Additional Resources:
Product Page
3D Model
PCB Footprint
date
06/06/2022
page
1 of 7
SERIES: PSK-60 │ DESCRIPTION: INTERNAL AC-DC POWER SUPPLY
FEATURES
universal input voltage range (85~264 VAC)
IEC/EN/UL 62368 certified
meets CISPR32/EN 55032 Class B without external components
4,000 VAC isolation rating
short-circuit, over-current, over-voltage protections
MODEL
output
voltage
output
current
output
power
ripple
and noise
efficiency
(Vdc)
max
(A)
max
(W)
max
(mVp-p)
typ
5
10.0
50
120
84
PSK-60-12
12
5.0
60
120
87
PSK-60-15
15
4.0
60
120
88
PSK-60-24
24
2.5
60
120
89
PSK-60-48
48
1.25
60
120
90
PSK-60-5
PART NUMBER KEY
PSK-60 - XX- X
Base Number
Output Voltage
Mounting Style
blank = board mount
T = chassis mount
DIN = DIN-rail mount
cui.com
Product Page
3D Model
PCB Footprint
CUI Inc │ SERIES: PSK-60 │ DESCRIPTION: AC-DC POWER SUPPLY
date 06/06/2022 │ page 2 of 7
INPUT
parameter
conditions/description
min
max
units
voltage
ac input
dc input
85
100
264
370
Vac
Vdc
47
63
Hz
1.8
1.0
A
frequency
current
at 115 Vac
at 230 Vac
inrush current
at 115 Vac
at 230 Vac
no load power consumption
at 230 Vac
typ
45
90
A
0.5
W
max
units
20,000
4,000
3,000
1,800
470
μF
OUTPUT
parameter
capacitive load
5 Vdc output
12 Vdc output
15 Vdc output
24 Vdc output
48 Vdc output
min
initial set point accuracy
at full load
±2
line regulation
rated load
±0.5
load regulation
0%~100% load
±1.0
hold-up time
at 115 Vac
at 230 Vac
8
65
ms
±0.02
%/°C
temperature coefficient
typ
PROTECTIONS
parameter
min
over voltage protection
5 Vdc output, clamp or hiccup
12 Vdc output, clamp or hiccup
15 Vdc output, clamp or hiccup
24 Vdc output, clamp or hiccup
48 Vdc output, clamp or hiccup
over current protection
auto recovery
short circuit protection
hiccup, continuous, auto recovery
typ
max
units
9
16
25
35
60
Vdc
110
SAFETY & COMPLIANCE
parameter
isolation voltage
input to output
min
safety approvals
UL/cUL, EN, IEC 62368
safety class
Class II
EMI/EMC
CISPR 32/EN 55032 Class B
ESD
IEC/EN 61000-4-2 Contact ±6KV/Air ±8KV, perf. Criteria B
radiated immunity
IEC/EN 61000-4-3 10 V/m, perf. Criteria A
EFT/burst
IEC/EN 61000-4-4 ±4KV, perf. Criteria B
surge
IEC/EN 61000-4-5 line to line ±2KV/line to ground ±4KV, perf. Criteria B (see recomended EMC circuit)
IEC/EN 61000-4-5 ±1KV line to line, perf. Criteria B
conducted immunity
IEC/EN 61000-4-6 10 Vr.m.s, perf. Criteria A
voltage dips and interruption
IEC/EN 61000-4-11 0%, 70%, perf. Criterial B
MTBF
per MIL-HDBK-217F at 25 °C
RoHS
yes
4,000
300,000
cui.com
typ
max
units
Vac
hours
Product Page
3D Model
PCB Footprint
date 06/06/2022 │ page 3 of 7
DERATING CURVES
EFFICIENCY CURVES
cui.com
Product Page
3D Model
PCB Footprint
date 06/06/2022 │ page 4 of 7
ENVIRONMENTAL
parameter
max
units
operating temperature
min
-40
70
°C
storage temperature
-40
85
°C
max
units
storage humidity
typ
SOLDERABILITY
parameter
min
typ
wave soldering
5~10 seconds (±5 °C)
260
°C
manual welding
3~5 seconds (±10 °C)
360
°C
max
units
MECHANICAL
parameter
min
dimensions
87.00 x 52.00 x 29.50 (board mount)
135.00 x 70.00 x 37.90 (chassis mount)
137.00 x 70.00 x 42.40 (DIN-rail)
weight
board mount
chassis mount
DIN-rail
cooling
free air convection
case material
black plastic, flame-retardant and heat-resistant (UL94V-0)
units: mm [inch]
pin diameter tolerance: ± 0.1 [±0.004]
PIN CONNECTIONS
Function
1
AC(L)
2
AC(N)
3
+Vo
4
-Vo
mm
mm
mm
210
290
360
MECHANICAL DRAWING (BOARD MOUNT)
PIN
typ
cui.com
g
g
g
Product Page
units: mm [inch]
tolerance: ± 1.00 [±0.040]
wire range: 24 - 12 AWG
tightening torque: 0.4 N·m
PIN CONNECTIONS
Function
1
AC(L)
2
NC
3
AC(N)
4
+Vo
5
-Vo
6
NC
7
NC
8
NC
MECHANICAL DRAWING (DIN-RAIL MOUNT)
units: mm [inch]
installed on DIN-RAIL TS35
PIN CONNECTIONS
PIN
Function
1
AC(L)
2
NC
3
AC(N)
4
+Vo
5
-Vo
6
NC
7
NC
8
NC
PCB Footprint
date 06/06/2022 │ page 5 of 7
MECHANICAL DRAWING (CHASSIS MOUNT)
PIN
3D Model
cui.com
Product Page
3D Model
PCB Footprint
date 06/06/2022 │ page 6 of 7
APPLICATION CIRCUIT
Figure 1
Table 1
Recommended External Circuit Components
Part no.
C1
C2
FUSE
PSK-60-5
680 μF
PSK-60-12
330 μF
PSK-60-15
1 μF
330 μF
PSK-60-24
200 μF
PSK-60-48
100 μF
MOV
TVS
SMBJ7.0A
3.15A/250V,
slow-blow
SMBJ20A
S10K300
SMBJ20A
SMBJ30A
SMBJ64A
EMC RECOMMENDED CIRCUIT
Figure 2
Table 2
Component
Reccomended value
FUSE
3.15A/250V, slow-blow, required
MOV1
S20K300
MOV2/MOV3
S10K300
GDT
EM3600XS
CX
0.22 μF/ 275 Vac
CY1, CY2
1 nF / 400 Vac
R1
1 MΩ / 2 W
LDM
4.7 uH
LCM
2 mH
cui.com
Product Page
3D Model
PCB Footprint
date 06/06/2022 │ page 7 of 7
REVISION HISTORY
rev.
description
date
1.0
initial release
07/14/2020
1.01
din-rail mechanical drawing updated
03/12/2021
1.02
figure and circuit drawings updated
03/25/2021
1.03
UKCA mark added
06/06/2022
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
CUI offers a two (2) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a
life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
很抱歉,暂时无法提供与“PSK-60-12”相匹配的价格&库存,您可以联系我们找货
