Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/05/2022
page 1 of 4
MODEL: UJC-HP-G-SMT-TR | DESCRIPTION: USB RECEPTACLE
FEATURES
• USB Type C receptacle
• mates with standard USB Type C plugs
• designed for power only applications
• 8-pin
• reflow solder compatible
• tape & reel packaging
SPECIFICATIONS
parameter
conditions/description
min
typ
rated input voltage
rated input current
as per EIA-364-70, Method B
VBUS pins collectively (A4, A9, B4, B9)
GND pins individually (A1, A12, B1, B12)
contact resistance1
insulation resistance
at 500 Vdc for 1 minute between adjacent contacts
voltage withstand
insertion force
at a rate of 12.5 mm/min
5
withdrawal force
8
life
at a rate of 500 ± 50 cycles per hour
RoHS
yes
Note:
Vdc
5
1.25
A
A
40
mΩ
MΩ
100
Vac
N
-25
UL94V-0
units
operating temperature
flammability rating
max
N
cycles
85
°C
1. When measured at 20 mV / 100 mA max.
2. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted.
SOLDERABILITY
parameter
reel storage
at relative humidity
很抱歉,暂时无法提供与“UJC-HP-G-SMT-TR”相匹配的价格&库存,您可以联系我们找货
