B4B-XH-A-R(LF)(SN)
B4B-XH-A-R(LF)(SN)
    JST
    插件,P=2.5mm
    线对板针座 1x4P 直插 间距:2.5mm
B4B-XH-A-R(LF)(SN) 数据手册
XH CONNECTOR Emboss Emboss Tape Tape Radial Radial Tape Tape 2.5 mm pitch/Disconnectable Crimp style connectors 5 JS Specifications 1 XH CONNECTOR • Current rating: 3 A AC/DC (AWG #22) • Voltage rating: 250 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 1,000 VAC/minute • Applicable wire: AWG #30 to #22 • Applicable PC board thickness: 1.6 mm T The XH connector was developed based on the high reliability and versatility of our NH series connectors. The connector is very small with a mounting height of 9.8 mm. ● ● ● ● ● Original folded beam contact Box-shaped shrouded header Header with a boss Interchangeability Conforming to the HA terminal ® * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. ® ® Standards Recognized E60389 J50014297 ® ® PC board layout and Assembly layout 〈Through-hole type (viewed from soldening side)〉 Top entry type 5.75 Side entry type 2.5 ±0.05 (2.5 min.) 3.4 min. 2.5 min. 2.5 ±0.05 1.6 4.35 +0.2 +0.1 7 φ1.1 0 φ0.9  0 6.1 5.75 ±0.05 ±0.05 +0.1 φ1.7  0 (9.2 min.) 7 (9.8) (14.3) ±0.05 2 circuits:φ1 +0.1 3 circuits or more:φ0.9 0 (9.8) Top entry type with a boss +0.1 φ0.9  0 2 ±0.05 2 circuits :φ1±0.05 +0.1 3 circuits or more:φ0.9 0 (2.5 min.) 11.5 (3.4 min.) 2.5 ±0.05 Note: 1  . Tolerances are non-cumulative: ± 0.05 mm for all centers. 2. Hole dimensions differ according to the type of PC board and piercing method. If PC boards made of hard material are used, the hole dimensions should be larger. The dimensions above should serve as a guideline. Contact JST for details. End face of wafer on the mating side 1 2.5 1.3 0.2 3.9 6.5 11 〈SMT type (viewed from connector mounting side)〉 Side entry type 2.3 1.8 Note: 1  . Tolerances are non-cumulative: ± 0.05 mm for all centers. 2. The dimensions above should serve as a guideline. Contact JST for details. XH CONNECTOR XHコネクタ表1 Contact ● Shape A Shape SXH-001T-P0.6N SXH-001T-P0.6 SXH-002T-P0.6 2 1.95 1.6 1.8 Model No. ● Shape B A B Applicable Wire AWG# mm2 Insulation O.D (mm) Q’ty/ reel 5,000 0.13~0.33 26~22 1.3~1.9 0.08~0.33 28~22 0.9~1.9 0.05~0.13 30~26 0.9~1.3 8,000 XH CONNECTOR 2.4 2.35 Material and Finish Phosphor bronze, tin-plated (reflow treatment) 6.5 6.5 RoHS2 compliance Note: 1. Contact JST if you require gold-plated contacts or contacts made of brass. 2. Contact JST also if you require shielded wires, thin wires or other special wires. 3. SXH-001T-P0.6N is low-insertion force type contact, for easier insertion/ withdrawal, which would be less resistant to the vibration. Crimping machine Crimp applicator Contact SXH-001T-P0.6N SXH-001T-P0.6 AP-K2N MKS-L SXH-002T-P0.6 Applicator Dies Crimp applicator with dies MK/SXH-001-06N APLMK SXH001-06N MK/SXH-001-06 APLMK SXH001-06 MK/SXH-002-06 APLMK SXH002-06 XHコネクタ表2 Note: Contact JST for fully automatic crimping applicator. Housing No. of circuits 7.75 1 2 2 4.1 5.7 3 4 5 6 Circuit No.1 mark A B C 6 2.5 7 8 9 10 ● Plugged up 11 12 13 7.75 14 15 16 20 4.1 5.7 Model No. XHP-1 XHP-2 XHP-2(10.0)-U XHP-3 XHP-4 XHP-5 XHP-6 XHP-6(5.0)-U XHP-7 XHP-8 XHP-9 XHP-10 XHP-11 XHP-12 XHP-13 XHP-14 XHP-15 XHP-16 XHP-20 Q’ty/ bag 3.2 4.8 1,000 2.5 5.7 7.3 1,000 10.0 13.2 14.8 1,000 5.0 8.2 9.8 1,000 7.5 10.7 12.3 1,000 10.0 13.2 14.8 1,000 12.5 15.7 17.3 1,000 25.0 28.2 29.8 1,000 15.0 18.2 19.8 1,000 17.5 20.7 22.3 1,000 20.0 23.2 24.8 1,000 22.5 25.7 27.3 1,000 25.0 28.2 29.8 1,000 27.5 30.7 32.3 1,000 30.0 33.2 34.8 1,000 32.5 35.7 37.3 1,000 35.0 38.2 39.8 1,000 37.5 