GD25LT256EFIR
GD25LT256EFIR
    GIGADEVICE(兆易创新)
    SOP16
GD25LT256EFIR 数据手册
GD25LT256E GD25LT256E DATASHEET 1 GD25LT256E Contents 1. FEATURES .........................................................................................................................................................5 2. GENERAL DESCRIPTION ................................................................................................................................6 3. MEMORY ORGANIZATION...............................................................................................................................9 4. DEVICE OPERATION ...................................................................................................................................... 10 4.1. SPI MODE ............................................................................................................................................................ 10 4.2. QPI MODE............................................................................................................................................................ 10 4.3. QUAD DTR MODE ................................................................................................................................................. 10 4.4. ECC FUNCTION ...................................................................................................................................................... 10 4.5. RESET FUNCTION .................................................................................................................................................. 11 5. DATA PROTECTION ........................................................................................................................................ 12 6. DATA INTEGRITY CHECK .............................................................................................................................. 14 7. 8. 9. 6.1. ECC (ERROR CHECKING AND CORRECTING) ................................................................................................................. 14 6.2. ECS# (ERROR CORRECTED SIGNAL) PIN ...................................................................................................................... 15 6.3. PARITY CHECK (CRC) .............................................................................................................................................. 15 STATUS AND EXTENDED ADTRESS REGISTERS .................................................................................... 16 7.1. STATUS REGISTER ................................................................................................................................................... 16 7.2. FLAG STATUS REGISTER ........................................................................................................................................... 17 7.3. EXTENDED ADDRESS REGISTER .................................................................................................................................. 18 INTERNAL CONFIGURATION REGISTER ................................................................................................... 20 8.1. NONVOLATILE CONFIGURATION REGISTER ................................................................................................................... 20 8.2. VOLATILE CONFIGURATION REGISTER ......................................................................................................................... 22 8.3. SUPPORTED CLOCK FREQUENCIES .............................................................................................................................. 26 8.4. DATA SEQUENCE WRAPS BY DENSITY ......................................................................................................................... 27 COMMANDS DESCRIPTION .......................................................................................................................... 28 9.1. ENABLE 4-BYTE MODE (B7H) .................................................................................................................................. 33 9.2. DISABLE 4-BYTE MODE (E9H) .................................................................................................................................. 33 9.3. WRITE ENABLE (WREN) (06H) ................................................................................................................................ 34 9.4. WRITE DISABLE (WRDI) (04H) ................................................................................................................................ 34 9.5. WRITE ENABLE FOR VOLATILE STATUS REGISTER (50H) ................................................................................................. 35 9.6. WRITE STATUS REGISTER (WRSR) (01H) ................................................................................................................... 35 9.7. WRITE EXTENDED ADDRESS REGISTER (C5H)............................................................................................................... 36 9.8. WRITE NONVOLATILE/VOLATILE CONFIGURATION REGISTER (B1H/81H) ......................................................................... 37 9.9. READ STATUS REGISTER OR FLAG REGISTER (05H)........................................................................................................ 38 9.10. READ FLAG STATUS REGISTER OR FLAG REGISTER (70H) ................................................................................................ 39 9.11. READ NONVOLATILE/VOLATILE CONFIGURATION REGISTER (B5H/85H) ........................................................................... 39 2 GD25LT256E 9.12. READ EXTENDED ADDRESS REGISTER (C8H) ................................................................................................................ 40 9.13. READ DATA BYTES (03H/13H) ................................................................................................................................ 41 9.14. READ DATA BYTES AT HIGHER SPEED (0BH/0CH) ........................................................................................................ 42 9.15. QUAD OUTPUT FAST READ (6BH/6CH) ..................................................................................................................... 43 9.16. QUAD I/O FAST READ (EBH/ECH) ........................................................................................................................... 44 9.17. QUAD I/O DTR READ (EDH/EEH) ........................................................................................................................... 46 9.18. PAGE PROGRAM (PP) (02H/12H) ............................................................................................................................ 48 9.19. QUAD PAGE PROGRAM (32H/34H) .......................................................................................................................... 49 9.20. EXTEND QUAD PAGE PROGRAM (C2H/3EH) .............................................................................................................. 51 9.21. SECTOR ERASE (SE) (20H/21H) ............................................................................................................................... 52 9.22. 32KB BLOCK ERASE (BE) (52H/5CH) ....................................................................................................................... 53 9.23. 64KB BLOCK ERASE (BE) (D8H/DCH) ...................................................................................................................... 54 9.24. CHIP ERASE (CE) (60/C7H) ..................................................................................................................................... 55 9.25. CLEAR SR FLAGS (30H) ........................................................................................................................................... 56 9.26. ENABLE QPI (38H) ................................................................................................................................................ 56 9.27. DISABLE QPI (FFH) ................................................................................................................................................ 56 9.28. DEEP POWER-DOWN (DP) (B9H) ............................................................................................................................. 57 9.29. RELEASE FROM DEEP POWER-DOWN (ABH) ............................................................................................................... 57 9.30. READ UNIQUE ID (4BH) .......................................................................................................................................... 58 9.31. READ IDENTIFICATION (RDID) (9FH/9EH) ................................................................................................................. 59 9.32. PROGRAM/ERASE SUSPEND (PES) (75H) ................................................................................................................... 60 9.33. PROGRAM/ERASE RESUME (PER) (7AH) ................................................................................................................... 61 9.34. ERASE SECURITY REGISTERS (44H) ............................................................................................................................ 62 9.35. PROGRAM SECURITY REGISTERS (42H) ....................................................................................................................... 63 9.36. READ SECURITY REGISTERS (48H) ............................................................................................................................. 64 9.37. INDIVIDUAL BLOCK/SECTOR LOCK (36H)/UNLOCK (39H)/READ (3DH) ........................................................................... 66 9.38. GLOBAL BLOCK/SECTOR LOCK (7EH) OR UNLOCK (98H) ............................................................................................... 68 9.39. ENABLE RESET (66H) AND RESET (99H) ..................................................................................................................... 69 9.40. READ SERIAL FLASH DISCOVERABLE PARAMETER (5AH)................................................................................................. 70 10. ELECTRICAL CHARACTERISTICS .......................................................................................................... 72 10.1. POWER-ON TIMING ........................................................................................................................................... 72 10.2. INITIAL DELIVERY STATE ..................................................................................................................................... 72 10.3. ABSOLUTE MAXIMUM RATINGS ........................................................................................................................ 72 10.4. CAPACITANCE MEASUREMENT CONDITIONS .................................................................................................... 73 10.5. DC CHARACTERISTICS......................................................................................................................................... 74 10.6. AC CHARACTERISTICS ......................................................................................................................................... 75 11. 11.1. 12. ORDERING INFORMATION........................................................................................................................ 79 VALID PART NUMBERS ............................................................................................................................................ 80 PACKAGE INFORMATION ......................................................................................................................... 81 12.1. PACKAGE SOP16 300MIL ....................................................................................................................................... 81 12.2. PACKAGE TFBGA-24BALL (5X5 BALL ARRAY) ............................................................................................................. 82 3 GD25LT256E 13. REVISION HISTORY .................................................................................................................................... 83 4 GD25LT256E 1. FEATURES ◆ ◆ 256M-bit Serial Flash Fast Program/Erase Speed - 32M-Byte - Page Program time: 0.4ms typical - 256 Bytes per programmable page - Sector Erase time: 30ms typical - Block Erase time: 0.1/0.2s typical ◆ Standard, Quad SPI, DTR,QPI - Chip Erase time: 50s typical - Standard SPI: SCLK, CS#, SI, SO, WP#, RESET# ◆ - Quad SPI: SCLK, CS#, IO0, IO1, IO2, IO3, RESET# ◆ Flexible Architecture - QPI: SCLK, CS#, IO0, IO1, IO2, IO3, RESET# - Sector of 4K-Byte - SPI DTR (Double Transfer Rate) Read - Block of 32/64K-Byte - 3 or 4-Byte Address Mode - Erase/Program Suspend/Resume ◆ High Speed Clock Frequency Low Power Consumption - 200MHz for fast read with 30PF load - 25uA typical stand-by current - Quad I/O Data transfer up to 664Mbits/s - 5uA typical power down current - QPI Mode Data transfer up to 664Mbits/s - DTR Quad I/O Data transfer up to 1600Mbits/s with DQS ◆ Advanced Security Features - 128-bit Unique ID ◆ Allows XIP(execute in place)operation - 4K-Byte Security Registers With OTP Lock - High speed Read reduce overall XiP instruction fetch time - Continuous Read with Wrap further reduce data latency to ◆ fill up SoC cache ◆ Single Power Supply Voltage - Full voltage range:1.65~2.0V ◆ Software/Hardware Write Protection Endurance and Data Retention - Write protect all/portion of memory via software - Minimum 100,000 Program/Erase Cycles - Enable/Disable protection with WP# Pin - 20-year data retention typical - Advanced Sector Protection ◆ - Top or Bottom selection Package Information - SOP16 300mil ◆ Data Integrity Check - On-chip ECC (1-bit correction every - TFBGA-24ball (5x5 Ball Array) 8-Byte) (1) - CRC detects accidental changes to raw data Note: 1. When ECC is enabled, it is required to program minimum one or multiple aligned 8-Byte granularities. Every aligned 8Byte granularity should only be programmed once before Erase to ensure correct ECC operations. 5 GD25LT256E 2. GENERAL DESCRIPTION The GD25LT256E (256M-bit) Serial flash supports the standard Serial Peripheral Interface (SPI), and supports the Quad SPI and DTR mode: Serial Clock, Chip Select, Serial Data I/O0 (SI), I/O1 (SO), I/O2, I/O3, WP#, and RESET#. The Quad I/O & Quad output data is transferred with speed of 664Mbits/s, and the DTR Quad I/O data is transferred with speed of 1600Mbits/s. CONNECTION DIAGRAM Top View IO3 1 16 SCLK VCC 2 15 SI (IO0) RESET# 3 14 NC NC 4 13 DQS Top View NC 5 12 NC NC 6 11 NC CS# 7 10 VSS 9 WP# (IO2) SO (IO1) 8 A2 A3 NC NC B1 B2 B3 B4 B5 NC SCLK VSS VCC NC C1 C2 C3 A5 C4 C5 DNU VSS CS# DQS WP# (IO2) D1 D2 D3 D4 D5 IO3 NC VCC 16-LEAD SOP A4 RESET# ECS# SO(IO1) SI(IO0) E1 E2 E3 E4 E5 NC NC NC VCC VSS 24-BALL TFBGA (5x5 ball array) Note: 1. CS# must be driven high if chip is not selected. Please don’t leave CS# floating any time after power is on. 2. The DNU pin/ball must be floating. It may connect to internal signal inside. 3. The NC pin/ball is not connected to any internal signal. It is OK to connect it to the system ground (GND) or leave it floating. 