SPH40401R0NETG
SPH40401R0NETG
    DARFON(达方)
    SMD,4.7x4.2mm
    功率电感 SMD
SPH40401R0NETG 数据手册
Inductors CCoon ntteen ntt Low Profile Inductors Ordering Code .......................................................................................................................... 2 Product Range .......................................................................................................................... 3 Molding Inductors (SPM Series) ............................................................................................... 4 ▓Standard External Dimensions ........................................................................................ 4 ▓Part Numbers & Characteristics ...................................................................................... 5 Coating Inductors (SPN/SPH Series) ..................................................................................... 15 ▓Standard External Dimensions ...................................................................................... 15 ▓Part Numbers & Characteristic (SPH Series for High Current) ..................................... 17 Testing Condition & Requirements .......................................................................................... 37 Packaging Specification .......................................................................................................... 39 Assembly Inductors Assembly Inductors (SPI Series) ............................................................................................ 43 Product Range ........................................................................................................................ 43 ▓Standard External Dimensions ...................................................................................... 44 ▓Part Numbers & Characteristic (SPI Series) ................................................................. 48 Multi-Layer Chip Inductors (MLCI) Multi-Layer Power Inductors (IP Series) ................................................................................. 62 ▓Ordering Code .............................................................................................................. 62 ▓Standard External Dimensions ...................................................................................... 63 ▓Part Numbers & Characteristic ...................................................................................... 64 ▓Testing Condition & Requirements ................................................................................ 66 Multi-Layer High Frequency Inductors (HI Series) .................................................................. 68 ▓Ordering Code .............................................................................................................. 68 ▓Standard External Dimensions ...................................................................................... 69 ▓Part Numbers & Characteristic ...................................................................................... 70 ▓Testing Condition & Requirements ................................................................................ 77 Packaging Specification .......................................................................................................... 80 Cautions ......................................................................................................................................... 82 Inductors-SPM/SPH/SPN Ordering Code SPM 2520 2R2 M P S A Product Code: SPM: Molding Inductor SPN : Coating Inductor(Normal) SPH :Coating Inductor(High Current ) Dimension (L X W): mm Code Dimension Code Dimension Thickness Code: Code Thick Code Thick Code Thick 5 0.5 E 1.5 L 3.0 7 0.7 F 1.6 M 3.5 1210 1.2 X 1.0 mm 5050 5.0 X 5.0 mm 9 0.9 G 1.8 N 4.0 2016 2.0 X 1.6 mm 6060 6.0 X 6.0 mm A 1.0 H 2.0 P 4.5 2020 2.0 X 2.0 mm 7070 7.0 X 7.0 mm B 1.1 I 2.4 Q 5.0 2424 2.4 X 2.4 mm 8080 8.0 X 8.0 mm C 1.2 J 2.5 R 6.0 2520 2.5 X 2.0 mm 1010 10 X 10 mm D 1.4 K 2.8 S 6.5 3030 3.0 X 3.0 mm 1313 13 X 13 mm 4040 4.0 X 4.0 mm Inductor Value R22=0.22 uH 2R2=2.2 uH 220=22 uH 221=220 uH 102=1000 uH Tolerance Code: M: ±20% T: ±25% N: ±30% Packaging Code: P: Embossed Reel (7”) E: Embossed Reel (13”) Specification: S:Standard C:High Current R:Low DCR M: Standard with vertical mark H:High Current with vertical mark T: Specific Spec Inductors-SPM/SPN/SPH Product Rang Product Range Molding Inductors (SPM Series) DARFON Item Dimensions Inductance range Hieght SPM2016 (mm) 2.5*1.6 0.1uH (mm) max 1.0~1.2 0.47uH SPM2520 SPM3030 2.5*2.0 3.0*3.0 1.0~1.2 0.47uH 0.47uH 1.2 10uH SPM4040 4.0*4.0 1.2~2.0 0.1uH 10uH SPM5050 5.0*5.0 1.2~2.0 0.1uH 15uH SPM7070 7.0*7.0 1.2~5.0 0.1uH 22uH SPM1010 SPM1313 10.0*10.0 13.0*13.0 0.36uH 4.0 3.5~6.0 0.15uH 68uH 1uH 10uH 100uH 1mH 2.2uH 10uH 150uH Coating Inductors (SPN / SPH Series) Dimensions Height SPH2020 SPH2520 SPH3030 SPH4040 SPH5050 SPH6060 SPH8080 SPN2016 (mm) 2.0*2.0 2.5*2.0 3.0*3.0 4.0*4.0 5.0*5.0 6.0*6.0 8.0*8.0 2.0*1.6 (mm) max 1.0~1.2 1.0~1.2 1.0-~1.2 1.0~1.8 2.0~4.0 1.2~4.5 4.0 1.0 SPN2020 SPN2424 SPN2520 SPN3030 SPN4040 SPN5050 SPN6060 SPN8080 2.0*2.0 2.4*2.4 2.5*2.0 3.0*3.0 4.0*4.0 5.0*5.0 6.0*6.0 8.0*8.0 1.2 1.0~1.2 1.0~1.2 1.0~1.5 1.0~1.8 1.0~4.0 1.0~4.5 3.0~4.0 DARFON Item Inductance range 0.1uH 1uH 10uH 100uH 1mH 0.47uH 4.7uH 0.47uH 22uH 0.47uH 22uH 1.0uH 33uH 0.47uH 47uH 0.8uH 100uH 0.9uH 22uH 0.47uH 10uH 1.0uH 4.7uH 0.47uH 22uH 0.47uH 10uH 1.0uH 47uH 1.0uH 220uH 0.47uH 47uH 0.8uH 100uH 0.9uH 100uH Inductors-SPM (Molding) Molding Inductors (SPM Series) ▓Feature ▓Application 1. Magnetic shielded construction 2. Frequency range up to 3.0MHz 3. Higher rated current, capable handling at high current spikes -Notebook / Desktop applications -VGA card applications -DC-DC Converter applications -Low profile, high current power supplies ▓Standard External Dimensions Recommended Land Patterns A' B E (mm) (mm) (mm) L (mm) W (mm) H (mm) B (mm) SPM2016□□□□PSA 2.0±0.2 1.6±0.2 1.0max 0.5±0.3 0.9 2.0 SPM2016□□□□PSC 2.0±0.2 1.6±0.2 1.2max 0.5±0.3 0.9 SPM2520□□□□PSA 2.5±0.2 2.0±0.2 1.0max 0.6±0.2 SPM2520□□□□PSC 2.5±0.2 2.0±0.2 1.2max 0.6±0.2 Series Package Ree l Amount(pcs) 1.6 7” 2,000 2.0 1.6 7” 2,000 1.2 2.8 2.0 7” 2,000 1.2 2.8 2.0 7” 2,000 1R0 Recommended Land Patterns A' B E (mm) (mm) (mm) L (mm) W (mm) H (mm) C (mm) D (mm) SPM3030□□□□PSC 3.2±0.2 3.0±0.2 1.2max 0.8±0.2 1.2±0.2 1.2 4.2 SPM4040□□□□ESC 4.7±0.3 4.2±0.2 1.2max 0.8±0.3 2.0±0.3 2.4 SPM4040□□□□ESH 4.7±0.3 4.2±0.2 2.0max 0.8±0.3 2.0±0.3 SPM4040□□□□ECH 4.7±0.3 4.2±0.2 2.0max 0.8±0.3 2.0±0.3 SPM5050□□□□ESC 5.7±0.3 5.2±0.2 1.2max 1.0±0.3 SPM5050□□□□ESE 5.7±0.3 5.2±0.2 1.5max 1.0±0.3 SPM5050□□□□ESH 5.7±0.3 5.2±0.2 1.8max SPM5050□□□□ECL 5.7±0.3 5.2±0.2 3.0max SPM7070□□□□ESC 7.2±0.3 6.6±0.2 SPM7070□□□□ESE 7.0±0.3 6.5±0.2 SPM7070□□□□ESG 7.2±0.3 6.6±0.2 SPM7070□□□□ESL 6.95±0.35 SPM7070□□□□ERL SPM7070□□□□ECL Series Package Ree l Amount(pcs) 2.0 7” 2,000 5.4 2.5 13” 3,500 2.4 5.4 2.5 13” 2,000 2.4 5.4 2.5 13” 2,000 2.5±0.3 3.0 7.0 3.5 13” 3,000 2.5±0.3 3.0 7.0 3.5 13” 3,000 1.0±0.3 2.5±0.3 3.0 7.0 3.5 13” 3,000 1.0±0.3 2.5±0.3 3.0 7.0 3.5 13” 2,000 1.2max 1.5±0.3 3.0±0.3 4.0 8.5 3.5 13” 2,500 1.5max 1.5±0.3 3.0±0.3 4.0 8.5 3.5 13” 2,000 1.8max 1.5±0.3 3.0±0.3 4.0 8.5 3.5 13” 2,000 6.6±0.2 3.0max 1.5±0.3 3.0±0.3 4.0 8.5 3.5 13” 1,500 6.95±0.35 6.6±0.2 3.0max 1.5±0.3 3.0±0.3 4.0 8.5 3.5 13” 1,500 6.95±0.35 6.6±0.2 3.0max 1.5±0.3 3.0±0.3 4.0 8.5 3.5 13” 1,500 SPM7070□□□□ESQ 7.2±0.3 6.6±0.2 5.0max 1.5±0.3 3.0±0.3 4.0 8.5 3.5 13 1,000 SPM1010□□□□ESN 11.2±0.3 10.0±0.3 4.0max 2.0±0.5 3.0±0.5 5.5 13.5 4.0 13” 800 SPM1010□□□□ECN 11.2±0.3 10.0±0.3 4.0max 2.0±0.5 3.0±0.5 5.5 13.5 4.0 13” 800 SPM1313□□□□ECM 13.9±0.3 12.8±0.2 3.5max 2.0±0.5 5.0±0.5 8.0 14.5 6.0 13” 500 SPM1313□□□□ESQ 13.9±0.3 12.8±0.2 5.0max 2.0±0.5 5.0±0.5 8.0 14.5 6.0 13” 500 SPM1313□□□□ESR 13.9±0.3 12.8±0.2 6.0max 2.0±0.5 5.0±0.5 8.0 14.5 6.0 13” 500 Inductors-SPM (Molding) ▓Part Numbers & Characteristics SPM2016□□□□PSA (Thickness 1.0mm) DARFON P/N Inductance (uH) SPM2016R56MPSA 0.56 SPM2016R68MPSA 0.68 SPM20161R0MPSA 1.0 SPM20161R5MPSA SPM20162R2MPSA Tolerance DC Resistance (mΩ) Typ. Max. 44 59 Heat Rating Current DC Amps Saturation Current DC Amps Idc(A) Typ. Isat(A) Typ. 3.3 3.5 55 72 2.9 3.2 80 96 2.3 2.7 1.5 120 144 1.9 2.2 2.2 170 204 1.4 1.9 Heat Rating Current DC Amps Saturation Current DC Amps Idc(A) Typ. Isat(A) Typ. 3.8 4.2 ± 20% Measuring Condition 1MHz/1.0V SPM2016□□□□PSC (Thickness 1.2mm) DARFON P/N Inductance (uH) SPM2016R47MPSC 0.47 SPM20161R0MPSC 1.0 SPM20161R5MPSC 1.5 SPM20162R2MPSC 2.2 Tolerance ± 20% DC Resistance (mΩ) Typ. Max. 40 52 68 82 2.7 3.1 95 114 2.1 2.5 160 192 1.5 2.0 Heat Rating Current DC Amps Saturation Current DC Amps Measuring Condition 1MHz/1.0V SPM2520□□□□PSA (Thickness 1.0mm) DARFON P/N Inductance (uH) Tolerance DC Resistance (mΩ) Typ. Max. Idc(A) Typ. Isat(A) Typ. SPM2520R47MPSA 0.47 35 46 3.6 4.4 SPM25201R0MPSA 1.0 45 59 3.0 3.4 SPM25201R5MPSA 1.5 60 72 2.3 2.7 SPM25202R2MPSA 2.2 90 108 1.8 2.4 SPM25203R3MPSA 3.3 120 144 1.4 1.9 SPM25204R7MPSA 4.7 200 240 1.2 1.6 ± 20% All test data are referenced to 25℃ambient. ※Isat: DC current(A) that will cause inductance to drop approximately 30%. ※Idc: DC current(A) that will cause an approximate ᇞT of 40℃. Measuring Condition 100KHz/1.0V Inductors-SPM (Molding) SPM2520□□□□PSC (Thickness 1.2mm) DARFON P/N Inductance (uH) Tolerance DC Resistance (mΩ) Typ. Max. Heat Rating Current DC Amps Saturation Current DC Amps Idc(A) Typ. Isat(A) Typ. SPM2520R47MPSC 0.47 29 35 4.0 4.1 SPM2520R68MPSC 0.68 38.0 45.0 3.8 3.9 SPM25201R0MPSC 1.0 45.0 59.0 3.5 3.8 SPM25201R5MPSC 1.5 SPM25202R2MPSC 2.2 60.0 72.0 2.8 3.3 90.0 108.0 2.3 2.7 SPM25203R3MPSC 3.3 120.0 144.0 1.7 2.3 SPM25204R7MPSC 4.7 200.0 240.0 1.5 1.9 SPM25206R0MPSC 6.0 240.0 275.0 1.3 1.7 SPM2520100MPSC 10.0 400.0 460.0 1.0 1.3 Heat Rating Current DC Amps Saturation Current DC Amps Idc(A) Typ. Isat(A) Typ. ± 20% Measuring Condition 100KHz/1.0V SPM3030□□□□PSC (Thickness 1.2mm) DARFON P/N Inductance (uH) Tolerance DC Resistance (mΩ) Typ. Max. SPM3030R47MPSC 0.47 21 31 4.5 6.0 SPM30301R0MPSC 1.0 58 65 2.8 3.4 SPM30302R2MPSC 2.2 123 135 2.2 2.8 SPM3030100MPSC 100 405 490 1.1 1.3 Heat Rating Current DC Amps Saturation Current DC Amps ± 20% Measuring Condition 100KHz/1.0V SPM4040□□□□ESC (Thickness 1.2mm) DARFON P/N Inductance (uH) Tolerance DC Resistance (mΩ) Typ. Max. Idc(A) Typ. Isat(A) Typ. SPM4040R47MESC 0.47 19.0 21.0 6.0 6.8 SPM4040R68MESC 0.68 32.0 36.0 4.5 6.0 SPM40401R0MESC 1.0 43.0 47.0 4.2 5.2 SPM40401R5MESC 1.5 68.0 75.0 3.25 4.0 SPM40402R2MESC 2.2 79.4 83.5 2.75 3.5 SPM40403R3MESC 3.3 120.0 138.0 2.30 3.0 SPM40404R7MESC 4.7 175.0 195.0 1.8 2.8 SPM40406R8MESC 6.8 292.0 358.0 1.50 2.2 SPM4040100MESC 100 394.0 465.0 1.30 1.8 ± 20% All test data are referenced to 25℃ambient. ※Isat: DC current(A) that will cause inductance to drop approximately 30%. ※Idc: DC current(A) that will cause an approximate ᇞT of 40℃. Measuring Condition 100KHz/1.0V Inductors-SPM (Molding) SPM4040□□□□ESH (Thickness 2.0mm) DARFON P/N SPM4040R10NESH Inductance (uH) Tolerance 0.10 ± 30% DC Resistance (mΩ) Typ. Max. 3.5 4.0 Heat Rating Current DC Amps Saturation Current DC Amps Idc(A) Typ. Isat(A) Typ. 12.0 22.0 SPM4040R22MESH 0.22 6.0 6.6 9.0 12.5 SPM4040R47MESH 0.47 12.5 14.0 7.0 9.5 SPM4040R56MESH 0.56 14.0 16.0 6.5 9.0 SPM4040R68MESH 0.68 19.4 21.0 5.2 8.0 SPM40401R0MESH 1.0 24.0 27.0 4.5 7.0 SPM40401R5MESH 1.5 38.0 46.0 4.0 6.0 SPM40402R2MESH 2.2 52.0 58.0 3.0 5.0 ± 20% SPM40403R3MESH 3.3 74.0 87.0 2.5 4.0 SPM40404R7MESH 4.7 92.0 105.0 2.2 3.0 SPM40406R8MESH 6.8 162.0 178.0 2.0 2.1 SPM4040100MESH 10 256.0 282.0 1.6 1.8 Heat Rating Current DC Amps Saturation Current DC Amps Idc(A) Typ. Isat(A) Typ. Measuring Condition 100KHz/1.0V SPM4040□□□□ECH (Thickness 2.0mm) DARFON P/N Inductance (uH) SPM4040R10NECH 0.10 SPM4040R22MECH 0.22 SPM4040R47MECH 0.47 SPM40401R0MECH 1.0 SPM40402R2MECH 2.2 Tolerance ± 30% ± 20% DC Resistance (mΩ) Typ. Max. 4.5 5.0 11.0 30.0 7.3 8.0 9.0 17.0 14.0 15.5 6.0 11.5 32.0 36.0 4.2 8.5 79.4 83.0 4.0 6.0 Heat Rating Current DC Amps Saturation Current DC Amps Measuring Condition 100KHz/1.0V SPM5050□□□□ESC (Thickness 1.2mm) DARFON P/N Inductance (uH) Tolerance DC Resistance (mΩ) Typ. Max. Idc(A) Typ. Isat(A) Typ. SPM50501R0MESC 1.0 31.3 32.9 5.0 6.0 SPM50502R2MESC 2.2 67.0 76.0 3.5 4.0 SPM50503R3MESC 3.3 85.0 98.0 3.0 3.7 SPM50504R7MESC 4.7 145.0 163.0 2.3 2.7 SPM50506R8MESC 6.8 225.0 250.0 2.0 2.3 ± 20% All test data are referenced to 25℃ambient. ※Isat: DC current(A) that will cause inductance to drop approximately 30%. (note: SPM4040□□□□ECH specification is defined inductance to drop approximately 20%) ※Idc: DC current(A) that will cause an approximate ᇞT of 40℃. Measuring Condition 100KHz/1.0V Inductors-SPM (Molding) SPM5050□□□□ESE (Thickness 1.5mm) DARFON P/N Inductance (uH) Tolerance DC Resistance (mΩ) Typ. Max. Heat Rating Current DC Amps Saturation Current DC Amps Idc(A) Typ. Isat(A) Typ. SPM50501R0MESE 1.0 20.0 23.0 6.5 9.0 SPM50501R2MESE 1.2 22.5 26.0 6.0 8.0 SPM50502R2MESE 2.2 58.0 64.0 3.3 6.0 SPM50503R3MESE 3.3 65.0 72.0 3.2 5.0 SPM50504R7MESE 4.7 103 115 3.0 4.0 SPM50506R8MESE 6.8 167 180 2.5 3.2 SPM5050100MESE 10 220 246 2.0 3.0 SPM5050150MESE 15 310.0 350.0 1.3 2.3 Heat Rating Current DC Amps Saturation Current DC Amps Idc(A) Typ. Isat(A) Typ. ± 20% Measuring Condition 100KHz/1.0V SPM5050□□□□ESH (Thickness 2.0mm) DARFON P/N Inductance (uH) SPM5050R10NESH 0.10 SPM5050R22MESH 0.22 Tolerance ± 30% DC Resistance (mΩ) Typ. Max. 7.7 9.0 10.5 15.5 4.1 4.5 12.0 20.0 SPM5050R33MESH 0.33 5.5 5.9 11.5 16.0 SPM5050R47MESH 0.47 8.0 10.0 10.5 15.5 SPM5050R56MESH 0.56 8.2 10.0 9.5 13.0 SPM5050R68MESH 0.68 10.5 13.0 9.0 12.0 SPM50501R0MESH 1.0 15.0 17.0 8.0 9.5 SPM50501R5MESH 1.5 21.0 24.2 6.0 9.0 SPM50502R2MESH 2.2 30.0 35.0 5.0 6.5 SPM50503R3MESH 3.3 52.0 58.0 4.5 5.5 SPM50504R7MESH 4.7 78.0 85.0 3.5 4.0 SPM50505R6MESH 5.6 85.2 92.0 3.0 2.2 SPM50506R8MESH 6.8 107.0 120.0 2.8 3.6 SPM5050100MESH 10 140.0 155.0 2.4 3.4 ± 20% All test data are referenced to 25℃ambient. ※Isat: DC current(A) that will cause inductance to drop approximately 30%. ※Idc: DC current(A) that will cause an approximate ᇞT of 40℃. Measuring Condition 100KHz/1.0V Inductors-SPM (Molding) SPM5050□□□□ECL (Thickness 3.0mm) DARFON P/N Inductance (uH) Tolerance DC Resistance (mΩ) Typ. Max. 11.0 12.0 Heat Rating Current DC Amps Saturation Current DC Amps Idc(A) Typ. Isat(A) Typ. 8.5 14.0 SPM5050R68MECL 0.68 SPM50501R0MECL 1.0 13.0 14.0 7.0 11.0 SPM50501R2MECL 1.2 15.0 16.0 6.5 11.0 SPM50501R5MECL 1.5 20.0 25.0 6.0 10.0 SPM50502R2MECL 2.2 29.0 35.0 5.5 9.0 SPM50503R3MECL 3.3 32.0 38.0 5.0 7.0 SPM50504R7MECL 4.7 50.0 60.0 4.4 6.0 Heat Rating Current DC Amps Saturation Current DC Amps ± 20% Measuring Condition 100KHz/1.0V SPM7070□□□□ESC (Thickness 1.2mm) DARFON P/N Inductance (uH) Tolerance DC Resistance (mΩ) Typ. Max. Idc(A) Typ. Isat(A) Typ. SPM7070R56MESC 0.56 13.5 15.5 7.0 11.0 SPM7070R68MESC 0.68 15.0 17.5 6.7 9.0 SPM7070R82MESC 0.82 21.5 24.5 6.3 8.0 SPM70701R0MESC 1.0 25.0 29.0 6.0 7.0 SPM70702R2MESC 2.2 51.5 59.0 4.0 5.0 ± 20% SPM70703R3MESC 3.3 80.0 92.0 3.0 4.0 SPM70704R7MESC 4.7 106.0 122.0 2.7 3.5 SPM70706R8MESC 6.8 185.0 217.0 2.2 2.4 SPM7070100MESC 10 250.0 290.0 2.0 2.2 Heat Rating Current DC Amps Saturation Current DC Amps Measuring Condition 100KHz/1.0V SPM7070□□□□ESE (Thickness 1.5mm) DARFON P/N Inductance (uH) Tolerance DC Resistance (mΩ) Typ. Max. Idc(A) Typ. Isat(A) Typ. 6.8 7.8 10.0 19.5 SPM7070R33MESE 0.33 SPM7070R56MESE 0.56 9.5 11.0 9.0 14.0 SPM7070R68MESE 0.68 10.5 12.0 8.5 12.0 SPM7070R82MESE 0.82 15.0 17.0 7.0 10.0 SPM70701R0MESE 1.0 18.5 21.0 5.5 9.0 SPM70701R5MESE 1.5 37.0 42.5 5.0 7.0 