FX10A-168S-SV
FX10A-168S-SV
    HRS(广濑)
    SMD,P=0.5mm
    板对板连接器 立贴 针脚数:172Pin 间距:0.5mm 排数:2
FX10A-168S-SV 数据手册
15+Gbps 0.5mm pitch Stacking Connectors FX10 Series Electrical Interface for the OIF 100G Long-Haul DWDM Transmission Module (MSA-100GLH) ■Mechanical Features ● 0.5mm Pitch ● Stacking height : 4 to 8mm (2-piece type) 8 to 13mm (3-piece type) ● Number of Contacts With ground plate : 80 / 100 / 120 / 140 Without ground plate : 96 / 120 / 144 / 168 3-piece interposer : 120 / 144 /168 FX10A-168P/S-SV(83) assembly is specified for the OIF 100G Long-Haul DWDM Transmission Module host line card - MSA-100GLH electrical connector. ■With GND Plate Type Ground plate ● Suited to High-Density Applications Signal contact Housing The 0.5 mm signal contact pitch provides a smaller overall connector, using less mounting area on the board. m 5m ● Optional Ground Plate 0.7 mm Metal fitting Ground plate and metal fitting make contact An alternate style without the ground plate is available. The space provided by the ground plate removal has been filled with additional signal contacts. ●Smooth floating with high speed transmission capability supported by unique 3-piece floating system ●Multiple connectors are allowed on the same PCB (Allowable Mis-alignment Range : ± 0.3mm in XY direction) mm 0.5 5 0.7 ●Floating Interposer ing Float Flo ati ng ■Signal Integrity Features 60 115 The insertion-loss-to-crosstalk-ratio (ICR) with five-aggressor differential FEXT meets the extrapolated IEEE 802.3ap specification for 15+Gbps. 50 110 40 105 Z (Ohm) ●Insertion-Loss-to-Crosstalk-Ratio(ICR) ICR (dB) 30 100 20 ●Differential Impedance 85ø configuration and 100ø configuration are available. 95 10 0 90 ICR ICR spec 0 2 4 6 Frequency (GHz) S(3,3) 8 85 10 0 ■Stack Height ●2-piece type ●With ground plate Headers Receptacles FX10#-*S/*-SV 200 400 600 Time (ps) 800 1000 ●Without ground plate FX10#-xP/x-SV FX10#–xP/x–SV1 4mm 5mm Headers Receptacles FX10#-*S-SV FX10#-xP-SV FX10–xP–SV1 FX10#-xP-SV2 4mm 5mm 6mm FX10#-xP-SV3 FX10#-xP-SV4 7mm 8mm ●3-piece type Stacking Height 8mm 9mm 10mm 11mm 12mm 13mm Header (Mating side) FX10#-xP-SV FX10#-xP-SV FX10#-xP-SV1 FX10#-xP-SV2 FX10#-xP-SV3 FX10#-xP-SV4 Interposer FX10-xIP-xD(Q)-8H FX10-xIP-xD(Q)-8PH Header(Fixed side) FX10#-xP-SV FX10#-xP-SV1 FX10#-xP-SV1 FX10#-xP-SV1 FX10#-xP-SV1 FX10#-xP-SV1 ( ) Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● OIF MSA-100GLH Electrical Interface In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. (H) : Reference dimension 2016.12r 1 FX10 Series●15+Gbps 0.5mm pitch Stacking Connectors ■General Product Specifications (2 piece type) Rating Rated current Rated voltage 0.3 A 50 V AC Item 1. Insulation resistance 2. Voltage resistance 3. Contact resistance 4. Vibration resistance 5. Shock resistance Operating temperature range Operating humidity range -55 to 85ç (Note 1) Relative humidity 95% max (No condensation) Requirements 100Mø min No flashover or breakdown 60mø max No electrical discontinuity for 1µs or greater No damage, cracks, or parts looseness No electrical discontinuity for 1µs or greater No damage, cracks, or parts looseness Storage temperature range Storage humidity range -10 to +60ç (Note 2) 40 to 70% (Note 2) Conditions Measured at 100 V DC 150 V AC applied for 1 minute Measured at 100 mA Frequency : 10 to 55 Hz, amplitude of 0.75 mm in 3 axis directions, 10 cycles each. Acceleration of 490 m/s2, 11ms duration, sine half-wave waveform, for 3 cycles in both directions of each of the 3 axes Contact resistance of 70mø max, insulation resistance of Temperature of 40ç, humidity of 90 to 95%, 100Mø min, no damage, cracks, or parts duration 96 h looseness 7. Temperature cycle Contact resistance of 70mø max, insulation Temperature : -55ç → 15 to 35ç → 85ç → 15 to 35ç resistance of Time : 30 min. → 2 to 3 min. → 30 min. → 2 to 3 min. 100Mø min, no damage, cracks, or parts for 5 cycles looseness 8. Mating Cycles Contact resistance of 70mø max 50 times No damage, cracks, or parts looseness 9. Resistance to No melting of resin portion which affects Reflow : At the recommended temperature profile soldering heat performance Soldering iron temperature : 360ç for 5 seconds Note 1 : Includes temperature rise caused by current flow. Note 2 : The term storage refers to unused products kept for a long time prior to board mounting. Operating temperature and humidity range are applicable to the non-conducting state after board assembly. Note 3 : Information contained in this catalog represents general requirements for this series. Contact us for the drawings and specifications for a specific part number shown. Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 6. Damp heat (Steady state) ■Materials / Finish Part Insulator Material LCP Contacts Phosphor bronze Ground plate Metal fitting Phosphor bronze Phosphor bronze Finish Beige Contact Area: Gold plating Header Lead Area: Tin plating Contact Area: Gold plating Receptacle Lead Area: Flash plating Tin plating Tin plating Notes UL94V-0 ------- ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. FX10 # - * P / * - SV 1 (**) q w r t y u e q Series name : FX10 r Connector type w A : With guide post P : Header S : Receptacle t Mounting style SV : Straight SMT y Product height Blank : Standard 1 : Standard + 1mm u Packaging options Blank, (71) : Tray packaging (21), (91) : Embossed tape packaging B : Without guide post e Number of contacts With ground plate Signal/Ground : 80/8, 100/10, 120/12, 140/14 Without ground plate Signal : 96, 120, 144, 168 2 FX10 Series●15+Gbps 0.5mm pitch Stacking Connectors ■Headers without ground plate ●4mm Stacking Height A±0.2 (0.6) 5.9±0.3 ( 5.7) D±0.3 2.5±0.2 ( 0.5 ) 0.2 ±0.05 B±0.3 2-(Ø1) Guidepost C±0.1 Unit : mm HRS No. 570-0041-0 ** 570-0042-2 ** 570-0043-5 ** 570-0044-8 ** 570-0141-4 ** 570-0142-7 ** 570-0143-0 ** 570-0144-2 ** 570-0059-5 ** 570-0056-7 ** 570-0302-1 ** 570-0060-4 ** 570-0057-0 ** 570-0304-7 ** 570-0061-7 ** 570-0058-2 ** 570-0306-2 ** 570-0051-3 ** 570-0052-6 ** 570-0053-9 ** 570-0054-1 ** 570-0151-8 ** 570-0152-0 ** 570-0153-3 ** 570-0154-6 ** 570-0303-4 ** 570-0305-0 ** 570-0063-0 ** 570-0307-5 ** A B C 23.5 29.5 35.5 41.5 23.5 29.5 35.5 41.5 29.5 35.5 41.5 29.5 35.5 41.5 29.5 35.5 41.5 23.5 29.5 35.5 41.5 23.5 29.5 35.5 41.5 41.5 41.5 35.5 41.5 31.1 37.1 43.1 49.1 31.1 37.1 43.1 49.1 37.1 43.1 49.1 37.1 43.1 49.1 37.1 43.1 49.1 31.1 37.1 43.1 49.1 31.1 37.1 43.1 49.1 49.1 49.1 43.1 49.1 26.4 32.4 38.4 44.4 26.4 32.4 38.4 44.4 32.4 38.4 44.4 32.4 38.4 44.4 32.4 38.4 44.4 — — — — — — — — — — — — D 3.5 4.5 5.25 6.25 7.25 3.5 4.5 5.25 6.25 7.25 E F 31.5 37.5 43.5 49.5 31.5 37.5 43.5 49.5 37.5 43.5 49.5 37.5 43.5 49.5 37.5 43.5 49.5 31.5 37.5 43.5 49.5 31.5 37.5 43.5 49.5 49.5 49.5 43.5 49.5 28.3 34.3 40.3 46.3 28.3 34.3 40.3 46.3 34.3 40.3 46.3 34.3 40.3 46.3 34.3 40.3 46.3 28.3 34.3 40.3 46.3 28.3 34.3 40.3 46.3 46.3 46.3 40.3 46.3 Remarks With guideposts Without guideposts [Specifications number]-**, (**) (71) : Tray packaging / AuP 0.1µm (83) : Embossed tape packaging 1RL : 1000pcs / AuP 0.76µm (85) : Embossed tape packaging 1RL : 250pcs / AuP 0.76µm (91) : Embossed tape packaging 1RL : 1000pcs / AuP 0.1µm (93) : Tray packaging / AuP 0.76µm Note 1: There is no polarity with respect to board mounting for this product. Note 2: The coplanarity of this product's SMT leads is 0.1mm or less. Note 3: Please order embossed tape packaged items by the reel. ■Board-to-Board Distance BRecommended PCB Layout Dimensions (Metal mask) HEADER CONNECTOR FX10A(B)-168P-SV*(83) 1.45±0.05 3 PCB PCB RECEPTACLE CONNECTOR FX10A(B)-168S-SV(83) 6.3+0.1 0 0.5 ±0.03 0 2 -0.1 1 2 Ø1.1 ±0.05 2 Ø1.2 ±0.05 0 4.1 -0.1 E +0.1 0 0 F -0.1 C ±0.05 A ±0.05 SOLDER 2 B 1 (A) (1.1):MATING LENGTH Recommended metal mask thickness : 0.15mm 3.1 +0.1 0 Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. FX10A-96P-SV(**) FX10A-120P-SV(**) FX10A-144P-SV(**) FX10A-168P-SV(**) FX10A-96P-SV1(**) FX10A-120P-SV1(**) FX10A-144P-SV1(**) FX10A-168P-SV1(**) FX10A-120P-SV2(**) FX10A-144P-SV2(**) FX10A-168P-SV2(**) FX10A-120P-SV3(**) FX10A-144P-SV3(**) FX10A-168P-SV3(**) FX10A-120P-SV4(**) FX10A-144P-SV4(**) FX10A-168P-SV4(**) FX10B-96P-SV(**) FX10B-120P-SV(**) FX10B-144P-SV(**) FX10B-168P-SV(**) FX10B-96P-SV1(**) FX10B-120P-SV1(**) FX10B-144P-SV1(**) FX10B-168P-SV1(**) FX10B-168P-SV2(**) FX10B-168P-SV3(**) FX10B-144P-SV4(**) FX10B-168P-SV4(**) No. of Contacts Signal 96 120 144 168 96 120 144 168 120 144 168 120 144 168 120 144 168 96 120 144 168 96 120 144 168 168 168 144 168 0.3±0.03(Land) 0.25±0.03(Metal mask) Note 1 The cross-hatched area inside the SMT land may come into contact with the connector contacts and thus care should be taken that the pattern does not extend beyond the SMT land width. 