KNP700JB-91-0R12
KNP700JB-91-0R12
    YAGEO(国巨)
    AXIAL-D8.2X24.5MM
    KNP700JB-91-0R12
KNP700JB-91-0R12 数据手册
無法顯示連結的圖像。檔案可能已移動、重新命名或刪除。請驗證連結指向正確的檔案及位置。 DATA SHEET WIREWOUND RESISTORS General Purpose KNP Series ±1%, ±2%, ±5% 1/4W to 7W Product specification – August 13, 2021 V.0 RoHS compliant & Halogen Free Through Hole Resistors WireWound Resistors Product Specification ORDERING INFORMATION Part number of the wirewound resistor is identified by the series, power rating, tolerance, packing, temperature coefficient, forming and resistance value. PART NUMBER APPLICATIONS  Power applications  Home appliance  Industry KNP 100 J T - 73- 100R (1) (2) (3) (4) (5) (6) (7) (1) SERIES KNP Series (2) POWER RATING -25 = 1/4W 200 = 2W 500 = 5W 50S = 1/2W 3WS = 3W 600 = 6W FEATURES -50 = 1/2W 3SS = 3W 700 = 7W  Higher power rating 1WS = 1W 300 = 3W 7WS = 7W 100 = 1W 400 = 4W 2WS = 2W 5WS = 5W  Wide resistance range  High stable performance and high reliability  Flameproof coating equivalent to UL-94V-0  RoHS compliant & halogen-free (3) TOLERANCE F = ±1% G = ±2% J = ±5% R = Reel Pack B = Bulk (4) PACKAGING T = Box Pack (5) TEMPERATURE COEFFICIENT OF RESISTANCE - = Based on spec. (6) FORMING 52- = 52.4mm FK = FK Type 73- = 73mm FFK = F-form Kink 91- = 91mm FKK = FKK Type M = M-Type Forming FT = FT Type Forming MB = M-form W/flat PN = PANAsert F = F Type AV = AVIsert (7) RESISTANCE VALUE E24 & E96 Series Example: 0R1= 0.1Ω, 100R= 100Ω, 1K = 1,000Ω www.yageo.com Aug. 13, 2021 V.0 2 22 KNP Through Hole Resistors Product Specification WireWound Resistors KNP DIMENSIONS Unit: mm Normal Miniature L ψD H ψd KNP-25 KNP50S 6.3 ± 0.5 2.5 ± 0.3 28 ± 2.0 0.55 ± 0.05 KNP-50 KNP1WS 9.0 ± 0.5 3.5 ± 0.3 26 ± 2.0 0.55 ± 0.05 KNP2WS 11.5 ± 1.0 4.6 ± 0.5 35 ± 2.0 0.8 ± 0.05 KNP3SS 11.5 ± 1.0 4.6 ± 0.5 35 ± 2.0 0.8 ± 0.05 KNP3WS 15.5 ± 1.0 5.2 ± 0.5 33 ± 2.0 0.8 ± 0.05 17.5 ± 1.0 6.2 ± 0.5 32 ± 2.0 0.8 ± 0.05 17.5 ± 1.0 6.2 ± 0.5 32 ± 2.0 0.8 ± 0.05 24.5 ± 1.0 8.2 ± 0.5 38 ± 2.0 0.8 ± 0.05 24.5 ± 1.0 8.2 ± 0.5 38 ± 2.0 0.8 ± 0.05 24.5 ± 1.0 8.2 ± 0.5 38 ± 2.0 0.8 ± 0.05 KNP100 KNP200 KNP300 KNP5WS KNP400 KNP500 KNP7WS KNP600 KNP700 - DERATING CURVE KNP-25 ~ KNP3WS Rated Power (%) 100 80 60 40 36 20 70 200 275 Ambient Temperature (°C) KNP300 ~ KNP700 Rated Power (%) 100 80 60 40 31 20 40 200 275 Ambient Temperature (°C) www.yageo.com Aug. 13, 2021 V.0 3 22 Through Hole Resistors Product Specification WireWound Resistors KNP ELECTRICAL CHARACTERISTICS CHARACTERISTICS KNP-25 KNP-50 KNP100 KNP200 KNP300 KNP400 KNP500 KNP600 KNP700 Power Rating at 40 °C 3W 4W 5W 6W 7W Power Rating at 70 °C 1/4W 1/2W 1W 2W Resistance Range (±1%) 0.1Ω 150Ω 0.1Ω 750Ω 0.1Ω 1.5KΩ 0.1Ω 2.4KΩ 0.1Ω 3.3KΩ 0.1Ω 3.3KΩ 0.1Ω 6.2KΩ 0.1Ω 6.2KΩ 0.1Ω 6.2KΩ Resistance Range (±2% & ±5%) 0.1Ω 200Ω 0.1Ω 800Ω 0.1Ω 2.2KΩ 0.1Ω 2.7KΩ 0.1Ω 3.9KΩ 0.1Ω 3.9KΩ 0.1Ω 6.8KΩ 0.1Ω 6.8KΩ 0.1Ω 6.8KΩ Voltage Proof on Insulation 250V 300V 400V 400V 400V 400V 400V 400V 400V Maximum working voltage √(P X R) Operating