SMCJ58CA
SMCJ58CA
    YJSEMI(元捷)
    SMCJ58CA
SMCJ58CA 数据手册
山东元捷电子科技 Shan dong YuanJie Electronic Technology Technical Information SMCJ SERIES Surface Mount Transient Voltage Suppressor Diodes )HDWXUHV ƹ Excellent clamping capability ◆ Low dynamic impedance ◆ Solder dip 260 °C max. 10 s, per JESD 22-B106 0HFKDQLFDO'DWD &DVHDO-214AB (SMC) Molded plastic body Terminals: Tin plated leads, solderable per J-STD- 002 and JESD22-B102 0RXQWLQJ3RVLWLRQAny 0D[LPXP5DWLQJV (OHFWULFDO&KDUDFWHULVWLFV Ratings at TA = 25°C unless otherwise specified PARAMETER SYMBOL Peak power dissipation, with a 10/1000us waveform(1)(2 ) Power dissipation, on infinite heat sink at TL=75℃(2) Peak forward surge current, 8.3 ms single half sine-wave unidirectional only (3) Operating junction and storage temperature range Maximum instantaneous forward voltage at 100A for unidirectional only(4) Junction to ambient Junction to lead Notes: (1) (2) (3) (4) (5) UNIT Max PPPM W 1500 PD W 6.5 IFSM A 200 TJ,TST G ℃ -55 to +150 VFM V 3.5/5.0 RθJ-A ℃/W 75 RθJ-L ℃/W 15 Non-repetitive current pulse, per Fig. 3 and derated above TA= 25℃per Fig.2. Mounted on 0.31 x 0.31" (8.0 x 8.0 mm) copper pads to each terminal Measured on 8.3ms single half sine-wave or equivalent square wave,duty cycle=4 pulses per minute maximum. VF=3.5V Max for devices of VBR≤220v,and VF=5.0v Max for devices of VBR>220v. Mounted on minimum recommended pad layout. Revision:2018-12-12 1 www.yjsemi.com.cn 山东元捷电子科技 Technical Information Shandong YuanJie Electronic Technology SMCJ SERIES Surface Mount Transient Voltage Suppressor Diodes Transient Voltage Suppressors-SMD Part No. SMCJ5.0A SMCJ6.0A SMCJ6.5A SMCJ7.0A SMCJ7.5A SMCJ8.0A SMCJ8.5A SMCJ9.0A SMCJ10A SMCJ11A SMCJ12A SMCJ13A SMCJ14A SMCJ15A SMCJ16A SMCJ17A SMCJ18A SMCJ19A SMCJ20A SMCJ22A SMCJ24A SMCJ26A SMCJ28A SMCJ30A SMCJ33A SMCJ36A SMCJ40A SMCJ43A SMCJ45A SMCJ48A SMCJ51A SMCJ54A SMCJ58A SMCJ60A SMCJ64A SMCJ70A SMCJ75A SMCJ78A SMCJ80A SMCJ85A SMCJ90A SMCJ100A SMCJ110A SMCJ120A SMCJ130A SMCJ140A SMCJ150A SMCJ160A SMCJ170A SMCJ180A SMCJ190A SMCJ200A SMCJ220A SMCJ250A SMCJ300A SMCJ350A SMCJ400A SMCJ440A SMCJ5.0CA SMCJ6.0CA SMCJ6.5CA SMCJ7.0CA SMCJ7.5CA SMCJ8.0CA SMCJ8.5CA SMCJ9.0CA SMCJ10CA SMCJ11CA SMCJ12CA SMCJ13CA SMCJ14CA SMCJ15CA SMCJ16CA SMCJ17CA SMCJ18CA SMCJ19CA SMCJ20CA SMCJ22CA SMCJ24CA SMCJ26CA SMCJ28CA SMCJ30CA SMCJ33CA SMCJ36CA SMCJ40CA SMCJ43CA SMCJ45CA SMCJ48CA SMCJ51CA SMCJ54CA SMCJ58CA SMCJ60CA SMCJ64CA SMCJ70CA SMCJ75CA SMCJ78CA SMCJ80CA SMCJ85CA SMCJ90CA SMCJ100CA SMCJ110CA SMCJ120CA SMCJ130CA SMCJ140CA SMCJ150CA SMCJ160CA SMCJ170CA SMCJ180CA SMCJ190CA SMCJ200CA SMCJ220CA SMCJ250CA SMCJ300CA SMCJ350CA SMCJ400CA SMCJ440CA Revision:2018-12-12 Peak Power Dissipation 10/1000μ sec(W) Reverse Stand-Off Voltage VRWM(V) Breakdown Voltage VBR (V) Min @ IT Breakdown Voltage VBR (V) Max @ IT Test Current IT (mA) Max Clamping Voltage VC (V)@ IPP Peak Pulse Current IPP (A) Reverse Leakage IR (μA) @ VRWM 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 1500 5.0 