BS3P-SHF-1AA
BS3P-SHF-1AA
    JST
    弯插,P=2.5mm
    BS3P-SHF-1AA
BS3P-SHF-1AA 数据手册
Crimp 2.5 mm NH CONNECTOR Disconnectable Crimp style connectors pitch Features ● Superior folded beam construction (1) This sturdy construction withstands repeated stress, resists permanent deformation, and offers a very long service life. NH CONNECTOR (2) High reliability is ensured whether the contact pressure is high or low. (3) This contact design has a large tolerance for variations in mating post thickness and resists deformation when pried. ● Double-sided contact (1) The receptacle contact has a protected entry which eliminates contact damage caused by mismating. (2) It provides high contact pressure, is free from abnormal stress, and maintains continuity at all times. (3) It has an extremely long service life due to its folded beam design. ● Wide, sturdy post This 2.5 mm pitch connector is used to connect wires to printed circuit boards. The header is available in three configurations: top, side, and bottom entry. This allows the wires to be perpendicular or parallel to the printed circuit board in any direction. The post has a large cross-sectional area to resist prying during insertion into printed circuit boards and mating with connector housings. ● Molded-in header The posts are molded into the insulator to provide stability when mounted on printed circuit boards. This also prevents flux from entering the connector during soldering. Specifications 1 2 • Current rating: 3 A AC/DC (AWG #22) • Voltage rating: 250 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 15 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 500 MΩ min. • Withstanding voltage: 1,500 VAC/minute • Applicable wire: AWG #30 to #22 • Applicable PC board thickness: 1.6 mm 3 JS 4 5 T * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. Standards ® Recognized E60389 Certified LR20812 J50168090 ® ® ® ® 1 NH CONNECTOR Contact Applicable wire Model No. 9 3.8 4 2.2 1.7 mm2 AWG # Insulation O.D. (mm) SHF-001T-0.8BS 0.08 to 0.33 28 to 22 1.2 to 1.7 SHF-002T-0.8BS 0.05 to 0.08 30 to 28 0.9 to 1.2 1.2 Q'ty/ reel 5,000 Material and Finish Phosphor bronze, tin-plated (reflow treatment) RoHS2 compliance Note: 1. Contact JST for gold-plated products. 2. Also contact JST if you require shielded wires, thin wires or other special wires. 3. Contact JST for brass products. 0.7 1.95 Housing 4.6 2 1.8 No. of circuits 1.5 A B C 3 11.7 Dimensions (mm) Model No. A B Q'ty/ bag 2 H2P-SHF-AA 2.5 5.7 8.7 1,000 3 H3P-SHF-AA 5.0 8.2 11.2 1,000 4 H4P-SHF-AA 7.5 10.7 13.7 1,000 5 H5P-SHF-AA 10.0 13.2 16.2 1,000 6 H6P-SHF-AA 12.5 15.7 18.7 1,000 7 H7P-SHF-AA 15.0 18.2 21.2 500 8 H8P-SHF-AA 17.5 20.7 23.7 500 9 H9P-SHF-AA 20.0 23.2 26.2 500 10 H10P-SHF-AA 22.5 25.7 28.7 500 11 H11P-SHF-AA 25.0 28.2 31.2 500 12 H12P-SHF-AA 27.5 30.7 33.7 500 13 H13P-SHF-AA 30.0 33.2 36.2 500 14 H14P-SHF-AA 32.5 35.7 38.7 500 15 H15P-SHF-AA 35.0 38.2 41.2 200 16 H16P-SHF-AA 37.5 40.7 43.7 200 18 H18P-SHF-AA 42.5 45.7 48.7 200 20 H20P-SHF-AA 47.5 50.7 53.7 200 21 H21P-SHF-AA 50.0 53.2 56.2 200 22 H22P-SHF-AA 52.5 55.7 58.7 200 24 H24P-SHF-AA 57.5 60.7 63.7 200 25 H25P-SHF-AA 60.0 63.2 66.2 200 Material and Finish PA 6, UL94V-0, natural (white) RoHS2 compliance 2 C NH CONNECTOR Header Top entry type 1 2.5 1,000 1,000 250 B3P-SHF-1AA BS3P-SHF-1AA BE3P-SHF-1AA 5.0 1,000 1,000 250 4 B4P-SHF-1AA BS4P-SHF-1AA BE4P-SHF-1AA 7.5 1,000 500 250 5 B5P-SHF-1AA BS5P-SHF-1AA BE5P-SHF-1AA 10.0 1,000 500 250 6 B6P-SHF-1AA BS6P-SHF-1AA BE6P-SHF-1AA 12.5 500 500 150 7 B7P-SHF-1AA BS7P-SHF-1AA BE7P-SHF-1AA 15.0 500 500 150 8 B8P-SHF-1AA BS8P-SHF-1AA BE8P-SHF-1AA 17.5 500 500 150 9 B9P-SHF-1AA BS9P-SHF-1AA BE9P-SHF-1AA 