RB521C30
RB521C30
Schottky Barrier Diode
http://www.willsemi.com
Features
100mA Average rectified forward current
Low forward voltage
Low leakage current
Small package SOD-923
SOD-923
Pin1
Applications
Pin2
Circuit
Low Current rectification
Absolute maximum ratings
Marking
Parameter
Symbol
Value
Unit
Reverse voltage (repetitive peak)
VRM
30
V
Reverse voltage (DC)
VR
30
V
IO
100
mA
IFSM
0.5
A
TJ
150
O
C
Operating temperature
Topr
-40 ~ 125
O
C
Storage temperature
Tstg
-40 ~ 150
O
C
Peak forward surge current (8.3ms single sine pluse)
Junction temperature
Electronics characteristics (TA=25oC)
Parameter
Symbol
Condition
Min.
Typ.
Max.
Unit
Reverse Voltage
VR
IR=100uA
30
Forward Voltage
VF
IF=10mA
0.35
V
IF=100mA
0.47
V
Reverse current
IR
VR=10V
6
uA
VR=30V
15
uA
Junction capacitance
CJ
VR=5V, F=1MHz
21
pF
Thermal Resistance
Rθ(JA)
Junction to Ambient
650
K/W
Order Informations
Device
RB521C30-2/TR
Package
Marking
Shipping
SOD-923
1* (1)
10000/Reel&Tape
Note 1:*= Month code(A~Z);1= Device code;
Will Semiconductor Ltd.
1
Jan, 2019 - Rev. 1.3
RB521C30
Typical characteristics (Ta=25oC, unless otherwise noted)
1000
o
150 C
o
Reverse Current(uA)
Forward Current(A)
0.1
o
125 C
o
65 C
o
85 C
0.01
o
25 C
o
0C
1E-3
o
-50 C
o
85 C
100
125 C
10
o
65 C
1
o
0C
o
25 C
0.1
o
-50 C
1E-4
0.0
0.1
0.2
0.3
0.4
0.5
0.6
0.01
5
10
Forward Voltage(V)
30
Reverse Voltage(V)
Forward voltage vs. Forward current
Reverse current vs. Reverse voltage
125
100
100
f=1MHz
75
Cj(pF)
Forward Current(mA)
15
10
50
25
50
75
100
125
1
150
o
Ambient temperature( C)
10
15
Reverse Voltage(V)
Forward current derating curve
Junction capacitance vs. Reverse voltage
Maximum Peak Surge
Forward Current-IFSM(A)
6
IFSM
T
4
2
Single Pluse Width-T(ms)
IFSM-T Characteristics
2
RB521C30
PACKAGE OUTLINE DIMENSIONS
SOD-923
E
A
E1
Ⅱ
b
D
Ⅰ
SIDE VIEW
TOP VIEW
c
θ
Ⅰ
Ⅱ
θ
SIDE VIEW
Symbol
Dimensions in Millimeters
Min.
Typ.
Max.
A
0.35
0.40
0.45
D
0.55
0.60
0.65
E
0.90
1.00
1.10
E1
0.70
0.80
0.90
b
0.15
0.30
c
0.20
7°Ref
θ
3
RB521C30
TAPE AND REEL INFORMATION
Reel Dimensions
RD
Reel Dimensions
Tape Dimensions
W
P1
Quadrant Assignments For PIN1 Orientation In Tape
Q1
Q2
Q1
Q2
Q3
Q4
Q3
Q4
RD
Reel Dimension
W
Overall width of the carrier tape
P1
Pitch between successive cavity centers
Pin1
Pin1 Quadrant
User Direction of Feed
7inch
13inch
1 8mm
12mm
16mm
2mm
4mm
8mm
Q1
Q2
Q3
4
Q4
很抱歉,暂时无法提供与“RB521C30-2/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.23468
- 20+0.21456
- 100+0.19445
- 500+0.17433
- 1000+0.16495
- 2000+0.15824
- 国内价格
- 1+0.40579
- 500+0.13475
- 5000+0.09086
- 10000+0.07400