SPM70702R2MESE 2.2 46.0 54.0 3.5 6.0 SPM70703R3MESE 3.3 54.0 63.0 3.3 5.5 SPM70704R7MESE 4.7 76.0 85.0 3.0 5.0 SPM70705R6MESE 5.6 96.0 118.0 2.8 4.5 SPM70706R8MESE 6.8 125.0 135.0 2.5 4.0 SPM7070100MESE 10 165.0 175.0 2.0 3.0 ± 20% All test data are referenced to 25℃ambient. ※Isat: DC current(A) that will cause inductance to drop approximately 30%. (note: SPM5050□□□□ECL specification is defined inductance to drop approximately 20%) ※Idc: DC current(A) that will cause an approximate ᇞT of 40℃. Measuring Condition 100KHz/1.0V Inductors-SPM (Molding) SPM7070□□□□ESG (Thickness 1.8mm) DARFON P/N Inductance (uH) Tolerance DC Resistance (mΩ) Typ. Max. Heat Rating Current DC Amps Saturation Current DC Amps Idc(A) Typ. Isat(A) Typ. SPM7070R33MESG 0.33 5.2 6.8 12.0 22.0 SPM7070R47MESG 0.47 7.3 8.4 11.0 17.0 SPM7070R68MESG 0.68 10.8 12.7 9.0 16.0 SPM7070R82MESG 0.82 13.4 15.9 8.0 14.0 SPM70701R0MESG 1.0 14.5 17.0 7.0 12.0 SPM70702R2MESG 2.2 31.0 35.0 5.0 8.0 SPM70703R3MESG 3.3 56.0 60.0 3.5 7.0 SPM70704R7MESG 4.7 68.0 70.0 3.2 5.5 SPM70706R8MESG 6.8 101.0 110.0 2.8 4.5 SPM70708R2MESG 8.2 124.0 142.0 2.5 4.0 SPM7070100MESG 10 155.0 166.0 2.0 3.0 Heat Rating Current DC Amps Saturation Current DC Amps ± 20% Measuring Condition 100KHz/1.0V SPM7070□□□□ESL (Thickness 3.0mm) Inductance (uH) Tolerance SPM7070R10NESL 0.10 ± 30% SPM7070R22MESL DARFON P/N DC Resistance (mΩ) Typ. Max. Idc(A) Typ. Isat(A) Typ. 1.5 1.7 32.5 60.0 0.22 2.5 2.8 23.0 34.0 SPM7070R33MESL 0.33 3.0 3.5 21.0 25.0 SPM7070R47MESL 0.47 3.5 4.1 18.0 20.0 SPM7070R56MESL 0.56 3.9 4.5 16.5 18.0 SPM7070R68MESL 0.68 4.5 5.0 16.0 17.0 SPM7070R82MESL 0.82 7.0 7.5 14.0 16.0 SPM70701R0MESL 1.0 8.5 9.0 12.0 15.0 SPM70701R5MESL 1.5 10.6 12.1 10.0 13.0 SPM70702R2MESL 2.2 15.5 18.0 8.0 10.0 SPM70702R5MESL 2.5 18.0 20.0 7.0 10.0 SPM70703R3MESL 3.3 25.0 28.0 6.5 9.0 SPM70704R7MESL 4.7 32.5 35.0 5.5 6.5 SPM70705R6MESL 5.6 36.0 42.0 5.0 6.3 SPM70706R8MESL 6.8 43.9 50.0 4.5 6.0 SPM70708R2MESL 8.2 54.0 60.0 4.5 6.0 SPM7070100MESL 10 62.0 68.0 4.0 5.5 SPM7070220MESL 22 144.0 160.0 2.5 3.0 ± 20% All test data are referenced to 25℃ambient. ※Isat: DC current(A) that will cause inductance to drop approximately 30%. ※Idc: DC current(A) that will cause an approximate ᇞT of 40℃. Measuring Condition 100KHz/1.0V Inductors-SPM (Molding) SPM7070□□□□ERL (Thickness 3.0mm) DARFON P/N Inductance (uH) Tolerance DC Resistance (mΩ) Heat Rating Current DC Amps Saturation Current DC Amps Typ. Max. Idc(A) Typ. Isat(A) Typ. 5.2 6.0 16.0 16.0 5.5 6.6 15.0 15.0 7.7 9.3 12.5 14.5 SPM7070R82MERL 0.82 SPM70701R0MERL 1.0 SPM70701R5MERL 1.5 SPM70702R2MERL 2.2 12.0 13.8 10.0 14.0 SPM70703R3MERL 3.3 19.6 22.5 7.7 10.0 Heat Rating Current DC Amps Saturation Current DC Amps Idc(A) Typ. Isat(A) Typ. 32.5 60.0 ± 20% Measuring Condition 100KHz/1.0V SPM7070□□□□ECL (Thickness 3.0mm) DARFON P/N SPM7070R10NECL Inductance (uH) Tolerance 0.10 ± 30% DC Resistance (mΩ) Typ. Max. 1.5 1.7 SPM7070R22MECL 0.22 2.5 2.8 23.0 40.0 SPM7070R33MECL 0.33 3.5 3.9 20.0 30.0 SPM7070R47MECL 0.47 4.0 4.2 17.5 26.0 SPM7070R56MECL 0.56 4.7 5.0 16.5 25.5 SPM7070R68MECL 0.68 5.0 5.5 15.5 25.0 SPM7070R82MECL 0.82 6.7 8.0 13.0 24.0 SPM70701R0MECL 1.0 SPM70701R5MECL 1.5 SPM70702R2MECL SPM70702R5MECL 9.0 10.0 11.0 22.0 14.0 15.0 9.0 18.0 2.2 18.0 20.0 8.0 14.0 2.5 20.0 22.0 7.0 14.0 SPM70703R3MECL 3.3 28.0 30.0 6.0 13.5 SPM70704R7MECL 4.7 37.0 40.0 5.5 10.0 SPM70706R8MECL 6.8 54.0 60.0 4.5 8.0 SPM70708R2MECL 8.2 64.0 68.0 4.0 7.5 SPM7070100MECL 10 102.0 105.0 3.0 7.0 ± 20% All test data are referenced to 25℃ambient. ※Isat: DC current(A) that will cause inductance to drop approximately 30%. (note: SPM7070□□□□ECL specification is defined inductance to drop approximately 20%) ※Idc: DC current(A) that will cause an approximate ᇞT of 40℃. Measuring Condition 100KHz/1.0V Inductors-SPM (Molding) SPM7070□□□□ESQ (Thickness 5.0mm) DARFON P/N SPM7070R10NESQ Inductance (uH) Tolerance 0.10 ± 30% DC Resistance (mΩ) Typ. Max. 0.9 1.1 Heat Rating Current DC Amps Saturation Current DC Amps Idc(A) Typ. Isat(A) Typ. 43.0 48.0 SPM7070R22MESQ 0.22 1.1 1.3 30.0 35.0 SPM7070R36MESQ 0.36 2.7 3.1 21.0 25.0 SPM7070R56MESQ 0.56 3.4 3.6 20.0 18.0 SPM7070R68MESQ 0.68 3.3 3.6 18.0 17.0 SPM7070R82MESQ 0.82 4.6 4.9 16.5 17.0 SPM70701R0MESQ 1.0 4.5 5.3 14.5 16.0 SPM70701R5MESQ 1.5 6.0 7.5 11.5 15.0 SPM70702R2MESQ 2.2 9.0 10.2 10.5 13.5 SPM70703R3MESQ 3.3 14.0 15 9.0 12.0 SPM70704R7MESQ 4.7 23.0 25.0 6.5 8.0 SPM70705R6MESQ 5.6 31.5 34.4 6.0 7.0 SPM70706R8MESQ 6.8 31 35.5 5.5 6.5 SPM70708R2MESQ 8.2 40.0 43.0 5.0 5.5 SPM7070100MESQ 10 48.0 55.0 4.5 5.0 Heat Rating Current DC Amps Saturation Current DC Amps ± 20% Measuring Condition 100KHz/1.0V SPM1010□□□□ESN (Thickness 4.0mm) DARFON P/N Inductance (uH) Tolerance DC Resistance (mΩ) Typ. Max. Idc(A) Typ. Isat(A) Typ. SPM1010R36MESN 0.36 1.1 1.3 30.0 50.0 SPM1010R45MESN 0.45 1.1 1.3 29.0 40.0 SPM1010R56MESN 0.56 1.6 1.8 25.0 33.0 SPM10101R0MESN 1.0 3.0 3.3 18.0 28.0 SPM10101R5MESN 1.5 3.8 4.2 16.0 24.0 SPM10102R0MESN 2.0 5.2 5.8 14.0 20.0 SPM10102R2MESN 2.2 6.0 7.0 12.0 18.0 SPM10103R3MESN 3.3 10.8 11.8 10.0 16.0 SPM10104R7MESN 4.7 17.0 20.0 8.5 15.0 SPM10105R6MESN 5.6 20.0 23.0 8.0 14.0 SPM10106R8MESN 6.8 22.5 25.0 7.0 12.0 SPM10108R2MESN 8.2 25.0 27.0 6.5 9.0 SPM1010100MESN 10 27.0 30.0 6.5 8.5 SPM1010150MESN 15 40.0 45.0 6.3 7.0 SPM1010220MESN 22 60.0 66.0 5.0 5.5 SPM1010330MESN 33 85.0 92.0 4.0 4.5 SPM1010470MESN 47 130.0 145.0 3.3 3.5 SPM1010680MESN 68 178.0 195.0 2.3 3.0 ± 20% All test data are referenced to 25℃ambient. ※Isat: DC current(A) that will cause inductance to drop approximately 30%. ※Idc: DC current(A) that will cause an approximate ᇞT of 40℃. Measuring Condition 100KHz/1.0V Inductors-SPM (Molding) SPM1010□□□□ECN (Thickness 4.0mm) DARFON P/N Inductance (uH) Tolerance DC Resistance (mΩ) Typ. Max. Heat Rating Current DC Amps Saturation Current DC Amps Idc(A) Typ. Isat(A) Typ. SPM1010R36MECN 0.36 1.1 1.3 30.0 60.0 SPM1010R39MECN 0.39 1.1 1.3 30.0 60.0 SPM1010R45MECN 0.45 1.1 1.3 29.0 45.0 SPM1010R68MECN 0.68 2.4 2.7 22.0 39.0 SPM1010R88MECN 0.88 2.7 3.0 20.0 38.0 SPM10101R5MECN 1.5 3.8 4.2 16.0 33.0 SPM10102R2MECN 2.2 6.7 7.0 12.0 27.0 SPM10103R3MECN 3.3 10.8 11.8 10.0 18.7 SPM10104R7MECN 4.7 15.0 16.5 9.5 17.0 Heat Rating Current DC Amps Saturation Current DC Amps Idc(A) Typ. Isat(A) Typ. ± 20% Measuring Condition 100KHz/1.0V SPM1313□□□□ECM (Thickness 3.5mm) DARFON P/N Inductance (uH) Tolerance DC Resistance (mΩ) Typ. Max. SPM1313R22MECM 0.22 1.1 1.3 38.0 65.0 SPM1313R33MECM 0.33 1.3 1.5 36.5 62.0 SPM1313R47MECM 0.47 1.7 2.0 32.0 55.0 SPM1313R56MECM 0.56 1.8 2.2 29.0 51.0 SPM1313R68MECM 0.68 2.3 2.5 28.0 49.0 SPM13131R0MECM 1.0 3.3 3.5 24.0 40.0 SPM13131R5MECM 1.5 5.1 5.5 19.0 35.0 SPM13132R2MECM 2.2 7.2 8.0 16.0 29.0 SPM13133R3MECM 3.3 10.0 12.0 12.0 27.0 SPM13134R7MECM 4.7 16.0 18.0 9.0 22.0 ± 20% All test data are referenced to 25℃ambient. ※Isat: DC current(A) that will cause inductance to drop approximately 30%. (note: SPM1010□□□□ECN and SPM1313□□□□ECM specifications are defined inductance to drop approximately 20%) ※Idc: DC current(A) that will cause an approximate ᇞT of 40℃. Measuring Condition 100KHz/1.0V Inductors-SPM (Molding) SPM1313□□□□ESQ (Thickness 5.0mm) DARFON P/N Inductance (uH) Tolerance DC Resistance (mΩ) Typ. Max. Heat Rating Current DC Amps Saturation Current DC Amps Idc(A) Typ. Isat(A) Typ. 45.0 60.0 SPM1313R15MESQ 0.15 0.38 0.45 SPM1313R36MESQ 0.36 0.64 0.95 41.0 55.0 SPM1313R47MESQ 0.47 0.85 1.1 38.0 50.0 SPM1313R56MESQ 0.56 1.1 1.3 36.0 45.0 SPM1313R68MESQ 0.68 1.2 1.5 34.0 40.0 SPM1313R82MESQ 0.82 1.5 1.7 31.0 34.0 SPM13131R0MESQ 1.0 1.9 2.2 26.0 30.0 SPM13131R5MESQ 1.5 2.8 3.2 23.0 27.0 SPM13132R2MESQ 2.2 4.0 5.0 15.0 24.0 SPM13133R3MESQ 3.3 5.9 7.0 14.0 22.0 SPM1313100MESQ 10 19.0 22.0 9.0 12.0 SPM1313220MESQ 22 51.0 58.0 4.5 6.5 SPM1313270MESQ 27 58.0 66.0 4.0 6.3 SPM1313330MESQ 33 75.0 84.0 3.5 6.0 SPM1313470MESQ 47 116.0 130.0 3.0 5.0 Heat Rating Current DC Amps Saturation Current DC Amps ± 20% Measuring Condition 100KHz/1.0V SPM1313□□□□ESR (Thickness 6.0mm) DARFON P/N Inductance (uH) Tolerance DC Resistance (mΩ) Typ. Max. Idc(A) Typ. Isat(A) Typ. SPM1313R22MESR 0.22 0.50 0.60 36.00 70.00 SPM1313R33MESR 0.33 0.60 0.80 35.00 65.00 SPM1313R47MESR 0.47 0.7 0.9 34 60.00 SPM1313R68MESR 0.68 1.00 1.20 32.00 45.00 SPM13131R0MESR 1.00 1.60 1.90 31.00 43.00 SPM13132R2MESR 2.20 3.30 4.10 21.00 30.00 SPM13133R3MESR 3.30 5.30 6.40 17.00 22.00 SPM13134R7MESR 4.7 7.2 9.0 16.00 18.0 SPM13136R8MESR 6.8 9.5 12.0 12.0 15.0 SPM13138R2MESR 8.2 13.6 16.0 11.0 13.5 SPM1313100MESR 10 18.0 20.7 10.0 12.5 SPM1313120MESR 12 20.0 23.0 7.0 10.0 SPM1313150MESR 15 25.0 29.0 6.0 9.0 SPM1313220MESR 22 34.0 39.5 5.0 7.5 SPM1313270MESR 27 49.0 56.0 4.5 6.5 SPM1313330MESR 33 65.0 75.0 4.0 6.0 SPM1313470MESR 47 80.0 90.0 3.5 5.5 SPM1313680MESR 68 120.0 140.0 3.0 4.5 SPM1313101MESR 100 180.0 200.0 2.5 3.5 SPM1313121MESR 120 210.0 235.0 2.3 3.2 SPM1313151MESR 150 300.0 350.0 2.0 2.7 ± 20% All test data are referenced to 25℃ambient. ※Isat: DC current(A) that will cause inductance to drop approximately 30%. ※Idc: DC current(A) that will cause an approximate ᇞT of 40℃. Measuring Condition 100KHz/1.0V Inductors – SPN/SPH (Coating) Coating Inductors (SPN/SPH Series) ▓Feature ▓Application 1. Small and low profile inductor 2. It corresponds to high current 3. Simple and original magnetic shield structure For small DC/DC converter (HDD, DVC, DSC, LCD display, notebook, tablet, Bluetooth earphone, cellular phones) ▓Standard External Dimensions BOTTOM Series L (mm) W (mm) H (mm) SPN2016□□□□PSA SPN2520□□□□PSA SPH2520□□□□PSA SPN2520□□□□PSC SPH2520□□□□PSC 2.0±0.2 2.5±0.2 2.5±0.3 2.5±0.2 2.5±0.3 1.6±0.2 2.0±0.2 2.0±0.3 2.0±0.2 2.0±0.3 1.0max 1.0max 1.0±0.1 1.2max 1.2±0.1 Recommended Land Patterns A B E (mm) (mm) (mm) 1.7 2.3 0.6 2.1 0.8 0.85 2.1 0.8 0.85 2.1 0.8 0.85 2.1 0.8 0.85 Package Reel Amount(pcs) 7” 7" 7" 7" 7" 2,000 2,000 2,000 2,000 2,000 BOTTOM Seri SPN2020□□□□PTC SPH2020□□□□PCC SPH2020□□□□PTA SPH2020□□□□PTC SPN2424□□□□PTA SPN2424□□□□PTC SPN3030□□□□PTA SPH3030□□□□PTA SPN3030□□□□PTC SPH3030□□□□PTC SPN3030□□□□PTE SPN4040□□□□ETA SPH4040□□□□ETA SPN4040□□□□ETC SPH4040□□□□ETC SPN4040□□□□ETG SPH4040□□□□ETG SPN5050□□□□PTA SPN5050□□□□PTC SPN5050□□□□PTD SPH5050□□□□PTH SPN5050□□□□ETI SPN5050□□□□ETL SPN5050□□□□ETN SPH5050□□□□ETN L (mm) W (mm) H (mm) C (mm) D (mm) 2.0±0.1 2.0±0.1 2.0±0.1 2.0±0.1 2.4±0.1 2.4±0.1 3.0±0.1 3.0±0.1 3.0±0.1 3.0±0.1 3.0±0.1 4.0±0.2 4.0±0.2 4.0±0.2 4.0±0.2 4.0±0.2 4.0±0.2 4.9±0.1 4.9±0.1 4.9±0.1 4.9±0.1 4.9±0.1 4.9±0.2 4.9±0.1 4.9±0.1 2.0±0.1 2.0±0.1 2.0±0.1 2.0±0.1 2.4±0.1 2.4±0.1 3.0±0.1 3.0±0.1 3.0±0.1 3.0±0.1 3.0±0.1 4.0±0.2 4.0±0.2 4.0±0.2 4.0±0.2 4.0±0.2 4.0±0.2 4.9±0.1 4.9±0.1 4.9±0.1 4.9±0.1 4.9±0.1 4.9±0.2 4.9±0.1 4.9±0.1 1.2max 1.2max 1.0max 1.2max 1.0max 1.2max 1.0max 1.0max 1.2max 1.2max 1.5max 1.0max 1.0max 1.2max 1.2max 1.8max 1.8max 1.0max 1.2max 1.4max 2.0max 2.4max 3.0max 4.0max 4.0max 1.25±0.2 1.25±0.2 1.25±0.2 1.25±0.2 1.45±0.2 1.45±0.2 1.9±0.2 1.9±0.2 1.9±0.2 1.9±0.2 1.9±0.2 2.5±0.2 2.5±0.2 2.5±0.2 2.5±0.2 2.5±0.2 2.5±0.2 3.3±0.2 3.3±0.2 3.3±0.2 3.3±0.2 3.3±0.2 3.3±0.2 3.3±0.2 3.3±0.2 0.5±0.2 0.5±0.2 0.5±0.2 0.5±0.2 0.6±0.2 0.6±0.2 0.9±0.2 0.9±0.2 0.9±0.2 0.9±0.2 0.9±0.2 1.1±0.2 1.1±0.2 1.1± .2 1.1±0.2 1.1±0.2 1.1±0.2 1.4±0.2 1.4±0.2 1.4±0.2 1.4±0.2 1.4±0.2 1.2±0.2 1.4±0.2 1.4±0.2 15 Recommended Land Patterns A B E (mm) (mm) (mm) 2.0 1.35 0.65 2.0 1.35 0.65 2.0 1.35 0.65 2.0 1.35 0.65 2.0 1.45 0.7 2.0 1.45 0.7 2.7 2.2 0.8 2.7 2.2 0. 2.7 2.2 0.8 2.7 2.2 0.8 2.7 2.2 0.8 3.7 2.8 1.2 3.7 2.8 1.2 3.7 2.8 1.2 3.7 2.8 1.2 3.7 2.8 1.2 3.7 2.8 1.2 4.0 3.6 1.5 4.0 3.6 1.5 4.0 3.6 1.5 4.0 3.6 1.5 4.0 3.6 1.5 4.0 3.6 1.5 4.0 3.6 1.5 4.0 3.6 1.5 Package Reel Amount(pcs) 7” 7” 7” 7” 7” 7” 7" 7" 7" 7" 7" 13" 13" 13" 13" 13" 13" " 7" 7" 7" 13" 7" 13" 13" 2,500 2,500 2,500 2,500 2,500 2,500 2,000 2,000 2,000 2,000 2,000 5,000 5,000 4,500 4,500 3,500 3,500 1,000 1,000 1,000 800 2,500 500 1,500 1,500 Rev. 201304 Inductors – SPN/SPH (Coating) BOTTOM ries SPN6060□□□□PTA SPN6060□□□□PTC SPH6060□□□□PTC SPN6060□□□□PTD SPN6060□□□□ETH SPH6060□□□□ETH SPN6060□□□□ETK SPH6060□□□□ETK SPN6060□□□□ETP SPH6060□□□□ETP SPN8080□□□□ETL SPN8080□□□□ETN SPH8080□□□□ETN L (mm) W (mm) H (mm) C (mm) D (mm) 6.0±0.2 6.0±0.2 6.0±0.2 6.0±0.2 6.0±0.2 6.0±0.2 6.0±0.2 6.0±0.2 6.0±0.2 6.0±0.2 8.0±0.2 8.0±0.2 8.0±0.2 6.0±0.2 6.0±0.2 6.0±0.2 6.0±0.2 6.0±0.2 6.0±0.2 6.0±0.2 6.0±0.2 6.0±0.2 6.0±0.2 8.0±0.2 8.0±0.2 8.0±0.2 1.0max 1.2max 1.2max 1.4max 2.0max 2.0max 2.8max 2.8max 4.5max 4.5max 3.0max 4.0max 4.0max 4.0±0.2 4.0±0.2 4.0±0.2 4.0±0.2 4.0±0.2 4.0±0.2 4.0±0.2 4.0±0.2 4.0±0.2 4.0±0.2 5.6±0.3 5.6±0.3 5.6±0.3 1.65±0.2 1.65±0.2 1.65±0.2 1.65±0.2 1.65±0.2 1.65±0.2 1.65±0.2 1.65±0.2 1.65±0.2 1.65±0.2 1.6±0.3 1.6±0.3 1.6±0.3 16 Recommended Land Patterns A B E (mm) (mm) (mm) 5.7 4.7 1.6 5.7 4.7 1.6 5.7 4.7 1.6 5.7 4.7 1.6 5.7 4.7 1.6 5.7 4.7 1.6 5.7 4.7 1.6 5.7 4.7 1.6 5.7 4.7 1.6 5.7 4.7 1.6 7.5 5.6 1.8 7.5 5.6 1.8 7.5 5.6 1.8 Package Reel Amount(pcs) 7” 7” 7” 7” 13” 13” 13” 13” 13” 13” 13" 13" 13" 1,000 1,000 1,000 1,000 2,500 2,500 2,000 2,000 1,500 1,500 1,000 1,000 1,000 Rev. 201304 Inductors – SPN/SPH (Coating) ▓Part Numbers & Characteristic (SPH Series for High Current) SPH2020□□□□PSA (Thickness 1.0mm) DARFON P/N Inductance (uH) DC Resistance (mΩ) Tolerance Heat Rating Current DC Amp. Saturation Current DC Amps. Typ. Max. Idc(A) Max. Isat(A) Max. 52 62 2.00 2.10 60 72 1.85 1.85 SPH2020R47NPTA 0.47 SPH2020R68NPTA 0.68 SPH20201R0NPTA 1.0 80 96 1.60 1.55 SPH20201R5MPTA 1.5 100 120 1.45 1.35 SPH20202R2MPTA 2.2 175 210 1.10 1.10 ± 30% Measuring Condition 100KHz,1V ± 20% SPH20203R3MPTA 3.3 250 300 1.00 0.88 SPH20204R7MPTA 4.7 320 384 0.82 0.76 Heat Rating Current DC Amp. Saturation Current DC Amps. SPH2020□□□□PCC (Thickness 1.2mm) DARFON P/N Inductance (uH) DC Resistance (mΩ) Tolerance Typ. Max. Idc(A) Max. Isat(A) Max. SPH2020R47MPCC 0.47 40 46 2.30 4.20 SPH2020R68MPCC 0.68 50 58 2.00 3.50 SPH20201R0MPCC 1.0 56 64 1.90 2.55 SPH20201R5MPCC 1.5 75 86 1.65 2.00 SPH20202R2MPCC 2.2 95 109 1.45 1.75 SPH20203R3MPCC 3.3 155 178 1.15 1.35 SPH20204R7MPCC 4.7 210 242 0.95 1.15 Heat Rating Current DC Amp. Saturation Current DC Amps. ± 20% Measuring Condition 1MHz,1V SPH2020□□□□PTC (Thickness 1.2mm) DARFON P/N SPH20201R0NPTC Inductance (uH) DC Resistance (mΩ) Tolerance 1.0 Measuring Condition Typ. Max. Idc(A) Max. Isat(A) Max. 73 88 1.65 2.20 ± 30% SPH20201R5NPTC 1.5 100 120 1.40 1.80 SPH20202R2MPTC 2.2 129 155 1.20 1.60 SPH20203R3MPTC 3.3 227 272 0.90 1.25 SPH20204R7MPTC 4.7 325 390 0.75 1.10 ± 20% 100KHz,1V ※Isat :DC current(A) that will cause inductance to drop approximately 30% ※Idc: DC current(A) that will cause an approximate ᇞT of 20℃(at 25℃ambient) 17 Rev. 201304 Inductors – SPN/SPH (Coating) SPH2520□□□□PSA (Thickness 1.0mm) DARFON P/N Inductance (uH) DC Resistance (mΩ) Tolerance Heat Rating Current DC Amp. Saturation Current DC Amps. Typ. Max. Idc(A) Typ. Isat(A) Max. 32 38 2.67 3.00 49 59 2.40 2.43 SPH2520R50NPSA 0.50 SPH2520R68NPSA 0.68 SPH25201R0NPSA 1.0 68 82 1.98 2.20 SPH25201R5MPSA 1.5 95 114 1.65 1.58 SPH25202R2MPSA 2.2 136 163 1.40 1.39 SPH25203R3MPSA 3.3 207 248 1.15 1.17 ± 30% Measuring Condition 1MHz,1V ± 20% SPH25204R7MPSA 4.7 269 323 0.99 1.08 SPH25206R8MPSA 6.8 404 485 0.81 0.77 SPH2520100MPSA 10 508 610 0.72 0.65 Saturation Current DC Amps. Isat(A) Max. SPH2520□□□□PSC (Thickness 1.2mm) DARFON P/N Inductance (uH) Typ. Max. Heat Rating Current DC Amp. Idc(A) Typ. 29 35 3.70 3.50 32 38 3.60 3.40 DC Resistance (mΩ) Tolerance SPH2520R47NPSC 0.47 SPH2520R50NPSC 0.50 SPH25201R0NPSC 1.0 43 52 2.60 2.45 SPH25201R5MPSC 1.5 72 86 2.20 2.07 SPH25202R2MPSC 2.2 90 108 1.85 1.95 SPH25203R3MPSC 3.3 155 186 1.45 1.60 SPH25204R7MPSC 4.7 212 254 1.20 