1206N470J101CT
1206N470J101CT
    WALSIN(华新科)
    陶瓷电容/独石电容 1206
1206N470J101CT 数据手册
Multilayer Ceramic Capacitors Approval Sheet MULTILAYER CERAMIC CAPACITORS General Purpose Series (4V to 100V) 0201 to 1812 Sizes NP0, X7R, X6S, X7S & X5R Dielectrics Halogen Free & RoHS Compliance *Contents in this sheet are subject to change without prior notice. Page 1 of 21 ASC_General Purpose Series Sep. 2022 Multilayer Ceramic Capacitors Approval Sheet 1. DESCRIPTION MLCC consists of a conducting material and electrodes. To manufacture a chip-type SMT and achieve miniaturization, high density and high efficiency, ceramic condensers are used. WTC’s MLCC is made by NP0, X7R, X6S and X5R dielectric material and which provides product with high electrical precision, stability and reliability. 2. FEATURES 3. APPLICATIONS a. b. c. a. b. c. d. A wide selection of sizes is available (0201 to 1812). High capacitance in given case size. Capacitor with lead-free termination (pure Tin). For general digital circuit. For power supply bypass capacitors. For consumer electronics. For telecommunication. 4. HOW TO ORDER 1206 Size Inch (mm) 0201 (0603) 0402 (1005) 0603 (1608) 0805 (2012) 1206 (3216) 1210 (3225) 1812 (4532) Page 2 of 21 B Dielectric N=NP0 (C0G) B=X7R X=X5R S=X6S A=X7S 104 K Capacitance Two significant digits followed by no. of zeros. And R is in place of decimal point. eg.: 0R5=0.5pF 1R0=1.0pF 4 104=10x10 =100nF Tolerance A=±0.05pF B=±0.1pF C=±0.25pF D=±0.5pF F=±1% G=±2% J=±5% K=±10% M=±20% Z=-20/+80% 500 Rated voltage Two significant digits followed by no. of zeros. And R is in place of decimal point. C Termination C=Cu/Ni/Sn T Packaging style T=7” reeled G=13” reeled 4R0=4 VDC 6R3=6.3 VDC 100=10 VDC 160=16 VDC 250=25 VDC 500=50 VDC 101=100 VDC ASC_General Purpose Series Sep. 2022 Multilayer Ceramic Capacitors Approval Sheet 5. EXTERNAL DIMENSIONS Outline Size Inch (mm) L (mm) W (mm) 01R5 (0402) 0.4±0.02 0.2±0.02 0.2±0.02 0.6±0.03 0.3±0.03 0.3±0.03 0.6±0.05#2 0.3±0.05#2 0.3±0.05#2 0.6±0.09#3 0.3±0.09#3 0.3±0.09#3 0201 (0603) 0402 (1005) 1.00±0.05 0.50±0.05 Soldering Method * MB (mm) V R 0.10±0.03 L R T (mm)/Symbol 0.15+0.1/-0.05 0.50±0.05 N R 0.50+0.02/-0.05 Q R 1.00±0.20 0.50±0.20 0.5±0.20 E R 1.60±0.10 