4. The pin of RESET# will remain internal pull up function while this pin is not physically connected in system configuration. However, the internal pull up function will be disabled if the system has physical connection to RESET# pin. 6 GD25LT256E PIN DESCRIPTION Table 1 Pin Description for SOP16 package Pin No. Pin Name I/O Description 1 IO3 I/O Data Input Output 3 2 VCC 3 RESET# I Reset Input 7 CS# I Chip Select Input 8 SO (IO1) I/O Data Output (Data Input Output 1) 9 WP# (IO2) I/O Data Input Output 2 10 VSS 13 DQS O Data Strobe Signal Output 15 SI (IO0) I/O Data Input (Data Input Output 0) 16 SCLK I Power Supply Ground Serial Clock Input Table 2 Pin Description for TFBGA24 5*5 ball array package Pin No. Pin Name I/O Description A4 RESET# I Reset Input A5 ECS# O ECC Correction Signal B2 SCLK I Serial Clock Input B3/C1/E5 VSS Ground B4/D1/E4 VCC Power Supply C2 CS# I Chip Select Input C3 DQS O Data Strobe Signal Output C4 WP# (IO2) I/O Data Input Output 2 C5 DNU I D2 SO (IO1) I/O Data Output (Data Input Output 1) D3 SI (IO0) I/O Data Input (Data Input Output 0) D4 IO3 I/O Data Input Output 3 Do Not Use (It may connect to internal signal inside) 7 GD25LT256E BLOCK DIAGRAM Write Control Logic Status Register RESET# IO2 IO3 SCLK CS# SI(IO0) SPI Command & Control Logic High Voltage Generators Page Address Latch/Counter Flash Memory Column Decode And 256-Byte Page Buffer SO(IO1) DQS ECS# Write Protect Logic and Row Decode WP# Byte Address Latch/Counter 8 GD25LT256E 3. MEMORY ORGANIZATION GD25LT256E Each device has Each block has Each sector has Each page has 32M 64/32K 4K 256 Bytes 128K 256/128 16 - pages 8192 16/8 - - sectors 512/1024 - - - blocks UNIFORM BLOCK SECTOR ARCHITECTURE GD25LT256E 64K Bytes Block Sector Architecture Block 511 510 …… …… 2 1 0 Sector Address range 8191 1FFF000h 1FFFFFFh …… …… …… 8176 1FF0000h 1FF0FFFh 8175 1FEF000h 1FEFFFFh …… …… …… 8160 1FE0000h 1FE0FFFh …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… …… 47 02F000h 02FFFFh …… …… …… 32 020000h 020FFFh 31 01F000h 01FFFFh …… …… …… 16 010000h 010FFFh 15 00F000h 00FFFFh …… …… …… 0 000000h 000FFFh 9 GD25LT256E 4. DEVICE OPERATION 4.1. SPI Mode Standard SPI The GD25LT256E features a serial peripheral interface on 4 signals bus: Serial Clock (SCLK), Chip Select (CS#), Serial Data Input (SI) and Serial Data Output (SO). Both SPI bus mode 0 and 3 are supported. Input data is latched on the rising edge of SCLK and data shifts out on the falling edge of SCLK. Quad SPI The GD25LT256E supports Quad SPI operation when using the “Quad Output Fast Read”, “Quad I/O Fast Read”, “Quad Page Program” (6BH/6CH, EBH/ECH, 32H/34H, C2H/3EH) commands. These commands allow data to be transferred to or from the device at four times the rate of the standard SPI. When using the Quad SPI command the SI and SO pins become bidirectional I/O pins: IO0 and IO1. DTR Quad SPI The GD25LT256E supports DTR Quad SPI operation when using the “DTR Quad I/O Fast Read” (EDH/EEH) command. These commands allow data to be transferred to or from the device at eight times the rate of the standard SPI, and data output will be latched on both rising and falling edges of the serial clock. When using the DTR Quad SPI command the SI and SO pins become bidirectional I/O pins: IO0 and IO1. 4.2. QPI Mode The GD25LT256E supports Quad Peripheral Interface (QPI) operations only when the device is switched from Standard/Quad SPI mode to QPI mode using the “Enable the QPI (38H)” command. The QPI mode utilizes all four IO pins to input the command code. Standard/Quad SPI mode and QPI mode are exclusive. Only one mode can be active at any given times. “Enable the QPI (38H)” and “Disable the QPI (FFH)” commands are used to switch between these two modes. Upon power-up and after software reset using “”Reset (99H)” command, the default state of the device is Standard/Quad SPI mode. 4.3. Quad DTR Mode The GD25LT256E supports Quad DTR operations only when the device is Quad DTR mode, which could be entered by setting Byte in Configuration Register as E7H/C7H with the “Write Volatile Configuration Register command (81H)”. By setting Byte in Configuration Register not equal to E7H/C7H with the “Write Volatile Configuration Register command (81H)”, Quad DTR Mode is quitted. The Quad DTR Mode utilizes all four IO pins to input the command code latched on the rising edge of SCLK. All four IO pins are used to input the address output the data on both rising and falling edges of SCLK. 4.4. ECC Function The ECC Correction Signal (ECS#) pin is provided to the system hardware designers to determine the ECC status during any Read operation. The ECS# pin will be pulled low during any 8-Byte Read data output period in which an ECC event has occurred. ECS# pin can be used to represent SEC (Single Error Correction). ECC Correction Signal Output pin is an Open-Drain connection. 10 GD25LT256E 4.5. RESET Function The RESET# pin allows the device to be reset by the control. The RESET# pin goes low for a minimum period of tRLRH will reset the flash. After reset cycle, the flash is at the following states: -Standby mode -All the volatile bits will return to the default status as power on. Figure 1 RESET Condition CS# RESET# RESET 11 GD25LT256E 5. DATA PROTECTION The GD25LT256E provide the following data protection methods: ◆ Write Enable (WREN) command: The WREN command is set the Write Enable Latch bit (WEL). The WEL bit will return to reset by the following situation: -Power-Up/ Software reset (66H+99H) -Write Disable (WRDI) -Write Status Register (WRSR) -Write Extended Address Register (WEAR) -Write Nonvolatile Configuration Register (WNVCR) -Write Volatile Configuration Register (WVCR) -Page Program (PP) -Sector Erase (SE) / Block Erase (BE) / Chip Erase (CE) -Erase Security Registers / Program Security Registers ◆ Software Protection Mode: -The Block Protect (BP3, BP2, BP1, and BP0) bits and Top Bottom (TB) bit define the section of the memory array that can be read but cannot be changed. - Individual Block Protection bit provides the protection selection of each individual block and sectors in the top and bottom block. ◆ Hardware Protection Mode: WP# goes low to protect the BP0~BP3 bits, TB bit and SRP0 bit. ◆ Deep Power-Down Mode: In Deep Power-Down Mode, all commands are ignored except the Release from Deep Power-Down Mode command and reset command (66H+99H). Table 3 GD25LT256E Protected area size Status Register Content Memory Content TB BP3 BP2 BP1 BP0 Blocks Addresses Density Portion X 0 0 0 0 NONE NONE NONE NONE 0 0 0 0 1 511 01FF0000h-01FFFFFFh 64KB Upper 1/512 0 0 0 1 0 510 to 511 01FE0000h-01FFFFFFh 128KB Upper 1/256 0 0 0 1 1 508 to 511 01FC0000h-01FFFFFFh 256KB Upper 1/128 0 0 1 0 0 504 to 511 01F80000h-01FFFFFFh 512KB Upper 1/64 0 0 1 0 1 496 to 511 01F00000h-01FFFFFFh 1MB Upper 1/32 0 0 1 1 0 480 to 511 01E00000h-01FFFFFFh 2MB Upper 1/16 0 0 1 1 1 448 to 511 01C00000h-01FFFFFFh 4MB Upper 1/8 0 1 0 0 0 384 to 511 01800000h-01FFFFFFh 8MB Upper 1/4 0 1 0 0 1 256 to 511 01000000h-01FFFFFFh 16MB Upper 1/2 1 0 0 0 1 0 00000000h-0000FFFFh 64KB Lower 1/512 1 0 0 1 0 0 to 1 00000000h-0001FFFFh 128KB Lower 1/256 1 0 0 1 1 0 to 3 00000000h-0003FFFFh 256KB Lower 1/128 1 0 1 0 0 0 to 7 00000000h-0007FFFFh 512KB Lower 1/64 1 0 1 0 1 0 to 15 00000000h-000FFFFFh 1MB Lower 1/32 1 0 1 1 0 0 to 31 00000000h-001FFFFFh 2MB Lower 1/16 12 GD25LT256E 1 0 1 1 1 0 to 63 00000000h-003FFFFFh 4MB Lower 1/8 1 1 0 0 0 0 to 127 00000000h-007FFFFFh 8MB Lower 1/4 1 1 0 0 1 0 to 255 00000000h-00FFFFFFh 16MB Lower 1/2 X 1 1 0 X ALL 00000000h-01FFFFFFh 32MB ALL X 1 X 1 X ALL 00000000h-01FFFFFFh 32MB ALL Table 4 GD25LT256E Individual Block Protection (WPS=0) Block Sector Address range Individual Block Lock Operation 8191 01FF F000h 01FF FFFFh 512 Blocks …… …… …… Block Lock: 36H+Address 8176 01FF0000h 01FF0FFFh Block Unlock: 39H+Address 510 …… 01FE0000h 01FEFFFFh Read Block Lock: 3DH+Address …… …… …… …… Global Block Lock: 7EH …… …… …… …… Global Block Unlock: 98H …… …… …… …… 1 …… 010000h 01FFFFh 15 00F000h 00FFFFh …… …… …… 0 000000h 000FFFh 511 0 Notes: 1. Protection configuration: This bit is used to select which Write Protect scheme should be used. 2. Volatile lock bits. Each volatile bit corresponds to and provides volatile protection for an individual memory sector, which is locked temporarily (protection is cleared when the device is reset or powered down). 3. The first and last sectors will have volatile protections at the 4KB sector level. Each 4KB sector in these sectors can be individually locked by volatile lock bits setting. 13 GD25LT256E 6. DATA INTEGRITY CHECK The data storage and transmission errors will cause unexpected Flash device variation that makes a harmful impact on overall system functions. To prevent these errors, GD25LT256E product provides advanced Data Integrity Check function. For the data storage and data transmission in the flash device, Data Integrity Check can check errors and correct them, allowing self-checking and preventing errors in advance. The Data Integrity Check function includes two methods: - ECC (Error Checking and Correcting): to prevent the data storage errors - Parity Check (CRC): to prevent the data transmission errors The register data and software signals can also be used to associate the Data Integrity Check function to fully record the results of checking, and can also immediately feedback. 6.1. ECC (Error Checking and Correcting) Error Correction Codes (ECC) is a commonly used technique in non-volatile memory to reduce the device Bit Error Rate (BER) during the device operation life and improve device reliability. To achieve error detection and correction, redundancy data must be added to store the ECC calculation results for a given length of data. In GD25LT256E, every aligned 8-Byte data (A[2:0] = 0, 0, 0) stored in the memory array will be checked by the internal ECC engine using SEC (Single Error Correction) Hsiao Codes algorithm. With 8-Byte ECC data granularity, ECC calculation latency time can be minimized and highest level of data integrity can be preserved. The default value of all memory data is FFH (Erased) when the device is shipped from the factory. A “Page Program (02H/12H)” or a “Quad Page Program (32H/3EH)” command can be used to program the user data into the memory array. When ECC is enabled (ECC=1 in Configuration Register), ECC calculation will be performed during the internal programming operation and the results are stored in the redundancy or spare area of the memory array. It is necessary to program every page in aligned 8-Byte granularity so that ECC engine can store the correct ECC information. It is also required that every aligned 8-Byte data granularity can only be programmed once to avoid additional ECC calculation in the same granularity resulting incorrect ECC results. A technique previously known as “Incremental Byte/Bit Programming to the same Byte location” cannot be used for GD25LT256E when ECC is enabled. During data read operations, the internal ECC engine will check the ECC results stored in the spare area and apply necessary error correction or error detection to the main array data being read out. It is necessary to check the ECC Status Bits (SEC) in the Status Register after every Read operation to see if the data read out contains one error or not. A Read operation can start from any Byte address and continue through the entire memory array, so it is not necessary to align the 8-Byte granularity boundary address to start a Read command. Additional hardware monitoring of the ECC status can also be used to observe the ECC status in real time during any data output. When configured, the ECS# (ECC Correction Signal) pin will be pulled low during any aligned 8-Byte data output if it contains SEC event. The ECC mode can be exited through anyone of the following situations: - Sending a new Read Command - Issuing Software Reset Command - Hardware Reset - Power-up cycle 14 GD25LT256E 6.2. ECS# (Error corrected Signal) Pin The ECS# pin is a real time hardware signal to feedback the ECC correction status. The ECS# pin is designed as an open drain structure. In normal situation, the ECS# is kept on High-Z state. Once error correction begins, the ECS# pin will pull low during the whole ECC chunk unit after a duration of tECSV delay timing The ECS# (ECC Correction Signal) pin will be pulled low during any aligned 8-Byte data output if it contains SEC (Single Error Correction) event. Figure 2. ECS# Timing CS# SCLK IO[3:0] Command & Address & Dummys ECC chunk (8 Bytes) ECC chunk (8 Bytes) High-Z High-Z ECS# tECSV ECC chunk with ECC error detected 6.3. Parity Check (CRC) The parity check function can only be operated at DTR QPI read, it does not support STR read. The bit7~6 in Byte of the Configuration Register can set the parity check function. For read operation after the Parity check function is enabled, the data CRC bit should be output by each CRC chunk unit. Otherwise, read CRC code might be error. The CRC Chunk size can be configured as 16-Byte, 32-Byte, or 64-Byte by the Configure Register setting. However, when the device enters the “Read with Wrap” mode, while the CRC function is also enabled, and the CRC Chunk size will be set to be identical with the Wrap Length (16, 32 or 64 Byte) by internal circuitry. Only when the device is not in the “Read with Wrap” mode, the original CRC Chunk size setting will be restored. The data CRC Bytes are calculated by exclusive-OR on each I/O bus in the CRC chunk. Figure 3. CRC Timing CS# SCLK IO[3:0] Command & Address & Dummys CRC Multiple of CRC chunks 15 CRC Multiple of CRC chunks GD25LT256E 7. STATUS AND EXTENDED ADTRESS REGISTERS 7.1. Status Register No. Bit Name Description Note S0 WIP Erase/Write In Progress Volatile, read only S1 WEL Write Enable Latch Volatile, read only S2 BP0 Block Protect Bits Non-volatile writable S3 BP1 Block Protect Bits Non-volatile writable S4 BP2 Block Protect Bits Non-volatile writable S5 BP3 Block Protect Bits Non-volatile writable S6 TB Top/Bottom Protect Bit Non-volatile writable S7 SRP0 Status Register Protection Non-volatile writable The status and control bits of the Status Register are as follows: WIP bit The Write in Progress (WIP) bit indicates whether the memory is busy in program/erase/write status register or configuration register progress. When WIP bit sets to 1, means the device is busy in program/erase/write status register or configuration register progress, when WIP bit sets 0, means the device is not in program/erase/write status register or configuration register progress. WEL bit The Write Enable Latch (WEL) bit indicates the status of the internal Write Enable Latch. When set to 1 the internal Write Enable Latch is set, when set to 0 the internal Write Enable Latch is reset and no Write, Program or Erase command is accepted. TB bit The Top Bottom (TB) bit is non-volatile. The Top/Bottom (TB) bit is used to configure the Block Protect area by BP bit (BP3, BP2, BP1, and BP0), starting from Top or Bottom of the memory array. The TB bit is defaulted as “0”, which means Top area protect. When it is set to “1”, the protect area will change to Bottom area of the memory device. This bit is written with the Write Status Register (WRSR) command. BP3, BP2, BP1, BP0 bits The Block Protect (BP3, BP2, BP1, and BP0) bits are non-volatile. They define the size of the area to be software protected against Program and Erase commands. These bits are written with the Write Status Register (WRSR) command. When the Block Protect (BP3, BP2, BP1, and BP0) bits are set to 1, the relevant memory area becomes protected against Page Program (PP), Sector Erase (SE) and Block Erase (BE) commands. The Block Protect (BP3, BP2, BP1, and BP0) bits can be written provided that the Hardware Protected mode has not been set. The Chip Erase (CE) command is executed only if none sector or block is protected. SRP0 SRP1 bits The Status Register Protect SRP0 bit are non-volatile Read/Write bits in the status register. The SRP0 bit in conjunction 16 GD25LT256E with SRP1 bit (Reference Configuration Register) control the method of write protection: software protection, hardware protection, power supply lock-down or one time programmable protection. SRP1 SRP0 WP# Status Register X 0 X Software Protected 0 1 0 Hardware Protected 0 1 1 Hardware Unprotected 1 1 X One Time Program(1) Description The Status Register can be written to after a Write Enable command, WEL=1. (Default) WP#=0, the Status Register locked and cannot be written to. WP#=1, the Status Register is unlocked and can be written to after a Write Enable command, WEL=1. Status Register is permanently protected and cannot be written to. NOTE: 1. This feature is available on special order. Please contact GigaDevice for details. 