FFC2A32-10-T
FFC2A32-10-T
    GCT
    SMD,P=0.5mm
    FPC/FFC连接器 间距:0.50mm 10Pin 抽屉式 立贴
FFC2A32-10-T 数据手册
PRODUCT SPECIFICATION Part Number Product Description Doc Number FFC2XXX Rev E 0.5mm Pitch ZIF FPC 0.5mm FFC Spec Prepared CC Checked Page 1 Approved Side Entry (Back Flip Type Actuator) Side Entry (Front Flip Type Actuator) Side Entry (Back Flip Type Actuator with Ear Lock)   09/09/22 Side Entry (Slide Actuator) Top Entry   VJ Date     www.gct.co   YR PRODUCT SPECIFICATION Part Number Product Description Doc Number FFC2XXX Rev E 0.5mm Pitch ZIF FPC 0.5mm FFC Spec Prepared CC Checked VJ Date 09/09/22 Page 2 Approved YR 1.0 SCOPE.   This specification covers performance, tests and quality requirements for 0.5mm Pitch ZIF FPC Connector     2.0 APPLICABLE DOCUMENTS. EIA-364 Electronics Industries Association     3.0 REQUIREMENTS. 3.1 Design and Construction Product shall be of design, construction and physical dimensions specified on applicable product drawing.     3.2 Materials and Finish 3.2.1 Housing: Specified on product drawing 3.2.2 Actuator: Specified on product drawing 3.2.3 Contact: High performance copper alloy (phosphor bronze) Finish: (a) Finish: see ordering grid (b) Under-plate: Nickel-plated all over 3.2.4 Fitting Nail: Brass, Tin-plated overall 3.3 Ratings 3.3.1 Voltage rating: Specified on product drawing 3.3.2 Current rating: Specified on product drawing 3.3.3 Operating Temperature Range: -25°C to +85°C             www.gct.co   PRODUCT SPECIFICATION Part Number Product Description Doc Number FFC2XXX Rev E 0.5mm Pitch ZIF FPC 0.5mm FFC Spec Prepared CC Checked VJ Date 09/09/22 Page 3 Approved YR 4.0 PERFORMANCE. Item Test Condition Requirement Examination of Product Visual, dimensional and functional per applicable quality inspection plan. Product shall meet requirements of applicable product drawing and specification. Item Test Condition Requirement Low-signal Level Contact Resistance Mate connectors, measure by dry circuit, 20mV Max., 100mA Max, in accordance with EIA-364-23. As specified on product drawing Insulation Resistance Unmated connectors, apply 500 V DC between adjacent terminals, in accordance with EIA-364-21. 50 MΩ Min. Dielectric Withstanding Voltage Test between adjacent contacts of unmated connectors, in accordance with EIA-364-20. 250 VAC Min. at sea level for 1 minute. No discharge, flashover or breakdown. Current leakage: 0.5 mA max. Temperature Rise Mate connector: measure the temperature rise at rated current after: 0.5 A/Power contact. The temperature rise above ambient shall not exceed 30°C The ambient condition is still air at 25°C In accordance with EIA-364-70, Method 2. 30°C Max. Change allowed 4.1 Electrical Performance. 4.2 Mechanical Performance. Item Test Condition Requirement Durability The sample should be mounted in the tester and fully mated and unmated the number of cycles specified at the rate of 10±3mm/min. In accordance with EIA-364-09. 20 Cycles Min. FPC Retention Force Insert the actuator, pull the FPC at the speed rate of 10±3 mm/min. Refer to FPC withdrawal force Refer to paragraph 7         www.gct.co   PRODUCT SPECIFICATION Part Number Product Description Doc Number FFC2XXX E 0.5mm Pitch ZIF FPC 0.5mm FFC Spec Prepared CC Checked VJ Date 09/09/22 Page 4 Approved Item Test Condition Requirement Repeated Actuator Insertion/Withdrawal Insert and withdraw actuator up to 20 cycles at the speed rate of less than 10 cycles/minute. Appearance: No Damage LLCR: As specified on product drawing Terminal/Housing Retention Force Apply axial pull out force at the speed rate of 10±3 mm/minute. On the terminal assembled in the housing. 0.15kgf Min. Fitting Nail/Housing Retention Force Vibration Shock (Mechanical)   Rev   Apply axial pull out force at the speed rate of 10± 3 mm/minute. On the fitting nail assembled in the housing. The electrical load condition shall be 100 mA maximum for all contacts. Subject to a simple harmonic motion having amplitude of 0.76mm (1.52mm maximum total excursion) in frequency between the limits of 10 and 55 Hz. The entire frequency range, from 10 to 55 Hz and return to 10 Hz, shall be traversed in approximately 1 minute. This motion shall be applied for 2 hours in each of three mutually perpendicular directions. In accordance with EIA-364-28, Condition I. Subject mated connectors to 50 G’s (peak value) half-sine shock pulses of 11 milliseconds duration. Three shocks in each direction shall be applied along the three mutually perpendicular axes of the test specimen (18 shocks). The electrical load condition shall be 100mA maximum for all contacts. In accordance with EIA-364-27, test