0.80±0.10 0.80±0.07 S R/W 0.50±0.10 H R/W X R/W 0.50±0.10 H R/W 0.60±0.10 A R/W 0.80±0.10 B R/W 1.25±0.10 D R 0.85±0.10 T R/W 1.25±0.20 I R 0.80±0.10 B R/W 0.95±0.10 C R 1.25±0.10 D R 1.15±0.15 J R 1.60±0.20 G R T R/W P R 0.95±0.10 C R 0.85±0.10 T R 1.25±0.10 D R 1.60±0.20 G R 2.00±0.20 K R M R 1.25±0.10 D R 1.40±0.15 F R 1.60±0.20 G R 2.00±0.20 K R 1.25±0.10 D R 1.60±0.20 G R 2.00±0.20 K R 2.50±0.30 M R 2.80±0.30 U * R = Reflow soldering process ; W = Wave soldering process. ** For 1808/1812/1825_200V~4000V and safety certificated products. *** For 1206_≧1000V, 1808/1812_200V~4000V and safety certificated products. #1: For 0603/Cap≧10µF or 0603(≦ 6.3V)/Cap≧4.7µF or 0603(>10V)/Cap>1µF products. #2: For 0201/ 0.1uF < Cap < 0.68uF products, Excluding 0201X334~474(≦ 6.3V) & 0201X224(≦ 10V). #3: For 0201/Cap≧0.68µF products. #4: For 1210(100V)/Cap>1µF or 1210(250V)/Cap>0.47µF or 1210(400V~630V)/Cap>0.22µF. #5: For 1206(100V)/Cap≧1.2µF products. R L 0603 (1608) 1.60+0.15/-0.10 0.80+0.15/-0.10 0.80+0.15/-0.10 T 1.60±0.20#1 0.80±0.20#1 W MB MB Fig. 1 The outline of MLCC 2.00±0.15 1.25±0.10 0805 (2012) 2.00±0.20 3.20±0.15 1.25±0.20 1.60±0.15 1206 (3216) 3.20±0.20 1.60±0.20 2.50±0.20 1210 (3225) 3.20±0.40 2.50±0.30 2.50±0.30 3.20±0.60#4 2.50±0.50#4 4.50±0.40 1808 (4520) 2.03±0.25 (4.5+0.5/-0.3)** 4.50±0.40 3.20±0.30 1812 (4532) (4.5+0.5/-0.3)** 3.20±0.40 Page 3 of 21 ASC_General Purpose Series 0.25 +0.05/-0.10 0.40±0.15 0.8±0.20#1 0.85±0.10 3.20+0.30/-0.1 1.60+0.30/-0.10 1.60+0.30/-0.10 3.30+0.30/-0.1#5 3.20±0.30 0.15±0.05 2.50±0.50#4 0.50±0.20 0.60±0.20 (0.5±0.25)*** 0.75±0.25 0.75±0.25 (0.5±0.25)*** 0.75±0.25 (0.5±0.25)*** Sep. 2022 Multilayer Ceramic Capacitors Approval Sheet 6. GENERAL ELECTRICAL DATA Dielectric NP0 X7R Size Capacitance range* X5R X6S X7S 0201, 0402, 0603, 0805, 1206, 1210, 1812 0.1pF to 0.1µF 100pF to 47µF 100pF to 220µF 0.1µF to 100µF 0.1µF to 100µF J (±5%), K (±10%), M (±20%) K (±10%), M (±20%) K (±10%), M (±20%) K (±10%), M (±20%) #1 Capacitance tolerance** Rated voltage (WVDC) Operating temperature Capacitance characteristic Termination Cap≤5pF : A (±0.05pF), B (±0.1pF), C (±0.25pF) 5pF0.47µF; X7R: ≦10% 1206≧2.2µF; 1210≧10µF 0603/475(6.3V) 35V ≦3.5% ≦10% 0603≧1µF; 