ESD9N5BL-2/TR
ESD9N5BL-2/TR
    WILLSEMI(韦尔)
    DFN1006-2
    双向TVS 5V截止 峰值浪涌电流:3A@8/20US
ESD9N5BL-2/TR 数据手册
ESD9N5BL ESD9N5BL 1-Line, Bi-directional, Transient Voltage Suppressor http//:www.sh-willsemi.com Descriptions The ESD9N5BL is a bi-directional TVS (Transient Voltage Suppressor). It is specifically designed to protect sensitive electronic components which are connected to low speed data lines and control lines from over-stress caused by ESD (Electrostatic Discharge), EFT (Electrical Fast Transients) and Lightning. DFN1006-2L (Bottom View) The ESD9N5BL may be used to provide ESD protection up to ±20kV (contact and air discharge) according to IEC61000-4-2, and withstand peak pulse current up to 3A (8/20μs) according to IEC61000-4-5. Pin1 Pin2 The ESD9N5BL is available in DFN1006-2L package. Standard products are Pb-free and Halogen-free. Circuit diagram Features  Reverse stand-off voltage: ±5V Max  Transient protection for each line according to IEC61000-4-2 (ESD): ±20kV (contact and air discharge) IEC61000-4-4 (EFT): 20A (5/50ns) IEC61000-4-5 (surge): 3A (8/20μs) * = Month code (A~Z)  Capacitance: CJ = 5.0pF typ.  Low leakage current: IR < 1nA typ.  Low clamping voltage: VCL = 13V typ. @ IPP = 16A (TLP)  Solid-state silicon technology .B=Device Code Marking (Top View) Order information Applications  Cellular handsets  Tablets  Laptops  Other portable devices  Network communication devices Will Semiconductor Ltd. 1 Device Package Shipping ESD9N5BL-2/TR DN1006-2L 10000/Tape&Reel Revision 1.4, 2015/07/01 ESD9N5BL Absolute maximum ratings Parameter Symbol Rating Unit Peak pulse power (tp = 8/20μs) Ppk 33 W Peak pulse current (tp = 8/20μs) IPP 3 A ESD according to IEC61000-4-2 air discharge VESD ESD according to IEC61000-4-2 contact discharge Junction temperature TJ Operating temperature TOP Lead temperature TL Storage temperature TSTG ±20 ±20 kV 125 o -40~85 o 260 o -55~150 o C C C C Electrical characteristics (TA=25 oC, unless otherwise noted) Definitions of electrical characteristics Will Semiconductor Ltd. 2 Revision 1.4, 2015/07/01 ESD9N5BL o Electrical characteristics (TA=25 C, unless otherwise noted) Parameter Symbol Condition Min. Typ. Max. Unit ±5 V 100 nA Reverse stand-off voltage VRWM Reverse leakage current IR VRWM = 5V VBR IBR = 1mA 5.1 V IHOLD = 50mA 5.1 V Reverse breakdown voltage Reverse holding voltage VHOLD
ESD9N5BL-2/TR
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出等。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换和分配,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
