RUH-1S109R1A
RUH-1S109R1A
    UDE
    RUH-1S109R1A
RUH-1S109R1A 数据手册
T : To: Customer P/N: UDE P/N: RUH-1S109R1A Description: USB 2.0 over RJ45 Tab Down Through Hole 10/100/1000 Base-T Contact Area : Gold Flash LED:L-Green/Yellow; R-Green/Yellow Spec No. RUH005-00 Approved Checked Update Date 2010/11/24 Prepared RUH-1S109R1A Spec No. : RUH005-00 1. MECHANICAL DIMENSION 1.1 Product Dimension General Tolerance : -1- X.X : ± 0.25 X XX : ± 0 13 X.XX 0.13 www.ude-corp.com RUH-1S109R1A Spec No. : RUH005-00 1.2 Recommened PCB Layout Component Side of Board p All dimension tolerance are ±0.05mm unless otherwise specified -2- www.ude-corp.com RUH-1S109R1A Spec No. : RUH005-00 1.3 Standard RJ45 Plug Specification - All dimensions follow : FCC subpart F, 68,500, Figure (C)(2)(i) & (C)(2)(ii) & (C)(3)(i) IEC 60603-7 - All plugs must be meeting the requirements of plug Go & No-Go No Go gauge. Gauge follow : FCC subpart F, 68,500, Figure (C)(4)(i) & (C)(5)(i) - There must be no damage to Housing and Locking Latch. - There must be no nicks and cuts in cable. - Durability : 750 cycles generally -3- www.ude-corp.com RUH-1S109R1A Spec No. : RUH005-00 1.4 Standard USB 2.0 Plug Specification - All dimensions follow : Universal Series Bus Specification 2.0 (April 27,2000) Figure 6-9. USB Series A Plug Interface Drawing -4- www.ude-corp.com RUH-1S109R1A Spec No. : RUH005-00 2. REQUIREMENTS 2.1 Design g and Construction Product shall be of design, construction and physical dimensions specified on applicable. 2.2 Material 2.2.1 Terminal Parts (Underplating : 30μ" min. Nickel overall) 2.2.1.1 RJ Terminal : PH. Bronze, Thickness=0.30mm Finish : Contact Area : Gold Flash 2.2.1.2 USB Terminal : PH. Bronze, Thickness=0.25mm Finish : Contact Area : Gold Flash Solder Tail : 100μ" min. Tin 2.2.1.3 Input Terminal : Brass, Thickness=0.35mm Finish : 100μ" min. Tin 2.2.2 Plastic Parts 2.2.2.1 RJ Housing : High Temperature Thermoplastic, Black 2.2.2.2 USB Housing : Thermoplastic, Black 2.2.2.3 USB Holder : Thermoplastic, Black 2.2.2.4 2 2 2 4 Spacer : Thermoplastic, Thermoplastic Black 2.2.3 Shield Parts 2.2.3.1 Front Shield : Stainless, Thickness=0.20mm, unplating Thickness=0.20mm, 2.2.3.2 Back Shield : Stainless, Thickness 0.20mm, Pre-soldering Pre soldering 2.2.3.3 USB Shield : Stainless, Thickness=0.25mm, unplating -5- www.ude-corp.com RUH-1S109R1A Spec No. : RUH005-00 2.3 Operating and Storage Temperature Operating : 0°C to +70°C p g Temperature p Storage Temperature : -40°C to +85°C 2.4 RJ45 specifications Insulation Resistance 500MΩ min. Insertion force with the latch depressed 22N max Removal force with the latch depressed 44N max Locking Force of Plug Latch : 50N min. @ 