0805≥2.2µF; 1206≧2.2µF; 1210≧10µF X5R: #1 ≦5% 0201≧0.01µF; 0805≧1µF; 1210≧10µF 0201≧ 224 (6.3V,10V,16V) , ≦7% 0603≧0.33µF 0402≧ 475 (6.3V,16V), 0402≧ 225(10V), 25V ≦3.5% 0201≧0.1µF; 0402≧0.056µF; 0603≧0.47µF; 0603=106 (6.3V) ≦10% 0805≧2.2µF; 1206≧4.7µF; 1210≧22µF TT18X≧ 475(10V) , TT15X series ≦12.5% 0402≧0.47µF X6S: 0201≧0.01µF; 0402≧0.033µF; 0603≧0.15µF; ≦5% 0201/474(4V),0201>104 (6.3V,10V), 0805≧0.68µF; 1206≧2.2µF; 1210≧4.7µF 16V ≦ 3.5% 0402≧ 225 (6.3V), 0201/X7R≧0.022µF; 0402≧0.22uF; ≦10% 0402/475 (10V), 0603/106 (6.3V), 0603>0.47µF; 0805≧2.2µF; 1206≧4.7µF; 1210≧22µF 0201≧0.012µF; 0402≧0.22µF; X7S: ≦10% 0603≧0.33µF; 0805≧2.2µF; 1206≧2.2µF; 1210≧22µF 10V ≦5% 0402/225(6.3V) ≦15% 0201≧0.1µF; 0402≧1µF #1 Excluding X5R/0201/105(6.3V);225(10V) , 0402X475M6R3 (1.0±0.2Vrms,1KHz±10%) 6.3V ≦10% 4V ≦15% ≦15% ≦20% --- 0201≧0.1µF; 0402≧1µF; 0603≧10µF; 0805≧4.7µF; 1206≧47µF; 1210≧100µF 0402≧2.2µF --- X5R: Rated D.F.≦ Exception of D.F. ≦ *Before initial measurement (Class II only): vol. To apply de-aging at 150°C for 1hr then set ≦3% 1206≧0.47µF for 24±2 hrs at room temp. ≧100V ≦2.5% ≦5% 0603≧0.068µF; 0805>0.1µF; 1206≧1µF; 1210≧2.2µF ≦10% 0805>0.22µF; 1210≧3.3µF ≦3% 0201(50V); 0603≧0.047µF; 0805≧0.18µF; 1206≧0.47µF ≦5% 0201≧0.01uF; 1210≧3.3µF 50V ≦2.5% ≦10% 0402≧0.012µF; 0603>0.1µF; 0805≧1µF;1206≧2.2µF; 1210≧10µF ≦12.5% 1206=10µF 35V ≦3.5% ≦10% 0603≧1µF; 0805≥2.2µF; 1206≧2.2µF; 1210≧10µF ≦5% 0201=0.01µF; 0805≧1µF ≦7% 0603≧0.33µF 25V ≦3.5% 0201>0.01µF; 0402≧0.10µF; 0603≧0.47µF; ≦10% 0805≧2.2µF; 1206≧4.7µF; 1210≧10µF ≦12.5% 0402≧0.47µF;0805=10µF 0201=0.01µF; 0402≧0.033µF; 0603≧0.15µF; 0805≧0.68µF; 1206≧2.2µF; 1210≧4.7µF 0201>0.01uF; 0402≧ 0.22uF; ≦3.5% ≦10% 0603>0.47µF; 0805≧2.2µF; 1206≧4.7µF; 1210≧22µF ≦12.5% 0402≧1µF;0805=10µF 0201≧0.012µF; 0402≧0.22µF; ≦10% 0603≧0.33µF; 0805≧2.2µF; 1206≧2.2µF; 1210≧22µF; 01R5/X5R ≦5% ≦12.5% 0805=10µF ≦15% 0201>0.1µF; 0402≧1µF; 0603≧10µF 0201>0.1µF; 0402≧1µF; 0603≧10µF; ≦15% 0805≧4.7µF; 1206≧47µF; 1210≧100µF ≦10% ≦20% 0402≧2.2µF ≦15% ----- ≦5% 16V 10V 6.3V 4V * "Room condition" Temperature: 15 to 35°C, Relativ e humidity: 25 to 75%, Atmospheric pressure: 86 to 106kPa. Page 12 of 21 ASC_General Purpose Series Sep. 2022 Multilayer Ceramic Capacitors No. Item Approval Sheet Test Condition Requirements X6S: Rated D.F.