6.0 6.5 7.0 7.5 8.0 8.5 9.0 10 11 12 13 14 15 16 17 18 19 20 22 24 26 28 30 33 36 40 43 45 48 51 54 58 60 64 70 75 78 80 85 90 100 110 120 130 140 150 160 170 180 190 200 220 250 300 350 400 440 6.40 6.67 7.22 7.78 8.33 8.89 9.44 10.0 11.1 12.2 13.3 14.4 15.6 16.7 17.8 18.9 20.0 21.1 22.2 24.4 26.7 28.9 31.1 33.3 36.7 40.0 44.4 47.8 50.0 53.3 56.7 60.0 64.4 66.7 71.1 77.8 83.3 86.7 88.8 94.4 100 111 122 133 144 155 167 178 189 200 211 224 246 279 335 391 447 492 7.00 7.37 7.98 8.60 9.21 9.83 10.4 11.1 12.3 13.5 14.7 15.9 17.2 18.5 19.7 20.9 22.1 23.3 24.5 26.9 29.5 31.9 34.4 36.8 40.6 44.2 49.1 52.8 55.3 58.9 62.7 66.3 71.2 73.7 78.6 86.0 92.1 95.8 97.6 104 111 123 135 147 159 171 185 197 209 220 232 247 272 309 371 432 494 543 10 10 10 10 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 9.2 10.3 11.2 12.0 12.9 13.6 14.4 15.4 17.0 18.2 19.9 21.5 23.2 24.4 26.0 27.6 29.2 30.8 32.4 35.5 38.9 42.1 45.4 48.4 53.3 58.1 64.5 69.4 72.7 77.4 82.4 87.1 93.6 96.8 103.0 113.0 121.0 126.0 129.6 137.0 146.0 162.0 177.0 193.0 209.0 226.8 243.0 259.0 275.0 291.6 307.8 324.0 356.0 405.0 486.0 567.0 648.0 713.0 163.04 145.63 133.93 125.00 116.28 110.29 104.17 97.40 88.24 82.42 75.38 69.77 64.66 61.48 57.69 54.35 51.37 48.73 46.30 42.25 38.56 35.63 33.04 30.99 28.14 25.82 23.26 21.61 20.63 19.38 18.20 17.22 16.03 15.50 14.56 13.27 12.40 11.90 11.57 10.95 10.27 9.26 8.47 7.77 7.18 6.61 6.17 5.79 5.45 5.14 4.87 4.6 4.2 3.7 3.1 2.6 2.3 2.1 1000 1000 500 200 100 50 20 10 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 2 www.yjsemi.com.cn 山东元捷电子科技 Technical Information Shandong YuanJie Electronic Technology SMCJ SERIES Surface Mount Transient Voltage Suppressor Diodes  Typical Characteristics FIG2: Pulse Power or Current vs. Initial Junction Temperature PPP or IPP(%) PPPM(KW) FIG1:Peak Pulse Power Rating Curve 100 Non-Repetitive Pulse Waveform shown in Fige.3 TA=25℃ 100 75 10 50 1.0 25 0.1 0.31×0.31"(8.0×8.0mm) Copper Pad Areas 0.1μs 1μs 0 10μs 100μs 1.0ms 10ms 0 25 50 75 100 125 150 175 TJ (℃) td(μs) tr=10μs Peak Value IPPM 100 FIG4:Typical Transient Thermal Impedance Rth(℃/W) IPPM(%) FIG3: Pulse Waveform 150 200 TJ=25℃ Pulse Width(td) is defined as the Point where the Peak Current Decays to 50% of IPPM 100 10 Half Value - IPP 2 IPPM 50 1 10/1000μs Waveform as Defined by R.E.A. td 0 0 1.0 2.0 3.0 0.1 0.001 4.0 0.01 0.1 1 100 10 t( ms) tp(s) PD(W) IFSM(A) FIG5: Maximum Non-Repetitive Surge Current 200 1000 TJ=TJMax. 8.3ms Single Half Sine-Wave FIG6:Steady State Power Dissipation 7 6 100 5 4 50 3 2 1 10 0 0 0 Revision:2018-12-12 10 100 Number of Cycles 3 25 50 75 100 125 150 175 200 TL(℃) www.yjsemi.com.cn 山东元捷电子科技 Technical Information Shandong YuanJie Electronic Technology SMCJ SERIES Surface Mount Transient Voltage Suppressor Diodes  3DFNDJH2XWOLQH'LPHQVLRQV(unit:mm) DO-214AB (SMC) 0RXQWLQJ3DG/D\RXW(unit:mm) 3 4 3 4 3 Revision:2018-12-12 4 Dim Millimeters 3 98 3 6.80 3 38 4 3.00 4 4.00 www.yjsemi.com.cn
SMCJ58CA 价格&库存
很抱歉,暂时无法提供与“SMCJ58CA”相匹配的价格&库存,您可以联系我们找货
