SCT12A2DHKR
SCT12A2DHKR
    SCT(芯洲科技)
    DFN20L_3.5X4.5MM
    SCT12A2是一款高效率的全集成同步升压转换器,支持2.7V至20V的输入电压范围和高达15A的开关电流。该器件具有负载断开控制功能,可防止关断状态下的输入电压通过到输出端。
SCT12A2DHKR 数据手册
SCT12A2 SILICONCONTENT TECHNOLOGY 2.7V-20V VIN, 15A Switch Current, Fully Integrated Synchronous Boost Converter with Load Disconnection Control FEATURES    DESCRIPTION Wide Input Voltage Range: 2.7V-20V Wide Output Voltage Range:4.5V-21V Fully Integrated 13mΩ High Side FET and 11mΩ Low Side FET Up to 96% Efficiency at Vin=7.2V, Vout=15V, and Iout=2A Up to 15A Switch Current and Programmable Peak Current Limit Load Disconnection Control with an External PChannel MOSFET Typical Shut-down Current: 1uA Programmable Switching Frequency: 200kHz1.0MHz PFM Mode Programmable Soft Start Output and Feedback Overvoltage Protection Thermal Shutdown Protection: 150°C Available in DFN-20L 3.5mmx4.5mm Package           The SCT12A2 is a high efficiency synchronous boost converter with fully integrated a 13mΩ high-side MOSFET and an 11mΩ low-side MOSFET, supporting 2.7V to 20V input voltage range and up to 15-A switch current. The switch current limit can be adjustable with an external resistor. The SCT12A2 adapts constant off-time peak current control to provide fast transient. An external compensation network allows flexibility setting loop dynamics to achieve optimal transient performance at different load conditions. Connection MODE pin to ground selects the Pulse Frequency Modulation (PFM) operation. The SCT12A2 offers the gate control for an external P-channel MOSFET to disconnect load from boost converter output. This safety feature prevents the damage on load from input shooting through to output in shutdown condition. The SCT12A2 monitors both output voltage and feedback voltage to protect over voltage condition. It features cycle-by-cycle peak current limit and thermal shutdown protection when the device over loads. APPLICATIONS    Bluetooth Audio Power Banks Type-C Power Delivery The device is available in a low-profile package DFN20L 3.5mmx4.5mmx0.9mm with enhanced thermal power pad. TYPICAL APPLICATION 100% L1 VOUT VIN C4 R2 SW FSW C6 C7 70% VOUT PGATE VIN ON C1 OFF EN FB SCT12A2 VCC COMP R5 ILIM C3 80% BOOT Efficiency C2 90% R3 R4 60% 50% 40% 30% 3.6VIN_15VOUT 20% PGND SS AGND MODE R1 C5 C8 C9 7.2VIN_15VOUT 10% 0% 0.01 12VIN_15VOUT 0.10 1.00 10.00 Output Current (A) Power Efficiency, Vout=15V For more information www.silicontent.com©2018 Silicon Content Technology Co., Ltd. All Rights Reserved Product folder link: SCT12A2 1 SCT12A2 REVISION HISTORY NOTE: Page numbers for previous revisions may differ from page numbers in the current version. Revision 1.0 released to market DEVICE ORDER INFORMATION PART NUMBER PACKAGE MARKING PACKAGE DISCRIPTION SCT12A2DHK 12A2 20-Lead 3.5mm×4.5mm Plastic DFN 1)For Tape & Reel, Add Suffix R (e.g. SCT12A2DHKR) ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION -0.3 UNIT 28 V VIN, SW, VOUT, FSW, 19 ILIM FSW 3 18 COMP 4 17 FB 16 VOUT 15 VOUT -0.3 22 V VCC, LIM,FB, EN,SS, COMP, MODE -0.3 5.5 V SW 5 SW 6 Operating junction C temperature TJ(2) Storage temperature TSTG (1) (2) -65 150 20 2 PGATE 125 1 EN SW -40 AGND MAX SCT12A2 PGND SW 7 14 VOUT BOOT 8 13 PGATE VIN 9 12 MODE C 10 11 NC BOOT MIN VCC DESCRIPTION Top View: 20-Lead Plastic DFN 3.5mmx4.5mm SS Over operating free-air temperature unless otherwise noted(1) Stresses beyond those listed under Absolute Maximum Rating may cause device permanent damage. The device is not guaranteed to function outside of its Recommended Operation Conditions. The IC includes over temperature protection to protect the device during overload conditions. Junction temperature will exceed 150°C when over temperature protection is active. Continuous operation above the specified maximum operating junction temperature will reduce lifetime PIN FUNCTIONS NAME NO. VCC 1 EN 2 FSW 3 SW 4,5,6,7 BOOT 8 VIN 9 SS 10 NC 11 PIN FUNCTION Internal linear regulator output. Connect a 1uF or larger ceramic capacitor to ground. VCC cannot to be externally driven. No additional components or loading is recommended on this pin. Enable logic input. A 800KΩ resistor connects this pin to ground inside. Floating disables the device. Place a resistor from this pin to SW to set the switching frequency. Switching node of the boost converter. Power supply for the high-side FET gate driver. Must connect a 0.1uF or greater ceramic capacitor between BOOT pin and SW node. Power supply input. Must be locally bypassed with a capacitor as close as possible to the pin. Place a ceramic cap from this pinto ground to program soft-start time. An internal 5uA current source pulls SS pin to VCC. Not Connected. 