≦ vol. Q/ D.F. (Dissipation Exception of D.F. ≦ ≦3% ≧100V ≦2.5% ≦5% ≦10% ≦3% ≦5% 50V ≦2.5% ≦10% Factor) 35V 25V 16V 10V 6.3V 4V 1206≧0.47µF 0603≧0.068µF;0805>0.1µF;1206≧1µF;1210≧2.2µF 0805>0.22µF;1210≧3.3µF 0201(50V); 0603≧0.047µF; 0805≧0.18µF;1206≧0.47µF 0201≧0.01uF;1210≧3.3µF 0402≧0.012µF;0603>0.1µF; 0805≧1µF; 1206≧2.2µF;1210≧10µF ≦3.5% ≦10% 0603≧1µF;0805≥2.2µF;1206≧2.2µF;1210≧10µF ≦5% 0201≧0.01µF;0805≧1µF;1210≧10µF ≦7% 0603≧0.33µF ≦3.5% 0201≧0.1µF; 0402≧0.10µF;0603≧0.47µF; ≦10% 0805≧2.2µF; 1206≧4.7µF;1210≧22µF ≦12.5% 0402≧0.47µF;0805=10µF 0201≧0.01µF;0402≧0.033µF;0603≧0.15µF; ≦5% 0805≧0.68µF;1206≧2.2µF;1210≧4.7µF 0201≧0.1uF; 0402≧0.22uF; ≦3.5% ≦10% 0603>0.47µF; 0805≧2.2µF;1206≧4.7µF;1210≧22µF ≦12.5% 0402=1µF;0805=10µF 0201≧0.012µF;0402≧0.22µF; ≦10% 0603≧0.33µF; 0805≧2.2µF;1206≧2.2µF;1210≧22µF ≦5% ≦12.5% 0805=10µF ≦15% 0201≧0.1µF; 0402≧1µF 0201≧0.1µF;0402≧0.47µF; 0603≧10µF; ≦15% 0805≧4.7µF;1206≧47µF; 1210≧100µF ≦10% ≦20% 0402≧2.2µF ≦15% ----- X7S: Rated D.F.≦ vol. Exception of D.F. ≦ ≦3% ≧100V ≦2.5% ≦5% ≦10% ≦3% ≦5% 50V ≦2.5% ≦10% 35V 25V 16V 10V 6.3V 4V 4. Dielectric Strength * To apply voltage (≤100V) 250%. * Duration: 1 to 5 sec. * Charge and discharge current less than 50mA. 1206≧0.47µF 0603≧0.068µF;0805>0.1µF;1206≧1µF;1210≧2.2µF 0805>0.22µF;1210≧3.3µF 0201(50V); 0603≧0.047µF; 0805≧0.18µF;1206≧0.47µF 0201≧0.01uF; 1210≧3.3µF 0402≧0.012µF;0603>0.1µF; 0805≧1µF; 1206≧2.2µF;1210≧10µF ≦3.5% ≦10% 0603≧1µF;0805≥2.2µF;1206≧2.2µF;1210≧10µF ≦5% 0201≧0.01µF;0805≧1µF;1210≧10µF ≦7% 0603≧0.33µF ≦3.5% 0201≧0.1µF;0402≧0.10µF;0603≧0.47µF; ≦10% 0805≧2.2µF; 1206≧4.7µF;1210≧22µF ≦12.5% 0402≧0.47µF 0201≧0.01µF;0402≧0.033µF;0603≧0.15µF; ≦5% 0805≧0.68µF;1206≧2.2µF;1210≧4.7µF ≦3.5% 0201≧0.1uF; 0402≧ 0.22uF; ≦10% 0603>0.47µF;0805≧2.2µF;1206≧4.7µF; 1210≧22µF 0201≧0.012µF;0402≧0.22µF; ≦10% 0603≧0.33µF; 0805≧2.2µF;1206≧2.2µF;1210≧22µF ≦5% ≦15% 0201≧0.1µF; 0402≧1µF 0201≧0.1µF;0402≧1µF;0603≧10µF; ≦15% 0805≧4.7µF; 1206≧47µF; 1210≧100µF ≦10% ≦20% 0402≧2.2µF ≦15% ----- * No evidence of damage or flash over during test. * "Room condition" Temperature: 15 to 35°C, Relativ e humidity: 25 to 75%, Atmospheric pressure: 86 to 106kPa. Page 13 of 21 ASC_General Purpose Series Sep. 2022 Multilayer Ceramic Capacitors Approval Sheet No Item Test Condition Requirements . 