7.2. Flag Status Register No. Bit Name Description Note FS0 ADS Current Address Mode Volatile, read only FS1 Protection 0=clear;1=failure or protection error Volatile, read only FS2 SUS_P Program Suspend Volatile, read only FS3 Reserved Reserved Volatile, read only FS4 PE Program Error bit Volatile, read only FS5 EE Erase Error bit Volatile, read only FS6 SUS_E Erase Suspend Volatile, read only FS7 RY/BY# Ready/Busy# Volatile, read only The status and control bits of the Flag Status Register are as follows: ADS bit The Address Status (ADS) bit is a read only bit that indicates the current address mode the device is operating in. The device is in 3-Byte address mode when ADS=0 (default), and in 4-Byte address mode when ADS=1. Protection bit The Protection bit is a read only bit that indicates a program or erase failure. Indicates whether an ERASE or PROGRAM operation has attempted to modify the protected array sector, or whether a PROGRAM operation has attempted to access the locked OTP space. Error bits can be reset by CLEAR FLAG STATUS REGISTER command (30H). SUS_E, SUS_P bits The SUS_E and SUS_P bits are read only bits in the Flag Status Register (FS6 and FS2) that are set to 1 after executing an Erase/Program Suspend (75H) command (The Erase Suspend will set the SUS_E to 1,and the Program Suspend will set the SUS_P to 1). The SUS_E and SUS_P bits are cleared to 0 by Erase/Program Resume (7AH) command, software reset (66H+99H) command as well as a power-down, power-up cycle. 17 GD25LT256E PE bit The Program Error (PE) bit is a read only bit that indicates a program failure. It will also be set when the user attempts to program a protected array sector or access the locked OTP space. Error bits can be reset by CLEAR FLAG STATUS REGISTER command (30H). EE bit The Erase Error (EE) bit is a read only bit that indicates an erase failure. It will also be set when the user attempts to erase a protected array sector or access the locked OTP space. Error bits can be reset by CLEAR FLAG STATUS REGISTER command (30H). RY/BY# bit The RY/BY# bit is a read only bit that indicates Program or Erase Status bit. Indicates whether one of the following command cycles is in progress: WRITE STATUS REGISTER, WRITE NONVOLATILE CONFIGURATION REGISTER, PROGRAM, or ERASE. 7.3. Extended Address Register Table 5 Extended Address Register No. Name Description Note EA0 A24 Address bit Volatile writable EA1 Reserved Reserved Reserved EA2 Reserved Reserved Reserved EA3 Reserved Reserved Reserved EA4 Reserved Reserved Reserved EA5 Reserved Reserved Reserved EA6 Reserved Reserved Reserved EA7 SEC Error Correction bit Volatile, read only The extended address register is only used when the address mode is 3-Byte mode, as to set the higher address. A24=1 indicates the upper 128Mb memory address, A24=0 indicates the lower 128Mb. The default value of EA0 is “0”. For the read operation, the whole array data can be continually read out with one command. Data output starts from the selected top or bottom 128Mb, and it can cross the boundary. When the last Byte of the segment is reached, the next Byte (in a continuous reading) is the first Byte of the next segment. However, the EAR (Extended Address Register) value does not change. The random access reading can only be operated in the selected segment. The Chip erase command will erase the whole chip and is not limited by EAR selected segment. However, the sector erase, block erase, program operation are limited in selected segment and will not cross the boundary. A24 bit The Extended Address Bit A24 is used only when the device is operating in the 3-Byte Address Mode (ADS=0), which is volatile writable by C5H command. The lower 128Mb memory array (00000000h – 00FFFFFFh) is selected when A24=0, and all instructions with 3-Byte addresses will be executed within that region. When A24=1, the upper 128Mb memory array (01000000h – 01FFFFFFh) will be selected. If Configuration Register Byte is set to FEH, or an “Enter 4-Byte Address Mode (B7H)” instruction is issued, the device will require 4-Byte address input for all address related instructions, and the Extended Address Bit A24 setting will be ignored. 18 GD25LT256E SEC bits SEC (Single Error Correction) Status Bit are used to show the ECC results for the last Read operation. SEC bit will be cleared to 0 once the device accepts a new Read command. SEC 0 1 Definitions No ECC events in all aligned 8-Byte granularities SEC events in single or multiple 8-Byte granularities, and the data is OK to use. (Unless it contains more than one odd bit errors in 8-Byte granularity) 19 GD25LT256E 8. INTERNAL CONFIGURATION REGISTER The memory configuration is set by an internal configuration register that is not directly accessible to users. The user can change the default configuration at power up by using the WRITE NONVOLATILE CONFIGURATION REGISTER. Information from the nonvolatile configuration register overwrites the internal configuration register during power on or after a reset. The user can change the configuration during device operation using the WRITE VOLATILE CONFIGURATION REGISTER command. Information from the volatile configuration registers overwrite the internal configuration register immediately after the WRITE command completes. Nonvolatile to volatile register download after power-on or RESET Nonvolatile configuration register Nonvolatile to internal register download after power-on or RESET Volatile configuration register Volatile to internal register download after Write Volatile Configuration Register Command Internal configuration register Device behavior 8.1. Nonvolatile Configuration Register Nonvolatile Configuration Register bits set the device configuration after power-up or reset. All bits are erased (FFh) unless stated otherwise. This register is read from and written to using the READ NONVOLATILE CONFIGURATION REGISTER and the WRITE NONVOLATILE CONFIGURATION REGISTER commands, respectively. The commands use the main array address scheme, but only the LSB is used to access different register settings, thereby providing up to 256 Bytes of registers (See the table below for the details). A READ command from a reserved address returns FFh. A WRITE command to a reserved setting is ignored, flag status register bit 1 is set, and the write enable latch bit isn’t cleared. Table 6 Nonvolatile Configuration Register Addr Settings I/O mode bit7 bit6 bit5 bit4 bit3 bit2 bit1 bit0 Description 1 1 1 1 1 1 1 1 SPI or QPI with DQS (Default) 1 1 0 1 1 1 1 1 SPI or QPI W/O DQS 1 1 1 0 0 1 1 1 Quad DTR with DQS 1 1 0 0 0 1 1 1 Quad DTR W/O DQS The Same as Default Value (SPI Others Dummy cycle configuration(1-7) 0 with DQS) 0 0 0 0 20 0 0 0 Initiation Dummy According to Specific Command GD25LT256E 0 0 0 0 0 0 1 1 3 Dummy 0 0 0 0 0 1 0 0 4 Dummy … 0 05~1D: 5~29 Dummy 0 0 1 1 1 1 0 Initiation Dummy According to Others Specific Command x x x x x x 0 x x x x x x x 1 Security Registers Locked x x x 0 x x x x SRP1 Unlocked (Default) x x x 1 x x x x SRP1 Locked 1 1 1 1 1 1 1 1 50 Ohm (Default) 1 1 1 1 1 1 1 0 35 Ohm Driver Strength 1 1 1 1 1 1 0 1 25 Ohm configuration 1 1 1 1 1 1 0 0 18 Ohm OTP configuration The Same as Default Value (50 Ohm) 1 x x x x x x CRC Disabled (Default) 1 0 x x x x x x 16-Byte CRC 0 1 x x x x x x 32-Byte CRC 0 0 x x x x x x 64-Byte CRC x x 1 1 x x x x ODT Disabled (Default) x x 1 0 x x x x 150-Ohm ODT x x 0 1 x x x x 100-Ohm ODT x x 0 1 x x x x 50-Ohm ODT x x x x 1 x x x DLP Disabled x x x x 0 x x x DLP Enabled Protection x x x x x 1 x x BP Protection (Default) configuration x x x x x 0 x x WPS Protection(8) x x x x x x x 1 ECC Enabled x x x x x x x 0 ECC Disabled (Default) 1 1 1 1 1 1 1 1 3-Byte Address (Default) 1 1 1 1 1 1 1 0 4-Byte Address On die termination DLP configuration ECC configuration Beyond 128Mb addr. configuration XIP configuration(9) The Same as Default Value (3- Others Byte Address) 1 1 1 1 1 1 1 1 XIP Disabled (Default) 1 1 1 1 1 1 1 0 XIP Enabled The Same as Default Value (XIP Others (Default) 1 CRC configuration Security Registers unlocked x Others 30 Dummy Wrap configuration Disabled) 1 1 1 1 1 1 1 1 Wrap Disabled (Default) 1 1 1 1 1 1 1 0 64-Byte Wrap 1 1 1 1 1 1 0 1 32-Byte Wrap 21 GD25LT256E 1 1 1 1 1 1 0 0 16-Byte Wrap The Same as Default Value (Wrap Others Disabled) Notes: 1. The number of cycles must be set to accord with the clock frequency, which varies by the type of FAST READ command (See Supported Clock Frequencies table). Insufficient dummy clock cycles for the operating frequency causes the memory to read incorrect data. 2. 03H/13H: SPI 0 dummy; QPI&DTR N/A 3. 05H/70H/9EH/9FH: SPI&QPI 0 dummy; DTR 8 dummy. 4. 3DH: SPI 0dummy; QPI&DTR 8 dummy. 5. 4BH/5AH/B5H/85H: SPI&QPI&DTR 8 dummy. 6. 0BH/0CH/6BH/6CH/48H: SPI 8dummy; QPI&DTR dummy follow CONFIGURATION REGISTER (initiation = 16 dummy) 7. EBH/ECH/EDH/EEH: SPI&QPI&DTR dummy follow CONFIGURATION REGISTER (initiation = 16 dummy) 8. When WPS protection is enabled, the entire memory array is being protected after Power-up or Reset. 9. Only Quad I/O (EBH and ECH) and DTR Quad I/O fast read (EDH and EEH) support wrap read and XIP operation. 8.2. Volatile Configuration Register Volatile Configuration Register bits temporarily set the device configuration after power-up or reset. All bits are erased (FFh) unless stated otherwise. This register is read from and written to using the READ VOLATILE CONFIGURATION REGISTER and the WRITE VOLATILE CONFIGURATION REGISTER commands, respectively. The commands use the main array address scheme; however, only the LSB is used to access different register settings to provide up to 256 Bytes of registers (See the table below for the details). A READ command from a reserved address returns FFh. A WRITE command to a reserved setting is ignored, flag status register bit 1 is set, and the write enable latch bit isn’t cleared. Table 7 Volatile Configuration Register Addr Settings I/O mode bit7 bit6 bit5 bit4 bit3 bit2 bit1 bit0 Description 1 1 1 1 1 1 1 1 SPI or QPI with DQS (Default) 1 1 0 1 1 1 1 1 SPI or QPI W/O DQS 1 1 1 0 0 1 1 1 Quad DTR with DQS 1 1 0 0 0 1 1 1 Quad DTR W/O DQS The Same as Default Value (SPI Others with DQS) 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 3 Dummy Dummy cycle 0 0 0 0 0 1 0 0 4 Dummy configuration(1-7) … 0 Reserved x Specific Command 05~1D: 5~29 Dummy 0 0 1 1 1 1 0 30 Dummy Initiation Dummy According to Others Initiation Dummy According to 0 Specific Command x x x x 22 x x x Reserved GD25LT256E 1 1 1 1 1 1 1 1 50 Ohm (Default) 1 1 1 1 1 1 1 0 35 Ohm Driver Strength 1 1 1 1 1 1 0 1 25 Ohm configuration 1 1 1 1 1 1 0 0 18 Ohm The Same as Default Value (50 Others 1 1 x x x x x x CRC Disabled (Default) 1 0 x x x x x x 16-Byte CRC 0 1 x x x x x x 32-Byte CRC 0 0 x x x x x x 64-Byte CRC x x 1 1 x x x x ODT Disabled (Default) x x 1 0 x x x x 150-Ohm ODT x x 0 1 x x x x 100-Ohm ODT x x 0 1 x x x x 50-Ohm ODT x x x x 1 x x x DLP Disabled x x x x 0 x x x DLP Enabled Protection x x x x x 1 x x BP Protection (Default) configuration x x x x x 0 x x WPS Protection(8) x x x x x x x 1 ECC Enabled x x x x x x x 0 ECC Disabled (Default) 1 1 1 1 1 1 1 1 3-Byte Address (Default) 1 1 1 1 1 1 1 0 4-Byte Address CRC configuration On die termination DLP configuration ECC configuration Ohm) Beyond 128Mb addr. configuration XIP configuration(9) The Same as Default Value (3- Others Byte Address) 1 1 1 1 1 1 1 1 XIP Disabled (Default) 1 1 1 1 1 1 1 0 XIP Enabled The Same as Default Value (XIP Others Wrap configuration Disabled) 1 1 1 1 1 1 1 1 Wrap Disabled (Default) 1 1 1 1 1 1 1 0 64-Byte Wrap 1 1 1 1 1 1 0 1 32-Byte Wrap 1 1 1 1 1 1 0 0 16-Byte Wrap The Same as Default Value (Wrap Others Disabled) Notes: 1. The number of cycles must be set to accord with the clock frequency, which varies by the type of FAST READ command (See Supported Clock Frequencies table). Insufficient dummy clock cycles for the operating frequency causes the memory to read incorrect data. 2. 03H/13H: SPI 0 dummy; QPI&DTR N/A 3. 05H/70H/9EH/9FH: SPI&QPI 0 dummy; DTR 8 dummy. 4. 3DH: SPI 0dummy; QPI&DTR 8 dummy. 5. 4BH/5AH/B5H/85H: SPI&QPI&DTR 8 dummy. 23 GD25LT256E 6. 0BH/0CH/6BH/6CH/48H: SPI 8dummy; QPI&DTR dummy follow CONFIGURATION REGISTER (initiation = 16 dummy) 7. EBH/ECH/EDH/EEH: SPI&QPI&DTR dummy follow CONFIGURATION REGISTER (initiation = 16 dummy) 8. When WPS protection is enabled, the entire memory array is being protected after Power-up or Reset. 9. Only Quad I/O (EBH and ECH) and DTR Quad I/O fast read (EDH and EEH) support wrap read and XIP operation. DLP bit The DLP bit is Data Learning Pattern Enable bit, which is writable by B1/81H command. For Quad output, Quad I/O and Quad I/O DTR Fast Read commands, a pre-defined “Data Learning Pattern” can be used by the flash memory controller to determine the flash data output timing on 4 I/O pins. When DLP=1, from the third dummy clocks, the flash will output “00110100” Data Learning Pattern sequence on each of the I/O or 4 I/O pins until data output. During this period, controller can fine tune the data latching timing for each I/O pins to achieve optimum system performance. DLP=0 will disable the Data Learning Pattern output. Figure 4. Data Learning Pattern Sequence Diagram (STR, Dummy Clock ≥ 10) CS# SCLK Address Data Dummy Data Learning Pattern IO[3:0] Command Address 0 0 1 1 0 1 0 0 0 0 D D 7 6 5 4 3 2 1 0 7 6 Data Note: 12 dummy cycle example Figure 5. Data Learning Pattern Sequence Diagram (STR, Dummy Clock < 10) CS# SCLK Address Dummy Data Data Learning Pattern IO[3:0] Command Address 0 0 1 1 0 1 D D 7 6 5 4 3 2 Note: 8 dummy cycle example 24 Data D D D D GD25LT256E Figure 6. Data Learning Pattern Sequence Diagram (DTR, Dummy Clock ≥ 6) CS# SCLK Address Data Dummy Data Learning Pattern IO[3:0] Command Address 0 0 1 1 0 1 0 0 0 0 D 7 6 5 4 3 2 1 0 7 6 Data Note: 7 dummy cycle example Figure 7. Data Learning Pattern Sequence Diagram (DTR, Dummy Clock < 6) CS# SCLK Address Data Dummy Data Learning Pattern IO[3:0] Command Address 0 0 1 1 0 1 D D 7 6 5 4 3 2 Note: 5 dummy cycle example 25 Data D D D GD25LT256E 8.3. Supported Clock Frequencies Table 8 Clock Frequencies of TFBGA-24 (5x5 Ball Array) Quad I/O FAST READ Number of Dummy Clock QPI DTR Cycle STR DTR 3 20 20 20 4 40 40 40 5 60 60 60 6 84 84 84 7 84 84 84 8 104 104 104 9 104 104 104 10 133 133 133 11 133 133 133 12 152 152 152 13 152 152 152 14 166 166 166 15 166 166 166 16 and above 166 200 200 Note: 1. Values are guaranteed by characterization and not 100% tested in production Table 9 Clock Frequencies of SOP16 (300mil) Quad I/O FAST READ Number of Dummy Clock QPI DTR Cycle STR DTR 3 20 20 20 4 40 40 40 5 60 60 60 6 84 84 84 7 84 84 84 8 104 104 104 9 104 104 104 10 133 133 133 11 133 133 133 12 152 152 152 13 152 152 152 14 and above 166 166 166 Note: 1. Values are guaranteed by characterization and not 100% tested in production 26 GD25LT256E 8.4. Data Sequence Wraps by Density Table 10 Sequence of Bytes during Wrap Starting Address 16-Byte Wrap 32-Byte Wrap 64-Byte Wrap 0 0-1-2- . . . -15-0-1- . . 0-1-2- . . . -31-0-1- . . 0-1-2- . . . -63-0-1- . . 1 1-2- . . . -15-0-1-2- . . 1-2- . . . -31-0-1-2- . . 1-2- . . . -63-0-1-2- . . …. …. 15-16-17- . . . -63-0-1- . . …. …. 15 15-0-1-2-3- . . . -15-0-1- . . 15-16-17- . . . -31-0-1- . . …. …. …. 31 - 31-0-1-2-3- . . . -31-0-1- . . 31-32-33- . . . -63-0-1- . . … …. …. …. 63 - - 63-0-1- . . . -63-0-1- . . 