S07M
S07M
    STARSEA(星海)
S07M 数据手册
S07A THRU S07M SURFACE MOUNT GENERAL PURPOSE SILICON RECTIFIER Reverse Voltage - 50 to 1000 Volts Forward Current - 0.7 Ampere SOD-123FL FEATURES Glass passivated device Ideal for surface mouted applications Low reverse leakage Metallurgically bonded construction High temperature soldering guaranteed: 260 C/10 seconds,0.375”(9.5mm) lead length, 5 lbs. (2.3kg) tension MECHANICAL DATA Case: SOD-123FL molded plastic body over passivated chip Terminals: Solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight:0.0007 ounce, 0.02 grams Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. SYMBOLS Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TL =130 C (NOTE 1) Peak forward surge current 8.3ms single half sine-wave superimposed on rated load Maximum instantaneous forward voltage at 1.0A Maximum DC reverse current TA=25 C at rated DC blocking voltage TA=125 C Typical junction capacitance (NOTE 2) Typical thermal resistance (NOTE 3) Operating junction and storage temperature range VRRM VRMS VDC S07A S07B S07D S07G S07J S07K S07M SA SB SD SG SJ SK SM 50 35 50 100 70 100 200 140 200 400 280 400 600 420 600 800 560 800 1000 700 1000 UNITS V V V I(AV) 0.7 A IFSM 25.0 A VF 1.1 V IR 10.0 50.0 µA CJ RθJA TJ,TSTG 4 95 -55 to +150 pF C/W C Note: 1.Averaged over any 20ms period. 2.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3.PCB mounted on 0.2*0.2" (5.0*5.0mm) coppeer pad area. STAR SEA DN:S09B01A0 RATINGS AND CHARACTERISTIC CURVES S07A THRU S07M FIG.2 -- TYPICAL JUNCTION CAPACITANCE 10 TJ = 150°C m AMPERES TJ = 25°C TJ = 100°C 8 7 6 5 4 3 2 1 100 600 700 800 900 1000 0 1100 INSTANTANEOUS FORWARD VOLTAGE,mV TJ = 150°C 10 TJ = 125°C TJ = 100°C 1 TJ = 75°C TJ = 50°C 0.1 TJ = 25°C 0.01 0 100 200 300 400 500 600 700 800 900 INSTANTANEOUS REVERSE VOLTAGE,V 5 10 15 20 25 30 35 40 FIG.4 -- FORWARD DERATING CURVE AVERAGE FORWARD CURRENT, AMPERES 100 0 REVERSE VOLTAGE,VOLTS FIG.3 -- TYPICAL INSTANTANEOUS REVERSE CHARACTERISTICS DN:S09B01A0 9 CAPACITANCE, pF 1000 µ AMPERES INSTANTANEOUS REVERSE CURRENT INSTANTANEOUS FORWARD CURRENT FIG.1 --TYPICAL FORWARD CHARACTERISTIC 1.2 Resistive or Inductive Load 1.0 0.8 0.6 0.4 0.2 3.0 x 3.0mm 40 µm Thick Copper Pad Areas 0 0 20 40 60 80 100 120 140 160 AMBIENT TEMPERATURE, STAR SEA
很抱歉,暂时无法提供与“S07M”相匹配的价格&库存,您可以联系我们找货