5. Insulation Resistance *Test temp.: Room Temperature. 10GΩ or RxC≧ 500Ω-F whichever is smaller. *To apply rated voltage for MAX. 120sec. Class II (X7R, X7E, X5R,X6S,X7S) Rated voltage Insulation Resistance 100V: All X7R 50V:0402>0.01µF;0603≥1µF;0805≥1µF;1206≥4.7µF;1210≥4.7µF 35V:0805≥2.2µF;1206≧ 2.2µF;1210≧10µF 25V:0402≥1µF;0603≥2.2µF;0805≥2.2µF;1206≥10µF;1210≥10µF 16V: 0201≥0.1µF,0402≥0.22µF;0603≥1µF; 0805≥2.2µF;1206≥10µF;1210≥47µF 10GΩ or RxC≧100 Ω-F whichever is smaller. 10V:0201≥47nF;0402≥0.47µF;0603≥0.47µF;0805≥2.2µF; 1206≥4.7µF;1210≥47µF 6.3V ; 4V ; Size≥1812 Rated voltage Insulation Resistance All X6S items, All X7S items 100V: 1210≥3.3µF 50V: 0402≥0.1µF; 0603≥2.2µF; 0805≥10µF;1206≥10µF 35V: 0603≥1µF; 25V: 0201≥0.1µF; 0402≥2.2µF;0603≥10µF; 0805≥10µF;1206≥22µF RxC≧50 Ω-F. 16V: 0603≥10µF; 0402≥1µF; 0201≥0.22µF 10V: 0201>0.1µF; 0402≥1µF; 0603≥10µF; 0805≥47µF 6.3V:0201≥0.1µF; 0402≥1µF; 0603>4.7µF; 0805≥47µF; 1206≥10µF 4V: 0603≥22µF; 0805≥47µF; 1206≥100µF 6. Temperature Coefficient With no electrical load. T.C. Operating Temp T.C. Capacitance Change NPO -55~125°C at 25°C NPO Within ±30ppm/°C X7R -55~125°C at 25°C X7S -55 ~ 125°C at 25°C X7R Within ±15% X7S Within ±22% X5R -55~ 85°C at 25°C X5R X6S -55~105°C at 25°C *Before initial measurement (Class II only): X6S To apply de-aging at 150°C for 1hr then set for 24±2 hrs at room temp. * Measurement voltage for Class II: 01005 Cap≤0.01µF: 0.5V Cap>0.01µF: 0.2V *0201X104/6.3V~25V: 0.5V 0201X224&474/10V: 0.5V 0402 Cap0.01µF;0603≥1µF;0805≥1µF;1206≥4.7µF;1210≥4.7µF 35V:0603≥1µF;0805≥2.2µF; 1206≧ 2.2µF;1210≧10µF 25V:0201≧0.1uF; 0402≥0.22µF; 0603≥2.2µF;0805≥2.2µF; 1206≥10µF;1210≥10µF 16V: 0201≧ 0.1uF;0402≥0.22µF;0603≥1µF;0805≥2.2µF; 1206≥10µF;1210≥47µF 10V:0201≥47nF;0402≥0.47µF;0603≥0.47µF;0805≥2.2µF; 1206≥4.7µF;1210≥47µF 6.3V ; 4V ; All X6S/X7S items; Size≥1812 1GΩ or RxC≧10 Ω-F whichever is smaller. * "Room condition" Temperature: 15 to 35°C, Relativ e humidity: 25 to 75%, Atmospheric pressure: 86 to 106kPa. Page 16 of 21 ASC_General Purpose Series Sep. 2022 Multilayer Ceramic Capacitors No 14 Item Humidity (Damp Heat) Load Approval Sheet Test Condition