AW8737SCSR
AW8737SCSR
    AWINIC(艾为)
    CSP14
AW8737SCSR 数据手册
AW8737S Data Sheet Nov 2017 V1.1 High efficiency, Low noise, Ultralow distortion, Constant large volume, Upgrade Seventh generation Class K Audio Amplifier FEATURES DESCRIPTION     AW8737S is designed to enhance smart mobile phone sound quality, which is a new high efficiency, low noise, ultra-low distortion, constant large volume, upgrading seventh generation class K audio amplifier. Using a new generation K-Chargepump technology, efficiency reaches 93%, power amplifier’s overall efficiency is up to 80%, greatly prolong the mobile phone usage time. The AW8737S noise floor is as low as to 53μV, with 97dB high signal-to-noise-ratio(SNR). The ultra-low distortion 0.008% and unique no-crack-noise (NCN) technology brings high quality music enjoyment. AW8737S has 0.6W, 0.8W, 1W and 1.2W four selectable speaker-guard output power levels, recommended using rated power of 0.5W and above speakers. AW8737S integrated unique NCN technology, the output power cannot drop along with lithium battery voltage lower down. Within lithium battery voltage range (3.3V--4.35V), output power is constant, preventing the voice becomes smaller and smaller during usage of cell phone. The AW8737S uses Awinic proprietary TDD-Noise suppression technology and EMI suppression technology, effectively restrain TDD-Noise and EMI interference. AW8737S has built-in over current protection, over-temperature protection and short circuit protection function, effectively protect the chip. The AW8737S uses small 0.4mm pitch 1.6mmx1.68mm CSP-14 package. Low noise:53μV Power amplifier overall efficiency 80% Ultra-low distortion:0.008% Within Lithium battery voltage range, output power is maintained constant  Selectable speaker-guard power level:0.6w,0.8W, 1W,1.2W  No-crack-noise (NCN) technology  Super TDD-Noise suppression  Excellent pop-click suppression  One wire pulse control  High PSRR:-68dB(217Hz)  ESD protection:±6kV (HBM)  Small 0.4mm pitch 1.6mm×1.68mm CSP-14package APPLICATIONS  Smart phone APPLICATION DIAGRAM VBAT CS1 4.7uF CF1 2.2uF CS2 0.1uF A3,B3 A4 Pulse Input 1 Single-End Input 2 3 4 15nF 3KΩ Cin Rin A2 VDD D1 B1 C1 C1P C1N C2P C2N SHDN PVDD Cin Rin 3KΩ D2 AW8737S A1 D3 COUT 4.7uF 10V INN Cd 220pF 15nF CF2 2.2uF VOP B4 SPK B1 C2 1nF B2 C3 1nF INP VON D4 GND C2,C4 Figure 1 AW8737S single-ended input application diagram All trademarks are the property of their respective owners. www.awinic.com.cn COPYRIGHT ©2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 1 AW8737S Data Sheet Nov 2017 V1.1 PIN CONFIGURATION AND TOP MARK AW8737SCSR TOP VIEW VON D GND C VDD VOP B INN VDD SHDN A 2 3 D C2P C1P C C1N GND B C2N A INP 1 AW8737SCSR MARKING PVDD 2 1 4 3 4 K37S–AW8737SCSR XXXX–Production tracking code Please notice the pin number Figure 2 K37S XXXX AW8737S pin diagram top view and device marking PIN DESCRIPTION Number Symbol Description A1 A2 A3 A4 B1 B3 B4 C1 C2,C4 D1 D2 D3 D4 INP INN VDD SHDN C2N VDD VOP C1N GND C2P C1P PVDD VON Positive audio input terminal Negative audio input terminal Power supply Chip power down pin,active low;one wire pulse control; Negative side of the external charge pump flying capacitor C2 Power supply Positive audio output terminal Negative side of the external charge pump flying capacitor C1 Ground Positive side of the external charge pump flying capacitor C2 Positive side of the external charge pump flying capacitor C1 Boost charge pump output voltage Negative audio output terminal AWINIC CLASS K FAMILY ITEM TEST CONDITION AW8736 AW8737 AW8737S AW8738 PVDD(V) VDD=4.2V 5.8 6.05 6.05 6.05 