2 Not required in products without guideposts. FX10A(B)-168P-SV(83) FX10A(B)-168P-SV1(83) FX10A(B)-168P-SV2(83) FX10A(B)-168P-SV3(83) FX10A(B)-168P-SV4(83) SOLDER 3 FX10A(B)-168S-SV(83) 1 (A) 2 B 4 4.3±0.127 5.3±0.127 5 6.0±0.127 6 7 7.0±0.127 8 8.0±0.127 Note 1 Stacking height from lead to lead (reference dimensions) 2 Board-to-board distance 3 Stencil (metal mask) shall be based on Hirose's recommended aperture and thickness. 3 FX10 Series●15+Gbps 0.5mm pitch Stacking Connectors ■Receptacles without ground plate A±0.2 B±0.3 3.2±0.3 ( 7.1 ) 0.2 ±0.05 2.5 ±0.2 7.3 ±0.3 ( 0.5 ) Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ( 0.6 ) 2-(Ø1) C±0.1 Guidepost Unit : mm A B C D E FX10A-96S-SV(**) No. of Contacts HRS No. Signal 570-0241-9 ** 96 23.5 31.1 26.4 31.5 28.3 FX10A-120S-SV(**) 570-0242-1 ** 120 29.5 37.1 32.4 37.5 34.3 FX10A-144S-SV(**) 570-0243-4 ** 144 35.5 43.1 38.4 43.5 40.3 FX10A-168S-SV(**) 570-0244-7 ** 168 41.5 49.1 44.4 49.5 46.3 FX10B-96S-SV(**) 570-0251-2 ** 96 23.5 31.1 26.4 31.5 28.3 Part No. FX10B-120S-SV(**) 570-0252-5 ** 120 29.5 37.1 32.4 37.5 34.3 FX10B-144S-SV(**) 570-0253-8 ** 144 35.5 43.1 38.4 43.5 40.3 FX10B-168S-SV(**) 570-0254-0 ** 168 41.5 49.1 44.4 49.5 46.3 Remarks With guideposts Without guideposts [Specifications number] -✽ ✽, (✽ ✽) Blank: Tray packaging / AuP 0.1µm (21) : Embossed tape packaging 1RL : 1000pcs / AuP 0.1µm (83) : Embossed tape packaging 1RL : 1000pcs / AuP 0.76µm (84) : Embossed tape packaging 1RL : 500pcs / AuP 0.76µm (85) : Embossed tape packaging 1RL : 250pcs / AuP 0.76µm (93) : Tray packaging / AuP 0.76µm Note 1 : There is no polarity with respect to board mounting for this product. Note 2 : The coplanarity of this product's SMT leads is 0.1mm or less. Note 3 : Please order embossed tape packaged items by the reel. Note 4 : Using multiple connectors between two boards is not recommended. BRecommended PCB Layout Dimensions (Metal mask) Recommended metal mask thickness : 0.15mm D +0.1 0 0 E -0.1 C±0.05 Ø1.2±0.05 1 A±0.05 1.45±0.05 Note 1 Not required in products without guideposts. 4 7.7 +0.1 0 0 4.5 -0.1 0.5±0.03 3.1 +0.1 0 1 Ø1.1±0.05 0.3±0.03(Land) 0.25±0.03(Metal mask) FX10 Series●15+Gbps 0.5mm pitch Stacking Connectors ■Headers with ground plate Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●4mm Stacking Height Unit : mm Part No. HRS No. No.of Contacts A Signal Ground 80 8 23.5 B C D E F FX10A-80P/8-SV(**) 570-0001-5 ** 18 31.1 26.4 31.5 28.3 FX10A-100P/10-SV(**) 570-0002-8 ** 100 10 29.5 24 37.1 32.4 37.5 34.3 FX10A-120P/12-SV(**) 570-0003-0 ** 120 12 35.5 30 43.1 38.4 43.5 40.3 FX10A-140P/14-SV(**) 570-0004-3 ** 140 14 41.5 36 49.1 44.4 49.5 46.3 FX10B-80P/8-SV(**) 570-0021-2 ** 80 8 23.5 18 31.1 — 31.5 28.3 FX10B-100P/10-SV(**) 570-0022-5 ** 100 10 29.5 24 37.1 — 37.5 34.3 FX10B-120P/12-SV(**) 570-0023-8 ** 120 12 35.5 30 43.1 — 43.5 40.3 FX10B-140P/14-SV(**) 570-0024-0 ** 140 14 41.5 36 49.1 — 49.5 46.3 Remarks With guideposts Without guideposts [Specifications number] -✽ ✽, (✽ ✽) (71) : Tray packaging (91) : Embossed tape packaging Note 1 : There is no polarity with respect to board mounting for this product. Note 2 : The coplanarity of this product's SMT leads is 0.1mm or less. Note 3 : Please order embossed tape packaged items by the reel. (One reel holds 1,000 pieces.) Note 4 : Using multiple connectors between identical boards is not recommended. BRecommended PCB Layout Dimensions (Metal mask) Recommended metal mask thickness : 0.15mm Note 1 Cross-hatched portions, totaling n places, indicate the ground circuits. 2 Cross-hatched portions, 2 places on both sides, indicate the metal fittings. 3 The cross-hatched area inside the SMT land may come into contact with the connector contacts and thus care should be taken that the pattern does not extend beyond the SMT land width. 4 Not required in products without guideposts. 