Requirements *Test temp.:40±2°C *Humidity:90~95%RH *Test time:500+24/-0 hrs. *To apply voltage: Rated voltage (MAX. 500V) *Before initial measurement (Class II only): To apply de-aging at 150°C for 1hr then set for 24±2 hrs at room temp. * Cap. / DF(Q) / I.R. Measurement to be made after de-aging at 150°C for 1hr then set for 24±2 hrs at room temp. * No remarkable damage. Cap change: NP0: ±7.5% or 0.75pF whichever is larger. X7R, X5R, X6S, X7S: ≥10V**,within ±12.5%; ≦6.3V within ±25%; **10V: 0603≧4.7µF;0402≧ 1µF;0201≧0.1µF, within ±25%; Q/D.F. value: NP0: C≥30pF,Q≥200;C0.1µF;0805≧1µF(0805/X7R>0.47µF); 1206≧2.2µF;1210≧10µF; 0603≧1µF;0805≥2.2µF;1206≧2.2µF;1210≧10µF 0201≧0.01µF(0201/X5R=0.01µF);0805≧1µF;1210≧10µF* 0603≧0.33µF 0201≧0.1µF(0201/X5R>0.01µF); 0603≧0.47µF;TTseries 0402≧0.10µF(0402/X7R≧0.056µF);0805≧2.2µF; 1206≧4.7µF;1210≧22µF(1210/X5R≧10µF)*; 0402≧0.47µF 0603≧0.15µF;0805≧0.68µF;1206≧2.2µF;1210≧4.7µF 0201≧0.01µF(0201/X7R≧0.022µF);0402≧0.033µF; 0603>0.47µF;0805≧2.2µF;1206≧4.7µF;1210≧22µF 16V ≦5% 10V ≦7.5% 6.3V ≦15% ≦30% 0201≧0.1µF;0402≧1µF(0402/X6S≧0.47µF); 0603≧10µF;0805≧4.7µF;1206≧47µF;1210≧100µF 4V ≦20% --- --- ≦15% ≦15% 0201≧0.012µF;0402≧0.22µF; 0603≧0.33µF;0805≧2.2µF;1206≧2.2µF;1210≧22µF ≦20% 0201≧0.1µF;0402≧1µF;0603/X5R≧10µF;01R5/X5R *I.R.: ≥10V, 500MΩ or 25 Ω-F whichever is smaller. Class II (X7R, X5R, X6S, X7S) Rated voltage Insulation Resistance 100V: All X7R;1210≥3.3µF 50V: 0402>0.01µF;0603≥1µF;0805≥1µF;1206≥4.7µF;1210≥4.7µF 35V:0603≥1µF;0805≥2.2µF; 1206≧ 2.2µF;1210≧10µF 25V:0201≧0.1uF; 0402≥0.22µF; 0603≥2.2µF;0805≥2.2µF; 1206≥10µF;1210≥10µF 16V: 0201≧ 0.1uF;0402≥0.22µF;0603≥1µF;0805≥2.2µF; 1206≥10µF;1210≥47µF 500MΩ or RxC≧5 Ω-F whichever is smaller. 10V:0201≥47nF;0402≥0.47µF;0603≥0.47µF;0805≥2.2µF; 1206≥4.7µF;1210≥47µF 6.3V ; 4V ; All X6S/X7S items; Size≥1812 * "Room condition" Temperature: 15 to 35°C, Relativ e humidity: 25 to 75%, Atmospheric pressure: 86 to 106kPa. Page 17 of 21 ASC_General Purpose Series Sep. 2022 Multilayer Ceramic Capacitors No 15. Item Approval Sheet Test Condition High Temperature *Test temp.: NP0, X7R/X7E/X7S: 125±3°C Load X6S: 105±3°C (Endurance) X5R: 85±3°C *Test time: 1000+24/-0 hrs. *To apply voltage: (1) 100% of rated voltage for below