condition A.     www.gct.co   0.01kgf Min. Appearance: No Damage LLCR: 60 mΩ Max. Discontinuity: 1 u sec Max. Appearance: No Damage LLCR: 60 mΩ Max. Discontinuity: 1 u sec Max. YR PRODUCT SPECIFICATION Part Number Product Description Doc Number FFC2XXX Rev E 0.5mm Pitch ZIF FPC 0.5mm FFC Spec Prepared CC VJ Checked Date 09/09/22 Page 5 Approved YR 4.3 Environmental Performance. Item Test Condition Requirement Resistance to Reflow Soldering Heat Pre Heat: 150°C ~180°C, 60~90sec. Heat: 230°C Min., 40sec Min. Peak Temp.: 260°C Max, 10sec Max. No Damage Resistance to Hand Soldering Heat Soldering iron:350±10°C Duration:3~4 sec. No Damage Thermal Shock Mate module and subject to follow condition for 5 cycles. 1 cycles: -40 +0/3 °C, 30 minutes +85 +3/-0 °C, 30 minutes In accordance with EIA-364-32, test condition A. Appearance: No Damage LLCR: 60 mΩ Max. Discontinuity: 1 u sec Max. Mated Connector 40°C, 90~95% RH, Refer to Method II. In accordance with EIA-364-31, test condition A. Appearance: No Damage LLCR: 60 mΩ Max. Insulation Resistance: 50MΩ Min. Dielectric Withstanding Voltage: No discharge, flashover or breakdown. Current leakage: 0.5 mA max. Humidity Temperature Life SO2 Gas Salt Spray Solderability Subject mated connectors to temperature life at 85°C for 96 hours. Measure Signal. In accordance with EIA-364-17, test condition A. Mate applicable FPC and expose them to the following SO2 gas atmosphere. Temperature: 40±2°C Gas Density: 50±5 ppm Duration: 24 hours Subject mated/unmated connectors to 5% salt-solution concentration, 35°C for 48 hours. In accordance with EIA-364-26, test condition B. Subject the test area of contacts into the flux for 5-10 sec. And then into solder bath, Temperature at 245 ±5°C, for 4-5 sec. In accordance with EIA-364-52. Test report available on request Appearance: No Damage LLCR: 60 mΩ Max. Appearance: No Damage LLCR: 60 mΩ Max. Appearance: No Damage LLCR: 60 mΩ Max. Solder able area shall have minimum of 95% solder coverage. See product drawing Note. Flowing Mixed Gas shall be conducted upon customer request, costs may apply.         www.gct.co   PRODUCT SPECIFICATION Part Number Product Description Doc Number FFC2XXX Rev E 0.5mm Pitch ZIF FPC 0.5mm FFC Spec Prepared CC Checked 5.0 INFRA RED REFLOW CONDITION. 5.1 Lead-Free Process: Duration = 2 times         www.gct.co   VJ Date 09/09/22 Page 6 Approved YR PRODUCT SPECIFICATION Part Number Product Description Doc Number FFC2XXX Rev E 0.5mm Pitch ZIF FPC 0.5mm FFC Spec CC Prepared VJ Checked Date 09/09/22 Page 7 Approved 6.0 PRODUCT QUALIFICATION AND TEST SEQUENCE. Test or Examination Examination of Product Low-signal Level Contact Resistance Insulation Resistance Dielectric Withstanding Voltage Temperature Rise Test Group 5 6 7 8 Test Sequence 1 2 3 4 1,3 1,7 1,6 1,5 1,9 1,5 2,6 2,5 2,4 2,8 2,4 1,3 1,4 9 10 11 12 1,3 1,6 1,3 1,3 2,5 3,7 4,6 2 Durability 4 Vibration 3 Shock (Mechanical) 4 Thermal Shock 3 Humidity 5 Temperature Life 3 2 SO2 Gas Salt Spray 3 Solderability 2 Repeated Actuator Insertion/Withdrawal 2 FPC Retention Force 3 Terminal / Housing Retention Force Fitting Nail / Housing Retention Force Resistance to Soldering Heat Resistance to Hand Soldering Heat Sample Size   4 5 2 2 2   5 5 5 5     5 www.gct.co 5   5 5 5 5 5 YR PRODUCT SPECIFICATION Part Number Product Description Doc Number FFC2XXX Rev E 0.5mm Pitch ZIF FPC 0.5mm FFC Spec Prepared CC Checked VJ Date 09/09/22 Page 8 Approved 7.0 FPC WITHDRAWAL FORCE. No. Of Ckt. 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37     Withdrawal Force (Min) 0.3Kgf 0.5Kgf 1.0Kgf 1.5Kgf     No. Of Ckt. 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 www.gct.co   Withdrawal Force (Min) 1.5Kgf 2.0Kgf YR PRODUCT SPECIFICATION Part Number Product Description Doc Number FFC2XXX Rev E 0.5mm Pitch ZIF FPC 0.5mm FFC Spec Prepared CC Checked VJ Date 09/09/22 Page 9 Approved Revision Details: Revision Information Page Release Date A Specification Released - 16/06/2010 B Leaded temperature profile removed 6 26/11/2015 1,2 10/09/2019 1,8 18/02/2020 2,3,5 09/09/2022 C D Add back flip type & Change LLCR specification from 20mΩ max. to 40mΩ max. Add back flip with ear lock type & update FPC Retention Force E Update wording in Requirements           www.gct.co   YR
FFC2A32-10-T 价格&库存
很抱歉,暂时无法提供与“FFC2A32-10-T”相匹配的价格&库存,您可以联系我们找货
FFC2A32-10-T
  • 1+2.87472
  • 10+2.52017
  • 25+2.33331
  • 50+2.21234
  • 100+2.09136
  • 250+1.95122
  • 500+1.85779
  • 1200+1.74519
  • 2400+1.69010
  • 8400+1.56792
库存:983
FFC2A32-10-T
    FFC2A32-10-T
      FFC2A32-10-T
        • 1+4.87080
        • 10+3.89880
        • 30+3.41280
        库存:80