1.40 SPH25206R8MPSC 6.8 370 444 1.00 1.04 SPH2520100MPSC 10 750 900 0.75 0.77 SPH2520220MPSC 22 1050 1260 0.50 0.50 ± 30% Measuring Condition 1MHz,1V ± 20% ※Isat :DC current(A) that will cause inductance to drop approximately 30% ※Idc: DC current(A) that will cause an approximate ᇞT of 20℃(at 25℃ambient) (note: SPH2520□□□□PSA SPH2520□□□□PSC specifications are defined an approximately ᇞT of 40℃) 18 Rev. 201304 Inductors – SPN/SPH (Coating) SPH3030□□□□PTA (Thickness 1.0mm) DARFON P/N SPH30301R2NPTA Inductance (uH) DC Resistance (mΩ) Tolerance 1.2 Heat Rating Current DC Amp. Saturation Current DC Amps. Measuring Condition Typ. Max. Idc(A) Max. Isat(A) Max. 65 78 1.48 1.70 ± 30% SPH30301R5NPTA 1.5 75 90 1.37 1.44 SPH30302R2MPTA 2.2 83 100 1.30 1.30 SPH30303R3MPTA 3.3 130 156 1.03 1.00 SPH30304R7MPTA 4.7 170 204 0.90 0.85 SPH30306R8MPTA 6.8 250 300 0.74 0.70 SPH3030100MPTA 10 350 420 0.62 0.60 SPH3030150MPTA 15 550 660 0.48 0.45 SPH3030220MPTA 22 770 924 0.41 0.38 Saturation Current DC Amps. Isat(A) Max. ± 20% 100KHz,1V SPH3030□□□□PTC (Thickness 1.2mm) DARFON P/N Inductance (uH) Typ. Max. Heat Rating Current DC Amp. Idc(A) Max. 33 40 1.90 2.60 48 58 1.71 2.20 DC Resistance (mΩ) Tolerance SPH3030R47NPTC 0.47 SPH30301R0NPTC 1.0 SPH30301R5NPTC 1.5 55 66 1.60 1.70 SPH30302R2MPTC 2.2 75 90 1.37 1.50 SPH30303R3MPTC 3.3 100 120 1.21 1.20 SPH30304R7MPTC 4.7 130 156 1.06 1.00 SPH30306R8MPTC 6.8 190 228 0.89 0.85 SPH3030100MPTC 10 270 324 0.72 0.73 SPH3030150MPTC 15 450 540 0.57 0.53 SPH3030220MPTC 22 630 756 0.50 0.50 ± 30% Measuring Condition 100KHz,1V ± 20% ※Isat :DC current(A) that will cause inductance to drop approximately 30% ※Idc: DC current(A) that will cause an approximate ᇞT of 20℃(at 25℃ambient) 19 Rev. 201304 Inductors – SPN/SPH (Coating) SPH4040□□□□ETA (Thickness 1.0mm) DARFON P/N Inductance (uH) DC Resistance (mΩ) Tolerance ± 30% Heat Rating Current DC Amp. Saturation Current DC Amps. Measuring Condition Typ. Max. Idc(A) Max. Isat(A) Max. 56 67 1.90 2.00 SPH40401R0NETA 1.0 SPH40402R2META 2.2 85 102 1.50 1.20 SPH40403R3META 3.3 100 120 1.40 1.10 SPH40404R7META 4.7 140 168 1.20 0.95 SPH40406R8META 6.8 200 240 1.00 0.80 SPH4040100META 10 300 360 0.75 0.62 SPH4040150META 15 430 516 0.60 0.54 SPH4040220META 22 570 684 0.50 0.45 Heat Rating Current DC Amp. Saturation Current DC Amps. 100KHz,1V ± 20% SPH4040□□□□ETC (Thickness 1.2mm) DARFON P/N Inductance (uH) DC Resistance (mΩ) Tolerance ± 30% Measuring Condition Typ. Max. Idc(A) Max. Isat(A) Max. 42 50 2.200 2.800 SPH40401R0NETC 1.0 SPH40402R2METC 2.2 60 72 1.900 1.650 SPH40403R3METC 3.3 70 84 1.700 1.400 SPH40404R7METC 4.7 95 114 1.500 1.200 SPH40406R8METC 6.8 125 150 1.300 0.900 SPH4040100METC 10 170 204 1.100 0.800 SPH4040150METC 15 260 312 0.750 0.650 SPH4040220METC 22 400 480 0.620 0.500 Heat Rating Current DC Amp. Saturation Current DC Amps. 100KHz,1V ± 20% SPH4040□□□□ETG (Thickness 1.8mm) DARFON P/N SPH40401R0NETG Inductance (uH) DC Resistance (mΩ) Tolerance 1.0 Measuring Condition Typ. Max. Idc(A) Max. Isat(A) Max. 27 32 3.20 4.00 ± 30% SPH40401R5NESG 1.5 40 48 2.64 3.30 SPH40402R2METG 2.2 42 50 2.20 3.00 SPH40403R3METG 3.3 55 66 2.00 2.30 SPH40404R7METG 4.7 70 84 1.70 2.00 SPH40406R8METG 6.8 98 118 1.45 1.60 SPH4040100METG 10 150 180 1.20 1.30 SPH4040150METG 15 210 252 0.85 1.10 SPH4040220METG 22 290 348 0.72 0.90 SPH4040330METG 33 460 552 0.55 0.70 100KHz,1V ± 20% ※Isat :DC current(A) that will cause inductance to drop approximately 30% ※Idc: DC current(A) that will cause an approximate ᇞT of 20℃(at 25℃ambient) 20 Rev. 201304 Inductors – SPN/SPH (Coating) SPH5050□□□□PTH (Thickness 2.0mm) DARFON P/N Inductance (uH) DC Resistance (mΩ) Tolerance Heat Rating Current DC Amp. Saturation Current DC Amps. Measuring Condition Typ. Max. Idc(A) Max. Isat(A) Max. SPH50501R0NPTH 0.47 12 14 5.00 6.10 SPH50501R0NPTH 1.0 21 25 3.60 4.00 SPH50501R5NPTH 1.5 26 31 3.20 3.35 SPH50502R2NPTH 2.2 35 42 2.90 2.90 SPH50503R3NPTH 3.3 48 58 2.40 2.40 SPH50504R7MPTH 4.7 60 72 2.00 2.00 SPH50506R8MPTH 6.8 90 108 1.65 1.60 SPH5050100MPTH 10 120 144 1.45 1.30 SPH5050150MPTH 15 165 198 1.20 1.10 SPH5050220MPTH 22 260 312 1.00 0.90 Saturation Current DC Amps. Isat(A) Max. ± 30% 100KHz,1V ± 20% SPH5050□□□□ETN (Thickness 4.0mm) DARFON P/N Inductance (uH) SPH50501R5NETN 1.5 SPH50502R2NETN 2.2 Typ. Max. Heat Rating Current DC Amp. Idc(A) Max. 17 22 4.50 6.40 22 29 3.70 5.00 DC Resistance (mΩ) Tolerance Measuring Condition ± 30% SPH50503R3NETN 3.3 27 35 3.30 4.00 SPH50504R7NETN 4.7 29 38 3.10 3.30 SPH50506R8METN 6.8 49 64 2.40 2.80 SPH5050100METN 10 56 73 2.10 2.30 SPH5050150METN 15 80 104 1.80 2.00 100KHz,1V ± 20% SPH5050220METN 22 126 164 1.40 1.50 SPH5050330METN 33 180 234 1.20 1.30 SPH5050470METN 47 310 403 0.90 1.10 ※Isat :DC current(A) that will cause inductance to drop approximately 30% ※Idc: DC current(A) that will cause an approximate ᇞT of 20℃(at 25℃ambient) 21 Rev. 201304 Inductors – SPN/SPH (Coating) SPH6060□□□□PTC (Thickness 1.2mm) DARFON P/N Inductance (uH) SPH60601R0NPTC 1.0 SPH60601R5NPTC 1.5 DC Resistance (mΩ) Tolerance Heat Rating Current DC Amp. Saturation Current DC Amps. Measuring Condition Typ. Max. Idc(A) Max. Isat(A) Max. 50 60 2.40 3.00 67 80 2.10 2.60 ± 30% SPH60602R5NPTC 2.5 90 108 1.80 2.10 SPH60603R3NPTC 3.3 105 126 1.70 1.80 SPH60604R7MPTC 4.7 125 150 1.55 1.60 SPH60605R3MPTC 5.3 125 150 1.55 1.50 SPH60606R8MPTC 6.8 165 198 1.35 1.30 SPH6060100MPTC 10 200 240 1.20 1.00 SPH6060150MPTC 15 295 354 0.80 0.80 100KHz,1V ± 20% SPH6060220MPTC 22 465 558 0.65 0.76 SPH6060330MPTC 33 580 696 0.55 0.59 SPH6060470MPTC 47 965 1158 0.46 0.52 SPH6060680MPTC 68 1160 1392 0.41 0.44 SPH6060101MPTC 100 1670 2004 0.32 0.35 Heat Rating Current DC Amp. Saturation Current DC Amps. SPH6060□□□□ETH (Thickness 2.0mm) DARFON P/N Inductance (uH) DC Resistance (mΩ) Tolerance Measuring Condition Typ. Max. Idc(A) Max. Isat(A) Max. SPH60600R8NETH 0.8 20 24 4.10 6.40 SPH60601R5NETH 1.5 26 31 3.60 4.30 SPH60602R2NETH 2.2 34 41 2.90 3.20 ± 30% SPH60603R3NETH 3.3 40 48 2.75 2.80 SPH60604R7NETH 4.7 58 70 2.15 2.40 SPH60606R8NETH 6.8 85 102 1.80 2.00 SPH6060100METH 10 125 150 1.50 1.90 290 348 0.95 1.25 100KHz,1V ± 20% SPH6060220METH 22 ※Isat :DC current(A) that will cause inductance to drop approximately 30% ※Idc: DC current(A) that will cause an approximate ᇞT of 20℃(at 25℃ambient) 22 Rev. 201304 Inductors – SPN/SPH (Coating) SPH6060□□□□ETK (Thickness 2.8mm) DARFON P/N Inductance (uH) SPH60600R9NETK 0.9 SPH60601R5NETK 1.5 DC Resistance (mΩ) Tolerance Heat Rating Current DC Amp. Saturation Current DC Amps. Measuring Condition Typ. Max. Idc(A) Max. Isat(A) Max. 13 17 4.60 6.70 16 21 4.20 5.10 ± 30% SPH60602R2NETK 2.2 20 26 3.70 4.20 SPH60603R0NETK 3.0 23 30 3.40 3.60 SPH60604R7METK 4.7 31 40 3.00 2.70 SPH60606R0METK 6.0 40 52 2.50 2.50 SPH6060100METK 10 65 85 1.90 1.90 SPH6060150METK 15 95 124 1.80 1.60 SPH6060220METK 22 135 176 1.40 1.30 SPH6060330METK 33 220 286 1.10 1.10 SPH6060470METK 47 300 390 0.92 1.00 SPH6060680METK 68 420 546 0.77 0.80 SPH6060101METK 100 600 780 0.66 0.65 Saturation Current DC Amps. Isat(A) Max. ± 20% 100KHz,1V SPH6060□□□□ETP (Thickness 4.5mm) DARFON P/N Inductance (uH) Typ. Max. Heat Rating Current DC Amp. Idc(A) Max. DC Resistance (mΩ) Tolerance SPH60601R0NETP 1.0 14 18 4.50 9.80 SPH60601R3NETP 1.3 16 21 4.20 8.20 SPH60601R8NETP 1.8 19 25 3.90 7.20 SPH60602R3NETP 2.3 22 29 3.60 6.40 SPH60603R0NETP 3.0 24 31 3.30 5.60 SPH60604R5METP 4.5 30 39 3.10 4.40 SPH60606R3METP 6.3 36 47 3.00 3.60 SPH6060100METP 10 46 60 2.40 3.10 SPH6060150METP 15 70 91 1.90 2.50 SPH6060220METP 22 107 139 1.60 2.00 SPH6060330METP 33 141 183 1.40 1.65 SPH6060470METP 47 211 274 1.15 1.40 SPH6060680METP 68 304 395 0.95 1.10 SPH6060101METP 100 466 606 0.75 0.90 ± 30% Measuring Condition 100KHz,1V ± 20% ※Isat :DC current(A) that will cause inductance to drop approximately 30% ※Idc: DC current(A) that will cause an approximate ᇞT of 20℃(at 25℃ambient) 23 Rev. 201304 Inductors – SPN/SPH (Coating) SPH8080□□□□ETN (Thickness 4.0mm) DARFON P/N Inductance (uH) DC Resistance (mΩ) Tolerance Heat Rating Current DC Amp. Saturation Current DC Amps. Measuring Condition Typ. Max. Idc(A) Max. Isat(A) Max. SPH80800R9NETN 0.9 6 8 7.80 13.00 SPH80801R4NETN 1.4 7 9 7.00 10.00 SPH80802R0NETN 2.0 9 12 6.30 8.10 ± 30% SPH80803R6NETN 3.6 15 20 4.90 6.40 SPH80804R7NETN 4.7 18 23 4.10 5.40 SPH80806R8NETN 6.8 25 33 3.70 4.40 SPH8080100METN 10 34 44 3.10 3.80 SPH8080150METN 15 50 65 2.40 2.90 SPH8080220METN 22 66 86 2.20 2.40 ± 20% 100KHz,1V ※Isat :DC current(A) that will cause inductance to drop approximately 30% ※Idc: DC current(A) that will cause an approximate ᇞT of 20℃(at 25℃ambient) 24 Rev. 201304 Inductors – SPN/SPH (Coating) ▓Part Numbers & Characteristic (SPN Series) SPN2016□□□□PSA (Thickness 1.0mm) DARFON P/N Inductance (uH) DC Resistance (mΩ) Tolerance Heat Rating Current DC Amp. Saturation Current DC Amps. Measuring Condition Typ. Max. Idc(A) Typ. Isat(A) Max. SPN2016R47NPSA 0.47 49 59 2.60 2.56 SPN2016R68NPSA 0.68 71 86 2.25 2.2 SPN20161R0NPSA 1.0 96 115 1.60 1.69 SPN20161R5NPSA 1.5 143 172 1.40 1.46 SPN20161R8NPSA 1.8 175 210 1.35 1.35 SPN20162R2MPSA 2.2 196 235 1.30 1.26 SPN20163R3MPSA 3.3 247 296 1.05 0.90 SPN20164R7MPSA 4.7 370 444 0.90 0.76 SPN20166R8MPSA 6.8 664 797 0.60 0.72 SPN2016100MPSA 10 1108 1330 0.45 0.55 Saturation Current DC Amps. Isat(A) Max. ± 30% 1MHz,1V ± 20% SPN2020□□□□PTC (Thickness 1.2mm) DARFON P/N SPN20201R0NPTC Inductance (uH) Typ. Max. Heat Rating Current DC Amp. Idc(A) Max. 70 84 1.70 1.90 DC Resistance (mΩ) Tolerance 1.0 Measuring Condition ± 30% SPN20201R5NPTC 1.5 90 108 1.50 1.65 SPN20202R2MPTC 2.2 107 128 1.37 1.35 SPN20203R3MPTC 3.3 190 228 1.02 1.00 SPN20204R7MPTC 4.7 241 289 0.91 0.90 Saturation Current DC Amps. Isat(A) Max. ± 20% 100KHz,1V SPN2424□□□□PTA (Thickness 1.0mm) DARFON P/N SPN2424R68NPTA Inductance (uH) Typ. Max. Heat Rating Current DC Amp. Idc(A) Max. 60 72 1.57 2.20 DC Resistance (mΩ) Tolerance 0.68 Measuring Condition ± 30% SPN24241R0NPTA 1.0 70 84 1.41 1.80 SPN24241R5MPTA 1.5 110 132 1.16 1.55 SPN24242R2MPTA 2.2 150 180 0.97 1.29 SPN24243R3MPTA 3.3 220 264 0.77 1.00 SPN24244R7MPTA 4.7 290 348 0.67 0.88 SPN24246R8MPTA 6.8 410 492 0.57 0.75 SPN2424100MPTA 10 690 828 0.45 0.55 SPN2424150MPTA 15 1020 1224 0.37 0.47 SPN2424220MPTA 22 1470 1764 0.30 0.39 100KHz,1V ± 20% ※Isat :DC current(A) that will cause inductance to drop approximately 30% ※Idc: DC current(A) that will cause an approximate ᇞT of 20℃(at 25℃ambient) (note: SPN2016□□□□PSA specifications is defined an approximately ᇞT of 40℃) 25 Rev. 201304 Inductors – SPN/SPH (Coating) SPN2424□□□□PTC (Thickness 1.2mm) DARFON P/N Inductance (uH) DC Resistance (mΩ) Tolerance Heat Rating Current DC Amp. Saturation Current DC Amps. Typ. Max. Idc(A) Max. Isat(A) Max. 50 60 2.10 2.90 77 92 1.30 2.35 SPN2424R47NPTC 0.47 SPN24241R0NPTC 1.0 SPN24241R5NPTC 1.5 100 120 1.15 2.10 SPN24242R2MPTC 2.2 140 168 1.00 1.70 SPN24243R3MPTC 3.3 225 270 0.75 1.40 SPN24244R7MPTC 4.7 300 360 0.65 1.15 SPN24246R8MPTC 6.8 420 504 0.55 0.95 SPN2424100MPTC 10 600 720 0.45 0.81 Heat Rating Current DC Amp. Saturation Current DC Amps. ± 30% Measuring Condition 100KHz,1V ± 20% SPN2520□□□□PSA (Thickness 1.0mm) DARFON P/N Inductance (uH) DC Resistance (mΩ) Tolerance Typ. Max. Idc(A) Typ. Isat(A) Max. 38 46 2.65 2.50 52 62 2.20 2.05 SPN2520R47NPSA 0.47 SPN2520R68NPSA 0.68 SPN25201R0NPSA 1.0 70 84 1.90 1.75 SPN25201R5MPSA 1.5 107 128 1.50 1.45 SPN25202R2MPSA 2.2 158 190 1.20 1.20 SPN25203R3MPSA 3.3 229 275 1.00 0.94 ± 30% Measuring Condition 1MHz,1V ± 20% SPN25204R7MPSA 4.7 332 398 0.82 0.80 SPN25206R8MPSA 6.8 443 532 0.71 0.68 SPN2520100MPSA 10 712 854 0.55 0.56 ※Isat :DC current(A) that will cause inductance to drop approximately 30% ※Idc: DC current(A) that will cause an approximate ᇞT of 20℃(at 25℃ambient) (note: SPN2520□□□□PSA specifications are defined an approximately ᇞT of 40℃) 26 Rev. 201304 Inductors – SPN/SPH (Coating) SPN2520□□□□PSC (Thickness 1.2mm) DARFON P/N SPN2520R47NPSC Inductance (uH) DC Resistance (mΩ) Tolerance 0.47 Heat Rating Current DC Amp. Saturation Current DC Amps. Measuring Condition Typ. Max. Idc(A) Typ. Isat(A) Max. 47 56 2.40 2.75 ± 30% SPN25201R0NPSC 1.0 73 88 2.15 2.20 SPN25201R5MPSC 1.5 105 126 1.65 1.80 SPN25202R2MPSC 2.2 129 155 1.55 1.55 SPN25203R3MPSC 3.3 227 272 1.15 1.25 SPN25204R7MPSC 4.7 338 406 1.08 1.05 SPN25206R8MPSC 6.8 510 612 0.78 0.85 SPN2520100MPSC 10 630 756 0.72 0.73 Heat Rating Current DC Amp. Saturation Current DC Amps. 1MHz,1V ± 20% SPN3030□□□□PTA (Thickness 1.0mm) DARFON P/N SPN30301R0NPTA Inductance (uH) DC Resistance (mΩ) Tolerance 1.0 Measuring Condition Typ. Max. Idc(A) Max. Isat(A) Max. 65 78 1.40 1.30 ± 30% SPN30301R5NPTA 1.5 80 96 1.30 1.20 SPN30302R2MPTA 2.2 95 114 1.10 1.10 SPN30303R3MPTA 3.3 140 168 0.94 0.87 SPN30304R7MPTA 4.7 190 228 0.78 0.75 SPN30306R8MPTA 6.8 300 360 0.63 0.61 SPN3030100MPTA 10 450 540 0.51 0.50 SPN3030150MPTA 15 740 888 0.40 0.40 SPN3030220MPTA 22 1030 1236 0.35 0.35 SPN3030330MPTA 33 1550 1860 0.28 0.26 SPN3030470MPTA 47 2050 2460 0.24 0.22 ± 20% 100KHz,1V ※Isat :DC current(A) that will cause inductance to drop approximately 30% ※Idc: DC current(A) that will cause an approximate ᇞT of 20℃(at 25℃ambient) (note: SPN2520□□□□PSC specifications are defined an approximately ᇞT of 40℃) 27 Rev. 201304 Inductors – SPN/SPH (Coating) SPN3030□□□□PTE (Thickness 1.5mm) DARFON P/N SPN30301R0NPTE Inductance (uH) DC Resistance (mΩ) Tolerance 1.0 Heat Rating Current DC Amp. Saturation Current DC Amps. Measuring Condition Typ. Max. Idc(A) Max. Isat(A) Max. 30 36 2.10 2.10 ± 30% SPN30301R5NPTE 1.5 40 48 1.82 1.80 SPN30302R2MPTE 2.2 60 72 1.50 1.48 SPN30303R3MPTE 3.3 80 96 1.23 1.21 SPN30304R7MPTE 4.7 120 144 1.04 1.02 SPN30306R8MPTE 6.8 160 192 0.88 0.87 SPN3030100MPTE 10 230 276 0.71 0.70 SPN3030150MPTE 15 360 432 0.56 0.56 SPN3030220MPTE 22 520 624 0.47 0.47 SPN3030330MPTE 33 840 1008 0.37 0.39 SPN3030470MPTE 47 1340 1608 0.30 0.32 Heat Rating Current DC Amp. Saturation Current DC Amps. ± 20% 100KHz,1V SPN4040□□□□ETA (Thickness 1.0mm) DARFON P/N SPN40401R0NETA Inductance (uH) DC Resistance (mΩ) Tolerance 1.0 Measuring Condition Typ. Max. Idc(A) Max. Isat(A) Max. 100 120 1.05 1.80 ± 30% SPN40402R2NETA 2.2 150 180 0.89 1.15 SPN40403R3META 3.3 180 216 0.82 1.10 SPN40404R7META 4.7 210 252 0.75 0.90 SPN40406R8META 6.8 300 360 0.62 0.74 SPN4040100META 10 380 456 0.60 0.56 SPN4040150META 15 510 612 0.51 0.47 SPN4040220META 22 870 1044 0.40 0.36 SPN4040330META 33 1540 1848 0.30 0.28 SPN4040470META 47 1810 2172 0.28 0.24 100KHz,1V ± 20% ※Isat :DC current(A) that will cause inductance to drop approximately 30% ※Idc: DC current(A) that will cause an approximate ᇞT of 20℃(at 25℃ambient) 28 Rev. 201304 Inductors – SPN/SPH (Coating) SPN4040□□□□ETC (Thickness 1.2mm) DARFON P/N Inductance (uH) DC Resistance (mΩ) Tolerance ± 30% Heat Rating Current DC Amp. Saturation Current DC Amps. Measuring Condition Typ. Max. Idc(A) Max. Isat(A) Max. 60 72 1.50 2.50 SPN40401R0NETC 1.0 SPN40402R2METC 2.2 90 108 1.20 1.65 SPN40403R3METC 3.3 130 156 0.98 1.20 SPN40404R7METC 4.7 140 168 0.96 1.05 SPN40406R8METC 6.8 180 216 0.84 0.90 SPN4040100METC 10 240 288 0.77 0.74 SPN4040150METC 15 400 480 0.60 0.56 SPN4040220METC 22 480 576 0.54 0.51 SPN4040330METC 33 810 972 0.42 0.40 SPN4040470METC 47 1000 1200 0.37 0.35 Saturation Current DC Amps. Isat(A) Max. 100KHz,1V ± 20% SPN4040□□□□ETG (Thickness 1.8mm) DARFON P/N Inductance (uH) Typ. Max. Heat Rating Current DC Amp. Idc(A) Max. 30 36 1.83 4.00 DC Resistance (mΩ) Tolerance SPN40401R0NETG 1.0 ± 30% SPN40402R2METG 2.2 60 72 1.44 2.70 SPN40403R3METG 3.3 70 84 1.23 2.00 SPN40404R7METG 4.7 90 108 1.20 1.70 SPN40406R8METG 6.8 110 132 1.06 1.45 SPN4040100METG 10 180 216 0.84 