QS20.241
QS20.241
    PULS
    QS20.241
QS20.241 数据手册
QS20.241, QS20.241-A1, QS20.241-C1 24V, 20A, SINGLE PHASE INPUT Q-Series POWER SUPPLY                AC 100-240V Wide-range Input Width only 82mm Efficiency up to 93.9% ATEX and IECEx Approved (-A1 Version) -C1 Version with Conformal Coated PC-board 150% (720W) Peak Load Capability Safe HiccupPLUS Overload Mode Easy Fuse Tripping due to High Overload Current Active Power Factor Correction (PFC) Negligible low Inrush Current Surge Short-term Operation down to 60Vac and up to 300Vac Full Power Between -25°C and +60°C DC-OK Relay Contact Quick-connect Spring-clamp Terminals 3 Year Warranty GENERAL DESCRIPTION SHORT-FORM DATA The most outstanding features of this Dimension QSeries DIN-rail power supply are the high efficiency and the small size, which are achieved by a synchronous rectification and further novel design details. Output voltage Adjustment range Output current With short-term peak power capability of 150% and built-in large sized output capacitors, these features help start motors, charge capacitors and absorb reverse energy and often allow a unit of a lower wattage class to be used. High immunity to transients and power surges as well as low electromagnetic emission makes usage in nearly every environment possible. The integrated output power manager, a wide range input voltage design and virtually no input inrush current make installation and usage simple. Diagnostics are easy due to the dry DC-ok contact, a green DC-ok LED and red overload LED. Unique quick-connect spring-clamp terminals allow a safe and fast installation and a large international approval package for a variety of applications makes this unit suitable for nearly every situation. ORDER NUMBERS Power Supply Accessory DC 24V 24 - 28V 20 – 17A 30 – 26A Output power 480W 720W Output ripple < 100mVpp Input voltage AC 100-240V Mains frequency 50-60Hz AC Input current 4.56 / 2.48A Power factor 0.95 / 0.90 AC Inrush current typ. 9 / 7A peak Efficiency 92.4 / 93.9% Losses 39.6 / 31.4W Temperature range -25°C to +70°C Derating 12W/°C Hold-up time typ. 32 / 51ms Dimensions 82x124x127mm continuous for typ. 4s continuous for typ. 4s 20Hz to 20MHz ±15% ±6% at 120 / 230Vac at 120 / 230Vac at 120 / 230Vac at 120 / 230Vac at 120 / 230Vac operational +60 to +70°C at 120 / 230Vac WxHxD MARKINGS QS20.241 QS20.241-A1 QS20.241-C1 24-28V Standard unit ATEX approved unit Conformal coated unit ZM2.WALL ZM15.SIDE YR40.242 YR40.245 Wall mount bracket Side mount bracket Redundancy module Redundancy module IND. CONT. EQ. UL 508 IECEx UL 60950-1 Class I Div 2 ATEX II 3G Ex ec nC II T3 Gc Sep. 2019 / Rev. 2.3 DS-QS20.241-EN All parameters are specified at 24V, 20A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany Marine EMC, LVD, RoHS 1/26 QS20.241, QS20.241-A1, QS20.241-C1 24V, 20A, SINGLE PHASE INPUT Q-Series INDEX Page 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. Intended Use .......................................................3 Installation Requirements ...................................3 AC-Input...............................................................4 DC-Input...............................................................5 Input Inrush Current ...........................................5 Output .................................................................6 Hold-up Time .......................................................8 DC-OK Relay Contact ..........................................8 Efficiency and Power Losses................................9 Lifetime Expectancy and MTBF.........................10 Functional Diagram...........................................10 Terminals and Wiring ........................................11 Front Side and User Elements ...........................12 EMC ....................................................................13 Environment ......................................................14 Protection Features ...........................................15 Safety Features ..................................................15 Dielectric Strength ............................................16 Approvals ...........................................................17 Physical Dimensions and Weight ......................18 Page 21. Accessories ........................................................ 19 21.1. ZM2.WALL Wall Mounting Bracket ....... 19 21.2. ZM15.SIDE Side Mounting Bracket ........ 19 21.3. YR40 Redundancy Modules ..................... 20 22. Application Notes ............................................. 21 22.1. Repetitive Pulse Loading .......................... 21 22.2. Peak Current Capability ........................... 22 22.3. Back-feeding Loads .................................. 22 22.4. External Input Protection ......................... 22 22.5. Charging of Batteries ............................... 23 22.6. Output Circuit Breakers............................ 