range. Rated Capacitance Size Dielectric voltage range ≦10V C≧ 0.1µF X5R/X7R/ 0201 ≧16V C >0.1µF X6S/X7S ≦16V C >1.0µF X5R 25V,50V C≧1.0µF 6.3V,10V 0402 C >1.0µF X6S 16V,25V C≧1.0µF X7R/X7S 6.3V,10V C≧1.0µF 4V C≧22µF X5R/X7R/ X6S/X7S 6.3V,10V C≧4.7µF 0603 25V C≧1.0µF X5R/X6S/X7S X7R 35V C≧1.0µF 4V C≧47µF X5R/X7R/ 6.3V C≧22µF X6S/X7S 10V,50V C≧10µF 16V C >10µF 0805 X6S 25V C≧10µF X7R/X7S C≧10µF 16V,25V C≧22µF X5R C≧47µF 1206 X5R/X7R/X6S ≦6.3V 16V C≧47µF X5R/X7R/X6S 1210 100V C≧3.3µF X7R 6.3V C >1.0µF TT15 X5R TT21 X5R/X7R/X6S ≦10V C≧10µF **1WV items must follow de-rating conditions. (2) 150% of rated voltage for below range. Rated Size Dielectric Capacitance voltage 16V,25V C=0.1µF X5R/X6S 0201 16V C≧0.022µF X7R 50V C>0.01µF X7R/X5R/ 0402 X6S 10~25V C≧0.22µF 50V~100V C>0.22µF X7S 50V C>0.1µF X7R 25V C=1.0µF 0603 50V C≧1.0µF X5R X5R/X7R/ 10V,16V C≧1.0µF X6S/X7S 100V C≧0.47µF 50V C≧0.68µF X5R/X7R/ 0805 X6S/X7S 35V C≧2.2µF 10~25V C≧4.7µF 100V C≧1.0µF X7R 50V C≧2.2µF 1206 100V C>1.0µF X5R/X6S/ X7S 50V C=4.7µF X5R/X7R/ 50V~100V C≧2.2µF 1210 X6S/X7S 1825 2220 100V~250V C≧1.0µF X7R 2225 (3) ≤ 6.3V or C ≥10µF :150% of rated voltage. (4) 10V ≤ Ur < 250V: 200% of rated voltage. (5) 500V: 150% of rated voltage. (6) Ur ≥ 630V: 120% of rated voltage * Before initial measurement (Class II only): To apply de-aging at 150°C for 1hr then set for 24±2 hrs at room temp. * Cap. / DF(Q) / I.R. Measurement to be made after de-aging at 150°C for 1hr then set for 24±2 hrs at room temp. ** De-rating conditions: Requirements * No remarkable damage. Cap change: NP0: ±3.0% or ±0.3pF whichever is larger X7R, X5R, X6S, X7S: ≥10V**,within ±12.5%; ≤ 6.3V within ±25%; **10V: 0603≥4.7µF;0402≥1µF;0201≥0.1µF, within ±25% Q/D.F. value: NP0: More than 30pF, Q≥350 10pF≤C0.1µF;0805≧1µF(0805/X7R>0.47µF); 1206≧2.2µF;1210≧10µF; ≦20% 0603≧1µF;0805≥2.2µF;1206≧2.2µF;1210≧10µF ≦10% 0201≧0.01µF(0201/X5R=0.01µF);0805≧1µF;1210≧10µF* ≦14% 0603≧0.33µF 0201≧0.1µF(0201/X5R>0.01µF); 0603≧0.47µF;TTseries ≦15% 0402≧0.10µF(0402/X7R≧0.056µF);0805≧2.2µF; 1206≧4.7µF;1210≧22µF(1210/X5R≧10µF)*; ≦20% 0402≧0.47µF ≦10% 0603≧0.15µF;0805≧0.68µF;1206≧2.2µF;1210≧4.7µF 16V ≦5% 10V ≦7.5% 6.3V ≦15% ≦30% 0201≧0.1µF;0402≧1µF(0402/X6S≧0.47µF); 0603≧10µF;0805≧4.7µF;1206≧47µF;1210≧100µF 