M3317
M3317
    HEYCO
    M3317
M3317 数据手册
“Stay Connected” with Liquid Tight Cordgrips ® NO O-RING REQUIRED! ® Heyco -Tite Liquid Tight Cordgrips Straight-Thru, NPT Hubs with Integral Sealing Ring The Ultimate in Liquid Tight Strain Relief Protection • Integral Sealing Ring ensures a superior seal at the clearance or threaded mounting hole location, every time. • Widest range of approved cable diameters. Cable ranges listed are for the maximum IP68 sealing range. Contact Heyco for UL approved 514B cable ranges. • IP 68 rated. • Approved for NEMA 4, 4X, 6 and 6P applications. • Ratchet design of sealing nut assembly provides superior antivibration protection and ensures a firm grip on the cable. • Acme threads on body prevent skipping and speed installation. • All nylon construction with Buna N or TPE sealing gland resists salt water, weak acids, gasoline, alcohol, oil, grease, and common solvents. (This feature is not assessed by UL.) • Multiple sizes for flexible cord diameters ranging from .065˝ (1,7 mm) to 1.730˝ (44,0 mm). • We recommend using the fitting with the smallest maximum diameter that will fit your application. • Locknuts not included. For nylon locknut specifications or to order locknuts separately, see page 3-47. • For Heyco Liquid Tight Threaded Plugs, see page 3-51. • Consult Heyco for cordgrips molded in other colors. CABLE DIA. RANGE Minimum PART NO. Maximum Black DESCRIPTION Gray in. mm. in. .065 .115 1,7 2,9 .210 .250 5,3 M4514 6,4 M4516 M4515 RLTCG 1/4 M4517 LTCG 1/4 .540 13,7 1.29 32,8 .45 11,4 .21 5,3 .63 16,0 .065 .105 1,7 2,7 .230 .315 5,8 M3458 8,0 M3228 M3459 RLTCG 3/8 M3229 LTCG 3/8 .680 17,3 1.41 35,8 .49 12,4 .21 5,3 .82 20,8 .095 .170 2,4 4,3 .290 7,4 M4518 .450 11,4 M3231 M4519 RLTCG 1/2 M3232 LTCG 1/2 .875 22,2 1.70 43,2 .61 15,5 .21 5,3 .98 24,9 .180 .260 4,6 6,6 .400 10,2 M4520 .545 13,8 M3200 M4521 RLTCG LL 1/2 M3201 LTCG LL 1/2 .875 22,2 1.68 42,7 .44 11,2 .25 6,4 1.06 26,9 .250 6,4 .490 12,4 M3460 M3461 RLTCG 3/4 1.040 26,4 2.00 50,8 .62 15,7 .25 6,4 1.30 33,0 .420 10,7 .435 11,0 mm. PART DIMENSIONS A B C D E or Clearance Max. O.A. Thread Wrenching Nut Hole Dia. Length Length Thk. Flat Size in. mm. in. mm. in. mm. in. mm. in. mm. .630 16,0 M3234GA M3235GA LTCG 3/4 .705 17,9 M3234 M3235 .490 12,4 .785 19,9 M8439 .590 15,0 1.000 25,4 M8437 M8440 RLTCG 1 M8438 LTCG 1 1.326 33,7 2.41 61,2 .76 19,3 .30 7,6 1.73 43,9 .787 20,0 1.020 25,9 M4522 .875 22,2 1.260 32,0 M4524 M4523 RLTCG 1-1/4 M4525 LTCG 1-1/4 1.680 42,7 2.69 68,3 .78 19,8 .30 7,6 2.05 52,1 1.000 25,4 1.240 31,5 M3319 1.230 31,2 1.560 39,6 M3317 M3320 RLTCG 1-1/2 M3318 LTCG 1-1/2 1.920 48,8 2.81 71,3 .77 19,6 .36 9,1 2.46 62,5 1.160 29,5 1.350 34,3 M3323 1.450 36,8 1.730 43,9 M3321 M3324 RLTCG 2 M3322 LTCG 2 2.400 60,8 2.93 74,3 .79 20,1 .42 10,7 2.73 69,3 Standard colors black and gray. A Buna N compression gland for sealing. SUGGESTED CLEARANCE HOLE FOR NONTHREADED MOUNTING Acme threads prevent skipping, speed installation. Domed sealing nut resists snags, sheds contaminants. B C D Internal ratchet provides self-locking against vibration. E Collet design of body accommodates various size cords, cables, tubing. Integral Sealing Ring provides light seal at mounting panel without O-ring. INTEGRAL SEALING RING Material Certifications Quick Specs 3-1 Flammability Rating Temperature Range IP Rating Nylon 6/6 w/Buna N or TPE Sealing Gland Listed under Underwriters’ Laboratories File E51579 Recognized under the Component Program of Underwriters’ Laboratories File E51579 Certified By Canadian Standard Association File 93876C Approved for NEMA 4, 4X, 6 and 6P Applications 94V-2–Consult factory for V0 material Static -40°F (-40°C) to 239°F (115°C) Dynamic -4°F (-20°C) to 212°F (100°C) IP 68 (70 PSI, 5 BAR) 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com
M3317 价格&库存
很抱歉,暂时无法提供与“M3317”相匹配的价格&库存,您可以联系我们找货
M3317
    • 1+166.482051+21.57925