27 GD25LT256E 9. COMMANDS DESCRIPTION All commands, addresses and data are shifted in and out of the device, beginning with the most significant bit on the first rising edge of SCLK after CS# is driven low. Then, the one-Byte command code must be shifted in to the device, with most significant bit first on SI, and each bit is latched on the rising edges of SCLK. Every command sequence starts with a one-Byte command code. Depending on the command, this might be followed by address Bytes, or by data Bytes, or by both or none. CS# must be driven high after the last bit of the command sequence has been completed. For the command of Read, Fast Read, Read Status Register or Release from Deep Power-Down, and Read Device ID, the shifted-in command sequence is followed by a data-out sequence. All read instruction can be completed after any bit of the data-out sequence is being shifted out, and then CS# must be driven high to return to deselected status. For the command of Page Program, Sector Erase, Block Erase, Chip Erase, Write Status Register, Write Enable, Write Disable or Deep Power-Down command, CS# must be driven high exactly at a Byte boundary, otherwise the command is rejected, and is not executed. That is CS# must be driven high when the number of clock pulses after CS# being driven low is an exact multiple of eight. For Page Program, if at any time the input Byte is not a full Byte, nothing will happen and WEL will not be reset. Table 11 Commands (Standard SPI & DTR Quad SPI) Quad SPI DTR Standard SPI Command name Code Command- Dummy Address- Clock Data Cycles CommandAddressData (s-d-d) Dummy Address Data Clock Bytes Bytes Cycles Software Reset Operations Reset Enable 66H 1-0-0 0 4-0-0 0 0 0 Reset Memory 99H 1-0-0 0 4-0-0 0 0 0 9E/9FH 1-0-(1) 0 4-0-(4) 8 0 1 to ∞ 5AH 1-1-(1) 8 4-4-(4) 8 4BH 1-1-(1) 8 4-4-(4) 8 3(4) 1 to ∞ Read 03H 1-1-(1) 0 - - 3(4) 1 to ∞ Fast Read 0BH 1-1-(1) 8 4-4-(4) 16 3(4) 1 to ∞ Quad Output Fast Read 6BH 1-1-(4) 8 4-4-(4) 16 3(4) 1 to ∞ Quad I/O Fast Read EBH 1-4-(4) 16 4-4-(4) 16 3(4) 1 to ∞ DTR Quad I/O Fast Read EDH 1-4d-(4d) 16 4-4-(4) 16 3(4) 1 to ∞ Read ID Operations Read ID Read Serial Flash Discovery Parameter Read Unique ID 3(STR) 4(DTR) 1 to ∞ Read Memory Operations Read Memory Operations with 4-Byte Address 4-Byte Read 13H 1-1-(1) 0 - - 4 1 to ∞ 4-Byte Fast Read 0CH 1-1-(1) 8 4-4-(4) 16 4 1 to ∞ 6CH 1-1-(4) 8 4-4-(4) 16 4 1 to ∞ ECH 1-4-(4) 16 4-4-(4) 16 4 1 to ∞ 4-Byte Quad Output Fast Read 4-Byte Quad I/O Fast Read 28 GD25LT256E 4-Byte DTR Quad I/O EEH 1-4d-(4d) 16 4-4-(4) 16 4 1 to ∞ Write Enable 06H 1-0-0 0 4-0-0 0 0 0 Write Disable 04H 1-0-0 0 4-0-0 0 0 0 Volatile SR Write Enable 50H 1-0-0 0 4-0-0 0 0 0 Read Status Register 05H 1-0-(1) 0 4-0-(4) 8 0 1 to ∞ Read Flag Status Register 70H 1-0-(1) 0 4-0-(4) 8 0 1 to ∞ B5H 1-1-(1) 8 4-4-(4) 8 3(4) 1 85H 1-1-(1) 8 4-4-(4) 8 3(4) 1 C8H 1-0-(1) 8 4-0-(4) 8 0 1 01H 1-0-1 0 4-0-4 0 0 1 B1H 1-1-1 0 4-4-4 0 3(4) 1 81H 1-1-1 0 4-4-4 0 3(4) 1 C5H 1-0-1 0 4-0-4 0 0 1 30H 1-0-0 0 4-0-0 0 0 0 Page Program 02H 1-1-1 0 4-4-4 0 3(4) Quad Input Fast Program 32H 1-1-4 0 4-4-4 0 3(4) C2H 1-4-4 0 4-4-4 0 3(4) 12H 1-1-1 0 4-4-4 0 4 34H 1-1-4 0 4-4-4 0 4 3EH 1-4-4 0 4-4-4 0 4 4KB Sector Erase 20H 1-1-0 0 4-4-0 0 3(4) 0 32KB Block Erase 52H 1-1-0 0 4-4-0 0 3(4) 0 64KB Block Erase D8H 1-1-0 0 4-4-0 0 3(4) 0 Fast Read Write Operations Read Register Operations Read Nonvolatile Configuration Register Read Volatile Configuration Register Read Extended Address Register Write Register Operations Write Status Register Write Nonvolatile Configuration Register Write Volatile Configuration Register Write Extended Address Register Clear Flag Status Register Operation Clear Flag Status Register Program Operations Extended Quad Input Fast Program 1 to 256 1 to 256 1 to 256 Program Operations with 4-Byte Address 4-Byte Page Program 4-Byte Quad Input Fast Program 4-Byte Quad Input Extended Fast Program 1 to 256 1 to 256 1 to 256 Erase Operations 29 GD25LT256E Chip Erase C7/60H 1-0-0 0 4-0-0 0 0 0 Erase Operations with 4-Byte Address 4-Byte 4KB Sector Erase 21H 1-1-0 0 4-4-0 0 4 0 4-Byte 32KB Block Erase 5CH 1-1-0 0 4-4-0 0 4 0 4-Byte 64KB Block Erase DCH 1-1-0 0 4-4-0 0 4 0 Program/Erase Suspend 75H 1-0-0 0 4-0-0 0 0 0 Program/Erase Resume 7AH 1-0-0 0 4-0-0 0 0 0 1 to ∞ Suspend/Resume Operations One-Time Programmable (OTP) Operations Read OTP Array 48H 1-1-(1) 8 4-4-(4) 16 3(4) Program OTP Array 42H 1-1-1 0 4-4-4 0 3(4) Erase OTP Array 44H 1-1-0 0 4-4-0 0 3(4) 38H 1-0-0 0 4-0-0 0 0 0 B7H 1-0-0 0 4-0-0 0 0 0 E9H 1-0-0 0 4-0-0 0 0 0 B9H 1-0-0 0 4-0-0 0 0 0 ABH 1-0-0 0 4-0-0 0 0 0 1 to 256 0 QPI Mode Operation Enable QPI 4-Byte Address Mode Operations Enter 4-Byte Address Mode Exit 4-Byte Address Mode Deep Power-Down Operations Enter Deep Power Down Release From Deep Power Down Advanced Sector Protection Operations Individual Sector Lock 36H 1-1-0 0 4-4-0 0 3(4) 0 Individual Sector Unlock 39H 1-1-0 0 4-4-0 0 3(4) 0 Read Sector Lock 3DH 1-1-(1) 0 4-4-(4) 8 3(4) 1 Global Sector Lock 7EH 1-0-0 0 4-0-0 0 0 0 Global Sector Unlock 98H 1-0-0 0 4-0-0 0 0 0 Table 12 Commands (QPI) Command name Code Command- Dummy Clock Address Data Address-Data Cycles Bytes Bytes Software Reset Operations Reset Enable 66H 4-0-0 0 0 0 Reset Memory 99H 4-0-0 0 0 0 9E/9FH 4-0-(4) 0 0 1 to ∞ 4BH 4-4-(4) 8 3(4) 1 to ∞ 5AH 4-4-(4) 8 3 1 to ∞ Read ID Operations Read ID Read Unique ID Read Serial Flash Discovery Parameter 30 GD25LT256E Read Memory Operations Fast Read 0BH 4-4-(4) 8 3(4) 1 to ∞ Quad Output Fast Read 6BH 4-4-(4) 8 3(4) 1 to ∞ Quad I/O Fast Read EBH 4-4-(4) 16 3(4) 1 to ∞ DTR Quad I/O Fast Read EDH 4-4d-(4d) 16 3(4) 1 to ∞ Read Memory Operations with 4-Byte Address 4-Byte Fast Read 0CH 4-4-(4) 8 4 1 to ∞ 4-Byte Quad Output Fast Read 6CH 4-4-(4) 8 4 1 to ∞ 4-Byte Quad I/O Fast Read ECH 4-4-(4) 16 4 1 to ∞ 4-Byte DTR Quad I/O Fast Read EEH 4-4d-(4d) 16 4 1 to ∞ Write Enable 06H 4-0-0 0 0 0 Write Disable 04H 4-0-0 0 0 0 Volatile SR Write Enable 50H Write Operations Read Register Operations Read Status Register 05H 4-0-(4) 0 0 1 to ∞ Read Flag Status Register 70H 4-0-(4) 0 0 1 to ∞ B5H 4-4-(4) 8 3(4) 1 85H 4-4-(4) 8 3(4) 1 C8H 4-0-(4) 0 0 1 FFH 4-0-0 0 0 0 01H 4-0-4 0 0 1 B1H 4-4-4 0 3(4) 1 81H 4-4-4 0 3(4) 1 C5H 4-0-4 0 0 1 30H 4-0-0 0 0 0 Page Program 02H 4-4-4 0 3(4) 1 to 256 Quad Input Fast Program 32H 4-4-4 0 3(4) 1 to 256 Extended Quad Input Fast Program C2H 4-4-4 0 3(4) 1 to 256 Read Nonvolatile Configuration Register Read Volatile Configuration Register Read Extended Address Register QPI Mode Operation Disable QPI Write Register Operations Write Status Register Write Nonvolatile Configuration Register Write Volatile Configuration Register Write Extended Address Register Clear Flag Status Register Operation Clear Flag Status Register Program Operations Program Operations with 4-Byte Address 4-Byte Page Program 12H 4-4-4 0 4 1 to 256 4-Byte Quad Input Fast Program 34H 4-4-4 0 4 1 to 256 3EH 4-4-4 0 4 1 to 256 4-Byte Quad Input Extended Fast Program 31 GD25LT256E Erase Operations 4KB Sector Erase 20H 4-4-0 0 3(4) 0 32KB Block Erase 52H 4-4-0 0 3(4) 0 64KB Block Erase D8H 4-4-0 0 3(4) 0 C7/60H 4-0-0 0 0 0 Chip Erase Erase Operations with 4-Byte Address 4-Byte 4KB Sector Erase 21H 4-4-0 0 4 0 4-Byte 32KB Block Erase 5CH 4-4-0 0 4 0 4-Byte 64KB Block Erase DCH 4-4-0 0 4 0 Program/Erase Suspend 75H 4-0-0 0 0 0 Program/Erase Resume 7AH 4-0-0 0 0 0 Suspend/Resume Operations One-Time Programmable (OTP) Operations Read OTP Array 48H 4-4-(4) 8 3(4) 1 to ∞ Program OTP Array 42H 4-4-(4) 0 3(4) 1 to 256 Erase OTP Array 44H 4-4-0 0 3(4) Enter 4-Byte Address Mode B7H 4-0-0 0 0 0 Exit 4-Byte Address Mode E9H 4-0-0 0 0 0 Enter Deep Power Down B9H 4-0-0 0 0 0 Release From Deep Power Down ABH 4-0-0 0 0 0 0 4-ByteAddress Mode Operations Deep Power-Down Operations Advanced Sector Protection Operations Individual Sector Lock 36H 4-4-0 0 3(4) 0 Individual Sector Unlock 39H 4-4-0 0 3(4) 0 Read Sector Lock 3DH 4-4-(4) 8 3(4) 1 Global Sector Lock 7EH 4-0-0 0 0 0 Global Sector Unlock 98H 4-0-0 0 0 0 Table of ID Definitions GD25LT256E Operation Code M7-M0 ID23-ID16 ID15-ID8 ID7-ID0 9E/9FH C8 66 19 FF 32 GD25LT256E 9.1. Enable 4-Byte Mode (B7H) The Enable 4-Byte Mode command enables accessing the address length of 32-bit for the memory area of the higher density (larger than 128Mb). The GD25LT256E default is in 24-bit address mode. After sending the Enable 4-Byte Mode command, the ADS bit (FS0) will be set to 1 to indicate the 4-Byte address mode has been enabled. Once the 4-Byte address mode is enabled, the address length becomes 32-bit instead of the default 24 bit. The Disable 4-Byte Mode or Reset or Power-off will disable 4-Byte mode. Figure 8 Enable 4-Byte Mode Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 SCLK Command SI B7H Figure 9 Enable 4-Byte Mode Sequence Diagram (QPI & Quad DTR) CS# 0 1 SCLK Command B7H IO[3:0] 9.2. Disable 4-Byte Mode (E9H) The Disable 4-Byte Mode command is executed to exit the 4-Byte address mode and return to the default 3-Byte address mode. After sending the Disable 4-Byte Mode command, the ADS bit (FS0) will be clear to be 0 to indicate the 4-Byte address mode has been disabled, and then the address length will return to 24-bit. Figure 10 Disable 4-Byte Mode Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 SCLK Command SI E9H Figure 11 Disable 4-Byte Mode Sequence Diagram (QPI and Quad DTR) CS# 0 1 SCLK Command E9H IO[3:0] 33 GD25LT256E 9.3. Write Enable (WREN) (06H) The Write Enable (WREN) command is for setting the Write Enable Latch (WEL) bit. The Write Enable Latch (WEL) bit must be set prior to every Page Program (PP), Sector Erase (SE), Block Erase (BE), Chip Erase (CE), Write Status Register (WRSR), Write Extended Address Register (WEAR), Write Nonvolatile/Volatile configure register and Erase/Program Security Registers command. The Write Enable (WREN) command sequence: CS# goes low  sending the Write Enable command  CS# goes high. Figure 12 Write Enable Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 SCLK Command SI 06H Figure 13 Write Enable Sequence Diagram (QPI and Quad DTR) CS# 0 1 SCLK Command 06H IO[3:0] 9.4. Write Disable (WRDI) (04H) The Write Disable command is for resetting the Write Enable Latch (WEL) bit. The Write Disable command sequence: CS# goes low Sending the Write Disable command CS# goes high. The WEL bit is reset by following condition: Power-up and upon completion of the Write Status Register, Write Extended Address Register (WEAR), Write Nonvolatile/Volatile configure register, Page Program, Sector Erase, Block Erase, Chip Erase, Erase/Program Security Registers and Reset commands. Figure 14 Write Disable Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 SCLK Command SI 04H Figure 15 Write Disable Sequence Diagram (QPI and Quad DTR) CS# 0 1 SCLK Command 04H IO[3:0] 34 GD25LT256E 9.5. Write Enable for Volatile Status Register (50H) The non-volatile Status Register bits can also be written to as volatile bits. This gives more flexibility to change the system configuration and memory protection schemes quickly without waiting for the typical non-volatile bit write cycles or affecting the endurance of the Status Register non-volatile bits. The Write Enable for Volatile Status Register command must be issued prior to a Write Status Register command, and any other commands cannot be inserted between them. Otherwise, Write Enable for Volatile Status Register will be cleared. The Write Enable for Volatile Status Register command will not set the Write Enable Latch bit, it is only valid for the Write Status Register command to change the volatile Status Register bit values. Figure 16 Write Enable for Volatile Status Register Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 SCLK Command 50H SI High-Z SO Figure 17 Write Enable for Volatile Status Register Sequence Diagram (QPI & Quad DTR) CS# 0 1 SCLK Command 50H IO[3:0] 9.6. Write Status Register (WRSR) (01H) The Write Status Register (WRSR) command allows new values to be written to the Status Register. Before it can be accepted, a Write Enable (WREN) command must previously have been executed. After the Write Enable (WREN) command has been decoded and executed, the device sets the Write Enable Latch (WEL). The Write Status Register (WRSR) command has no effect on Byte 2 of the Status Register. CS# must be driven high after the eighth of the data Byte has been latched in. Otherwise, the Write Status Register (WRSR) command is not executed. As soon as CS# is driven high, the self-timed Write Status Register cycle (whose duration is tW) is initiated. While the Write Status Register cycle is in progress, the Status Register may still be read to check the value of the Write In Progress (WIP) bit. The Write In Progress (WIP) bit is 1 during the self-timed Write Status Register cycle, and is 0 when it is completed. When the cycle is completed, the Write Enable Latch (WEL) is reset. The Write Status Register (WRSR) command allows the user to change the values of the Block Protect (TB, BP3, BP2, BP1, and BP0) bits, to define the size of the area that is to be treated as read-only, as defined in Table1. The Write Status Register (WRSR) command also allows the user to set or reset the Status Register Protect (SRP0) bit in accordance with the Write Protect (WP#) signal. The Status Register Protect (SRP1 and SRP0) bits and Write Protect (WP#) signal allow the device to be put in the Hardware Protected Mode. The Write Status Register (WRSR) command is not executed once the Hardware Protected Mode is entered. 35 GD25LT256E Figure 18 Write Status Register Sequence Diagram (SPI) CS# SCLK 0 1 2 3 4 5 6 7 8 Command SI 01H 9 10 11 12 13 14 15 Status Register in 7 6 5 MSB SO 4 3 2 1 0 High-Z Figure 19 Write Status Register Sequence Diagram (QPI) CS# 0 1 2 3 SCLK IO[3:0] Command SR in 01H SR7-4 SR3-0 Figure 20 Write Status Register Sequence Diagram (Quad DTR) CS# 0 1 2 SCLK SR in IO[3:0] 01H SR7-4 SR3-0 9.7. Write Extended Address Register (C5H) The Extended Address Register is a volatile register that stores the 4th Byte address (A31-A24) when the device is operating in the 3-Byte Address Mode (ADS=0). To write the Extended Address Register bits, a Write Enable (06H) instruction must previously have been executed for the device to accept the Write Extended Address Register instruction (Status Register bit WEL must equal 1). Once write enabled, the instruction is entered by driving /CS low, sending the instruction code “C5H”, and then writing the Extended Address Register data Byte. Upon power up or the execution of a Software/Hardware Reset, the Extended Address Register bit values will be cleared to 0. The Extended Address Register is only effective when the device is in the 3-Byte Address Mode. When the device operates in the 4-Byte Address Mode (ADS=1), any command with address input of A31-A24 will replace the Extended Address Register values. It is recommended to check and update the Extended Address Register if necessary when the device is switched from 4-Byte to 3-Byte Address Mode. 36 GD25LT256E Figure 21 Write Extended Address Register Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 C5H 7 Extended Addr. Register In 6 5 4 3 2 1 High-Z MSB SCLK Command SI SO 0 Figure 22 Write Extended Address Register Sequence Diagram (QPI) CS# 0 1 2 3 SCLK Command EAR in EAR 7-4 C5H IO[3:0] EAR 3-0 Figure 23 Write Extended Register Sequence Diagram (DTR, QPI) CS# 0 1 2 SCLK IO[3:0] EAR in EAR EAR 7-4 3-0 C5H 9.8. Write Nonvolatile/Volatile Configuration Register (B1H/81H) The Write Nonvolatile/Volatile Configuration Register (WRCR) command allows new values to be written to the Nonvolatile/Volatile Configuration Register. Before it can be accepted, a Write Enable (WREN) command must previously have been executed. After the Write Enable (WREN) command has been decoded and executed, the device sets the Write Enable Latch (WEL). CS# must be driven high after the data Byte has been latched in. If not, the Write Configuration Register (WRCR) command is not executed. As soon as CS# is driven high, the self-timed Write Configuration Register cycle (whose duration is tW for B1H) is initiated. The Write In Progress (WIP) bit is 1 during the self-timed Write Configuration Register