LCM1602K-FL-YBW
LCM1602K-FL-YBW
    OTHER
    Module
    LCM1602K-FL-YBW
LCM1602K-FL-YBW 数据手册
LONGTECH OPTICS Pin connections LCM1602K LCM1602K-FL-YBW 显示模式:黄绿底色,VDD=5V PIN NO Symbol 1 VSS 2 VDD 3 V0 3.51 4 RS 3.00 0.56 5 R/W 6 E 7 DB0 8 DB1 9 DB2 10 DB3 11 DB4 12 DB5 13 DB6 14 DB7 15 A 16 K T2 0.05 1.6 Feature DB0-DB7 COM 1 2 3 4 5 --- --- --- --- 14 15 16 DDRAM address 00 01 02 --- --- --- --- --0EH 0FH DDRAM address 40 41 42 --- --- --- --- --4EH 4FH LCD DRIVER A K LED BKL T1 T2 UNIT Without or EL backlight 4.6 9.5 8.6 13.5 8.6 13.5 mm mm mm With LED bottom backlight SEG SEG LCD module thinkness With edge LED backlight LCD PANEL Standard Symbol Min Typ Max Input voltage VI -0.3 -------- 5.5 Power supply VDD-VSS -0.3 -------- VDD Unit V Electronical characteristics Mechanical thinkness LCD CONTROLLER AND DRIVER Item Display position Block diagram: VDD VSS V0 RS R/W E Absolute Maximum Rating Display character address code 1. 2-line x16 characters display; 5x8 dots with cursor 2. Built-in controller (KS0066U or Equivalent) 3. +5V power supply(Also available for +3.3V) 4. 1/16 duty cycle;1/5bias; 5. TN, HTN, STN or FSTN mode 6. BKL to be driven by pin1,pin2,or pin15,pin16,or A,K 0.05 5.23 0.61 5.75 T1 Mechanical data Item Standard Unit Module dimension 84.0x44.0 mm Item Symbol Input voltage VDD Supply current IDD Recommended LCD driving voltage VDD-V0 for normal temp version module Condition Standard Min Typ Max Unit +5V 4.7 5.0 5.5 V +3.3V 2.7 3.3 5.3 V VDD=5V ------ 1.5 4 mA -20ºC 4.8 5.0 5.3 0 ºC 4.6 4.8 5.0 25ºC 4.3 4.5 4.7 50ºC 4.2 4.3 4.5 70ºC 4.1 4.2 4.3 V Viewing area 64.5x16.4 mm LED forward voltage VF 25ºC ------ 4.2 5..0 V Dot size 0.56x0.61 mm LED forward current IF 25ºC ------ 120 ----- mA IEL VEL=110V AC 400Hz ------- ------ Character size 3.00x5.23 mm EL power supply current ----- mA
LCM1602K-FL-YBW 价格&库存
很抱歉,暂时无法提供与“LCM1602K-FL-YBW”相匹配的价格&库存,您可以联系我们找货
