DATA SHEET
WIRELESS COMPONENTS
Ceramic Chip Antenna
ANT1005LL14R2400A
2.4 - 2.5GHZ
Product Specification – February 14, 2017 V. 0
1005 Series
Product specification
WIRELESS COMPONENTS
FEATURES
Compact size
Omni-directional Radiation
Tape & reel automatic
mounting
Reflow process compatible
RoHS compliant
APPLICATIONS
2.4GHz WiFi device
Bluetooth gadget
Zigbee device
ISM band equipment
2
7
ORDERING INFORMATION
All part numbers are identified by the series, packing type, material, size,
antenna type, working frequency and packing quantity.
PART NUMBER
ANT 1005 L L14 R 2400A
(1)
(2)
(3) (4)
(5)
(6)
(1) PRODUCT
ANT = Antenna
(2) SIZE
1005 = 1.0 × 0.5 mm
(3) ANTENNA TYPE
L,F,A = Chip Antenna
(4) SERIAL NO.
L14
(5) PACKING STYLE
R = Tape and Reel
(6) WORKING FREQUENCY
2400 = 2.4GHz
www.yageo.com
Feb. 14, 2017 V.0
WIRELESS COMPONENTS
3
7
SPECIFICATION
Table 1
VALUE
DESCRIPTION
Working Frequency
2.4 ~ 2.484 GHz
Bandwidth
120 MHz(Typ.)
VSWR
3.0 Max
Polarization
Linear
Azimuth Beamwidth
Omni-directional
Peak Gain
2.21 dBi(Typ.)
Impedance
50 Ω
Operating Temperature
- 40~105 ℃
Maximum Power
1W
Termination
Ag (Environmentally-Friendly Leadless)
Resistance to Soldering Heats
260℃ , 5sec.
NOTE
1. The specification is defined on Yageo evaluation board
DIMENSIONS
Table 2 Mechanical Dimension
L (mm)
W (mm)
T (mm)
P1 (mm)
P2 (mm)
P3 (mm)
P4 (mm)
DIMENSION
1.0 ±0.10
0.5 ±0.10
0.37(max)
0.25 +0.1/-0.05
0.15 +0.1/-0.05
0.25 +0.1/-0.05
0.15 +0.1/-0.05
OUTLINES
TOP
BOTTOM
Table 3 Termination configuration
TERMINAL NAME
FUNCTION
P1
Ground Point
P2
Ground Point
P3
Feeding Point
P4
Feeding Point
TOP
Fig. 1 Antenna outlines
BOTTOM
www.yageo.com
Feb. 14, 2017 V.0
WIRELESS COMPONENTS
4
7
REFERENCE DESIGN OF EVALUATION BOARD
Fig. 2 Outlook and dimension of evaluation board
Unit:mm
Fig. 3 Footprint
www.yageo.com
Feb. 14, 2017 V.0
WIRELESS COMPONENTS
5
7
Fig. 4 Details of soldering Pad
www.yageo.com
Feb. 14, 2017 V.0
WIRELESS COMPONENTS
6
7
ELECTRICAL PERFORMANCES
Fig. 5 Return loss
Evaluation board and XYZ direction
Max Gain = 2.21dBi
Efficiency = 70.3%
Fig. 6 Radiation pattern
www.yageo.com
Feb. 14, 2017 V.0
WIRELESS COMPONENTS
7
7
REVISION HISTORY
REVISION DATE
CHANGE NOTIFICATION
Version 0
Feb. 14, 2017
DESCRIPTION
New data sheet for SMD type antenna, 2.45GHz application, 1005
series PIFA mode
www.yageo.com
Feb. 14, 2017 V.0
很抱歉,暂时无法提供与“ANT1005LL14R2400A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10000+0.6695810000+0.08588
- 20000+0.6343420000+0.08136
