JST180N30D5
JST180N30D5
    JESTEK(吉思泰)
    PDFNWB-8(5x6)
JST180N30D5 数据手册
JST180N30D5 30V N-Channel Mosfet PDFNWB5*6-8L FEATURES ● RDS(ON) < 2.4mΩ @ VGS = 10V ● RDS(ON) < 3.3mΩ @ VGS = 4.5V APPLICATIONS  Load Switch  PWM Application  Power management MARKING 1: S 3: S 5: D 7: D 2: S 4: G 6: D 8: D N-CHANNEL MOSFET YYMM:Date Code(year&month) Maximum ratings (TC=25℃ unless otherwise noted) Symbol bol Parameter Max. Units VDSS Drain-Source Voltage 30 V VGSS Gate-Source Voltage ±20 V TC = 25℃ 115 A TC = 100℃ 72 460 A 240 mJ 70 W 1.78 ℃/W -55 to +150 ℃ ID Continuous Drain Current IDM Pulsed Drain Current EAS Single Pulsed Avalanche Energy PD Power Dissipation RθJC TJ, TSTG note1 note2 TC = 25℃ Thermal Resistance, Junction to Case Operating and Storage Temperature Range A 1/6 JST180N30D5 MOSFET ELECTRICAL CHARACTERISTICS Tc=25 ℃ unless otherwise specified Symbol bol Parameter Test Condition Min. Typ. Max. Units Off Characteristic V(BR)DSS Drain-Source Breakdown Voltage VGS = 0V,ID = 250μA A 30 - - V IDSS Zero Gate Voltage Drain Current VDS =30V, VGS = 0V - - 1 μA IGSS Gate to Body Leakage Current VGS = ±20V, VDS = 0V - - ±100 nA V On Characteristics VGS(th) Gate Threshold Voltage VDS=VGS, ID = 250μA 1 1.6 2.5 RDS(on) Static Drain-Source On-Resistance VGS =10V, ID =30A - 1.9 2.4 note3 VGS =4.5V, ID =15A - 2.5 3.3 - 4800 - pF - 735 - pF - 420 - pF - 40 - nC - 6 - nC - 19 - nC - 20 - ns - 32 - ns - 75 - ns - 28 - ns mΩ Dynamic Characteristics Ciss Input Capacitance Coss Output Capacitance Crss Reverse Transfer Capacitance Qg Total Gate Charge Qgs Gate-Source Charge Qgd Gate-Drain(“Miller”) Charge VDS =25V, VGS = 0V, f = 1.0MHz VDS=15V, ID =24A, VGS =4.5V Switching Characteristics td(on) Turn-On Delay Time tr Turn-On Rise Time td(off) Turn-Off Delay Time tf VDS =15V, ID=1A, RG= 1Ω, VGS =10V Turn-Off Fall Time Drain-Source Diode Characteristics and Maximum Ratings IS Maximum Continuous Drain to Source Diode Forward Current - - 115 A ISM Maximum Pulsed Drain to Source Diode Forward Current - - 230 A VSD Drain to Source Diode Forward Voltage VGS = 0V, ISD=30A, TJ = 25℃ - - 1.2 V trr Reverse Recovery Time - 49 85 ns Qrr Reverse Recovery Charge TJ= 25°C, IS=1A, di/dt =100A/μs - 18 35 nC Notes: 1. Repetitive Rating: Pulse width limited by maximum junction temperature 2 . TJ=25℃,VDD=25V,VG=10V, RG=25Ω 3 . Pulse Test: Pulse width ≤ 380μs, Duty Cycle ≤ 2% 2/6 JST180N30D5 Typical Characteristics Figure1. Output Characteristics Figure3. Rdson-Drain Current Figure5. Capacitance Characteristics Figure2. Transfer Characteristics Figure4. Typical Source-Drain Diode Forward Voltage Figure6. Gate Charge 3/6 JST180N30D5 Figure7. Normalized Breakdown Voltage vs. Temperature Figure9. Safe Operation Area Figure8. Normalized on Resistance vs. Temperature Figure10. Maximum Drain Current vs. Case Temperature Figure11. Transient Thermal Response Curve 4/6 JST180N30D5 Figure 1. Gate Charge Test Circuit & Waveform Figure 2. Resistive Switching Test Circuit & Waveforms Figure 3. Unclamped Inductive Switching Test Circuit & Waveforms 5/6 JST180N30D5 Package Outline Dimensions Symbol A A1 A2 D D1 E E1 E2 b e L L1 L2 L3 H θ Dimensions In Millimeters Min. Max. 0.650 0.850 0.152 REF. 0~0.05 2.900 3.100 2.300 2.600 2.900 3.100 3.150 3.450 1.535 1.935 0.200 0.400 0.550 0.750 0.300 0.500 0.180 0.480 0~0.100 0~0.100 0.315 0.515 9° 13° Dimensions In Inches Min. Max. 0.026 0.033 0.006 REF. 0~0.002 0.114 0.122 0.091 0.102 0.114 0.122 0.124 0.136 0.060 0.076 0.008 0.016 0.022 0.030 0.012 0.020 0.007 0.019 0~0.004 0~0.004 0.012 0.020 9° 13° 6/6
JST180N30D5 价格&库存
很抱歉,暂时无法提供与“JST180N30D5”相匹配的价格&库存,您可以联系我们找货
