SUHR-06V-S
SUHR-06V-S
    JST
    P=0.8mm
    1X6P 0.8MM
SUHR-06V-S 数据手册
Emboss Tape SUH CONNECTOR 0.8mm pitch/Disconnectable Crimp style connectors • SUR header in common use • Current rating 1.0 A • Miniaturization Specifications ––––––––––––––––––– This SUH connector is developed for crimping type SUR connector that has been designed for 0.8 mm pitch wire-toboard insulation displacement connector. This connector adopted the first crimping method in a minimum 0.8 mm pitch of the wire-to-board type connector. Housing lance method provides the good workability and a constriction contact method provides the excellent contact reliability. • Current rating: 1.0 A AC, DC (AWG #28) • Voltage rating: 30 V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 30 mΩ max. After environmental tests/ 50 mΩ max. • Insulation resistance: 100 MΩ min. • Withstanding voltage: 200 VAC/minute • Applicable wire: Conductor size/ AWG #32 to #28 Insulation O.D./ 0.5 to 0.6 mm * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 PC board layout and Assembly layout Top entry type Side entry type 1.95 1.65 ±0.1 1.2 ±0.1 ±0.1 0.7 0.8 ±0.05 0.3 Connector outline 0.5 ±0.05 1.75 1.65 2.3 ±0.1 2.7 0.8 ±0.05 Connector outline 2.2 0.7 ±0.1 1.2 ±0.1 0.35 ±0.1 1.1 ±0.05 ±0.1 0.5 1.7 ±0.1 2.75 4.15 1.7 1 ±0.1 ±0.1 4.1 Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ±0.03 mm for all centers. The dimensions above should serve as a guideline. Contact JST for details. Contact Model No. 2.52 Applicable wire AWG# Insulation O.D. (mm) mm2 SSUH-003T-P0.15 0.032∼0.08 32∼28 Q'ty/ reel 0.5∼0.6 45,000 1.45 0.39 0.7 Material and Finish 0.75 Phosphor bronze, tin-plated (reflow treatment) 0.83 RoHS compliance Contact Crimping machine Crimp applicator SSUH-003T-P0.15 AP-K2N MKS-L-10-4 − Applicator Dies − Note: Contact JST for fully automatic crimping applicator. 1 Crimp applicator with dies MK/SSUH-003-015 APLMK SSUH003-015 − SUH CONNECTOR Housing With protrusions C 1.65 A 1.4 0.8 Circuit No.1 SUHR-02V-S-B SUHR-02V-S SUHR-03V-S-B SUHR-03V-S SUHR-04V-S-B SUHR-04V-S SUHR-05V-S-B SUHR-05V-S SUHR-06V-S-B SUHR-06V-S 1.7 3.1 SUHR-08V-S-B 1.25 0.8 B 4.4 9.2 SUHR-10V-S-B SUHR-10V-S SUHR-12V-S-B SUHR-12V-S SUHR-14V-S-B SUHR-14V-S SUHR-16V-S-B SUHR-16V-S 10.8 SUHR-17V-S-B SUHR-20V-S-B Without protrusions A SUHR-20V-S 1.65 Circuit No.1 1.7 3.1 RoHS compliance 0.8 1.25 B Shrouded header Top entry type 2 2.7 B 0.6 A 1 Side entry type B BM02B-SURS-TF SM02B-SURS-TF BM03B-SURS-TF SM03B-SURS-TF BM04B-SURS-TF SM04B-SURS-TF BM05B-SURS-TF SM05B-SURS-TF BM06B-SURS-TF SM06B-SURS-TF BM08B-SURS-TF SM08B-SURS-TF BM10B-SURS-TF SM10B-SURS-TF BM12B-SURS-TF SM12B-SURS-TF BM14B-SURS-TF SM14B-SURS-TF BM16B-SURS-TF SM16B-SURS-TF BM17B-SURS-TF SM17B-SURS-TF BM20B-SURS-TF SM20B-SURS-TF A 0.8 2.7 1.75 Circuit No.1 1 0.2 RoHS compliance This product displays (LF)(SN) on a label. Note: These products listed above are supplied on embossed-tape. 1 0.45 2
SUHR-06V-S 价格&库存
很抱歉,暂时无法提供与“SUHR-06V-S”相匹配的价格&库存,您可以联系我们找货
SUHR-06V-S
  • 1+4.280671+0.55542
  • 10+3.6694510+0.47611
  • 25+3.4381625+0.44610
  • 50+3.2741850+0.42483
  • 100+3.11861100+0.40464
  • 250+2.92248250+0.37919
  • 500+2.78280500+0.36107
  • 2000+2.523322000+0.32740
  • 4000+2.402864000+0.31177
SUHR-06V-S
    库存:1621
    SUHR-06V-S
      • 1+2.203411+0.28589
      • 10+2.1424510+0.27798
      • 50+1.5937750+0.20679
      • 100+1.22799100+0.15933
      • 500+1.15832500+0.15029
      • 1000+1.106061000+0.14351
      • 2000+1.071222000+0.13899
      库存:610