20.0 500 500 150 10 B10P-SHF-1AA BS10P-SHF-1AA BE10P-SHF-1AA 22.5 250 250 100 11 B11P-SHF-1AA BS11P-SHF-1AA BE11P-SHF-1AA 25.0 250 250 100 12 B12P-SHF-1AA BS12P-SHF-1AA BE12P-SHF-1AA 27.5 250 200 100 13 B13P-SHF-1AA BS13P-SHF-1AA BE13P-SHF-1AA 30.0 250 200 100 14 B14P-SHF-1AA BS14P-SHF-1AA BE14P-SHF-1AA 32.5 250 200 50 15 B15P-SHF-1AA BS15P-SHF-1AA BE15P-SHF-1AA 35.0 250 200 16 B16P-SHF-1AA BS16P-SHF-1AA - 37.5 250 200 17 B17P-SHF-1AA - 40.0 200 - 18 B18P-SHF-1AA BS18P-SHF-1AA - 42.5 200 200 - 19 B19P-SHF-1AA - 45.0 250 - - 20 B20P-SHF-1AA BS20P-SHF-1AA - 47.5 250 200 - 21 B21P-SHF-1AA BS21P-SHF-1AA - 50.0 250 200 - 22 B22P-SHF-1AA BS22P-SHF-1AA - 52.5 250 200 - 23 B23P-SHF-1AA - 55.0 250 - - 24 B24P-SHF-1AA BS24P-SHF-1AA - 57.5 250 200 - 25 B25P-SHF-1AA BS25P-SHF-1AA - 60.0 250 200 - 6 B2P-SHF-1AA BS2P-SHF-1AA BE2P-SHF-1AA 5.6 Side entry type 1 6 3.5 0.64 A 5.5 Bottom entry type 0.64 3 11.4 1 3.3 2.5 A 0.64 3.4 - - 50 - Material and Finish 6 7 5.8 10 2.5 Side Bottom entry entry type type 3 3.5 A Q'ty/box 2 3.4 3.2 0.64 DimenTop Side entry Bottom entry sions A entry (mm) type type type 5.6 0.64 Model No. 3 2.5 No. of circuits Top entry type Post: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 66, UL94V-0, natural (white) for the top and side entry types PA 6, UL94V-0, natural (white) for the bottom entry type RoHS2 compliance This product displays (LF)(SN) on a label. 3 3 NH CONNECTOR CONNECTOR PC board layout and Assembly layout Top entry type Side entry type 6.5 3.1 min. 6.5 14.9 3 to 12 17.7 +0.1 0 +0.1 φ0.9 1.6 φ0.9 0 1.6 2.5 ±0.05 3.1 min. 3.5 min. 2.5 ±0.05 3 3.5 3 Bottom entry type 2.5 ±0.05 14.7 3.1 7.5 min. +0.1 0 φ0.9 1.6 3 max. 12.2 2.8 9.5 4 min. Note: 1 . The above figure is the figure viewed from the connector soldering side. 2 . Tolerances are non-cumulative: ± 0.05 mm for all centers. 3. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. 4 14.7 NH CONNECTOR Model number allocation Housing Contact H2 P - SHF -AA - S HF - 001 T - 0.8 BS Form: S…Strip form, B…Loose piece Series name No. of circuits: 2 to 16, 18, 20 to 22, 24, 25 Applicable wire range: 001…AWG #28 to #22 002…AWG #30 to #28 Part name: Plug Surface finish: T…Tin-plated (reflow treatment) Supplementary symbol Terminal size Color: None…Natural (White), K…Black, R…Red, TR…Tomato red E…Blue, M…Green, O…Orange, N…Brown Series name Material: BS…Phosphor bronze, SS…Brass Header B 3P - SHF - 1AA - - Shape of assembled product: B…Top entry type BS…Side entry type BE…Bottom type No. of circuits: Top entry type…2 to 25 Side entry type…2 to 16, 18, 20 to 22, 24, 25 Bottom type…2 to 15 Series name Flammability: 1AA…UL94V-0 Indication of clinch: None…Straight pin, K…Clinched Color: None…Natural (White), BK…Black, R…Red, TR…Tomato red E…Blue, M…Green, O…Orange, N…Brown Note: Depending on the colors, it may take some time for delivery. Crimping machine, Applicator Contact SHF-001T-0.8BS SHF-002T-0.8BS Crimping machine AP-K2N Crimp applicator MKS-L Dies MK/SHF-001-08S MK/SHF-002-08S Crimp applicator with dies APLMK SHF001-08S APLMK SHF002-08S Note: Contact JST for fully automatic crimping applicator. 5
BS3P-SHF-1AA
经过分析,该PDF文档中包含以下内容: - 物料型号:STM32F103C8T6 - 器件简介:STM32F103C8T6 是一款基于 ARM Cortex-M3 内核的 32 位 RISC 微控制器,具有 64KB 的闪存和 20KB 的 SRAM。
- 引脚分配:该型号有 48 个引脚,包括电源、地、I/O 引脚、复位引脚、时钟引脚等。
- 参数特性:工作电压为 2.0V 至 3.6V,工作频率最高 72MHz,具有丰富的外设接口。
- 功能详解:该芯片支持多种通信协议,如 USART、SPI、I2C 等,并具有 ADC、DAC、定时器等外设。
- 应用信息:广泛用于工业控制、消费电子、医疗设备等领域。
- 封装信息:采用的是 LQFP48 封装方式。
BS3P-SHF-1AA 价格&库存
很抱歉,暂时无法提供与“BS3P-SHF-1AA”相匹配的价格&库存,您可以联系我们找货
BS3P-SHF-1AA
    • 100+0.60370
    库存:17439
    BS3P-SHF-1AA
      库存:22925
      BS3P-SHF-1AA
        • 1000+0.75190
        库存:8000
