HSS3414A
HSS3414A
    HUASHUO(华朔)
    SOT23-3
HSS3414A 数据手册
HSS3414A N-Ch 20V Fast Switching MOSFETs Description Product Summary The HSS3414A is the high cell density trenched Nch MOSFETs, which provides excellent RDSON and efficiency for most of the small power switching and load switch applications. The HSS3414A meet the RoHS and Green Product requirement with full function reliability approved. ⚫ ⚫ ⚫ ⚫ VDS 20 V RDS(ON),max 26 mΩ ID 6 A SOT23 Pin Configuration Green Device Available Super Low Gate Charge Excellent Cdv/dt effect decline Advanced high cell density Trench technology Absolute Maximum Ratings Symbol Parameter Rating Units VDS Drain-Source Voltage 20 V VGS Gate-Source Voltage ±12 V ID@TA=25℃ Continuous Drain Current, VGS @ 4.5V1 6.0 A ID@TA=70℃ Continuous Drain Current, VGS @ 4.5V1 5.0 A IDM Pulsed Drain Current2 17 A PD@TA=25℃ Total Power Dissipation3 1 W PD@TA=70℃ Total Power Dissipation3 0.66 W TSTG Storage Temperature Range -55 to 150 ℃ TJ Operating Junction Temperature Range -55 to 150 ℃ Thermal Data Symbol Parameter Max. Unit RθJA Thermal Resistance Junction-ambient 1 120 ℃/W www.hs-semi.cn Ver 2.0 1 HSS3414A N-Ch 20V Fast Switching MOSFETs Electrical Characteristics (TJ=25 ℃, unless otherwise noted) Symbol BVDSS Parameter Drain-Source Breakdown Voltage △BVDSS/△TJ BVDSS Temperature Coefficient RDS(ON) Static Drain-Source On-Resistance2 VGS(th) Gate Threshold Voltage Conditions Min. Typ. Max. Unit VGS=0V , ID=250uA 20 --- --- V Reference to 25℃ , ID=1mA --- 0.018 --- V/℃ VGS=4.5V , ID=4A --- 21 26 VGS=2.5V , ID=3A --- 28 35 VGS=1.8V , ID=2A △VGS(th) VGS(th) Temperature Coefficient IDSS Drain-Source Leakage Current m --- 40 50 0.35 --- 1.0 V --- -3.1 --- mV/℃ VDS=16V , VGS=0V , TJ=25℃ --- --- 1 VDS=16V , VGS=0V , TJ=55℃ --- --- 5 VGS=VDS , ID =250uA uA IGSS Gate-Source Leakage Current VGS=±12V , VDS=0V --- --- ±100 nA gfs Forward Transconductance VDS=5V , ID=4A --- 30 --- S Qg Total Gate Charge (4.5V) --- 8.6 --- Qgs Gate-Source Charge --- 1.37 --- Qgd Gate-Drain Charge --- 2.3 --- VDS=15V , VGS=4.5V , ID=4A nC --- 5.2 --- Rise Time VDS=10V , VGS=4.5V , RG=3.3 --- 34 --- Turn-Off Delay Time ID=4A --- 23 --- Fall Time --- 9.2 --- Ciss Input Capacitance --- 670 --- Coss Output Capacitance --- 75 --- Crss Reverse Transfer Capacitance --- 68 --- Min. Typ. Max. Unit --- --- 6 A --- --- 17 A --- --- 1.2 V Td(on) Tr Td(off) Tf Turn-On Delay Time VDS=15V , VGS=0V , f=1MHz ns pF Diode Characteristics Symbol Parameter IS Continuous Source Current1,4 ISM Pulsed Source Current2,4 VSD Diode Forward Voltage2 Conditions VG=VD=0V , Force Current VGS=0V , IS=1A , TJ=25℃ Note : 1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper. 2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2% 3.The power dissipation is limited by 150℃ junction temperature 4.The data is theoretically the same as I D and IDM , in real applications , should be limited by total power dissipation. www.hs-semi.cn Ver 2.0 2 HSS3414A N-Ch 20V Fast Switching MOSFETs www.hs-semi.cn Ver 2.0 3 HSS3414A N-Ch 20V Fast Switching MOSFETs www.hs-semi.cn Ver 2.0 4 HSS3414A N-Ch 20V Fast Switching MOSFETs Ordering Information Part Number HSS3414A www.hs-semi.cn Package code SOT-23 Ver 2.0 Packaging 3000/Tape&Reel 5
HSS3414A 价格&库存
很抱歉,暂时无法提供与“HSS3414A”相匹配的价格&库存,您可以联系我们找货
