To:
Customer P/N:
UDE P/N: RB1-2S5BAK1A
Description: RJ45 1X1 Tab Down
Through Hole
10/100/1000 Base-T
Contact Area : Gold Flash
LED:L-Green/Yellow;R-Green/Yellow
Spec No.
RB1475-00
Approved
Checked
Update Date
2017/5/15
Revision
B
Prepared
RB1-2S5BAK1A
Spec No. : RB1475-00
1. MECHANICAL DIMENSION
1.1 Product Dimension
Unit:mm
General Tolerance :
-1-
X.X : ± 0.38
X.XX : ± 0.20
www.ude-corp.com
RB1-2S5BAK1A
1.2 Recommened PCB Layout
Component Side of Board
All dimension tolerance are ±0.05mm unless otherwise specified
Table1
Layout
Trace
component
Grounding
Test
Point
Via Hole
PTH
NPTH
Component side
X
X
O
X
X
X
O
Inner layer
O
NA
O
NA
O
X
O
Bottom side
O
O
O
O
O
X
O
Layer
X--Forbid; O--OK; NA--Not Applicable.
-2-
www.ude-corp.com
RB1-2S5BAK1A
Spec No. :
1.3 Recommended panel cutout
-3-
www.ude-corp.com
RB1-2S5BAK1A
1.4 Standard RJ45 Plug Specification
- All dimensions follow :
FCC subpart F, 68,500, Figure (C)(2)(i) & (C)(2)(ii) & (C)(3)(i)
IEC 60603-7
- All plugs must be meeting the requirements of plug Go & No-Go gauge.
Gauge follow : FCC subpart F, 68,500, Figure (C)(4)(i) & (C)(5)(i)
- There must be no damage to Housing and Locking Latch.
- There must be no nicks and cuts in cable.
- Durability : 750 cycles generally
-4-
www.ude-corp.com
RB1-2S5BAK1A
2. REQUIREMENTS
2.1 Design and Construction
Product shall be of design, construction and physical dimensions specified
on applicable.
2.2 Material
2.2.1 Terminal Parts (Underplating : 50μ" min. Nickel overall)
2.2.1.1 RJ Terminal : Phosphor Bronze, Thickness=0.30mm
Finish : Contact Area : Gold Flash
2.2.1.2 Input Terminal : Brass, Thickness=0.35mm
Finish : 100μ" min. Tin
2.2.1.3 Case Terminal : Brass, Thickness=0.30mm
2.2.2 Plastic Parts
2.2.2.1 Housing : PA6T, Black
2.2.2.2 Case : PA6T, Black
2.2.3 Shield Parts : Stainless, Thickness=0.20mm, Pre-soldering
-5-
www.ude-corp.com
RB1-2S5BAK1A
2.3 Operating and Storage Temperature
Operating Temperature : 0°C to +70°C
Storage Temperature : -40°C to +85°C
2.4 RJ45 specifications
Insulation Resistance :500MΩ min.
Insertion force with the latch depressed : 20N max
Removal force with the latch depressed : 20N max
Locking Force of Plug Latch : 50N min. @ 60+/-5 sec
2.5 Performance and Test Description
Product is designed to meet electrical, mechanical and environmental
performance requirements specified in below table. All tests are performed
at ambient environmental conditions per MIL-STD-1344A and EIA-364
unless otherwise specified.
2.6 Packaging and Packing
All parts shall be packaged and packed to protect against physical
damage、corrosion and deterioration during shipment and storage.
-6-
www.ude-corp.com
RB1-2S5BAK1A
3. ELECTRICAL CHARACTERISTICS @ 25℃
3.1 Schematic
RJ45
OUTPUT
INPUT
CT R5
1:1
TD1+ R1
C1 TX1+
75Ω
TD1- R2
C2 TX1-
1:1
TD2+ R3
C3 TX2+
75Ω
TD2- R4
C6 TX2-
1:1
TD3+ R7
C4 TX3+
75Ω
TD3- R8
C5 TX3-
1:1
TD4+ R9
C7 TX4+
75Ω
TD4- R10
C8 TX4-
2KV 1000pF
CT R6
Shield
L1
L3
Yellow
Yellow
Green
Green
L2
L4
Emitting Color
Green
Yellow
λp (nm)
570
588
Vf @If=20mA
1.7 ~2.6 V
1.7 ~2.6 V
-7-
Ir @Vr=5V
10μA max.
10μA max.
www.ude-corp.com
RB1-2S5BAK1A
3.2 Transmitter filter & Receiver filter
Type : Balance low pass 100Ω impedance
Insertion loss :
Return loss :
1~100 MHz
-1.0dB max.
100~125 MHz
-1.2dB max.
1~30 MHz
-18dB min.
load 100Ω
30~60MHz
-16dB min.
load 100Ω
60~80MHz
-12dB min.
load 100Ω
80~100MHz
-10dB min.
load 100Ω
3.3 Common Mode Rejection
@ 1~100 MHz
-30dB min.
3.4 Cross Talk
@ 1~100 MHz
3.5 Inductance
-30dB min.
@ 100KHz, 0.1V, 8mA DC BIAS
Input (R1-R2), Input(R3-R4), Input (R7-R8), Input(R9-R10): 350 μH min.
3.6 Hi-Pot Test
Input(R1-R2)
To Output(C1-C2) : 1500Vac 60s or 2250Vdc 60s
Input(R3-R4)
To Output(C3-C6) : 1500Vac 60s or 2250Vdc 60s
Input(R7-R8)
To Output(C4-C5) : 1500Vac 60s or 2250Vdc 60s
Input(R9-R10)
To Output(C7-C8) : 1500Vac 60s or 2250Vdc 60s
-8-
www.ude-corp.com
RB1-2S5BAK1A
4. ORDER INFORMATION
R
B
1
2
S 5B
A B
AK1
C
A
D
A. LED Code :
L-Green/Yellow;R-Green/Yellow.
B. Mechanical Code :
w/ UDE Logo, All Spring
C. Schematics Code :
AK1 : AK1 circuit
D. Plating Code :
Underplating
Solder Tail
100μ" min. Bright Tin
100μ" min. Matted Tin
A : Gold Flash
1 : Gold Flash
C : 6μ" gold
6 : 6μ" gold
B : 10μ" gold
Contact Area
D : 15μ" gold
2 : 15μ" gold
F : 30μ" gold
3 : 30μ" gold
G : 50μ" gold
4 : 50μ" gold
-9-
www.ude-corp.com
RB1-2S5BAK1A
5. WAVE SOLDERING TEMPERATURE PROFILE
- 10 -
www.ude-corp.com
RB1-2S5BAK1A
6. Revision History
Issue Date Revision
Comments
2010/12/2
A
Initial Release .
2017/5/15
B
Update Product Drawing
- 11 -
Operator
Max
www.ude-corp.com
很抱歉,暂时无法提供与“RB1-2S5BAK1A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+16.99920
- 10+14.55840
- 60+11.66400
- 120+10.10880
- 480+9.39600
- 1020+9.09360