2For more information www.silicontent.com© 2018 Silicon Content Technology Co., Ltd. Product folder link: SCT12A2 All Rights Reserved SCT12A2 MODE 12 Ground connected enables PSM mode. PGATE 13 Gate driver output for an external P-channel MOSFET to disconnect load. Boost converter output. Connect a 1uF decoupling capacitor as close to VOUT pins and power ground pad as possible to reduce the ringing voltage of SW. Feedback Input. Connect a resistor divider from VOUT to FB to set up output voltage. The device regulates FB to the internal reference value of 1.2V typical. Output of the error amplifier and switching converter loop compensation point. Inductor peak current limit set point input. A resistor connecting this pinto ground sets current limit through low-side power FET. VOUT 14,15,16 FB 17 COMP 18 ILIM 19 AGND 20 Analog ground. Analog ground should be used as the common ground for all small signal analog inputs and compensation components. No electrical connection to PGND inside. PGND 21 Power ground. Must be soldered directly to ground planes using multiple vias directly under the IC for improved thermal performance and electrical contact. RECOMMENDED OPERATING CONDITIONS Over operating free-air temperature range unless otherwise noted PARAMETER VIN VOUT TJ DEFINITION Input voltage range Output voltage range Operating junction temperature MIN MAX UNIT 2.7 4.5 -40 20 21 125 V V °C MIN MAX UNIT -2 +2 kV -0.5 +0.5 kV ESD RATINGS PARAMETER VESD DEFINITION Human Body Model(HBM), per ANSI-JEDEC-JS-001-2014 specification, all pins(1) Charged Device Model(CDM), per ANSI-JEDEC-JS-0022014specification, all pins(2) (1) HBM and CDM stressing are done in accordance with the ANSI/ESDA/JEDEC JS-001-2014 specification THERMAL INFORMATION PARAMETER RθJA RθJC THERMAL METRIC Junction to ambient thermal resistance(1) Junction to case thermal resistance(1) DFN-20L 38 39 UNIT °C/W (1) SCT provides RθJA and RθJC numbers only as reference to estimate junction temperatures of the devices. RθJA and RθJC are not a characteristic of package itself, but of many other system level characteristics such as the design and layout of the printed circuit board (PCB) on which the SCT12A2 is mounted, thermal pad size, and external environmental factors. The PCB board is a heat sink that is soldered to the leads and thermal pad of the SCT12A2. Changing the design or configuration of the PCB board changes the efficiency of the heat sink and therefore the actual RθJA and RθJC. For more information www.silicontent.com© 2018 Silicon Content Technology Co., Ltd. All Rights Reserved 3 Product folder link: SCT12A2 SCT12A2 ELECTRICAL CHARACTERISTICS VIN=3.6V, TJ=-40°C~125°C, typical values are tested under 25°C. SYMBOL PARAMETER TEST CONDITION MIN TYP MAX UNIT Power Supply and Output VIN Operating input voltage 2.7 20 V VOUT Output voltage range 4.5 21 V VIN_UVLO Input UVLO Hysteresis 2.6 200 2.7 V mV ISD Shutdown current 1 3 uA IQ VCC Quiescent current from VIN Quiescent current from VOUT Internal linear regulator VIN rising EN=0, no load and measured on VIN pin 1 420 4.8 EN=2V, no load, no switching IVCC=5mA, VIN=6V uA uA V Reference and Control Loop FPWM mode PSM mode VFB=1.2V 1.180 1.196 1.206 1.220 1.230 1.244 100 V V nA VREF Reference voltage of FB IFB FB pin leakage current GEA VCOMP=1.5V 200 uS VFB=VREF-200mV, VCOMP=1.5V 20 uA VFB=VREF+200mV, VCOMP=1.5V 20 uA VCOMP_H Error amplifier trans-conductance Error amplifier maximum source current Error amplifier maximum sink current COMP high clamp VFB=1V, RILIM=100KΩ 1.5 V VCOMP_L COMP low clamp VFB=1.5V, RILIM=100KΩ,PFM 0.6 V Power MOSFETs RDSON_H High side FET on-resistance 13 mΩ RDSON_L 11 mΩ 15 A ICOMP_SRC ICOMP_SNK Low side FET on-resistance Current Limit ILIM Peak current limit Enable and Mode Enable high threshold VEN Enable low threshold REN Enable pull down resistance VMODE ISS MODE high threshold MODE low threshold Soft-start charging current RILIM=100kΩ VCC=5V 1.2 V V kΩ 4 V V uA 0.4 800 VCC=5V 1.5 5 Switching Frequency FSW Switching frequency RFSW=301k, VOUT=12V 520 tON_MIN Minimum on-time RFSW=301k, VOUT=12V 160 200 ns tOFF_MIN Minimum off-time RFSW=301k, VFB=0V 480 150 ns kHz Load Disconnection Control IPGATE VPGATE_C PGATE pull down current Clamp voltage between PGATE and VOUT 250 6.1 uA 7 V Protection VOVP_VOUT Output overvoltage threshold VOUT rising 4For more information www.silicontent.com© 2018 Silicon Content Technology Co., Ltd. Product folder link: SCT12A2 22 All Rights Reserved V SCT12A2 SYMBOL VOVP_VFB TSD PARAMETER TEST CONDITION Hysteresis Feedback overvoltage with respect to reference voltage Thermal shutdown threshold Hysteresis VFB rising VFB falling TJ rising MIN TYP 400 110 105 150 20 MAX UNIT mV % % °C °C For more information www.silicontent.com© 2018 Silicon Content Technology Co., Ltd. All Rights Reserved 5 Product folder link: SCT12A2 SCT12A2 100% 100% 90% 90% 80% 80% 70% 70% Efficiency Efficiency TYPICAL CHARACTERISTICS 60% 50% 40% 60% 50% 40% 30% 3.6VIN_12VOUT 30% 3.6VIN_15VOUT 20% 7.2VIN_12VOUT 20% 7.2VIN_15VOUT 10% 12VIN_15VOUT 10% 0% 0.01 0.10 1.00 0% 0.01 10.00 0.10 Output Current (A) 100% 100% 90% 90% 80% 80% 70% 70% 60% 50% 40% 3.6VIN_12VOUT 60% 50% 40% 7.2VIN_12VOUT 30% 3.6VIN_15VOUT 20% 7.2VIN_15VOUT 20% 3.6VIN_18VOUT 10% 7.2VIN_18VOUT 10% 0% 0.01 0.10 1.00 0% 0.01 10.00 0.10 Output Current (A) 1.00 10.00 Output Current (A) Figure 3. Efficiency, fsw=400 kHz, 1-cell Battery, PFM Figure 4. Efficiency, fsw=400KHz, 2-cells Battery, PFM 1600 16 1400 14 1200 12 1000 10 ILIM (A) FSW (kHz) 10.00 Figure 2. Efficiency, Vout=15V, fsw=400KHz, PFM Efficiency Efficiency Figure 1. Efficiency, Vout=12V, fsw=400KHz, PFM 