SMCJ5.0(A) – SMCJ170(A)
Taiwan Semiconductor
1500W, 5V - 170V Surface Mount Transient Voltage Suppressor
FEATURES
KEY PARAMETERS
Ideal for automated placement
Glass passivated chip junction
Excellent clamping capability
Meets ISO 7637-2 (Pulse 1/2a/2b/3a/3b)
Fast response time: Typically less than
1.0ps from 0 V to BV min
Typical IR less than 1μA above 10V
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
VWM
5 - 170
V
VBR
6.4 - 231
V
PPK
1500
W
TJ MAX
150
°C
Package
DO-214AB (SMC)
Configuration
Single die
APPLICATIONS
Protect sensitive circuit from damage by high voltage transients
Lighting, ESD transient voltage protection of IC, system
Inductive switching load protection of IC, system
Electrical Fast Transient Immunity protection of IC, system
MECHANICAL DATA
Case: DO-214AB (SMC)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 0.210g (approximately)
DO-214AB (SMC)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
VALUE
UNIT
PPK
1500
W
PD
5
W
IFSM
200
A
VF
3.5 / 5.0
V
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
Peak power dissipation at TA = 25°C, tp = 1ms
(1)
Steady state power dissipation at T A = 25°C
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load
(2)
Forward Voltage @ IF = 100A for Unidirectional only
Notes:
1. Non-repetitive current pulse per Fig.5 and derated above TA = 25°C per Fig.2
2. VF = 3.5V on SMCJ5.0 - SMCJ90 devices and VF = 5.0V on SMCJ100 - SMCJ170 devices
Devices for bipolar applications
1. For bidirectional use C or CA suffix for types SMCJ5.0 - types SMCJ170
2. Electrical characteristics apply in both directions
1
Version: S2104
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-ambient thermal resistance
RӨJA
55
°C/W
Junction-to-case thermal resistance
RӨJC
10
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
Part number
SMCJ5.0
SMCJ5.0A
SMCJ5V0A
SMCJ6.0
SMCJ6.0A
SMCJ6V0A
SMCJ6.5
SMCJ6.5A
SMCJ6V5A
SMCJ7.0
SMCJ7.0A
SMCJ7V0A
SMCJ7.5
SMCJ7.5A
SMCJ7V5A
SMCJ8.0
SMCJ8.0A
SMCJ8V0A
SMCJ8.5
SMCJ8.5A
SMCJ8V5A
SMCJ9.0
SMCJ9.0A
SMCJ9V0A
SMCJ10
SMCJ10A
SMCJ11
SMCJ11A
SMCJ12
SMCJ12A
SMCJ13
SMCJ13A
SMCJ14
SMCJ14A
SMCJ15
SMCJ15A
SMCJ16
SMCJ16A
SMCJ17
SMCJ17A
SMCJ18
SMCJ18A
SMCJ20
SMCJ20A
SMCJ22
SMCJ22A
SMCJ24
SMCJ24A
Marking
code
Breakdown voltage
VBR@IT
(V)
Test
current
IT
(mA)
Working
stand-off
voltage
VWM
(V)
Maximum
Maximum
peak impulse
Reverse
current
Leakage
(Note 2)
(Note 3)
IPPM
IR@VWM (µA)
(A)
Maximum
clamping
voltage
(Note 2)
VC@IPPM
(V)
GDD
Min
6.4
Max
7.3
10
5
1000
164
9.6
GDE
6.4
7
10
5
1000
171
9.2
GDF
6.67
8.15
10
6
1000
138
11.4
GDG
6.67
7.37
10
6
1000
152
10.3
GDH
7.22
8.82
10
6.5
500
128
12.3
GDK
7.22