23 22.7. Parallel Use to Increase Output Power .... 24 22.8. Parallel Use for Redundancy .................... 24 22.9. Series Operation ....................................... 25 22.10. Inductive and Capacitive Loads................ 25 22.11. Operation on Two Phases ........................ 25 22.12. Use in a Tightly Sealed Enclosure ............ 25 22.13. Mounting Orientations ............................ 26 The information presented in this document is believed to be accurate and reliable and may change without notice. No part of this document may be reproduced or utilized in any form without permission in writing from the publisher. TERMINOLOGY AND ABREVIATIONS PE and symbol Earth, Ground PE is the abbreviation for Protective Earth and has the same meaning as the symbol . This document uses the term “earth” which is the same as the U.S. term “ground”. T.b.d. To be defined, value or description will follow later. AC 230V A figure displayed with the AC or DC before the value represents a nominal voltage with standard tolerances (usually ±15%) included. E.g.: DC 12V describes a 12V battery disregarding whether it is full (13.7V) or flat (10V) 230Vac A figure with the unit (Vac) at the end is a momentary figure without any additional tolerances included. 50Hz vs. 60Hz As long as not otherwise stated, AC 230V parameters are valid at 50Hz mains frequency. may A key word indicating flexibility of choice with no implied preference. shall A key word indicating a mandatory requirement. should A key word indicating flexibility of choice with a strongly preferred implementation. Sep. 2019 / Rev. 2.3 DS-QS20.241-EN All parameters are specified at 24V, 20A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 2/26 QS20.241, QS20.241-A1, QS20.241-C1 24V, 20A, SINGLE PHASE INPUT Q-Series 1. INTENDED USE This device is designed for installation in an enclosure and is intended for the general use such as in industrial control, office, communication, and instrumentation equipment. Do not use this power supply in equipment, where malfunction may cause severe personal injury or threaten human life. This device is designed for use in hazardous, non-hazardous, ordinary or unclassified locations. 2. INSTALLATION REQUIREMENTS This device may only be installed and put into operation by qualified personnel. This device does not contain serviceable parts. The tripping of an internal fuse is caused by an internal defect. If damage or malfunction should occur during installation or operation, immediately turn power off and send unit to the factory for inspection. Mount the unit on a DIN-rail so that the output terminals are located on the top and the input terminals are located on the bottom of the unit. For other mounting orientations see de-rating requirements in this document. See chapter 22.13. This device is designed for convection cooling and does not require an external fan. Do not obstruct airflow and do not cover ventilation grid (e.g. cable conduits) by more than 30%! Keep the following installation clearances: 40mm on top, 20mm on the bottom, 5mm on the left and right sides are recommended when the device is loaded permanently with more than 50% of the rated power. Increase this clearance to 15mm in case the adjacent device is a heat source (e.g. another power supply). A disconnecting means shall be provided for the output of the power supplies when used in applications according to CSA C22.2 No 107.1-01. WARNING Risk of electrical shock, fire, personal injury or death. - Do not use the power supply without proper grounding (Protective Earth). Use the terminal on the input block for earth connection and not one of the screws on the housing. - Turn power off before working on the device. Protect against inadvertent re-powering. - Make sure that the wiring is correct by following all local and national codes. - Do not modify or repair the unit. - Do not open the unit as high voltages are present inside. - Use caution to prevent any foreign objects from entering the housing. - Do not use in wet locations or in areas where moisture or condensation can be expected. - Do not touch during power-on, and immediately after power-off. Hot surfaces may cause burns. Notes for use in hazardous location areas: The power supply is suitable for use in Class I Division 2 Groups A, B, C, D locations. Additionally, the QS20.241-A1 is suitable for use in Group II Category 3 (Zone 2) environments and is evaluated according to EN 60079-0:2009 and EN 60079-15:2010. WARNING EXPLOSION HAZARDS! Substitution of components may impair suitability for this environment. Do not disconnect the unit or operate the voltage adjustment unless power has been switched off or the area is known to be non-hazardous. A suitable enclosure must be provided for the end product which has a minimum protection of IP54 and fulfils the requirements of the