60+/-5 sec Durability : 750 cycles 2.5 USB 2.0 specifications Insulation Resistance 1000MΩ min. Dielectric Withstanding Voltage : 500Vac @1min Insertion force : 35N max Removal force : 10N min D bili : 1500 cycles Durability l 2.6 Performance and Test Description Product is designed to meet electrical, mechanical and environmental performance requirements specified in below table. All tests are performed at ambient environmental conditions per MIL MIL-STD-1344A STD 1344A and EIA-364 EIA 364 unless otherwise specified. 2.7 Packaging and Packing All parts shall be packaged and packed to protect against physical damage、corrosion and deterioration during shipment and storage. -6- www.ude-corp.com RUH-1S109R1A Spec No. : RUH005-00 3. ELECTRICAL CHARACTERISTICS 3.1 Schematic RJ45 OUTPUT INPUT VCC  R1 1:1 0.1μF TD1+ R2 C1  TX1+ 75Ω TD1‐ R3 1:1 0.1μF TD2+  R4 C2  TX1‐ C3  TX2+ 75Ω TD2‐ R5 1:1 0.1μF TD3+  R6 C6  TX2‐ C4  TX3+ 75Ω TD3‐ R7 1:1 0.1μF 0 μ TD4+ R8 TD4+  R8 C5  TX3‐ C7 TX4+ C7  TX4+ 75Ω TD4‐ R9 GND  R10 C8  TX4‐ 2KV 1000pF Shield L3 Yellow L1 Green L4 Yellow Green L2 Emitting Color λp (nm) Vf @If=20mA Green 565 1.7 ~2.6 V 585 1 7 ~2.6 26V Yellow 1.7 -7- Ir @Vr=5V 10μA max. 10μA max max. www.ude-corp.com RUH-1S109R1A Spec No. : RUH005-00 3.2 Transmitter filter & Receiver filter Type yp : Balance low pass p 100Ω impedance p Insertion loss : 1~100 MHz -1.0dB max. Return loss : 1~30 MHz -18dB min. load 100Ω 30~60MHz -16dB min. load 100Ω 60~80MHz -12dB min. load 100Ω 80~100MHz -10dB min. load 100Ω 3.3 Common Mode Rejection @ 1~100 MHz -30dB min. 3.4 Cross Talk @ 1~100 MHz -30dB min. 3.5 Inductance @ 100KHz, 0.1V, 8mA DC BIAS Input(R2-R3), Input(R4-R5), Input(R6-R7), Input(R8-R9)350 μH min. 3.6 Hi-Pot Test Input(R2-R3) To Output(C1-C2) : 1500Vac 60s or 2250Vdc 60s Input(R4-R5) To Output(C3-C6) : 1500Vac 60s or 2250Vdc 60s Input(R6-R7) To Output(C4-C5) : 1500Vac 60s or 2250Vdc 60s Input(R8-R9) Input(R8 R9) To Output(C7-C8) Output(C7 C8) : 1500Vac 60s or 2250Vdc 60s -8- www.ude-corp.com RUH-1S109R1A Spec No. : RUH005-00 4. ORDER INFORMATION R U H - 1 S 10 A B 9R1 C A D A. LED Code : L-Green/Yellow; R-Green/Yellow. B. Mechanical Code : w/ UDE Logo, w/ all Spring C. Schematics Code : 9R1 : 9R1 circuit D. Plating Code : Underplating 30μ" min. Nickel overall Solder Tail 100μ" min. Bright Tin Contact Area 100μ" min. Matted Tin A : Gold Flash 1 : Gold Flash C : 6μ" gold 6 : 6μ" gold ld B : 10μ" gold D : 15μ" gold 2 : 15μ" gold F : 30μ" gold 3 : 30μ" gold G : 50μ 50μ" gold 4 : 50μ 50μ" gold -9- www.ude-corp.com RUH-1S109R1A Spec No. : RUH005-00 5. DIPPING TEMPERATURE PROFILE - 10 - www.ude-corp.com
RUH-1S109R1A 价格&库存
很抱歉,暂时无法提供与“RUH-1S109R1A”相匹配的价格&库存,您可以联系我们找货
