Additional Resources:
Product Page
3D Model
date
08/05/2022
page 1 of 4
MODEL: CMC-6027-24T | DESCRIPTION: ELECTRET CONDENSER MICROPHONE
FEATURES
• omnidirectional
• high signal to noise ratio
• -24 dB sensitivity rating
SPECIFICATIONS
parameter
conditions/description
directivity
omnidirectional
sensitivity (S)
f = 1 kHz, 1 Pa, 0 dB = 1 V/Pa
min
typ
max
-27
-24
-21
standard operating voltage (Vs)
2
max operating voltage
f = 1 kHz, 1 Pa
sensitivity reduction (∆S-Vs)
f = 1 kHz, 1 Pa, Vs = 2.0 ~ 1.5 Vdc
2.2
100
current consumption (IDSS)
Vs = 2.0 Vdc, RL = 2.2 kΩ
signal to noise ratio (S/N)
f = 1 kHz, 1 Pa, A-weighted
total harmonic distortion (THD)
at 94 dB SPL
dimensions
Ø6.0 x 2.7
material
Al
terminal
solder pads
0.5
70
operating temperature
storage temperature
Notes:
Hz
mA
dBA
1
115
dB SPL
mm
weight
RoHS
dB
20,000
acoustic overload point (AOP)
Vdc
kΩ
-3
frequency (f)
dB
Vdc
10
output impedance (Zout)
units
0.2
g
-20
70
°C
-20
70
°C
yes
1. We use the “Pascal (Pa)” indication of sensitivity as per the recomendation of I.E.C. (International Electrotechnical Commission). The sensitivity of “Pa” will increase
20 dB compared to the “ubar” indication. Example: -60 dB (0 dB = 1 V/ubar) = -40 dB ( 1V/Pa)
2. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106 kPa pressure, unless otherwise noted.
SOLDERABILITY
parameter
min
typ
max
units
hand soldering
for maximum 2 seconds
310
320
330
°C
cuidevices.com
Product Page
3D Model
CUI DEVICES | MODEL: CMC-6027-24T | DESCRIPTION: ELECTRET CONDENSER MICROPHONE
MECHANICAL DRAWING
units: mm
FREQUENCY RESPONSE CURVE
MEASUREMENT CIRCUIT
RL = 2.2 kΩ
C = 1 µF
cuidevices.com
date 08/05/2022 | page 2 of 4
Additional Resources: Product Page
3D Model
date 08/05/2022 | page 3 of 4
PACKAGING
units: mm
Inner Box Size: 62 x 62 x 3 mm
Middle Box Size: 125 x 65 x 28 mm
Outer Box Size: 210 x 210 x 280 mm
Inner Box QTY: 100 pcs per box
Middle Box QTY: 1,000 pcs per box
Outer Box QTY: 24,000 pcs per box
Lot No.
XXXXXXXXXX
Model No.
CUI Inv# .XXXXXXXXXXX
CUI Part#.XXXXXXXXXX
Quantity.
XXXX
Pcs
Date:
DD MM YY
G
MADE IN CHINA
* T he label sticked on inner boxes
and the outer of carton
cuidevices.com
Product Page
3D Model
date 08/05/2022 | page 4 of 4
REVISION HISTORY
rev.
description
date
1.0
initial release
11/07/2016
1.01
updated packaging
06/19/2017
1.02
added dimensions to mechanical drawing
12/11/2018
1.03
brand update
01/09/2020
1.04
logo, datasheet style update
08/05/2022
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CMC-6027-24T”相匹配的价格&库存,您可以联系我们找货