EN 60079-15. Sep. 2019 / Rev. 2.3 DS-QS20.241-EN All parameters are specified at 24V, 20A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 3/26 QS20.241, QS20.241-A1, QS20.241-C1 24V, 20A, SINGLE PHASE INPUT Q-Series 3. AC-INPUT AC input AC input range Allowed voltage L or N to earth Input frequency Turn-on voltage Shut-down voltage Input current Power factor *) Crest factor **) Start-up delay Rise time Turn-on overshoot nom. min. min. min. max. nom. typ. typ. typ. AC 100-240V 85-276Vac 60-85Vac 276-300Vac 276Vac 50–60Hz 77Vac 73Vac 53Vac typ. typ. typ. typ. typ. typ. max. AC 100V 5.47A 0.96 1.6 640ms 80ms 85ms 100mV suitable for TN-, TT- and IT mains networks continuous operation full power for 200ms, no damage between 0 and 85Vac < 500ms continuous, IEC 62103 ±6% steady-state value, see Fig. 3-1 steady-state value, see Fig. 3-1 dynamic value AC 120V 4.56A 0.95 1.7 610ms 80ms 85ms 100mV AC 230V 2.48A 0.90 2.05 660ms 80ms 85ms 100mV at 24V, 20A, see Fig. 3-3 at 24V, 20A, see Fig. 3-4 at 24V, 20A see Fig. 3-2 0mF, 24V, 20A, see Fig. 3-2 20mF, 24V, 20A, see Fig. 3-2 see Fig. 3-2 *) The power factor is the ratio of the true (or real) power to the apparent power in an AC circuit. **) The crest factor is the mathematical ratio of the peak value to RMS value of the input current waveform. Rated input range max. 500ms Turn-on full power for 200ms Shut-down POUT Fig. 3-2 Turn-on behavior, definitions Input Voltage VIN 60V 85V Input Current, typ. 5 4 3 Rise Time Fig. 3-4 Power factor vs. output load Power Factor, typ. 100Vac 120Vac 1.0 ac 0V 10 Vac 120 0.95 ac 0.85 230V 2 Start-up delay 276V 300Vac Fig. 3-3 Input current vs. output load at 24V 6A - 5% Output Voltage Overshoot Fig. 3-1 Input voltage range 230Vac 0.9 0.8 1 Output Current 0 2 4 6 8 10 12 14 16 18 20A Output Current 0.75 2 4 6 8 10 12 14 16 18 20A Sep. 2019 / Rev. 2.3 DS-QS20.241-EN All parameters are specified at 24V, 20A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 4/26 QS20.241, QS20.241-A1, QS20.241-C1 24V, 20A, SINGLE PHASE INPUT Q-Series 4. DC-INPUT DC input DC input range DC input current Allowed Voltage L/N to Earth Turn-on voltage Shut-down voltage nom. min. typ. max. typ. typ. DC 110-150V 88-187Vdc 4.6A 375Vdc 74Vdc 69Vdc + Power Supply AC L N PE - + - 110Vdc, at 24V, 20A IEC 62103 steady state value steady state value Instructions for DC use: a) Use a battery or similar DC source. For other sources contact PULS b) Connect +pole to L and –pole to N. c) Connect the PE terminal to an earth wire or to the machine ground. Fig. 4-1 Wiring for DC Input Battery -20%/+25% Load DC 5. INPUT INRUSH CURRENT An active inrush limitation circuit limits the input inrush current after turn-on of the input voltage and after short input voltage interruptions. The charging current into EMI suppression capacitors is disregarded in the first microseconds after switch-on. max. AC 100V 13Apeak AC 120V 13Apeak AC 230V 13Apeak typ. 11Apeak 9Apeak 7Apeak Inrush energy max. 5A2s 5A2s 5A2s Inrush delay (A) typ. 400ms 400ms 650ms Inrush current over entire temperature range; mains interruptions > 750ms over entire temperature range; mains interruptions > 750ms over entire temperature range; mains interruptions > 750ms see (A) in Fig. 5-1 Fig. 5-1 Input inrush current, typical behavior A…. Inrush delay Input: Output: Ambient: Upper curve: Middle curve: Lower curve: Time basis: 230Vac 24V, 20A 25°C Input current 5A / DIV Input voltage 500V / DIV Output voltage 20V / DIV 100ms / DIV Sep. 2019 / Rev. 2.3 DS-QS20.241-EN All parameters are specified at 24V, 20A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 5/26 QS20.241, QS20.241-A1, QS20.241-C1 24V, 20A, SINGLE PHASE INPUT Q-Series 6. OUTPUT Output voltage Adjustment range Factory setting Line regulation Load regulation Ripple and noise voltage Output current Output power nom. min. max. typ. max. max. max. nom. nom. nom. 24V 24-28V 30V ****) 24.1V 10mV 100mV 100mVpp 20A 17A 30A *) nom. 26A *) nom. nom. typ. min. max. typ. Short-circuit current min. max. max. 480W 720W *) 4s 3.5s 4.5s 7s cont. current HiccupPLUS mode**) 30A ***) 40A ***) 14A ***) Output capacitance typ. 8 500µF BonusPower® time BonusPower® recovery time Overload behaviour *) **) ***) ****) guaranteed at clockwise end position of potentiometer ±0.2%, at full load, cold unit 60-300Vac static value, 0A  20A 20Hz to 20MHz, 50Ohm continuously available at 24V, see Fig. 6-1 continuously available at 28V, see Fig. 6-1 short term available BonusPower® *), at 24V, for typical 4s, see Fig. 6-1 short term available BonusPower® *), at 28V, for typical 4s, see Fig. 6-1 continuously available short term available BonusPower® *) duration until the output voltage dips, see Fig. 6-2 overload free time to reset power manager Fig. 6-4 output voltage > 20Vdc, see Fig. 6-1 output voltage < 20Vdc, see Fig. 6-1 load impedance 50mOhm, see Fig. 6-3 load impedance 50mOhm, see