TL-PK-11
TL-PK-11
    BRADY
    TL-PK-11
TL-PK-11 数据手册
Technical Data Sheet BRADY B​-351 THERMAL TRANSFER PRINTABLE TAMPER-​RESISTANT WHITE VINYL LABEL STOCK TDS No. B​-351 Effective Date: 1/11/2019 Description: GENERAL Print Technology​: Thermal Transfer Material Type​: Tamper-​Resistant Vinyl Finish​: Matte White Adhesive​: Acrylic APPLICATIONS Rating and serial plates that require high performance and resistance to product tampering RECOMMENDED RIBBONS Brady Series R6200 Brady Series R6000 Halogen Free REGULATORY APPROVALS For information on the Weee-RoHS compliance status for a Brady Product go to one of the following websites: In Canada: ​www.bradycanada.ca/weee-rohs In Europe: ​www.bradyeurope.com/rohs In Japan: ​ www.​brady.co.jp/products/labelsuse/rohs All other regions: ​www.bradyid.com/weee-rohs SPECIAL FEATURES Brady B-​351 is designed to fracture easily in order to show signs of product tampering and to prevent one-​piece label removal. Use caution when removing from liner as material is fragile. Details: PHYSICAL PROPERTIES Thickness Adhesion to: -​Stainless Steel -​Painted Enamel ​-Polypropylene ​-Powder coated ​-Textured ABS -​Glass Tack Tensile Strength and Elongation Application Temperature TEST METHODS ASTM D 1000 ​Total (excluding liner) ASTM D 1000 20 minute dwell 24 hour dwell ASTM D 2979 Polyken™ Probe Tack 0.5 second dwell ASTM D 1000 Lowest application temperature to stainless steel AVERAGE RESULTS 0.0028 inches (0.071mm) Label destroys upon removal after both 20 minutes and 24 hours for all test surfaces 45.4 oz (1288 g) 6.3 lbs/in (110 N/100 mm), 2% 50°F (10°C) Samples were printed with the Brady Series R6200 and Brady Series R6000 Halogen Free ribbons. Samples applied to aluminum panels and allowed to dwell 24 hours at room temperature prior to testing. Unless noted otherwise, results were the same for both ribbons. PERFORMANCE PROPERTIES TEST METHODS TYPICAL RESULTS Long Term Service Temperature 30 days at various temperatures No visible effect to label at 80°C. Slight discoloration at 100°C, but is functional. Low Service Temperature 30 days at -40°F (-40°C) No visible effect Short Term Service Temperature 5 minutes at various temperatures No visible effect to label at 180°C. Severe discoloration at 240°C but label still functional. Humidity Resistance 30 days at 100°F (37°C), 95% R.H. No visible effect UV Light Resistance 30 days in UV Sunlighter​TM​ 100 No visible effect Weatherability ASTM G155, Cycle 1 30 days in Xenon Arc Weatherometer No visible effect Abrasion Resistance Taber Abraser, CS-10 grinding wheels, 500 g/arm, 100 cycles (Fed. Std. 191A, Method 5306) R6200: Moderate print removal and print smear. Print still legible. R6000: Slight print removal. Print still legible. PERFORMANCE PROPERTY SOLVENT RESISTANCE Samples were printed with the Brady Series R6200 and the Brady Series R6000 Halogen Free ribbons. Samples applied to aluminum panels and allowed to dwell 24 hours at room temperature prior to testing. Testing consisted of 5 cycles of 10 minute immersions in the specified chemicals followed by 30 minute recovery periods. After final immersion samples rubbed 10 times with cotton swabs saturated in test fluids. CHEMICAL REAGENT SUBJECTIVE OBSERVATION OF VISUAL CHANGE EFFECT TO LABEL STOCK R6200 R6000 Halogen Free Isopropyl Alcohol No visible effect No visible effect without/ with No visible effect without/ with rub. rub. No visible effect No visible effect without rub. No visible effect without rub. Formula 409​® ​Cleaner Slight print removal with rub. Slight print removal with rub. No visible effect No visible effect without/ with No visible effect without/ with Northwoods​™ ​Buzz Saw rub. rub. Citrus Degreaser JP-​8 Jet Fuel Slight adhesive ooze No visible effect without/ with No visible effect without/ with rub. rub. Mineral Spirits Slight adhesive ooze No visible effect without/ with No visible effect without/ with rub. rub. SAE 20 wt Oil @ 70°C No visible effect No visible effect without/ with No visible effect without/ with rub. rub. Gasoline Slight adhesive ooze No visible effect without rub. No visible effect without rub. Slight print removal with rub. Slight print removal with rub. No visible effect No visible effect without/ with No visible effect without/ with Super Agitene​® rub. rub. Deionized Water No visible effect No visible effect without/ with No visible effect without/ with rub. rub. 10% Sodium Hydroxide No visible effect No visible effect without/ with No visible effect without/ with Solution rub. rub. 10% Sulfuric Acid Solution No visible effect No visible effect without/ with No visible effect without/ with rub. rub. B-​351 is not recommended for use in harsh solvents such as MEK, Acetone, and 1,1,1​-Trichloroethane. Shelf life is ​two years from the date of receipt​ for this product as long as this product is stored in its original packaging in an environment below 80° F (27° C) and 60% RH. It remains the responsibility of the user to assess the risk of using this product. We encourage customers to develop testing protocols that will qualify a product's fitness for use in their actual application Trademarks: Formula 409® is a registered trademark of the Clorox Company Northwoods™ is a trademark of the Superior Chemical Corporation Polyken™ is a trademark of Testing Machines Inc. Sunlighter™ is a trademark of the Test Lab Apparatus Company Super Agitene® is a registered trademark of Graymills Corporation ASTM: American Society for Testing and Materials (U.S.A.) SAE: Society of Automotive Engineers (U.S.A.) All SI units (metric) are mathematically derived from U.S. conventional units. Note: ​All values shown are averages and should not be used for specification purposes. Test data and test results contained in this document are for general information only and shall not be relied upon by Brady customers for designs and specifications, or be relied on as meeting specified performance criteria. Customers desiring to develop specifications or performance criteria for specific product applications should contact Brady for further information. Product compliance information is based upon information provided by suppliers of the raw materials used by Brady to manufacture this product or based on results of testing using recognized analytical methods performed by a third party, independent laboratory. As such, Brady makes no independent representations or warranties, express or implied, and assumes no liability in connection with the use of this information. WARRANTY Brady products are sold with the understanding that the buyers will test them in actual use and determine for themselves their adaptability to their intended uses. Brady warrants to the buyers that its products are free from defects in material and workmanship, but limits its obligation under this warranty to replacement of the product shown to Brady's satisfaction to have been defective at the time Brady sold it. This warranty does not extend to any persons obtaining the product from the buyers. This warranty is in lieu of any other warranty, express or implied, including, but not limited to, any implied warranty of merchantability or fitness for a particular purpose, and of any other obligations or liability on Brady's part. Under no circumstances will Brady be liable for any loss, damage, expense, or consequential damages of any kind arising in connection with the use, or inability to use, Brady's products. Copyright 2019 Brady Worldwide, Inc. | All Rights Reserved Material may not be reproduced or distributed in any form without written permission. Brady North America | 6555 W. Good Hope Rd | Milwaukee, WI 53223 | USA | Tel: 414​-358-​6600 | Fax: 800-​292-​2289
TL-PK-11 价格&库存
很抱歉,暂时无法提供与“TL-PK-11”相匹配的价格&库存,您可以联系我们找货