30% 1.00 Output Current (A) 800 600 8 6 4 400 Fsw 200 Current Limit 2 0 0 0 200 400 600 800 0 100 150 200 250 300 350 RILIM (kOhm) RFSW (kOhm) Figure 5. Switching Frequency vs FSW Resistance 50 Figure 6. Inductor Peak Current Limit vs RLIM Resistance 6For more information www.silicontent.com© 2018 Silicon Content Technology Co., Ltd. Product folder link: SCT12A2 All Rights Reserved SCT12A2 16.0 15.0 15.0 15.5 VOUT (V) VOUT (V) 14.9 14.9 15.0 14.8 7.2VIN_15VOUT 14.5 Vout=15V 14.8 14.7 14.0 0.0 0.5 1.0 1.5 2.0 0.0 2.5 2.0 4.0 8.0 10.0 12.0 14.0 Figure 8. Line Regulation (Vout=15V) 530 600 520 500 510 400 Iq (uA) FSW (kHz) Figure 7. Load Regulation (Vin=7.2V, Vout=15V) 500 490 300 200 FSW 480 470 -50 6.0 VIN (V) IOUT (A) 0 50 100 Iq 100 0 -50 150 0 Temperature(ºC) 50 100 150 Temperature(ºC) Figure 9. Frequency vs Temperature Figure 10. Quiescent Current vs Temperature 3.0 1.25 2.5 1.23 2.0 VFB (V) ISD (uA) 1.21 1.5 1.19 1.0 ISD 0.5 VFB 1.17 0.0 1.15 -50 0 50 100 Temperature(ºC) Figure 11. Shutdown Current vs Temperature 150 -50 0 50 100 150 Temperature(ºC) Figure 12. Feedback Reference vs Temperature For more information www.silicontent.com© 2018 Silicon Content Technology Co., Ltd. All Rights Reserved 7 Product folder link: SCT12A2 SCT12A2 FUNCTIONAL BLOCK DIAGRAM UVLO VIN 9 VCC BOOT SW SW SW SW 1 8 4 5 6 7 OTP UVLO Q2 BOOT Regulator LDO Thermal Sensor 15 VOUT FB VOUT Q1 OVP Load Disconnect Control Dead Time and PWM Control Logic 11 NC Q Q R 5uA + + 17 FB GM 1.2V + Mode Selection + + S UVLO EN 12 10 SS ON/OFF and Protection UVLO VIN 34pF UVLO OVP OTP V/I 1/N 3 18 COMP + FSW 16 VOUT OVP PGATE 13 MODE 14 VOUT 800k 1.2V 2 21 19 20 EN PGND ILIM AGND 8For more information www.silicontent.com© 2018 Silicon Content Technology Co., Ltd. Product folder link: SCT12A2 All Rights Reserved SCT12A2 OPERATION Overview The SCT12A2 device is a fully integrated synchronous boost converter, which regulates output voltage higher than input voltage. The constant off-time peak current mode control provides fast transient with pseudo fixed switching frequency. When low-side MOSFET Q1 turns on, input voltage forces the inductor current rise. Sensed voltage on low-side MOSFET peak current rises above the voltage of COMP. After the inductor current reaches the peak current, the device turns off low-side MOSFET and inductor goes through body diode of high-side MOSFET Q2 during dead time. After dead time duration, the device turns on high-side MOSFET Q2 and the inductor current decreases. Based on Vin and Vout voltage, the device predicts required off-time and turns off high-side MOSFET Q2.This repeats on cycle-by-cycle based. The voltage feedback loop regulates the FB voltage to a 1.2V reference with an internal trans-conductance error amplifier. The feedback loop stability and transient response are optimized through an external loop compensation network connected to the COMP pin. When MODE pin is connected to ground, the SCT12A2 works at PFM mode to further increase the efficiency in light load condition. The quiescent current of SCT12A2 is 420uA typical under no-load condition and not switching. Disabling the device, the typical supply shutdown current is 1μA. A resistor connected between SW pin and the FSW pin sets the switching frequency. The wide switching frequency range of 200 kHz to 1.0 MHz offers optimization on efficiency or size of filter components. The SCT12A2 provides PGATE pin to control the gate of an external load disconnection P-channel MOSFET, which completely disconnects the load from the input during output shutdown condition. During start-up, the SCT12A2 gradually turns on the load disconnection switch to limit the inrush current. The SCT12A2 device features adjustable soft-start time, cycle-by-cycle low-side FET current limit, over-voltage protection, and over-temperature protection. The SCT12A2 uses two separate ground pins to avoid ground bouncing due to the high switching current through the N-channel power MOSFET. AGND pin sets the reference for all control functions. The source of the power MOSFET connects to PGND pin. Both grounds must be connected to the thermal pad on the PCB at the closest point. VIN Power The SCT12A2 is designed to operate from an input voltage supply range between 2.7 V to 20V. If the input supply is located more than a few inches from the converter, additional bulk capacitance may be required in addition to the ceramic bypass capacitors. A typical choice is ceramic capacitor with a value of 47μF or 2 x 22uF. VCC Power The internal VCC LDO provides the bias power supply for internal circuitries. A ceramic capacitor of no less than 1uF is required to bypass from VCC pin to ground. During starting up, input of VCC LDO is from VIN pin. Once the output voltage at VOUT pin exceeds VIN voltage, VCC LDO switches its input to VOUT pin. This allows higher voltage headroom of VCC at lower input voltage. The maximum current capability of VCC LDO is 130mA typical. No additional components or loading are recommended on this pin. Under Voltage Lockout UVLO The SCT12A2 features UVLO protection for voltage rails of VIN, VCC and BOOT-SW from the converter