7.98
10
6.5
500
140
11.2
GDL
7.78
9.51
10
7
200
118
13.3
GDM
7.78
8.6
10
7
200
131
12.0
GDN
8.33
10.30
1
7.5
100
110
14.3
GDP
8.33
9.21
1
7.5
100
122
12.9
GDQ
8.89
10.9
1
8
50
105
15.0
GDR
8.89
9.83
1
8
50
115
13.6
GDS
9.44
11.5
1
8.5
15.9
GDT
9.44
10.4
1
8.5
14.4
GDU
10
12.2
1
9
10
93
16.9
GDV
10
11.1
1
9
10
102
15.4
GDW
GDX
GDY
GDZ
GED
GEE
GEF
GEG
GEH
GEK
GEL
GEM
GEN
GEP
GEQ
GER
GES
GET
GEU
GEV
GEW
GEX
GEY
GEZ
11.1
11.1
12.2
12.2
13.3
13.3
14.4
14.4
15.6
15.6
16.7
16.7
17.8
17.8
18.9
18.9
22.2
24.4
24.4
26.7
26.7
13.6
12.3
14.9
13.5
16.3
14.7
17.6
15.9
19.1
17.2
20.4
18.5
21.8
19.7
23.1
20.9
24.4
22.1
27.1
24.5
29.8
26.9
32.6
29.5
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
10
10
11
11
12
12
13
13
14
14
15
15
16
16
17
17
18
18
22
24
24
5
5
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
83
92
78
86
71
79
66
73
61
67
58
64
54
60
51
57
48
53
43
48
39
44
36
40
18.8
17.0
20.1
18.2
22.0
19.9
23.8
21.5
25.8
23.2
26.9
24.4
28.8
26.0
30.5
27.6
32.2
29.2
35.8
32.4
39.4
35.5
43.0
38.9
2
Version: S2104
Part number
SMCJ26
SMCJ26A
SMCJ28
SMCJ28A
SMCJ30
SMCJ30A
SMCJ33
SMCJ33A
SMCJ36
SMCJ36A
SMCJ40
SMCJ40A
SMCJ43
SMCJ43A
SMCJ45
SMCJ45A
SMCJ48
SMCJ48A
SMCJ51
SMCJ51A
SMCJ54
SMCJ54A
SMCJ58
SMCJ58A
SMCJ60
SMCJ60A
SMCJ64
SMCJ64A
SMCJ70
SMCJ70A
SMCJ75
SMCJ75A
SMCJ78
SMCJ78A
SMCJ85
SMCJ85A
SMCJ90
SMCJ90A
SMCJ100
SMCJ100A
SMCJ110
SMCJ110A
SMCJ120
SMCJ120A
SMCJ130
SMCJ130A
SMCJ150
SMCJ150A
SMCJ160
SMCJ160A
SMCJ170
SMCJ170A
Marking
code
GFD
GFE
GFF
GFG
GFH
GFK
GFL
GFM
GFN
GFP
GFQ
GFR
GFS
GFT
GFU
GFV
GFW
GFX
GFY
GFZ
GGD
GGE
GGF
GGG
GGH
GGK
GGL
GGM
GGN
GGP
GGQ
GGR
GGS
GGT
GGU
GGV
GGW
GGX
GGY
GGZ
GHD
GHE
GHF
GHG
GHH
GHK
GHL
GHM
GHN
GHP
GHQ
GHR
Breakdown voltage
VBR@IT
(V)
Min
28.9
28.9
31.1
31.1
33.3
33.3
36.7
36.7
40
40
44.4
44.4
47.8
47.8
50
50
53.3
53.3
56.7
56.7
60
60
64.4
64.4
66.7
66.7
71.1
71.1
77.8
77.8
83.3
83.3
86.7
86.7
94.4
94.4
100
100
111
111
122
122
133
133
144
144
167
167
178
178
189
189
Max
35.3
31.9
38
34.4
40.7
36.8
44.9
40.6
48.9
44.2
54.3
49.1
58.4
52.8
61.1
55.3
65.1
58.9
69.3
62.7
73.3
66.3
78.7
71.2
81.5
73.7
86.9
78.6
95.1
86
102
92.1
106
95.8
115
104
122
111
136
123
149
135
163
147
176
159
204
185
218
197
231
209
Test
current
IT
(mA)
Working
stand-off
voltage
VWM
(V)
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
26
26
28
28
30
30
33
33
36
36
40
40
43
43
45
45
48
48
51
51
54
54
58
58
60
60
64
64
70
70
75
75
78
78
85
85
90
90
100
100
110
110
120
120
130
130
150
150
160
160
170
170
3
Maximum
Maximum
peak impulse
Reverse
current
Leakage
(Note 2)
(Note 3)
IPPM
IR@VWM (µA)
(A)
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
33
37
31
34
29
32