Fig. 6-3 average (R.M.S.) current, load impedance 90% of the adjusted output voltage F Overload LED (red) On, when the voltage on the output terminals is 2000m (6500ft), see Fig. 15-2 III IEC 62103, EN 50178, altitudes up to 2000m II altitudes from 2000m to 6000m 2 IEC 62103, EN 50178, not conductive The unit does not release any silicone or other LABS-critical substances and is suitable for use in paint shops. Altitude Altitude de-rating Over-voltage category Degree of pollution LABS compatibility *) Operational temperature is the same as the ambient temperature and is defined as the air temperature 2cm below the unit. **) Do not energize while condensation is present Fig. 15-1 Output current vs. ambient temp. Allowed Output Current at 24V Fig. 15-2 Output current vs. altitude Allowed Output Current at 24V 30A for typ. 4s 25 30A 20 continuous 15 20 10 5 5 Ambient Temperature 0 20 40 continuous 15 10 0 -25 for typ. 4s 25 A A... Tamb < 60°C B... Tamb < 50°C C... Tamb < 40°C 0 2000 C Altitude 0 60 70°C B 4000 6000m Sep. 2019 / Rev. 2.3 DS-QS20.241-EN All parameters are specified at 24V, 20A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 14/26 QS20.241, QS20.241-A1, QS20.241-C1 24V, 20A, SINGLE PHASE INPUT Q-Series 16. PROTECTION FEATURES Output protection Output over-voltage protection Degree of protection Penetration protection Over-temperature protection Input transient protection Internal input fuse *) Electronically protected against overload, no-load and short-circuits *) typ. 32Vdc In case of an internal power supply defect, a redundant circuit limits the maximum output voltage. The output max. 37Vdc shuts down and automatically attempts to restart. IP 20 EN/IEC 60529 > 3.5mm / > 5mm top side / bottom side; e.g. screws, small parts yes Output shut-down with automatic restart MOV (Metal Oxide Varistor) included not user replaceable In case of a protection event, audible noise may occur. 17. SAFETY FEATURES Input / output separation *) Class of protection Isolation resistance PE resistance Touch current (leakage current) *) SELV IEC/EN 60950-1 PELV IEC/EN 60204-1, EN 50178, IEC 62103, IEC 60364-4-41 double or reinforced insulation I PE (Protective Earth) connection required > 5MOhm input to output, 500Vdc < 0.1Ohm typ. 0.23mA / 0.63mA 100Vac, 50Hz, TN-,TT-mains / IT-mains typ. 0.34mA / 0.93mA 120Vac, 60Hz, TN-,TT-mains / IT-mains typ. 0.58mA / 1.56mA 230Vac, 50Hz, TN-,TT-mains / IT-mains < 0.31mA / 0.77mA 110Vac, 50Hz, TN-,TT-mains / IT-mains < 0.45mA / 1.13mA 132Vac, 60Hz, TN-,TT-mains / IT-mains < 0.80mA / 2.00mA 264Vac, 50Hz, TN-,TT-mains / IT-mains double or reinforced insulation Sep. 2019 / Rev. 2.3 DS-QS20.241-EN All parameters are specified at 24V, 20A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 15/26 QS20.241, QS20.241-A1, QS20.241-C1 24V, 20A, SINGLE PHASE INPUT Q-Series 18. DIELECTRIC STRENGTH The output voltage is floating and has no ohmic connection to the ground. Type and factory tests are conducted by the manufacturer. Field tests may be conducted in the field using the appropriate test equipment which applies the voltage with a slow ramp (2s up and 2s down). Connect all input-terminals together as well as all output poles before conducting the test. When testing, set the cut-off current settings to the value in the table below. Type test 60s A 2500Vac B 3000Vac C 500Vac D 500Vac Factory test 5s 2500Vac 2500Vac 500Vac 500Vac Field test 5s 2000Vac 2000Vac 500Vac 500Vac > 15mA > 15mA > 40mA > 1mA Fig. 18-1 Dielectric strength Input DC-ok B*) L N Cut-off current setting B A D Output Earth, PE C + - To fulfil the PELV requirements according to EN60204-1 § 6.4.1, we recommend that either the + pole, the – pole or any other part of the output circuit shall be connected to the protective earth system. This helps to avoid situations in which a load starts unexpectedly or can not be switched off when unnoticed earth faults occur. B*) When testing input to DC-OK ensure that the max. voltage between DC-OK and the output is not exceeded (column D). We recommend connecting DC-OK pins and the output pins together when performing the test. Sep. 2019 / Rev. 2.3 DS-QS20.241-EN All parameters are specified at 24V, 20A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 16/26 QS20.241, QS20.241-A1, QS20.241-C1 24V, 20A, SINGLE PHASE INPUT Q-Series 19. APPROVALS EC Declaration of Conformity The CE mark indicates conformance with the - EMC directive 2004/108/EC, - Low-voltage directive (LVD) 2006/95/EC, - RoHS directive 2011/65/EU and the - ATEX directive 94/9/EC (only for QS20.241-A1) CB Scheme, Information Technology Equipment IEC 60950-1 2nd Edition UL 508 IND. CONT. EQ. UL 60950-1 2nd Edition ANSI / ISA 12.12.01-2007 (Class I Div 2) EN 60079-15 ATEX (QS20.241-A1 only) Marine SEMI F47 GOST P II 3G Ex ec nC II T3 Gc Listed for use as Industrial Control Equipment; U.S.A. (UL 508) and Canada (C22.2 No. 