5 FX10 Series●15+Gbps 0.5mm pitch Stacking Connectors ■Headers with ground plate ●5mm Stacking Height A±0.2 (0.5) 0.2±0.05 5.9±0.3 (5.7) 2.5±0.2 A 0.5±0.05 (0.75) (0.75) (6) B±0.2 4.5±0.3 C±0.3 Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (0.6) 2-(Ø1) D±0.1 Guidepost Unit : mm Part No. HRS No. No. of Contacts A Signal Ground 80 8 23.5 B C D E F FX10A-80P/8-SV1(**) 570-0101-0 ** 18 31.1 26.4 31.5 28.3 FX10A-100P/10-SV1(**) 570-0102-2 ** 100 10 29.5 24 37.1 32.4 37.5 34.3 FX10A-120P/12-SV1(**) 570-0103-5 ** 120 12 35.5 30 43.1 38.4 43.5 40.3 FX10A-140P/14-SV1(**) 570-0104-8 ** 140 14 41.5 36 49.1 44.4 49.5 46.3 FX10B-80P/8-SV1(**) 570-0121-7 ** 80 8 23.5 18 31.1 — 31.5 28.3 FX10B-100P/10-SV1(**) 570-0122-0 ** 100 10 29.5 24 37.1 — 37.5 34.3 FX10B-120P/12-SV1(**) 570-0123-2 ** 120 12 35.5 30 43.1 — 43.5 40.3 FX10B-140P/14-SV1(**) 570-0124-5 ** 140 14 41.5 36 49.1 — 49.5 46.3 Remarks With guideposts Without guideposts [Specifications number] -✽ ✽, (✽ ✽) (71) : Tray packaging (91) : Embossed tape packaging Note 1 : There is no polarity with respect to board mounting for this product. Note 2 : The coplanarity of this product's SMT leads is 0.1mm or less. Note 3 : Please order embossed tape packaged items by the reel. (One reel holds 1,000 pieces.) Note 4 : Using multiple connectors between identical boards is not recommended. BRecommended PCB Layout Dimensions (Metal mask) Recommended metal mask thickness : 0.15mm Note 1 Cross-hatched portions, totaling n places, indicate the ground circuits. 2 Cross-hatched portions, 2 places on both sides, indicate the metal fittings. 3 The cross-hatched area inside the SMT land may come into contact with the connector contacts and thus care should be taken that the pattern does not extend beyond the SMT land width. 4 Not required in products without guideposts. 6 FX10 Series●15+Gbps 0.5mm pitch Stacking Connectors ■Receptacles with ground plate A±0.2 (0.5) 0.2±0.05 7.3±0.3 (7.1) 2.5±0.2 A 0.5±0.05 (0.75) (0.75) (6) Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (0.6) 3.2±0.3 B±0.2 C±0.3 2-(Ø1) Guidepost D±0.1 Unit : mm Part No. HRS No. No. of Contacts A Signal Ground 80 8 23.5 B C D E F FX10A-80S/8-SV(**) 570-0201-4 ** 18 31.1 26.4 31.5 28.3 FX10A-100S/10-SV(**) 570-0202-7 ** 100 10 FX10A-120S/12-SV(**) 570-0203-0 ** 120 12 29.5 24 37.1 32.4 37.5 34.3 35.5 30 43.1 38.4 43.5 40.3 FX10A-140S/14-SV(**) 570-0204-2 ** 140 14 41.5 36 49.1 44.4 49.5 46.3 FX10B-80S/8-SV(**) 570-0221-1 ** 80 8 23.5 18 31.1 — 31.5 28.3 FX10B-100S/10-SV(**) 570-0222-4 ** 100 10 29.5 24 37.1 — 37.5 34.3 FX10B-120S/12-SV(**) 570-0223-7 ** 120 12 35.5 30 43.1 — 43.5 40.3 FX10B-140S/14-SV(**) 570-0224-0 ** 140 14 41.5 36 49.1 — 49.5 46.3 Remarks With guideposts Without guideposts [Specifications number] -✽ ✽, (✽ ✽) (71) : Tray packaging (91) : Embossed tape packaging Note 1 : There is no polarity with respect to board mounting for this product. Note 2 : The coplanarity of this product's SMT leads is 0.1mm or less. Note 3 : Please order embossed tape packaged items by the reel. (One reel holds 1,000 pieces.) BRecommended PCB Layout Dimensions (Metal mask) Recommended metal mask thickness : 0.15mm Note 1 Cross-hatched portions, totaling n places, indicate the ground circuits. 2 Cross-hatched portions, 2 places on both sides, indicate the metal fittings. 3 Not required in products without guideposts. 7 FX10 Series●15+Gbps 0.5mm pitch Stacking Connectors ■General Product Specifications (3 piece type) Rating Rated current Rated voltage 0.3A 50V AC Operating temperature range Operating humidity range -55 to 85ç (Note 1) Relative humidity 95% max (No condensation) Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Item Requirements 1. Insulation resistance 100Mø min 2. Voltage resistance No flashover or breakdown 3. Contact resistance 8mm height : 80mø max 9mm height : 85mø max 10mm height : 90mø max 11mm height : 95mø max 12mm height : 100mø max 13mm height : 105mø max 4. Vibration resistance No electrical discontinuity for 1µs or greater No damage, cracks, or parts looseness 5. Shock resistance No electrical discontinuity for 1µs or greater No damage, cracks, or parts looseness Storage temperature range Storage humidity range -10 to +60ç (Note 2) 40 to 70% (Note 2) Conditions Measured at 100 V DC 150 V AC applied for 1 minute Measured at 100 mA Frequency : 10 to 55 Hz, amplitude of 0.75mm in 3 axis directions, 10 cycles each. Acceleration of 490m/s2, 11ms duration, sine half-wave waveform, for 3 cycles in both directions of each of the 3 axes 6. Damp heat (Steady state) Contact resistance change : 20 mø or less, Temperature of 40ç, humidity of 90 to 95%, insulation resistance of 100Mø min, no duration 96 h damage, cracks, or parts looseness Temperature : -55ç → 15 to 35ç → 85ç → 15 to 35ç 7. Temperature cycle Contact resistance change : 20mø or less, Time : 30 min. → 2 to 3 min. → 30 min. → 2 to 3 min. insulation resistance of 100Mø min, no for 5 cycles damage, cracks, or parts looseness 8. Mating Cycles Contact resistance change : 20mø or less 50 times No damage, cracks, or parts looseness