26
29
24
27
22
24
19
21
18
19
16
18
15
16
14
16
13.8
15
12.6
13.9
11.7
13
11.3
12.5
10.4
11.5
9.8
10.7
8.8
9.7
8
8.9
7.3
8.1
6.8
7.5
5.8
6.4
5.4
6
5.1
5.7
Maximum
clamping
voltage
(Note 2)
VC@IPPM
(V)
46.6
42.1
50.0
45.4
53.5
48.4
59.0
53.3
64.3
58.1
71.4
64.5
76.7
69.4
80.3
72.7
85.5
77.4
91.1
82.4
96.3
87.1
103
93.6
107
96.8
114
103
125
113
134
121
139
126
151
137
160
146
179
162
196
177
214
193
231
209
266
243
287
259
304
275
Version: S2104
Notes:
1. VBR measure after IT applied for 30ms, IT = square wave pulse or equivalent
2. Surge current waveform per Fig.5 and derate per Fig.2
3. For bipolar types having VWM of 10V and under, the IR limit is doubled
4. All terms and symbols are consistent with ANSI/IEEE C62.35
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
SMCJx
DO-214AB (SMC)
3,000 / Tape & Reel
Notes:
1. “x” defines voltage from 5V(SMCJ5.0) to 170V(SMCJ170)
4
Version: S2104
CHARACTERISTICS CURVES
Fig.1 Peak Pulse Power Rating Curve
Fig.2 Pulse Derating Curve
PEAK PULSE POWER(PPP) OR CURRENT (IPP)
DERATING IN PERCENTAGE (%)
PPPM, PEAK PULSE POWER (kW)
100
NON-REPETITIVE
PULSE WAVEFORM
SHOWN in Fig.5
10
1
0.1
0.1
1
10
100
1000
125
100
75
50
25
Fig.3 Typical Junction Capacitance
IFSM, PEAK FORWARD SURGE CURRENT (A)
CJ, JUNCTION CAPACITANCE (pF)
UNIDIRECTIONAL
BIDRECTIONA
10000
VR=0
100
VR-rated
stand-off voltage
10
1
75
100
125
150
Fig.4 Maximum Non-repetitive Forward Surge
Current
100000
f=1.0MHz
Vsig=50mVp-p
50
TA, AMBIENT TEMPERATURE (°C)
tp, PULSE WIDTH, (μs)
1000
25
10
1000
8.3ms single half sine wave
Unidirectional only
100
10
1
1
100
10
100
NUMBER OF CYCLES AT 60 Hz
V(BR), BREAKDOWN VOLTAGE (V)
5
Version: S2104
Fig.5 Clamping Power Pulse Waveform
120
IPPM, PEAK PULSE CURRENT (%)
110
Peak value
IPPM
100
Pulse width(td) is defined
as the point where the peak
current decays to 50% of IPPM
90
Rise time tr=10μs to 100% of IPPM
80
70
Half value-IPPM/2
10/1000μs, waveform
as defined by R.E.A.
60
50
40
30
td
10
1
1.5
2
2.5
3
3.5
4
4.5
5
t, TIME (ms)
6
Version: S2104
PACKAGE OUTLINE DIMENSIONS
DO-214AB (SMC)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Cathode band for uni-directional products only
7
Version: S2104
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
8
Version: S2104
很抱歉,暂时无法提供与“SMCJ6V0CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+9.251161+1.19913
- 10+5.7638510+0.74711
- 100+3.75375100+0.48656
- 500+2.88967500+0.37456
- 1000+2.611081000+0.33845
- 国内价格 香港价格
- 3000+2.257053000+0.29256
- 6000+2.078826000+0.26946
- 9000+1.987989000+0.25768
- 15000+1.8859415000+0.24446
- 21000+1.8255221000+0.23663
- 30000+1.7668130000+0.22902