1.20 SPN4040150METG 15 250 300 0.65 0.94 SPN4040220METG 22 360 432 0.59 0.80 SPN4040330METG 33 530 636 0.49 0.65 SPN4040470METG 47 650 780 0.42 0.57 SPN4040680METG 68 1000 1200 0.32 0.47 SPN4040101METG 100 1500 1800 0.27 0.40 SPN4040151METG 150 2500 3000 0.22 0.31 SPN4040221METG 220 4000 4800 0.17 0.27 Measuring Condition 100KHz,1V ± 20% ※Isat :DC current(A) that will cause inductance to drop approximately 30% ※Idc: DC current(A) that will cause an approximate ᇞT of 20℃(at 25℃ambient) 29 Rev. 201304 Inductors – SPN/SPH (Coating) SPN5050□□□□PTA (Thickness 1.0mm) DARFON P/N SPN50501R0NPTA Inductance (uH) DC Resistance (mΩ) Tolerance 1.0 Heat Rating Current DC Amp. Saturation Current DC Amps. Measuring Condition Typ. Max. Idc(A) Max. Isat(A) Max. 70 84 1.75 2.35 ± 30% SPN50502R2NPTA 2.2 105 126 1.40 1.50 SPN50503R3MPTA 3.3 125 150 1.25 1.40 SPN50504R7MPTA 4.7 145 174 1.15 1.20 SPN50506R8MPTA 6.8 185 222 1.00 1.00 SPN5050100MPTA 10 250 300 0.90 0.85 SPN5050150MPTA 15 400 480 0.65 0.68 SPN5050220MPTA 22 600 720 0.45 0.55 Heat Rating Current DC Amp. Saturation Current DC Amps. 100KHz,1V ± 20% SPN5050□□□□PTC (Thickness 1.2mm) DARFON P/N SPN50501R0NPTC Inductance (uH) DC Resistance (mΩ) Tolerance 1.0 Measuring Condition Typ. Max. Idc(A) Max. Isat(A) Max. 53 64 2.30 4.50 ± 30% SPN50501R5NPTC 1.5 70 84 2.20 3.80 SPN50502R2MPTC 2.2 85 102 2.00 3.10 SPN50503R3MPTC 3.3 160 192 1.45 2.40 SPN50504R7MPTC 4.7 180 216 1.40 2.20 SPN50506R8MPTC 6.8 260 312 1.10 1.70 SPN5050100MPTC 10 420 504 0.85 1.40 SPN5050150MPTC 15 670 804 0.64 1.20 Heat Rating Current DC Amp. Saturation Current DC Amps. 100KHz,1V ± 20% SPN5050□□□□PTD (Thickness 1.4mm) DARFON P/N Inductance (uH) DC Resistance (mΩ) Tolerance Typ. Max. Idc(A) Max. Isat(A) Max. SPN5050R47NPTD 0.47 25 30 3.30 5.80 SPN50501R2NPTD 1.2 45 54 2.40 3.80 SPN50502R2NPTD 2.2 65 78 2.00 2.80 SPN50503R3NPTD 3.3 80 96 1.70 2.35 SPN50504R7NPTD 4.7 100 120 1.40 2.05 SPN50506R8MPTD 6.8 150 180 1.20 1.60 SPN5050100MPTD 10 200 240 1.05 1.40 ± 30% Measuring Condition 100KHz,1V ± 20% SPN5050150MPTD 15 320 384 0.65 1.10 SPN5050220MPTD 22 450 540 0.55 0.90 ※Isat :DC current(A) that will cause inductance to drop approximately 30% ※Idc: DC current(A) that will cause an approximate ᇞT of 20℃(at 25℃ambient) 30 Rev. 201304 Inductors – SPN/SPH (Coating) SPN5050□□□□ETI (Thickness 2.4mm) DARFON P/N Inductance (uH) SPN50501R0NETI 1.0 SPN50501R5NETI 1.5 DC Resistance (mΩ) Tolerance Heat Rating Current DC Amp. Saturation Current DC Amps. Measuring Condition Typ. Max. Idc(A) Max. Isat(A) Max. 16 19 4.40 5.80 22 26 3.60 5.20 ± 30% SPN50502R2NETI 2.2 29 35 3.10 4.10 SPN50503R3NETI 3.3 43 52 2.40 3.10 SPN50504R7METI 4.7 55 66 2.00 2.70 SPN50506R8METI 6.8 80 96 1.60 2.20 SPN5050100METI 10 125 150 1.20 1.70 100KHz,1V ± 20% SPN5050150METI 15 170 204 1.00 1.40 SPN5050220METI 22 230 276 0.82 1.20 SPN5050330METI 33 370 444 0.63 1.00 Saturation Current DC Amps. Isat(A) Max. SPN5050□□□□ETL (Thickness 3.0mm) DARFON P/N Inductance (uH) Typ. Max. Heat Rating Current DC Amp. Idc(A) Max. 10 13 5.00 9.00 15 20 4.00 6.60 DC Resistance (mΩ) Tolerance SPN5050R47NETL 0.47 SPN50501R0NETL 1.0 SPN50502R2NETL 2.2 23 30 3.50 4.20 SPN50503R3METL 3.3 30 39 3.00 3.60 SPN50504R7METL 4.7 35 46 2.60 3.10 SPN50506R8METL 6.8 52 68 2.30 2.50 SPN5050100METL 10 70 91 1.70 2.10 ± 30% Measuring Condition 100KHz,1V ± 20% SPN5050150METL 15 125 163 1.40 1.60 SPN5050220METL 22 180 234 1.05 1.40 SPN5050330METL 33 225 293 0.80 1.15 SPN5050470METL 47 325 423 0.70 0.95 ※Isat :DC current(A) that will cause inductance to drop approximately 30% ※Idc: DC current(A) that will cause an approximate ᇞT of 20℃(at 25℃ambient) 31 Rev. 201304 Inductors – SPN/SPH (Coating) SPN5050□□□□ETN (Thickness 4.0mm) DARFON P/N Inductance (uH) SPN50501R5NETN 1.5 SPN50502R2NETN 2.2 DC Resistance (mΩ) Tolerance Heat Rating Current DC Amp. Saturation Current DC Amps. Measuring Condition Typ. Max. Idc(A) Max. Isat(A) Max. 20 26 3.60 6.00 22 29 3.50 4.60 ± 30% SPN50503R3NETN 3.3 27 35 3.30 3.80 SPN50504R7NETN 4.7 29 38 3.10 3.30 SPN50506R8METN 6.8 49 64 2.30 2.60 SPN5050100METN 10 56 73 2.10 2.30 SPN5050150METN 15 80 104 1.80 2.00 100KHz,1V ± 20% SPN5050220METN 22 126 164 1.40 1.60 SPN5050330METN 33 180 234 1.20 1.30 SPN5050470METN 47 310 403 0.90 1.10 Saturation Current DC Amps. Isat(A) Max. SPN6060□□□□PTA (Thickness 1.0mm) DARFON P/N Inductance (uH) Typ. Max. Heat Rating Current DC Amp. Idc(A) Max. DC Resistance (mΩ) Tolerance SPN60601R5MPTA 1.5 90 108 1.90 2.40 SPN60602R2MPTA 2.2 110 132 1.70 1.90 SPN60603R3MPTA 3.3 135 162 1.50 1.60 SPN60604R7MPTA 4.7 165 198 1.40 1.40 SPN60606R8MPTA 6.8 220 264 1.00 1.20 SPN6060100MPTA 10 270 324 0.85 1.00 SPN6060220MPTA 22 580 696 0.70 0.65 ± 20% Measuring Condition 100KHz,1V ※Isat :DC current(A) that will cause inductance to drop approximately 30% ※Idc: DC current(A) that will cause an approximate ᇞT of 20℃(at 25℃ambient) 32 Rev. 201304 Inductors – SPN/SPH (Coating) SPN6060□□□□PTC (Thickness 1.2mm) DARFON P/N SPN60602R5NPTC Inductance (uH) DC Resistance (mΩ) Tolerance 2.5 Heat Rating Current DC Amp. Saturation Current DC Amps. Measuring Condition Typ. Max. Idc(A) Max. Isat(A) Max. 90 108 1.73 2.10 ± 30% SPN60604R0NPTC 4.0 105 126 1.57 1.80 SPN60605R3MPTC 5.3 125 150 1.40 1.50 SPN60606R8MPTC 6.8 165 198 1.18 1.30 SPN6060100MPTC 10 235 282 1.00 1.00 SPN6060150MPTC 15 330 396 0.79 0.80 SPN6060220MPTC 22 530 636 0.63 0.76 SPN6060330MPTC 33 700 840 0.53 0.59 SPN6060470MPTC 47 1050 1260 0.46 0.52 SPN6060680MPTC 68 1350 1620 0.41 0.44 SPN6060101MPTC 100 2180 2616 0.32 0.35 Heat Rating Current DC Amp. Saturation Current DC Amps. ± 20% 100KHz,1V SPN6060□□□□PTD (Thickness 1.4mm) DARFON P/N Inductance (uH) DC Resistance (mΩ) Tolerance Typ. Max. Idc(A) Max. Isat(A) Max. 42 50 2.75 4.00 55 66 2.30 3.00 SPN60601R2NPTD 1.2 SPN60602R2NPTD 2.2 SPN60603R3NPTD 3.3 75 90 2.00 2.50 SPN60604R7MPTD 4.7 090 108 1.90 2.00 SPN60606R8MPTD 6.8 115 138 1.65 1.70 SPN6060100MPTD 10 140 168 1.40 1.40 SPN6060150MPTD 15 210 252 1.20 1.15 SPN6060220MPTD 22 300 360 1.00 0.95 ± 30% Measuring Condition 100KHz,1V ± 20% ※Isat :DC current(A) that will cause inductance to drop approximately 30% ※Idc: DC current(A) that will cause an approximate ᇞT of 20℃(at 25℃ambient) 33 Rev. 201304 Inductors – SPN/SPH (Coating) SPN6060□□□□ETH (Thickness 2.0mm) DARFON P/N Inductance (uH) DC Resistance (mΩ) Tolerance Heat Rating Current DC Amp. Saturation Current DC Amps. Measuring Condition Typ. Max. Idc(A) Max. Isat(A) Max. SPN60600R8NETH 0.8 20 24 3.80 5.50 SPN60601R5NETH 1.5 26 31 3.20 4.00 SPN60602R2NETH 2.2 34 41 2.70 3.20 ± 30% SPN60603R3NETH 3.3 40 48 2.60 2.80 SPN60604R7NETH 4.7 58 70 2.00 2.40 SPN60606R8NETH 6.8 85 102 1.80 2.00 SPN6060100METH 10 125 150 1.40 1.70 290 348 0.95 1.05 Heat Rating Current DC Amp. Saturation Current DC Amps. 100KHz,1V ± 20% SPN6060220METH 22 SPN6060□□□□ETK (Thickness 2.8mm) DARFON P/N Inductance (uH) SPN60600R9NETK 0.9 SPN60601R5NETK 1.5 DC Resistance (mΩ) Tolerance Measuring Condition Typ. Max. Idc(A) Max. Isat(A) Max. 13 17 4.60 6.60 16 21 4.20 5.00 ± 30% SPN60602R2NETK 2.2 20 26 3.70 4.20 SPN60603R0NETK 3.0 23 30 3.40 3.60 SPN60604R7METK 4.7 31 40 3.00 2.70 SPN60606R0METK 6.0 40 52 2.50 2.50 SPN6060100METK 10 65 85 1.90 1.90 SPN6060150METK 15 95 124 1.80 1.60 SPN6060220METK 22 135 176 1.40 1.30 SPN6060330METK 33 220 286 1.10 1.10 SPN6060470METK 47 300 390 0.92 0.95 SPN6060680METK 68 420 546 0.77 0.76 SPN6060101METK 100 600 780 0.66 0.62 ± 20% 100KHz,1V ※Isat :DC current(A) that will cause inductance to drop approximately 30% ※Idc: DC current(A) that will cause an approximate ᇞT of 20℃(at 25℃ambient) 34 Rev. 201304 Inductors – SPN/SPH (Coating) SPN6060□□□□ETP (Thickness 4.5mm) DARFON P/N Inductance (uH) DC Resistance (mΩ) Tolerance Heat Rating Current DC Amp. Saturation Current DC Amps. Typ. Max. Idc(A) Max. Isat(A) Max. SPN60601R0NETP 1.0 14 18 4.20 8.50 SPN60601R3NETP 1.3 16 21 4.00 8.00 SPN60601R8NETP 1.8 18 23 3.70 7.00 SPN60602R3NETP 2.3 21 27 3.50 6.00 SPN60603R0NETP 3.0 24 31 3.20 5.00 SPN60604R5METP 4.5 31 40 3.00 4.00 SPN60606R3METP 6.3 38 49 2.80 3.80 SPN6060100METP 10 47 61 2.50 3.00 SPN6060150METP 15 77 100 1.90 2.30 SPN6060220METP 22 115 150 1.50 1.90 SPN6060330METP 33 145 189 1.40 1.50 SPN6060470METP 47 220 286 1.10 1.30 SPN6060680METP 68 330 429 0.90 1.00 SPN6060101METP 100 500 650 0.70 0.80 Heat Rating Current DC Amp. Saturation Current DC Amps. ± 30% Measuring Condition 100KHz,1V ± 20% SPN8080□□□□ETL (Thickness 3.0mm) DARFON P/N Inductance (uH) DC Resistance (mΩ) Tolerance Typ. Max. Idc(A) Max. Isat(A) Max. 9 12 6.20 7.80 12 16 5.30 6.20 SPN80801R0NETL 1.0 SPN80801R5NETL 1.5 SPN80802R2NETL 2.2 15 20 4.80 4.90 SPN80803R3METL 3.3 19 25 4.30 4.20 SPN80804R7METL 4.7 22 29 4.00 3.60 SPN80806R8METL 6.8 29 38 3.40 3.00 SPN8080100METL 10 33 43 3.00 2.40 ± 30% Measuring Condition 100KHz,1V ± 20% SPN8080150METL 15 60 78 2.20 2.00 SPN8080220METL 22 70 91 1.90 1.75 SPN8080330METL 33 120 156 1.50 1.30 SPN8080470METL 47 170 221 1.30 1.10 ※Isat :DC current(A) that will cause inductance to drop approximately 30% ※Idc: DC current(A) that will cause an approximate ᇞT of 20℃(at 25℃ambient) 35 Rev. 201304 Inductors – SPN/SPH (Coating) SPN8080□□□□ETN (Thickness 4.0mm) DARFON P/N Inductance (uH) DC Resistance (mΩ) Tolerance Heat Rating Current DC Amp. Saturation Current DC Amps. Measuring Condition Typ. Max. Idc(A) Max. Isat(A) Max. SPN80800R9NETN 0.9 6 8 7.80 11.00 SPN80801R4NETN 1.4 7 9 7.00 9.00 SPN80802R0NETN 2.0 9 12 6.30 7.40 ± 30% SPN80803R6NETN 3.6 15 20 4.90 5.30 SPN80804R7NETN 4.7 18 23 4.10 4.70 SPN80806R8NETN 6.8 25 33 3.70 4.00 SPN8080100METN 10 34 44 3.10 3.40 SPN8080150METN 15 50 65 2.40 2.70 SPN8080220METN 22 66 86 2.20 2.20 SPN8080330METN 33 100 130 1.70 1.90 SPN8080470METN 47 150 195 1.40 1.50 SPN8080680METN 68 230 299 1.10 1.20 SPN8080101METN 100 290 377 1.00 1.00 ± 20% 100KHz,1V ※Isat :DC current(A) that will cause inductance to drop approximately 30% ※Idc: DC current(A) that will cause an approximate ᇞT of 20℃(at 25℃ambient) 36 Rev. 201304 Inductors – SPM/SPN/SPH Testing Condition & Requirements No. Item Specification Description 1. Operation temp.:-40℃ ~ +125℃(Including self-generated heat) Product temperature range Storage temp.: -40℃ ~ +85℃ 2. Appearance 2.1 2.2 Core chipping No defects or abnormalities. Test Method --Visual inspection The appearance standard of the chipping size in top side, of bottom side ferrite core is following dimension. L : 0.5 mm (max) W: 0.5 mm (max) Using calipers Size of voids occurring to coating resin is specified as following. Using calipers 1. Width direction (dimension a) : acceptable when a ≦w/2 nonconforming when a > w/2 Void appearance tolerance 2. Length direction (dimension b) : it is not specified. limitation 3. When total area of voids(including one exposing coil) occurring to each sides is not greater than 50% of coating resin area that is acceptable 2.3 Electrode appearance criterion for exposed wire 3. Solder ability Visual inspection The surface of terminal immersed shall be minimum of 90% covered with a new coating of solder Solder heat proof : 1. Preheating : 160±10℃ 90s 2. Retention time: 245±5℃ for 3 ± 1 sec 4. Vibration Inductance change : within ± 10% without mechanical damage such as break 1. Vibration frequency : (10Hz to 55Hz to 10Hz) in 60 sec. as a period 2. Vibration time : period cycled for 2 hr in each of 3 mutual perpendicular directions 3. Amplitude: 1.5mm max. 5. Terminal strength No detachment of terminal pin and no breakage of wire Add static load 4.9N(500gf) to inductor through hole of test board for 10 ± 2 sec 6. Thermal shock Inductance change : within ± 10% without mechanical damage such as break 1. Repeat 100 cycles as follow : (-40℃ ± 2℃ , 30±3 minutes) → (room temperature , 5 minutes) → (+125℃ ± 2℃ , 30±3 minutes) → (room temperature , 5 minutes) 2. Recovery : 48+4/-0 hours of recovery under the standard condition after the test. 7. 8. High temperature resistance Inductance change : within ± 10% without mechanical damage such as break 1. Environment condition : 85℃±2℃ 2. Applied current : rated current 3. Duration : 500 +4/-0 hours Humidity resistance Inductance change : within ± 10% without mechanical damage such as break 1. Environment condition : 60℃±2℃ 2. Humidity : 90~95% 3. Applied current : rated current 4. Duration : 500 +4/-0 hours 37 Rev. 201304 Inductors – SPM/SPN/SPH No. Item Specification Description Test Method 9. Low temperature storage Inductance change : within ± 10% without mechanical damage such as break Store temperature : -40℃ ± 2℃ for total 500 +4/-0 hours 10. High temperature storage Inductance change : within ± 10% without mechanical damage such as break Store temperature : +125℃ ± 2℃ for total 500 +4/-0 hours Reflow Profile Chart (Reference) 38 Rev. 201304 Inductors – SPM/SPN/SPH Packaging Specification  Embossed Tape PRODUCT SIZE CODE TYPE SPM2016 □□□□PSA SPM2016 □□□□PSC SPM2520 □□□□PSA SPM2520 □□□□PSC SPM3030 □□□□PSC SPM4040 □□□□ESC SPM4040 □□□□ESH SPM4040 □□□□ECH SPM5050 □□□□ESC SPM5050 □□□□ESE SPM5050 □□□□ESH SPM5050 □□□□ECL SPM7070 □□□□ESC SPM7070 □□□□ESE SPM7070 □□□□ESG SPM7070 □□□□ESL SPM7070 □□□□ERL SPM7070 □□□□ECL SPM7070 □□□□ESQ SPM1010 □□□□ESN SPM1010 □□□□ECN SPM1313 □□□□ECM SPM1313 □□□□ESQ SPM1313 □□□□ESR A B P SIZE TOL SIZE TOL SIZE 1.84 (0.072) 1.84 (0.072) 2.6 (0.102) 2.6 (0.102) 3.4 (0.134) 4.4 (0.173) 4.4 (0.173) 4.4 (0.173) 5.40 (0.213) 5.40 (0.213) 5.60 (0.213) 5.40 (0.213) 6.95 (0.274) 7.0 (0.276) 6.95 (0.274) 7.6 (0.299) 7.6 (0.299) 7.6 (0.299) 6.9 (0.272) 10.9 (0.429) 10.9 (0.429) 13.3 (0.524) 13.3 (0.524) 13.3 (0.524) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) 2.25 (0.089) 2.25 (0.089) 3.0 (0.118) 3.0 (0.118) 3.8 (0.150) 5.1 (0.201) 5.1 (0.201) 5.1 (0.201) 6.1 (0.240) 6.1 (0.240) 6.0 (0.236) 6.0 (0.236) 7.4 (0.291) 7.5 (0.295) 7.45 (0.293) 7.6 (0.299) 7.6 (0.299) 7.6 (0.299) 7.5 (0.295) 12.2 (0.480) 12.2 (0.480) 14.5 (0.571) 14.5 (0.571) 14.5 (0.571) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) 4.0 (0.157) 4.0 (0.157) 4.0 (0.157) 4.0 (0.157) 4.0 (0.157) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 12.0 (0.472) 12.0 (0.472) 12.0 (0.472) 12.0 (0.472) 12.0 (0.472) 12.0 (0.472) 12.0 (0.472) 16.0 (0.630) 16.0 (0.630) 20.0 (0.787) 20.0 (0.787) 20.0 (0.787) F TOL SIZE W TOL SIZE T TOL ± 0.1 3.5 ± 0.05 8.00 ± 0.1 (±0.004) (0.138) (±0.004) (0.315) (±0.004) ± 0.1 3.5 ± 0.05 8.00 ± 0.1 (±0.004) (0.138) (±0.004) (0.315) (±0.004) ± 0.1 3.5 ± 0.1 8.0 ± 0.1 (±0.004) (0.138) (±0.004) (0.315) (±0.004) ± 0.1 3.5 ± 0.1 8.0 ± 0.1 (±0.004) (0.138) (±0.004) (0.315) (±0.004) ± 0.1 3.5 ± 0.1 8.0 ± 0.3 (±0.004) (0.138) (±0.004) (0.315) (±0.0118) ± 0.1 5.5 ± 0.1 12.0 ± 0.3 (±0.004) (0.0.217) (±0.004) (0.4725) (±0.012) ± 0.1 5.5 ± 0.1 12.0 ± 0.3 (±0.004) (0.217) (±0.004) (0.4725) (±0.012) ± 0.1 5.5 ± 0.1 12.0 ± 0.3 (±0.004) (0.217) (±0.004) (0.4725) (±0.012) ± 0.1 5.5 ± 0.1 12.0 ± 0.3 (±0.004) (0.217) (±0.004) (0.472) (±0.012) ± 0.1 5.5 ± 0.1 12.0 ± 0.3 (±0.004) (0.217) (±0.004) (0.472) (±0.012) ± 0.1 5.5 ± 0.1 12.0 ± 0.3 (±0.004) (0.217) (±0.004) (0.472) (±0.012) ± 0.1 5.5 ± 0.1 12.0 ± 0.3 (±0.004) (0.217) (±0.004) (0.472) (±0.012) ± 0.1 7.5 ± 0.1 16.0 ± 0.3 (±0.004) (0.295) (±0.004) (0.630) (±0.012) ± 0.1 7.5 ± 0.1 16.0 ± 0.3 (±0.004) (0.295) (±0.004) (0.630) (±0.012) ± 0.1 7.5 ± 0.1 16.0 ± 0.3 (±0.004) (0.295) (±0.004) (0.630) (±0.012) ± 0.1 7.5 ± 0.1 16.0 ± 0.3 (±0.004) (0.295) (±0.004) (0.630) (±0.012) ± 0.1 7.5 ± 0.1 16.0 ± 0.3 (±0.004) (0.295) (±0.004) (0.630) (±0.012) ± 0.1 7.5 ± 0.1 16.0 ± 0.3 (±0.004) (0.295) (±0.004) (0.630) (±0.012) ± 0.1 7.5 ± 0.1 16.0 ± 0.3 (±0.004) (0.295) (±0.004) (0.630) (±0.012) ± 0.1 11.5 ± 0.1 24.0 ± 0.3 (±0.004) (0.453) (±0.004) (0.984) (±0.012) ± 0.1 11.5 ± 0.1 24.0 ± 0.3 (±0.004) (0.453) (±0.004) (0.984) (±0.012) ± 0.1 11.5 ± 0.1 24.0 ± 0.3 (±0.004) (0.453) (±0.004) (0.984) (±0.012) ± 0.1 11.5 ± 0.1 24.0 ± 0.3 (±0.004) (0.453) (±0.004) (0.984) (±0.012) ± 0.1 11.5 ± 0.1 24.0 ± 0.3 (±0.004) (0.453) (±0.004) (0.984) (±0.012) K SIZE TOL SIZE TOL 0.22 (0.0087) 0.22 (0.0087) 0.3 (0.012) 0.3 (0.012) 0.3 (0.012) 0.35 (0.014) 0.35 (0.014) 0.35 (0.014) 0.35 (0.014) 0.35 (0.014) 0.35 (0.014) 0.35 (0.014) 0.35 (0.014) 0.35 (0.014) 0.35 (0.014) 0.4 (0.016) 0.4 (0.016) 0.4 (0.016) 0.35 (0.014) 0.4 (0.016) 0.4 (0.016) 0.4 (0.016) 0.4 (0.016) 0.4 (0.016) ± 0.05 (±0.002) ± 0.05 (±0.002) ± 0.05 (±0.002) ± 0.05 (±0.002) ± 0.05 (±0.002) ± 0.05 (±0.002) ± 0.05 (±0.002) ± 0.05 (±0.002) ± 0.05 (±0.002) ± 0.05 (±0.002) ± 0.05 (±0.002) ± 0.05 (±0.002) ± 0.05 (±0.002) ± 0.05 (±0.002) ± 0.05 (±0.002) ± 0.05 (±0.002) ± 0.05 (±0.002) ± 0.05 (±0.002) ± 0.05 (±0.002) ± 0.05 (±0.002) ± 0.05 (±0.002) ± 0.05 (±0.002) ± 0.05 (±0.002) ± 0.05 (±0.002) 1.15 (0.045) 1.15 (0.045) 1.35 (0.053) 1.35 (0.053) 1.40 (0.053) 1.40 (0.055) 2.20 (0.087) 2.50 (0.098) 1.6 (0.063) 1.6 (0.063) 2.1 (0.083) 3.2 (0.126) 1.5 (0.059) 1.7 (0.067) 2.1 (0.827) 3.6 (0.142) 3.6 (0.142) 3.6 (0.142) 5.3 (0.209) 4.5 (0.177) 4.5 (0.177) 4.0 (0.157) 6.45 (0.254) 6.45 (0.254) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.3 (±0.012) ± 0.25 (±0.01) ± 0.25 (±0.01) Unit : mm(inch) 39 Rev. 201304 Inductors – SPM/SPN/SPH PRODUCT SIZE CODE TYPE SPN2016□□□□PSA SPH2020□□□□PTA SPN2520□□□□PSA SPH2520□□□□PSA SPN2520□□□□PSC SPH2520□□□□PSC SPN2020□□□□PTC SPH2020□□□□PCC SPH2020□□□□PTC SPN2424□□□□PTA SPN2424□□□□PTC SPN3030□□□□PTA SPH3030□□□□PTA SPN3030□□□□PTC SPH3030□□□□PTC SPN3030□□□□PTE SPN4040□□□□ETA SPH4040□□□□ETA SPN4040□□□□ETC SPH4040□□□□ETC SPN4040□□□□ETG SPH4040□□□□ETG SPN5050□□□□PTA SPN5050□□□□PTC SPN5050□□□□PTD SPH5050□□□□PTH SPN5050□□□□ETI SPN5050□□□□ETL SPN5050□□□□ETN SPH5050□□□□ETN SPN6060□□□□PTA SPN6060□□□□PTC SPH6060□□□□PTC SPN6060□□□□PTD A B P F W SIZE TOL SIZE TOL SIZE TOL SIZE TOL SIZE 1.84 (0.072) 2.2 (0.087) 2.25 (0.089) 2.6 (0.102) 2.25 (0.089) 2.6 (0.102) 2.2 (0.087) 2.2 (0.087) 2.2 (0.087) 2.6 (0.102) 2.6 (0.102) 3.2 (0.126) 3.2 (0.126) 3.2 (0.126) 3.2 (0.126) 3.2 (0.126) 4.3 (0.169) 4.3 (0.169) 4.3 (0.169) 4.3 (0.169) 4.3 (0.169) 4.3 (0.169) 5.25 (0.207) 5.25 (0.207) 5.25 (0.207) 5.25 (0.207) 5.25 (0.207) 5.15 (0.203) 5.15 (0.203) 5.15 (0.203) 6.3 (0.248) 6.3 (0.248) 6.3 (0.248) 6.3 (0.248) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) 2.25 (0.089) 2.2 (0.087) 2.80 (0.110) 3.0 (0.118) 2.80 (0.110) 3.0 (0.118) 2.2 (0.087) 2.2 (0.087) 2.2 (0.087) 2.6 (0.102) 2.6 (0.102) 3.2 (0.126) 3.2 (0.126) 3.2 (0.126) 3.2 (0.126) 3.2 (0.126) 4.3 (0.169) 4.3 (0.169) 4.3 (0.169) 4.3 (0.169) 4.3 (0.169) 4.3 (0.169) 5.25 (0.207) 5.25 (0.207) 5.25 (0.207) 5.25 (0.207) 5.25 (0.207) 5.15 (0.203) 5.15 (0.203) 5.15 (0.203) 6.3 (0.248) 6.3 (0.248) 6.3 (0.248) 6.3 (0.248) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) 4.0 (0.157) 4.0 (0.157) 4.0 (0.157) 4.0 (0.157) 4.0 (0.157) 4.0 (0.157) 4.0 (0.157) 4.0 (0.157) 4.0 (0.157) 4.0 (0.157) 4.0 (0.157) 4.0 (0.157) 4.0 (0.157) 4.0 (0.157) 4.0 (0.157) 4.0 (0.157) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) 3.5 (0.138) 3.5 (0.138) 3.5 (0.138) 3.5 (0.138) 3.5 (0.138) 3.5 (0.138) 3.5 (0.138) 3.5 (0.138) 3.5 (0.138) 3.5 (0.138) 3.5 (0.138) 3.5 (0.138) 3.5 (0.138) 3.5 (0.138) 3.5 (0.138) 3.5 (0.138) 5.5 (0.217) 5.5 (0.217) 5.5 (0.217) 5.5 (0.217) 5.5 (0.217) 5.5 (0.217) 5.5 (0.217) 5.5 (0.217) 5.5 (0.217) 5.5 (0.217) 5.5 (0.217) 5.5 (0.217) 5.5 (0.217) 5.5 (0.217) 5.5 (0.217) 5.5 (0.217) 5.5 (0.217) 5.5 (0.217) ± 0.05 (±0.004) ± 0.05 (±0.004) ± 0.05 (±0.004) ± 0.05 (±0.004) ± 0.05 (±0.004) ± 0.05 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) 8.00 (0.315) 8.00 (0.315) 8.00 (0.315) 8.00 (0.315) 8.00 (0.315) 8.00 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 12.0 (0.472) 12.0 (0.472) 12.0 (0.472) 12.0 (0.472) 12.0 (0.472) 12.0 (0.472) 12.0 (0.472) 12.0 (0.472) 12.0 (0.472) 12.0 (0.472) 12.0 (0.472) 12.0 (0.472) 12.0 (0.472) 12.0 (0.472) 12.0 (0.472) 12.0 (0.472) 12.0 (0.472) 12.0 (0.472) T TOL SIZE K TOL ± 0.1 0.22 ± 0.05 (±0.004) (0.0087) (±0.002) ± 0.1 0.25 ± 0.05 (±0.004) (0.009) (±0.002) ± 0.1 0.3 ± 0.05 (±0.004) (0.012) (±0.002) ± 0.1 0.3 ± 0.05 (±0.004) (0.012) (±0.002) ± 0.1 0.3 ± 0.05 (±0.004) (0.012) (±0.002) ± 0.1 0.3 ± 0.05 (±0.004) (0.012) (±0.002) ± 0.2 0.25 ± 0.05 (±0.008) (0.009) (±0.002) ± 0.2 0.25 ± 0.05 (±0.008) (0.009) (±0.002) ± 0.2 0.25 ± 0.05 (±0.008) (0.009) (±0.002) ± 0.2 0.25 ± 0.05 (±0.008) (0.009) (±0.002) ± 0.2 0.25 ± 0.05 (±0.008) (0.009) (±0.002) ± 0.2 0.3 ± 0.05 (±0.008) (0.012) (±0.002) ± 0.2 0.3 ± 0.05 (±0.008) (0.012) (±0.002) ± 0.2 0.3 ± 0.05 (±0.008) (0.012) (±0.002) ± 0.2 0.3 ± 0.05 (±0.008) (0.012) (±0.002) ± 0.2 0.3 ± 0.05 (±0.008) (0.012) (±0.002) ± 0.3 0.3 ± 0.1 (±0.012) (0.012) (±0.004) ± 0.3 0.3 ± 0.1 (±0.012) (0.012) (±0.004) ± 0.3 0.3 ± 0.1 (±0.012) (0.012) (±0.004) ± 0.3 0.3 ± 0.1 (±0.012) (0.012) (±0.004) ± 0.3 0.3 ± 0.1 (±0.012) (0.012) (±0.004) ± 0.3 0.3 ± 0.1 (±0.012) (0.012) (±0.004) ± 0.3 0.3 ± 0.1 (±0.012) (0.012) (±0.004) ± 0.3 0.3 ± 0.1 (±0.012) (0.012) (±0.004) ± 0.3 0.3 ± 0.1 (±0.012) (0.012) (±0.004) ± 0.3 0.3 ± 0.1 (±0.012) (0.012) (±0.004) ± 0.3 0.3 ± 0.1 (±0.012) (0.012) (±0.004) ± 0.3 0.4 ± 0.1 (±0.012) (0.016) (±0.004) ± 0.3 0.4 ± 0.1 (±0.012) (0.016) (±0.004) ± 0.3 0.4 ± 0.1 (±0.012) (0.016) (±0.004) ± 0.3 0.4 ± 0.1 (±0.012) (0.016) (±0.004) ± 0.3 0.4 ± 0.1 (±0.012) (0.016) (±0.004) ± 0.3 0.4 ± 0.1 (±0.012) (0.016) (±0.004) ± 0.3 0.4 ± 0.1 (±0.012) (0.016) (±0.004) SIZE TOL 1.15 (0.045) 1.3 (0.051) 1.35 (0.053) 1.35 (0.053) 1.35 (0.053) 1.35 (0.053) 1.3 (0.051) 1.3 (0.051) 1.3 (0.051) 1.3 (0.051) 1.3 (0.051) 1.4 (0.055) 1.4 (0.055) 1.6 (0.063) 1.6 (0.063) 1.9 (0.075) 1.4 (0.055) 1.4 (0.055) 1.6 (0.063) 1.6 (0.063) 2.1 (0.083) 2.1 (0.083) 1.4 (0.055) 1.4 (0.055) 1.6 (0.063) 2.3 (0.091) 2.7 (0.106) 3.2 (0.126) 4.2 (0.165) 4.2 (0.165) 1.4 (0.055) 1.6 (0.063) 1.6 (0.063) 1.6 (0.063) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) Unit : mm(inch) 40 Rev. 201304 Inductors – SPM/SPN/SPH PRODUCT SIZE CODE Series SPN6060□□□□ETH SPH6060□□□□ETH SPN6060□□□□ETK SPH6060□□□□ETK SPN6060□□□□ETP SPH6060□□□□ETP SPN8080□□□□ETL SPN8080□□□□ETN SPH8080□□□□ETN A B P F W T K SIZE TOL SIZE TOL SIZE TOL SIZE TOL SIZE TOL SIZE TOL SIZE TOL 6.3 (0.248) 6.3 (0.248) 6.3 (0.248) 6.3 (0.248) 6.3 (0.248) 6.3 (0.248) 8.3 (0.327) 8.3 (0.327) 8.3 (0.327) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) 6.3 (0.248) 6.3 (0.248) 6.3 (0.248) 6.3 (0.248) 6.3 (0.248) 6.3 (0.248) 8.3 (0.327) 8.3 (0.327) 8.3 (0.327) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 8.0 (0.315) 12.0 (0.472) 12.0 (0.472) 12.0 (0.472) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) 5.5 (0.217) 5.5 (0.217) 5.5 (0.217) 5.5 (0.217) 5.5 (0.217) 5.5 (0.217) 7.5 (0.295) 7.5 (0.295) 7.5 (0.295) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) 12.0 (0.472) 12.0 (0.472) 12.0 (0.472) 12.0 (0.472) 12.0 (0.472) 12.0 (0.472) 16.0 (0.630) 16.0 (0.630) 16.0 (0.630) ± 0.3 (±0.012) ± 0.3 (±0.012) ± 0.3 (±0.012) ± 0.3 (±0.012) ± 0.3 (±0.012) ± 0.3 (±0.012) ± 0.3 (±0.012) ± 0.3 (±0.012) ± 0.3 (±0.012) 0.4 (0.016) 0.4 (0.016) 0.4 (0.016) 0.4 (0.016) 0.4 (0.016) 0.4 (0.016) 0.5 (0.020) 0.5 (0.020) 0.5 (0.020) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) 2.3 (0.090) 2.3 (0.090) 3.1 (0.122) 3.1 (0.122) 4.7 (0.185) 4.7 (0.185) 3.4 (0.134) 4.5 (0.177) 4.5 (0.177) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) ± 0.1 (±0.004) Unit : mm(inch) 41 Rev. 201304 Inductors – SPM/SPN/SPH Reel Specifications  Reel 7” Code Dimensions D 180 ± 1.5 P 62.0 ± 1.5 D 330 ± 1.5 P 100 ± 1.5  Reel 13” Code Dimensions 42 Rev. 201304 Inductors – SPI (Assembly) Assembly Inductors (SPI Series) Product Range DARFON Item SPIRI73 SPIRI74 SPIRI124 SPIRI125 SPIRI127 SPIRR6025 SPIRR6028 SPIRR7028 SPIRR7032 SPIRR7045 SPIRR1045 SPIRR1255 SPIRR1265 SPIRR1275 SPIRH3D16 SPIRH4D18 SPIRH4D28 SPIRH5D18 SPIRH5D28 SPIRH6D18 SPIRH6D28 SPIRH6D38 SPIRH103R SPIRH104R SPIRD0715 SPIRD0728 SPIRD1015 SPIRD1024 Dimensions (mm) max 7.5*7.5*3.5 7.5*7.5*4.5 12.5*12.5*4.5 12.5*12.5*6.2 12.5*12.5*8.0 6.2*6.2*2.7 6.2*6.2*3.0 7.2*7.2*3.0 7.2*7.2*3.4 7.2*7.2*4.8 10.4*10.4*4.8 12.8*12.8*5.8 12.8*12.8*6.85 12.8*12.8*7.85 4.3*4.3*2.0 5.2*5.2*2.0 5.2*5.2*3.0 6.2*6.2*2.1 6.2*6.2*3.0 7.1*7.1*1.9 7.2*7.2*3.0 7.2*7.2*4.0 10.3*10.5*3.1 10.3*10.5*4.0 7.1*7.1*1.5 7.5*7.5*2.8 10.3*10.3*1.5 10.3*10.3*2.5 Inductance range 0.1uH 10uH 10uH 1mH 1mH 10uH 1mH 1uH 100uH 3.9uH 330uH 10uH 1mH 2.4uH 47uH 4.7uH 100uH 4.7uH 100uH 3.3uH 47uH 3.3uH 1mH 3.3uH 1mH 10uH 1.5m 6.0uH 1.5mH 2.0uH 220uH 1.2uH 1.5uH 1.0uH 220uH 33uH 39uH 1.2uH 180uH 4.1uH 100uH 2.6uH 3.3uH 100uH 10uH 3.0uH 100uH 3.3uH 100uH 0.8uH 470uH 1.5uH 3.3uH 2.2uH 2.7uH 3.9uH 43 330uH 47uH 68uH 47uH 33uH Rev. 201304 Inductors – SPI (Assembly) ▓Standard External Dimensions Unit: Inch / mm Part No SPIRI73 SPIRI74 A 0.295 max 7.50 max 0.295 max 7.50 max B 0.295 max 7.50 max 0.295 max 7.50 max C 0.138 max 3.5 max 0.177 max 4.50 max D 0.079 2.00 0.079 2.00 E 0.043 1.10 0.043 1.10 F 0.200 5.08 0.200 5.08 G 0.248 6.30 0.248 6.30 H 0.118 3.00 0.118 3.00 I 0.075 1.91 0.075 1.91 J 0.177 4.50 0.177 4.50 K 0.413 10.50 0.413 10.50 C 0.177 max 4.50 max 0.244 max 6.20 max 0.315 max 8.00 max D 0.197 5.00 0.197 5.00 0.197 5.00 E 0.079 2.00 0.079 2.00 0.079 2.00 F 0.299 7.60 0.299 7.60 0.299 7.60 G 0.393 10.00 0.393 10.00 0.393 10.00 H 0.236 6.00 0.236 6.00 0.236 6.00 I 0.118 3.00 0.118 3.00 0.118 3.00 J 0.276 7.00 0.276 7.00 0.276 7.00 K 0.709 18.00 0.709 18.00 0.709 18.00 Unit: Inch / mm Part No SPIRI124 SPIRI125 SPIRI127 A 0.492 max 12.50 max 0.492 max 12.50 max 0.492 max 12.50 max B 0.492 max 12.50 max 0.492 max 12.50 max 0.492 max 12.50 max 44 Rev. 201304 Inductors – SPI (Assembly) Unit: Inch / mm Part No SPIRR6025 SPIRR6028 SPIRR7028 SPIRR7032 SPIRR7045 SPIRR1045 SPIRR1255 SPIRR1265 SPIRR1275 A 0.236±0.079 6.0±0.2 0.236±0.079 6.0±0.2 0.276±0.079 7.0±0.2 0.276±0.079 7.0±0.2 0.276±0.079 7.0±0.2 0.398±0.0118 10.1±0.3 0.492±0.118 10.1±0.3 0.492±0.118 10.1±0.3 0.492±0.118 10.1±0.3 B 0.236±0.079 6.0±0.2 0.236±0.079 6.0±0.2 0.276±0.079 7.0±0.2 0.276±0.079 7.0±0.2 0.276±0.079 7.0±0.2 0.398±0.0118 10.1±0.3 0.492±0.118 10.1±0.3 0.492±0.118 10.1±0.3 0.492±0.118 10.1±0.3 C 0.099±0.0079 2.5±0.2 0.110±0.0079 2.5±0.2 0.110±0.0079 2.5±0.2 0.126±0.0079 3.2±0.2 0.177±0.118 4.5±0.3 0.177±0.118 4.5±0.3 0.217±0.0118 5.5±0.3 0.256±0.0138 6.5±0.35 0.295±0.0138 7.5±0.35 D 0.079±0.0040 2.0±0.1 0.079±0.0040 2.0±0.1 0.079±0.0040 2.0±0.1 0.079±0.0040 2.0±0.1 0.079±0.0040 2.0±0.1 0.118±0.0040 3.0±0.1 0.118±0.0040 3.0±0.1 0.118±0.0040 3.0±0.1 0.118±0.0040 3.0±0.1 45 E 0.118 typ 3.0 typ F 0.059 typ 1.5 typ G 0.0866 2.2 H 0.079 2.0 I 0.103 2.6 0.118 typ 3.0 typ 0.059 typ 1.5 typ 0.0866 2.2 0.079 2.0 0.103 2.6 0.193 typ 4.0 typ 0.059 typ 1.5 typ 0.0866 2.2 0.079 2.0 0.103 3.6 0.193 typ 4.0 typ 0.059 typ 1.5 typ 0.0866 2.2 0.079 2.0 0.142 3.6 0.193 typ 4.0 typ 0.236±0.0079 6.0±0.2 0.339±0.0118 8.6±0.3 0.339±0.0118 8.6±0.3 0.339±0.0118 8.6±0.3 0.059 typ 1.5 typ 0.079±0.0059 2.0±0.15 0.079±0.0059 2.0±0.15 0.079±0.0059 2.0±0.15 0.079±0.0059 2.0±0.15 0.0866 2.2 0.079 2.0 0.142 3.6 0.126 3.2 0.099 2.5 0.322 8.2 0.126 3.2 0.099 2.5 0.322 8.2 0.126 3.2 0.099 2.5 0.322 8.2 0.126 3.2 0.099 2.5 0.322 8.2 Rev. 201304 Inductors – SPI (Assembly) Unit: Inch / mm Part No SPIRH3D16 SPIRH4D18 SPIRH4D28 SPIRH5D18 SPIRH5D28 SPIRH6D18 SPIRH6D28 SPIRH6D38 A 0.150±0.012 3.8±0.5 0.185±0.012 4.7±0.5 0.185±0.12 4.7±0.5 0.225±0.12 5.7±0.5 0.225±0.12 5.7±0.5 0.264±0.158 6.7±0.4 0.264±0.158 6.7±0.4 0.264±0.158 6.7±0.4 B 0.150±0.012 3.8±0.5 0.185±0.012 4.7±0.5 0.0185±0.012 4.7±0.5 0.225±0.12 5.7±0.5 0.225±0.12 5.7±0.5 0.264±0.158 6.7±0.4 0.264±0.158 6.7±0.4 0.264±0.158 6.7±0.4 C 0.071±0.008 1.8±0.2 0.079 max 2.0 max D 0.150 3.8 E 0.044 1.1 F 0.150 3.8 G 0.196 max 5.0 max H 0.044 1.1 I 0.181 4.6 J 0.067 1.7 0.177 4.5 0.059 1.5 0.177 4.5 0.272 max 6.9 max 0.059 1.5 0.209 5.3 0.075 1.9 0.119 max 3.0 max 0.177 4.5 0.059 1.5 0.177 4.5 0.272 max 6.9 max 0.059 1.5 0.209 5.3 0.075 1.9 0.083 max 2.1 max 0.217 5.5 0.079 2.0 0.217 5.5 0.323max 8.2 max 0.079 2.0 0.248 6.3 0.085 2.15 0.119 max 3.0 max 0.217 5.5 0.079 2.0 0.217 5.5 0.323max 8.2 max 0.079 2.0 0.248 6.3 0.085 2.15 0.075 max 1.9 max 0.256 6.5 0.079 2.0 0.256 6.5 0.375 max 9.5 max 0.079 2.0 0.288 7.3 0.105 2.65 0.119 max 3.0 max 0.256 6.5 0.079 2.0 0.256 6.5 0.375 max 9.5 max 0.079 2.0 0.288 7.3 0.105 2.65 0.158 max 4.0 max 0.256 6.5 0.079 2.0 0.256 6.5 0.375 max 9.5 max 0.079 2.0 0.288 7.3 0.105 2.65 Unit: Inch / mm Part No A B C D E F G H I SPIRH103R 0.398 max 10.3 max 0.414 max 10.5 max 0.048±0.006 1.2±0.15 0.048±0.006 1.2±0.15 0.63 1.6 0.414 max 10.5 max 0.303±0.012 7.7±0.3 0.303±0.012 7.7±0.3 0.126 3.2 0.398 max 10.3 max 0.119±0.004 3.0±0.1 0.119±0.004 3.0±0.1 0.288 7.3 SPIRH104R 0.122 max 3.1 max 0.150±0.008 3.8±0.2 0.288 7.3 0.126 3.2 0.63 1.6 46 Rev. 201304 Inductors – SPI (Assembly) Unit: Inch / mm Part No SPIRD7015 SPIRD7028 A 0.271±0.157 6.9±0.4 0.276±0.020 7.0±0.5 B 0.059 max 1.5 max 0.110 max 2.8 max C 0.079 2.0 0.079 2.0 D 0.288 7.3 0.288 7.3 E 0.288 7.3 0.288 7.3 Unit: Inch / mm Part No SPIRD1015 SPIRD1024 A 0.406 max 10.3 max 0.406 max 10.3 max B 0.406 max 10.3 max 0.406 max 10.3 max 47 C 0.059 max 1.5 max 0.099 max 2.5 max D 0.119 3.0 0.119 3.0 E 0.410 10.4 0.410 10.4 F 0.146 3.7 0.146 3.7 Rev. 201304 Inductors – SPI (Assembly) ▓Part Numbers & Characteristic (SPI Series) ● SPIRI Series DARFON P/N Inductance L (uH) Tolerance Rated current (A) DC Resistance (Ω) ± 20% Marking Measuring Condition SPIRI73 SPIRI73100M 10 1.68 0.072 --- SPIRI73120M 12 1.52 0.098 --- SPIRI73150M 15 1.33 0.130 --- SPIRI73180M 18 1.20 0.140 --- SPIRI73220M 22 1.07 0.190 --- SPIRI73270M 27 0.96 0.210 --- SPIRI73330M 33 0.91 0.240 --- SPIRI73390M 39 0.77 0.320 --- SPIRI73470M 47 0.76 0.360 --- SPIRI73560M 56 0.68 0.470 --- SPIRI73680M 68 0.61 0.520 --- SPIRI73820M 82 0.57 0.690 --- SPIRI73101M 100 0.50 0.790 --- SPIRI73121M 120 0.49 0.890 --- SPIRI73151M 150 0.43 1.270 --- SPIRI73181M 180 0.39 1.450 --- SPIRI73221M 220 0.35 1.650 --- SPIRI73271M 270 0.32 2.310 --- SPIRI73331M 330 0.28 2.620 --- SPIRI73391M 390 0.26 2.940 --- SPIRI73471M 470 0.24 4.180 --- SPIRI73561M 560 0.22 4.670 --- SPIRI73681M 680 0.19 5.730 --- ± 20% SPIRI73821M 820 0.18 6.540 --- SPIRI73102M 1000 0.16 9.440 --- 48 100KHz, 1V Rev. 201304 Inductors – SPI (Assembly) DARFON P/N Inductance L (uH) Tolerance Rated current (A) DC Resistance (Ω) ± 20% Marking Measuring Condition SPIRI74 SPIRI74100M 10 1.84 0.072 --- SPIRI74120M 12 1.71 0.098 --- SPIRI74150M 15 1.47 0.130 --- SPIRI74180M 18 1.31 0.140 --- SPIRI74220M 22 1.23 0.190 --- SPIRI74270M 27 1.12 0.210 --- SPIRI74330M 33 0.96 0.240 --- SPIRI74390M 39 0.91 0.320 --- SPIRI74470M 47 0.88 0.360 --- SPIRI74560M 56 0.75 0.470 --- SPIRI74680M 68 0.69 0.520 --- SPIRI74820M 82 0.61 0.690 --- SPIRI74101M 100 0.60 0.790 --- SPIRI74121M 120 0.52 0.890 --- SPIRI74151M 150 0.46 1.270 --- SPIRI74181M 180 0.42 1.450 --- SPIRI74221M 220 0.36 1.650 --- SPIRI74271M 270 0.34 2.310 --- SPIRI74331M 330 0.32 2.620 --- SPIRI74391M 390 0.29 2.940 --- SPIRI74561M 560 0.23 4.670 --- SPIRI74681M 680 0.22 5.730 --- SPIRI74821M 820 0.20 6.540 --- SPIRI74102M 1000 0.18 9.440 --- ± 20% 49 100KHz, 1V Rev. 201304 Inductors – SPI (Assembly) DARFON P/N Inductance L (uH) Tolerance Rated current (A) DC Resistance (Ω) ± 20% Marking Measuring Condition SPIRI124 SPIRI1243R9M 3.9 6.50 0.015 --- SPIRI1244R7M 4.7 5.70 0.018 --- SPIRI1246R8M 6.8 4.90 0.023 --- SPIRI124100M 10 4.50 0.028 --- SPIRI124120M 12 4.00 0.038 --- SPIRI124150M 15 3.20 0.050 --- SPIRI124180M 18 3.10 0.057 --- SPIRI124220M 22 2.90 0.066 --- SPIRI124270M 27 2.80 0.080 --- SPIRI124330M 33 2.70 0.097 --- SPIRI124390M 39 2.10 0.132 --- SPIRI124470M 47 1.90 0.150 --- SPIRI124560M 56 1.80 0.190 --- SPIRI124680M 68 1.50 0.220 --- SPIRI124820M 82 1.30 0.260 --- SPIRI124101M 100 1.20 0.308 --- SPIRI124121M 120 1.10 0.380 --- SPIRI124151M 150 0.95 0.530 --- SPIRI124181M 180 0.85 0.620 --- SPIRI124221M 220 0.80 0.700 --- SPIRI124271M 270 0.60 0.876 --- SPIRI124331M 330 0.50 0.990 --- ± 20% 50 100KHz, 1V Rev. 201304 Inductors – SPI (Assembly) DARFON P/N Inductance L (uH) Tolerance Rated current (A) DC Resistance (Ω) ± 20% Marking Measuring Condition SPIRI125 SPIRI125100M 10 4.00 0.025 --- SPIRI125120M 12 3.50 0.027 --- SPIRI125150M 15 3.30 0.030 --- SPIRI125180M 18 3.00 0.038 --- SPIRI125220M 22 2.80 0.045 --- SPIRI125270M 27 2.30 0.055 --- SPIRI125330M 33 2.10 0.063 --- SPIRI125390M 39 2.00 0.075 --- SPIRI125470M 47 1.80 0.085 --- SPIRI125560M 56 1.70 0.110 --- SPIRI125680M 68 1.50 0.120 --- SPIRI125820M 82 1.40 0.140 --- SPIRI125101M 100 1.30 0.165 --- SPIRI125121M 120 1.10 0.195 --- SPIRI125151M 150 1.00 0.250 --- SPIRI125181M 180 0.90 0.290 --- SPIRI125221M 220 0.80 0.400 --- SPIRI125271M 270 0.75 0.460 --- SPIRI125331M 330 0.68 0.510 --- SPIRI125391M 390 0.65 0.690 --- SPIRI125471M 470 0.58 0.770 --- SPIRI125561M 560 0.54 0.880 --- SPIRI125681M 680 0.48 1.200 --- ± 20% SPIRI125821M 820 0.43 1.340 --- SPIRI125102M 1000 0.40 1.530 --- SPIRI1272R4M 2.4 8 0.012 --- SPIRI1274R7M 4.7 6.80 0.016 --- SPIRI1277R6M 7.6 5.90 0.020 --- SPIRI127100M 10 5.40 0.022 --- SPIRI127120M 12 4.90 0.025 --- SPIRI127150M 15 4.50 0.027 --- SPIRI127180M 18 3.90 0.039 --- SPIRI127220M 22 3.60 0.043 --- SPIRI127270M 27 3.40 0.046 --- SPIRI127330M 33 3.00 0.065 --- SPIRI127390M 39 2.75 0.073 --- SPIRI127470M 47 2.50 0.100 --- 100KHz, 1V SPIRI127 ± 20% 51 100KHz, 1V Rev. 201304 Inductors – SPI (Assembly) ● SPIRR Series DARFON P/N Inductance L (uH) Tolerance Rated current (A) DC Resistance (Ω) ± 20% Marking Measuring Condition SPIRR6025 SPIRR60254R7M 4.7 1.50 0.050 --- SPIRR60256R8M 6.8 1.30 0.080 --- SPIRR6025100M 10 1.00 0.098 --- SPIRR6025150M 15 0.88 0.140 --- SPIRR6025220M 22 0.73 0.208 --- SPIRR6025330M 33 0.59 0.310 --- SPIRR6025470M 47 0.48 0.390 --- ± 20% SPIRR6025680M 68 0.42 0.540 --- SPIRR6025101M 100 0.33 0.810 --- 100KHz, 1V SPIRR6028 SPIRR6028M 3.3 1.60 0.050 --- SPIRR6028M 6.8 1.50 0.073 --- SPIRR6028M 10 1.30 0.098 --- SPIRR6028M 15 1.00 0.128 --- SPIRR6028M 22 0.77 0.172 --- SPIRR6028M 33 0.69 0.290 --- SPIRR6028M 47 0.59 0.420 --- SPIRR6028M 68 0.50 0.533 --- SPIRR6028M 100 0.42 0.730 --- ± 20% 100KHz, 1V SPIRR7028 SPIRR70283R3M 3.3 1.60 0.045 --- SPIRR70284R7M 4.7 1.50 0.054 --- SPIRR70286R8M 6.8 1.30 0.071 --- SPIRR7028100M 10 1.10 0.100 --- SPIRR7028150M 15 0.88 0.156 --- SPIRR7028220M 22 0.75 0.220 --- SPIRR7028330M 33 0.65 0.290 --- SPIRR7028470M 47 0.54 0.410 --- ± 20% 52 100KHz, 1V Rev. 201304 Inductors – SPI (Assembly) DARFON P/N Inductance L (uH) Tolerance Rated current (A) DC Resistance (Ω) ± 20% Marking 0.028 --- Measuring Condition SPIRR7032 SPIRR70323R3M 3.3 1.90 SPIRR70324R7M 4.7 1.70 0044 --- SPIRR70326R8M 6.8 1.60 0.050 --- SPIRR7032100M 10 1.40 0.064 --- SPIRR7032150M 15 1.10 0.090 --- SPIRR7032220M 22 0.96 0.132 --- SPIRR7032330M 33 0.75 0.192 --- SPIRR7032M470 47 0.67 0.290 --- SPIRR7032680M 68 0.59 0.372 --- SPIRR7032101M 100 0.45 0.540 --- SPIRR7032151M 150 0.37 0.780 --- SPIRR7032221M 220 0.29 1.260 --- SPIRR7032331M 330 0.22 2.000 --- SPIRR7032471M 470 0.20 2.460 --- ± 20% SPIRR7032681M 680 0.16 3.780 --- SPIRR7032102M 1000 0.13 5.740 --- SPIRR70453R3M 3.3 2.30 0.024 --- SPIRR70454R7M 4.7 2.00 0.036 --- SPIRR70456R8M 6.8 1.70 0.045 --- SPIRR7045100M 10 1.30 0.047 --- SPIRR7045150M 15 1.10 0.063 --- SPIRR7045220M 22 0.90 0.075 --- SPIRR7045330M 33 0.82 0.120 --- SPIRR7045470M 47 0.75 0.150 --- SPIRR7045680M 68 0.60 0.210 --- SPIRR7045101M 100 0.50 0.300 --- SPIRR7045151M 150 0.40 0.410 --- SPIRR7045221M 220 0.33 0.624 --- SPIRR7045331M 330 0.25 0.890 --- SPIRR7045471M 470 0.22 1.260 --- SPIRR7045681M 680 0.20 1.780 --- SPIRR7045102M 1000 0.14 2.740 --- 100KHz, 1V SPIRR7045 ± 20% 53 100KHz, 1V Rev. 201304 Inductors – SPI (Assembly) DARFON P/N Inductance L (uH) Tolerance Rated current (A) DC Resistance (Ω) ± 20% Marking 2.5 0.044 --- Measuring Condition SPIRR1045 SPIRR1045100M 10 SPIRR1045150M 15 2.2 0.057 --- SPIRR1045220M 22 1.90 0.071 --- SPIRR1045330M 33 1.60 0.100 --- SPIRR1045470M 47 1.40 0.120 --- SPIRR1045680M 68 1.20 0.170 --- SPIRR1045101M 100 1.00 0.240 --- SPIRR1045151M 150 0.79 0.420 --- SPIRR1045221M 220 0.65 0.570 --- SPIRR1045331M 330 0.54 0.820 --- SPIRR1045471M 470 0.47 1.240 --- ± 20% SPIRR1045681M 680 0.38 1.920 --- SPIRR1045102M 1000 0.29 3.360 --- SPIRR1045152M 1500 0.22 4.080 --- SPIRR12556R0M 6.0 3.60 0.020 SPIRR1255100M 10 3.40 0.026 SPIRR1255150M 15 2.80 0.032 SPIRR1255220M 22 2.30 0.041 SPIRR1255330M 33 1.90 0.050 SPIRR1255470M 47 1.60 0.075 SPIRR1255680M 68 1.30 0.100 SPIRR1255101M 100 1.10 0.140 SPIRR1255151M 150 0.88 0.230 SPIRR1255221M 220 0.72 0.330 SPIRR1255331M 330 0.59 0.500 SPIRR1255471M 470 0.49 0.630 100KHz, 1V SPIRR1255 ± 20% SPIRR1255681M 680 0.43 0.920 SPIRR1255102M 1000 0.34 1.350 SPIRR1255152M 1500 0.29 2.080 54 100KHz, 1V Rev. 201304 Inductors – SPI (Assembly) DARFON P/N Inductance L (uH) Tolerance Rated current (A) DC Resistance (Ω) ± 20% Marking Measuring Condition SPIRR1265 SPIRR12652R0M 2.0 6.20 0.014 --- SPIRR12654R2M 4.2 5.50 0.018 --- SPIRR12657R0M 7.0 5.00 0.022 --- SPIRR1265100M 10 4.80 0.025 --- SPIRR1265150M 15 4.20 0.029 --- SPIRR1265220M 22 3.50 0.038 --- SPIRR1265330M 33 2.80 0.049 --- SPIRR1265470M 47 2.40 0.070 --- SPIRR1265680M 68 2.00 0.095 --- SPIRR1265101M 100 1.60 0.150 --- SPIRR1265221M 220 1.00 0.330 --- SPIRR12751R2M 1.2 8.20 0.009 SPIRR12752R7M 2.7 7.00 0.012 SPIRR12753R9M 3.9 6.70 0.013 SPIRR12755R6M 5.6 6.30 0.014 SPIRR12756R8M 6.8 5.90 0.016 SPIRR1275100M 10 5.40 0.019 SPIRR1275150M 15 4.70 0.022 4.00 0.032 ± 20% 100KHz, 1V SPIRR1275 ± 20% SPIRR1275220M 22 SPIRR1275330M 33 3.20 0.048 SPIRR1275470M 47 2.70 0.064 SPIRR1275680M 68 2.00 0.094 SPIRR1275101M 100 1.90 0.150 SPIRR1275151M 150 1.50 0.210 SPIRR1275221M 220 1.30 0.310 55 100KHz, 1V Rev. 201304 Inductors – SPI (Assembly) ● SPIRH Series DARFON P/N Inductance L (uH) Tolerance Rated current (A) DC Resistance (Ω) ± 20% Marking Measuring Condition SPIRH3D16 SPIRH3D161R5M 1.5 1.55 0.052 --- SPIRH3D162R2M 2.2 1.20 0.072 --- SPIRH3D163R3M 3.3 1.10 0.085 --- SPIRH3D164R7M 4.7 0.90 0.105 --- SPIRH3D166R8M 6.8 0.73 0.170 --- SPIRH3D16100M 10 0.55 0.210 --- SPIRH3D16150M 15 0.45 0.295 --- SPIRH3D16220M 22 0.40 0.430 --- SPIRH3D16330M 33 0.32 0.675 --- ± 20% 100KHz, 1V SPIRH4D18 SPIRH4D181R0M 1.0 1.72 0.045 --- SPIRH4D182R2M 2.2 1.32 0.060 --- SPIRH4D182R7M 2.7 1.28 0.070 --- SPIRH4D183R3M 3.3 1.04 0.085 --- SPIRH4D183R9M 3.9 0.88 0.110 --- SPIRH4D184R7M 4.7 0.84 0.128 --- SPIRH4D185R6M 5.6 0.80 0.145 --- SPIRH4D186R8M 6.8 0.76 0.158 --- SPIRH4D188R2M 8.2 0.68 0.185 --- SPIRH4D18100M 10 0.61 0.200 --- SPIRH4D18120M 12 0.56 0.210 --- SPIRH4D18150M 15 0.50 0.240 --- SPIRH4D18180M 18 0.48 0.338 --- SPIRH4D18220M 22 0.41 0.397 --- SPIRH4D18270M 27 0.35 0.441 --- SPIRH4D18330M 33 0.32 0.694 --- SPIRH4D18390M 39 0.30 0.709 --- ± 20% 56 100KHz, 1V Rev. 201304 Inductors – SPI (Assembly) DARFON P/N Inductance L (uH) Tolerance Rated current (A) DC Resistance (Ω) ± 20% Marking Measuring Condition SPIRH4D28 SPIRH4D281R2M 1.2 2.56 0.0236 --- SPIRH4D281R8M 1.8 2.20 0.0275 --- SPIRH4D282R2M 2.2 2.04 0.0313 --- SPIRH4D282R7M 2.7 1.60 0.0433 --- SPIRH4D283R3M 3.3 1.57 0.0492 --- SPIRH4D283R9M 3.9 1.44 0.0648 --- SPIRH4D284R7M 4.7 1.32 0.0720 --- SPIRH4D285R6M 5.6 1.17 0.1009 --- SPIRH4D286R8M 6.8 1.12 0.1089 --- SPIRH4D288R2M 8.2 1.04 0.1175 --- SPIRH4D28100M 10 1.00 0.1283 --- SPIRH4D28120M 12 0.84 0.1316 --- SPIRH4D28150M 15 0.76 0.1490 --- 0.72 0.1660 --- ± 20% SPIRH4D28180M 18 SPIRH4D28220M 22 0.70 0.2350 SPIRH4D28270M 27 0.58 0.2610 SPIRH4D28330M 33 0.56 0.3780 SPIRH4D28390M 39 0.50 0.3837 --- SPIRH4D28470M 47 0.48 0.5870 --- SPIRH4D28560M 56 0.41 0.6245 --- SPIRH4D28680M 68 0.35 0.6990 --- SPIRH4D28820M 82 0.32 0.9148 --- SPIRH4D28101M 100 0.29 1.020 --- SPIRH4D28121M 120 0.27 1.270 --- SPIRH4D28151M 150 0.24 1.350 --- SPIRH4D28181M 180 0.22 1.540 --- 100KHz, 1V SPIRH5D18 SPIRH5D184R1M 4.1 1.95 0.057 --- SPIRH5D185R4M 5.4 1.60 0.076 --- SPIRH5D186R2M 6.2 1.40 0.096 --- SPIRH5D188R9M 8.9 1.25 0.116 --- SPIRH5D18100M 10 1.20 0.124 --- SPIRH5D18120M 12 1.10 0.153 --- SPIRH5D18150M 15 0.97 0.196 --- SPIRH5D18180M 18 0.85 0.210 --- SPIRH5D18220M 22 0.80 0.290 --- SPIRH5D18270M 27 0.75 0.330 --- SPIRH5D18330M 33 0.65 0.386 --- SPIRH5D18390M 39 0.57 0.520 --- SPIRH5D18470M 47 0.54 0.595 --- SPIRH5D18560M 56 0.50 0.665 --- SPIRH5D18680M 68 0.43 0.840 --- ± 20% SPIRH5D18820M 82 0.41 0.978 --- SPIRH5D18101M 100 0.36 1.200 --- 57 100KHz, 1V Rev. 201304 Inductors – SPI (Assembly) DARFON P/N Inductance L (uH) Tolerance Rated current (A) DC Resistance (Ω) ± 20% Marking Measuring Condition SPIRH5D28 SPIRH5D282R6M 2.6 2.60 0.018 --- SPIRH5D283R0M 3.0 2.40 0.024 --- SPIRH5D284R2M 4.2 2.20 0.031 --- SPIRH5D285R3M 5.3 1.90 0.038 --- SPIRH5D286R2M 6.2 1.80 0.045 --- SPIRH5D288R2M 8.2 1.60 0.053 --- SPIRH5D28100M 10 1.30 0.065 --- SPIRH5D28120M 12 1.20 0.076 --- SPIRH5D28150M 15 1.10 0.103 --- SPIRH5D28180M 18 1.00 0.110 --- SPIRH5D28220M 22 0.90 0.122 --- SPIRH5D28270M 27 0.85 0.175 --- SPIRH5D28330M 33 0.75 0.189 --- SPIRH5D28390M 39 0.70 0.212 --- SPIRH5D28470M 47 0.62 0.260 --- SPIRH5D28560M 56 0.58 0.305 --- SPIRH5D28680M 68 0.52 0.355 --- SPIRH5D28820M 82 0.46 0.463 --- SPIRH5D28101M 100 0.42 0.520 --- SPIRH6D183R3M 3.3 3.00 0.069 --- SPIRH6D184R7M 4.7 2.40 0.075 --- 2.20 0.106 --- ± 20% 100KHz, 1V SPIRH6D18 ± 20% SPIRH6D186R8M 6.8 SPIRH6D18100M 10 1.80 0.150 --- SPIRH6D283R0M 3.0 3.00 0.024 --- SPIRH6D283R9M 3.9 2.60 0.027 --- SPIRH6D285R0M 5.0 2.40 0.031 --- SPIRH6D286R0M 6.0 2.25 0.035 --- SPIRH6D287R3M 7.3 2.10 0.054 --- SPIRH6D288R6M 8.6 1.85 0.058 --- SPIRH6D28100M 10 1.70 0.065 --- SPIRH6D28120M 12 1.55 0.070 --- SPIRH6D28150M 15 1.40 0.084 --- SPIRH6D28180M 18 1.32 0.095 --- SPIRH6D28220M 22 1.20 0.128 --- SPIRH6D28270M 27 1.05 0.142 --- SPIRH6D28330M 33 0.97 0.165 --- SPIRH6D28390M 39 0.86 0.210 --- SPIRH6D28470M 47 0.80 0.238 --- SPIRH6D28560M 56 0.73 0.277 --- SPIRH6D28680M 68 0.65 0.304 --- 100KHz, 1V SPIRH6D28 ± 20% SPIRH6D28820M 82 0.60 0.390 --- SPIRH6D28101M 100 0.54 0.535 --- 58 100KHz, 1V Rev. 201304 Inductors – SPI (Assembly) DARFON P/N Inductance L (uH) Tolerance Rated current (A) DC Resistance (Ω) ± 20% Marking Measuring Condition SPIRH6D38 SPIRH6D383R3M 3.3 3.50 0.020 --- SPIRH6D385R0M 5.0 2.90 0.024 --- SPIRH6D386R0M 6.0 2.50 0.027 --- SPIRH6D387R3M 7.3 2.30 0.031 --- SPIRH6D388R6M 8.6 2.20 0.034 --- SPIRH6D38100M 10 2.00 0.038 --- SPIRH6D38120M 12 1.70 0.053 --- SPIRH6D38150M 15 1.60 0.057 --- SPIRH6D38180M 18 1.50 0.092 --- 1.30 0.096 --- ± 20% SPIRH6D38220M 22 SPIRH6D38270M 27 1.20 0.109 --- SPIRH6D38330M 33 1.10 0.124 --- SPIRH6D38390M 39 1.00 0.138 --- SPIRH6D38470M 47 0.95 0.155 --- SPIRH6D38560M 56 0.85 0.202 --- SPIRH6D38680M 68 0.75 0.234 --- SPIRH6D38820M 82 0.70 0.324 --- SPIRH6D38101M 100 0.65 0.358 --- 100KHz, 1V SPIRH103R SPIRH103R0R8N 0.8 11.2 0.0057 --- SPIRH103R1R5N 1.5 8.00 0.011 --- SPIRH103R2R2N 2.2 6.70 0.0159 --- SPIRH103R3R3N 3.3 5.56 0.021 --- SPIRH103R4R7N 4.7 4.55 0.030 --- SPIRH103R6R8N 6.8 3.84 0.035 --- SPIRH103R8R0N 8.0 3.54 0.050 --- SPIRH103R100N 10 3.18 0.059 --- SPIRH103R150N 15 2.60 0.091 --- SPIRH103R220N 22 2.16 0.143 --- SPIRH103R330N 33 1.74 0.202 --- SPIRH103R470N 47 1.43 0.299 --- ± 30% 59 100KHz, 1V Rev. 201304 Inductors – SPI (Assembly) DARFON P/N Inductance L (uH) Tolerance Rated current (A) DC Resistance (Ω) ± 20% Marking Measuring Condition SPIRH104R SPIRH104R1R5N 1.5 10.0 0.0081 --- SPIRH104R2R5N 2.5 7.50 0.010 --- SPIRH104R3R8N 3.8 6.00 0.013 --- SPIRH104R4R7N 4.7 5.50 0.022 --- SPIRH104R5R2N 5.2 5.50 0.022 --- SPIRH104R7R0N 7.0 4.80 0.027 --- SPIRH104R100N 10 4.40 0.035 --- SPIRH104R150N 15 3.60 0.050 --- 2.90 0.073 --- ± 30% SPIRH104R220N 22 SPIRH104R330N 33 2.30 0.093 --- SPIRH104R470N 47 2.10 0.128 --- SPIRH104R680N 68 1.50 0.213 --- SPIRH104R101N 100 1.35 0.304 --- SPIRH104R151N 150 1.15 0.506 --- SPIRH104R221N 220 0.92 0.756 --- SPIRH104R331N 330 0.70 1.090 --- 60 100KHz, 1V Rev. 201304 Inductors – SPI (Assembly) ● SPIRD Series DARFON P/N Inductance L (uH) Tolerance Rated current (A) DC Resistance (Ω) ± 20% Marking Measuring Condition SPIRD7015 SPIRD70153R3T 3.3 2.10 0.085 --- SPIRD70154R7T 4.7 1.70 0.115 --- SPIRD70156R8T 6.8 1.45 0.144 --- SPIRD7015100T 10 1.25 0.225 --- SPIRD7015150T 15 1.05 0.290 --- SPIRD7015220T 22 0.85 0.450 --- SPIRD7015470T 47 0.55 0.850 --- SPIRD70282R2T 2.2 4.00 0.028 --- SPIRD70282R7T 2.7 3.60 0.030 --- SPIRD70283R3T 3.3 3.20 0.035 --- SPIRD70284R7T 4.7 2.60 0.045 --- SPIRD70286R8T 6.8 2.20 0.058 --- SPIRD7028100T 10 1.80 0.075 --- SPIRD7028220T 22 1.20 0.180 --- SPIRD7028470T 47 0.90 0.390 --- SPIRD7028680T 68 0.80 0.510 --- ± 25% 100KHz, 1V SPIRD7028 ± 25% 100KHz, 1V SPIRD1015 SPIRD10152R7T 2.7 3.40 0.042 --- SPIRD10153R3T 3.3 3.00 0.057 --- SPIRD10154R7T 4.7 2.60 0.071 --- SPIRD10156R8T 6.8 2.10 0.106 --- SPIRD1015100T 10 1.80 0.140 --- SPIRD1015220T 22 1.20 0.288 --- SPIRD1015470T 47 0.80 0.654 --- SPIRD10243R9T 3.9 3.80 0.036 --- SPIRD10244R7T 4.7 3.60 0.039 --- SPIRD10246R8T 6.8 2.70 0.068 --- SPIRD1024100T 10 2.60 0.082 --- SPIRD1024150T 15 1.70 0.120 --- SPIRD1024220T 22 1.40 0.178 --- SPIRD1024330T 33 1.20 0.252 --- ± 25% 100KHz, 1V SPIRD1024 ± 25% 61 100KHz, 1V Rev. 201304 Inductors-MLCI (IP Series) Multi-Layer Power Inductors (IP Series) ▓Feature ▓Application 1. Small and light weight 2. Low DC resistance DC/DC converter for the Mobile equipment; Mobile Phone, DSC, WLAN ▓Ordering Code IP 2012 1R0 M P S 9 PRODUCT CODE IP : Multilayer Power Inductor (Lead Free) DIMENSION (L X W) Code Dimension EIA 1608 1.6 x 0.80 mm 0603 2012 2.0 X 1.25 mm 0805 2016 2.0 X 1.6 mm 0806 2520 2.5 X 2.0 mm 1008 INDUCTANCE CODE Code R47 1R0 1R5 2R2 3R3 4R7 Inductance 0.47 1.0 1.5 2.2 3.3 4.7 (uH) TOLERANCE CODE M: ±20% PACKAGING CODE T: Paper tape reel P: Embossed reel SPECIFICATION CODE S: Standard L: Light loading current THICKNESS CODE Code Thickness (mm) 5 7 8 9 B 0.5 0.7 0.8 0.9 1.2 62 Rev. 201304 Inductors-MLCI (IP Series) ▓Standard External Dimensions Unit: mm/(inch) Packing Quantity (pcs/reel) Paper Embossed Tape Tape Series L W T A (Min/Max) IP2012 (0805) 2.0±0.2 (0.079±0.008) 1.25±0.2 (0.049±0.008) 0.55 max (0.021max) 0.20/0.80 (0.008/0.032) 4,000 IP2012 (0805) 2.0±0.2 (0.079±0.008) 1.25±0.2 (0.049±0.008) 1.0 max (0.039max) 0.20/0.80 (0.008/0.032) ---- 3,000 IP2016 (0806) 2.0±0.2 (0.079±0.008) 1.6±0.2 (0.063±0.008) 1.0 max (0.039max) 0.20/0.80 (0.008/0.032) ---- 3,000 IP2520 (1008) 2.5±0.2 (0.098±0.008) 2.0±0.2 (0.079±0.008) 1.0 max (0.039max) 0.20/0.80 (0.008/0.032) ---- 3,000 ---- Recommended Pad Dimensions Soldering resist Land Pattern SMD Inductor c b a Size mm (EIA) L x W (mm) a (mm) b (mm) c (mm) 2012 (0805) 2.0 x 1.25 0.8 to 1.2 0.8 to 1.2 0.9 to 1.6 2016 (0806) 2.0 x 1.6 0.8 to 1.2 0.8 to 1.2 0.9 to 1.6 2520 (1008) 2.5 x 2.0 1.0 to 1.4 0.6 to 1.0 63 1.8 to 2.2 Unit: mm/(inch) Rev. 201304 Inductors-MLCI (IP Series) ▓Part Numbers & Characteristic ● IP2012 (EIA 0805) Ordering Code Inductance Inductance [uH] Tolerance Measuring frequency [MHz] DC Resistance [Ω] Rated Current [A] (max.) Saturation Current [A] (max.) 0.12±25% 1.10 0.90 0.19±25% 0.90 0.70 IP2012R47MTS5 0.47 IP20121R0MTS5 1.00 IP20122R2MTS5 2.20 0.34±25% 0.60 0.35 IP2012R47MPS9 0.47 0.09±25% 1.20 1.20 IP20121R0MPS9 1.00 0.11±25% 1.00 1.10 IP20121R5MPS9 1.50 0.13±25% 0.95 0.90 0.17±25% 0.95 0.55 ±20% 1 ±20% 1 IP20122R2MPS9 2.20 IP20123R3MPS9 3.30 0.19±25% 0.80 0.30 IP20124R7MPS9 4.70 0.23±25% 0.80 0.18 IP20124R7MPL9 4.70 1 0.25±25% 0.80 -- 2 0.60±25% 0.50 -- ±20% IP2012100MPL9 Thickness [mm] (max.) 0.55 1.0 1.0 10.0 ● IP2016 (EIA 0806) Ordering Code Measuring Inductance Inductance frequency [uH] Tolerance [MHz] DC Resistance [Ω] Rated Current [A] (max.) IP2016R47MPS9 0.47 0.07±25% 1.60 IP20161R0MPS9 1.00 0.11±25% 1.30 IP20161R5MPS9 1.50 0.12±25% 1.20 0.13±25% 1.20 ±20% 1 Thickness [mm] (max.) 1.0 IP20162R2MPS9 2.20 IP20163R3MPS9 3.30 0.15±25% 1.10 IP20164R7MPS9 4.70 0.18±25% 0.90 DC Resistance [Ω] Rated Current [A] (max.) Saturation Current [A] (max.) 0.06±25% 1.60 0.90 0.07±25% 1.50 0.70 ● IP2520 (EIA 1008) Ordering Code Inductance Inductance [uH] Tolerance Measuring frequency [MHz] IP25201R0MPS9 1.00 IP25201R5MPS9 1.50 IP25202R2MPS9 2.20 0.09±25% 1.30 0.60 IP25204R7MPS9 4.70 0.13±25% 1.10 0.25 ±20% 1 Thickness [mm] (max.) 1.0 ※Rated current specifies that self-heat generation is below 40℃ during DC loaded (at 20℃) ※Saturated current specifies that inductance drop is below 30% during DC loaded (at 20℃) ※Operating temperature range from -55℃ to 125℃. 