Note 1 : Includes temperature rise caused by current flow. Note 2 : The term storage refers to unused products kept for a long time prior to board mounting. Operating temperature and humidity range are applicable to the non-conducting state after board assembly. Note 3 : Information contained in this catalog represents general requirements for this series. Contact us for the drawings and specifications for a specific part number shown. ■Materials / Finish Part Insulator Contacts Ground bar Material LCP Phosphor bronze Phosphor bronze Finish Black/Gray Contact Area: Gold plating Ni plating ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. FX10 - # IP - 36 DM1 - #H (#) q w e q Series Name : FX10 w Pin count : 120, 144, 168 pins e Connector type IP : Interposer r Number of Diff-pairs t Signal type 8 D : Diff. 100 ohm Q : Diff. 85 ohm (Blank) : Open pin field r t y u i y Pin configuration Blank = Standard (all diff pairs), M* =Reduced GND pins u Stacking height 8H : 8 to 10mm 8PH : 11 to 13mm i Specification suffix # (Blank) : Ni1.5µm + Au0.1µm (03) : Ni1.5µm + Au0.76µm Notes UL94V-0 ----- FX10 Series●15+Gbps 0.5mm pitch Stacking Connectors 6.76±0.5 A±0.5 6.5±0.5 7.7±0.5 ■Interposer (3piece type) Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Mating side (Gray) Fixed side (Black) Unit : mm Part No. HRS No. FX10-168IP-40D-8H(**) 608-0001-3 ** FX10-168IP-40D-8PH(**) 608-0004-1 ** FX10-168IP-52Q-8H(**) 608-0002-6 ** Signal Differential Singleended Ground type pairs 100ø 40 4 84 85ø 52 8 56 0 168 0 FX10-168IP-52Q-8PH(**) 608-0005-4 ** FX10-168IP-8H(**) 608-0003-9 ** Open pin field FX10-168IP-8PH(**) 608-0006-7 ** FX10-144IP-32D-8H(**) 608-0007-0 ** FX10-144IP-32D-8PH(**) 608-0011-7 ** FX10-144IP-44Q-8H(**) 608-0008-2 ** FX10-144IP-44Q-8PH(**) 608-0010-4 ** FX10-144IP-8H(**) 608-0009-5 ** Open pin field 100ø 85ø FX10-144IP-8PH(**) 608-0012-0 ** FX10-120IP-28D-8H(**) 608-0013-2 ** FX10-120IP-28D-8PH(**) 608-0014-5 ** FX10-120IP-36Q-8H(**) 608-0015-8 ** FX10-120IP-36Q-8PH(**) 608-0016-0 ** FX10-120IP-8H(**) 608-0017-3 ** Open FX10-120IP-8PH(**) 608-0018-6 ** pin field 100ø 85ø 32 pins 12 pins 8 48 0 144 0 4 For 11 to 13mm height 49.1 8 40 0 120 0 For 8 to 10mm height For 11 to 13mm height For 8 to 10mm height For 11 to 13mm height For 8 to 10mm height For 11 to 13mm height 43.1 For 8 to 10mm height For 11 to 13mm height For 8 to 10mm height For 11 to 13mm height For 8 to 10mm height 60 36 Remarks For 8 to 10mm height 68 44 28 A For 11 to 13mm height 37.1 For 8 to 10mm height For 11 to 13mm height For 8 to 10mm height For 11 to 13mm height [Specifications number] -✽ ✽, (✽ ✽) Blank : Contact plating Ni1.5µm+Au0.1µm (03) : Contact plating Ni1.5µm+Au0.76µm 8mm Header (Mating side) FX10#-xP-SV Stacking height 9mm FX10#-xP-SV 10mm FX10#-xP-SV1 11mm FX10#-xP-SV2 12mm FX10#-xP-SV3 13mm FX10#-xP-SV4 Interposer FX10-xIP-xD(Q)-8H Header (Fixed side) FX10#-xP-SV FX10#-xP-SV1 FX10#-xP-SV1 FX10#-xP-SV1 FX10-xIP-xD(Q)-8PH FX10#-xP-SV1 FX10#-xP-SV1 9 FX10 Series●15+Gbps 0.5mm pitch Stacking Connectors ■Signal integrity (2 piece type) ● Pin assignment To match 100 ohm differential impedance and to reduce crosstalk, a staggered GSGSG pin assignment is recommended. (G=ground and S=signal) GSGSG signal Diff pair ground ● Impedance Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. The differential impedance is 100 +/- 10 ohm for FX10 at 30 ps rise time (20% to 80%). 5mm (without GND) 115 115 110 110 105 105 Z (Ohm) Z (Ohm) 4mm (without GND) 100 95 100 95 90 90 S(3,3) 85 0 200 400 600 Time (ps) 800 S(3,3) 85 1000 0 200 800 115 115 110 110 105 105 100 100 95 95 90 90 S(3,3) S(3,3) 85 1000 5mm (with GND) Z (Ohm) Z (Ohm) 4mm (with GND) 400 600 Time (ps) 0 200 400 600 Time (ps) 800 1000 85 0 200 400 600 Time (ps) 800 1000 ● Propagation delay The propagation delay is 62 and 67 ps for FX10 of 4mm and 5mm height (with and without GND), respectively. 10 FX10 Series●15+Gbps 0.5mm pitch Stacking Connectors ● Insertion loss The differential insertion loss crosses 1dB at 10.8 and 9.2GHz for FX10 of 4mm and 5mm height, respectively. 4mm (without GND) 5mm (without GND) S (dB) 0 S (dB) 0 IL 5 10 Frequency (GHz) 15 IL 20 0 4mm (with GND) 5 10 Frequency (GHz) 15 20 5mm (with GND) S (dB) 0 IL 0 5 10 Frequency (GHz) 15 20 ● Return loss The differential return loss meets the IEEE 802.3ap specification to 20 + and 13.5 GHz for FX10 of 4mm and 5mm height, respectively. 