Ouput noise(μV) VDD=4.2V,f=20Hz to 20kHz,input ac grounded,8V/V,A-weighting 125 52 53 40 VDD=3.6V,Po=1.0W,RL=8Ω+33μH 75 80 80 83 Efficiency(%) www.awinic.com.cn COPYRIGHT ©2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 2 AW8737S Data Sheet Nov 2017 V1.1 FUNCTIONAL DIAGRAM Figure 3 AW8737S functional diagram APPLICATION DIAGRAM VBAT CS1 4.7uF CF1 2.2uF CS2 0.1uF A3,B3 A4 Pulse Input 1 Single-End Input 3 2 4 15nF 3KΩ Cin Rin A2 VDD D1 B1 C1 C1P C1N C2P C2N SHDN PVDD Rin 15nF 3KΩ D2 AW8737S A1 D3 COUT 4.7uF 10V INN Cd 220pF Cin CF2 2.2uF VOP B4 SPK B1 C2 1nF B2 C3 1nF INP VON D4 GND C2,C4 Figure 4 AW8737S single-ended input application diagram (Note 1) Note1:when single-ended input,input audio signal can arbitrarily connect to one of INN,INP input terminal,the other terminal connects to ground through input capacitor and resistance. www.awinic.com.cn COPYRIGHT ©2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 3 AW8737S Data Sheet Nov 2017 V1.1 VBAT CS1 4.7uF A3,B3 A4 Pulse Input 1 Differential Input 3 2 CF2 2.2uF CF1 2.2uF CS2 0.1uF VDD D2 D1 B1 C1 C1P C1N C2P C2N SHDN PVDD D3 COUT 4.7uF 10V 4 15nF 3KΩ Cin Rin A2 INN AW8737S Cd 220pF Cin Rin 15nF 3KΩ A1 VOP B4 SPK B1 C2 1nF B2 C3 1nF INP VON D4 GND C2,C4 Figure 5 AW8737S differential input application diagram ORDERING INFORMATION Product Type Operation temperature range Package Device Marking Moisture Sensitivity Level Environmental Information Delivery Form AW8737SCSR -40℃~85℃ CSP-14 K37S MSL1 ROHS+HF Tape and Reel 3000 pcs AW8737S Shipment R: Tape & Reel Package type CS: CSP14 ABSOLUTE MAXIMUM RATING(Note2) Parameter Range Supply Voltage VDD -0.3V to 6V Chargepump output voltage PVDD -0.3V to 7V VOP,VON -0.3V to PVDD+0.3V C1P ,C2P -0.3V to PVDD+0.3V C1N,C2N -0.3V to VDD+0.3V INP,INN Input Pin Voltage -0.3V to VDD+0.3V www.awinic.com.cn COPYRIGHT ©2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 4 AW8737S Data Sheet Nov 2017 V1.1 84.9℃/W Package Thermal Resistance θJA -40℃ to 85℃ Ambient Temperature Range 165℃ Maximum Junction Temperature TJMAX -65℃ to 150℃ Storage Temperature Range TSTG 260℃ Lead Temperature(Soldering 10 Seconds) (Note ESD Rating 3) ±6KV HBM(human body model) CDM ±1.5KV MM ±250V Latch-up +IT:450mA Test Condition:JEDEC STANDARD NO.78D NOVEMBER 2011 -IT:-450mA Note 2:Stresses beyond those listed under "absolute maximum ratings" may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other conditions beyond those indicated under "recommended operating conditions" is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. Note 3:The human body model is a 100pF capacitor discharged through a 1.5kΩ resistor into each pin. Test method: MIL-STD-883H Method 3015.8 MODE DESCRIPTION(TA=25℃,VDD=4.2V) AW8737S audio amplifier outer input capacitor is Cin,outer input resist is Rin,inner input resist is 16.6KΩ, gain Av is 319.5K/(Rin+16.6K). Recommended typical application is: 1、 Cin=15nF,Rin=3KΩ,Av=16.3V/V; 2、 Cin=15nF,Rin=10KΩ,Av=12V/V; Gain(V/V) Mode Enable Signal NCN Power(W) Rin=3KΩ Rin=10KΩ RL=8Ω+ 33μH Mode1 16.3 12 1.2 1.6 Mode2 16.3 12 1 1.3 Mode3 16.3 12 0.8 1.0 Mode4 16.3 12 0.6 0.8 www.awinic.com.cn RL=6Ω+ 33μH NCN Function COPYRIGHT ©2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 5 AW8737S Data Sheet Nov 2017 V1.1 ELECTRICAL CHARACTERISTICS Test condition:TA=25℃, VDD=3.6V,RL=8Ω+33μH,f=1kHz(unless otherwise noted) Parameter Test conditions Min Typ Max Units VDD Power supply voltage 3.0 5.5 V VIH SHDN high input voltage 1.3 VDD V VIL SHDN low input voltage 0 0.35 V 30 mV 1 μA |VOS| Output offset voltage Vin=0V, VDD=3.0V to 5.5V -30 ISD Shutdown current VDD=3.6V, SHDN =0V TTG Thermal AGC start temperature threshold 150 ℃ TTGR Thermal AGC exit temperature threshold 130 ℃ TSD Over temperature protection threshold 160 ℃ TSDR Over temperature recovery threshold 120 ℃ TON Start-up time 40 ms protection 0 K-Chargepump 1.5* VDD =3.0V to 4V PVDD VDD >4V Vhys 6.05 OVP hysteresis VDD >4V FCP Charge Pump frequency VDD=3.0V to 5.5V ηCP Charge pump efficiency VDD=3.6V, Iload=200mA TST Soft-start time No load,COUT=4.7μF IL V VDD Output voltage V 50 0.8 Current limit when PVDD short to ground 1.06 mV 1.33 93 MHz % 1 1.2 1.4 ms 200 300 400 mA 15 mA Class K power amplifier(Mode1-Mode4) Iq Quiescent current VDD=4.2V,Vin=0,no load 10 η Efficiency VDD=3.6V, Po=1.0W, RL=8Ω+33μH 80 Modulation frequency VDD=3.0V to 5.5V Av gain external input resistance=3kΩ Vin Recommend input voltage VDD=3.0V to 5.5V Rini Inner input resistance Mode1~Mode4 16.6 kΩ Fhin Input high pass filter corner frequency Cin=15nF,external input resistance=3kΩ 542 Hz Fosc Mode1 NCN output power Pncn Mode2 NCN output power www.awinic.com.cn 600 800 % 1000 16.3 kHz V/V 1 Vp VDD=4.2V, RL=8Ω+33μH 1.08 1.2 1.32 W VDD=4.2V, RL=6Ω+33μH 1.44 1.6 1.76 W VDD=4.2V, RL=4Ω+15μH 2.16 2.4 2.64 W VDD=4.2V, RL=3Ω+15μH 2.16 2.4 2.64 W VDD=4.2V, RL=8Ω+33μH 0.9 1 1.1 W VDD=4.2V, RL=6Ω+33μH 1.17 1.3 1.43 W VDD=4.2V, RL=4Ω+15μH 1.8 2 2.2 W COPYRIGHT ©2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 6 AW8737S Data Sheet Nov 2017 V1.1 Parameter Mode3 NCN output power Pncn Mode4 NCN output power PSRR SNR Test conditions Min Typ Max Units VDD=4.2V, RL=3Ω+15μH 2.16 2.4 2.64 W VDD=4.2V, RL=8Ω+33μH 0.72 0.8 0.88 W VDD=4.2V, RL=6Ω+33μH 0.9 1.0 1.1 W VDD=4.2V, RL=4Ω+15μH 1.44 1.6 1.76 W VDD=4.2V, RL=3Ω+15μH 1.8 2.0 2.2 W VDD=4.2V, RL=8Ω+33μH 0.54 0.6 0.66 W VDD=4.2V, RL=6Ω+33μH 0.72 0.8 0.88 W VDD=4.2V, RL=4Ω+15μH 1.08 1.2 1.32 W VDD=4.2V, RL=3Ω+15μH 1.44 1.6 1.76 W VDD=4.2V, Vp-p_sin=200mV 217Hz -68 dB VDD=4.2V, Vp-p_sin=200mV 1kHz -68 dB 97 dB 53 μVrms 58 μVrms 68 μVrms VDD=3.6V,Po=1W,RL=8Ω+33μH,f=1kHz, Mode1 0.008 % VDD=3.6V,Po=1W,RL=6Ω+33μH,f=1kHz,Mode1 0.008 % Power supply rejection ratio Signal-to-noise ratio VDD=4.2V, Po=1.75W, THD+N=1%, RL=8Ω+33μH,Av=8V/V VDD=4.2V, f=20Hz to 20kHz, input ac grounded,AV=8V/V Vn Output noise voltage VDD=4.2V, f=20Hz to 20kHz, input ac grounded, 12V/V A-weighting VDD=4.2V, f=20Hz to 20kHz, input ac grounded, 16V/V THD+N Total harmonic distortion+noise One wire pulse control TH SHDN high level duration time VDD=3.0V to 5.5V 0.75 2 10 μs TL SHDN low level duration time VDD=3.0V to 5.5V 0.75 2 10 μs TLATCH SHDN turn on delay time VDD=3.0V to 5.5V 150 500 μs TOFF SHDN turn off delay time VDD=3.0V to 5.5V 150 500 μs TAT Attack time -13.5dB gain attenuation completed TRL Release time 13.5dB gain release completed AMAX Maximum attenuation NCN(Note 4) 40 ms 1.2 s -13.5 dB Note 4:Attack time points to 13.5dB gain attenuation time;Release time points to 13.5dB gain recovery time. www.awinic.com.cn COPYRIGHT ©2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 7 AW8737S Data Sheet Nov 2017 V1.1 MEASUREMENT SETUP AW8737S features switching digital output, as shown in Figure 6. Need to connect a low pass filter to VOP/VON output respectively to filter out switch modulation frequency, then measure the differential output of filter to obtain analog output signal. 