107-1-01); E-File: E198865 Recognized for use as Information Technology Equipment, Level 5; U.S.A. (UL 60950-1) and Canada (C22.2 No. 60950-1); E-File: E137006 Applicable for altitudes up to 2000m. Recognized for use in Hazardous Location Class I Div 2 T3 Groups A,B,C,D systems; U.S.A. (ANSI / ISA 12.12.01-2007) and Canada (C22.2 No. 213-M1987) Suitable for use in Class 1 Zone 2 Groups IIa, IIb and IIc locations. Number of ATEX certificate: EPS 09 ATEX 1 236 X The power supply must be built-in in an IP54 enclosure. GL (Germanischer Lloyd) classified and ABS (American Bureau for Shipping) PDA Environmental category: C, EMC2 Marine and offshore applications SEMI F47-0706 Ride-through compliance for semiconductor industry. Full SEMI range compliance (Input: AC120V or higher, output: < 480W) Certificate of Conformity for Russia and other GUS countries Sep. 2019 / Rev. 2.3 DS-QS20.241-EN All parameters are specified at 24V, 20A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 17/26 QS20.241, QS20.241-A1, QS20.241-C1 24V, 20A, SINGLE PHASE INPUT Q-Series 20. PHYSICAL DIMENSIONS AND WEIGHT Weight DIN-Rail Installation Clearances 1200g / 2.65lb Use 35mm DIN-rails according to EN 60715 or EN 50022 with a height of 7.5 or 15mm. The DIN-rail height must be added to the unit depth (127mm) to calculate the total required installation depth. See chapter 2 Fig. 20-1 Front view Fig. 20-2 Side view Sep. 2019 / Rev. 2.3 DS-QS20.241-EN All parameters are specified at 24V, 20A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 18/26 QS20.241, QS20.241-A1, QS20.241-C1 24V, 20A, SINGLE PHASE INPUT Q-Series 21. ACCESSORIES 21.1. ZM2.WALL WALL MOUNTING BRACKET This bracket is used to mount the power supply onto a flat surface without utilizing a DIN-Rail. 21.2. ZM15.SIDE SIDE MOUNTING BRACKET This bracket is used to mount Dimension units sideways with or without utilizing a DIN-Rail. The two aluminum brackets and the black plastic slider of the unit have to be detached, so that the steel brackets can be mounted. For sideway DIN-rail mounting, the removed aluminum brackets and the black plastic slider need to be mounted on the steel bracket. Side mounting with DIN-rail brackets Side mounting without DIN-rail brackets Sep. 2019 / Rev. 2.3 DS-QS20.241-EN All parameters are specified at 24V, 20A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 19/26 QS20.241, QS20.241-A1, QS20.241-C1 24V, 20A, SINGLE PHASE INPUT Q-Series 21.3. YR40 REDUNDANCY MODULES YR40.242 – (2x 20A Inputs, 1x 40A output) The YR40.242 is equipped with two input channels, which are individually decoupled by utilizing mosfet technology. Using mosfets instead of diodes reduces the heat generation and the voltage drop between input and output. The YR40.242 does not require an additional auxiliary voltage and is self-powered even in case of a short circuit across the output. Due to the low power losses, the unit is very slender and only requires 36mm width on the DIN-rail. YR40.245 – (1x 40A input, 1x 40A output) The YR40.245 is a 40A single channel redundancy module, which is equipped with a plug connector on the output. The plug connector allows replacing the power supply or the redundancy module while the system is running. The plug connector avoids that the output wires can touch and short the load circuit. The YR40.245 is very slender and only requires 46mm width on the DIN-rail. It also utilizes mosfet technology instead of diodes for low heat generation and a minimal voltage drop between input and output. It does not require an additional auxiliary voltage and is selfpowered even in case of a short circuit across the output. Fig. 21-1 Typical 1+1 Redundant configuration for 20A with a dual redundancy module 24V 20A Load ++ - - DC- 24V,20A OK QS20.241 Power Supply L N PE + - Output YR40.242*) Redundancy Module Fig. 21-2 Typical N+1 or 1+1 Redundant configuration for 20A with multiple YR40.245 redundancy modules Failure Monitor ++ Failure Monitor ++ - - DC- 24V,20A OK QS20.241 Power Supply QS20.241 Power Supply L N PE Output ++ -- YR40.245 Redundancy Module L N PE L N PE + - + - + QS20.241 Power Supply Output YR40.245 Redundancy Module Input - L N PE + - I I I - + DC24V,20A OK Input Input Input 1 2 also possible - + -- DC24V,20A OK *) YR40.241 I 24V 20A Load L N PE Sep. 2019 / Rev. 2.3 DS-QS20.241-EN All parameters are specified at 24V, 20A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 20/26 QS20.241, QS20.241-A1, QS20.241-C1 24V, 20A, SINGLE PHASE INPUT Q-Series 22. APPLICATION NOTES 22.1. REPETITIVE PULSE LOADING Typically, a load current is not constant and varies over time. This power supply is designed to support loads with a higher short-term power demand (=BonusPower®). The short-term duration is hardware controlled by an output power manager and is available on a repeated basis. If the BonusPower® load lasts longer than the hardware controller allows it, the