Temp. Range - 40°C to +200°C Temperature Coefficient ±300ppm/°C Note: For resistance value out of above range is by request. CHARACTERISTICS KNP50S KNP1WS KNP2WS KNP3SS KNP3WS Power Rating at 40 °C KNP5WS KNP7WS 5W 7W Power Rating at 70 °C 1/2W 1W 2W 3W 3W Resistance Range (±1%) 0.1Ω 150Ω 0.1Ω 750Ω 0.1Ω 1.5KΩ 0.1Ω 1.5KΩ 0.1Ω 2.4KΩ 0.1Ω 3.3KΩ 0.1Ω 3.3KΩ Resistance Range (±2% & ±5%) 0.1Ω 200Ω 0.1Ω 800Ω 0.1Ω 2.2KΩ 0.1Ω 2.2KΩ 0.1Ω 2.7KΩ 0.1Ω 3.9KΩ 0.1Ω 3.9KΩ Voltage Proof on Insulation 200V 300V 400V 400V 400V 400V 400V Maximum working voltage √(P X R) Operating Temp. Range - 40°C to +200°C Temperature Coefficient ±300ppm/°C Note: For resistance value out of above range is by request. www.yageo.com Aug. 13, 2021 V.0 4 22 Through Hole Resistors WireWound Resistors Product Specification KNP TEST AND REQUIRMENTS TEST TEST METHOD Short Time Overload IEC 60115-1 4.13 10 times rated power for 5 sec. ±2%+0.05Ω Voltage Proof on IEC 60115-1 4.7 In V-Block for 60 sec. test voltage as No Breakdown Insulation PROCEDURE APPRAISE above table Temperature Coefficient IEC 60115-1 4.8 Between -40°C to +155°C By Type Insulation Resistance IEC 60115-1 4.6 In V-Block for 60 sec. >100MΩ Solderability IEC 60115-1 4.17 245±5°C for 3±0.5 Sec. 95% Min. coverage Solvent Resistance of IEC 60115-1 4.30 IPA for 5±0.5 Min. with ultrasonic No deterioration of Marking coatings and markings Robustness of IEC 60115-1 4.16 Terminations Damp Heat Steady State Direct load for 10 Sec. in the direction of ≥2.5Kg(24.5N) the terminal leads IEC 60115-1 4.24 40±2°C,90-95% RH for 56 days, loaded ±5.0%+0.05Ω with 0.1 times RCWV Endurance at 70°C IEC 60115-1 4.25 70±2°C at RCWV(or Umax., whichever ±5.0%+0.05Ω less) for 1,000 Hr.(1.5 Hr.on,0.5 Hr. off) Temperature Cycling IEC 60115-1 4.19  -55°C  Room Temp.  ±1.0%+0.05Ω +155°C Room Temp.(5 cycles) Resistance to Soldering IEC 60115-1 4.18 Heat 260±3°C for 10±1 Sec., immersed to a ±1.0 %+0.05Ω point 3±0.5mm from the body Accidental Overload IEC 60115-1 4.26 4 times RCWV for 1 Min. Test No evidence of flaming or arcing Note: RCWV (Rated Continuous Working Voltage ): The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V=√(P X R) or max. working voltage whichever is less Where V=Continuous rated DC or AC (rms) working voltage (V) P=Rated power (W) R=Resistance value (Ω) www.yageo.com Aug. 13, 2021 V.0 5 22 Through Hole Resistors WireWound Resistors Product Specification KNP PULSE DIAGRAMS KNP100 Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration tp: Pulse repetition time KNP200 Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration tp: Pulse repetition time www.yageo.com Aug. 13, 2021 V.0 6 22 Through Hole Resistors WireWound Resistors Product Specification KNP KNP300 Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration tp: Pulse repetition time KNP400 Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration tp: Pulse repetition time www.yageo.com Aug. 13, 2021 V.0 7 22 Through Hole Resistors