XARR-03VF
XARR-03VF
    JST
    P=2.5mm
    1X3P 2.5MM
XARR-03VF 数据手册
XA CONNECTOR 2.5mm pitch/Disconnectable Crimp style wire-to-wire connectors Specifications ––––––––––––––––––– • Current rating: 3A AC, DC max. (AWG #20) • Voltage rating: 250V AC, DC max. • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/10m Ω max. After environmental testing/20m Ω max. • Insulation resistance: 500M Ω min. • Withstanding voltage: 1,500V AC/minute • Applicable wire: AWG #28 to #20 * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. 2.5mm pitch wire-to-wire connector that can mate with the socket of XA connector (board-to-wire type). Reliable secondary retainer is available. Panel mount is applicable. • Possible to mate with the existing XA socket • Inner type contact lance • Mountable on a variety of panels • Secondary retainer • Secure lock construction Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 2 R9851220 Panel layout and Assembly layout (7.1) Without panel locks D ±0.05 C +0.1 0 (22.7) (7.1) With panel locks 4.65 ±0.05 6.7 +0.1 0 (22.7) Note: C and D dimensions: Refer to receptacle housing. 1 XA CONNECTOR Contact Pin contact Socket contact 1.9 1.9 15.1 6.5 6.6 4.8 2.9 0.8 1.3 1.6 2.4 2.3 1.3 3.1 Model No. Pin contact Socket contact SXAM-001T-P0.6 SXA-001T-P0.6 SXAM-01T-P0.6 SXA-01T-P0.6 mm2 Applicable wire AWG # Insulation O.D.(mm) Pin contact Q'ty / reel Socket contact 0.08∼0.33 28∼22 0.8∼1.9 7,000 8,000 0.22∼0.5 24∼20 1.5∼1.9 7,000 8,000 Material and Finish Phosphor bronze, tin-plated (reflow treatment) RoHS compliance Note: Contact JST for gold-plated products. Crimping machine Crimp applicator Contact  MKS-L SXA-001T-P0.6 AP-K2N SXA-01T-P0.6 *MKS-SC  MKS-L *MKS-SC Applicator Dies Crimp applicator with dies MK/SXAM/XA-001-06 APLMK SXAM/XA001-06 SC/SXAM/XA-001-06 APLSC SXAM/XA001-06 MK/SXAM/XA-01-06 APLMK SXAM/XA01-06 SC/SXAM/XA-01-06 APLSC SXAM/XA01-06 Contact  MKS-L SXAM-001T-P0.6 AP-K2N SXAM-01T-P0.6 Applicator Dies Crimping machine Crimp applicator Crimp applicator with dies MK/SXAM/XA-001-06 APLMK SXAM/XA001-06 *MKS-SC SC/SXAM/XA-001-06 APLSC SXAM/XA001-06  MKS-L MK/SXAM/XA-01-06 APLMK SXAM/XA01-06 *MKS-SC SC/SXAM/XA-01-06 APLSC SXAM/XA01-06 Note: *Strip-crimp applicator Receptacle housing (for pin contact) Circuits Without panel locks 2 3 8 4 7 5 6 6 J S A B 5 4 T H J S T H 7 8 8 2 2.5 3 8 9 10 1 11 Circuit No.1 identification 12 13 21.6 14 15 Model No. Without panel locks With panel locks XARR-02VF XARR-02V XARR-03VF XARR-03V XARR-04VF XARR-04V XARR-05VF XARR-05V XARR-06VF XARR-06V ― XARR-07V XARR-08VF XARR-08V XARR-09VF XARR-09V XARR-10VF XARR-10V ― XARR-11V XARR-12VF XARR-12V ― XARR-13V ― XARR-14V ― XARR-15V A Dimensions (mm) B C D 2.5 7.5 7.9 11.2 1,000 5.0 10.0 10.4 13.7 1,000 7.5 12.5 12.9 16.2 1,000 10.0 15.0 15.4 18.7 1,000 12.5 17.5 17.9 21.2 500 15.0 20.0 20.4 23.7 500 17.5 22.5 22.9 26.2 500 20.0 25.0 25.4 28.7 500 22.5 27.5 27.9 31.2 500 25.0 30.0 30.4 33.7 500 27.5 32.5 32.9 36.2 500 30.0 35.0 35.4 38.7 500 32.5 37.5 37.9 41.2 500 35.0 40.0 40.4 43.7 500 Material With panel locks PA 66, UL94V-0, natural (white) RoHS compliance Note: C and D dimensions: Panel layout dimensions 8 7 6 S A B J 4 T 8 3 8 2 2.5 5 H J S T H (3.2) 1 Circuit No.1 identification (14.0) 21.6 2 Q'ty / bag XA CONNECTOR Plug housing (for socket contact) Circuits Standard type XAP-02V-1 XAP-03V-1 XAP-04V-1 XAP-05V-1 XAP-06V-1 XAP-07V-1 XAP-08V-1 XAP-09V-1 XAP-10V-1 XAP-11V-1 XAP-12V-1 XAP-13V-1 XAP-14V-1 XAP-15V-1 2 3 Circuit No.1 identification 9.5 4 (2.4) 5 H JST 6 7 2.5 1 Circuit No. Dimensions (mm) Model No. Standard type 2 8 3 9 10 A B 4 11 5 12 6 13 14 7 15 Retainer mountable type XARP-02V XARP-03V XARP-04V XARP-05V XARP-06V XARP-07V XARP-08V XARP-09V XARP-10V XARP-11V XARP-12V XARP-13V XARP-14V XARP-15V Q'ty / bag Retainer Standard mountable type type A B 2.5 7.3 1,000 1,000 5.0 9.8 1,000 1,000 7.5 12.3 1,000 1,000 10.0 14.8 1,000 1,000 12.5 17.3 1,000 1,000 15.0 19.8 1,000 1,000 17.5 22.3 1,000 1,000 20.0 24.8 1,000 1,000 22.5 27.3 1,000 1,000 25.0 29.8 1,000 1,000 27.5 32.3 1,000 1,000 30.0 34.8 1,000 1,000 32.5 37.3 500 1,000 35.0 39.8 500 1,000 8 Material PA 66, UL94V-0, natural (white) Retainer mountable type RoHS compliance Circuit No.1 identification H JST 1 Circuit No. (2.4) 2.5 10.5 2 3 B A 4 5 6 7 8 Retainer Circuits 2 3 4 5 6 7 A 8 9 2.5 10 11 12 2.5 7.8 0.95 13 14 15 Model No. XMS-02V XMS-03V XMS-04V XMS-05V XMS-06V XMS-07V XMS-08V XMS-09V XMS-10V XMS-11V XMS-12V XMS-13V XMS-14V XMS-15V A Q'ty / bag 2.5 1,000 5.0 1,000 7.5 1,000 10.0 1,000 12.5 1,000 15.0 1,000 17.5 1,000 20.0 1,000 22.5 1,000 25.0 1,000 27.5 1,000 30.0 1,000 32.5 1,000 35.0 1,000 Material Glass-filled PA 66, UL94V-0, natural (ivory) RoHS compliance 3
XARR-03VF
1. 物料型号:文档列出了XA系列连接器的型号,例如SXAM-001T-P0.6和SXA-01T-P0.6,以及它们适用的电线规格和绝缘外径。
2. 器件简介:XA系列连接器是2.5mm间距的线对线连接器,可与XA系列插座(板对线类型)的插座配合使用。具有可靠的二次保持器,适用于面板安装。
3. 引脚分配:文档提供了针脚接触和插座接触的型号,以及适用的电线规格和绝缘外径。
4. 参数特性:包括电流额定值、电压额定值、温度范围、接触电阻、绝缘电阻和耐电压等。
5. 功能详解:文档描述了连接器的锁定结构和可能的配合情况。
6. 应用信息:提供了连接器的适用电线规格(AWG #28 至 #20)和符合RoHS标准的信息。
7. 封装信息:包括了连接器的尺寸、材料和完成类型,例如磷青铜镀锡(回流处理)和RoHS合规性。
8. 标准和认证:文档列出了连接器符合的国际标准和认证,如E60389和LR20812。
9. 面板布局和组装布局:提供了连接器在没有面板锁和有面板锁时的尺寸信息。
10. 材料:连接器的主体材料是PA 66,UL94V-0,自然色(白色),并符合RoHS标准。
XARR-03VF 价格&库存
很抱歉,暂时无法提供与“XARR-03VF”相匹配的价格&库存,您可以联系我们找货
XARR-03VF
    库存:6000