output voltage will dip and the next BonusPower® is available after the BonusPower® recovery time (see chapter 6) has elapsed. To avoid this, the following rules must be met: a) The power demand of the pulse must be below 150% of the nominal output power. b) The duration of the pulse power must be shorter than the allowed BonusPower® time. (see output section) c) The average (R.M.S.) output current must be below the specified continuous output current. If the R.M.S. current is higher, the unit will respond with a thermal shut-down after a period of time. Use the maximum duty cycle curve (Fig. 22-2) to check if the average output current is below the nominal current. Fig. 22-1 Repetitive pulse loads, definitions Fig. 22-2 Max. duty cycle curve 1.0 PPEAK TPEAK DutyCycle max. 150% 0.6 100% 0.4 P0 P0 = 100% 0.2 0 100 P0 PPEAK T0 TPEAK Example: P0 = 10% P0 = 50% P0 = 75% 0.8 T0 Base load (W) Pulse load (above 100%) Duration between pulses (s) Pulse duration (s) 110 DutyCycle = T0 = 120 130 PPEAK 150% 140 Tpeak Tpeak + T0 Tpeak - (DutyCycle x Tpeak) DutyCycle A load is powered continuously with 240W (= 50% of the rated output load). From time to time a peak power of 720W (= 150% of the rated output load) is needed for 1 second. The question is: How often can this pulse be supplied without overloading the power supply? - Make a vertical line at PPEAK = 150% and a horizontal line where the vertical line crosses the P0 = 50% curve. Read the max. duty cycle from the duty cycle-axis (= 0.37) - Calculate the required pause (base load) length T0: - Result: The required pause length = 1.7s T0= - Max. repetition rate = pulse +pause length = 2.7s Tpeak - (DutyCycle x Tpeak) DutyCycle = 1s - (0.37 x 1s) 0.37 = 1.7s More examples for pulse load compatibility: PPEAK 720W 720W 600W P0 480W 0W 240W TPEAK 1s 1s 1s T0 >25s >1.3s > 0.75s PPEAK 720W 720W 720W P0 240W 240W 240W TPEAK 0.1s 1s 3s T0 >0.16s >1.6s >4.9s Sep. 2019 / Rev. 2.3 DS-QS20.241-EN All parameters are specified at 24V, 20A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 21/26 QS20.241, QS20.241-A1, QS20.241-C1 24V, 20A, SINGLE PHASE INPUT Q-Series 22.2. PEAK CURRENT CAPABILITY Solenoids, contactors and pneumatic modules often have a steady state coil and a pick-up coil. The inrush current demand of the pick-up coil is several times higher than the steady-state current and usually exceeds the nominal output current (including the PowerBoost). The same situation applies when starting a capacitive load. Branch circuits are often protected with circuit breakers or fuses. In case of a short or an overload in the branch circuit, the fuse needs a certain amount of over-current to trip or to blow. The peak current capability ensures the safe operation of subsequent circuit breakers. Assuming the input voltage is turned on before such an event, the built-in large sized output capacitors inside the power supply can deliver extra current. Discharging this capacitor causes a voltage dip on the output. The following two examples show typical voltage dips: Fig. 22-3 Peak load with 2x the nominal current for 50ms, typ. Fig. 22-4 Peak load with 5x the nominal current for 5ms, typ. Peak load 40A (resistive) for 50ms Output voltage dips from 24V to 20V. Peak load 100A (resistive) for 5ms Output voltage dips from 24V to 16V. Please note: The DC-OK relay triggers when the voltage dips more than 10% for longer than 1ms. 22.3. BACK-FEEDING LOADS Loads such as decelerating motors and inductors can feed voltage back to the power supply. This feature is also called return voltage immunity or resistance against Back- E.M.F. (Electro Magnetic Force). This power supply is resistant and does not show malfunctioning when a load feeds back voltage to the power supply. It does not matter whether the power supply is on or off. The maximum allowed feed-back-voltage is 34Vdc. The absorbing energy can be calculated according to the built-in large sized output capacitor which is specified in chapter 6. 22.4. EXTERNAL INPUT PROTECTION The unit is tested and approved for branch circuits up to 20A. An external protection is only required if the supplying branch has an ampacity greater than this. Check also local codes and local requirements. In some countries local regulations might apply. If an external fuse is necessary or utilized, minimum requirements need to be considered to avoid nuisance tripping of the circuit breaker. A minimum value of 10A B- or C-Characteristic breaker should be used Sep. 2019 / Rev. 2.3 DS-QS20.241-EN All parameters are specified at 24V, 20A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 22/26 QS20.241, QS20.241-A1, QS20.241-C1 24V, 20A, SINGLE PHASE INPUT Q-Series 22.5. CHARGING OF BATTERIES The power supply can be used to charge lead-acid or maintenance free batteries. (Two 12V batteries in series) Instructions for charging batteries: a) Set output voltage (measured at no load and at the battery end of the cable) very precisely to the end-of-charge voltage. End-of-charge voltage 27.8V 27.5V 27.15V 26.8V Battery temperature 10°C 20°C 30°C 40°C b) Use a 30A or 32A circuit breaker (or blocking diode) between the power supply and the battery. c) Ensure that the output current of the power supply is below the allowed charging current of the battery. d) Use only matched batteries when putting 12V types in series. e) The return current to the power supply (battery discharge current) is typ. 9mA when the power supply is switched off (except in case a blocking diode is utilized). 