malfunctioning and the battery over discharging. The default VIN rising threshold is 2.6V typical at startup and falling threshold is 2.4V typical at shutdown. The internal VCC LDO dropout voltage is about 100mV and the device is disabled when VCC falling trips 2.1V typical threshold. The internal charge pump from BOOT to SW powers the gate driver to high-side MOSFET Q2. The BOOT UVLO circuit monitors the capacitor voltage between BOOT pin and SW pin. When the voltage of BOOT to SW falls below a preset threshold 3V typical, high-side MOSFET Q2 turns off. As a result, the device works as a non-synchronous boost converter. For more information www.silicontent.com© 2018 Silicon Content Technology Co., Ltd. All Rights Reserved 9 Product folder link: SCT12A2 SCT12A2 Enable and Start-up When applying a voltage higher than the EN high threshold (maximum 1.2V), the SCT12A2 enables all functions and starts converter operation. To disable converter operation, EN voltage needs fall below its lower threshold (minimum 0.4V). An internal 800KΩ resistor connects EN pin to the ground. Floating EN pin automatically disables the device. The SCT12A2 features programmable soft start to prevent inrush current during power-up. SS pin sources an internal 5μA current charging an external soft-start capacitor CSS when EN pin exceeds turn-on threshold. The device uses the lower voltage between the internal voltage reference 1.2V and the SS pin voltage as the reference input voltage of error amplifier and regulates the output. The soft-start completes when SS pin voltage exceeds the internal 1.2V reference. Use equation 1 to calculate the soft-start time (10% to 90%). When EN pin is pulled low to disable the device, the SS pin will be discharged to ground. t SS = where     CSS ∗ VREF ISS (1) tSS is the soft start time VREF is the internal reference voltage of 1.2V CSS is the capacitance connecting to SS pin ISS is the source current of 5uA to SS pin Adjustable Switching Frequency The SCT12A2 features adjustable switching frequency from 200kHz to 1.0MHz.To set the switching frequency, an external resistor between SW pin and FSW pin is a must to guarantee the proper operation. Use Equation 2 or the curves in Figure 5 to determine the resistance for a given switching frequency. To reduce the solution size, one can typically set the switching frequency as higher as possible, but need to consider the tradeoff of the thermal dissipation and minimum on time of low-side power MOSFET. 6∗( 𝑅𝐹𝑅𝐸𝑄 = where:      1 𝑓𝑆𝑊 − 𝑇𝐷𝐸𝐿𝐴𝑌 ∗ 𝑉𝑂𝑈𝑇 𝑉𝐼𝑁 ) (2) 𝐶𝐹𝑅𝐸𝑄 fSW is the desired switching frequency TDELAY = 90 ns CFREQ = 34 pF VIN is the input voltage VOUT is the output voltage Adjustable Peak Current Limit The SCT12A2 boost converter implements cycle-by-cycle peak current limit function with sensing the internal lowside power MOSFET Q1 during overcurrent condition. While the Q1 is turned on, its conduction current is monitored by the internal sensing circuitry. Once the low-side MOSFET Q1 current exceeds the limit, it turns off immediately. An external resistor connecting ILIM pin to ground sets the low-side MOSFET Q1 peak current limit threshold. Use Equation 3 or Figure 6 to calculate the peak current limit. 𝐼𝐿𝐼𝑀 = 1500 𝑅𝐿𝐼𝑀 (3) where: 10For more information www.silicontent.com© 2018 Silicon Content Technology Co., Ltd. Product folder link: SCT12A2 All Rights Reserved SCT12A2   ILIM is the peak current limit RLIM is the resistance between ILIM pin to ground. This current limit function is realized by detecting the current flowing through the low-side MOSFET. The current limit feature loses function in the output hard short circuit conditions. At normal operation, when the output hard shorts to ground, there is a direct path to short the input voltage through high-side MOSFET Q2 or its body diode even the Q2 is turned off. This could damage the circuit components and cause catastrophic failure at load circuit. Load Disconnection Control For both non-synchronous and synchronous boost converter, there is a non-fully controlled current path from converter input to output load through the diode or the high-side MOSFET body diode. During start up, once VIN is present, VOUT is moved to VIN level due to the direct path from input to output even when the device is shut down or the load is not ready. The presence of unwanted output voltage before system start up sequence could cause system to latch off or malfunction. To address the above issues, the SCT12A2 provides a solution to insert an external P-channel MOSFET to disconnect the load from the converter output in application as shown in Figure 13. Choosing a lower Rdson of the disconnection P-channel MOSFET Q3 reduces impact on the efficiency. The source of Q3 needs connect to VOUT pin. Output capacitor is required at both VOUT pin and the source of P-channel MOSFET to maintain the loop stability. In Figure 13, PGATE pin connecting to gate of Q3 has a constant sink current pulling down capability and a resistance pulling up capability. During SCT12A2 starting up, internal circuitry softly starts up of P-channel MOSFET. When gate-source voltage of external P-channel MOSFET