TP2012-A1255DAT/LF
TP2012-A1255DAT/LF
    ACX(璟德)
TP2012-A1255DAT/LF 数据手册
ACX Advanced Ceramic X TP 2012 Series Multilayer Chip Triplexers Features  Monolithic structure including one low-pass and two band-pass filters with loss pole at adjacent passband RoHS compliant Applications  Triple-band for GPS and 2.4GHz/5GHz WLAN Specifications Insertion Loss (dB) Passband (MHz) Part Number Return Loss (dB) Attenuation (dB) 0.6 max. 1560 ~ 1610 @25°C 10 min. 0.7 max. 14 min. @ 2400 ~ 2500 MHz 15 min. @ 4800 ~ 6000 MHz @-40~85°C 2400 ~ 2500 TP2012 -A1255DA 0.73 max. 10 min. @ 3600 ~ 3750 MHz @25°C 20 min. @ 4800 ~ 5000 MHz 10 min. 0.81 max. @-40~85°C 10 min. @ 7200 ~7500 MHz 10 min. @ 9600 ~10000 MHz Isolation (dB) Low to Middle band @ 1559~1606 20 min. Middle to High band @ 4800~5000 20 min. 24 min. @ 860 ~ 960 MHz 24 min. @ 1545 ~ 1605 MHz 0.8 max 4900 ~ 5950 @25°C 10 min. 0.92 max 25 min. @ 1710 ~ 1990 MH Low to High band 30 min. @ 2170 MHz @ 1559~1606 10 min. @ 8100 ~ 8800 MHz 25 min. @-40~85°C 15 min. @ 8820 ~ 9800 MHz 25 min. @ 9800 ~ 11800 MHz Q’ty/Reel (pcs) Operating Temperature Range Storage Temperature Range Storage Period Power Capacity : 4,000 : -40 ~ +85 oC : -40 ~ +85 oC : 12 months max. : 2W max. Part Number TP   Type 2012  - A  TP : Triplexer 1255  DA    /LF   Dimensions ( L × W )  Material Code A  Frequency Range  Specification Code DA  Packaging  Soldering /LF=lead-free TP2012-A1255DAT/LF 2.0 × 1.2 mm 1255=1610MHz /2450MHz /5500MHz T: Tape & Reel B: Bulk REV:2 PAGE:1/7 ACX Advanced Ceramic X Terminal Configuration     No. Terminal Name No. Terminal Name  GND  GND  Common Port  High-Band Port (5G)  GND  GND  Low-Band Port (1.5G)  Middle-Band Port (2.4G)     Dimensions and Recommended PC Board Pattern a a Unit : mm p W T c g b L L W T a 2.0 1.25 0.95 0.1 0.1 0.1 0.3  0.1 Mark Dimensions 1.0 b c g p 0.2  0.3+0.1 0.35  0.65  0.1 /-0.2 0.1 0.05 1.4 * 1.65 Solder Resist 0.75 * * 0.35 1 Land Through-hole ( 0.35/0.55) 0.3 0.35 * * Line width should be designed to match 50characteristic impedance, depending on PCB material and thickness. TP2012-A1255DAT/LF REV:2 PAGE:2/7 ACX Advanced Ceramic X Measuring Diagram Network Analyzer Port 1 (50) Port 4 (50) Port 2 (50) Port 3 (50) GND GND GND GND *In Application, It is not necessary to add the DC blocking capacitors at all ports when DC voltages are present at these RF ports. Typical Electrical Characteristics (T=25oC) Return Loss 0 -10 -10 dB(S(4,4)) dB(S(3,3)) dB(S(2,2)) dB(S(1,1)) dB(S(4,3)) dB(S(2,3)) dB(S(1,3)) Attenuation 0 -20 -30 -40 -20 -30 -40 -50 -50 0 2 4 6 8 10 12 freq, GHz 0 2 4 6 8 10 12 freq, GHz Notes The contents of this data sheet are subject to change without notice. Please confirm the specifications and delivery conditions when placing your order. TP2012-A1255DAT/LF REV:2 PAGE:3/7 ACX Advanced Ceramic X Taping Specifications Tape Dimensions (Unit: mm) & Quantity A’ 1.75 ± 0.1 D E F C ∣ ∣ B T A EMBOSS TAPE Type A A’ B C D E F T 4.0± 4.0± 1.35± 2.15± 2.0± 3.5± 8.0± 1.08± Quantity/reel Tape material Plastic 4,000pcs 2012 0.1 0.1 0.05 0.05 0.05 0.1 0.1 (Embossed) 0.05 Reel Dimensions (Unit: mm) 1.4 ± 0.2 Label 178± 1 60±1 Label: Customer’s Name, ACX P/N, Q’ty, Date, ACX Corp. 13.5±0.5 B A Type A B 2012 2.3±0.5 9.0±0.3 Leader and Trailer Tape Trailer End Trailer (160 mm min.) Empty Compartments with Cover Tape TP2012-A1255DAT/LF REV:2 PAGE:4/7 ACX Advanced Ceramic X Peel-off Force Top Cover Tape Peeling Direction
TP2012-A1255DAT/LF 价格&库存
很抱歉,暂时无法提供与“TP2012-A1255DAT/LF”相匹配的价格&库存,您可以联系我们找货
