L722AC
L722AC
    SWITCHCRAFT
L722AC 数据手册
8 7 6 2.26 57.3 5 4 3 2 1 0.12 3.1 0.75 19.1 F F 0.58 14.6 FLEX RELIEF 0.10 [2.5 mm] PIN REF 5/16-32 THREAD REF CABLE OPENING FLEX RELIEF SEE TABLE CABLE CLAMP HANDLE FLEX RELIEF JACK & BUSHING CABLE OPENING FLEX RELIEF SEE TABLE 0.08 [2.0 mm] PIN REF CABLE OPENING FLEX RELIEF SEE TABLE HANDLE FLEX RELIEF JACK & BUSHING CABLE CLAMP 0.05 [1.3 mm] PIN REF HANDLE JACK & BUSHING CABLE CLAMP E E 722ACF & 722ACFL 712ACF & 712ACFL 1.51 38.2 732ACF & 732ACFL 0.12 3.1 D D 0.58 14.6 CABLE OPENING NO FLEX RELIEF SEE TABLE HANDLE 5/16-32 THREAD REF 0.10 [2.5 mm] PIN REF CABLE OPENING NO FLEX RELIEF SEE TABLE 0.08 [2.0 mm] PIN REF HANDLE JACK & BUSHING CABLE CLAMP CABLE OPENING NO FLEX RELIEF SEE TABLE HANDLE JACK & BUSHING CABLE CLAMP 0.05 [1.3 mm] PIN REF JACK & BUSHING CABLE CLAMP C C 722AC 712AC 732AC SLEEVE B NOTES: B 1. MATERIALS: HANDLE - THERMOPLASTIC, BLACK CABLE CLAMP - THERMOPLASTIC, BLACK FLEX RELIEF - THERMOPLASTIC ELASTOMER BUSHING - THERMOPLASTIC, BLACK PART NUMBER POWER JACK: HOUSING - COPPER ALLOY, NICKEL PLATED INSULATOR HOUSING - THERMOPLASTIC, BLACK TERMINAL INSULATORS - PHENOLIC PIN, SPRING, TERMINALS - COPPER ALLOY, SILVER PLATED 2. THESE PARTS ARE CURRENT CARRY ONLY NOT TO BE USED FOR CONNECT OR DISCONNECT UNDER LOAD. A 712AC B NONE CABLE RANGE YES 0.190 [4.83] - 0.220 [5.59] 712ACFL YES 0.220 [5.59] - 0.250 [6.35] NONE YES 0.190 [4.83] - 0.220 [5.59] 3. SHIPPED UNASSEMBLED. 722ACFL YES 0.220 [5.59] - 0.250 [6.35] 4. THESE PRODUCTS ARE RoHS COMPLIANT 732AC B JACK TERMINAL LAYOUT THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. UNLESS OTHERWISE SPECIFIED 0.324 [8.23] 732ACF YES 0.190 [4.83] - 0.220 [5.59] 732ACFL YES 0.220 [5.59] - 0.250 [6.35] B 28009 3-14-18 PC TJK A ECO 27926 8-17-17 SRC TJK ECO NUMBER DATE REVISIONS 7 6 5 4 BY APVD SIZE WIDTH MULT FINISH 1. ALL DIMENSIONS IN INCHES [mm] REV 8 CUSTOMER DRAWING SCALE 3:1 0.324 [8.23] 722ACF NONE SHUNT TIP 0.324 [8.23] 712ACF 722AC B FLEX RELIEF - TWO PLACE DECIMALS 0.02 - THREE PLACE DECIMALS 0.005 [0.13] DATE DRAWN BY 12-28-16 SRC DO NOT SCALE DRAWING SolidWorks CAD File NAME A SPEC No. SCALE CHKD SRC 8-10-17 3:2 APVD TJK 8-17-17 CABLE POWER JACKS, RoHS C TEMPER MATERIAL SPEC No. FIRST USED ON [0.5] LBS/M PART No. SHEET 1 OF 712AC-732AC 712ACF-732ACF 712ACFL-732ACFL 1 REV B
L722AC 价格&库存
很抱歉,暂时无法提供与“L722AC”相匹配的价格&库存,您可以联系我们找货
