ZE05-24DP-2H
ZE05-24DP-2H
    HRS(广濑)
    SMD,P=2mm,卧贴
    线对板针座 卧贴 间距:2mm
ZE05-24DP-2H 数据手册
APPLICABLE STANDARD OPERATING TEMPERATURE RANGE -40 C TO 2 60 V △ Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents. RATING VOLTAGE CURRENT ITEM CONSTRUCTION STORAGE TEMPERATURE RANGE +125 C AC/DC + 60C (1) RELATIVE HUMIDITY 85% MAX STORAGE HUMIDITY RANGE (NOT DEWED) 2 2 A 2 SPECIFICATIONS TEST METHOD GENERAL EXAMINATION MARKING -10 C TO REQUIREMENTS VISUALLY AND BY MEASURING INSTRUMENT. CONFIRMED VISUALLY. QT AT ACCORDING TO DRAWING. × × × × 10 mΩ MAX . 10 mΩ MAX . × × - - ELECTRIC CHARACTERISTICS CONTACT RESISTANCE CONTACT RESISTANCE MILLIVOLT LEVEL METHOD INSULATION RESISTANCE 1A DC. 10 mV AC MAX, 500 V DC. 100 MΩ MIN. × - VOLTAGE PROOF 1000 V AC FOR 1 min. NO FLASHOVER OR BREAKDOWN. × - ① CONTACT RESISTANCE: 20 m MAX. ② NO DAMAGE, CRACK AND LOOSENESS OF PARTS. × × - - ① NO ELECTRICAL DISCONTINUITY OF 7MIN , 1s MIN. ② CONTACT RESISTANCE: 20 m MAX. ③ NO DAMAGE, CRACK AND LOOSENESS OF PARTS. ① NO ELECTRICAL DISCONTINUITY OF 7MIN , 1s MIN. ② NO DAMAGE, CRACK AND LOOSENESS OF PARTS. × × × - - - × - × - ① 100N MIN. × - ① CONTACT RESISTANCE: 20 m MAX. ② INSULATION RESISTANCE:100 M MIN. ③ NO DAMAGE, CRACK AND LOOSENESS OF PARTS. ① CONTACT RESISTANCE: 20 m MAX. ② NO DAMAGE, CRACK AND LOOSENESS OF PARTS. × × × - - - × × - - ① CONTACT RESISTANCE: 20 m MAX. ② NO DAMAGE, CRACK AND LOOSENESS OF PARTS. ① CONTACT RESISTANCE: 20 m MAX. ② NO DAMAGE, CRACK AND LOOSENESS OF PARTS. ① CONTACT RESISTANCE: 20 m MAX. × × - - × × - - × - NO PLATING PEELING OF THE TERMINALS, MELTINGS OF HOUSINGS. A NEW UNIFORM COATING OF SOLDER SHALL COVER A MINIMUM OF 95 % OF THE SURFACE BEING IMMERSED. × - × - 0.1 mA(DC OR 1000Hz) MECHANICAL CHARACTERISTICS MECHANICAL OPERATION 30 TIMES INSERTIONS AND EXTRACTIONS. VIBRATION FREQUENCY 20 TO 200Hz (88m/s ) SWEEP TIME 3min.(ROUND TRIP) AT 3h FOR 3 DIRECTIONS. SHOCK 981m/s DURATION OF PULSE 6ms AT 3 TIMES FOR 6 DIRECTIONS. 2 2 LOCK STRENGTH MEASURE BREAK STRENGTH OF THE LOCK BY PULLING THE CONNECTOR IN THE MATING DIRECTION. ENVIRONMENTAL CHARACTERISTICS 90 ~ 95 %, DAMP HEAT (STEADY STATE) EXPOSED AT 60 C, RAPID CHANGE OF TEMPERATURE DRY HEAT TEMPERATURE- 40 →ROOM TEMP →125C→ ROOM TEMP TIME 30 → 5 → 30 → 5 min UNDER 1000 CYCLES. EXPOSED AT 140C, 120 h. COLD EXPOSED AT -40C , 120 h. RESISTANCE TO SO2 GAS EXPOSED IN 25 PPM AT 75% MIN FOR 96h. RESISTANCE TO SOLDERING HEAT SOLDERABILITY REFLOW TEMP. OVER 260C , 10sec. PREHEAT 180CMAX , 120sec. SOLDERED AT SPECIFIED TEMPERATURE PROFILE. COUNT 2 1 △ REMARK (NOTE1) 96 h. DESCRIPTION OF REVISIONS DESIGNED DIS-T-00006023 YH.MAMADA APPROVED "STORAGE" means a long-term storage state for the unused product before assembly to PCB. Note QT:Qualification Test AT:Assurance Test FORM HD0011-2-1 CHECKED X:Applicable Test PART NO. HIROSE ELECTRIC CO., LTD. CODE NO. HH.TSUKUMO HK.UMEHARA 20200407 20171106 CHECKED HK.UMEHARA 20171106 DESIGNED YH.MAMADA 20171106 DRAWN MN.SATOH 20171102 DRAWING NO. SPECIFICATION SHEET DATE ELC-368633-00-00 ZE05-24DP-2H CL752-2107-0-00 2 1/1
ZE05-24DP-2H 价格&库存
很抱歉,暂时无法提供与“ZE05-24DP-2H”相匹配的价格&库存,您可以联系我们找货
ZE05-24DP-2H
    • 1+18.83520
    • 10+18.39240
    • 30+18.10080
    库存:16
    ZE05-24DP-2H
    • 300+20.14177300+2.61338
    • 600+19.18065600+2.48868
    • 900+18.63991900+2.41852
    • 1500+17.980541500+2.33296
    • 2100+17.559022100+2.27827
    • 3000+17.123123000+2.22171
    库存:276