10nF 500Ω VOP INP Rin Cin 30kHz Low-Pass Fliter AW8737S VON INN 500Ω Rin Cin 10nF Figure 6 AW8737S test setup Low pass filter uses resistance and capacitor values listed in Table 1. Rfilter Cfilter Low-pass cutoff frequency 500Ω 10nF 32kHz 1kΩ 4.7nF 34kHz Table 1 AW8737S recommended values for low pass filter Output Power Calculation According to the above test methods, the differential analog output signal is obtained at the output of the low pass filter. The valid values Vo_rms of the differential signal as shown below: Vo_rms The power calculation of Speaker is as follows: PL  www.awinic.com.cn (Vo _ rms) 2 RL (RL:load impedance of the speaker) COPYRIGHT ©2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 8 AW8737S Data Sheet Nov 2017 V1.1 TYPICAL CHARACTERISTICS Efficiency vs Po K-chargepump Efficiency 100 100 90 90 VDD=3.6V 80 VDD=4.2V 80 VDD=4.2V Efficiency( % ) 70 Efficiency( % ) VDD=3.6V 60 50 40 30 70 60 50 40 30 20 20 RL=8Ω+33μH 10 CF1,CF2=2.2μF COUT =4.7μF 10 0 0 0 0.2 0.4 0.6 0.8 1 1.2 1.4 1.6 1.8 2 0 0.2 0.4 0.6 Po ( W ) 0.8 1 1.2 1.4 1.6 1.8 2 10K 20K Po ( W ) GAIN vs FREQUENCY OUTPUT POWER vs VDD 1.4 24 AW8737S Po keep constant Mode1 1.2 22 20 Mode2 18 Mode3 0.8 Mode4 0.6 16 Gain( V/V ) NCN Output Power( W ) 1.0 Mode1~Mode4 Rine=3kΩ Cin=1μF RL=8Ω+33μH 14 12 10 8 0.4 6 4 0.2 2 RL=8Ω+33μH 0 3.3 3.5 3.7 3.9 20 4.3 4.1 50 100 VDD ( V ) 1K FREQUENCY ( Hz ) THD+N vs Po THD+N vs FREQUENCY 10 1 THD+N (%) THD+N (%) 1 10 Mode1 0.8W VDD=4.2V Rine=3kΩ Cin=1μF RL=8Ω+33μH 0.1 0.01 0.001 20 Mode1 0.8W VDD=4.2V Rine=3kΩ Cin=1μF RL=6Ω+33μH 0.1 0.01 50 100 1K 10K 0.001 20 20K Frequency ( Hz ) www.awinic.com.cn 50 100 1K 10K 20K Po( W ) COPYRIGHT ©2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 9 AW8737S Data Sheet Nov 2017 V1.1 Po vs VIN 2 Po vs VIN 2 Mode1 VDD=4.2V f=1kHz RL=8Ω+33μH 1 NCN Po (W) Po (W) 1 Mode2 VDD=4.2V f=1kHz RL=8Ω+33μH 0.5 NCN 0.5 1.30 0.28 0.1 0.1 0.5 0.1 1 2 Po vs VIN 2 Mode3 VDD=4.2V f=1kHz RL=8Ω+33μH 1 Mode4 VDD=4.2V f=1kHz RL=8Ω+33μH Po (W) 1 NCN 0.5 0.23 NCN 0.5 1.07 0.2 0.1 0.93 0.1 0.5 0.1 1 2 0.5 0.1 VIN ( Vp ) 1 2 VIN ( Vp ) PSRR vs FREQUENCY PSRR vs FREQUENCY 0 0 Mode1 Rine=3kΩ Cin=1μF RL=8Ω+33μH -10 -20 Mode4 Rine=3kΩ Cin=1μF RL=8Ω+33μH -10 -20 -30 PSRR (dB) -30 PSRR (dB) 2 VIN ( Vp ) Po vs VIN 2 1 0.5 0.1 VIN ( Vp ) Po (W) 1.20 0.25 -40 -50 VDD=4.2V VDD=3.6V -40 -50 -60 -60 -70 -70 -80 -80 -90 VDD=4.2V VDD=3.6V -90 20 100 1K 10K 20K 20 Frequency ( Hz ) www.awinic.com.cn 100 1K 10K 20K Frequency ( Hz ) COPYRIGHT ©2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 10 AW8737S Data Sheet Nov 2017 V1.1 SHUTDOWN SEQUENCE STARTUP SEQUENCE SHDN SHDN VOP&VON 10ms/div VOP&VON NCN ATTACK SEQUENCE 100μs/div NCN RELEASE SEQUENCE Vin Vin VOP-VON VOP-VON 200ms/div 10ms/div www.awinic.com.cn COPYRIGHT ©2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 11 AW8737S Data Sheet Nov 2017 V1.1 DETAILED FUNCTIONAL DESCRIPTION AW8737S is designed to enhance smart mobile phone sound quality, which is a new high efficiency, low noise, ultra-low distortion, constant large volume, upgrading seventh generation class K audio amplifier, referred to as K7S. Using a new generation K-Chargepump technology, efficiency reaches 93%, power amplifier’s overall efficiency is up to 80%, greatly prolong the mobile phone usage time. The AW8737S noise floor is as low as to 53μV, with 97dB high signal-to-noise-ratio(SNR). The ultra-low distortion 0.008% and unique no-crack-noise (NCN) technology brings high quality music enjoyment. AW8737S has 0.6W, 0.8W, 1W and 1.2W four selectable speaker-guard output power levels, recommended using rated power of 0.5W and above speakers. AW8737S integrated unique NCN technology, the output power cannot drop along with lithium battery voltage lower down. Within lithium battery voltage range (3.3V--4.35V), output power is constant, preventing the voice becomes smaller and smaller during usage of cell