22.6. OUTPUT CIRCUIT BREAKERS Standard miniature circuit breakers (MCB’s or UL1077 circuit breakers) are commonly used for AC-supply systems and may also be used on 24V branches. MCB’s are designed to protect wires and circuits. If the ampere value and the characteristics of the MCB are adapted to the wire size that is used, the wiring is considered as thermally safe regardless of whether the MCB opens or not. To avoid voltage dips and under-voltage situations in adjacent 24V branches which are supplied by the same source, a fast (magnetic) tripping of the MCB is desired. A quick shutdown within 10ms is necessary corresponding roughly to the ride-through time of PLC's. This requires power supplies with high current reserves and large output capacitors. Furthermore, the impedance of the faulty branch must be sufficiently small in order for the current to actually flow. The best current reserve in the power supply does not help if Ohm’s law does not permit current flow. The following table has typical test results showing which B- and C-Characteristic MCBs magnetically trip depending on the wire cross section and wire length. Fig. 22-5 Test circuit Power Supply AC MCB + + Wire length DC S1... Fault simulation switch *) Load S1 - Maximal wire length*) for a fast (magnetic) tripping: 0.75mm² 1.0mm² 1.5mm² 2.5mm² 26m 35m 62m 82m C-2A 23m 29m 54m 72m C-3A 15m 19m 31m 51m C-4A 7m 10m 15m 26m C-6A 5m 7m 10m 16m C-8A 2m 3m 5m 7m C-10A 1m 2m C-13A 19m 27m 38m 57m B-6A 7m 11m 14m 23m B-10A 1m 2m 3m 5m B-13A Don’t forget to consider twice the distance to the load (or cable length) when calculating the total wire length (+ and – wire). Sep. 2019 / Rev. 2.3 DS-QS20.241-EN All parameters are specified at 24V, 20A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 23/26 QS20.241, QS20.241-A1, QS20.241-C1 24V, 20A, SINGLE PHASE INPUT Q-Series 22.7. PARALLEL USE TO INCREASE OUTPUT POWER Unit A AC Power supplies from the same series (Q-Series) can be paralleled to increase the output power. The output voltage shall be adjusted to the same value (±100mV) with the same load conditions on all units, or the units can be left with the factory settings. DC + + Unit B If more than three units are connected in parallel, a fuse or circuit breaker with a rating of 30A or 32A is required on each output. Alternatively, a diode or redundancy module can also be utilized. Load AC - + - Keep an installation clearance of 15mm (left / right) between two power DC supplies and avoid installing the power supplies on top of each other. Do not use power supplies in parallel in mounting orientations other than the standard mounting orientation (input terminals on bottom and output terminals on the top of the unit) or in any other condition where a derating of the output current is required (e.g. altitude, above 60°C, …). Pay attention that leakage current, EMI, inrush current, harmonics will increase when using multiple power supplies. 22.8. PARALLEL USE FOR REDUNDANCY Power supplies can be paralleled for redundancy to gain higher system availability. Redundant systems require a certain amount of extra power to support the load in case one power supply unit fails. The simplest way is to put two power supplies in parallel. This is called a 1+1 redundancy. In case one power supply unit fails, the other one is automatically able to support the load current without any interruption. 24V Failure Redundant systems for a higher power demand are usually built in a 20A Monitor Load N+1 method. E.g. five power supplies, each rated for 20A are paralleled to build a 80A redundant system. For N+1 redundancy the same restrictions apply as for increasing the output power, see also section 22.7. Please note: This simple way to build a redundant system does not cover failures such as an internal short circuit in the secondary side of the power supply. In such a case, the defective unit becomes a load for the other power supplies and the output voltage can not be maintained any more. This can be avoided by utilizing decoupling diodes or Mosfets, which are included in the redundancy module YR40.241 or YR40.242. ++ -- DC24V,20A OK QS20.241 Power Supply L N PE + - Output YR40.242*) Redundancy Module ++ -- DC24V,20A OK QS20.241 Power Supply Input Input 1 2 L N PE + - + - Recommendations