is lower than the threshold voltage, the Q3 is turned on and the load is connected to VOUT pin. The source-gate voltage of external P-channel MOSFET is clamped up to 8V when the P-channel MOSFET is fully turned on. When the Enable is disabled or the input voltage lower than the VIN UVLO threshold, the SCT12A2 shuts off the external P-channel MOSFET and disconnect the load L1 VIN C7 SW Q2 VOUT Q1 Q3 VOUT_LOAD C5A C5B 8V PGATE UVLO EN 250uA Figure 13. Load Disconnection Control For more information www.silicontent.com© 2018 Silicon Content Technology Co., Ltd. All Rights Reserved 11 Product folder link: SCT12A2 SCT12A2 Over Voltage Protection and Minimum On-time The SCT12A2 features both VOUT pin over voltage protection and the FB pin over voltage protection. If the VOUT pin is above 22V typical or FB pin voltage exceeds 1.32V typical, the device stops switching immediately until the VOUT pin drops below 21 V or FB pin voltage drops below 1.26V. The OVP function prevents the connected output circuitry from un-predictive overvoltage. The low-side MOSFET has minimum on-time 160ns typical limitation. While the device is operating at minimum on time and further increasing Vin push output voltage beyond regulation point. With output and feedback over voltage protection, the converter skips pulse with turning off high-side MOSFET and prevents output running higher to damage the load. Pulse Frequency Modulation (PFM) Modes Connecting MODE pin to ground, the SCT12A2 works at Pulse Frequency Modulation (PFM) mode to improve the power efficiency in light load. As the load current decreasing, the COMP pin voltage decreases as resulting the inductor current down. With the load current further decreasing, the COMP pin voltage decreases and be clamped to a voltage corresponding to the ILIM/12. The converter extends the off time of high-side MOSFET Q2 to reduce the average delivered current to output. The switching frequency is lower and varied depending on loading condition. In PFM mode, the peak inductor current is fixed at around 1A and the output voltage is regulated 0.7% higher than the setting out put voltage. When the inductor current decreased to zero, zero-cross detection circuitry on high-side MOSFET Q2 forces the Q2 off until the beginning of the next switching cycle. The boost converter does not sink current from the load at light load. Thermal Shutdown Once the junction temperature in the SCT12A2 exceeds 150C, the thermal sensing circuit stops switching until the junction temperature falling below 125C, and the device restarts. Thermal shutdown prevents the damage on device during excessive heat and power dissipation condition. 12For more information www.silicontent.com© 2018 Silicon Content Technology Co., Ltd. Product folder link: SCT12A2 All Rights Reserved SCT12A2 APPLICATION INFORMATION Typical Application L1 1.5uH Q3 VIN R2 390k C2 47uF SW R3 680k C6 1uF C4 0.1uF VOUT_LOAD C7A 47uF C7B 47uF BOOT FSW VOUT VIN PGATE EN FB ON C1 0.1uF OFF VCC SCT12A2 COMP ILIM C3 1uF PGND SS AGND MODE R1 100k C5 47nF R5 16.9k C9 4.7nF R4 59k C8 47pF Figure 14. One Cell Battery Input, 15V Output with Load Disconnection Protection Design Parameters Design Parameters Example Value Input Voltage 3.0V to 14V Output Voltage 15V Output Current 2A Output voltage ripple (peak to peak) 100mV Switching Frequency 400 kHz Operation Mode PFM *For description in the typical application section, the converter output before PMOS is specified as VOUT and the converter output after PMOS is specified as VOUT_LOAD in below. For more information www.silicontent.com© 2018 Silicon Content Technology Co., Ltd. All Rights Reserved 13 Product folder link: SCT12A2 SCT12A2 Switching Frequency The resistor connected from FSW to SW sets switching frequency of the converter. The resistor value required for a desired frequency can be calculated using equation 3. High frequency can reduce the inductor and output capacitor size with the tradeoff of more thermal dissipation and lower efficiency. 𝑅𝐹𝑅𝐸𝑄 = 𝑉 1 −𝑇𝐷𝐸𝐿𝐴𝑌 ∗ 𝑂𝑈𝑇 ) 𝑓𝑆𝑊 𝑉𝐼𝑁 6∗( 𝐶𝐹𝑅𝐸𝑄 (3) Table 1. RFSW Value for Common Switching Frequencies (Vin=3.6V, Vout=15V, Room Temperature) where:  fSW is the desired switching frequency  TDELAY = 90 ns  CFREQ = 34 pF  VIN is the input voltage  VOUT is the output voltage Fsw RFSW 230 KHz 680 KΩ 400 KHz 390 KΩ 575 KHz 270 KΩ 715 KHz 200 KΩ Peak Current Limit Using equation 4 the correct external resistor at ILIM pin sets the peak input current. For a typical current limit of 12A, the resistor value is 100KΩ. The minimum current limit must be higher than the required peak switch current at lowest input voltage and the highest output power not to hit the current limit and still regulate the output voltage. 𝐼𝐿𝐼𝑀 = 1500 𝑅𝐿𝐼𝑀 (4) Table 2. RLIM Value for Inductor Peak Current (Vin=3.6V, Vout=15V, L=1.5uH, Room Temperature) where: ILIM RLIM  ILIM is the peak current limit 15 A 100 KΩ  RLIM is the resistance of ILIM pin to ground 10 A 150 KΩ 7.5A 200 KΩ Output Voltage The output voltage is set by an external resistor divider R3 and R4 in typical application schematic. A minimum current of typical 20uA flowing through feedback resistor divider gives good accuracy and noise covering. The value of R3 can be calculated by equation 5. 