WireWound Resistors Product Specification KNP KNP500 Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration tp: Pulse repetition time KNP700 Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration tp: Pulse repetition time www.yageo.com Aug. 13, 2021 V.0 8 22 Through Hole Resistors WireWound Resistors Product Specification KNP KNP2WS Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration tp: Pulse repetition time KNP3WS Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration tp: Pulse repetition time www.yageo.com Aug. 13, 2021 V.0 9 22 Through Hole Resistors WireWound Resistors Product Specification 22 KNP KNP3SS Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration tp: Pulse repetition time KNP5WS Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration tp: Pulse repetition time www.yageo.com Aug. 13, 2021 V.0 10 Through Hole Resistors WireWound Resistors Product Specification 22 KNP KNP7WS Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration tp: Pulse repetition time www.yageo.com Aug. 13, 2021 V.0 11 Through Hole Resistors WireWound Resistors Product Specification 22 KNP AXIAL / REEL TAPE SPECIFICATION Unit: mm Normal Miniature a KNP-25 KNP50S 6 ± 0.5 A B1-B2 (Max.) 52.4 ± 1.5 1.2 26.0 ± 1.5 1.0 52.4 ± 1.5 1.2 73.0 ± 1.5 1.5 52.4 ± 1.5 1.2 73.0 ± 1.5 1.5 52.4 ± 1.5 1.2 S (spacing) T (max. deviation of spacing) 5 KNP-50 KNP1WS 6 ± 0.5 KNP100 KNP2WS KNP3SS 6 ± 0.5 KNP200 KNP300 KNP400 KNP3WS KNP5WS 6 ± 0.5 KNP500 KNP600 KNP7WS 6 ± 0.5 91.0 ± 1.5 1.5 10 KNP700 - 6 ± 0.5 91.0 ± 1.5 1.5 10 5 5 1 mm per 10 spacing, 0.5 mm per 5 spacing 10 www.yageo.com Aug. 13, 2021 V.0 12 Through Hole Resistors WireWound Resistors Product Specification 22 KNP TAPE ON REEL PACKING TYPE Unit: mm/piece Normal Miniature Across Flange(A) B Quantity Per Reel KNP-25 KNP50S 66.5 75.5 5,000 KNP-50 KNP1WS 66.5 75.5 2,500 KNP100 KNP2WS KNP3SS 87 96 2,000 KNP200 KNP3WS 87 96 1,000 KNP300 KNP400 KNP5WS 87 96 1,000 www.yageo.com Aug. 13, 2021 V.0 13 Through Hole Resistors WireWound Resistors Product Specification 22 KNP TAPE ON BOX PACKING TYPE DIMENSIONS Unit: mm/piece Normal Miniature A B C Quantity Per Box KNP-25 KNP50S 48 102 255 5,000 KNP-25 KNP50S 81 104 260 5,000 KNP-50 KNP1WS 73 45 258 1,000 KNP100 KNP2WS KNP3SS 81 91 260 1,000 KNP100 KNP2WS KNP3SS 103 78 260 1,000 KNP200 KNP3WS 81 91 260 1,000 KNP200 KNP3WS 103 94 260 1,000 KNP300 KNP400 KNP5WS 81 91 260 500 KNP300 KNP400 KNP5WS 103 78 260 500 KNP500 KNP600 KNP7WS 116 79 255 250 KNP700 - 116 79 255 250 BULK PACKING Normal Miniature Piece/Per Inner Box Bag/Per Inner Box Piece Per Bag KNP-25 KNP50S 10,000 10 1,000 KNP-50 KNP1WS 5,000 5 1,000 KNP100 KNP2WS KNP3SS 2,000 4 500 KNP200 KNP3WS 1,000 2 500 KNP300 KNP400 KNP5WS 1,000 2 500 KNP500 KNP600 KNP7WS 500 10 50 KNP700 - 500 10 50 www.yageo.com Aug. 13, 2021 V.0 14 Through Hole Resistors WireWound Resistors Product Specification 22 KNP FORMING M TYPE TYPE DIMENSIONS Unit: mm Normal Miniature L ψD ψd P H KNP-25 KNP50S 