山东晶导微电子有限公司
RS2ABF THRU RS2MBF
Jingdao Microelectronics
Surface Mount Fast Recovery Rectifiers
Reverse Voltage - 50 to 1000 V
PINNING
Forward Current - 2 A
PIN
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Easy to pick and place
• Fast reverse recovery time
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: R2AB-R2MB
Simplified outline SMBF symbol
MECHANICAL DATA
• Case: SMBF
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 57mg / 0.002oz
Absolute Maximum Ratings and Characteristics
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Symbols
RS2ABF
RS2BBF
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
Maximum RMS voltage
V RMS
35
70
Maximum DC Blocking Voltage
V DC
50
100
Maximum Average Forward Rectified Current
at T c = 125 °C
I F(AV)
2
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
50
A
Maximum Forward Voltage at 2 A
VF
1.3
V
IR
5
100
μA
Cj
28
pF
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
at V R =4V, f=1MHz
Maximum Reverse Recovery Time
t rr
(1)
Typical Thermal Resistance (2)
Operating and Storage Temperature Range
RS2JBF
RS2KBF
RS2MBF
Units
400
600
800
1000
V
140
280
420
560
700
V
200
400
600
800
1000
V
RS2DBF RS2GBF
150
250
500
ns
RθJA
RθJC
60
18
°C/W
T j , T stg
-55 ~ +150
°C
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2016.01
SMBF-F-RS2ABF~RS2MBF-2A1KV
Page 1 of 3
山东晶导微电子有限公司
RS2ABF THRU RS2MBF
Fig.2 Typical Reverse Characteristics
3.0
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
100
T J =125°C
10
1.0
T J =25°C
0.1
00
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
0.01
0.0
40
60
80
100
120
140
Fig.4 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
10
percent of Rated Peak Reverse Voltage (%)
Case Temperature (°C)
T J =25°C
100
10
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
1
0.5
1.0
1.5
2.0
2.5
Instaneous Forward Voltage (V)
0.1
1.0
10
100
Reverse Voltage (V)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
60
50
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
2016.01
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
RS2ABF THRU RS2MBF
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SMBF
∠ALL ROUND
C
A
∠ALL ROUND
D
E
A
V M
g
Top View
mil
Bottom View
A
C
D
E
HE
e
max
1.3
0.26
4.4
3.7
5.5
2.2
min
1.1
0.18
4.2
3.5
5.1
1.9
max
51
10
173
146
216
86
min
43
7
165
138
200
75
UNIT
mm
9°
Type number
Marking code
RS2ABF
R2AB
RS2BBF
R2BB
RS2DBF
R2DB
RS2GBF
R2GB
RS2JBF
R2JB
RS2KBF
R2KB
RS2MBF
R2MB
1.8(71)
2.54(100)
3.0(118)
40
Marking
Unit:mm(mil)
2016.01
g
1.0
The recommended mounting pad size
1.8(71)
g
pad
e
E
A
pad
HE
JD512266B0
Page 3 of 3
很抱歉,暂时无法提供与“RS2DBF”相匹配的价格&库存,您可以联系我们找货
