be responsible for any bodily injury, fires or accident, property damage or any consequential damages resulting from misuse or misapplication of its products. Products are sold without warranty of any kind, either express or implied, including but not limited to any implied warranty of merchantability or fitness for a particular purpose. 8. Warning for handling Gallium and Arsenic(GaAs) Products (Applying to GaAs MMIC, Photo Reflector). This Products uses Gallium(Ga) and Arsenic(As) which are specified as poisonous chemicals by law. For the prevention of a hazard, do not burn, destroy, or process chemically to make them as gas or power. When the product is disposed, please follow the related regulation and do not mix this with general industrial waste or household waste. 9. The product specifications and descriptions listed in this catalog are subject to change at any time, without notice. Ver.1.0 www.njr.com - 48 -
