YLNR-03VF
YLNR-03VF
    JST
    P=4.5mm
    1X3P 4.5MM
YLNR-03VF 数据手册
YLN CONNECTOR 4.5mm pitch/Disconnectable Crimp style Wire-to-wire connectors Specifications ––––––––––––––––––– YLN • Current rating: 10 A max. AC, DC (7 A when retainers are mounted) • Voltage rating: 300 V max. AC, DC • Temperature range: -25˚C to +90˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 7 mΩ max. After environmental tests/ 10 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 1,500 VAC/minute • Applicable wire: AWG #26 to #16 0.13 to 1.25 mm2 * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. The YLN connector adds variations in shape to the existing color variations of the YL connector in order to improve identification of connectors. Moreover, this connector has a mechanism to prevent incomplete mating by utilizing the inertial force generated when the plug and receptacle are mated and therefore, ensures complete mating. • Design to prevent incidental mating with the YL connector • Inertial force mechanism • Interchangeability • Finger friendly design Note: The current rating differs depending on the number of circuits and the wire size used in each connector. The table below lists the current rating as a function of the number of circuits and the wire size. Current unit : A Circuits Wire size(AWG) #20 #22 #16 #18 #24 #26 2 10 7 5 4 3 2 3 9 6 4 4 3 2 4 9 6 4 4 3 2 6 8 5 3 3 2 2 Note: Secondary retainers cannot be used with AWG #16 wires. Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 2 R9351052 Assembly layout 10.8 17.05 (including retainer) 35.1 35.1 38.7 (including retainer) 38.7 (including retainer) 1 YLN CONNECTOR Contact Applicable wire Model No. 2 Pin contact AWG # Insulation O.D. (mm) SYM-01T-P0.5A SYF-01T-P0.5A 0.13∼0.5 26∼20 1.3∼2.5 0.5∼1.25 20∼16 2.0∼3.4 0.3+0.3∼ 0.5+0.5 22+22∼ 20+20 1.5+1.5∼ 2.0+2.0 Pin contact mm2 Socket contact Q'ty/ reel 4,000 19.5 4.4 SYM-41T-P0.5A SYF-41T-P0.5A 2 (     ) 0.5 1.1 SYM-01T-P0.5A 5,000 Material and Finish Phosphor bronze, tin-plated (reflow treatment) RoHS compliance Note: 1. Contact JST for special products. 2. Retainers cannot be used with electric wire whose insulation O.D. exceeds 2.7 mm and AWG #16. 2.8 Socket contact Crimping machine Crimp applicator Contact 14.2 4.4 2 SYM-01T-P0.5A SYF-01T-P0.5A 1.1 1.8 SYM-41T-P0.5A SYF-41T-P0.5A MKS-L *MKS-SC-YL AP-K2N MKS-L *MKS-SC-YL Applicator Dies Crimp applicator with dies MK/SYF/M-01-05 APLMK SYF/M01-05 SC/SYF/M-01-05 APLSC SYF/M01-05 MK/SYF/M-41-05 APLMK SYF/M41-05 SC/SYF/M-41-05 APLSC SYF/M41-05 Note: *Strip-crimp applicator Housing Material: Housing...PA 66, UL94V-0, natural (white) Retainer...Glass-filled PA 66, UL94V-0, natural (ivory) Voltage Current Circuits rating rating Receptacle housing (for pin contact) YLNR-02VF Q'ty/ bag YLNP-02V Q'ty/ bag 10.2 YLS-02V (Used with both housings with 2 and 4 circuits) Q'ty/ bag 1 1 L 250 No.1 hole mark Q'ty/ bag YLNP-03V Q'ty/ bag 10.2 1,000 2.9 YLS-03V (Used with both housings with 3 and 6 circuits) Q'ty/ bag 1 No.1 hole mark 16.1 26.6 Q'ty/ bag YLNP-04V 15.3 6A Q'ty/ bag YLS-02V (Used with both housings with 2 and 4 circuits) Q'ty/ bag 250 1,000 1 1 3 250 8.3 11 13.8 6.5 3 L JST 2 4 L JST 2 (9A) 4 300V 1,000 2.9 No.1 hole mark 20.9 YLNR-04VF 4 500 1 L 2 15.5 18.3 6.5 2 250 12.8 6A (9A) L JST 300V 3 3 JST 3 26.6 500 No.1 hole mark 20.9 YLNR-03VF 10.8 8.3 JST 11 13.8 6.5 L JST 7A 300V (10A) 2 2 26.6 Retainer 2 10.8 Plug housing (for socket contact) No.1 hole mark 20.9 YLNR-06VF 26.6 16.1 Q'ty/ bag 2.9 No.1 hole mark YLNP-06V 15.3 Q'ty bag YLS-03V (Used with both housings with 3 and 6 circuits) Q'ty/ bag 1 No.1 hole mark 20.9 RoHS compliance Note: Current rating in parentheses is for use with AWG #16 wire. (Retainers are not mountable.) 2 12.8 2 5 4 200 200 1 4 L JST 15.5 2 5 18.3 (8A) 6.5 5A 3 6 300V 3 6 L JST 6 No.1 hole mark 2.9 1,000
YLNR-03VF
物料型号: - SYM-01T-P0.5A - SYM-41T-P0.5A - SYF-01T-P0.5A - SYF-41T-P0.5A
器件简介: YLN连接器是可分离的压接式线对线连接器,具有4.5mm的间距。它增加了YL连接器的形状变化以改善连接器的识别,并具有防止不完全配对的机制。
引脚分配: 文档中没有提供具体的引脚分配图,但提到了适用的电线规格和电路数量。
参数特性: - 最大电流:10A AC/DC(安装固定器时为7A) - 电压等级:最大300V AC/DC - 温度范围:-25°C至+90°C - 接触电阻:初始值/最大7mΩ,环境测试后/最大10mΩ - 绝缘电阻:最小1000MΩ - 耐压:1500VAC/分钟 - 适用电线:AWG #26至#16,0.13至1.25mm²
功能详解: YLN连接器设计用于防止与YL连接器意外配对,具有惯性力机制以确保完全配对,可互换性,以及对用户友好的设计。
应用信息: 文档中没有提供具体的应用场景,但根据其特性,可能适用于需要高电流和电压等级的线对线连接。
封装信息: - 材料和表面处理:磷青铜,镀锡(回流处理) - 绝缘体外径(mm):根据电线规格和电路数量而变化 - 适用电线范围:AWG #26至#16,0.13至1.25mm²
YLNR-03VF 价格&库存
很抱歉,暂时无法提供与“YLNR-03VF”相匹配的价格&库存,您可以联系我们找货
YLNR-03VF
    • 1+2.045651+0.26516
    • 100+1.77234100+0.22973
    • 300+1.42450300+0.18465
    • 500+1.35825500+0.17606
    • 1000+1.300271000+0.16854
    • 4000+1.267144000+0.16425
    • 5000+1.258865000+0.16318
    库存:250
    YLNR-03VF
      库存:5500
      YLNR-03VF
        • 10+2.58784
        库存:3130
        YLNR-03VF
          库存:15000
          YLNR-03VF
            库存:1300
            YLNR-03VF
              • 1+2.711261+0.35143
              • 10+2.3625410+0.30623
              • 50+1.8307550+0.23730
              • 100+1.47332100+0.19097
              • 500+1.39486500+0.18080
              • 1000+1.342551000+0.17402
              • 2000+1.316402000+0.17063
              库存:24
              YLNR-03VF
                • 250+1.65580
                • 500+1.61415
                • 1000+1.58916
                库存:2880