4mm (without GND) 5mm (without GND) RL (dB) 0 RL (dB) 0 RL RL Spec RL RL Spec 0 5 10 Frequency (GHz) 15 20 0 4mm (with GND) 5 10 Frequency (GHz) 15 20 5mm (with GND) 0 RL (dB) 0 RL (dB) Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0 RL RL Spec RL RL Spec 0 5 10 Frequency (GHz) 15 20 0 5 10 Frequency (GHz) 15 20 11 FX10 Series●15+Gbps 0.5mm pitch Stacking Connectors ● Near-end crosstalk (NEXT) The staggered GSGSG pin assignment results in low differential NEXT between neighboring pairs. 4mm (without GND) 5mm (without GND) 0 0 NEXT S (dB) S (dB) NEXT 0 5 10 Frequency (GHz) 15 0 20 5 Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4mm (with GND) 10 Frequency (GHz) 15 20 5mm (with GND) 0 0 S (dB) NEXT S (dB) NEXT 0 5 10 Frequency (GHz) 15 20 0 5 10 Frequency (GHz) 15 20 ● Far-end crosstalk (FEXT) The staggered GSGSG pin assignment results in low differential FEXT between neighboring pairs. 4mm (without GND) 5mm (without GND) 0 0 FEXT S (dB) S (dB) FEXT 0 5 10 Frequency (GHz) 15 0 20 5 4mm (with GND) 15 20 5mm (with GND) 0 0 FEXT S (dB) FEXT S (dB) 0 12 10 Frequency (GHz) 5 10 Frequency (GHz) 15 20 0 5 10 Frequency (GHz) 15 20 FX10 Series●15+Gbps 0.5mm pitch Stacking Connectors ● Insertion-loss-to-crosstalk ratio (ICR) The insertion-loss-to-crosstalk ratio (ICR) with five-aggressor differential FEXT meets the extrapolated IEEE 802.3ap specification to 10+ Gbps. 5mm (without GND) 60 50 50 40 40 ICR (dB) ICR (dB) 4mm (without GND) 60 30 20 20 10 10 ICR ICR spec 0 2 4 6 Frequency (GHz) 8 0 10 4mm (with GND) 60 50 50 40 40 30 20 0 2 4 6 Frequency (GHz) 8 10 5mm (with GND) 30 20 10 0 ICR ICR spec 60 ICR (dB) ICR (dB) Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0 30 10 ICR ICR spec 0 2 4 6 Frequency (GHz) 8 10 0 ICR ICR spec 0 2 4 6 Frequency (GHz) 8 10 13 FX10 Series●15+Gbps 0.5mm pitch Stacking Connectors ■Signal integrity (3-piece type) ● Pin assignment Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. For 100 ohm type interposer, pin assignment shall be GSGSG. For 85 ohm type interposer, pin assignment shall be GSSG. 1.Differential Impedance 100Ÿ Type 2.Differential Impedance 85Ÿ Type 3.Open Pin Field Type (With Ground Bar) (With Ground Bar) (No Ground Bar) Pin Assignment Pin Assignment Pin Assignment Row A Row A Row A Row B Row B Row B Signal Pin Ground Bar Dedicated Ground Pin Differential Pair ● Impedance ● Insertion Loss 8mm (85 ohm type) 8mm (85 ohm type) 105 0 100 95 -1 S (dB) Z (Ohm) 90 85 -2 -3 80 -4 75 IL 70 -5 TDR, Rise-time: 50ps(20-80%) 65 0.9 0.95 1 1.05 1.1 1.15 Time (ns) 1.2 1.25 1.3 ● Return Loss The differential return loss meets the IEEE 802.3ap specification to 20+GHz for FX10 of 8mm height. 8mm (85 ohm type) 0 -5 -10 RL (dB) -15 -20 -25 -30 -35 -40 RL RL spec -45 -50 14 0 5 10 Frequency (GHz) 15 20 0 5 10 Frequency (GHz) 15 20 FX10 Series●15+Gbps 0.5mm pitch Stacking Connectors ● Near-end crosstalk (NEXT) 0 0 -10 -10 -20 -20 S (dB) S (dB) 8mm (85 ohm type) -30 -40 -40 -50 -50 Sdd(2,5) Sdd(2,3) -60 0 5 10 15 20 -60 0 5 10 15 20 Frequency (GHz) Frequency (GHz) ● Far-end crosstalk (FEXT) 8mm (85 ohm type) -10 -10 -20 -20 S(dB) S(dB) 0 -30 -30 -40 -40 -50 -50 -60 -60 0 5 10 Frequency(GHz) 15 20 6 8 10 12 14 Frequency(GHz) 16 18 20 ● Insertion-loss-to-crosstalk ratio (ICR) The insertion-loss-to-crosstalk ratio (ICR) with fiveaggressor differential FEXT meets the extrapolated IEEE 802.3ap specification to 15+Gbps. 8mm (85 ohm type) 60 50 40 ICR (dB) Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. -30 30 20 10 0 ICR ICR spec 0 5 10 15 20 Frequency (GHz) 15 FX10 Series●15+Gbps 0.5mm pitch Stacking Connectors BEmbossed Carrier Tape Dimensions 0 Ø1.5 +0.1 12±0.1 4±0.1 2 ±0.1 1.75±0.1 ●Headers (D) 0.9 (0.4) Insertion Connector A B C FX10#-80P/8-SV 20.2 40.4 44 FX10#-100P/10-SV B±0.1 C±0.3 A±0.1 FX10#-120P/12-SV 34.2 68.4 72 FX10#-96P-SV 20.2 40.4 44 Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FX10#-144P-SV Unreeling direction 0.2 ±0.05 1.75±0.1 +0.1 0 64 45.5 50.5 FX10#-168P-SV1 ( 3.5) 26.2 52.4 56 20.2 40.4 44 59 4.8 26.2 52.4 56 34.2 68.4 72 64 76.5 81.5 45.5 50.5 59 64 76.5 81.5 0.9 B±0.1 C±0.3 Unit : mm Insertion Connector A B C E F G FX10#-80S/8-SV 20.2 40.4 44 45.5 50.5 FX10#-100S/10-SV FX10#-120S/12-SV (7.6) (8) 59 64 34.2 68.4 72 76.5 81.5 FX10#-96S-SV 20.2 40.4 44 45.5 50.5 FX10#-144S-SV 0.2 ±0.05 26.2 52.4 56 FX10#-140S/14-SV FX10#-120S-SV FX10#-168S-SV 26.2 52.4 56 59 64 34.2 68.4 72 76.5 81.5 Note : There is no