cycle, and is 0 when it is completed. When the cycle is completed, the Write Enable Latch (WEL) is reset. Figure 24 Write Nonvolatile/Volatile Configuration Register Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 28 29 30 31 32 33 34 35 36 37 38 39 SCLK Command SI B1H/81H 24-bit address 23 22 21 3 2 1 MSB 0 7 Configuration register in 6 5 4 3 2 1 0 MSB Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 37 GD25LT256E Figure 25 Write Nonvolatile/Volatile Configuration Register Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 9 8 SCLK Command B1H/81H IO[3:0] Address CR in Addr. Addr. Addr. Addr. Addr. Addr. CR7-4 CR3-0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 26 Write Nonvolatile/Volatile Configuration Register Sequence Diagram (Quad DTR) CS# 0 1 2 3 4 5 SCLK CR in IO[3:0] B1H or 81H Addr. Addr. Addr. Addr. Addr. Addr. CR7-4 CR3-0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.9. Read Status Register or Flag Register (05H) The Read Status Register (RDSR) command is for reading the Status Register. The Status Register may be read at any time, even while a Program, Erase or Write Status Register cycle is in progress. When one of these cycles is in progress, it is recommended to check the Write in Progress (WIP) bit before sending a new command to the device. It is also possible to read the Status Register continuously. For command code “05H”, the SO will output Status Register bits S7~S0. Figure 27 Read Status Register or flag register Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 7 6 SCLK Command SI SO 05H High-Z 5 SR out 4 3 2 1 MSB 0 7 6 5 SR out 4 3 2 MSB Figure 28 Read Status Register or flag register Sequence Diagram (QPI) CS# 0 1 2 3 4 5 SCLK SR out Command IO[3:0] 05H SR out SR7-4 SR3-0 SR7-4 SR3-0 38 SR out 1 0 7 GD25LT256E Figure 29 Read Status Register or flag register Sequence Diagram (Quad DTR) CS# 0 1 9 10 11 SCLK Dummy IO[3:0] 9.10. SR out 05H SR out SR out SR 7-4SR 3-0SR 7-4SR 3-0 Read Flag Status Register or Flag Register (70H) The Read Flag Status Register command is for reading the Flag Status Register. The Flag Status Register may be read at any time, even while a Program, Erase or Write Status Register cycle is in progress. When one of these cycles is in progress, It is also possible to read the Flag Status Register continuously. Figure 30 Read Status Register or flag register Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 7 6 SCLK Command SI 70H High-Z SO 5 FSR out 4 3 2 1 MSB 0 7 6 5 FSR out 4 3 2 1 0 7 MSB Figure 31 Read Status Register or flag register Sequence Diagram (QPI) CS# 0 1 2 3 4 5 SCLK Command 70H IO[3:0] FSR out FSR 7-4 FSR 3-0 FSR out FSR 7-4 FSR out FSR 3-0 Figure 32 Read Status Register or flag register Sequence Diagram (Quad DTR) CS# 0 1 9 10 11 SCLK Dummy IO[3:0] 9.11. 70H FSR out FSR FSR 7-4 3-0 FSR out FSR FSR 7-4 3-0 FSR out Read Nonvolatile/Volatile Configuration Register (B5H/85H) The Nonvolatile/Volatile Configuration Register command is for reading the Nonvolatile/Volatile Configuration Registers. It is followed by a 3-Byte address (A23-A0) or a 4-Byte address (A31-A0) and a dummy Byte, and each bit is latched-in on the rising edge of SCLK. Then the Configuration Register, at that address, is shifted out on SO, and each bit is shifted out, at a Max frequency fC, on the falling edge of SCLK. Read Nonvolatile/Volatile Configuration Register command, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. 39 GD25LT256E Figure 33 Read Configuration Registers Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 SCLK Command 24-bit address 23 22 21 B5H/85H SI 3 2 1 0 High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK Dummy Byte 7 SI 6 5 4 3 2 1 0 7 6 MSB SO 5 CR out 4 3 2 1 0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 34 Read Configuration Registers Sequence (QPI) CS# 0 1 2 3 4 5 6 7 15 8 16 17 SCLK IO[3:0] dummy Command Address B5H/85H Addr. Addr. Addr. Addr. Addr. Addr. CR out CR7-4 CR3-0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 35 Read Configuration Registers Sequence (Quad DTR) CS# 0 1 2 3 4 SCLK IO[3:0] B5H or 85H Addr. Addr. Addr. Addr. Addr. Addr. dummy CS# 12 13 SCLK CR out IO[3:0] CR7-4 CR3-0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.12. Read Extended Address Register (C8H) Extended Address Register contains Address Bit A24. The Read Extended Address Register instruction is entered by driving 40 GD25LT256E CS# low and shifting the instruction code “C8H” into the SI pin on the rising edge of SCLK. The Extended Address Register bits are then shifted out on the SO pin at the falling edge of SCLK with most significant bit (MSB) first. When the device is in the 4-Byte Address Mode, the value of A24 bit is ignored. Figure 36 Read Extended Address Register Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 7 6 SCLK Command SI C8H High-Z SO 5 EAR out 4 3 2 1 0 MSB Figure 37 Read Extended Address Register Sequence Diagram (QPI) CS# 0 1 2 3 SCLK Command C8H IO[3:0] EAR out EAR 7-4 EAR 3-0 Figure 38 Read Status Register or flag register Sequence Diagram (Quad DTR) CS# 0 1 9 10 SCLK Dummy IO[3:0] 9.13. C8H EAR out EAR EAR 7-4 3-0 Read Data Bytes (03H/13H) The Read Data Bytes (READ) command is followed by a 3-Byte address (A23-A0) or a 4-Byte address (A31-A0), and each bit is latched-in on the rising edge of SCLK. Then the memory content, at that address, is shifted out on SO, and each bit is shifted out, at a Max frequency fR, on the falling edge of SCLK. The first Byte addressed can be at any location. The address is automatically incremented to the next higher address after each Byte of data is shifted out. The whole memory can, therefore, be read with a single Read Data Bytes (READ) command. Any Read Data Bytes (READ) command, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. 41 GD25LT256E Figure 39 Read Data Bytes Sequence Diagram CS# 0 1 2 3 4 5 6 7 8 28 29 30 31 32 33 34 35 36 37 38 39 9 10 SCLK Command SI 24-bit address 23 22 21 03H 2 1 0 MSB High-Z SO 3 MSB 7 6 Data Out1 5 4 3 2 1 Data Out2 0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.14. Read Data Bytes at Higher Speed (0BH/0CH) The Read Data Bytes at Higher Speed (Fast Read) command is for quickly reading data out. It is followed by a 3-Byte address (A23-A0) or a 4-Byte address (A31-A0) and dummy clocks, and each bit is latched-in on the rising edge of SCLK. Then the memory content, at that address, is shifted out on SO, and each bit is shifted out, at a Max frequency fC, on the falling edge of SCLK. The first Byte addressed can be at any location. The address is automatically incremented to the next higher address after each Byte of data is shifted out. Figure 40 Read Data Bytes at Higher Speed Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 SCLK Command SI 24-bit address 23 22 21 0BH 3 2 1 0 High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK Dummy Byte SI 7 6 5 4 3 2 1 0 7 MSB SO Data Out1 6 5 4 3 2 1 Data Out2 0 7 6 5 MSB Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 41 Read Data Bytes at Higher Speed Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 8 15 16 17 SCLK IO[3:0] dummy Command Address 0BH Addr. Addr. Addr. Addr. Addr. Addr. Byte 1 Data out Data Data out out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 42 Byte 2 GD25LT256E Figure 42 Read Data Bytes at Higher Speed Sequence Diagram (Quad DTR) CS# 0 1 2 3 4 5 SCLK Dummy IO[3:0] 0BH Addr. Addr. Addr. Addr. Addr. Addr. DQS CS# 20 21 SCLK Byte 1 Data Data out out IO[3:0] Byte 2 Data out DQS Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.15. Quad Output Fast Read (6BH/6CH) The Quad Output Fast Read command is followed by 3-Byte address (A23-A0) or a 4-Byte address (A31-A0) and dummy clocks, and each bit is latched in on the rising edge of SCLK, then the memory contents are shifted out 4-bit per clock cycle from IO3, IO2, IO1 and IO0. The first Byte addressed can be at any location. The address is automatically incremented to the next higher address after each Byte of data is shifted out. Figure 43 Quad Output Fast Read Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 SCLK Command IO0 24-bit address 23 22 21 6BH IO1 High-Z IO2 High-Z IO3 High-Z CS# 3 2 1 0 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK Dummy Clocks IO0 4 0 4 0 4 0 4 0 4 IO1 5 1 5 1 5 1 5 1 5 IO2 6 2 6 2 6 2 6 2 6 IO3 7 3 7 3 7 3 7 3 7 Byte1 Byte2 Byte3 Byte4 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 43 GD25LT256E Figure 44 Quad Output Fast Read Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 15 8 16 17 SCLK Command 6BH IO[3:0] Dummy Address Byte 1 Data out Addr. Addr. Addr. Addr. Addr. Addr. Byte 2 Data Data out out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 45 Quad Output Fast Read Sequence Diagram (Quad DTR) CS# 0 1 2 3 4 5 SCLK Dummy IO[3:0] 6BH Addr. Addr. Addr. Addr. Addr. Addr. DQS CS# 20 21 SCLK Byte 1 Data Data out out IO[3:0] Byte 2 Data out DQS Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.16. Quad I/O Fast Read (EBH/ECH) The Quad I/O Fast Read command is similar to the Quad Output Fast Read command but with the capability to input the 3Byte address (A23-0) or a 4-Byte address (A31-A0) and a “Continuous Read Mode” Byte and dummy clocks. 4-bit is transferred per clock by IO0, IO1, IO2, IO3, and each bit is latched in on the rising edge of SCLK, then the memory contents are shifted out 4-bit per clock cycle from IO0, IO1, IO2, IO3. The first Byte addressed can be at any location. The address is automatically incremented to the next higher address after each Byte of data is shifted out. Figure 46 Quad I/O Fast Read Sequence Diagram (SPI, M5-4≠ (1, 0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 29 30 31 32 33 SCLK Dummy Command 4 0 4 0 4 0 4 0 4 0 4 0 4 IO1 5 1 5 1 5 1 5 1 5 1 5 1 5 IO2 6 2 6 2 6 2 6 2 6 2 6 2 6 IO3 7 3 7 3 7 3 7 3 7 3 7 3 7 IO0 EBH A23-16 A15-8 A7-0 M7-0 Byte1 Byte2 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 44 GD25LT256E Figure 47 Quad I/O Fast Read Sequence Diagram (QPI, M5-4≠ (1, 0)) CS# 0 1 2 7 8 9 10 24 23 25 SCLK Command EBH IO[3:0] Dummy Address Addr. Byte 1 Data out M7-4 M3-0 Byte 2 Data Data out out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 48 Quad I/O Fast Read Sequence Diagram (Quad DTR, M5-4≠ (1, 0)) CS# 0 2 1 3 4 5 6 SCLK Dummy IO[3:0] EBH Addr. Addr. Addr. Addr. Addr. Addr. M7-4 M3-0 DQS CS# 20 21 SCLK Byte 1 Data Data out out IO[3:0] Byte 2 Data out DQS Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Quad I/O Fast Read with “Continuous Read Mode” The Quad I/O Fast Read command can further reduce command overhead through setting the “Continuous Read Mode” bits (M7-0) after the input 3-Byte address (A23-A0) or 4-Byte address (A31-A0). If the “Continuous Read Mode” bits (M5-4) = (1, 0), then the next Quad I/O Fast Read command (after CS# is raised and then lowered) does not require the EBH/ECH command code. If the “Continuous Read Mode” bits (M5-4) do not equal to (1, 0), the next command requires the command code, thus returning to normal operation. A Reset command can be used to reset (M5-4) before issuing normal command. The only way to quit the Quad I/O Continuous Read Mode” is to set the “Continuous Read Mode” bits (M5-4) not equal to (1, 0). Figure 49 Quad I/O Fast Read Sequence Diagram (STR, M5-4= (1, 0)) CS# 0 5 6 7 8 21 23 22 SCLK Dummy Address IO[3:0] Addr. M7-4 M3-0 Byte 1 Data out Byte 2 Data Data out out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 45 GD25LT256E Figure 50 Quad I/O Fast Read Sequence Diagram (DTR, M5-4= (1, 0)) CS# 0 1 2 3 18 19 SCLK Dummy IO[3:0] Byte 1 Byte 2 Data Data Data out out out Addr. Addr. Addr. Addr. Addr. Addr. M7-4 M3-0 DQS Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Quad I/O Fast Read with “16/32/64-Byte Wrap Around” The Quad I/O Fast Read command can be used to access a specific portion within a page by issuing Wrap configuration register Byte prior to EBH/ECH. The data being accessed can be limited to either a 16/32/64-Byte section of a 256-Byte page. The output data starts at the initial address specified in the command, once it reaches the ending boundary of the 16/32/64-Byte section, the output will wrap around the beginning boundary automatically until CS# is pulled high to terminate the command. The Burst with Wrap feature allows applications that use cache to quickly fetch a critical address and then fill the cache afterwards within a fixed length (16/32/64-Byte) of data without issuing multiple read commands. 9.17. Quad I/O DTR Read (EDH/EEH) The Quad I/O DTR Read instruction enables Double Transfer Rate throughput on quad I/O of Serial Flash in read mode. The address (interleave on 4 I/O pins) is latched on both rising and falling edge of SCLK, and data (interleave on 4 I/O pins) shift out on both rising and falling edge of SCLK. The 8-bit address can be latched-in at one clock, and 8-bit data can be read out at one clock, which means four bits at rising edge of clock, the other four bits at falling edge of clock. The first address Byte can be at any location. The address is automatically increased to the next higher address after each Byte data is shifted out, so the whole memory can be read out at a single Quad I/O DTR Read command. The address counter rolls over to 0 when the highest address has been reached. Once writing Quad I/O DTR Read command, the following address/dummy/data out will perform as 8-bit instead of previous 1-bit. While Program/Erase/Write Status Register cycle is in progress, Quad I/O DTR Read command is rejected without any impact on the Program/Erase/Write Status Register current cycle. Figure 51. DTR Quad I/O Fast Read Sequence Diagram (SPI, M5-4 ≠ (1, 0)) CS# 0 1 2 3 4 5 6 7 8 9 10 11 26 27 SCLK Command EDH IO0 Dummy 4 0 4 0 4 0 4 0 4 0 4 0 IO1 5 1 5 1 5 1 5 1 5 1 5 1 IO2 6 2 6 2 6 2 6 2 6 2 6 2 IO3 7 3 7 3 7 3 7 3 A23-0 DQS M7-0 7 3 7 3 Byt e1 Byt e2 High-Z Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 46 GD25LT256E Figure 52. DTR Quad I/O Fast Read Sequence Diagram (QPI, M5-4 ≠ (1, 0)) CS# 0 1 2 3 4 5 6 7 20 21 22 SCLK Command EDH IO[3:0] Dummy Address Byte 1 Byte 2 A23- A19- A15- A11- A7- A3- M7- M3A20 A16 A12 A8 A4 A0 M4 M0 Data out Data out Byte n Data out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 53. DTR Quad I/O Fast Read Sequence Diagram (Quad DTR, M5-4 ≠ (1, 0)) CS# 0 2 1 3 4 6 5 SCLK Dummy IO[3:0] EDH Addr. Addr. Addr. Addr. Addr. Addr. M7-4 M3-0 DQS CS# 20 21 SCLK Byte 1 Data Data out out IO[3:0] Byte 2 Data out DQS Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Quad I/O DTR Read with “Continuous Read Mode” The Quad I/O DTR Read command can further reduce command overhead through setting the “Continuous Read Mode” bits (M7-0) after the input address. If the “Continuous Read Mode” bits (M5-4) = (1, 0), then the next Quad I/O DTR Read command (after CS# is raised and then lowered) does not require the EDH/EEH command code. If the “Continuous Read Mode” bits (M5-4) do not equal to (1, 0), the next command requires the first EDH/EEH command code, thus returning to normal operation. The only way to quit the Quad I/O DTR Continuous Read Mode” is to set the “Continuous Read Mode” bits (M5-4) not equal to (1, 0). Figure 54. DTR Quad I/O Fast Read Sequence Diagram (M5-4 = (1, 0)) CS# 0 1 2 3 4 5 18 19 20 SCLK Dummy Address IO[3:0] A23- A19- A15- A11- A7- A3- M7- M3A20 A16 A12 A8 A4 A0 M4 M0 Byte 1 Byte 2 Data out Data out Byte n Data out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Quad I/O DTR Fast Read with “16/32/64-Byte Wrap Around” The Quad I/O DTR Fast Read command can be used to access a specific portion within a page by issuing Wrap configuration register Byte prior to EDH/EEH. The data being accessed can be limited to either a 16/32/64-Byte section of 47 GD25LT256E a 256-Byte page. The output data starts at the initial address specified in the command, once it reaches the ending boundary of the 16/32/64-Byte section, the output will wrap around the beginning boundary automatically until CS# is pulled high to terminate the command. The Burst with Wrap feature allows applications that use cache to quickly fetch a critical address and then fill the cache afterwards within a fixed length (16/32/64-Byte) of data without issuing multiple read commands. 