144
A
Terminal blocks
Type 220
Type 179
to Type 220 and Type 179
Header, centerline 5.08 mm / 0.200 inches, vertical
mounting, square contact pins 1 mm / 0.039 inches,
closed ends, codable
mounting,designed for THR, optional Tape on Reel
packaging for automated processing, square contact
pins 1 mm / 0.039 inches, closed ends, codable
Technical Data
Technical Data
ASP046
page 50
Type 213
page 100
Type 214
page 100
Type 249
page 98
Type 250
page 98
V/A
V/A
Accessories
for Type 220 and Type 179
Coding set
700024
page 206
Note for Type 179
Packaging for automated
processing is available on
demand. Please do not hesitate to contact us.
300 / 15
250 V / 4 kV / 10 A
300 / 15
250 V / 4 kV / 10 A
Insulation co-ordination according to EN 60664-1
Clearance and creepage distances min. 4.08 mm
Insulating material class
CTI 600
Overvoltage category
III
III
II
Pollution degree
3
2
2
Rated voltage
320
800
800
Rated test voltage
4
6
4
Protection category according
to IEC 529
IP00
Solder pin dimension
1.0 x 1.0 mm
Recommended pc board hole
dia.
Ø 1.5 mm
Solder pin length
3.25 mm
Pole size
2 - 24
Color
black
Dimensions in mm
1 mm = 0.0394 in.
CTI 600
III
III
II
Pollution degree
3
2
2
Rated voltage
320
800
800
Rated test voltage
4
6
4
to IEC 529
IP00
1.0 x 1.0 mm
dia.
Ø 1.5 mm
Solder pin length
3.25 mm
Pole size
2 - 12
Color
black
Dimensions in mm
1 mm = 0.0394 in.
L = (pole size - 1) x centerline + 6.28 mm / 0.247 inches
Part numbers (P/N)
Part numbers (P/N)
(information: page 110)
Complete the part number by
adding the pole size.
Type 220
P/N 312201
Type 179
02 03 04 05 06 07 08
09 10 11 12 13 14 15 16
P/N 311791
09 10 11 12
17 18 19 20 21 22 23 24
Type 220
centerline 10.16 mm / 0.400 inches
P/N 312202
09 10 11 12
* approval pending
Standard pole sizes
Standard pole sizes
Available on demand. Minimum order quantity 5000
pieces per item.
pieces per item.
很抱歉,暂时无法提供与“31220102”相匹配的价格&库存,您可以联系我们找货
