31191103
31191103
    METZCONNECT
    插件,P=3.81mm
    排针 间距:3.81mm 1x3P 插件
31191103 数据手册
Data Sheet PR044xxVBBN Page 1/5 P/N 311911xx xx=number of poles 2014/01/27 Illustration see enlarged drawing at the end of the document Product specification • pin header, THR solderable • centerline 3.81 mm, direction of connection vertical 0° • closed ends • color black • Tape & Reel packaging • codeable • Connection data V / A 300 / 8 10 A / 130 V / 2.5 kV / 3 / IEC 61984 Page 2/5 P/N 311911xx xx=number of poles 2014/01/27 Data Sheet PR044xxVBBN Technical Data General Data Solder pin length min. number of poles max. number of poles Insulating material class clearance/creepage dist. protection category Overvoltage category Pollution degree Rated voltage Rated test voltage 3.25 mm 2 12 CTI 600 3.01 mm IP 00 III 3 200 V 4.0 kV III 2 500 V 4 kV Connection data V/A 300 / 8 10 A / 130 V / 2.5 kV / 3 / IEC 61984 Material insulating material flammability class contact pin material contact pin surface PA66/6T V0 CuMg Ni + Sn Climatic properties upper limit temperature lower limit temperature 105 °C -40 °C General solderability Tolerance Acc. to IPC/JEDEC J-STD-020D-MSL 1 ISO 2768 -mH II 2 500 V 4.0 kV Page 3/5 P/N 311911xx xx=number of poles 2014/01/27 Data Sheet PR044xxVBBN Matching Part to P/N 311131 311141 313691 ASP044 ASP064 Product name RP034xxHBLO Typ 113 RP034xxHBLN Typ 114 RP034xxVBLN Typ 369 SP044xxVBNN ASP044 SP064xxVGNN ASP064 Accessories P/N 720293-01-2 Product name 720293 Data Sheet PR044xxVBBN Illustration Drawing L=(pole size - 1) x centerline + 5.2 [0.205] Page 4/5 P/N 311911xx xx=number of poles 2014/01/27 Data Sheet PR044xxVBBN PCB Layout Powered by TCPDF (www.tcpdf.org) Page 5/5 P/N 311911xx xx=number of poles 2014/01/27
31191103 价格&库存
很抱歉,暂时无法提供与“31191103”相匹配的价格&库存,您可以联系我们找货
  • 1+7.316901+0.94780
  • 10+6.1916310+0.80204
  • 100+5.26219100+0.68164
库存:381