𝑅3 = (𝑉𝑂𝑈𝑇 − 𝑉𝑅𝐸𝐹 ) × 𝑅4 𝑉𝑅𝐸𝐹 (5) where:  VREF is the feedback reference voltage, typical 1.2V Table 3. Feedback Resistor R3R4Value for Output Voltage (Room Temperature) VOUT R3 R4 9V 390 KΩ 59 KΩ 15 V 698 KΩ 59 KΩ 14For more information www.silicontent.com© 2018 Silicon Content Technology Co., Ltd. Product folder link: SCT12A2 All Rights Reserved SCT12A2 Inductor Selection The performance of inductor affects the power supply’s steady state operation, transient behavior, loop stability, and boost converter efficiency. The inductor value, DC resistance, and saturation current influences both efficiency and the magnitude of the output voltage ripple. Larger inductance values reduces inductor current ripple and therefore leads to lower output voltage ripple. For a fixed DC resistance, a larger value inductor yields higher efficiency via reduced RMS and core losses. However, a larger inductor within a given inductor family will generally have a greater series resistance, thereby counteracting this efficiency advantage. Inductor values can have ±20% or even ±30% tolerance with no current bias. When the inductor current approaches saturation level, its inductance can decrease 20% to 35% from the value at 0-A current depending on how the inductor vendor defines saturation. When selecting an inductor, choose its rated current especially the saturation current larger than its peak current during the operation. To calculate the current in the worst case, use the minimum input voltage, maximum output voltage, maxim load current and minimum switching frequency of the application, while considering the inductance with -30% tolerance and low-power conversion efficiency. For a boot converter, calculate the inductor DC current as in equation 6 𝐼𝐿𝐷𝐶 = Where     𝑉𝑂𝑈𝑇 × 𝐼𝑂𝑈𝑇 𝑉𝐼𝑁 × 𝜂 (6) VOUT is the output voltage of the boost converter IOUT is the output current of the boost converter VIN is the input voltage of the boost converter η is the power conversion efficiency Calculate the inductor current peak-to-peak ripple, ILPP, as in equation 7 𝐼𝐿𝑃𝑃 = Where      1 𝐿×( 1 𝑉𝑂𝑈𝑇 −𝑉𝐼𝑁 + 1 𝑉𝐼𝑁 ) × 𝑓𝑆𝑊 (7) ILPP is the inductor peak-to-peak current L is the inductance of inductor fSW is the switching frequency VOUT is the output voltage VIN is the input voltage Therefore, the peak switching current of inductor, ILPEAK, is calculated as in equation 8. 𝐼𝐿𝑃𝐸𝐴𝐾 = 𝐼𝐿𝐷𝐶 + 𝐼𝐿𝑃𝑃 2 (8) Set the current limit of the SCT12A2 higher than the peak current ILPEAK and select the inductor with the saturation current higher than the current limit. The inductor’s DC resistance (DCR), equivalent series resistance (ESR) at switching frequency and the core loss significantly affect the efficiency of power conversion. Core loss is related to the core material and different inductors have different core loss. For a certain inductor, larger current ripple generates higher DCR and ESR conduction losses and higher core loss. Usually, a data sheet of an inductor does not provide the ESR and core loss information. If needed, consult the inductor vendor for detailed information. There is a tradeoff among the inductor’s inductance, DCR and ESR resistance, and its footprint. Shielded inductors typically have higher DCR than unshielded inductors. Table 4 lists recommended inductors for the SCT12A2. Verify whether the recommended inductor can support the For more information www.silicontent.com© 2018 Silicon Content Technology Co., Ltd. All Rights Reserved 15 Product folder link: SCT12A2 SCT12A2 user's target application with the previous calculations and bench evaluation. In this application, the WE's inductor SMD7443552150 is used on SCT12A2 evaluation board. Table 4. Recommended Inductors Part Number L (uH) DCR Max (mΩ) Saturation Current/Heat Rating Current (A) Size Max (LxWxH mm) Vendor WE-HCI SMD 7443552150 1.5 5.3 17 / 14 10.5 x 10.2 x 4.0 WurthElektronix Input Capacitor Selection For good input voltage filtering, choose low-ESR ceramic capacitors. A 0.1μF ceramic bypass capacitor is recommended to be placed as close as possible to the VIN pin of the SCT12A2. A ceramic capacitor of more than 1.0μF is required at the VCC pin to get a stable operation of the internal LDO. For the power stage, because of the inductor current ripple, the input voltage changes if there is parasitic inductance and resistance between the power supply and the inductor. It is recommended to have enough input capacitance to make the input voltage ripple less than 100mV. Generally, 2x 22μF or 47uF input capacitance is recommended for most applications. Choose the right capacitor value carefully by considering high-capacitance ceramic capacitors DC bias effect, which has a strong influence on the final effective capacitance. Output Capacitor Selection For small output voltage ripple, choose a low-ESR output capacitor like a ceramic capacitor. Typically, three 22μF ceramic output capacitors work for most applications. Higher capacitor values can be used to improve the load transient response. Due to a capacitor’s derating under DC bias, the bias can significantly reduce capacitance. Ceramic capacitors can lose most of their capacitance at rated voltage. Therefore, leave margin on the voltage rating to ensure adequate effective capacitance. From the required output voltage ripple, use the equation 9 and 10 to calculate the minimum required effective capacitance, COUT. 