4V ≦20% --- --- ≦15% 0201≧0.01µF(0201/X7R≧0.022µF);0402≧0.033µF; 0603>0.47µF;0805≧2.2µF;1206≧4.7µF;1210≧22µF ≦15% 0201≧0.012µF;0402≧0.22µF; 0603≧0.33µF;0805≧2.2µF;1206≧2.2µF;1210≧22µF ≦20% 0201≧0.1µF;0402≧1µF;0603/X5R≧10µF;01R5/X5R *I.R.: ≥10V, 1GΩ or 50 Ω-F whichever is smaller. Class II (X7R, X5R, X6S, X7S) Insulation Resistance Rated voltage 100V: All X7R;1210≥3.3µF 50V: 0402>0.01µF;0603≥1µF;0805≥1µF;1206≥4.7µF;1210≥4.7µF 35V:0603≥1µF;0805≥2.2µF; 1206≧ 2.2µF;1210≧10µF 25V:0201≧0.1uF; 0402≥0.22µF; 0603≥2.2µF;0805≥2.2µF; 1206≥10µF;1210≥10µF 16V: 0201≧ 0.1uF;0402≥0.22µF;0603≥1µF;0805≥2.2µF; 1206≥10µF;1210≥47µF 1GΩ or RxC≧ 10 Ω-F whichever is smaller. 10V:0201≥47nF;0402≥0.47µF;0603≥0.47µF;0805≥2.2µF; 1206≥4.7µF;1210≥47µF 6.3V ; 4V ; All X6S/X7S items; Size≥1812 * "Room condition" Temperature: 15 to 35°C, Relativ e humidity: 25 to 75%, Atmospheric pressure: 86 to 106kPa. Page 18 of 21 ASC_General Purpose Series Sep. 2022 Multilayer Ceramic Capacitors Approval Sheet APPENDIXES ◙ Tape & reel dimensions Fig. 2 The dimension of paper tape Fig. 3 The dimension of plastic tape Size 0201 0402 0603 0805 1206 Thickness L N,E S,H,X A,H B,T A0 B0 0.40 +/-0.10 0.70 +/-0.10 0.70 +/-0.20 1.20 +/-0.20 1.05 +/-0.30 1.80 +/-0.30 1.50 +/-0.20 2.30 +/-0.20 1.50 +/-0.20 2.30 +/-0.20 T ≦0.55 ≦0.80 ≦1.20 ≦1.15 ≦1.20 0.23 +/-0.1 D,I < 1.80 < 2.70 B,T 1.90 +/-0.50 3.50 +/-0.50 1210 T C,D G,K 1808 M D,F G,K 1812 C,J,D G,P < 2.00
1206N470J101CT
物料型号:文档中没有明确列出具体的物料型号,但提到了多种尺寸和电压等级的多层陶瓷电容器(MLCC)。
器件简介:多层陶瓷电容器(MLCC)由导电材料和电极组成,用于实现表面贴装技术和小型化、高密度和高效率。WTC的MLCC采用NP0、X7R、X6S和X5R介质材料制造,提供高电气精度、稳定性和可靠性。
引脚分配:文档中没有提供具体的引脚分配图,但是提到了MLCC的尺寸范围从0201到1812。
参数特性: - 多种尺寸选择(0201至1812)。 - 在给定的封装尺寸下具有高电容值。 - 无铅端子(纯锡)的电容器。
功能详解: - 适用于一般数字电路。 - 用作电源旁路电容器。 - 用于消费电子产品。 - 用于电信领域。
应用信息:MLCC广泛应用于数字电路、电源旁路、消费电子和电信等领域。
封装信息:提供了不同尺寸的MLCC的外部尺寸信息,包括长度、宽度、厚度和标记符号,以及焊接方法。
1206N470J101CT 价格&库存
很抱歉,暂时无法提供与“1206N470J101CT”相匹配的价格&库存,您可以联系我们找货
1206N470J101CT
    1206N470J101CT
    • 1+1.92846
    • 10+1.08401
    • 50+0.71077
    • 100+0.60106
    • 500+0.42282
    • 1000+0.37108
    • 2000+0.32880
    • 4000+0.29634
    • 20000+0.29394
    库存:5038
    1206N470J101CT
      • 20+0.21006
      • 200+0.17615
      • 600+0.15725
      库存:1793