for building redundant power systems: a) b) c) Use separate input fuses for each power supply. Monitor the individual power supply units. Therefore, use the DCOK relay contact of the QS20 power supply. It is desirable to set the output voltages of all units to the same value (± 100mV) or leave it at the factory setting. I *) YR40.241 also possible Sep. 2019 / Rev. 2.3 DS-QS20.241-EN All parameters are specified at 24V, 20A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 I L N PE Germany 24/26 QS20.241, QS20.241-A1, QS20.241-C1 24V, 20A, SINGLE PHASE INPUT Q-Series 22.9. SERIES OPERATION Unit A AC Power supplies of the same type can be connected in series for higher output voltages. It is possible to connect as many units in series as needed, providing the sum of the output voltage does not exceed 150Vdc. Voltages with a potential above 60Vdc are not SELV any more and can be dangerous. Such voltages must be installed with a protection against touching. DC + + Unit B AC Earthing of the output is required when the sum of the output voltage is above 60Vdc. DC Avoid return voltage (e.g. from a decelerating motor or battery) which is applied to the output terminals. Load - + - Earth (see notes) Keep an installation clearance of 15mm (left / right) between two power supplies and avoid installing the power supplies on top of each other. Do not use power supplies in series in mounting orientations other than the standard mounting orientation (input terminals on bottom and output terminals on the top of the unit). Pay attention that leakage current, EMI, inrush current, harmonics will increase when using multiple power supplies. 22.10. INDUCTIVE AND CAPACITIVE LOADS The unit is designed to supply any kind of loads, including unlimited capacitive and inductive loads. 22.11. OPERATION ON TWO PHASES Power Supply L1 240V +15% max. The power supply can also be used on two-phases of a three-phase-system. Such a phase-to-phase connection is allowed as long as the supplying voltage is below 240V+15%. Use a fuse or a circuit breaker to protect the N input. The N input is internally not protected and is in this case connected to a hot wire. Appropriate fuses or circuit breakers are specified in section 22.4 “External Input Protection”. L3 AC L Fuse L2 internal fuse N PE DC 22.12. USE IN A TIGHTLY SEALED ENCLOSURE When the power supply is installed in a tightly sealed enclosure, the temperature inside the enclosure will be higher than outside. In such situations, the inside temperature defines the ambient temperature for the power supply. The following measurement results can be used as a reference to estimate the temperature rise inside the enclosure. The power supply is placed in the middle of the box, no other heat producing items are inside the box Enclosure: Load: Input: Temperature inside enclosure: Temperature outside enclosure: Temperature rise: Rittal Typ IP66 Box PK 9522 100, plastic, 254x180x165mm 24V, 16A; (=80%) load is placed outside the box 230Vac 49.2°C (in the middle of the right side of the power supply with a distance of 2cm) 24.4°C 24.8K Sep. 2019 / Rev. 2.3 DS-QS20.241-EN All parameters are specified at 24V, 20A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 25/26 QS20.241, QS20.241-A1, QS20.241-C1 24V, 20A, SINGLE PHASE INPUT Q-Series 22.13. MOUNTING ORIENTATIONS Mounting orientations other than input terminals on the bottom and output on the top require a reduction in continuous output power or a limitation in the maximum allowed ambient temperature. The amount of reduction influences the lifetime expectancy of the power supply. Therefore, two different derating curves for continuous operation can be found below: Curve A1 Curve A2 Recommended output current. Max allowed output current (results in approximately half the lifetime expectancy of A1). Fig. 22-6 Mounting Orientation A (Standard orientation) Output Current OUTPUT 20A 16 12 8 4 0 10 Power Supply INPUT Fig. 22-7 Mounting Orientation B (Upside down) 20 30 40 60°C 50 INPUT 20A 16 12 8 4 0 10 A2 A1 Ambient Temperature 20 30 40 60°C 50 Power Supply OUTPUT Output Current 20A 16 12 8 4 0 10 A2 A1 Ambient Temperature 20 30 40 60°C 50 Output Current OUTPUT Power Supply INPUT 20A 16 12 8 4 0 10 A2 A1 Ambient Temperature 20 30 40 60°C 50 INPUT Power Supply Output Current OUTPUT Fig. 22-10 Mounting Orientation E (Horizontal ccw) Ambient Temperature Output Current Fig. 22-8 Mounting Orientation C (Table-top mounting) Fig. 22-9 Mounting Orientation D (Horizontal cw) A1 20A 16 12 8 4 0 10 A2 A1 Ambient Temperature 20 30 40 50 60°C Sep. 2019 / Rev. 2.3 DS-QS20.241-EN All parameters are specified at 24V, 20A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 26/26
QS20.241 价格&库存
很抱歉,暂时无法提供与“QS20.241”相匹配的价格&库存,您可以联系我们找货
QS20.241
    • 1+3403.08000
    库存:20
    QS20.241
      • 1+3796.87458
      库存:170
      QS20.241
        • 1+4501.288501+582.31039
