Page 1/5
Data sheet
P/N
AST045xx
xx=number of poles
ST045xxDDNC AST045
2022/04/05
Version: X
Illustrations
Dimensional drawing
Drill pattern
See enlarged drawings at the end of document
Product specification
• spring clamp terminal block, solderable, double solder pins
• centerline 5.00 mm, direction of connection 45°
• fittable without loss of poles
• color gray
• eccentric lever
Data sheet
Page 2/5
ST045xxDDNC AST045
P/N
AST045xx
xx=number of poles
2022/04/05
Version: X
Technical Data
General Data
Solder pin length
min. number of poles
3.5 mm
max. number of poles
24
Insulating material class
CTI 400
clearance/creepage dist.
4 mm
Protection category
IP20
Min. insul. strip length
6 mm
Rated current
12 A
Overvoltage category
III
III
II
Pollution degree
3
2
2
Rated voltage
32 V
200 V
200 V
Rated test voltage
1.5 kV
1.5 kV
1.5 kV
2
Terminal data
rat.wiring solid AWGmax
0.2 mm² - 1.5 mm² / AWG 28 - AWG 16
rat.wiring strand.AWGmax
Approvals
V / A / AWG
approval UL - File No.
1 mm²
300 / 13 / 28 - 16
E121004
250 V / 13.5 A / T60
Material
insulating material
PA46
flammability class
V0
spring material
Spring steel
contact material
CuZn
Contact surface
Ni + Sn
Glow-Wire Flammability GWFI
Glow-Wire Flammability GWIT
REACh
compliant
REACh - substance (SVHC)
none
Climatic Data
upper limit temperature
105 °C
lower limit temperature
-40 °C
general
Data sheet
Page 3/5
ST045xxDDNC AST045
P/N
AST045xx
xx=number of poles
2022/04/05
Version: X
Technical Data
Tolerance
ISO 2768 -mH
Solderability
Acc. to JEDEC JESD22-B102E 245°C/5s
Data sheet
ST045xxDDNC AST045
Page 4/5
P/N
AST045xx
xx=number of poles
2022/04/05
Version: X
Illustrations
Dimensional drawing
L=(pole size - 1) x centerline + 5 mm [0.197]
Data sheet
ST045xxDDNC AST045
Page 5/5
P/N
AST045xx
xx=number of poles
2022/04/05
Version: X
Illustrations
Drill pattern
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“AST0450204”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+18.624841+2.40962
- 10+13.3896110+1.73231
- 25+11.6722825+1.51012
- 50+10.5671750+1.36715
- 100+9.63411100+1.24643
- 250+8.64752250+1.11879
- 500+8.06514500+1.04345
- 1000+7.601491000+0.98346
- 5000+6.873345000+0.88925
- 国内价格
- 1+13.85640
- 10+11.82600
- 30+10.55160
