Technical Data Sheet
RF_35/09.14/6.2
Dieses Dokument ist urheberrechtlich geschützt ● This document is protected by copyright ● Rosenberger Hochfrequenztechnik GmbH & Co. KG
Rosenberger
HSD®
RIGHT ANGLE PLUG
FOR PCB
D4S20G-400A5-Y
f
All dimensions are in mm; tolerances according to ISO 2768 m-H
EMC-screening must be assured by chassis compartment. Control box manufacturer is responsible for EMCscreening.
Interface
According to
RN_059-01
Documents
Assembly instruction
Panel piercing
Pinning instruction
Test specification
D4V013
MB_261
RN_053-01
RN_061-01
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.de
Tel. : +49 8684 18-0
Email : info@rosenberger.de
Page
1/4
Rosenberger
HSD®
RIGHT ANGLE PLUG
FOR PCB
D4S20G-400A5-Y
Material and plating
RF_35/09.14/6.2
Connector parts
Center contact
Outer contact (Interface)
Outer contact (PCB)
Cover
Dielectric
Housing
Material
Spring bronze
Brass
Zinc Alloy
Alpaca
LCP
PA 6T/66
Plating
Gold, 0.15 µm (Interface)
Tin, 0.5-2 µm (PCB)
Nickel, 3-6 µm
Tin, 2-5 µm, over nickel 1-5 µm
Electrical data
Impedance, differential mode
Frequency
Return loss
Insertion loss
Skew (between signal contacts)
Nearend-Crosstalk
Farend-Crosstalk
Insulation resistance
Signal contact resistance
Outer contact resistance
Test voltage
Working voltage
Power current
RF-leakage (shielding effectiveness)
100 differential signalling, for one pair or quad cable shielded
DC to 2.0 GHz
20 dB, DC to ≤ 1 GHz
17 dB, > 1 GHz to ≤ 2 GHz
0.1 dB @ 1.0 GHz
5 psec
30 dB
35 dB
1x103 M
10 m
7.5 m
250 V rms
100 V rms
1.5 A DC
75 dB up to 1 GHz (IEC 62153-4-7)
65 dB up to 2 GHz (IEC 62153-4-7)
Mechanical data
Mating cycles
Engagement force
Disengagement force
Retention force latch
Coding efficiency
25
30
5
110
80
N
N
N
N
Environmental data
Temperature range
Thermal shock
Temperature and humidity
Vibration (Random)
Mechanical shock
High-Temp. Exposure
Soldering profile
RoHS
-40°C to +105°C
DIN IEC 60068-2-14 Test NA
USCar 2 – 4 5.6.2
DIN IEC 60068-2-64
DIN IEC 60068-2-27
DIN IEC 60068-2-2
acc. to IEC 60068-2-58; Group 3&4
compliant
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.de
Page
2/4
Rosenberger
HSD®
RIGHT ANGLE PLUG
FOR PCB
D4S20G-400A5-Y
Packing
Standard
175 pcs in tape & reel
1050 pcs (175 pcs in tape & reel, 6 reels in box)
8.6 g
RF_35/09.14/6.2
Weight
g
Coding
Part number has to be accomplished by codification
Coding
Plug
Colour
RAL
Part-Number
A
black
sim. 9005
D4S20G-400A5-A
B
white
sim. 9001
D4S20G-400A5-B
C
blue
sim. 5005
D4S20G-400A5-C
D
bordeaux
sim. 4004
D4S20G-400A5-D
E
green
sim. 6002
D4S20G-400A5-E
F
brown
sim. 8011
D4S20G-400A5-F
Z
waterblue
sim. 5021
D4S20G-400A5-Z
Colour
RAL
Part-Number
G
grey
sim. 7031
D4S20G-400A5-G
H
violet
sim. 4003
D4S20G-400A5-H
J
beige
sim. 1001
D4S20G-400A5-J
O
light green
sim. 6027
D4S20G-400A5-O
Coding for special use
Control box manufacturer is responsible for pinning
Coding
Plug
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.de
h
Page
3/4
Rosenberger
HSD®
RIGHT ANGLE PLUG
FOR PCB
D4S20G-400A5-Y
RF_35/09.14/6.2
Change History
Rev.
Date
Change
f00
09.05.16
Note “Suction face Ø4.5” changed to “(Suction face Ø4.5)”
g00
02.06.16
h00
07.12.20
Bundle size changed from “1200 pcs in box (6 X 200 pcs in blister tray)”
To “1050 pcs in box (6 x 175 pcs/reel)”
Coding J added
While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on
our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our
products, we reserve the right to make changes judged to be necessary.
Draft
Date
Approved
Date
Rev.
Engineering change number
Name
Date
R. Bippus
11.06.07
T. Georg
07.12.20
h00
20-2333
M. Jacobs
07.12.20
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.de
Page
4/4
很抱歉,暂时无法提供与“D4S20G-400A5-C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+85.92480
- 175+34.29000
- 525+33.14520
- 1050+32.57280
- 国内价格 香港价格
- 1+149.888261+19.41578
- 10+127.3681710+16.49864
- 25+119.3910825+15.46532
- 50+113.6920650+14.72710