phone. The AW8737S built in excellent pop-click noise suppression circuit, effectively avoids pop-click noise during shutdown, wakeup, and power-up/down operation of AW8737S. The AW8737S uses awinic proprietary TDD-Noise suppression technology and EMI suppression technology, effectively restrain TDD-Noise and EMI interference. AW8737S has built-in over current protection, over-temperature protection and short circuit protection function, effectively protect the chip. The AW8737S uses small 0.4mm pitch 1.6mmx1.68mm CSP-14 package. The AW8737S is specified over the industrial temperature range of -40℃ to 85℃. CONSTANT OUTPUT POWER In the mobile phone audio applications, the NCN function to promote music volume and quality is very attractive, but as the lithium battery voltage drops, general power amplifier output power will reduce gradually, leads to smaller and smaller music volume. So, it is hard to provide high quality music within the battery voltage range. The AW8737S uses unique second generation NCN technology, within lithium battery voltage range(3.3V--4.35V), output power is constant, the output power cannot drop along with lithium battery voltage lower down. Even if the battery voltage drops, AW8737S can still provide high quality large volume music enjoyment. AW8737S has four operation modes, the four modes have NCN function, the output power level is 1.2W,1W,0.8W,0.6W, respectively. Second Generation NCN technology In audio application, output signal will be undesirable distortion caused by too large input and power supply voltage down with battery, and clipped output signal may cause permanent damage to the speaker. The traditional NCN function adjusts system gain automatically to generate desired output by detecting the “Crack” distortion of output signal, makes the output audio signal maintain smooth, not only can effectively avoid overloading output power to the damage of speaker, at the same time bring the constant shock of high quality music enjoyment. The traditional NCN function is shown below in figure 7. www.awinic.com.cn COPYRIGHT ©2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 12 AW8737S Data Sheet Nov 2017 V1.1 Crack Noise Battery Voltage NCNOFF NCNON Crack Noise Battery Voltage NCNOFF Figure 7 NCNON Traditional NCN Operation Principle AW8737S adopts Awinic unique second generation NCN technology, the output signal is free from limitation of power rail. When battery voltage drops, NCN output signal will not distort, output amplitude remains unchanged, keeping constant output power, as shown in figure 8. Even if the battery voltage drops, AW8737S can still provide high quality large volume music enjoyment. Supply Rail Battery Voltage Traditional NCN function Figure 8 Constant output power Second Generation NCN funciton Second generation NCN Operation Principle Attack time Attack time is the time it takes for the gain to be attenuated -13.5dB once the audio signal exceeds the NCN threshold. Fast attack times allow the NCN to react quickly and prevent transients such as symbol crashes from being distorted. However, fast attack times can lead to volume pumping, where the gain reduction and release becomes noticeable, as the NCN cycles quickly. Slower attack times cause the NCN to ignore the fast transients, and instead act upon longer, louder passages. Selecting an attack time that is too slow can lead to increased distortion in the case of the No Clip function. According to mobile phone and portable equipment audio features, attack time of AW8737S is set to be 40ms, effectively keeping the music rhythm, and at the