64 Rev. 201304 Inductors-MLCI (IP Series) ▓Electric Properties DC Bias characteristics Inductance vs Frequency 65 Rev. 201304 Inductors-MLCI (IP Series) ▓Testing Condition & Requirements No. Item Test Condition Requirements Appearance Inductors shall be visually inspected for visible evidence of defect. No harmful defect for piratical use. 2 Inductance a. Temperature: 25+/- 3℃ b. Relative Humidity: 45 to 75%RH c. Measuring equipment:HP4286A、HP4287A Measuring Jig: HP42851-61100 Within specified tolerance. 3 DC Resistance Measuring instrument: HP4338B、HIOKI IM-3570 In accordance with electrical specification. 4 Dimension Dimension shall be measured with caliper or micrometer In accordance with dimension specification. 5 Solder-ability Immerse a test sample into a methanol solution containing rosin and 90% of the termination is to be immerse into SAC305(Sn96.5Ag3.0Cu0.5) solder of 245±5℃ for soldered evenly and continuously. 3±1 seconds. Resistance to Soldering Heat Immerse a test sample into a methanol solution containing resin, preheat it at 150 to 180℃ for 2~3 minutes and immerse into molten solder of 260+/-5℃ for 10+/-1 second so that both terminal electrodes are completely submerged. After this test samples shall be taken out and measured after kept at room temperature for 2 to 3 hours. 1 6 No visible damage Remained terminal electrode : 70% min. Inductance variation within 30% Solder the chip to test jig then apply a force in the direction shown in below. The soldering shall be done with the reflow method and shall be conducted with care so that the soldering is uniform and free of defects such as heat shock. 4.5 b 20 50 Pressurizing speed : 1.0mm/sec. Pressurize 40 c 7 Bending Strength R230 a Capacitance Meter 100 t :1.6mm(0.8mm for 0603&1005 size) Fig. a. Size 1608 2012 2016 2520 8 Thermal Shock a 1.0 1.2 b 3.0 4.0 45 Flexure : 1mm No mechanical damage shall be observed. 45 Fig. b. C 1.2 1.65 Solder a test sample to printed circuit board, and conduct 5 cycles of test under the conditions shown as below. Condition for 1 cycle Step1:-55+0 / -2℃ 30±3 min. Step2:Room temperature within 2 to 3 min. Step3:+125 +2 / -0℃ 30±3 min. Measured at room temperature after placing for 2 to 3 hrs. 66 No visible damage Inductance variation within 30% Rev. 201304 Inductors-MLCI (IP Series) No. 9 11 12 13 Item Test Condition Requirements High Humidity State Life Test Keep a test sample in an atmosphere with a temperature of 40±2℃, 90~95%RH for 500 +24/-0 hours. After the removal from test chamber, 2 to 3 hours of No visible damage. Inductance variation within 30%. recovery under standard condition, and measurement shall be made after 24±2 hrs of recovery under standard condition. High Humidity Load Life Test Solder a test sample to printed circuit board then keep the test sample in an atmosphere with a temperature of 40±2℃, 90~95%RH for 500+24/-0 hours while supplying the rated current. No visible damage. Inductance variation within 30%. After the removal from test chamber, 2 to 3 hours of recovery under standard condition, and measurement shall be made after 24±2 hrs of recovery under standard condition. High Temperature State Life Test Keep a test sample in an atmosphere with a temperature of 85±2℃ for 500+24/-0 hours. After the removal from No visible damage. test chamber, 2 to 3 hours of recovery under standard Inductance variation within 30%. condition, and measurement shall be made after 24±2 hrs of recovery under standard condition. High Temperature Load Solder a test sample to printed circuit board then keep the test sample in an atmosphere with a temperature of 85±2℃ for 500+24/-0 hours while supplying the rated current. No visible damage. Inductance variation within 30%. After the removal from test chamber, 2 to 3 hours of recovery under standard condition, and measurement shall be made after 24±2 hrs of recovery under standard condition. 67 Rev. 201304 Inductors-MLCI (HI Series) Multi-Layer High Frequency Inductors (HI Series) ▓Feature ▓Application 1. For high frequency application 2. Tight tolerance physical dimensions 3. Tight Inductance tolerance, Excellent Q and Guaranteed SRF range For high frequency application: cellular phone, WLAN, PHS, EMI countermeasure in high frequency circuits and computer communication etc. ▓Ordering Code HI 1005 1N5 S T PRODUCT CODE HI : High Frequency Inductor (Lead Free) DIMENSION (L X W) Code Dimension EIA 0603 0.6 X 0.3 mm 0201 1005 1.0 X 0.5 mm 0402 1608 1.6 X 0.8 mm 0603 INDUCTANCE CODE Code 1N5 15N R15 Inductance 1.5 (nH) 15 150 TOLERANCE CODE D = ± 0.1 nH C = ± 0.2 nH S = ± 0.3 nH G = ± 2% H= ± 3% J= ± 5% K = ± 10% PACKAGING CODE T = Tape 68 Rev. 201304 Inductors-MLCI (HI Series) ▓Standard External Dimensions Unit: mm/(inch) Series HI0603 (0201) HI1005 (0402) HI1608 (0603) L W 0.60±0.03 (0.024±0.001) 1.00±0.10 (0.040±0.004) 1.60±0.15 (0.063±0.006) T 0.30±0.03 (0.012±0.001) 0.50±0.10 (0.020±0.004) 0.80±0.15 (0.031±0.006) Packing Quantity (pcs/reel) A (Min/Max) 0.30±0.03 (0.012±0.001) 0.50±0.10 (0.020±0.004) 0.80±0.15 (0.031±0.006) Paper Tape 0.10/0.20 (0.004/0.008) 0.10/0.30 (0.004/0.012) 0.20/0.60 (0.008/0.024) 15,000 10,000 4,000 Recommended Pad Dimensions Soldering resist Land Pattern SMD Inductor c b a Size mm (EIA) L x W (mm) a (mm) b (mm) c (mm) 0603 (0201) 0.6*0.3 0.15 to 0.35 0.2 to 0.3 0.25 to 0.3 1005 (0402) 1.0*0.5 0.3 to 0.5 0.35 to 0.45 0.4 to 0.5 1608 (0603) 1.6*0.8 0.7 to 1.0 0.6 to 0.8 0.7 to 0.8 ▓Available Inductance Value Series HI0603 HI1005 HI1608 EIA Size 0201 0402 0603 Available Inductance 0.3nH~100nH 0.6nH~270nH 1nH~470nH 69 Rev. 201304 Inductors-MLCI (HI Series) ▓Part Numbers & Characteristic ● HI0603 series (EIA 0201) Inductance Ordering Code (nH) Available Tolerance Q L, Q Measuring Frequency Self-Resonance Frequency (MHz) DC Resistance (Ω) Rated Packing Current Amount of (mA) 7” reel HI06030N3□T 0.3 ±0.1nH Min. 4 (MHz) 100 Min. 10,000 typ. >13000 Max. 0.07 typ. 0.03 Max. 250 HI06030N4□T 0.4 ±0.1nH 4 100 10,000 >13000 0.07 0.04 250 HI06030N5□T 0.5 ±0.1nH 4 100 10,000 >13000 0.08 0.05 250 HI06030N6□T 0.6 ±0.1nH 4 100 10,000 >13000 0.08 0.05 250 HI06030N7□T 0.7 ±0.1nH 4 100 10,000 >13000 0.09 0.06 250 HI06030N8□T 0.8 ±0.1nH 4 100 10,000 >13000 0.10 0.07 250 HI06030N9□T 0.9 ±0.1nH 4 100 10,000 >13,000 0.10 0.07 250 HI06031N0□T 1.0 ±0.3nH, ±0.1nH 4 100 10,000 >13,000 0.14 0.09 250 HI06031N1□T 1.1 ±0.3nH, ±0.2nH, ±0.1nH 4 100 10,000 >13,000 0.14 0.09 250 HI06031N2□T 1.2 ±0.3nH, ±0.2nH, ±0.1nH 4 100 10,000 >13,000 0.14 0.09 250 HI06031N3□T 1.3 ±0.3nH, ±0.2nH, ±0.1nH 4 100 10,000 >13,000 0.14 0.10 250 HI06031N5□T 1.5 ±0.3nH, ±0.2nH, ±0.1nH 4 100 10,000 >13,000 0.18 0.10 230 HI06031N6□T 1.6 ±0.3nH, ±0.2nH, ±0.1nH 4 100 10,000 >13,000 0.18 0.12 230 HI06031N8□T 1.8 ±0.3nH, ±0.2nH, ±0.1nH 4 100 10,000 >13,000 0.19 0.13 200 HI06032N0□T 2.0 ±0.3nH, ±0.2nH, ±0.1nH 4 100 8,800 >13,000 0.20 0.14 200 HI06032N1□T 2.1 ±0.3nH, ±0.2nH, ±0.1nH 4 100 8,800 >13,000 0.20 0.15 200 HI06032N2□T 2.2 ±0.3nH, ±0.2nH, ±0.1nH 4 100 8,800 >13,000 0.22 0.15 200 HI06032N4□T 2.4 ±0.3nH, ±0.2nH, ±0.1nH 4 100 8,300 11,700 0.24 0.15 200 HI06032N7□T 2.7 ±0.3nH, ±0.2nH, ±0.1nH 5 100 7,700 11,340 0.25 0.17 200 HI06033N0□T 3.0 ±0.3nH, ±0.2nH, ±0.1nH 5 100 7,200 11,000 0.28 0.20 180 HI06033N2□T 3.2 ±0.3nH, ±0.2nH, ±0.1nH 5 100 6,700 10,800 0.30 0.20 180 HI06033N3□T 3.3 ±0.3nH, ±0.2nH, ±0.1nH 5 100 6,700 10,400 0.30 0.20 180 HI06033N6□T 3.6 ±0.3nH, ±0.2nH, ±0.1nH 5 100 6,400 9,000 0.30 0.23 170 HI06033N9□T 3.9 ±0.3nH, ±0.2nH, ±0.1nH 5 100 6,000 8,790 0.30 0.23 170 HI06034N3□T 4.3 ±0.3nH, ±3%, ±0.1nH 5 100 5,700 8,000 0.40 0.24 150 HI06034N7□T 4.7 ±0.3nH, ±3%, ±0.1nH 5 100 5,300 7,750 0.40 0.26 150 HI06035N1□T 5.1 ±0.3nH, ±3%, ±0.1nH 5 100 5,000 7,210 0.40 0.26 150 HI06035N6□T 5.6 ±0.3nH, ±3%, ±0.1nH 5 100 4,200 6,680 0.40 0.32 150 HI06036N2□T 6.2 ±0.3nH, ±3%, ±0.1nH 5 100 3,800 6,800 0.44 0.32 150 HI06036N8□T 6.8 ±5%, ±3% 5 100 3,500 6,800 0.50 0.34 150 HI06037N5□T 7.5 ±5%, ±3% 5 100 3,300 6,000 0.53 0.36 150 HI06038N2□T 8.2 ±5%, ±3% 5 100 3,200 5,800 0.55 0.38 150 HI06039N1□T 9.1 ±5%, ±3% 5 100 3,000 5,000 0.62 0.38 150 HI060310N□T 10 ±5%, ±3% 5 100 2,800 4,860 0.65 0.40 150 HI060312N□T 12 ±5%, ±3% 5 100 2,400 4,520 0.70 0.50 100 HI060315N□T 15 ±5%, ±3% 5 100 2,200 4,820 0.80 0.60 100 HI060318N□T 18 ±5%, ±3% 5 100 2,200 3,000 0.90 0.85 100 HI060322N□T 22 ±5%, ±3% 5 100 1,800 2,950 1.20 0.86 100 HI060327N□T 27 ±5%, ±3% 4 100 1,800 2,610 1.80 0.88 50 HI060333N□T 33 ±5% 4 100 1,700 2,210 2.10 1.05 50 HI060339N□T 39 ±5% 4 100 1,500 1,860 2.40 1.18 50 HI060347N□T 47 ±5% 4 100 1,300 1,800 2.80 1.74 100 HI060356N□T 56 ±5% 4 100 1,100 1,600 3.00 1.85 80 HI060368N□T 68 ±5% 4 100 1,100 1,500 2.66 2.30 80 HI060382N□T 82 ±5% 4 100 1,000 1,400 3.37 2.60 70 HI0603R10□T 100 ±5% 4 100 900 1,200 3.74 3.00 60 Pcs 15,000 □ Tolerance: D=±0.1nH, C=±0.2nH ,S=±0.3nH, G=±2%, H=±3%, J=±5%, K=±10% ※ Operating Temperature range: -55 ℃ to +125 ℃ 70 Rev. 201304 Inductors-MLCI (HI Series) L,Q vs. Frequency Characteristics Ordering Code HI06030N3□T HI06030N4□T HI06030N5□T HI06030N6□T HI06030N7□T HI06030N8□T HI06030N9□T HI06031N0□T HI06031N1□T HI06031N2□T HI06031N3□T HI06031N5□T HI06031N6□T HI06031N8□T HI06032N0□T HI06032N1□T HI06032N2□T HI06032N4□T HI06032N7□T HI06033N0□T HI06033N2□T HI06033N3□T HI06033N6□T HI06033N9□T HI06034N3□T HI06034N7□T HI06035N1□T HI06035N6□T HI06036N2□T HI06036N8□T HI06037N5□T HI06038N2□T HI06039N1□T HI060310N□T HI060312N□T HI060315N□T HI060318N□T HI060322N□T HI060327N□T HI060333N□T HI060339N□T HI060347N□T HI060356N□T HI060368N□T HI060382N□T HI0603R10□T 100 MHz 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 1.3 1.5 1.6 1.8 2.0 2.1 2.2 2.4 2.7 3.0 3.2 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 10.0 12.0 15.0 18.0 22.0 27.0 33.0 39.0 47.0 56.0 68.0 82.0 100.0 500 MHz 0.3 0.4 0.5 0.6 0.7 0.8 0.8 0.9 1.0 1.2 1.2 1.4 1.6 1.7 1.9 2.0 2.1 2.3 2.5 2.8 3.0 3.2 3.4 3.7 4.1 4.4 4.9 5.3 6.0 6.3 7.1 7.8 8.7 9.3 11.3 14.5 17.2 21.4 26.6 31.9 38.2 44.0 54.0 66.0 80.0 103.0 Typical Inductance(nH) Typical Q 800 900 1.8 2.0 2.4 100 500 800 900 1.8 2.0 2.4 MHz MHz GHz GHz GHz MHz MHz MHz MHz GHz GHz GHz 0.3 0.3 0.3 0.3 0.3 6 14 19 20 32 35 39 0.4 0.4 0.4 0.4 0.4 6 14 19 20 32 35 39 0.5 0.5 0.5 0.5 0.5 6 14 19 20 33 36 40 0.5 0.5 0.5 0.5 0.5 6 15 19 20 33 36 40 0.6 0.6 0.6 0.6 0.6 6 15 20 21 34 37 41 0.7 0.7 0.7 0.7 0.7 6 14 19 20 32 35 39 0.8 0.8 0.8 0.8 0.8 6 15 20 21 35 37 42 0.9 0.9 0.9 0.9 0.9 5 13 17 18 28 30 33 1.0 1.0 0.9 0.9 0.9 6 14 18 20 30 32 34 1.2 1.2 1.2 1.2 1.2 6 14 18 19 28 30 32 1.2 1.2 1.2 1.2 1.2 6 13 17 18 27 28 31 1.3 1.3 1.4 1.4 1.4 6 14 18 20 30 32 34 1.6 1.6 1.6 1.6 1.6 6 14 18 20 28 30 31 1.7 1.7 1.7 1.7 1.7 6 14 18 20 28 30 31 1.9 1.9 2.0 1.9 2.0 6 14 18 19 28 29 31 1.9 1.9 2.0 2.0 2.1 6 13 17 18 26 28 30 2.0 2.0 2.1 2.1 2.2 6 13 17 18 26 28 30 2.2 2.2 2.3 2.4 2.5 6 14 18 20 28 29 31 2.5 2.5 2.6 2.7 2.8 6 14 18 19 28 29 31 2.8 2.8 2.9 2.9 3.0 7 15 19 21 30 31 33 3.0 3.0 3.1 3.1 3.2 6 14 19 20 29 30 32 3.1 3.2 3.0 3.4 3.5 6 14 19 20 29 30 32 3.4 3.4 3.7 3.7 3.9 6 14 18 20 28 29 31 3.7 3.7 3.9 4.0 4.2 6 15 19 20 28 29 31 4.1 4.1 4.4 4.9 4.8 6 14 18 19 27 28 29 4.4 4.4 4.8 4.9 5.2 6 14 19 19 26 27 29 4.9 4.9 5.4 5.6 6.0 6 13 17 18 25 25 26 5.3 5.3 5.8 6.0 6.6 7 14 18 19 26 27 27 6.0 6.1 6.9 7.2 8.1 6 14 18 19 26 26 30 6.4 6.4 7.2 7.4 8.2 7 14 18 19 26 26 26 7.2 7.2 8.3 8.7 9.8 6 15 18 20 25 25 25 7.9 8.0 9.2 9.7 11.0 7 15 18 19 19 24 24 8.8 8.9 10.8 11.6 13.9 6 13 16 17 21 20 18 9.5 9.6 12.0 13.0 16.1 6 13 16 17 20 20 18 11.5 11.7 15.4 17.2 23.2 7 13 16 17 18 17 14 15.1 15.4 22.4 26.2 42.3 7 15 18 19 19 17 11 18.1 18.6 31.1 39.5 99.3 7 13 16 16 14 11 5 22.8 23.5 45.5 64.1 7 13 16 16 12 8 29.2 30.6 108.5 6 13 15 15 6 34.8 36.0 119.0 7 14 16 17 6 42.3 45.6 6 12 13 13 47.0 49.0 6 11 12 11 61.0 66.0 6 11 11 10 76.0 82.0 6 11 11 10 97.0 108.0 6 11 10 8 138.0 164.0 6 10 9 6 - Typical Electrical Characteristic 45  30  20  Q Inductance (nH) 35  25  15  6N8 25  20  15  10  5  0  10  100  1,000  Frequency (MHz) 0603 L vs Frequency 6N8 10  1N5 5  10,000  10000  1N5 40  22N 30  22N 0  10  100  1,000  Frequency (MHz) 0603 Q vs Frequency 71 10,000  22N Impedance (ohm) 35  1000  6N8 100  1N5 10  1  0  10  100  1,000  10,000  Frequency (MHz) 0603 Z vs Frequency Rev. 201304 Inductors-MLCI (HI Series) ● HI1005 series (EIA 0402) Inductance Ordering Code (nH) Available Tolerance Q L, Q Measuring Frequency Self-Resonance Frequency (MHz) DC Resistance (Ω) Rated Packing Current Amount of (mA) 7” reel HI10050N6□T HI10051N0□T 0.6 1.0 ±0.1nH ±0.3nH, ±0.2nH, ±0.1nH Min. 8 8 (MHz) 100 100 Min. 10,000 10,000 typ. >13,000 >13,000 Max. 0.08 0.08 typ. 0.02 0.02 Max. 1000 1000 HI10051N1□T 1.1 ±0.3nH, ±0.2nH, ±0.1nH 8 100 10,000 >13,000 0.08 0.03 1000 HI10051N2□T 1.2 ±0.3nH, ±0.2nH, ±0.1nH 8 100 10,000 >13,000 0.09 0.03 1000 HI10051N3□T 1.3 ±0.3nH, ±0.2nH, ±0.1nH 8 100 10,000 >13,000 0.09 0.04 1000 HI10051N5□T 1.5 ±0.3nH, ±0.2nH, ±0.1nH 8 100 10,000 >13,000 0.10 0.05 1000 HI10051N6□T 1.6 ±0.3nH, ±0.2nH, ±0.1nH 8 100 10,000 >13,000 0.10 0.05 1000 HI10051N8□T 1.8 ±0.3nH, ±0.2nH, ±0.1nH 8 100 6,000 12,220 0.12 0.05 900 HI10052N0□T 2.0 ±0.3nH, ±0.2nH, ±0.1nH 8 100 6,000 12,890 0.12 0.06 900 HI10052N2□T 2.2 ±0.3nH, ±0.2nH, ±0.1nH 8 100 6,000 12,430 0.13 0.06 900 HI10052N4□T 2.4 ±0.3nH, ±0.2nH, ±0.1nH 8 100 6,000 12,320 0.13 0.07 800 HI10052N7□T 2.7 ±0.3nH, ±0.2nH, ±0.1nH 8 100 6,000 10,070 0.16 0.09 800 HI10053N0□T 3.0 ±0.3nH, ±0.2nH, ±0.1nH 8 100 6,000 8,760 0.16 0.09 800 HI10053N3□T 3.3 ±0.3nH, ±0.2nH, ±0.1nH 8 100 6,000 8,120 0.16 0.09 800 HI10053N6□T 3.6 ±0.3nH, ±0.2nH, ±0.1nH 8 100 5,000 8,200 0.20 0.10 700 HI10053N9□T 3.9 ±0.3nH, ±0.2nH, ±0.1nH 8 100 4,000 8,390 0.20 0.10 700 HI10054N3□T 4.3 ±0.3nH, ±0.2nH, ±0.1nH 8 100 4,000 7,500 0.20 0.11 700 HI10054N7□T 4.7 ±0.3nH, ±0.2nH, ±0.1nH 8 100 4,000 7,010 0.20 0.11 700 HI10055N1□T 5.1 ±0.3nH, ±0.2nH, ±0.1nH 8 100 4,000 6,340 0.23 0.13 600 HI10055N6□T 5.6 ±0.3nH, ±0.2nH, ±0.1nH 8 100 4,000 5,760 0.23 0.13 600 HI10056N2□T 6.2 ±0.3nH, ±0.2nH, ±0.1nH 8 100 3,900 5,490 0.25 0.15 600 HI10056N8□T 6.8 ±5%,±3%, ±2% 8 100 3,900 5,430 0.25 0.14 600 HI10057N5□T 7.5 ±5%,±3%, ±2% 8 100 3,700 5,000 0.28 0.16 500 HI10058N2□T 8.2 ±5%,±3%, ±2% 8 100 3,500 4,660 0.28 0.17 500 HI10059N1□T 9.1 ±5%,±3%, ±2% 8 100 3,400 4,400 0.30 0.22 500 HI100510N□T 10 ±5%,±3%, ±2% 8 100 3,200 4,120 0.31 0.24 500 HI100512N□T 12 ±5%,±3%, ±2% 8 100 2,600 3,820 0.45 0.30 400 HI100515N□T 15 ±5%,±3%, ±2% 8 100 2,300 3,350 0.55 0.38 400 HI100518N□T 18 ±5%,±3%, ±2% 8 100 2,000 2,970 0.65 0.37 300 HI100522N□T 22 ±5%,±3%, ±2% 8 100 1,600 2,640 0.70 0.45 