𝑉𝑟𝑖𝑝𝑝𝑙𝑒_𝐶 = (𝑉𝑂𝑈𝑇 − 𝑉𝐼𝑁_𝑀𝐼𝑁 ) × 𝐼𝑂𝑈𝑇 𝑉𝑂𝑈𝑇 × 𝑓𝑆𝑊 × 𝐶𝑂𝑈𝑇 (9) 𝑉𝑟𝑖𝑝𝑝𝑙𝑒_𝐸𝑆𝑅 = 𝐼𝐿𝑝𝑒𝑎𝑘 × 𝐸𝑆𝑅 where         (10) Vripple_C is output voltage ripple caused by charging and discharging of the output capacitor. Vripple_ESR is output voltage ripple caused by ESR of the output capacitor. VIN_MIN is the minimum input voltage of boost converter. VOUT is the output voltage. IOUT is the output current. ILpeak is the peak current of the inductor. ƒSW is the converter switching frequency. ESR is the ESR resistance of the output capacitors. External P-channel MOSFET Selection To minimize the power efficiency impact on the boost system, the external P-channel MOSFET with smaller Rdson is inserted between the converter output and load circuit to implement the load disconnection protection. The SCT12A2 provides the gate drive capability for the external P-channel MOSFET, the maximum VGS of the P-channel MOSFET is clamped up to -7.1V typically if the VOUT is higher than 7.1V. Otherwise, the maximum VGS follows the VOUT pin voltage in the application. As a result, the low Rdson and low threshold P-channel MOSFET is preferred. Table 5 shows the recommended P-channel MOSFET details. 16For more information www.silicontent.com© 2018 Silicon Content Technology Co., Ltd. Product folder link: SCT12A2 All Rights Reserved SCT12A2 Table 5. Recommended External P-channel MOSFET Part Number Rdson (mΩ) ID (A) Max VDS (V) Max VGS (V) Vendor FDMC612PZ 8.4 14 -20 ±12 Fairchild CSD25404Q3 5.5 18 -20 ±12 Texas Instruments Loop Stability An external loop compensation network comprises resister R5, ceramic capacitors C8 and C9 connected to the COMP pin to optimize the loop response of the converter. The power stage small signal loop response of constant off time with peak current control can be modeled by equation 11. 𝑆 𝑆 𝑅𝑙𝑜𝑎𝑑 × (1 − 𝐷) (1 + 2𝜋×𝑓𝐸𝑆𝑅𝑍)(1 + 2𝜋×𝑓𝑅𝐻𝑃𝑍) 𝐺𝑃𝑆 (𝑆) = × 𝑆 2 × 𝑅𝑆𝐸𝑁𝑆𝐸 1+ (11) 2𝜋×𝑓𝑃 where  D is the switching duty cycle.  Rload is the output load resistance.  RSENSE is the equivalent internal current sense resistor, which is 0.08 Ω. 𝑓𝑃 = 1 (12) 2𝜋 × 𝑅𝑙𝑜𝑎𝑑 × 𝐶𝑂 where  CO is the output capacitance 𝑓𝑃𝐸𝑆𝑅𝑍 = 1 2𝜋 × 𝐸𝑆𝑅 × 𝐶𝑂 (13) where  ESR is the equivalent series resistance of the output capacitor. 𝑓𝑅𝐻𝑃𝑍 = 𝑅𝑙𝑜𝑎𝑑 × (1 − 𝐷)2 2𝜋 × 𝐿 (14) The COMP pin is the output of the internal trans-conductance amplifier. Equation 15 shows the small signal transfer function of compensation network. 𝐺𝐸𝐴 × 𝑅𝐸𝐴 × 𝑉𝑅𝐸𝐹 𝐺𝐶 (𝑆) = × 𝑉𝑂𝑈𝑇 (1 + where       (1 + 𝑆 2𝜋×𝑓𝐶𝑂𝑀𝑍 𝑆 2𝜋×𝑓𝐶𝑂𝑀𝑃1 )(1 + ) 𝑆 2𝜋×𝑓𝐶𝑂𝑀𝑃2 ) (15) GEA is the amplifier’s trans-conductance REA is the amplifier’s output resistance VREF is the reference voltage at the FB pin VOUT is the output voltage ƒCOMP1, ƒCOMP2 are the poles' frequency of the compensation network. ƒCOMZ is the zero's frequency of the compensation network. The next step is to choose the loop crossover frequency, ƒC . The higher frequency that the loop gain stays above zero before crossing over, the faster the loop response is. It is generally accepted that the loop gain cross over no higher than the lower of either 1/10 of the switching frequency, ƒSW , or 1/5 of the RHPZ frequency, ƒRHPZ. Then set the value of R5, C8, and C9 in typical application circuit by following these equations. For more information www.silicontent.com© 2018 Silicon Content Technology Co., Ltd. All Rights Reserved 17 Product folder link: SCT12A2 SCT12A2 𝑅5 = 2𝜋 × 𝑉𝑂𝑈𝑇 × 𝑅𝑆𝐸𝑁𝑆𝐸 × 𝑓𝐶 × 𝐶𝑂 (1 − 𝐷) × 𝑉𝑅𝐸𝐹 × 𝐺𝐸𝐴 (16) where  ƒC is the selected crossover frequency. 𝐶8 = 𝑅𝑙𝑜𝑎𝑑 × 𝐶𝑂 2 × 𝑅5 𝐶9 = 𝐸𝑆𝑅 × 𝐶𝑂 𝑅5 (17) (18) If the calculated value of C9 is less than 10pF, it can be left open. Designing the loop for greater than 45°of phase margin and greater than 10-dB gain margin eliminates output voltage ringing during the line and load transient. 18For more information www.silicontent.com© 2018 Silicon Content Technology Co., Ltd. Product folder link: SCT12A2 All Rights Reserved SCT12A2 Application Waveforms Test Condition: VIN=7.2V, VOUT=15V, Ta=27ºC. Figure 15. Switching Waveforms and Output Ripple Figure 16. Switching Waveforms and Output Ripple (Vout=15V, Iout=100mA) (Vout=15V, Iout=2A) Figure 17. Power up (Vout=15V, Iout=2A) Figure 18. Power Down (Vout=15V, Iout=2A) Figure 19. Load Transient (Vout=15V, Iout=0.2A to 1.8A, SR=250mA/us) Figure 20. Load Transient (Vout=15V, Iout=0.5A to 1.5A, SR=250mA/us) For more information www.silicontent.com© 2018 Silicon Content Technology Co., Ltd. All Rights Reserved 19 Product folder link: SCT12A2 SCT12A2 Layout Guideline The regulator could suffer from instability and noise problems without careful layout of PCB. Radiation of highfrequency noise induces EMI, so proper layout of the high-frequency switching path is essential. Minimize the length and area of all traces connected to the SW pin, and always use a ground plane under the switching regulator to minimize coupling. The input