same time eliminating the crack distortion, protecting the speaker. Release time Release time is the time it takes for the gain to return to its normal level once the audio signal returns below the NCN threshold. A fast release time allows the NCN to react quickly to transients, preserving the original dynamics of the audio source. However, similar to a fast attack time, a fast release time contributes to volume pumping. A slow release time makes the music smooth and soft, it is better to suppress the crack distortion, but longer release time will make music sounds “boring” ,lack of impact. www.awinic.com.cn COPYRIGHT ©2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 13 AW8737S Data Sheet Nov 2017 V1.1 According to mobile phone and portable equipment audio features, release time of AW8737S is set to be 1.2s. K-Chargepump AW8737S adopts a new generation of charge pump technology:K -Chargepump structure, it has high efficiency and large driving ability, working frequency is 1.1MHz,built in soft start circuit, current limiting control loop and over-voltage-protection(OVP) loop, guaranteeing system stable and reliable operation. High Efficiency AW8737S uses K-chargepump structure,booster output voltage PVDD is 1.5 times of supply voltage VDD, the ideal efficiency can reach 100%. K-chargepump efficiency is the ratio of output power to input power, that is  POUT *100% PIN For example, in an ideal M times chargepump, the input current IIN is M times of output current IOUT,the efficiency formula can be written as:  POUT V *I V *100%  OUT OUT *100%  OUT *100% PIN VIN * M * I OUT M *VIN M is charge pump work mode variable (1.5 times), VOUT is charge pump output voltage, VIN is power supply voltage, IOUT is load current. For K-chargepump, the output voltage is 1.5 times of the input voltage, due to the charge pump internal switch loss and IC static current loss, the actual efficiency will be up to 93%. Therefore, K-chargepump booster technology can greatly improve the power efficiency. Charge Pump Structure Figure 9 is charge pump basic principle diagram, the charge pump used in AW8737S has seven switches, the output voltage PVDD is 1.5 times as input voltage VDD through seven switches timing control. S1 C1P + VDD CIN 4.7uF S6 CF1 2.2uF S4 PVDD COUT 4.7uF C1N S2 + S7 C2P CF2 2.2uF S5 S3 C2N Figure 9 Charge Pump Principle Diagram The operation of the charge pump has two phases. In Φ 1, as shown in figure 10, switches S1, S2 and S3 are closed, VDD charges to the flying capacitor CF1 CF2. www.awinic.com.cn COPYRIGHT ©2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 14 AW8737S Data Sheet Nov 2017 V1.1 S1 C1P + VDD CIN 4.7uF S6 CF1 2.2uF S4 PVDD COUT 4.7uF C1N S2 + S7 C2P CF2 2.2uF S3 S5 C2N Charging Phase Φ1: Flying Capacitor Charging Figure 10 In Φ 2, as shown in figure 11: switches S1, S2 and S3 are disconnected, switches S4, S5, S6 and S7 are closed. Because the voltage across the capacitor can't mutation, so the voltage on flying capacitor CF1 CF2, is added to the VDD, which make PVDD risen to a higher voltage. S1 C1P + VDD CIN 4.7uF S6 CF1 2.2uF S4 PVDD COUT 4.7uF C1N S2 + S7 C2P CF2 2.2uF S3 S5 C2N Discharging Phase Figure 11 Φ2: Flying capacitor charge transfer to the output capacitance COUT Soft start K-chargepump has integrated soft start function in order to limit supply power inrush current during start-up. The supply current is limited to be 350 mA, and the soft start time is 1.2 ms. Current Limitation Control K-chargepump has integrated the current limitation control loop. In normal operation, when the heavy load or a situation that make