ESDA6V8UW
ESDA6V8UW
4-Lines, Uni-directional, Low Capacitance
http//:www.willsemi.com
Transient Voltage Suppressors
Descriptions
The ESDA6V8UW is a low capacitance TVS (Transient
Voltage Suppressor) array designed to protect high speed
data interfaces. It has been specifically designed to protect
sensitive electronic components which are connected to data
SOT-363
and transmission lines from over-stress caused by ESD
(Electrostatic Discharge).
The ESDA6V8UW incorporates four pairs of low
capacitance steering diodes plus a TVS diode.
The ESDA6V8UW may be used to provide ESD
protection up to ±8kV (contact discharge) according to
IEC61000-4-2, and withstand peak pulse current up to 3A
(8/20μs) according to IEC61000-4-5.
The ESDA6V8UW is available in SOT-363 package.
Circuit diagram
Standard products are Pb-free and Halogen-free.
Features
Reverse stand-off voltage: 5V Max
Transient protection for each line according to
I/O
Vcc
I/O
6
5
4
W
IEC61000-4-2 (ESD): ±8kV (contact discharge)
IEC61000-4-5 (surge): 3A (8/20μs)
Low capacitance: CI/O - GND = 0.70pF typ.
CI/O – I/O = 0.35pF typ.
1
2
3
I/O
GND
I/O
Low leakage current
Low clamping voltage
= Month code (A~Z)
Solid-state silicon technology
W
= Device code
Marking & Pin configuration (Top View)
Applications
USB 2.0
HDMI 1.3
SATA and eSATA
DVI
IEEE 1394
PCI Express
Portable Electronics
Notebooks
Will Semiconductor Ltd.
Order information
1
Device
Package
Shipping
ESDA6V8UW-6/TR
SOT-363
3000/Tape&Reel
2013/08/07 - Rev 4.0
ESDA6V8UW
Absolute maximum ratings
Parameter
Symbol
Rating
Unit
Peak pulse power (tp = 8/20μs)
Ppk
45
W
Peak pulse current (tp = 8/20μs)
IPP
3
A
ESD according to IEC61000-4-2 air discharge
VESD
ESD according to IEC61000-4-2 contact discharge
Operation junction temperature
Storage temperature
±8
kV
125
o
TL
260
o
TSTG
-55~150
o
TJ
Lead temperature
±15
C
C
C
Electrical characteristics (TA = 25oC, unless otherwise noted)
Definitions of electrical characteristics
2
ESDA6V8UW
Electrical characteristics (TA = 25 C, unless otherwise noted)
o
Parameter
Symbol
Condition
Min.
Typ.
Max.
Unit
5
V
1
μA
VRWM
Reverse leakage current
IR
VRWM = 5V
Reverse breakdown voltage
VBR
IBR = 1mA
6.5
8.0
9.0
V
Forward voltage
VF
IF = 10mA
0.6
0.9
1.2
V
Clamping voltage 1)
VCL
IPP = 1A, tp = 8/20μs
11
V
IPP = 3A, tp = 8/20μs
15
V
0.70
0.90
pF
0.35
0.50
pF
CI/O - GND
Junction capacitance
CI/O – I/O
1)
VR = 0V, f = 1MHz,
Any I/O to GND
VR = 0V, f = 1MHz,
Any I/O to I/O
According to IEC61000-4-5.
3
ESDA6V8UW
Typical characteristics (TA = 25 C, unless otherwise noted)
110
100
90
80
70
60
50
40
30
90
Front time: T1= 1.25 T = 8s
Time to half-value: T2= 20s
Current (%)
Peak pulse current (%)
o
T2
10
T
10
T1
15
Time (s)
30
35
tr = 0.7~1ns
15
0.8
Pulse waveform: tp = 8/20s
14
Junction capacitance (pF)
VC - Clamping voltage (V)
Time (ns)
Contact discharge current waveform per IEC61000-4-2
8/20μs waveform per IEC61000-4-5
13
12
11
10
9
8
t
60ns
30ns
40
2
3
Vcc = floated, I/O to GND
0.7
f = 1MHz
0.6
0.5
4
IPP - Peak pulse current (A)
2
3
4
5
VR - Reverse voltage (V)
Capacitance vs. Reveres voltage
Clamping voltage vs. Peak pulse current
1000
100
% of Rated power
Peak pulse power (W)
100
10
1
1
10
100
Pulse time ( s)
60
40
50
75
100
125
150
o
TA - Ambient temperature ( C)
Power derating vs. Ambient temperature
Non-repetitive peak pulse power vs. Pulse time
80
4
ESDA6V8UW
o
ESD clamping
ESD clamping
(+8kV contact discharge per IEC61000-4-2)
(-8kV contact discharge per IEC61000-4-2)
5
ESDA6V8UW
Package outline dimensions
SOT-363
Symbol
Dimensions In Millimeters
Min.
Typ.
Max.
A
0.850
1.050
A1
0.000
0.100
A2
0.800
0.900
1.000
b
0.220
0.290
c
0.115
0.150
D
2.020
2.070
2.120
E
1.250
1.300
1.350
E1
2.200
2.300
2.400
e
0.650 BSC
e1
1.300 BSC
L
0.500 REF
L1
θ
0.280
o
0.330
0.380
8o
0.85
1.85
Recommend land pattern (Unit: mm)
Note: This land pattern is for your reference only.
6
很抱歉,暂时无法提供与“ESDA6V8UW-6/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.73224
- 10+0.42984
- 30+0.20196
- 100+0.18576
- 500+0.17928
- 1000+0.17496