40.7 42.3 1,000 47.5 50.7 52.3 500 RoHS2 compliance Note: 1. XHP-2(10.0)-U is 2 circuits 10.0 mm pitch plugged up. Unlisted in UL/TÜV. 2. XHP-6(5.0)-U is 6 circuits 5.0 mm pitch plugged up. Unlisted in UL/TÜV. 7.75 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 4.1 5.7 Circuit No.1 mark B C PA 6, UL94V-0, natural (white) A B C C - Dimensions (mm) B Material and Finish Circuit No.1 mark A A ex. XHP-1-oo- (blank)...natural (white) BK...black R...red E...blue Y...yellow L...lemon yellow M...green D...orange N...brown FY...vivid yellow ex. XHP-2(10.0)-U-oo(blank)...natural (white) R...red E...blue 2 XH CONNECTOR XHコネクタ表3 Through-hole type shrouded header The shrouded headers are interchangeable with those of the NR and NRD insulation displacement connectors, and JQ board-to-board connectors. Top entry type No. of circuits Top entry type 2 B2B-XH-A 2 B2(10.0)B-XH-A-U 3 B3B-XH-A 4 B4B-XH-A 5 B5B-XH-A 6 B6B-XH-A 7 B7B-XH-A 8 B8B-XH-A 9 B9B-XH-A 10 B10B-XH-A 11 B11B-XH-A 12 B12B-XH-A 13 B13B-XH-A 14 B14B-XH-A 15 B15B-XH-A 16 B16B-XH-A 20 B20B-XH-A □0.64 3.4 7 ● plugged up 2.45 A (2.35) B 5.75 Top entry type □0.64 3.4 3.4 7 7 □0.64 (2.35) A B A 2.45 RoHS2 compliance This product displays (LF)(SN) on a label. Note: B2(10.0)B-XH-A-U is 2 circuits 10.0mm pitch plugged up. Unlisted in UL/TÜV. □0.64 2.5 A B Post: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 66, UL94V-0, natural (white) 5.75 7 11.5 2.45 Material and Finish (2.35) B 5.75 Side entry type 2.5 (6.1) 3.4 S( )B-XH-A-1: 7.6 S( )B-XH-A: 9.2 2.45 Model No. Q’ty/box Dimensions (mm) Side entry type Top entry type Side entry type A B 1,000 1,000 7.4 2.5 S2B-XH-A-1 S2B-XH-A 1,000 14.9 10.0 1,000 9.9 1,000 5.0 S3B-XH-A-1 S3B-XH-A 500 12.4 500 7.5 S4B-XH-A-1 S4B-XH-A 500 14.9 500 10.0 S5B-XH-A-1 S5B-XH-A 500 17.4 500 12.5 S6B-XH-A-1 S6B-XH-A 500 19.9 250 15.0 S7B-XH-A-1 S7B-XH-A 250 22.4 250 17.5 S8B-XH-A-1 S8B-XH-A 250 24.9 250 20.0 S9B-XH-A-1 S9B-XH-A 250 27.4 250 22.5 S10B-XH-A-1 S10B-XH-A 250 29.9 250 25.0 S11B-XH-A-1 S11B-XH-A 250 32.4 200 27.5 S12B-XH-A-1 S12B-XH-A 250 34.9 200 30.0 S13B-XH-A-1 S13B-XH-A 250 37.4 200 32.5 S14B-XH-A-1 S14B-XH-A 250 39.9 100 35.0 S15B-XH-A-1 S15B-XH-A 200 42.4 100 37.5 S16B-XH-A 100 52.4 47.5 - As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. S3B-XH-A(-1)-oo(blank)...natural (white) BK...black R...red E...blue Y...yellow L...lemon yellow M...green D...orange N...brown FY...vivid yellow Through-hole type shrouded header No. of circuits Top entry type of glass-filled nylon 0.64 2 □0.64 3 7 4 5 6 3.4 7 2.45 8 5.75 9 6.75 5.75 A B 6.75 10 11 12 7 13 14 3.4 15 2.5 6.75 ex. 7 □0.64 1,000 9.9 1,000 7.5 12.4 500 10.0 14.9 500 12.5 17.4 500 15.0 19.9 500 17.5 22.4 250 20.0 24.9 250 22.5 27.4 250 25.0 29.9 250 27.5 32.4 250 30.0 34.9 250 32.5 37.4 250 35.0 39.9 250 B2B-XH-2-oo(blank)...natural (ivory) C...black R...red E...blue Y...yellow M...green (0.96) A B 3 7.4 5.0 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 3.4 2.5 2.5 RoHS2 compliance This product displays (LF)(SN) on a label. 