capacitor needs to be close to the VIN pin and ground pad to reduce the input supply ripple. The placement and ground trace for C6 is critical for the performance of SW ringing voltage. Place capacitor C6 as close to VOUT pins and power ground pad as possible to reduce high frequency ringing voltage on SW pin. The layout should also be done with well consideration of the thermal. The center thermal pad should always be soldered to the board for mechanical strength and reliability, using multiple thermal vias (≤8mil) underneath the thermal pad. The bottom layer is a large ground plane connected to the PGND plane and AGND plane on top layer by vias. Since thermal pad is electrical power ground of the device, improper soldering thermal pad to ground plate on PCB will cause SW higher ringing and overshoot besides downgrading thermal performance. It is recommended 8mil diameter drill holes of thermal vias, but a smaller via offers less risk of solder volume loss. On applications where solder volume loss thru the vias is of concern, plugging or tenting can be used to achieve a repeatable process. AGND L1 VCC AGND EN ILIM MODE VIN SW COMP SW FB SW VOUT SW VOUT SW VOUT BOOT PGATE VIN MODE VOUT_P S VOUT D PMOS G SS PGATE PGND Figure 21. PCB Layout Example Top Layer Thermal Considerations The maximum IC junction temperature should be restricted to 125°C under normal operating conditions. Calculate the maximum allowable dissipation, PD(max) , and keep the actual power dissipation less than or equal to PD(max) . The maximum-power-dissipation limit is determined using Equation 19. 𝑃𝐷(𝑀𝐴𝑋) = 125 − 𝑇𝐶𝐴 𝑅θJA (19) where  TA is the maximum ambient temperature for the application.  RθJA is the junction-to-ambient thermal resistance given in the Thermal Information table. SCT12A2 DFN package includes a thermal pad that improves the thermal capabilities of the package. The real junction-to-ambient thermal resistance RθJA of the package greatly depends on the PCB type, layout, thermal pad connection and environmental factor. Using thick PCB copper and soldering the thermal pad to a large ground plate enhance the thermal performance. Using more vias connects the ground plate on the top layer and bottom layer around the IC without solder mask also improves the thermal capability. 20For more information www.silicontent.com© 2018 Silicon Content Technology Co., Ltd. Product folder link: SCT12A2 All Rights Reserved SCT12A2 PACKAGE INFORMATION TOP VIEW BOTTOM VIEW SYMBOL SIDE VIEW NOTE: 1. 2. 3. 4. 5. 6. Drawing proposed to be made a JEDEC package outline MO220 variation. Drawing not to scale. All linear dimensions are in millimeters. Thermal pad shall be soldered on the board. Dimensions of exposed pad on bottom of package do not include mold flash. Contact PCB board fabrication for minimum solder mask web tolerances between the pins. A A1 b c D D2 D3 e e1 e2 Nd E E2 E3 E4 L h Unit: Millimeter MIN TYP MAX 0.85 0.9 0.95 —— 0.01 0.05 0.18 0.25 0.30 0.18 0.20 0.25 4.40 4.50 4.60 3.10 3.20 3.30 3.85REF 0.50BSC 0.75BSC 0.25BSC 3.50BSC 3.40 3.50 3.60 2.10 2.20 2.30 0.35REF 0.75REF 0.35 0.40 0.45 0.20 0.25 0.30 For more information www.silicontent.com© 2018 Silicon Content Technology Co., Ltd. All Rights Reserved 21 Product folder link: SCT12A2 SCT12A2 TAPE AND REEL INFORMATION Device SCT12A2DHKR Reel Width 12 Package Type DFN A Ø329±1 Pins 20 REEL DIMENSIONS B C 12.8±1 Ø100±1 SPQ 3000 D Ø13.3±0.3 t 2.0±0.3 TYPE DIMENSIONS W (mm) A0 (mm) B0 (mm) K0 (mm) t (mm) P (mm) 12±0.30 3.80±0.10 4.80±0.10 1.18±0.10 0.30±0.05 8±0.10 E (mm) F (mm) P2 (mm) D (mm) D1 (mm) P0 (mm) 10P0 (mm) 1.75±0.10 5.50±0.10 2.00±0.10 1.55±0.10 1.50MIN 4.00±0.10 40.0±0.20 22For more information www.silicontent.com© 2018 Silicon Content Technology Co., Ltd. Product folder link: SCT12A2 All Rights Reserved SCT12A2 RELATED PARTS PART NUMBERS DESCRIPTION COMMENTS SCT12A3 15-A Fully-integrated Synchronous Boost Converter Vin=2.7V-20V, 15A switch peak current with load disconnection control and AAO SCT12A0 12-A Fully-integrated Synchronous Boost Converter Vin=2.7V-14V, 12A switch peak current without load disconnection control SCT12A1 12-A Fully-integrated Synchronous Boost Converter with load disconnection Vin=2.7V-14V, 12A switch peak current with load disconnection control L1 1.5uH Q3 VIN C4 0.1uF R2 390k C2 47uF 0.1uF C1 SW FSW C6 1uF R3 390k VOUT_LOAD C7A 47uF C7B 47uF BOOT VOUT VIN PGATE EN FB ON OFF VCC C3 1uF 1nF C0 R0 300k SCT12A3 COMP RAAO ILIM R1 100k MODE R6 220k CAAO PGND C5 1uF R5 16.9k C9 4.7nF R4 59k C8 47pF Figure 22. SCT12A3 Typical Application NOTICE: The information in this document is subject to change without notice. Users should warrant and guarantee the third party Intellectual Property rights are not infringed upon when integrating Silicon Content Technology (SCT) products into any application. SCT will not assume any legal responsibility for any said applications. 23 Silicon Content Technology Co., Ltd. #1 Floor 2 Building 15, Yard 33 Dijin Road, Haidian District, Beijing 100095 (86 10) 64779806 FAX: (86 10) 64779806 www.silicontent.com© Silicon Content 2018
SCT12A2DHKR 价格&库存
很抱歉,暂时无法提供与“SCT12A2DHKR”相匹配的价格&库存,您可以联系我们找货