polarity with respect to embossed tape packaging for this product. +0.05 R0.75 0 (Ø80) (G) ●Reel Dimensions Ø13±0.5 370 ( 0.4) A±0.1 Ø1.5 59 330 Note : There is no polarity with respect to embossed tape packaging for this product. ●Receptacles (E) (F) 16 45.5 50.5 20.2 40.4 44 FX10#-144P-SV1 Unreeling direction 76.5 81.5 FX10#-80P/8-SV1 FX10#-120P-SV1 4±0.1 64 76.5 81.5 FX10#-96P-SV1 12±0.1 3.8 26.2 52.4 56 FX10#-140P/14-SV1 34.2 68.4 72 2 ±0.1 59 34.2 68.4 72 FX10#-120P/12-SV1 +0.05 R0.75 0 Unit : mm E F G 45.5 50.5 FX10#-168P-SV FX10#-100P/10-SV1 (6.2) (6.6) 26.2 52.4 56 FX10#-140P/14-SV FX10#-120P-SV D 330 FX10 Series●15+Gbps 0.5mm pitch Stacking Connectors BRecommended Temperature Profile HRS test Conditions Test board Glass epoxy 161mm∞100mm∞1.6mm thick Solder method : Reflow Solder composition : Paste, Metal mask : 0.15mm thick Reflow cycles : 2 cycles Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 96.5%Sn/3%Ag/0.5%Cu The temperature profile is based on the above conditions. In individual applications the actual temperature may vary, depending on solder paste type, volume/thickness and board size/thickness. Consult your solder paste and equipment manufacturer for specific recommendations. BWashing Conditions Organic Solvent Cleaning Solvent Room temperature washing Heated washing IPA (Isopropyl alcohol) HCFC (Hydrochlorofluorocarbon) ™ ™ Water Type Cleaning When using water based cleaning agents (e.g., terpene, alkali saponifiers) make sure the labeling discloses any effect on metals, platings and plastics. Remove any moisture after cleaning. Residual flux or cleaning agents in the contact areas may affect the electrical performance. Cleaning Precautions Residual flux or cleaning agents in the contact areas may affect the electrical performance. Please make sure a thorough cleaning operation has been completed. BConnector Handling Precautions 1. Mating lengths and creepage distance The effective wipe length for this product is 1.1mm for the signal contact and 1 mm for the ground contact. Creepage of the header and receptacle during mating should be within 0.5 mm of the fully mated position. 2. PCB support Note that boards should not be supported solely by the connectors themselves. Support should be in the form of spacers and screws or other suitable methods to support the boards. 3. Solder repairs During repair, the flux could wick onto the contact area of the connector and cause reduced contact reliability. In this case, make sure you understand washing conditions before washing is implemented. 4. Miscellaneous ・Note that excessive twisting while inserting or withdrawing connectors will cause damage. ・Slight color differences on the molded items may be noted. However, these color differences will not affect the connector's performance. 17 FX10 Series●15+Gbps 0.5mm pitch Stacking Connectors BSpacer Suggested spacer style is shown below: Spacers are required to support the PWB’s and protect the SMT solder joints. Spacer Spacer, male-male, M3 thread Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. The recommended spacer height corresponds to the interposer stacking height as shown in the chart below. Stacking height Recommended spacer height Remark 4mm 4.3 ± 0.127mm 5mm 5.3 ± 0.127mm 6mm 6 ± 0.127mm 7mm 7 ± 0.127mm 8mm 8 ± 0.127mm 8mm 8 ± 0.127mm 9mm 9 ± 0.127mm 10mm 10 ± 0.127mm 11mm 11 ± 0.127mm 12mm 12 ± 0.127mm 13mm 13 ± 0.127mm 2 piece type 3 piece type ◆Recommended spacer location 10-30mm 10-30mm Four spacers located diagonally are required. Spacers should be located 10 to 30mm from the connector to prevent excessive mechanical loading on the interconnections. If assembly will be subjected to vibration, spacer should be located to prevent resonance, and additional spacer may be required. ■ Interposer installation Position the interposer directly over the mounting header. (Interposers have no polarity.) Fixed side (black side) of the interposer shall be mated with the mounting header (fixed side). Do not use SV2, SV3, or SV4 headers on both sides of the interposer. The wiping length on the mating side becomes shorter. Interposer Mounting header (Fixed side) 8mm Header (Mating side) FX10#-xP-SV 9mm FX10#-xP-SV 10mm FX10#-xP-SV1 FX10#-xP-SV1 11mm FX10#-xP-SV2 FX10#-xP-SV1 12mm FX10#-xP-SV3 13mm FX10#-xP-SV4 Stacking height 18 Mating side (Mold color: Gray) Fixed side (Mold color: Black) Interposer FX10-xIP-xD(Q)-8H FX10-xIP-xD(Q)-8PH