charge pump flow through very large current, the current limitation control loop will control charge pump maximum output current capacity, that is 2A. www.awinic.com.cn COPYRIGHT ©2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 15 AW8737S Data Sheet Nov 2017 V1.1 Over Voltage Protection(OVP)Control K-chargepump’s output voltage PVDD is a multiple of the input voltage VDD, which provide a high voltage rail for internal power amplifier circuits, allowing the amplifiers provide greater output dynamic range in the lithium battery voltage range, so as to realize the large volume, high quality class K audio enjoyment. K-chargepump has integrated the over voltage protection control loop, when the input voltage VDD is greater than 4V, the output voltage PVDD is no longer a multiple of VDD, but is controlled by over voltage protection(OVP) loop and is stable in 6.05V, and the hysteresis voltage is about 50mV. One-wire pulse control One wire pulse control technology only needs a single GPIO port to operate the chip, complete a variety of functions, it is very popular in the area of the GPIO port shortage and portable systems. When the control signal line is longer, because of the signal integrity or radio frequency interference problem, it will produce the narrow glitch signal. Awinic one wire pulse control technology integrated the Deglitch circuit in internal control pin, which can effectively eliminate the influence of the glitch signal, as shown in figure 12. AW8737S SHDN Deglitch Control signal with glitch Glitch is eleminated Figure 12 Awinic Deglitch function diagram The traditional one wire pulse control technology still receives pulse signal from control port when chip is startup, so when the master control chip (such as mobile phone BB) sends wrong pulse during normal operation, the system will enter into error states. AW8737S uses one wire pulse latch technology, after the master control chip has sent pulses, the state will be latched, no longer receive the latter mis-sending pulse signals, as shown in figure 13. TLATCH STATE 4 STATE 3 Traditional One Wire Pulse Control Shielding abnormal pulse signal STATE 4 STATE 3 Anti-interference One Wire Pulse Control Figure 13 Anti-interference One Wire Pulse Control Function Diagram One Wire Pulse Control AW8737S select each mode through the detection of number of the pulse signal rising edge of SHDN pin, as shown in figure 14: When SHDN pin pull high from shutdown mode, there is only a rising edge, AW8737S enter into mode 1,NCN output power is 1.2W; When high-low-high signal set to SHDN pin, www.awinic.com.cn COPYRIGHT ©2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD. 16 AW8737S Data Sheet Nov 2017 V1.1 there are two rising edges, AW8737S enter into mode 2, NCN output power is 1W; When there are three rising edges, AW8737S enter into mode 3,NCN output power is 0.8W; When there are four rising edges, AW8737S enter into mode 4,NCN function is turned off; AW8737S has four operation modes, the number of the rising edges does not allow more than four. MODE1 MODE2 MODE3 MODE4 TH TL 0.75μs
AW8737SCSR
物料型号:AW8737SCSR 器件简介:AW8737S 是一款高效能、低噪声、超低失真、恒定大音量的升级第七代Class K音频放大器,由上海艾为电子技术股份有限公司生产。
引脚分配:该芯片有14个引脚,包括正负音频输入端、电源、地、输出端以及控制引脚等。
参数特性:具有80%的功率放大器整体效率,超低失真0.008%,噪声水平53μV,高PSRR:-68dB(217Hz),ESD保护:±6kV (HBM)。
功能详解:新世代K-Chargepump技术,效率高达93%;集成的NCN技术防止输出功率随锂电池电压降低而下降;TDD-Noise抑制技术和EMI抑制技术有效抑制干扰;内置过流、过热和短路保护功能。
应用信息:适用于智能手机,提高音质,延长手机使用时间,防止通话过程中音量变小。
封装信息:采用小型0.4mm间距1.6mm×1.68mm CSP-14封装。
以上信息摘自AW8737S数据手册,其中包含了详细的技术规格、应用电路图、订购信息、封装描述以及热性能参数等。
AW8737SCSR 价格&库存
很抱歉,暂时无法提供与“AW8737SCSR”相匹配的价格&库存,您可以联系我们找货