9.18. Page Program (PP) (02H/12H) The Page Program (PP) command is for programming the memory. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit before sending the Page Program command. The Page Program (PP) command is entered by driving CS# Low, followed by the command code, three or four address Bytes and at least one data Byte on SI. If the 8 least significant address bits (A7-A0) are not all zero, all transmitted data that goes beyond the end of the current page are programmed from the start address of the same page (from the address whose 8 least significant bits (A7-A0) are all zero). CS# must be driven low for the entire duration of the sequence. The Page Program command sequence: CS# goes low  sending Page Program command  3-Byte address or 4-Byte address on SI  at least 1 Byte data on SI  CS# goes high. If more than 256 Bytes are sent to the device, previously latched data are discarded and the last 256 data Bytes are guaranteed to be programmed correctly within the same page. If less than 256 data Bytes are sent to device, they are correctly programmed at the requested addresses without having any effects on the other Bytes of the same page. CS# must be driven high after the eighth bit of the last data Byte has been latched in; otherwise the Page Program (PP) command is not executed. As soon as CS# is driven high, the self-timed Page Program cycle (whose duration is tPP) is initiated. While the Page Program cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Page Program cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A Page Program (PP) command applied to a page which is protected by the Block Protect (TB, BP3, BP2, BP1, and BP0) is not executed. Figure 55 Page Program Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 32 33 34 35 36 37 38 39 SCLK Command 24-bit address 23 22 21 2 Data Byte 1 1 0 7 MSB 6 5 4 3 2 1 2078 2079 6 2077 7 2076 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 2073 CS# 2072 MSB 2075 SI 3 2074 02H 1 0 SCLK Data Byte 3 Data Byte 2 SI 7 MSB 6 5 4 3 2 1 0 7 6 5 4 3 MSB 2 Data Byte 256 1 0 5 4 3 2 MSB Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 48 0 GD25LT256E Figure 56 Page Program Sequence Diagram (QPI) CS# 0 1 2 7 8 9 10 11 517 518 519 SCLK IO[3:0] Command Address 02H Addr. Byte 1 Data in Data in Byte 2 Data in Data in Data in Byte 256 Data Data in in Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 57 Page Program Sequence Diagram (Quad DTR) CS# 0 1 2 3 5 6 SCLK IO[3:0] Byte 1 Data Data Addr. Addr. Addr. Addr. Addr. Addr. in in 02H CS# 7 8 Byte 2 Data Data in in Byte 3 Data Data in in 260 261 Byte 255 Data Data in in Byte 256 Data Data in in SCLK IO[3:0] Byte 4~254 Data in Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.19. Quad Page Program (32H/34H) The Quad Page Program command is for programming the memory using four pins: IO0, IO1, IO2, and IO3. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit before sending the Page Program command. The quad Page Program command is entered by driving CS# Low, followed by the command code (32H/34H), three or four address Bytes and at least one data Byte on IO pins. If more than 256 Bytes are sent to the device, previously latched data are discarded and the last 256 data Bytes are guaranteed to be programmed correctly within the same page. If less than 256 data Bytes are sent to device, they are correctly programmed at the requested addresses without having any effects on the other Bytes of the same page. CS# must be driven high after the eighth bit of the last data Byte has been latched in; otherwise the Quad Page Program (PP) command is not executed. As soon as CS# is driven high, the self-timed Quad Page Program cycle (whose duration is tPP) is initiated. While the Quad Page Program cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Quad Page Program cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A Quad Page Program command applied to a page which is protected by the Block Protect (TB, BP3, BP2, BP1, and BP0) is not executed. 49 GD25LT256E Figure 58 Quad Page Program Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 28 29 30 31 32 33 34 35 36 37 38 39 9 10 SCLK 24-bit address 0 4 0 4 0 4 0 4 0 IO1 5 1 5 1 5 1 5 1 IO2 6 2 6 2 6 2 6 2 IO3 7 3 7 3 7 3 7 3 537 539 540 541 542 543 23 22 21 0 4 0 32H IO0 3 2 Byte1 Byte2 538 Command 1 MSB 536 CS# 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 SCLK Byte11Byte12 0 4 0 4 0 4 0 4 0 4 0 4 0 4 Byte253 0 4 0 Byte256 4 IO0 4 4 0 IO1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 IO2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 IO3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 59 Quad Page Program Sequence Diagram (QPI) CS# 0 1 2 7 8 9 10 11 517 518 519 SCLK IO[3:0] Command Address 32H Addr. Byte 1 Data in Data in Byte 2 Data in Data in Data in Byte 256 Data Data in in Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 50 GD25LT256E Figure 60 Quad Page Program Sequence Diagram (Quad DTR) CS# 0 1 2 3 5 6 SCLK IO[3:0] Byte 1 Data Data Addr. Addr. Addr. Addr. Addr. Addr. in in 32H CS# 7 8 Byte 2 Data Data in in Byte 3 Data Data in in 260 261 Byte 255 Data Data in in Byte 256 Data Data in in SCLK IO[3:0] Byte 4~254 Data in Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.20. Extend Quad Page Program (C2H/3EH) The Extend Quad Page Program command is for programming the memory using four pins: IO0, IO1, IO2, and IO3. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit before sending the Page Program command. The extend quad Page Program command is entered by driving CS# Low, followed by the command code (C2H/3EH), three or four address Bytes and at least one data Byte on IO pins. If more than 256 Bytes are sent to the device, previously latched data are discarded and the last 256 data Bytes are guaranteed to be programmed correctly within the same page. If less than 256 data Bytes are sent to device, they are correctly programmed at the requested addresses without having any effects on the other Bytes of the same page. CS# must be driven high after the eighth bit of the last data Byte has been latched in; otherwise the Extend Quad Page Program (EPP) command is not executed. As soon as CS# is driven high, the self-timed Extend Quad Page Program cycle (whose duration is tPP) is initiated. While the Extend Quad Page Program cycle is in progress, the Status Register may be read to check the value of the Write In Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Extend Quad Page Program cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. An Extend Quad Page Program command applied to a page which is protected by the Block Protect (TB, BP3, BP2, BP1, and BP0) is not executed. Figure 61 Extend Quad Page Program Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK Command Address 20 16 12 8 4 0 4 0 4 0 4 0 4 0 4 0 4 IO1 21 17 13 9 5 1 5 1 5 1 5 1 5 1 5 1 5 IO2 22 18 14 10 6 2 6 2 6 2 6 2 6 2 6 2 6 IO3 23 19 15 11 7 3 7 3 7 3 7 3 7 3 7 3 7 IO0 C2H A23-16 A15-8 A7-0 Byte1 Byte2 Byte3 Byte4 Byte5 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 51 GD25LT256E Figure 62 Extend Quad Page Program Sequence Diagram (QPI) CS# 0 1 2 7 8 9 10 11 517 518 519 SCLK Command Address C2H Addr. IO[3:0] Byte 1 Data in Byte 2 Data in Data in Data in Data in Byte 256 Data Data in in Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 63 Extend Quad Page Program Sequence Diagram (Quad DTR) CS# 0 1 2 3 5 6 SCLK IO[3:0] Byte 1 Data Data Addr. Addr. Addr. Addr. Addr. Addr. in in C2H CS# 7 8 Byte 2 Data Data in in Byte 3 Data Data in in 260 261 Byte 255 Data Data in in Byte 256 Data Data in in SCLK IO[3:0] Byte 4~254 Data in Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.21. Sector Erase (SE) (20H/21H) The Sector Erase (SE) command is erased the all data of the chosen sector. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit. The Sector Erase (SE) command is entered by driving CS# low, followed by the command code, and 3- Byte address or 4-Byte address on SI. Any address inside the sector is a valid address for the Sector Erase (SE) command. CS# must be driven low for the entire duration of the sequence. The Sector Erase command sequence: CS# goes low  sending Sector Erase command  3-Byte address or 4-Byte address on SI  CS# goes high. CS# must be driven high after the eighth bit of the last address Byte has been latched in; otherwise the Sector Erase (SE) command is not executed. As soon as CS# is driven high, the self-timed Sector Erase cycle (whose duration is tSE) is initiated. While the Sector Erase cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Sector Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A Sector Erase (SE) command applied to a sector which is protected by the Block Protect (TB, BP3, BP2, BP1, and BP0) bits is not executed. Figure 64 Sector Erase Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Command SI 20H 24 Bits Address 23 22 MSB 2 1 0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 52 GD25LT256E Figure 65 Sector Erase Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 SCLK Command Address 20H Addr. Addr. Addr. Addr. Addr. Addr. IO[3:0] Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 66 Sector Erase Sequence Diagram (Quad DTR) CS# 0 1 2 4 3 SCLK IO[3:0] Addr. Addr. Addr. Addr. Addr. Addr. 20H Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.22. 32KB Block Erase (BE) (52H/5CH) The 32KB Block Erase (BE) command is erased the all data of the chosen block. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit. The 32KB Block Erase (BE) command is entered by driving CS# low, followed by the command code, and 3-Byte address or 4-Byte address on SI. Any address inside the block is a valid address for the 32KB Block Erase (BE) command. CS# must be driven low for the entire duration of the sequence. The 32KB Block Erase command sequence: CS# goes low  sending 32KB Block Erase command  3-Byte address or 4-Byte address on SI  CS# goes high. CS# must be driven high after the eighth bit of the last address Byte has been latched in; otherwise the 32KB Block Erase (BE) command is not executed. As soon as CS# is driven high, the self-timed Block Erase cycle (whose duration is tSE) is initiated. While the Block Erase cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Block Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A 32KB Block Erase (BE) command applied to a block which is protected by the Block Protect (TB, BP3, BP2, BP1, and BP0) bits is not executed. Figure 67 32KB Block Erase Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Command SI 52H 24 Bits Address 23 22 MSB 2 1 0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 53 GD25LT256E Figure 68 32KB Block Erase Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 SCLK Command Address 52H Addr. Addr. Addr. Addr. Addr. Addr. IO[3:0] Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 69 32KB Block Erase Sequence Diagram (Quad DTR) CS# 0 1 2 4 3 SCLK IO[3:0] Addr. Addr. Addr. Addr. Addr. Addr. 52H Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.23. 64KB Block Erase (BE) (D8H/DCH) The 64KB Block Erase (BE) command is erased the all data of the chosen block. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit. The 64KB Block Erase (BE) command is entered by driving CS# low, followed by the command code, and 3-Byte address or 4-Byte address on SI. Any address inside the block is a valid address for the 64KB Block Erase (BE) command. CS# must be driven low for the entire duration of the sequence. The 64KB Block Erase command sequence: CS# goes low  sending 64KB Block Erase command  3-Byte address or 4-Byte address on SI  CS# goes high. CS# must be driven high after the eighth bit of the last address Byte has been latched in; otherwise the 64KB Block Erase (BE) command is not executed. As soon as CS# is driven high, the self-timed Block Erase cycle (whose duration is tSE) is initiated. While the Block Erase cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Block Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. A 64KB Block Erase (BE) command applied to a block which is protected by the Block Protect (TB, BP3, BP2, BP1, and BP0) bits is not executed. Figure 70 64KB Block Erase Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Command SI D8H 24 Bits Address 23 22 MSB 2 1 0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 54 GD25LT256E Figure 71 64KB Block Erase Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 SCLK Command Address D8H Addr. Addr. Addr. Addr. Addr. Addr. IO[3:0] Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 72 64KB Block Erase Sequence Diagram (Quad DTR) CS# 0 1 2 3 4 SCLK IO[3:0] D8H Addr. Addr. Addr. Addr. Addr. Addr. Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.24. Chip Erase (CE) (60/C7H) The Chip Erase (CE) command is erased the all data of the chip. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit .The Chip Erase (CE) command is entered by driving CS# Low, followed by the command code on Serial Data Input (SI). CS# must be driven Low for the entire duration of the sequence. The Chip Erase command sequence: CS# goes low  sending Chip Erase command  CS# goes high. CS# must be driven high after the eighth bit of the command code has been latched in; otherwise the Chip Erase command is not executed. As soon as CS# is driven high, the self-timed Chip Erase cycle (whose duration is tCE) is initiated. While the Chip Erase cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Chip Erase cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. The Chip Erase (CE) command is executed if the Block Protect (BP2, BP1, and BP0) bits are 0 The Chip Erase (CE) command is ignored if one or more sectors are protected. Figure 73 Chip Erase Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 SCLK Command 60H or C7H SI Figure 74 Chip Erase Sequence Diagram (QPI & Quad DTR) CS# 0 1 SCLK Command IO[3:0] 60H or C7H 55 GD25LT256E 9.25. Clear SR Flags (30H) The Clear Status Register Flags command resets bit FS1 (Protection), FS4 (Program Error bit) and FS5 (Erase Error bit) from status register. It is not necessary to set the WEL bit before the Clear Status Register command is executed. The Clear SR command will be not accepted even when the device remains busy with WIP set to 1, as the device does remain busy when either error bit is set. The WEL bit will be unchanged after this command is executed. Figure 75 Clear Status Register Flags Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 SCLK Command 30H SI Figure 76 Clear Status Register Flags Sequence Diagram (QPI & Quad DTR) CS# 0 1 SCLK Command 30H IO[3:0] 9.26. Enable QPI (38H) The device support both Standard/Quad SPI and QPI mode. The “Enable QPI (38H)” command can switch the device from SPI mode to QPI mode. In order to switch the device to QPI mode, “Enable QPI (38H)” command must be issued. When the device is switched from SPI mode to QPI mode, the existing Write Enable Latch and Program/Erase Suspend status, and the Wrap Length setting will remain unchanged. Figure 77 Enable QPI mode command Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 SCLK Command 38H SI Figure 78 Enable QPI mode command Sequence Diagram (Quad DTR) CS# 0 1 SCLK Command IO[3:0] 9.27. 