6.3 ± 0.5 2.5 ± 0.3 0.55 ± 0.05 10.0 ± 1 10.0 ± 1 KNP-50 KNP1WS 9.0 ± 0.5 3.5± 0.3 0.55 ± 0.05 12.5 ± 1 10.0 ± 1 KNP100 KNP2WS KNP3SS 11.5 ± 1.0 4.6 ± 0.5 0.8 ± 0.05 15.0 ± 1 12.5 ± 1 KNP200 KNP3WS 15.5 ± 1.0 5.2 ± 0.5 0.8 ± 0.05 20.0 ± 1 15.0 ± 1 KNP300 KNP400 KNP5WS 17.5 ± 1.0 6.2 ± 0.5 0.8 ± 0.05 25.0 ± 1 15.0 ± 1 KNP500 KNP600 KNP7WS 24.5 ± 1.0 8.2 ± 0.5 0.8 ± 0.05 30.0 ± 1 15.0 ± 1 www.yageo.com Aug. 13, 2021 V.0 15 Through Hole Resistors WireWound Resistors Product Specification 22 KNP MB TYPE TYPE DIMENSIONS Unit: mm Normal Miniature L ψD ψd P H1 H2 t KNP-25 KNP50S 6.3 ± 0.5 2.5 ± 0.3 0.55 ± 0.05 10.0 ± 1 6.0 ± 1 5.0 ± 1 1.2 ± 0.2 KNP-50 - 9.0 ± 0.5 3.5± 0.3 0.55 ± 0.05 12.5 ± 1 6.0 ± 1 5.0 ± 1 1.2 ± 0.2 - KNP1WS 9.0 ± 0.5 3.5± 0.3 0.8 ± 0.05 12.5 ± 1 6.0 ± 1 5.0 ± 1 1.4 ± 0.2 KNP100 KNP2WS KNP3SS 11.5 ± 1.0 4.6 ± 0.5 0.8 ± 0.05 15.0 ± 1 6.0 ± 1 5.0 ± 1 1.4 ± 0.2 KNP200 KNP3WS 15.5 ± 1.0 5.2 ± 0.5 0.8 ± 0.05 20.0 ± 1 10.0 ± 1 5.0 ± 1 1.4 ± 0.2 KNP300 KNP400 KNP5WS 17.5 ± 1.0 6.2 ± 0.5 0.8 ± 0.05 30.0 ± 1 15.0 ± 1 5.0 ± 1 1.4 ± 0.2 KNP500 KNP600 KNP7WS 24.5 ± 1.0 8.2 ± 0.5 0.8 ± 0.05 30.0 ± 1 15.0 ± 1 5.0 ± 1 1.4 ± 0.2 www.yageo.com Aug. 13, 2021 V.0 16 Through Hole Resistors Product Specification WireWound Resistors 17 22 KNP MHA TYPE TYPE DIMENSIONS Normal Miniature KNP-50 KNP1WS Unit: mm L ψD ψd B H0 HI P P0 9.0±0.5 3.5±0.3 0.55±0.05 17.5Max 19.0±1.0 4.0±1.0 30.0±1.0 15.0±0.3 P1 P2 F W W0 W1 ΨD0 7.5±1.0 3.75±0.5 7.5±0.5 18.0±0.5 5.0Min 9.0±0.5 4.0±0.2 MHB TYPE TYPE Normal DIMENSIONS Miniature L 15.5±1.0 KNP200 KNP3WS P 30.0±1.0 Unit: mm ψD ψd B 5.2±0.5 0.8±0.05 P0 15.0±0.3 H H0 HI H2 H3 21.0Max. 30Max. 18.0±1.0 5.5(Ref.) 8.0±1.5 16Max. PI P2 F W W0 W1 ΨD0 7.5±1.0 3.75±0.8 7.5±0.5 18.0±0.5 5.0Min. 9.0±0.5 4.0±0.3 www.yageo.com Aug. 13, 2021 V.0 Through Hole Resistors Product Specification WireWound Resistors 22 KNP MHC TYPE TYPE DIMENSIONS Normal Miniature L KNP200 KNP3WS Unit: mm ψD ψd B H HI P P0 15.5±1.0 5.2±0.5 0.8±0.05 21.0Max. 19.0±1.0 5.25±1.0 30.0±1.0 15.0±0.3 F W W0 W1 ΨD0 10.0±0.5 18.0±0.5 5.0Min. 9.0±0.5 4.0±0.2 F TYPE FK TYPE TYPE FFK TYPE FKK TYPE DIMENSIONS Unit: mm H HI E Max. Max. 5±1 18.5 3.5 3.5±1 24 5±1 20 3.5 3.5±1 28 5± 1 25 3.5 3.5±1 Normal Miniature L ψD ψd P h KNP-50 KNP1WS 9.0±0.5 3.5±0.3 0.55±0.05 6±1 8±1 22 KNP100 KNP2WS 11.5±1 4.6±0.5 0.8±0.05 6±1 8±1 KNP200 KNP3WS 15.5±1 5.2±0.5 0.8±0.05 8±1 8±1 Max. hl e www.yageo.com Aug. 13, 2021 V.0 18 Through Hole Resistors WireWound Resistors Product Specification TYPE 22 KNP PN TYPE (Taping Pack) AV TYPE (Taping Pac ) DIMENSIONS Unit: mm Normal Miniature H1 Max. H2 Max. H3 Max. KNP-25 KNP50S 13 21.5 8.5 KNP-50 KNP1WS 17 25.5 8.5 KNP100 KNP2WS KNP3SS 19 27.5 8.5 TYPE DIMENSIONS Unit: mm Normal Miniature H1 Max. H2 Max. H3 Max. KNP-25 KNP50S 11.5 20 8.5 KNP-50 KNP1WS 14.5 23 8.5 KNP100 KNP2WS KNP3SS 17.5 26 8.5 FT TYPE (Taping Pack) TYPE DIMENSIONS Unit: mm Normal Miniature H1 Max. H2 Max. H3 Max. KNP-25 KNP50S 10 18.5 8.5 KNP-50 KNP1WS 13 21.5 