Header (Fixed side) FX10#-xP-SV FX10#-xP-SV1 FX10#-xP-SV1 FX10#-xP-SV1 FX10 Series●15+Gbps 0.5mm pitch Stacking Connectors B Interposer removal The interposer can be removed from the mounting header by hand. (No special tools are needed.) Removal and re-mating of the fixed side can reduce the extraction force of the fixed side due to wear. It is recommend to replace the interposer to a new one once removed. B Multiple Mating Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. It is not recommended to use multiple 2-piece FX10 connectors on the same PWB. FX10 3-piece type has multiple mating capability. If multiple connectors are used on the same PWB, they must be oriented in the same direction. It is not recommended to mix orientations. ●Mating tolerance (3-piece type) Due to the floating interposer, FX10 3-piece type can accept mating tolerances of up to ±0.15mm tolerance in the X-axis and up to ±0.15mm in the Y-axis. 0.15mm 0.15mm 19 Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FX10 Series●15+Gbps 0.5mm pitch Stacking Connectors USA: HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE 2300 Warrenville Road, Suite 150, Downers Grove, IL 60515 Phone : +1-630-282-6700 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE 2841 Junction Ave, Suite 200 San Jose, CA. 95134 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE) 17197 N. Laurel Park Drive, Suite 253, Livonia, MI 48152 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hirose.com/us/ THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Schoenbergstr. 20, 73760 ostfildern Phone : +49-711-456002-1 Fax : +49-711-456002-299 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE Neumeyerstrasse 22-26, 90411 Nurnberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE Bayernstr. 3, Haus C 30855 Langenhagen, Germany Phone : +49-511 97 82 61 30 Fax : +49-511 97 82 61 35 http://www.hirose.com/eu/ FRANCE: HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE Regus La Garenne Colombes,Place de La Belgique, 71 Boulevard National La Garenne Colombes, 92250, France Phone : +33 (0) 1 7082 3170 Fax : +33 (1) 7082 3101 http://www.hirose.com/eu/ UNITED KINGDOM: HIROSE ELECTRIC EUROPE BV (UK BRANCH) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 http://www.hirose.com/eu/ CHINA: HIROSE ELECTRIC (SHANGHAI) CO., LTD. 1601, Henderson Metropolitan, NO.300, East Nanjing Road, Huangpu District, Shanghai, China 200001 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (SHANGHAI) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD. Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose.com/cn/ HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose.com/hk/ TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7350 http://www.hirose.com/tw/ KOREA: HIROSE KOREA CO.,LTD. 250, Huimanggongwon-ro, Siheung-si, Gyeonggi-do, Korea, 15083 Phone : +82-31-496-7000 or 7124 Fax : +82-31-496-7100 http://www.hirose.co.kr/ SINGAPORE: INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE HIROSE ELECTRIC SINGAPORE PTE. LTD. 10 Anson Road #26-16, International Plaza Office NO.552, Regus-Green Boulevard, Level5, Tower C, Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India 079903, Singapore Phone : +91-12-660-8018 Phone : +65-6324-6113 Fax : +91-120-4804949 Fax : +65-6324-6123 http://www.hirose.com/sg/ http://www.hirose.com/sg/ MALAYSIA: PENANG REPRESENTATIVE OFFICE 1-21-01, Suntech @ Penang Cybercity (1164), Lintang Mayang Pasir 3,11950, Bayan Baru, Penang, Malaysia. Phone : +604-619-2564 Fax : +604-619-2574 http://www.hirose.com/sg/ ® 20 INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma Gandhi (MG) Road, Bangalore 560 001, Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose.com/sg/ THAILAND: BANGKOK OFFICE (REPRESENTATIVE OFFICE) Unit 4703, 47th FL., 1 Empire Tower, South Sathorn Road, Yannawa, Sathorn, Bangkok 10120 Thailand Phone : +66-2-686-1255 Fax : +66-2-686-3433 http://www.hirose.com/sg/ 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 12/2016. Contents are subject to change without notice for the purpose of improvements.
FX10A-168S-SV 价格&库存
很抱歉,暂时无法提供与“FX10A-168S-SV”相匹配的价格&库存,您可以联系我们找货
FX10A-168S-SV
  • 13+62.2480013+8.06330
  • 25+58.9474825+7.63576
  • 50+42.6264350+5.52162
  • 100+40.88087100+5.29551
  • 250+36.99060250+4.79158
  • 500+35.10641500+4.54751
  • 1000+33.311461000+4.31500
库存:56
FX10A-168S-SV
  • 1+42.04200
  • 10+35.99540
  • 50+32.40860
库存:79