38H Disable QPI (FFH) To exit the QPI mode and return to Standard/Quad SPI mode, the “Disable QPI (FFH)” command must be issued. When 56 GD25LT256E the device is switched from QPI mode to SPI mode, the existing Write Enable Latch and Program/Erase Suspend status, and the Wrap Length setting will remain unchanged. Figure 79 Disable QPI mode command Sequence Diagram (QPI & Quad DTR) CS# 0 1 SCLK Command FFH IO[3:0] 9.28. Deep Power-Down (DP) (B9H) Executing the Deep Power-Down (DP) command is the only way to put the device in the lowest consumption mode (the Deep Power-Down Mode). It can also be used as an extra software protection mechanism, while the device is not in active use, since in this mode, the device ignores all Write, Program and Erase commands. Driving CS# high deselects the device, and puts the device in the Standby Mode (if there is no internal cycle currently in progress). But this mode is not the Deep Power-Down Mode. The Deep Power-Down Mode can only be entered by executing the Deep Power-Down (DP) command. Once the device has entered the Deep Power-Down Mode, all commands are ignored except the Release from Deep Power-Down (ABH) or Enable Reset (66H) and Reset (99H) commands. These commands can release the device from this mode. The Release from Deep Power-Down command releases the device from deep power down mode. The Deep Power-Down Mode automatically stops at Power-Down, and the device is in the Standby Mode after Power-Up. The Deep Power-Down command sequence: CS# goes low  sending Deep Power-Down command  CS# goes high. CS# must be driven high after the eighth bit of the command code has been latched in; otherwise the Deep Power-Down (DP) command is not executed. As soon as CS# is driven high, it requires a delay of tDP before the supply current is reduced to ICC2 and the Deep Power-Down Mode is entered. Any Deep Power-Down (DP) command, while an Erase, Program or Write cycle is in progress, is rejected without having any effects on the cycle that is in progress. Figure 80 Deep Power-Down Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 tDP 7 SCLK Command Deep Power-down mode B9H SI Figure 81 Deep Power-Down Sequence Diagram (QPI & Quad DTR) CS# 0 1 tDP SCLK Deep Power-down mode Command IO[3:0] 9.29. B9H Release from Deep Power-Down (ABH) To release the device from the Power-Down state, the command is issued by driving the CS# pin low, shifting the 57 GD25LT256E instruction code “ABH” and driving CS# high. Release from Power-Down will take the time duration of tRES1 (See AC Characteristics) before the device will resume normal operation and other com mand are accepted. The CS# pin must remain high during the tRES1 time duration. When used to release the device from the Power-Down state, the command is the same as previously described, After this time duration the device will resume normal operation and other command will be accepted. If the Release from PowerDown command is issued while an Erase, Program or Write cycle is in process (when WIP equal 1) the command is ignored and will not have any effects on the current cycle. Figure 82 Release Power-Down Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 t RES1 7 SCLK Command ABH SI Deep Power-down mode Stand-by mode Figure 83 Release Power-Down Sequence Diagram (QPI & Quad DTR) CS# 0 1 tRES1 SCLK Deep Power-down mode Command ABH IO[3:0] 9.30. Stand-by mode Read Unique ID (4BH) The Read Unique ID command accesses a factory-set read-only 128bit number that is unique to each device. The Unique ID can be used in conjunction with user software methods to help prevent copying or cloning of a system. The Read Unique ID command sequence: CS# goes low  sending Read Unique ID command  3-Byte address (000000H) or 4-Byte address (00000000H) on SI 1 Byte Dummy 128bit Unique ID Out CS# goes high. Figure 84 Read Unique ID Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 SCLK Command SI 24-bit address 23 22 21 4BH 3 2 1 0 High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK Dummy Byte SI 7 6 5 4 3 2 1 0 Data Out1 Data Out2 7 6 5 4 3 2 1 0 7 6 5 MSB MSB Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. SO 58 GD25LT256E Figure 85 Read Unique ID Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 8 15 16 17 SCLK Command 4BH IO[3:0] Address (000000H) Addr. Addr. Addr. Addr. Addr. Addr. Dummy Byte 1 UID out UID out Byte 2 UID out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 86 Read Unique ID Sequence Diagram (Quad DTR) CS# 0 2 1 3 4 5 SCLK Dummy IO[3:0] 4BH Addr. Addr. Addr. Addr. Addr. Addr. DQS CS# 12 13 SCLK IO[3:0] Byte 1 UID UID out out Byte 2 UID out DQS Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.31. Read Identification (RDID) (9FH/9EH) The Read Identification (RDID) command allows the 8-bit manufacturer identification to be read, followed by two Bytes of device identification and one Byte of data FFh. The device identification indicates the memory type in the first Byte, and the memory capacity of the device in the second Byte. The Read Identification (RDID) command while an Erase or Program cycle is in progress, is not decoded, and has no effect on the cycle that is in progress. The Read Identification (RDID) command should not be issued while the device is in Deep Power-Down Mode. The device is first selected by driving CS# low. Then, the 8-bit command code for the command is shifted in. This is followed by the 24-bit device identification, stored in the memory. Each bit is shifted out on the falling edge of Serial Clock. The Read Identification (RDID) command is terminated by driving CS# high at any time during data output. When CS# is driven high, the device is in the Standby Mode. Once in the Standby Mode, the device waits to be selected, so that it can receive, decode and execute commands. 59 GD25LT256E Figure 87 Read Identification ID Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCLK 9FH/9EH SI 7 6 MSB SO CS# Manufacturer ID 5 4 3 2 1 0 7 Memory Type ID23-16 6 5 4 3 2 1 0 MSB 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK SI SO Capacity ID15-8 6 5 4 3 2 1 7 Device ID7-0 0 7 6 5 4 3 Manufacturer ID 2 1 0 MSB MSB 7 6 5 4 3 2 1 0 MSB Figure 88 Read Identification ID Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 8 9 10 11 SCLK Command MID 7-4 9FH/9EH IO[3:0] (MID & DID) LOOP (MID & DID) LOOP MID DID DID 3-0 23-20 19-6 DID 15-2 DID 11-8 DID 7-4 DID 3-0 MID 7-4 MID 3-0 DID Figure 89 Read Identification ID Sequence Diagram (Quad DTR) CS# 0 10 1 11 12 13 SCLK Dummy IO[3:0] MID 7-4 9FH or 9EH (MID & DID) LOOP MID DID DID DID DID 3-0 23-20 19-16 15-12 11-8 DQS CS# 14 15 16 17 18 19 SCLK IO[3:0] DID 7-4 DID 3-0 MID 7-4 (MID & DID) LOOP MID DID DID DID DID 3-0 23-20 19-16 15-12 11-8 DID 7-4 DID 3-0 (MID & DID) LOOP MID MID DID 7-4 3-0 DQS 9.32. Program/Erase Suspend (PES) (75H) The Program/Erase Suspend command “75H”, allows the system to interrupt a page program or sector/block erase operation and then read data from any other sector or block. The Write Register command (01H, B1H) and Erase/Program 60 GD25LT256E Security Registers command (44H, 42H) and Erase commands (20H/21H, 52H/5CH, D8H/DCH, C7H, 60H) and Page Program command (02H/12H, 32H/34H, C2H/3EH) are not allowed during Program suspend. The Write Register command (01H, B1H) and Erase Security Registers command (44H) and Erase commands (20H/21H, 52H/5CH, D8H/DCH, C7H, 60H) are not allowed during Erase suspend. Program/Erase Suspend is valid only during the page program or sector/block erase operation. A maximum of time of “tsus” (See AC Characteristics) is required to suspend the program/erase operation. The Program/Erase Suspend command will be accepted by the device only if the SUS_E/SUS_P bit in the Status Register equal to 0 and WIP bit equal to 1 while a Page Program or a Sector or Block Erase operation is on-going. If the SUS_E/SUS_P bit equal to 1 or WIP bit equal to 0, the Suspend command will be ignored by the device. The WIP bit will be cleared from 1 to 0 within “tsus” and the SUS_E/SUS_P bit will be set from 0 to 1 immediately after Program/Erase Suspend. A power-off during the suspend period will reset the device and release the suspend state. Figure 90 Program/Erase Suspend Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 tSUS SCLK Command 75H SI High-Z SO Accept read command Figure 91 Program/Erase Suspend Sequence Diagram (QPI & Quad DTR) CS# 0 1 tSUS SCLK Accept read command Command IO[3:0] 9.33. 75H Program/Erase Resume (PER) (7AH) The Program/Erase Resume command must be written to resume the program or sector/block erase operation after a Program/Erase Suspend command. The Program/Erase Resume command will be accepted by the device only if the SUS_P/SUS_E bit equal to 1 and the WIP bit equal to 0. After issued the SUS_P/SUS_E bit in the status register will be cleared from 1 to 0 immediately, the WIP bit will be set from 0 to 1 within 200ns and the Sector or Block will complete the erase operation or the page will complete the program operation. The Program/Erase Resume command will be ignored unless a Program/Erase Suspend is active. Figure 92 Program/Erase Resume Sequence Diagram CS# 0 1 2 3 4 5 6 7 SCLK Command SI 7AH Resume Erase/Program 61 GD25LT256E Figure 93 Program/Erase Resume Sequence Diagram (QPI & Quad DTR) CS# 0 1 SCLK Command 7AH IO[3:0] 9.34. Resume Program/Erase Erase Security Registers (44H) The GD25LT256E provides 4K-Byte Security Registers which can be erased and programmed individually. These registers may be used by the system manufacturers to store security and other important information separately from the main memory array. The Erase Security Registers command is similar to Sector/Block Erase command. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit. The Erase Security Registers command sequence: CS# goes low  sending Erase Security Registers command  CS# goes high. CS# must be driven high after the eighth bit of the last address Byte has been latched in; otherwise the Erase Security Registers command is not executed. As soon as CS# is driven high, the self-timed Erase Security Registers cycle (whose duration is tSE) is initiated. While the Erase Security Registers cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Erase Security Registers cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. The Security Registers Lock Bit in the Configuration Register can be used to OTP protect the security registers. Once the bit is set to 1, the Security Registers will be permanently locked; the Erase Security Registers command will be ignored. Address Security Register A23-16 00H A15-12 0000 A11-0 Do not care Figure 94 Erase Security Registers command Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Command SI 24 Bits Address 23 22 MSB 44H 2 1 0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 95 Erase Security Registers command Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 SCLK IO[3:0] Command Address 44H Addr. Addr. Addr. Addr. Addr. Addr. Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 62 GD25LT256E Figure 96 Erase Security Registers command Sequence Diagram (Quad DTR) CS# 0 1 2 4 3 SCLK IO[3:0] Addr. Addr. Addr. Addr. Addr. Addr. 44H Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.35. Program Security Registers (42H) The Program Security Registers command is similar to the Page Program command. Each security register contains four pages content. A Write Enable (WREN) command must previously have been executed to set the Write Enable Latch (WEL) bit before sending the Program Security Registers command. The Program Security Registers command is entered by driving CS# Low, followed by the command code (42H), three address Bytes and at least one data Byte on SI. As soon as CS# is driven high, the self-timed Program Security Registers cycle (whose duration is tPP) is initiated. While the Program Security Registers cycle is in progress, the Status Register may be read to check the value of the Write in Progress (WIP) bit. The Write in Progress (WIP) bit is 1 during the self-timed Program Security Registers cycle, and is 0 when it is completed. At some unspecified time before the cycle is completed, the Write Enable Latch (WEL) bit is reset. If the Security Registers Lock Bit is set to 1, the Security Registers will be permanently locked. Program Security Registers command will be ignored. Address Security Register A23-16 00H A15-12 0000 A11-8 Page Address A7-0 Byte Address Figure 97 Program Security Registers command Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 32 33 34 35 36 37 38 39 SCLK Command 24-bit address 23 22 21 2 Data Byte 1 1 0 7 MSB 6 5 4 3 2 1 2078 2079 6 2077 7 2076 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 2073 CS# 2072 MSB 2075 SI 3 2074 42H 1 0 SCLK Data Byte 3 Data Byte 2 SI 7 MSB 6 5 4 3 2 1 0 7 6 5 4 3 MSB 2 Data Byte 256 1 0 5 4 3 2 MSB Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 63 0 GD25LT256E Figure 98 Program Security Registers command Sequence Diagram (QPI) CS# 0 1 2 7 8 9 10 11 517 518 519 SCLK IO[3:0] Command Address 42H Addr. Byte 1 Data in Data in Byte 2 Data in Data in Data in Byte 256 Data Data in in Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 99 Program Security Registers command Sequence Diagram (Quad DTR) CS# 0 1 2 3 5 6 SCLK IO[3:0] Byte 1 Data Data Addr. Addr. Addr. Addr. Addr. Addr. in in 42H CS# 7 8 Byte 2 Data Data in in Byte 3 Data Data in in 260 261 Byte 255 Data Data in in Byte 256 Data Data in in SCLK IO[3:0] Byte 4~254 Data in Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.36. Read Security Registers (48H) The Read Security Registers command is similar to Fast Read command. The command is followed by a 3-Byte address (A23-A0) and a dummy Byte, and each bit is latched-in on the rising edge of SCLK. Then the memory content, at that address, is shifted out on SO, and each bit is shifted out, at a Max frequency fC, on the falling edge of SCLK. The first Byte addressed can be at any location. The address is automatically incremented to the next higher address after each Byte of data is shifted out. Once the A11-A0 address reaches the last Byte of the register (Byte FFFH), it will reset to 000H, the command is completed by driving CS# high. Address Security Register A23-16 00H A15-12 0000 64 A11-8 Page Address A7-0 Byte Address GD25LT256E Figure 100 Read Security Registers command Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 SCLK Command SI 24-bit address 23 22 21 48H 3 2 1 0 High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK Dummy Byte 7 SI 6 5 4 3 2 1 0 7 MSB SO Data Out1 6 5 4 3 2 1 Data Out2 0 7 6 5 MSB Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 101 Read Security Registers command Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 8 23 24 25 SCLK Command IO[3:0] 48H Dummy Address Byte 1 Data out Addr. Addr. Addr. Addr. Addr. Addr. Byte 2 Data out Data out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 102 Read Security Registers command Sequence Diagram (Quad DTR) CS# 0 1 2 3 4 5 SCLK Dummy IO[3:0] Addr. Addr. Addr. Addr. Addr. Addr. 48H DQS CS# 20 21 SCLK IO[3:0] Byte 1 Data Data out out Byte 2 Data out DQS Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 65 GD25LT256E 9.37. Individual Block/Sector Lock (36H)/Unlock (39H)/Read (3DH) The individual block/sector lock provides an alternative way to protect the memory array from adverse Erase/Program. In order to use the Individual Block/Sector Locks, the WPS bit in Configuration Register bit 2 at address 4 must be set to 0. If WPS=1, the write protection will be determined by the combination of TB, BP (3:0) bits in the Status Register. The individual Block/Sector Lock command (36H) sequence: CS# goes low SI: Sending individual Block/Sector Lock command SI: Sending 3-Byte or 4-Byte individual Block/Sector Lock Address  CS# goes high. The individual Block/Sector Unlock command (39H) sequence: CS# goes low SI: Sending individual Block/Sector Unlock command SI: Sending 3-Byte or 4-Byte individual Block/Sector Lock Address  CS# goes high. The Read individual Block/Sector lock command (3DH) sequence: CS# goes low  SI: Sending Read individual Block/Sector Lock command SI: Sending 3-Byte or 4-Byte individual Block/Sector Lock Address  SO: The Block/Sector Lock Bit will out CS# goes high. If the least significant bit (LSB) is1, the corresponding block/sector is locked, if the LSB is 0, the corresponding block/sector is unlocked, Erase/Program operation can be performed. Figure 103 Individual Block/Sector Lock command Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Command 24 Bits Address 36H SI 23 22 MSB 2 1 0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 104 Individual Block/Sector Lock command Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 SCLK IO[3:0] Command Address 36H Addr. Addr. Addr. Addr. Addr. Addr. Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 105 Individual Block/Sector Lock command Sequence Diagram (Quad DTR) CS# 0 1 2 3 4 SCLK IO[3:0] 36H Addr. Addr. Addr. Addr. Addr. Addr. Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 66 GD25LT256E Figure 106 Individual Block/Sector Unlock command Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 SCLK Command 24 Bits Address 39H SI 23 22 MSB 2 1 0 Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 107 Individual Block/Sector Unlock command Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 SCLK Command Address 39H Addr. Addr. Addr. Addr. Addr. Addr. IO[3:0] Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 108 Individual Block/Sector Unlock command Sequence Diagram (Quad DTR) CS# 0 1 2 3 4 SCLK IO[3:0] 39H Addr. Addr. Addr. Addr. Addr. Addr. Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 109 Read Individual Block/Sector lock command Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 29 30 31 32 33 34 35 36 37 38 39 SCLK Command 3DH SI 23 22 3 2 Lock value out X X X X X X X High-Z SO 4 MSB 0 MSB Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. Figure 110 Read Individual Block/Sector lock command Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 8 15 16 17 SCLK IO[3:0] dummy Command Address 3DH Addr. Addr. Addr. Addr. Addr. Addr. Lock Value Data out Data out Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 67 GD25LT256E Figure 111 Read Individual Block/Sector lock command Sequence Diagram (Quad DTR) CS# 0 2 1 3 4 5 SCLK IO[3:0] 3DH Addr. Addr. Addr. Addr. Addr. Addr. dummy CS# 12 13 SCLK Lock Value Data Data out out IO[3:0] Note: The device default is in 24-bit address mode. For 4-Byte mode, the address length becomes 32-bit. 9.38. Global Block/Sector Lock (7EH) or Unlock (98H) All Block/Sector Lock bits can be set to 1 by the Global Block/Sector Lock command, or can set to 0 by the Global Block/Sector Unlock command. The Global Block/Sector Lock command (7EH) sequence: CS# goes low SI: Sending Global Block/Sector Lock command CS# goes high. The Global Block/Sector Unlock command (98H) sequence: CS# goes low SI: Sending Global Block/Sector Unlock command CS# goes high. Figure 112 Global Block/Sector Lock Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 SCLK Command 7EH SI High-Z SO Figure 113 Global Block/Sector Lock Sequence Diagram (QPI & Quad DTR) CS# 0 1 SCLK Command IO[3:0] 7EH 68 GD25LT256E Figure 114 Global Block/Sector Unlock Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 SCLK Command 98H SI High-Z SO Figure 115 Global Block/Sector Unlock Sequence Diagram (QPI & Quad DTR) CS# 0 1 SCLK Command 98H IO[3:0] 9.39. Enable Reset (66H) and Reset (99H) If the Reset command is accepted, any on-going internal operation (except in Continuous Read Mode) will be terminated and the device will return to its default power-on state and lose all the current volatile settings, such as Volatile Status Register bits, Write Enable Latch status (WEL), Program/Erase Suspend status, Read Parameter setting (P7-P0), Deep Power Down Mode, Continuous Read Mode bit setting (M7-M0). When Flash is in QPI Mode, DTR Mode or Continuous Read Mode (XIP), 66H&99H cannot reset Flash to power-on state. Therefore, it is recommended to send the following sequence to reset Flash in these modes: 1. 8CLK with IO= all “H” or all “L”: ensure Flash quit XIP mode 2. QPI format 66H/99H: ensure Flash in QPI mode and DTR mode can be reset 3. SPI format 66H/99H: ensure Flash in SPI mode can be reset The “Enable Reset (66H)” and the “Reset (99H)” commands can be issued in either SPI or QPI mode. The “Reset (99H)” command sequence as follow: CS# goes low  Sending Enable Reset command  CS# goes high  CS# goes low  Sending Reset command  CS# goes high. Once the Reset command is accepted by the device, the device will take approximately tRST / tRST_E to reset. During this period, no command will be accepted. Data corruption may happen if there is an on-going or suspended internal Erase or Program operation when Reset command sequence is accepted by the device. It is recommended to check the WIP bit and the SUS_P/SUS_E bits in Status Register before issuing the Reset command sequence. Figure 116 Enable Reset and Reset command Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 0 7 1 2 3 4 5 SCLK SI SO Command Command 66H 99H High-Z 69 6 7 GD25LT256E Figure 117 Enable Reset and Reset command Sequence Diagram (QPI & Quad DTR) CS# 0 1 0 1 SCLK Command Command 66H 99H IO[3:0] 9.40. Read Serial Flash Discoverable Parameter (5AH) The Serial Flash Discoverable Parameter (SFDP) standard provides a consistent method of describing the functional and feature capabilities of serial flash devices in a standard set of internal parameter tables. These parameter tables can be interrogated by host system software to enable adjustments needed to accommodate divergent features from multiple vendors. The concept is similar to the one found in the Introduction of JEDEC Standard, JESD68 on CFI. SFDP is a standard of JEDEC Standard No.216C. Figure 118 Read Serial Flash Discoverable Parameter command Sequence Diagram (SPI) CS# 0 1 2 3 4 5 6 7 8 9 10 28 29 30 31 SCLK Command SI 24-bit address 23 22 21 5AH 3 2 1 0 High-Z SO CS# 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 SCLK Dummy Byte 7 SI 6 5 4 3 2 1 0 Data Out1 5 4 3 2 7 6 MSB SO 1 0 Data Out2 7 6 5 MSB Figure 119 Read Serial Flash Discoverable Parameter command Sequence Diagram (QPI) CS# 0 1 2 3 4 5 6 7 8 15 16 17 SCLK IO[3:0] Dummy Command Address 5AH Addr. Addr. Addr. Addr. Addr. Addr. 70 Byte 1 Byte 2 SFDP SFDP SFDP out out out GD25LT256E Figure 120 Read Serial Flash Discoverable Parameter command Sequence Diagram (DTR, QPI) CS# 0 2 1 3 4 5 SCLK IO[3:0] 5AH Addr. Addr. Addr. Addr. Addr. Addr. Addr. Addr. DQS CS# 12 13 SCLK Dummy IO[3:0] Byte 1 Byte 2 SFDP SFDP SFDP out out out DQS Table 13 Signature and Parameter Identification Data Values (Please contact Gigadevice for details) 71 GD25LT256E 10. ELECTRICAL CHARACTERISTICS 10.1. POWER-ON TIMING Figure 121 Power-on Timing Vcc(max) Chip Selection is not allowed Vcc(min) tVSL Device is fully accessible VWI Time Table 14 Power-Up Timing and Write Inhibit Threshold Symbol Parameter tVSL VCC (min.) to device operation VWI Write Inhibit Voltage 10.2. Min. Max. 2.5 1 Unit ms 1.4 V INITIAL DELIVERY STATE The device is delivered with the memory array erased: all bits are set to 1(each Byte contains FFH).The Status Register contains 00H (all Status Register bits are 0). 10.3. ABSOLUTE MAXIMUM RATINGS Parameter Value Unit Ambient Operating Temperature -40 to 85 ℃ Storage Temperature -65 to 150 ℃ Transient Input/Output Voltage (note: overshoot) -2.0 to VCC+2.0 V Applied Input/Output Voltage -0.6 to VCC+0.4 V -0.6 to 2.5 V VCC 72 GD25LT256E Figure 122 Input Test Waveform and Measurement Level Maximum Negative Overshoot Waveform 20ns Maximum Positive Overshoot Waveform 20ns 20ns Vss Vcc + 2.0V Vss-2.0V Vcc 20ns 20ns 20ns 10.4. CAPACITANCE MEASUREMENT CONDITIONS Symbol Parameter Min Typ. Max Unit Conditions CIN Input Capacitance 6 pF VIN=0V COUT Output Capacitance 8 pF VOUT=0V CL Load Capacitance 12 Input Rise And Fall time pF 5 ns Input Pause Voltage 0.1VCC to 0.8VCC V Input Timing Reference Voltage 0.2VCC to 0.7VCC V Output Timing Reference Voltage 0.5VCC V Figure 123 Input Test Waveform and Measurement Level Input timing reference level 0.8VCC 0.7VCC 0.1VCC 0.2VCC Output timing reference level AC Measurement Level Note: Input pulse rise and fall time are 133MHz 1 ns fSCLK ≤ 100MHz 1 ns fSCLK ≤ 133MHz 0.8 ns fSCLK ≤ 166MHz 0.6 ns fSCLK 0.5 ns fSCLK ≤ 133MHz 2 ns fSCLK > 133MHz 1 ns fSCLK ≤ 100MHz 1 ns fSCLK ≤ 133MHz 0.8 ns fSCLK ≤ 166MHz 0.6 ns fSCLK 0.5 ns From Read to next Read tSHSL CS# High Time (Read/Write) From Write/Erase/Program to Read Statue Register tCLQX tCHQX tDVCH tDVCH tDVCL tCHDX tCHDX tCLDX Output Hold Time Data In Setup Time (STR) Data In Setup Time (DTR) Data In Hold Time (STR) Data In Hold Time (DTR) > 166MHz > 166MHz tSHQZ Output Disable Time 8 tQSV Clock transient to DQS valid time tDQSQ SIO valid skew related to DQS (12pF) 0.4 ns tQHS SIO hold skew factor (12pF) 0.4 ns Align to 30pF tCLQV 75 ns ns GD25LT256E tCLQV Clock Transient To Output Valid (30pF) 8 ns tCHQV Clock Transient To Output Valid (12pF) 6 ns tWHSL Write Protect Setup Time Before CS# Low 20 ns tSHWL Write Protect Hold Time After CS# High 100 ns tDP CS# High To Deep Power-Down Mode 3 μs tRES1 CS# High To Standby Mode 30 μs tSUS CS# High To Next Command After Suspend 20 μs tRST CS# High To Next Command After Reset (except from erase) 30 μs CS# High To Next Command After Reset (from erase) 30 ms 4 40 ms tRST_E tW Write Status Register Cycle Time Write Non-Volatile Configuration Register Cycle Time tBP1 Byte Program Time (First Byte) 30 50 μs tBP2 Additional Byte Program Time (After First Byte) 2.5 5 μs tPP Page Programming Time 0.4 1.2 ms tSE Sector Erase Time 30 400 ms tBE1 Block Erase Time(32K Bytes) 0.1 0.8 s tBE2 Block Erase Time(64K Bytes) 0.2 2 s tCE Chip Erase Time(GD25LT256E) 50 200 s Note: 1. Typical value tested at T = 25℃. 2. Value guaranteed by design and/or characterization, not 100% tested in production. 3. Time of CS# High To Next Command After Reset from 01H/B1H command would be tW + tRST 76 GD25LT256E Figure 124 Serial Input Timing tSHSL CS# tCHSL tSLCH tCHSH tSHCH SCLK tDVCH tCHCL tCLCH tCHDX LSB SI MSB SO High-Z Figure 125 Output Timing CS# tCLH SCLK tCLQV tCLQV tCLQX tSHQZ tCLL tCLQX SO LSB SI Least significant address bit (LIB) in Figure 126. Serial Input Timing (DTR) tSHSL CS# tSLCH tCLSH tCHSL tSHCH SCLK tDVCL tCLDX tDVCH IO[3:0] tCLCH MSB tCHCL LSB tCHDX Figure 127. Serial Output Timing (DTR) CS# tCLQV tCLH SCLK IO[3:0] tCLL tCHQV tCLQX tSHQZ MSB LSB tCHQX 77 GD25LT256E Figure 128. DQS Output Timing (DTR) CS# SCLK tQHS IO[7:0] tQSV tQSV DQS tDQSQ tDQSQ Figure 129 RESET Timing tRB CS# RESET# tRLRH tRHSL Table 15 Reset Timing Symbol Parameter Min. Typ. Max. Unit. tRLRH RESET# Low Pulse Width 1 μs tRHSL RESET# High Time Before Read 50 ns tRB Reset Recovery Time (Except for Erase Operation) 30 μs Reset Recovery Time (for Erase Operation) 30 ms Note: 1. Time of Reset Recovery Time from 01H/B1H command would be tW + tRB 78 GD25LT256E 11. ORDERING INFORMATION GD XX XX XX X X X X X Packing T or no mark: Tube Y: Tray R: Tape and Reel Green Code R: Pb Free + Halogen Free Green Package + RESET# Pin Temperature Range I: Industrial (-40℃ to +85℃) J: Industrial (-40℃ to +105℃)* E: Industrial (-40℃ to +125℃)* F: Industrial+ (-40℃ to +85℃) 3: Automotive (-40℃ to +85℃)* 2: Automotive (-40℃ to +105℃)* A: Automotive (-40℃ to +125℃)* Package Type F: SOP16 300mil B: TFBGA-24ball (5x5 Ball Array) Generation E: E Version Density 256: 256M bit Series LT: 1.8V, 4KB Uniform Sector, High Speed Product Family 25: SPI NOR Flash *This datasheet applies to temperature range I: Industrial (-40℃ to +85℃) and F: Industrial+ (-40℃ to +85℃) only. Please contact GigaDevice sales for extended temperature industrial products and automotive products. 79 GD25LT256E 11.1. Valid Part Numbers Please contact GigaDevice regional sales for the latest product selection and available form factors. Temperature Range I: Industrial (-40℃ to +85℃) Product Number Density Package Type GD25LT256EFIR GD25LT256EBIR 256Mbit 256Mbit SOP16 300mil TFBGA-24ball (5x5 Ball Array) Temperature Range F: Industrial+ (-40℃ to +85℃) Product Number Density Package Type GD25LT256EFFR GD25LT256EBFR 256Mbit 256Mbit SOP16 300mil TFBGA-24ball (5x5 Ball Array) 80 GD25LT256E 12. PACKAGE INFORMATION 12.1. Package SOP16 300mil D 16 9 E1 E h L1 L 1 h 8 θ “A” b Base Metal c A A2 b A1 e Detail “A” Dimensions Symbol A A1 A2 b c D E E1 Min - 0.10 2.05 0.31 0.10 10.20 10.10 7.40 Nom - 0.20 - 0.41 0.25 10.30 10.30 7.50 Max 2.65 0.30 2.55 0.51 0.33 10.40 10.50 7.60 Unit mm Note: 1. Both the package length and width do not include the mold flash. 2. Seating plane: Max. 0.1mm. 81 e L L1 0.40 1.27 1.27 1.40 h θ 0.25 0 - - 0.75 8 GD25LT256E 12.2. Package TFBGA-24BALL (5x5 ball array) 1 2 3 4 5 5 4 3 2 1 A A B B b C D C D1 D D e E E e E E1 A2 A A1 Dimensions Symbol A A1 A2 b E Min - 0.25 0.75 0.35 5.90 Nom - 0.30 0.80 0.40 6.00 Max 1.20 0.35 0.85 0.45 6.10 Unit mm E1 D1 e 4.00 1.00 7.90 4.00 Note: Both the package length and width do not include the mold flash. 82 D 8.00 8.10 GD25LT256E 13. REVISION HISTORY Version No 1.0 Description Initial release 83 Page Date All 2019-8-5 GD25LT256E Important Notice This document is the property of GigaDevice Semiconductor (Beijing) Inc. and its subsidiaries (the "Company"). This document, including any product of the Company described in this document (the “Product”), is owned by the Company under the intellectual property laws and treaties of the People’s Republic of China and other jurisdictions worldwide. The Company reserves all rights under such laws and treaties and does not grant any license under its patents, copyrights, trademarks, or other intellectual property rights. The names and brands of third party referred thereto (if any) are the property of their respective owner and referred to for identification purposes only. The Company makes no warranty of any kind, express or implied, with regard to this document or any Product, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The Company does not assume any liability arising out of the application or use of any Product described in this document. Any information provided in this document is provided only for reference purposes. It is the responsibility of the user of this document to properly design, program, and test the functionality and safety of any application made of this information and any resulting product. Except for customized products which has been expressly identified in the applicable agreement, the Products are designed, developed, and/or manufactured for ordinary business, industrial, personal, and/or household applications only. The Products are not designed, intended, or authorized for use as components in systems designed or intended for the operation of weapons, weapons systems, nuclear installations, atomic energy control instruments, combustion control instruments, airplane or spaceship instruments, traffic signal instruments, life-support devices or systems, other medical devices or systems (including resuscitation equipment and surgical implants), pollution control or hazardous substances management, or other uses where the failure of the device or Product could cause personal injury, death, property or environmental damage ("Unintended Uses"). Customers shall take any and all actions to ensure using and selling the Products in accordance with the applicable laws and regulations. The Company is not liable, in whole or in part, and customers shall and hereby do release the Company as well as it’s suppliers and/or distributors from any claim, damage, or other liability arising from or related to all Unintended Uses of the Products. Customers shall indemnify and hold the Company as well as it’s suppliers and/or distributors harmless from and against all claims, costs, damages, and other liabilities, including claims for personal injury or death, arising from or related to any Unintended Uses of the Products. Customers shall discard the device according to the local environmental law. Information in this document is provided solely in connection with the Products. The Company reserves the right to make changes, corrections, modifications or improvements to this document and the Products and services described herein at any time, without notice. 84
GD25LT256EFIR 价格&库存
很抱歉,暂时无法提供与“GD25LT256EFIR”相匹配的价格&库存,您可以联系我们找货