2.45 Q’ty/ bag (0.96) Post: Brass, copper-undercoated, tin-plated (reflow treatment) 5.75 Wafer: Glass-filled PA 66, UL94V-0, natural (ivory) 6.75 5.75 B B2B-XH-2 B3B-XH-2 B4B-XH-2 B5B-XH-2 B6B-XH-2 B7B-XH-2 B8B-XH-2 B9B-XH-2 B10B-XH-2 B11B-XH-2 B12B-XH-2 B13B-XH-2 B14B-XH-2 B15B-XH-2 Dimensions (mm) A B Material and Finish □0.64 A 2.45 Model No. 5.75 5.75 XH CONNECTOR Through-hole type shrouded header The shrouded headers are interchangeable with those of the NR and NRD insulation displacement connectors, and JQ board-to-board connectors. No. of circuits Top entry type with a boss □0.64 1 2 3 7 4 6 3.4 2.7 5 (2.35) 8 4.35 4.9 7 1.5 9 5.75 10 12 □0.64 Model No. A *B1B-XH-AM B2B-XH-AM B3B-XH-AM B4B-XH-AM B5B-XH-AM B6B-XH-AM B7B-XH-AM B8B-XH-AM B9B-XH-AM B10B-XH-AM B12B-XH-AM Dimensions (mm) B Q’ty/ box - 1,000 2.5 7.4 1,000 5.0 9.9 1,000 7.5 12.4 500 10.0 14.9 500 12.5 17.4 500 15.0 19.9 500 17.5 22.4 250 20.0 24.9 250 22.5 27.4 250 27.5 32.4 250 ̶ Material and Finish 3.4 1.5 7 Post: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 66, UL94V-0, natural (white) 2.45 φ1 (2.35) 1.6 A RoHS2 compliance This product displays (LF)(SN) on a label. Note: *Marked product is not UL/TÜV approved. B As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 2 5.75 ex. B1B-XH-AM-oo- 7 (blank)...natural (white) BK...black R...red E...blue Y...yellow L...lemon yellow M...green 3.4 1.5 XHコネクタSMT表-4 □0.64 2.5 φ1 1.6 A 2.45 (2.35) 2 5.75 B SMT type shrouded header □0.64 No. of circuits Model No. 3 4 6 Dimensions (mm) A B Q’ty/ reel S3B-XH-SM4-TB 5.0 12.5 500 S4B-XH-SM4-TB 7.5 15.0 500 S6B-XH-SM4-TB 12.5 20.0 500 5.5 Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 6T, UL94V-0, natural (ivory) Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment) 2.5 RoHS2 compliance This product displays (LF)(SN) on a label. Note: The products listed above are supplied on embossed-tape. A B 7 (3) As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. 6 3.75 S3B-XH-SM4-oo-TB(blank)...natural (ivory) M...green R...red E...blue L...lemon yellow 4 XH CONNECTOR Through-hole type shrouded header on radial-tape TV4 type 2-TV4 type 2-TV4 type B B A 2.5 6.75 A 2.45 2.5 No. of circuits 2 3 4 5 6 7 8 Model TV4 B3B-XH-TV4 B4B-XH-TV4 - 2.45 2.5 6.75 No. 2-TV4 B2B-XH-2-TV4 B3B-XH-2-TV4 B4B-XH-2-TV4 B5B-XH-2-TV4 B6B-XH-2-TV4 B7B-XH-2-TV4 B8B-XH-2-TV4 Dimensions (mm) A B Q’ty/box - 1,000 5.0 9.9 1,000 7.5 12.4 500 10.0 14.9 500 12.5 17.4 500 15.0 19.9 500 17.5 22.4 500 - 7 φ0.7) (  □0.64 □0.64 2.8 φ0.7) (  2.8 □0.64 6.75 7 7 2.45 7.4 φ0.7) (  RoHS2 compliance This product displays (LF)(SN) on a label. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. B2B-XH-2-TV4-oo(blank)...natural (TV4 type/white, 2-TV4 type/ivory) C...black (glass-filled) BK...black R...red E...blue Y...yellow M...green Material and Finish Post: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: TV4 type/ PA 66, UL94V-0, natural (white) 2-TV4 type/ Glass-filled PA 66, UL94V-0, natural (ivory) Taping specification Packaging specifications D 2 and 3 circuits :12.7 4 to 8 circuits :25.4 6.75 H TERMIN ALS & CONN ECTORS R 18 9 6 20 W Distance between the end of the tape and the first connector's center line (either end) Tail tape Leader tape φ4 2 circuits: 5.1 3 to 8 circuits: 3.85 2 circuits: 2.5 3 to 8 circuits: 5 12.7 Note: Conforms to JIC C 0806 of "Tape packaging of components with unidirectional leads on continuous tapes". Package type Distance between folds Box size Distance between the end of the tape and the first connector’s center line (either end) 2, 3 circuits Quantity 4~8 circuits 5 Flat pack (zigzag folded) 24 indexing holes per fold (304.8 mm) 316(W)×45(D)×330(H) mm 19.05 mm 1,000 pcs./box 500 pcs./box Note: Products of different packaging specifications are also available. Contact JST for details.
B4B-XH-A-R(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“B4B-XH-A-R(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
B4B-XH-A-R(LF)(SN)
  • 5+0.62565
  • 50+0.50490
  • 150+0.44453
  • 500+0.33938
  • 2500+0.30855
  • 5000+0.29321
库存:9042