300 HI100524N□T 24 ±5%,±3%, ±2% 8 100 1,400 2,450 0.80 0.48 300 HI100527N□T 27 ±5%,±3%, ±2% 8 100 1,400 2,370 0.80 0.49 300 HI100533N□T 33 ±5%,±3%, ±2% 8 100 1,200 2,040 0.90 0.63 200 HI100539N□T 39 ±5%,±3%, ±2% 8 100 1,100 1,800 1.00 0.70 200 HI100547N□T 47 ±5%,±3%, ±2% 8 100 900 1,660 1.10 0.82 200 72 Pcs 10,000 Rev. 201304 Inductors-MLCI (HI Series) Inductance Ordering Code (nH) Available Tolerance Q L, Q Measuring Frequency Self-Resonance Frequency (MHz) DC Resistance (Ω) Rated Packing Current Amount of (mA) 7” reel Min. (MHz) Min. typ. Max. typ. Max. HI100556N□T 56 ±5%,±3%, ±2% 8 100 750 1,560 1.10 0.84 200 HI100568N□T 68 ±5%,±3%, ±2% 8 100 750 1,330 1.20 0.99 180 HI100582N□T 82 ±5%,±3% 8 100 600 1,160 1.30 1.09 150 HI1005R10□T 100 ±5% 8 100 600 1,020 1.60 1.19 150 HI1005R12□T 120 ±5% 8 100 600 860 1.60 1.31 150 HI1005R15□T 150 ±5% 8 100 550 800 2.40 1.58 140 HI1005R18□T 180 ±5% 8 100 500 810 3.70 2.97 130 HI1005R22□T 220 ±5% 8 100 450 700 4.20 3.29 120 HI1005R27□T 270 ±5% 8 100 400 600 4.80 3.92 110 ※ Pcs 10,000 □ Tolerance: D=±0.1nH, C=±0.2nH ,S=±0.3nH, G=±2%, H=±3%, J=±5%, K=±10% ※ Operating Temperature range: -55 ℃ to +125 ℃ 73 Rev. 201304 Inductors-MLCI (HI Series) L,Q vs. Frequency Characteristics Ordering Code HI10050N6□T HI10051N0□T HI10051N1□T HI10051N2□T HI10051N3□T HI10051N5□T HI10051N6□T HI10051N8□T HI10052N0□T HI10052N2□T HI10052N4□T HI10052N7□T HI10053N0□T HI10053N3□T HI10053N6□T HI10053N9□T HI10054N3□T HI10054N7□T HI10055N1□T HI10055N6□T HI10056N2□T HI10056N8□T HI10057N5□T HI10058N2□T HI10059N1□T HI100510N□T HI100512N□T HI100515N□T HI100518N□T HI100522N□T HI100527N□T HI100533N□T HI100539N□T HI100547N□T HI100556N□T HI100568N□T HI100582N□T HI1005R10□T HI1005R12□T HI1005R15□T HI1005R18□T HI1005R22□T HI1005R27□T 100 MHz 0.6 1.0 1.1 1.2 1.3 1.5 1.6 1.8 2.0 2.2 2.4 2.7 3.0 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 10.0 12.0 15.0 18.0 22.0 27.0 33.0 39.0 47.0 56.0 68.0 82.0 100.0 120.0 150.0 180.0 220.0 270.0 500 MHz 0.6 1.0 1.1 1.2 1.3 1.5 1.5 1.7 2.0 2.1 2.3 2.7 2.9 3.2 3.5 3.7 4.1 4.5 4.9 5.5 6.1 6.6 7.1 8.0 8.7 10.0 11.7 14.9 17.8 21.8 27.1 33.2 40.2 49.1 59.2 74.7 94.7 117.6 159.8 207.2 - Typical Inductance(nH) 800 900 1.8 MHz MHz GHz 0.6 0.6 0.6 1.0 1.0 1.0 1.1 1.1 1.1 1.2 1.2 1.2 1.3 1.3 1.3 1.5 1.5 1.5 1.5 1.5 1.5 1.7 1.7 1.7 2.0 2.0 2.0 2.1 2.1 2.2 2.3 2.3 2.4 2.7 2.7 2.8 2.9 3.0 3.1 3.2 3.2 3.4 3.5 3.5 3.7 3.7 3.8 3.9 4.2 4.2 4.4 4.5 4.5 4.8 4.9 4.9 5.2 5.5 5.5 6.0 6.1 6.1 6.7 6.7 6.7 7.4 7.2 7.3 7.8 8.1 8.2 9.4 8.8 8.8 9.9 9.8 9.9 11.7 12.0 12.2 15.1 15.5 15.8 22.8 18.4 18.7 24.9 23.1 23.8 40.9 29.2 30.3 66.8 36.3 37.9 109.0 45.9 49.1 57.2 61.7 71.8 79.3 99.4 116.3 140.8 179.5 193.7 269.9 450.4 - 2.0 GHz 0.6 1.0 1.1 1.2 1.3 1.5 1.5 1.7 2.1 2.2 2.4 2.8 3.1 3.4 3.8 4.0 4.4 4.9 5.3 6.2 6.8 7.6 8.1 9.9 10.2 12.4 16.3 26.4 27.7 52.7 106.9 259.0 - Typical Q 2.4 100 500 800 900 1.8 2.0 2.4 GHz MHz MHz MHz MHz GHz GHz GHz 0.6 12 40 60 65 100 120 140 1.0 12 29 38 41 63 71 75 1.1 11 29 37 40 60 67 72 1.2 11 29 38 41 61 68 73 1.3 11 30 38 41 61 67 72 1.5 11 27 35 38 57 63 68 1.5 11 28 35 38 57 64 68 1.8 11 26 33 36 53 58 61 2.1 10 23 29 31 45 49 52 2.2 10 24 31 33 48 52 55 2.4 10 25 31 34 49 53 57 2.9 11 27 35 37 54 58 60 3.2 10 25 32 34 49 53 55 3.5 11 25 32 35 50 54 56 3.9 10 24 31 33 46 49 49 4.1 11 24 30 33 46 49 51 4.6 11 26 33 35 50 53 54 5.1 11 25 32 35 49 51 53 5.6 11 25 32 35 46 48 49 6.7 11 25 32 35 46 48 49 7.3 11 26 32 34 46 48 49 8.2 11 26 32 35 46 48 48 8.8 11 26 32 35 46 48 48 26 32 34 11.1 11 42 42 40 25 31 34 11.1 11 42 42 40 23 29 31 14.4 11 37 37 34 24 31 33 20.1 11 37 36 30 23 30 32 41.8 11 35 33 28 23 28 29 37.7 11 30 28 22 22 27 28 156.0 11 22 18 6 11 22 26 27 16 11 4 11 22 25 26 12 5 11 20 22 22 11 20 21 21 11 19 19 18 11 18 17 15 11 18 15 12 11 17 12 9 11 16 7 11 14 12 12 12 - R10 10,000  40  56N 35  33N 30  Impedance (ohm) 500  450  400  350  300  250  200  150  100  50  0  33N 25  Q Inductance (nH) Typical Electrical Characteristic 56N 20  15  10  15N 5  R10 0  10  100  1,000  Frequency (MHz) 1005 L vs Frequency 10,000  10  100  1,000  Frequency (MHz) 1005 Q vs Frequency 74 1,000  100  R10 56N 10  33N 15N 15N 1  10,000  1  10  100  1,000  10,000  Frequency (MHz) 1005 Z vs Frequency Rev. 201304 Inductors-MLCI (HI Series) ● HI1608 series (EIA 0603) Inductance Ordering Code (nH) Available Tolerance Q L, Q Measuring Frequency Self-Resonance Frequency (MHz) DC Resistance (Ω) Packing Rated Current Amount of 7” reel (mA) Min. (MHz) Min. typ. Max. typ. Max. HI16081N0□T 1.0 ±0.3nH, ±0.1nH 8 100 10,000 >13,000 0.05 0.01 1,000 HI16081N2□T 1.2 ±0.3nH, ±0.1nH 8 100 10,000 >13,000 0.05 0.02 1,000 HI16081N5□T 1.5 ±0.3nH, ±0.1nH 8 100 10,000 >13,000 0.10 0.03 1,000 HI16081N8□T 1.8 ±0.3nH, ±0.1nH 8 100 10,000 >13,000 0.10 0.04 1,000 HI16082N2□T 2.2 ±0.3nH, ±0.1nH 8 100 6,000 11,690 0.10 0.05 1,000 HI16082N7□T 2.7 ±0.3nH, ±0.1nH 10 100 6,000 8,930 0.13 0.06 1,000 HI16083N3□T 3.3 ±0.3nH, ±0.1nH 10 100 6,000 6,440 0.13 0.07 1,000 HI16083N9□T 3.9 ±0.3nH, ±0.1nH 10 100 6,000 7,280 0.15 0.08 1,000 HI16084N7□T 4.7 ±0.3nH, ±0.1nH 10 100 4,000 6,470 0.20 0.09 1,000 HI16085N6□T 5.6 ±0.3nH, ±0.1nH 10 100 4,000 5,230 0.23 0.10 600 HI16086N8□T 6.8 ±5%, ±2% 10 100 4,000 5,470 0.25 0.11 600 HI16088N2□T 8.2 ±5%, ±2% 10 100 3,500 4,460 0.28 0.14 600 HI160810N□T 10 ±5%, ±2% 12 100 3,200 4,360 0.30 0.15 600 HI160812N□T 12 ±5%, ±2% 12 100 2,600 3,480 0.35 0.17 600 HI160815N□T 15 ±5%, ±2% 12 100 2,300 3,310 0.40 0.19 600 HI160818N□T 18 ±5%, ±2% 12 100 2,000 3,080 0.45 0.21 600 HI160822N□T 22 ±5%, ±2% 12 100 1,600 2,670 0.50 0.29 600 HI160827N□T 27 ±5%, ±2% 12 100 1,400 2,270 0.55 0.27 600 HI160833N□T 33 ±5%, ±2% 12 100 1,200 1,970 0.60 0.36 600 HI160839N□T 39 ±5%, ±2% 12 100 1,100 1,830 0.65 0.37 500 HI160847N□T 47 ±5%, ±2% 12 100 900 1,670 0.70 0.47 500 HI160856N□T 56 ±5%, ±2% 12 100 900 1,530 0.75 0.46 500 HI160868N□T 68 ±5%, ±2% 12 100 700 1,360 0.85 0.51 400 HI160882N□T 82 ±5%, ±2% 12 100 600 1,290 0.95 0.57 300 HI1608R10□T 100 ±5%, ±2% 12 100 600 1,090 1.00 0.69 300 HI1608R12□T 120 ±5%, ±2% 8 50 500 1,030 1.20 0.74 300 HI1608R15□T 150 ±5%, ±2% 8 50 500 820 1.20 0.78 300 HI1608R18□T 180 ±5%, ±2% 8 50 400 690 1.30 0.92 300 HI1608R22□T 220 ±5%, ±2% 8 50 400 630 1.50 1.19 300 HI1608R27□T 270 ±5%, ±2% 8 50 400 520 1.90 1.19 150 HI1608R33□T 330 ±5%, ±2% 8 50 350 450 2.10 1.50 150 HI1608R39□T 390 ±5%, ±2% 8 50 350 400 2.30 1.80 150 HI1608R47□T 470 ±5%, ±2% 8 50 300 360 2.60 2.04 150 ※ Pcs 4,000 □ Tolerance: D=±0.1nH, C=±0.2nH ,S=±0.3nH, G=±2%, J=±5%, K=±10% ※ Operating Temperature range: -40 ℃ to +85 ℃ 75 Rev. 201304 Inductors-MLCI (HI Series) L,Q vs. Frequency Characteristics Typical Inductance(nH) Ordering Code HI16081N0□T HI16081N2□T HI16081N5□T HI16081N8□T HI16082N2□T HI16082N7□T HI16083N3□T HI16083N9□T HI16084N7□T HI16085N6□T HI16086N8□T HI16088N2□T HI160810N□T HI160812N□T HI160815N□T HI160818N□T HI160822N□T HI160827N□T HI160833N□T HI160839N□T HI160847N□T HI160856N□T HI160868N□T HI160882N□T HI1608R10□T HI1608R12□T HI1608R15□T HI1608R18□T HI1608R22□T HI1608R24□T HI1608R27□T HI1608R33□T HI1608R39□T HI1608R47□T Typical Q 100MH 500MH 800MH 900MH 1.8GHz 2.0GHz 2.4GHz 100MH 500MH 800MH 900MH 1.8GHz 2.0GHz 2.4GHz 14 40 53 60 1.0 1.1 1.1 1.1 1.1 1.1 1.0 93 32 174 14 38 49 54 1.2 1.2 1.2 1.2 1.2 1.2 1.1 84 32 143 12 31 39 43 1.5 1.6 1.6 1.6 1.6 1.5 1.5 62 33 88 13 34 42 46 1.8 1.8 1.8 1.8 1.8 1.8 1.7 68 37 97 14 36 46 50 2.2 2.2 2.2 2.2 2.2 2.2 2.2 73 42 101 14 36 47 45 2.7 2.7 2.7 2.7 2.7 2.7 2.7 72 45 94 14 37 47 50 3.3 3.3 3.3 3.3 3.5 3.5 3.6 67 47 77 15 36 46 49 3.9 3.9 3.9 3.9 4.0 4.0 4.1 66 48 81 15 39 50 53 4.7 4.6 4.6 4.7 4.9 4.9 5.1 70 53 80 15 39 50 54 5.6 5.5 5.6 5.6 6.1 6.3 6.7 67 52 69 15 38 49 52 6.8 6.7 6.7 6.8 7.3 7.5 7.9 66 53 66 16 37 48 50 8.2 8.1 8.2 8.3 9.5 9.9 11.0 59 49 54 16 39 49 52 10.0 9.9 10.1 10.2 11.7 12.3 13.9 60 50 52 16 36 46 48 12.0 12.2 12.6 12.8 16.6 18.4 24.4 47 39 31 17 40 50 52 15.0 15.1 15.6 15.9 21.0 23.4 31.9 49 41 31 17 39 48 50 18.0 18.1 18.9 19.3 27.7 32.2 52.2 43 35 21 17 39 46 47 22.0 22.3 23.8 24.6 45.7 63.5 521.1 29 19 1 18 39 45 46 27.0 27.8 30.3 31.6 85.8 191.2 19 8 18 39 43 43 33.0 34.9 38.8 40.9 19 36 39 37 39.0 41.3 47.7 51.2 17 34 36 34 47.0 50.0 58.9 64.0 19 35 34 31 56.0 62.0 77.7 87.5 18 33 29 25 68.0 76.8 103.2 121.7 19 32 25 20 82.0 96.5 145.3 187.2 18 30 19 12 100.0 123.7 222.4 343.5 19 28 14 120.0 156.0 355.0 18 21 150.0 227.9 17 17 180.0 336.8 16 13 220.0 520.7 16 240.0 16 270.0 14 330.0 14 390.0 13 470.0 - Typical Electrical Characteristic 1600 10000 1200 1000 40 56N 800 600 33N 400 200 15N 0 Impedance (ohm) 50 Q Inductance (nH) 60 R22 1400 30 20 10 R22 56N 0 10 100 1,000 10,000 Frequency (MHz) 1608 L vs Frequency 10 15N 1000 R22 56N 100 10 15N 33N 100 1,000 10,000 Frequency (MHz) 1608 Q vs Frequency 76 33N 1 10 100 1,000 10,000 Frequency (MHz) 1608 Z vs Frequency Rev. 201304 Inductors-MLCI (HI Series) ▓Testing Condition & Requirements No. 1 Item Appearance Test Condition Requirements Inductors shall be visually inspected for visible evidence of defect. a. Temperature: 25+/- 3℃ b. Relative Humidity: 45 to 75%RH c. Measuring equipment and fixture: 0603(0201) HP 4287+16196C 1005(0402) HP 4287+16193A 1608(0603) HP 4291+16192A a. Temperature: 25+/- 3℃ b. Relative Humidity: 45 to 75%RH c. Measuring equipment and fixture: 0603(0201) HP 4287+16196C 1005(0402) HP 4287+16193A 1608(0603) HP 4291+16192A a. Temperature: 25+/- 3℃ b. Relative Humidity: 45 to 75%RH c. Measuring equipment: HP 4338 No harmful defect for piratical use. 2 Inductance 3 Q Value 4 DC Resistance 5 Dimension Dimension shall be measured with caliper or micrometer 6 Solder-ability Immerse a test sample into a methanol solution containing rosin and 90% of the termination is to immerse into SAC305(Sn96.5Ag3.0Cu0.5) solder of 245±5℃ for 3±1 be soldered evenly and continuously. seconds. Resistance to Soldering Heat Immerse a test sample into a methanol solution containing resin, preheat it at 150 to 180℃ for 2~3 minutes and immerse into molten solder of 260+/-5℃ for 10+/-1 second so that both terminal electrodes are completely submerged. After this test samples shall be taken out and measured after kept at room temperature for 2 to 3 hours. 7 Within specified tolerance. In accordance with electrical specification. In accordance with electrical specification. In accordance with dimension specification. No visible damage Remained terminal electrode : 70% min. Inductance variation within 30% Solder the chip to test jig then apply a force in the direction shown in below. The soldering shall be done with the reflow method and shall be conducted with care so that the soldering is uniform and free of defects such as heat shock. 4.5 b 20 50 Pressurizing speed : 1.0mm/sec. Pressurize 40 c 8 R230 Bending Strength No mechanical damage shall be observed. a 100 t :1.6mm(0.8mm for 0603&1005 size) Fig. a. Size 0603 1005 1608 a 0.3 0.4 1.0 b 0.9 1.5 3.0 Capacitance Meter 45 Flexure : 1mm 45 Fig. b. C 0.3 0.5 1.2 77 Rev. 201304 Inductors-MLCI (HI Series) No. Item Test Condition Requirements Solder a test sample to printed circuit board, and conduct 5 cycles of test under the conditions shown as below. 0603 &1005 operating temp. range: -55~125℃ 1608 operating temp. range: -40~85℃ 9 Thermal Shock Cycle: Maximum operating temp. /(30+/-3min) within 3min No visible damage Inductance variation within 10% Q variation within 20% Minimum operating temp. (30+/-3min) 10 11 12 13 High Humidity State Life Test Keep a test sample in an atmosphere with a temperature of 40±2 ℃, 90~95%RH for 500 +24/-0 hours. After the removal from test chamber, 2 to 3 hours of recovery under standard condition, and measurement shall be made after 24±2 hrs of recovery under standard condition. No visible damage. Inductance variation within 10%. Q variation within 20%. High Humidity Load Life Test Solder a test sample to printed circuit board then keep the test sample in an atmosphere with a temperature of 40±2℃, 90~95%RH for 500+24/-0 hours while supplying the rated current. After the removal from test chamber, 2 to 3 hours of recovery under standard condition, and measurement shall be made after 24±2 hrs of recovery under standard condition. No visible damage. Inductance variation within 10%. Q variation within 20%. High Temperature State Life Test Keep a test sample in an atmosphere with a temperature of 85±2℃ for 500±12 hours. After the removal from test chamber, 2 to 3 hours of recovery under standard condition, and measurement shall be made after 24+/-2 hrs of recovery under standard condition. No visible damage. Inductance variation within 10%. Q variation within 20%. High Temperature Load Solder a test sample to printed circuit board then keep the test sample in an atmosphere with a temperature of 85±2 No visible damage. ℃ for 500±12 hours while supplying the rated current. Inductance variation within After the removal from test chamber, 2 to 3 hours of 10%. recovery under standard condition, and measurement Q variation within 20%. shall be made after 24±2 hrs of recovery under standard condition. 78 Rev. 201304 Inductors-MLCI Reflow Profile Chart (Reference)    Soldering Profile for SMT Process with Lead Free Solder Paste. The rate of preheat should not exceed 4℃/sec and a target of 2℃/sec is preferred. Ceramic chip components should be preheated to within 100 to 130 ℃ of the soldering. Soldering 240℃ to 260℃ 5 ~ 10 sec. 300 Temperature (℃) 250 Gradual Natural Cooling 200 Preheating 0 Time (sec.) over 1 min over 1 min Over 200℃,within 90sec    Soldering Profile for SMT Process with SnPb Solder Paste. The rate of preheat should not exceed 4℃/sec and a target of 2℃/sec is preferred. Ceramic chip components should be preheated to within 100 to 130 ℃ of the soldering. Soldering 220℃ to 230℃ 5 ~ 10 sec. 300 Temperature (℃) 250 200 Gradual Natural Cooling Preheating 0 Time (sec.) over 1 min over 1 min Over 200℃,within 40sec 79 Rev. 201304 Inductors-MLCI Packaging Specification  Paper Tape Product Size Code Symbol 1608(0603) (mm) 2012(0805) (mm) A 1.0 ±0.2 1.5 ±0.2 B 1.8 ±0.2 2.3 ±0.2 Insertion Pitch F 4.0 ±0.1 4.0 ±0.1 Tape Thickness T 1.1 max 0.8 max Chip cavity 80 Rev. 201304 Inductors-MLCI  Embossed Tape 4mm pitch tape P0 D0 P1 P2 K0 E T F A0 W B0 D1 T Direction of feed Top tape Symbol 2012 (0805) 2016 (0806) 2520 (1008) P1 PO P2 A0 B0 K0 W E F 4±0.1 4±0.1 2±0.05 1.55±0.2 2.3±0.2 1.3±0.1 8±0.3 1.75±0.1 3.5±0.05 1.5 (+0.1/-0.0) 0.3 max 4±0.1 4±0.1 2±0.05 1.8±0.1 2.2±0.1 1.3±0.1 8±0.3 1.75±0.1 3.5±0.05 1.5 (+0.1/-0.0) 0.3 max 4±0.1 4±0.1 2±0.05 2.3±0.1 2.8±0.1 1.4±0.1 8±0.3 1.75±0.1 3.5±0.05 1.5 (+0.1/-0.0) 0.3 max D0 T Unit: mm/(inch)  Reel Specifications Tape Width (mm) G (mm) T max.(mm) D (mm) 8 10.0±1.5 14.5 178±2.0 81 Rev. 201304 Inductors-Cautions  Peel Strength of Top Cover Tape The peel speed shall be about 300 mm/min. The peel strength of top cover tape shall be between 0.1 to 1.0N. Cautions ● Storage 1. The inductor shall be packaged in carrier tapes. 2. To keep storage place temperature from +5 to 35℃, humidity from 45 to 70% RH. 3. The storage atmosphere must be free of gas containing sulfur and chlorine. Also, avoid exposing the product to saline moisture. If the product is exposed to such atmospheres, the terminals will oxidize and solderability will be affected. 4. The solder ability is assured for 12 months from our final inspection date if the above storage condition is followed. ● Handling Inductor should be handled with care to avoid contamination or damage. The use of vacuum pick-up or plastic tweezers is recommended for manual placement. Tape and reeled packages are suitable for automatic pick and placement machine. 82 Rev. 201304
SPH40401R0NETG 价格&库存
很抱歉,暂时无法提供与“SPH40401R0NETG”相匹配的价格&库存,您可以联系我们找货