8.5 KNP100 KNP2WS KNP3SS 16 24.5 8.5 www.yageo.com Aug. 13, 2021 V.0 19 Through Hole Resistors Product Specification WireWound Resistors 22 KNP MARKING 4-BAND-CODE ±2%, ±5% COLOR BLACK BROWN RED ORANGE YELLOW GREEN BLUE VIOLET GREY WHITE GOLD SILVER 1st BAND 0 1 2 3 4 5 6 7 8 9 2nd BAND 0 1 2 3 4 5 6 7 8 9 3rd BAND 0 1 2 3 4 5 6 7 8 9 MULTIPLIER 1Ω 10Ω 100Ω 1KΩ 10KΩ 100K 1MΩ 10MΩ 0.001Ω 0.0001Ω 0.1Ω 0.01Ω TOLERANCE ± 1% ( F ) ± 2% ( G ) ±5%(J) ±1% 5-BAND-CODE www.yageo.com Aug. 13, 2021 V.0 20 Through Hole Resistors WireWound Resistors Product Specification 22 KNP REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 0 Aug. 2, 2021 - - First issue of this specification “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itse lf are unchanged. Any product change will be announced by PCN.” www.yageo.com Aug. 13, 2021 V.0 21 Through Hole Resistors WireWound Resistors Product Specification 22 KNP LEGAL DISCLAIMER Yageo, its distributors and agents (collectively, “Yageo”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. Yageo may make changes, modifications and/or improvements to product related information at any time and without notice. Yageo makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum extent permitted by law, Yageo disclaims (i) any and all liability arising out of the application or use of any Yageo product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non-infringement and merchantability. Yageo statements regarding the suitability of products for certain types of applications are based on Yageo’s knowledge of typical operating conditions for such types of applications in a generic nature. Such statements are neither binding statements of Yageo nor intended to constitute any warranty concerning the suitability for a specific customer application or use. They are intended for use only by customers with requisite knowledge and experience for determining whether Yageo products are the correct products for their application or use. In addition, unpredicatable and isolated cases of product failure may still occur, therefore, customer application or use of Yageo products which requires higher degree of reliability or safety, shall employ additional protective safeguard measures to ensure that product failure would not result in personal injury or property damage. Yageo products are not designed for application or use in medical, life-saving, or life-sustaining devices or for any other application or use in which the failure of Yageo products could result in personal injury or death. Customers using or selling Yageo products not expressly indicated for above-mentioned purposes shall do so at their own risk and agree to fully indemnify Yageo and hold Yageo harmless. Information provided here is intended to indicate product specifications only. Yageo reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com Aug. 13, 2021 V.0 22
KNP700JB-91-0R12 价格&库存
很抱歉,暂时无法提供与“KNP700JB-91-0R12”相匹配的价格&库存,您可以联系我们找货
